  4. iob node fix - Skript
198 Beiträge 34 Kommentatoren 82.5k Aufrufe 37 Beobachtet
    @mcu sagte in iob node fix - Skript:
    Nothing to do
    Hm. Der Codepart war einfach... ;-) Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
    M
    M
    mrjeschke
    nodejs 20 sieht bei mir im LXC-Container so aus.
    ioBroker nodejs fixer 2023-09-06
    Recommended nodejs-version is: 18.17.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/node           v20.5.1
    /usr/bin/npm            9.8.0
    /usr/bin/npx            9.8.0
    /usr/bin/corepack       0.19.0
    I found these nodejs versions available for installation:
    nodejs:
      Installed: 20.5.1-deb-1nodesource1
      Candidate: 20.5.1-deb-1nodesource1
      Version table:
     *** 20.5.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    Nothing to do, your installation is using the correct paths.
    You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    find: '/lost+found': Permission denied
    lxc
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:2 http://security.debian.org bookworm-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    ca-certificates is already the newest version (20230311).
    curl is already the newest version (7.88.1-10+deb12u1).
    gnupg is already the newest version (2.2.40-1.1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    *** Creating new /etc/apt/sources.list.d/nodesource.list
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    *** These repos are active after the adjustments:
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
    Fetched 17.3 kB in 0s (38.4 kB/s)
    Installing the recommended nodejs version now!
    ./iob_node_update: line 275: [: : integer expression expected
    Exact recommended version unknown, installing a fallback!
    The following packages will be DOWNGRADED:
      nodejs
    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
    Need to get 29.4 MB of archives.
    After this operation, 5249 kB disk space will be freed.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
    Fetched 29.4 MB in 2s (13.2 MB/s)
    dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
    (Reading database ... 37746 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
    Setting up nodejs (18.17.0-1nodesource1) ...
    Processing triggers for man-db (2.11.2-2) ...
    Updating fallback to latest nodejs v18 release
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Calculating upgrade... Done
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    After this operation, 7168 B of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
    Fetched 29.4 MB in 1s (43.5 MB/s)
    apt-listchanges: Reading changelogs...
    (Reading database ... 37813 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
    Setting up nodejs (18.17.1-1nodesource1) ...
    ./iob_node_update: line 300: [: : integer expression expected
    *** You need to manually restart your container now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    maik@iobtest:~$
      Nothing to do
      M
      M
      MCU
      @thomas-braun Frisch aufgesetzter LXC mit nodejs 16 ohne ioBroker.
      No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
      /usr/bin/nodejs         v16.20.2
      /usr/bin/node           v16.20.2
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      /usr/bin/corepack       0.17.0
      nodejs:
        Installed: 16.20.2-deb-1nodesource1
        Candidate: 16.20.2-deb-1nodesource1
        Version table:
       *** 16.20.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
      You are running nodejs v16.20.2. Do you want to install recommended version ?
      [sudo] password for prox:
      lxc
      ./iob_node_update: line 248: iob: command not found
      Hit:1 http://ftp.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org bullseye-security InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
      ca-certificates is already the newest version (20210119).
      curl is already the newest version (7.74.0-1.3+deb11u7).
      gnupg is already the newest version (2.2.27-2+deb11u2).
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Fetched 17.3 kB in 0s (57.5 kB/s)
        nodejs
      After this operation, 60.4 MB of additional disk space will be used.
      Fetched 29.4 MB in 1s (21.7 MB/s)
      (Reading database ... 22654 files and directories currently installed.)
      Unpacking nodejs (18.17.0-1nodesource1) over (16.20.2-deb-1nodesource1) ...
      Processing triggers for man-db (2.9.4-2) ...
        nodejs
      Fetched 29.4 MB in 1s (41.9 MB/s)
      (Reading database ... 25141 files and directories currently installed.)
      nodejs is already the newest version (18.17.1-1nodesource1).
      • M MCU
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        nodejs:
          Version table:
        lxc
          nodejs
          nodejs
        ohne ioBroker.
        dann kennt er natürlich (?) die empfohlene Version nicht
        @Thomas-Braun
        was tut er dann?
        M Thomas BraunT 2 Antworten Letzte Antwort
        • M mrjeschke
          /usr/bin/npm            9.8.0
          /usr/bin/npx            9.8.0
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          lxc
            nodejs
            nodejs
          maik@iobtest:~$
          Thomas BraunT
          Thomas BraunT
          Most Active Developer
          #66
          @mrjeschke sagte in iob node fix - Skript:
          Gut, der muss auch noch geprunt werden.
          Nanu?
          Muss ich schauen.
          Thx! Ich verzieh mich in die Code-Küche und brutzel noch was...
            ohne ioBroker.
            @Thomas-Braun
            was tut er dann?
            M
            M
            MCU
            #67
            @homoran Ich hab dann mit y bestätigt und er hat dann die v18 installiert.
              ohne ioBroker.
              @Thomas-Braun
              was tut er dann?
              Thomas BraunT
              Thomas BraunT
              #68
              @homoran sagte in iob node fix - Skript:
              was tut er dann?
              Dann geht es auf die neueste Version aus dem 18er-Zweig. Oder welcher nodejs-Entwicklungszweig auch immer gerade empfohlen wird. Der muss allerdings immer händisch im skript gesetzt werden, wenn sich die generelle Empfehlung ändert.
              NODE_MAJOR=18           #recommended major nodejs version for ioBroker, please adjust if the recommendation changes
              • M MCU
                #69
                hab ich auch gesehen, aber wieso?
                hier
                gibt er die recommended version komplett an.
                bei dir steht da (erwartungsgemäß) nichts
                edit: Hat sich mit Thomas' Antwort geklärt
                  hier
                  Thomas BraunT
                  Thomas BraunT
                  #70
                  bei dir steht da nichts
                  Bei @mrjeschke konnte die empfohlene Version auch direkt aus den iob-States gelesen werden.
                  Wenn es aber ein slave ist oder die Datenbank (noch) nicht geladen ist, dann greift der Fallback-Code.
                  So oder so soll am Ende immer die aktuellste Version aus dem empfohlenen Zweig installiert sein (inkl. aktuellem Schlüssel und aktueller, unverfrickelter nodesource.list)
                  Ich hatte überlegt, die Version auswählbar zu machen, hab mich aber dann dagegen entschieden.
                    #71
                    @thomas-braun alles gut!
                    Damit hast du jetzt auch den Fallback verifiziert.
                    ich hatte mich nur gefragt woher bei nicht vorhandener Empfehlung jetztcdue v18 kam.
                    Aber du denkst anscheinend an allem!
                      Thomas BraunT
                      Thomas BraunT
                      #72
                      Den konnte ich hier lokal schon ausgiebig testen. Hab mein Test-System mit diversen krummen Konstellationen malträtiert und das skript immer aufräumen lassen. :-)
                      Intern nenne ich es auch 'die nodejs-Putze'. :-D
                      • M mrjeschke
                        /usr/bin/npm            9.8.0
                        /usr/bin/npx            9.8.0
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        lxc
                          nodejs
                          nodejs
                        maik@iobtest:~$
                        Thomas BraunT
                        Thomas BraunT
                        #73
                        @mrjeschke
                        Bitte nochmal von einer nodejs@20 aus mit frischem Skript aufräumen lassen.
                          @mrjeschke
                          M
                          M
                          mrjeschke
                          #74
                          ioBroker nodejs fixer 2023-09-07
                          /usr/bin/nodejs         v20.6.0
                          /usr/bin/node           v20.6.0
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Installed: 20.6.0-1nodesource1
                            Candidate: 20.6.0-1nodesource1
                            Version table:
                           *** 20.6.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                               20.5.1-1nodesource1 500
                               20.5.0-1nodesource1 500
                               20.4.0-1nodesource1 500
                               20.3.1-1nodesource1 500
                               20.3.0-1nodesource1 500
                               20.2.0-1nodesource1 500
                               20.1.0-1nodesource1 500
                               20.0.0-1nodesource1 500
                               18.13.0+dfsg1-1 500
                          The following packages were automatically installed and are no longer required:
                            libc-ares2 node-busboy node-cjs-module-lexer node-undici node-xtend
                          Use 'sudo apt autoremove' to remove them.
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:3 http://security.debian.org bookworm-security InRelease
                          Fetched 17.3 kB in 1s (27.1 kB/s)
                            nodejs
                          Need to get 0 B/29.4 MB of archives.
                          After this operation, 5746 kB disk space will be freed.
                          dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
                          (Reading database ... 38007 files and directories currently installed.)
                          Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
                          maik@iobtest:~$
                          • M mrjeschke
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                              nodejs
                            maik@iobtest:~$
                            Thomas BraunT
                            Thomas BraunT
                            #75
                            Da hast du aber mal die dfsg-Version von nodejs installiert gehabt... Die kommt nämlich mit diesen jetzt obsoleten Paketen angeschleppt.
                            Aber das Skript selber schaut jetzt gut aus.
                              M
                              M
                              mrjeschke
                              #76
                              Hier noch die Version mit einer ganz frischen Installation.
                              Habe ich Gestern nicht mehr geschafft, da ich Nachtschicht hatte.
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              You are running nodejs v20.6.0. Do you want to install recommended version 18.17.1?
                              lxc
                              Fetched 17.3 kB in 1s (27.3 kB/s)
                                nodejs
                              Fetched 29.4 MB in 1s (31.3 MB/s)
                              (Reading database ... 37784 files and directories currently installed.)
                              maik@iobtest2:~$
                              • M mrjeschke
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                lxc
                                  nodejs
                                maik@iobtest2:~$
                                Thomas BraunT
                                Thomas BraunT
                                #77
                                Vielen Dank für das Beta-Testing!
                                Habe jetzt gestern noch ein pinning auf das nodesoure-Repo gelegt, das muss aber nicht getestet werden.
                                PR gegen den ioBroker ist gestellt. Mal schauen wie schnell das im upstream landet.
                                  M
                                  M
                                  MCU
                                  #78
                                  @thomas-braun Wenn irgendwann die empfohlene Version die 20 wäre, dann brauch ich nur
                                  NODE_MAJOR=20
                                  zu setzen und lasse dann
                                  iob_node_update
                                  laufen?
                                  • M MCU
                                    NODE_MAJOR=20
                                    iob_node_update
                                    laufen?
                                    Thomas BraunT
                                    Thomas BraunT
                                    #79
                                    @mcu
                                    Ja.
                                    Das muss dann natürlich, wenn das Skript in den iob Installer integriert wurde dann auch dort zentral einmal geändert werden.
                                    Oder ich schau mal ob man das nicht aus der Installer Library auslesen kann. Dann wäre es nur einmal dort zu ändern.
                                    Irgendwie/wo muss die recommended version ja auch dort drin sein.
                                    Edith: In meinem ähnlich gelagerten PR zum Installer wird das natürlich auch mit einer Variablen gesetzt, im alten war ja der Link zum obsoleten nodejs-Installerskript drin.
                                    Edit2: Wobei die Varible NODE_MAJOR auch nur dann als 'FallBack' zum tragen kommt, wenn aus den iob-States nichts ausgelesen werden kann.
                                    G 1 Antwort Letzte Antwort
                                      @mcu
                                      Ja.
                                      G
                                      G
                                      guitardoc
                                      #80
                                      @thomas-braun Kurze Frage dazu: wenn man gleichzeitig noch die Homebridge auf dem System hat, dann hat man zwei Installationen von Node drauf - Homebridge installiert Node in abweichenden Pfaden. Das können sogar unterschiedliche Versionen sein, es funktioniert trotzdem beides - ioB und Homebridge - einwandfrei. Kann der Node fixer das berücksichtigen, damit die Homebridge Installation nicht zerschossen wird oder interessiert das den Fixer gar nicht dass da noch eine zweite Installation drauf ist?
                                      • G guitardoc
                                        Thomas BraunT
                                        Thomas BraunT
                                        #81
                                        @guitardoc
                                        Der Fixer haut alles weg, was nicht in den Installationspfaden des nodesource-Paketes, aber im $PATH liegt.
                                        Wo liegt denn die Installation der Homebridge?
                                        Hab ich mangels Homebridge nicht getestet.
                                        Edit:
                                        Hab gerade mal geschaut. Deren nodejs wohnt in
                                        Node Path /opt/homebridge/bin/node
                                        Das dürfte vom iob-Skript nicht tangiert werden, liegt es doch nicht im Standard $PATH. Außer sie verändern die Einträge dort.
                                        Kannst es ja testen ...
                                          @guitardoc
                                          Edit:
                                          G
                                          G
                                          guitardoc
                                          schrieb am zuletzt editiert von guitardoc
                                          #82
                                          Die Installation der Homebridge liegt hier:
                                          Node.js und NPM sind unter /opt/homebridge/bin/ zu finden (und deshalb auch nur für Homebridge sichtbar und nutzbar).
                                          Edith: Posts haben sich überschnitten…
                                          84.1k
