  4. iob node fix - Skript
    apollon77A
198 Beiträge 34 Kommentatoren 80.6k Aufrufe 37 Beobachtet
  • M mrjeschke
    Hier noch die Version mit einer ganz frischen Installation.
    Habe ich Gestern nicht mehr geschafft, da ich Nachtschicht hatte.
    ioBroker nodejs fixer 2023-09-07
    Recommended nodejs-version is: 18.17.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v20.6.0
    /usr/bin/node           v20.6.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    I found these nodejs versions available for installation:
    nodejs:
      Installed: 20.6.0-1nodesource1
      Candidate: 20.6.0-1nodesource1
      Version table:
     *** 20.6.0-1nodesource1 500
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.5.1-1nodesource1 500
         20.5.0-1nodesource1 500
         20.4.0-1nodesource1 500
         20.3.1-1nodesource1 500
         20.3.0-1nodesource1 500
         20.2.0-1nodesource1 500
         20.1.0-1nodesource1 500
         20.0.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    Nothing to do, your installation is using the correct paths.
    You are running nodejs v20.6.0. Do you want to install recommended version 18.17.1?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    lxc
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    ca-certificates is already the newest version (20230311).
    curl is already the newest version (7.88.1-10+deb12u1).
    gnupg is already the newest version (2.2.40-1.1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    *** Creating new /etc/apt/sources.list.d/nodesource.list
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    *** These repos are active after the adjustments:
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
    Fetched 17.3 kB in 1s (27.3 kB/s)
    Installing the recommended nodejs version now!
    The following packages will be DOWNGRADED:
      nodejs
    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
    Need to get 29.4 MB of archives.
    After this operation, 5746 kB disk space will be freed.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
    Fetched 29.4 MB in 1s (31.3 MB/s)
    dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
    (Reading database ... 37784 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
    Setting up nodejs (18.17.1-1nodesource1) ...
    Processing triggers for man-db (2.11.2-2) ...
    nodejs is already the newest version (18.17.1-1nodesource1).
    Calculating upgrade... Done
    *** You need to manually restart your container now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    maik@iobtest2:~$
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #77
    Vielen Dank für das Beta-Testing!
    Habe jetzt gestern noch ein pinning auf das nodesoure-Repo gelegt, das muss aber nicht getestet werden.
    PR gegen den ioBroker ist gestellt. Mal schauen wie schnell das im upstream landet.
      M
      M
      MCU
      #78
      @thomas-braun Wenn irgendwann die empfohlene Version die 20 wäre, dann brauch ich nur
      NODE_MAJOR=20
      zu setzen und lasse dann
      iob_node_update
      laufen?
      • M MCU
        NODE_MAJOR=20
        iob_node_update
        laufen?
        Thomas BraunT
        Thomas BraunT
        #79
        @mcu
        Ja.
        Das muss dann natürlich, wenn das Skript in den iob Installer integriert wurde dann auch dort zentral einmal geändert werden.
        Oder ich schau mal ob man das nicht aus der Installer Library auslesen kann. Dann wäre es nur einmal dort zu ändern.
        Irgendwie/wo muss die recommended version ja auch dort drin sein.
        Edith: In meinem ähnlich gelagerten PR zum Installer wird das natürlich auch mit einer Variablen gesetzt, im alten war ja der Link zum obsoleten nodejs-Installerskript drin.
        Edit2: Wobei die Varible NODE_MAJOR auch nur dann als 'FallBack' zum tragen kommt, wenn aus den iob-States nichts ausgelesen werden kann.
        G 1 Antwort Letzte Antwort
          @mcu
          Ja.
          G
          G
          guitardoc
          #80
          @thomas-braun Kurze Frage dazu: wenn man gleichzeitig noch die Homebridge auf dem System hat, dann hat man zwei Installationen von Node drauf - Homebridge installiert Node in abweichenden Pfaden. Das können sogar unterschiedliche Versionen sein, es funktioniert trotzdem beides - ioB und Homebridge - einwandfrei. Kann der Node fixer das berücksichtigen, damit die Homebridge Installation nicht zerschossen wird oder interessiert das den Fixer gar nicht dass da noch eine zweite Installation drauf ist?
          • G guitardoc
            Thomas BraunT
            Thomas BraunT
            #81
            @guitardoc
            Der Fixer haut alles weg, was nicht in den Installationspfaden des nodesource-Paketes, aber im $PATH liegt.
            Wo liegt denn die Installation der Homebridge?
            Hab ich mangels Homebridge nicht getestet.
            Edit:
            Hab gerade mal geschaut. Deren nodejs wohnt in
            Node Path /opt/homebridge/bin/node
            Das dürfte vom iob-Skript nicht tangiert werden, liegt es doch nicht im Standard $PATH. Außer sie verändern die Einträge dort.
            Kannst es ja testen ...
              @guitardoc
              Edit:
              G
              G
              guitardoc
              schrieb am zuletzt editiert von guitardoc
              #82
              Die Installation der Homebridge liegt hier:
              Node.js und NPM sind unter /opt/homebridge/bin/ zu finden (und deshalb auch nur für Homebridge sichtbar und nutzbar).
              Edith: Posts haben sich überschnitten…
              • G guitardoc
                Thomas BraunT
                Thomas BraunT
                #83
                @guitardoc
                Dann gibt es da kein Problem.
                • G guitardoc
                  Thomas BraunT
                  Thomas BraunT
                  #84
                  @guitardoc
                  Wie schaut es denn aus, wenn du das Skript aufrufst?
                  • haselchenH
                    haselchenH
                    haselchen
                    #85
                    Das Skript unterstützt ja kein Docker/Container, also , wer auf die aktuelle 18.18.0 updaten möchte, kann das über diese Anleitung machen.
                    Installation Instructions
                    Node.js
                    If you have root access, you can omit the 'sudo' command as you already have full administrative privileges.
                    1. Download and import the Nodesource GPG key
                    sudo apt-get update
                    sudo apt-get install -y ca-certificates curl gnupg
                    sudo mkdir -p /etc/apt/keyrings
                    curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                    1. Create deb repository
                    NODE_MAJOR=18
                    echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
                    1. Run Update and Install
                    sudo apt-get update
                    sudo apt-get install nodejs -y
                    Mein Ergebnis:
                    • Marc BergM
                      Marc BergM
                      Marc Berg
                      #86
                      @haselchen sagte in iob node fix - Skript:
                      ... was aber nur notwendig ist, wenn man nicht das offizielle (Buanet-)Image nutzt.
                      F 1 Antwort Letzte Antwort
                      • haselchenH
                        haselchenH
                        haselchen
                        #87
                        @marc-berg
                        Korrekt.
                        Spreche da logischerweise nur für mich.
                        Ich hole mir nicht jedesmal nen neuen Container, wenn mal Node aktualisiert wird oder der JS Controller.
                        Das geht auch , soweit ich das praktiziere, in ein und dem gleichen Container.
                        Aus dem Gedächtnis heraus, musste ich , glaube ich, 1mal ein neues Container Image benutzen.
                        Ansonsten ist das jetzt hier seit ein paar Jahren der 2. Iobroker Container und läuft alles aktuell.
                        • haselchenH haselchen
                          @marc-berg
                          Korrekt.
                          Marc BergM
                          Marc BergM
                          Marc Berg
                          #88
                          Jedem nach seinem Gusto, ich finde es aber falsch solche Tipps zu verbreiten. Wohin das manuelle Rumgefrickel an Node führt, können wir hier täglich mehrfach "bewundern". Du magst das im Griff haben, viele andere nicht.
                          Wenn man Docker korrekt eingerichtet hat, ist es eine Sache von zwei Mausklicks oder drei Befehlen auf der Kommandozeile und man hat ein aktuelles Image mit allen Abhängigkeiten. So zumindest das Konzept hinter Docker, wie ich es verstanden habe.
                          • Marc BergM Marc Berg
                            F
                            F
                            fastfoot
                            #89
                            @marc-berg sagte in iob node fix - Skript:
                            wollte ich eig. genau so schreiben, aber das image(von heute Nacht) hat immer noch 18.17.1. Ich weiss dass André das umgestellt hat, evtl. geht da was beim deploy schief
                            • F fastfoot
                              Marc BergM
                              Marc BergM
                              Marc Berg
                              #90
                              @fastfoot sagte in iob node fix - Skript:
                              Das sind aber zwei verschiedene paar Schuhe, wie ich finde. @haselchen sprach von einem Upgrade auf eine neue Major Version.
                              Unabhängig davon kann man ja mit einem "apt update && apt upgrade" die Minor Version hochziehen, ohne viel kaputt machen zu können.
                              haselchenH F 2 Antworten Letzte Antwort
                                haselchenH
                                haselchenH
                                haselchen
                                #91
                                @marc-berg
                                Die Anleitung bezog sich auf Node 18.
                                Da man mit dem normalen update&upgrade von 18.17 nicht auf 18.18 mehr kommt.
                                Natürlich kann man bei MAJOR_NODE auch 20 eingeben, dann wird die Version auf 20 angehoben.
                                Mir ging es aber um die 18.18.0
                                Aber wie Du schon geschrieben hast, jeder nach seinem Gusto.
                                  F
                                  F
                                  fastfoot
                                  #92
                                  @marc-berg jaein, da das repo im image nicht umgestellt ist würde es auch keine Minor updates mehr geben. Irgendwo hatte André geschrieben dass er das repo umgestellt hat, aber das ist nicht der Fall. Vlt. soll das aber auch erst für die nächste Version gelten. @andre ?
                                  Marc BergM andreA 2 Antworten Letzte Antwort
                                  • F fastfoot
                                    Marc BergM
                                    Marc BergM
                                    Marc Berg
                                    #93
                                    Ah, okay. Dann sollte aber, wie du schreibst, an der Quelle angepackt und nicht Symptome behandelt werden.
                                      F
                                      F
                                      fastfoot
                                      #94
                                      voll deiner Meinung, das ist wohl auch der Grund warum das node-fix/update Skript(cooles Tool!) die Docker Container nicht unterstützt. Mal sehen ob André sich noch zu Wort meldet, sonst mach ich ein issue auf
                                      • F fastfoot
                                        Thomas BraunT
                                        Thomas BraunT
                                        #95
                                        Ich mach ja einen Bogen um die Dinger und mir ist immer gesagt worden, das macht man nicht so (klassisch per Paketmanager), man holt sich eine frische Tupperdose und gut ist. Deswegen auch keine Unterstützung über das Skript.
                                          F
                                          F
                                          fastfoot
                                          #96
                                          @thomas-braun naja, für klassische Containeranwendungen mag das richtig sein, aber der iobroker ist halt keine solche klassische Anwendung. Dennoch finde ich den Ausschluss ok weil das Image regelmässig neu gebaut wird und einem so auch keine Neuerungen entgehen.
                                          84.0k
