  4. js-controller 5.0.x jetzt für alle User im STABLE!
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.3k Aufrufe 65 Beobachtet
  • W Wildbill
    Nachdem ich gestern auf die aktuelle stable-Version des js-controller upgedated habe, habe ich wohl heute Nacht auch ein Problem gehabt, als backitup in Aktion trat. Hier der Auszug aus dem Log:
    2023-09-18 02:28:01.759 - error: host.iobroker-vm Caught by controller[0]: <--- Last few GCs --->
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[0]: [851:0x6322e80] 31928930 ms: Mark-sweep (reduce) 1749.7 (2083.9) -> 1749.7 (2083.9) MB, 120.0 / 0.0 ms (average mu = 0.698, current mu = 0.039) last resort; GC in old space requested
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[0]: [851:0x6322e80] 31929052 ms: Mark-sweep (reduce) 1749.7 (2083.9) -> 1749.7 (2083.9) MB, 121.9 / 0.0 ms (average mu = 0.537, current mu = 0.001) last resort; GC in old space requested
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[0]: <--- JS stacktrace --->
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[1]: 1: 0xb83f50 node::Abort() [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[2]: 2: 0xa94834 [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[3]: 3: 0xd647c0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[4]: 4: 0xd64b67 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[5]: 5: 0xf3039f v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[6]: 6: 0xf10760 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[7]: 7: 0xf081d4 v8::internal::FactoryBase::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[8]: 8: 0xf0a568 v8::internal::FactoryBase::NewRawTwoByteString(int, v8::internal::AllocationType) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[9]: 9: 0x11e7bb5 v8::internal::String::SlowFlatten(v8::internal::Isolate*, v8::internal::Handle, v8::internal::AllocationType) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[10]: 10: 0xd711a4 v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[11]: 11: 0xc6cd7a node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local, node::encoding) [io.backitup.0]
    2023-09-18 02:28:01.760 - error: host.iobroker-vm Caught by controller[12]: 12: 0xc64e4e node::StreamBase::Writev(v8::FunctionCallbackInfo const&) [io.backitup.0]
    2023-09-18 02:28:01.761 - error: host.iobroker-vm Caught by controller[13]: 13: 0xc68795 void node::StreamBase::JSMethod<&node::StreamBase::Writev>(v8::FunctionCallbackInfo const&) [io.backitup.0]
    2023-09-18 02:28:01.761 - error: host.iobroker-vm Caught by controller[14]: 14: 0xdc28b0 [io.backitup.0]
    2023-09-18 02:28:01.761 - error: host.iobroker-vm Caught by controller[15]: 15: 0xdc3def v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.backitup.0]
    2023-09-18 02:28:01.761 - error: host.iobroker-vm Caught by controller[16]: 16: 0x17036b9 [io.backitup.0]
    2023-09-18 02:28:01.761 - warn: host.iobroker-vm instance system.adapter.backitup.0 terminated due to SIGABRT
    2023-09-18 02:28:01.761 - info: host.iobroker-vm instance system.adapter.backitup.0 terminated with code null ()
    2023-09-18 02:28:01.761 - info: host.iobroker-vm Restart adapter system.adapter.backitup.0 because enabled
    2023-09-18 02:28:31.861 - info: host.iobroker-vm instance system.adapter.backitup.0 started with pid 10181
    2023-09-18 02:28:33.185 - info: backitup.0 (10181) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
    2023-09-18 02:28:33.350 - info: backitup.0 (10181) [iobroker] backup will be activated at 02:27 every 1 day(s)
    2023-09-18 02:28:33.393 - info: backitup.0 (10181) [ccu] backup will be activated at 01:37 every 3 day(s)
    Backitup startet immer um 2:27 Uhr mit dem iobroker-Backup. Ich habe iobroker als VM (Debian) unter Proxmox laufen und habe mir dann anheschaut, ob der Speicher ausging, aber dem scheint nicht so zu sein, man sieht nur eine kleine SPitze zu dem Zeitpunkt.
    Auch free -m zeigt mir, dass der Speicher ausreichen sollte, zudem wurde der SWAP auch nicht angerührt:
                 gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
    Speicher:       7944        4263        2819           0         862        3428
    Swap:            974           0         974
    Im Forum gibt es einige alte Threads, dass da wohl nodejs selbst ein Problem hat und irgendwie zu wenig Speicher zugewiesen wird, aber nichts, wo steht, mach das und dann passt es. Da ich vorher über Monate nie Probleme hatte, scheint wohl mit dem js-controller 5 irgendein Zusammenhang zu bestehen. Hat jemand eine Idee, wo ich schauen bzw. ansetzen kann?
    Restliche Adapter sind alle auf aktuellem stable-Stand bzw. einige wenige aus latest. Update gestern betraf den js-controller, web-Adapter, ws-Adapter und, ich meine, VIS.
    Gruss, Jürgen
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #130
    @wildbill welche node.js Version ist denn installiert? @ilovegym hat die Probleme nur mit einer bestimmten Version.
    Videotutorials & mehr
    • W Online
      W Online
      Wildbill
      #131
      @foxriver76 node.js ist 18.17.1 und npm 9.6.7. Ich meine auch, da einen Zusammenhang mit dem Sonos-Adapter zu finden. Ich hatte eben noch manuell ein Backup versucht und dabei im Log vom Adapter eine Meldung zu cover_png und danach 100en Hieroglyphen gehabt, analog, wie es
      @oFbEQnpoLKKl6mbY5e13 oben im Log hatte.
      Diese Meldung hatte ich auch gestern gleich mal, inklusive der 100e unentzifferbare Zeichen, als ich den js-controller upgedatet hatte und dann iobroker wieder hoch fuhr.
      Gruss, Jürgen
      O 1 Antwort Letzte Antwort
      • KobiK Offline
        KobiK Offline
        Kobi
        schrieb am zuletzt editiert von Kobi
        #132
        @foxriver76 Update vom js-controller 4.0.24 nach 5.0.12 führt zum Systemcrash beim Start von Sicherung im backitup Adapter (2.6.23).
        Während dem erwähnten Systemcrash lässt sich keine Verbindung zum Host via CLI herstellen, sodass danach keine Diagnose mittels [iob diag] mehr möglich ist und nur noch ein System Neustart Abhilfe schafft. Nach der Betätigung des Buttons <IOBROKER BACKUP STARTEN> sieht man im LOG-Fenster von backitup am Anfang noch lesbare Zeichen, danach werden nur noch Hieroglyphen dargestellt, bis schlussendlich der Admin Adapter abstürzt und nichts mehr funktioniert. Interessant ist die angezeigte Fehlermeldung:
        Parsing error on getStates("io.sonos.0.root.10_0_0_62.cover_png), returning "null" for "?PNG
        Mit der ursprünglichen js-controller Version 4.0.24 und den exakt gleichen verwendeten Versionsständen aller verwendeten Systemkomponenten funktioniert die Sicherung im backitup Adapter problemlos.
        Diagnose mit installiertem js-controller 4.0.24:
        iob_diag_js-controller 4_0_24.txt
        Diagnose mit installiertem js-controller 5.0.12:
        iob_diag_js-controller 5_0_12.txt
        Es stellt sich für mich die Frage, ob es allenfalls am SONOS Adapter liegen kann, welcher ich installiert habe und seit Jahren mehr oder weniger problemlos nutze?
        DuffyD 1 Antwort Letzte Antwort
        • W Wildbill
          Gruss, Jürgen
          O Offline
          O Offline
          #133
          @wildbill @foxriver76
          Ich habe gestern den Sonos-Adapter deinstalliert. Das Backup ist die Nacht einwandfrei gelaufen.
          @ilovegym
          Nutzt du den Sonos-Adapter?
          W FredFF ? 3 Antworten Letzte Antwort
          • O oFbEQnpoLKKl6mbY5e13
            @ilovegym
            W Online
            W Online
            Wildbill
            schrieb am zuletzt editiert von Wildbill
            #134
            @ofbeqnpolkkl6mby5e13 Wäre dann wohl eine Lösung, aber ist ja nicht Sinn der Sache. Ich könnte auch gut und gerne auf die Anzeige des Plattencovers im Sonos-Adapter verzichten, aber die restliche Funktionalität wäre schon gut zu haben. 😊
            Gruss, Jürgen
            EDIT: Die Frage wäre jetzt. Ist es ein Bug des Sonos-Adapters oder des js-controller? Je nachdem würde ich es da als issue aufmachen.
            • W Wildbill
              Gruss, Jürgen
              O Offline
              O Offline
              #135
              @wildbill
              Ich habe ihn auch aus weiteren Gründen deinstalliert. Ich bin diesen Adapter einfach leid. Er stürzt immer mal wieder ab, mit JS-Controller 5 verursacht er eine Meldung des Web-Adapters (Binary States) und er wird letztlich seit Jahren nicht mehr gepflegt. Ich nutze zur Steuerung sowieso die HTTP-API.
              • KobiK Kobi
                DuffyD Online
                DuffyD Online
                Duffy
                #136
                @kobi
                Ich habe bei meinem Testpi nun einmal den Sonos Adapter installiert und dann ein Backup mit dem Backitup Adapter gemacht.
                Es lief anstandslos durch.
                Pi mit Bookworm
                Sonos Adapter 2.5.3
                Leider fehlt mir der Mut den js-controller auf meinem Aktivsystem zu aktualisieren :-(
                Aber vielleicht kann mein Beitrag trotzdem zur Fehlerfindung beitragen.
                Started iobroker ...
                [DEBUG] [iobroker] - host.Testpi 659 states saved
                [DEBUG] [iobroker] - host.Testpi 866 objects saved
                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_18-12_11_15_Testpi_backupiobroker.tar.gz
                [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                [DEBUG] [iobroker] - done
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-1 is started ...
                [DEBUG] [influxDB] - Start InfluxDB Backup ...
                [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-1 is finish
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-2 is started ...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-12_11_39_influxDB-2_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-12_11_39_influxDB-2_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-12_11_39_influxDB-2_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-2 is finish
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-3 is started ...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-12_11_39_influxDB-3_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-12_11_39_influxDB-3_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-12_11_39_influxDB-3_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-3 is finish
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-4 is started ...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-12_11_40_influxDB-4_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-12_11_40_influxDB-4_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-12_11_40_influxDB-4_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for influxDB-4 is finish
                [DEBUG] [influxDB] - done
                [DEBUG] [zigbee] - found zigbee database: zigbee.0
                [DEBUG] [zigbee] - done
                [DEBUG] [onedrive] - Onedrive: Copy iobroker_2023_09_18-12_11_15_Testpi_backupiobroker.tar.gz...
                [DEBUG] [onedrive] - 47% uploaded from iobroker_2023_09_18-12_11_15_Testpi_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 94% uploaded from iobroker_2023_09_18-12_11_15_Testpi_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 100% uploaded from iobroker_2023_09_18-12_11_15_Testpi_backupiobroker.tar.gz
                [DEBUG] [onedrive] - iobroker_2023_09_18-12_11_15_Testpi_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1160 saved on Onedrive
                [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz...
                [DEBUG] [onedrive] - 2% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 5% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 7% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 10% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 12% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 14% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 17% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 19% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 22% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 24% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 26% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 29% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 31% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 34% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 36% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 38% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 41% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 43% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 46% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 48% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 50% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 53% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 55% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 58% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 60% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 62% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 65% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 67% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 70% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 72% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 74% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 77% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 79% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 82% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 84% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 86% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 89% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 91% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 94% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 96% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 98% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz
                [DEBUG] [onedrive] - influxDB_2023_09_18-12_11_20_influxDB-1_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1161 saved on Onedrive
                [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-12_11_39_influxDB-2_backupiobroker.tar.gz...
                [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-12_11_39_influxDB-2_backupiobroker.tar.gz
                [DEBUG] [onedrive] - influxDB_2023_09_18-12_11_39_influxDB-2_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1162 saved on Onedrive
                [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-12_11_39_influxDB-3_backupiobroker.tar.gz...
                [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-12_11_39_influxDB-3_backupiobroker.tar.gz
                [DEBUG] [onedrive] - influxDB_2023_09_18-12_11_39_influxDB-3_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1163 saved on Onedrive
                [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-12_11_40_influxDB-4_backupiobroker.tar.gz...
                [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-12_11_40_influxDB-4_backupiobroker.tar.gz
                [DEBUG] [onedrive] - influxDB_2023_09_18-12_11_40_influxDB-4_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1164 saved on Onedrive
                [DEBUG] [onedrive] - Onedrive: Copy zigbee.0_2023_09_18-12_11_41_Testpi_backupiobroker.tar.gz...
                [DEBUG] [onedrive] - 100% uploaded from zigbee.0_2023_09_18-12_11_41_Testpi_backupiobroker.tar.gz
                [DEBUG] [onedrive] - zigbee.0_2023_09_18-12_11_41_Testpi_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1165 saved on Onedrive
                [DEBUG] [onedrive] - done
                [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                [DEBUG] [clean] - done
                [DEBUG] [historyHTML] - new history html values created
                [DEBUG] [historyHTML] - done
                [DEBUG] [historyJSON] - new history json values created
                [DEBUG] [historyJSON] - done
                [EXIT] 0
                VG Duffy
                Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                Node.js: v22.23.2
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
                KobiK 1 Antwort Letzte Antwort
                  @ilovegym
                  FredFF Online
                  FredFF Online
                  FredF
                  Most Active Forum Testing
                  #137
                  @ofbeqnpolkkl6mby5e13 @Wildbill @foxriver76
                  In meinem Aktivsystem habe ich den Sonos Adapter in Benutzung.
                  Das update des js-controllers habe ich am Freitag gemacht und das geplante Backup gestern lief ohne Fehler im Log durch.
                  Node.js: v18.17.1
                  NPM: 9.6.7
                    @ilovegym
                    #138
                    @ofbeqnpolkkl6mby5e13 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                    @ilovegym
                    Hi, nein den nutze ich nicht.
                    Vom Bauchgefühl her tippe ich auf eine Änderung in Node 18.17.1, denn mit Node 18.17.0 läuft alles..
                    Ich habe 68 Adapter und 47000 States und 44000 Objekte, waren mal über 120000.. aber daran lag es nicht.
                    Mein lxc hat 32gb Ram und 8 Cores mit debian Bookworm, beim Betrieb sind meist 10-11 Gb Ram belegt, wobei linux ja einiges reserviert..
                    Ich habe auch schon mit den Einstellungen im js-Controller beim Ram experimtiert, das brachte aber eher mehr Fehler..
                    Wenn ich in ein paar Wochen wieder zurück bin, nehm ich mir das Problem mal genauer vor..
                    zur Zeit muss das alles so bleiben, läuft auch ohne Probleme stable durch..
                      @wildbill
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #139
                      Hast du diesbezüglich ein issue beim Adapter eröffnet?
                      Binary States sind allerdings nur eine deprecation WARNUNG da diese mit js-controller 5 noch unterstütz werden,
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                        @ilovegym
                        O Offline
                        O Offline
                        #140
                        Dann wissen wir jetzt wohl nur eine Sache sicher:
                        1. Hat nichts mit dem Sonos-Adapter zu tun
                          #141
                          1. doch gerade mit der 18.17.1 hab ich den Fehler
                          O 2 Antworten Letzte Antwort
                          • mcm1957M mcm1957
                            O Offline
                            O Offline
                            #142
                            @mcm57
                            Es gibt bereits ein Issue dafür, welches von @apollon77 mal erstellt wurde.
                            Beim Web-Adapter wurde das von mir erstellte Issue geschlossen, weil der Web-Adapter das vom Sonos-Adapter nur "durchreicht".
                              O Offline
                              O Offline
                              #143
                              @ilovegym
                              Ach so, missverstanden! Mist!
                                O Offline
                                O Offline
                                #144
                                @ilovegym
                                @FredF hat den Fehler mit node.js 18.17.1 nicht.
                                • DuffyD Duffy
                                  @kobi
                                  Pi mit Bookworm
                                  Sonos Adapter 2.5.3
                                  [EXIT] 0
                                  VG Duffy
                                  KobiK Offline
                                  KobiK Offline
                                  Kobi
                                  #145
                                  @duffy Danke für Dein aufschlussreiches Feedback. Bei den Unterschieden unserer Systemvoraussetzungen ist mir neben dem Pi mit Bookworm aufgefallen, dass Du gegenüber meiner eingesetzten SONOS-Version 2.3.1 die neuere Version 2.5.3 vom SONOS Adapter angegeben hast. Wo und wie komme ich zu der Version 2.5.3 vom SONOS-Adapter?
                                  Gerne würde ich einen Versuch mit dem backitup Adapter unter js-Controller 5.0.12, mit installiertem SONOS Adapter v 2.5.3 durchführen um zu testen, ob der backitup Adapter immer noch einen Systemcrash auslöst.
                                  mcm1957M DuffyD 2 Antworten Letzte Antwort
                                  • KobiK Kobi
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #146
                                    @kobi
                                    @Duffy
                                    Die aktuelle Version des sonos adapters (ioBroker.sonos) ist sowohl auf github als auch auf npm die 2.3.1. Hinweise auf eine 2.5.3 konnte ich nicht finden.
                                    • mcm1957M mcm1957
                                      @kobi
                                      @Duffy
                                      Marc BergM Online
                                      Marc BergM Online
                                      Marc Berg
                                      #147
                                      @mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                      da wird @Duffy wohl in der Zeile verrutscht sein und den Sonoff Adapter erwischt haben ...
                                      • KobiK Kobi
                                        DuffyD Online
                                        DuffyD Online
                                        Duffy
                                        schrieb am zuletzt editiert von Duffy
                                        #148
                                        @kobi
                                        Asche auf mein Haupt, Marc Berg hat recht.
                                        Ich bitte vielmals um Entschuldigung!
                                        Edit:
                                        Korrektur: Sonoff 2.5.3
                                        Node.js: v22.23.2
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          @kobi
                                          Edit:
                                          DuffyD Online
                                          DuffyD Online
                                          Duffy
                                          #149
                                          Jetzt habe ich aber wirklich SONOS 2.3.1 installiert und ein Backup gemacht.
                                          Es lief durch.
                                          [DEBUG] [iobroker] - host.Testpi 730 states saved
                                          [DEBUG] [iobroker] - host.Testpi 950 objects saved
                                          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_18-13_20_20_Testpi_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker" successfully deleted
                                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-2_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-2_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-2_backupiobroker" successfully deleted
                                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-3_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-3_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-3_backupiobroker" successfully deleted
                                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-4_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-4_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_18-13_20_45_influxDB-4_backupiobroker" successfully deleted
                                          [DEBUG] [onedrive] - Onedrive: Copy iobroker_2023_09_18-13_20_20_Testpi_backupiobroker.tar.gz...
                                          [DEBUG] [onedrive] - 47% uploaded from iobroker_2023_09_18-13_20_20_Testpi_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 94% uploaded from iobroker_2023_09_18-13_20_20_Testpi_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 100% uploaded from iobroker_2023_09_18-13_20_20_Testpi_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - iobroker_2023_09_18-13_20_20_Testpi_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1166 saved on Onedrive
                                          [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz...
                                          [DEBUG] [onedrive] - 2% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 5% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 7% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 10% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 12% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 14% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 17% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 19% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 22% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 24% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 26% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 29% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 31% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 34% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 36% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 38% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 41% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 43% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 46% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 48% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 50% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 53% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 55% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 58% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 60% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 62% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 65% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 67% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 70% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 72% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 74% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 77% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 79% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 82% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 84% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 86% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 89% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 91% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 94% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 96% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 98% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - influxDB_2023_09_18-13_20_26_influxDB-1_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1167 saved on Onedrive
                                          [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-13_20_45_influxDB-2_backupiobroker.tar.gz...
                                          [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-13_20_45_influxDB-2_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - influxDB_2023_09_18-13_20_45_influxDB-2_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1168 saved on Onedrive
                                          [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-13_20_45_influxDB-3_backupiobroker.tar.gz...
                                          [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-13_20_45_influxDB-3_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - influxDB_2023_09_18-13_20_45_influxDB-3_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1169 saved on Onedrive
                                          [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_09_18-13_20_45_influxDB-4_backupiobroker.tar.gz...
                                          [DEBUG] [onedrive] - 100% uploaded from influxDB_2023_09_18-13_20_45_influxDB-4_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - influxDB_2023_09_18-13_20_45_influxDB-4_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1170 saved on Onedrive
                                          [DEBUG] [onedrive] - Onedrive: Copy zigbee.0_2023_09_18-13_20_47_Testpi_backupiobroker.tar.gz...
                                          [DEBUG] [onedrive] - 100% uploaded from zigbee.0_2023_09_18-13_20_47_Testpi_backupiobroker.tar.gz
                                          [DEBUG] [onedrive] - zigbee.0_2023_09_18-13_20_47_Testpi_backupiobroker.tar.gz with Id: 265B81AA2EF75ADE!1171 saved on Onedrive
                                          [EXIT] 0
                                          Node.js: v22.23.2
                                          NPM: 10.9.4
                                          js-controller 7.1.2
                                          Linux: Trixie
                                          W 1 Antwort Letzte Antwort
