  4. iob node fix - Skript
    apollon77A
198 Beiträge 34 Kommentatoren 77.7k Aufrufe 37 Beobachtet
    @meister-mopper
    Magst du noch mal schauen?
    Meister MopperM
    Meister MopperM
    Meister Mopper
    @thomas-braun sagte in iob node fix - Skript:
    @meister-mopper
    Sorry, musste in die Heia und heute war ich auf Dienstreise.
    Es hat mit dem aktuellen Skript (wahrscheinlich) funktioniert.
    ioBroker nodejs fixer 2023-09-06
    No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs         v20.5.1
    /usr/bin/node           v20.5.1
    /usr/bin/npm            9.8.0
    /usr/bin/npx            9.8.0
    /usr/bin/corepack       0.19.0
    I found these nodejs versions available for installation:
    nodejs:
      Installed: 20.5.1-deb-1nodesource1
      Candidate: 20.5.1-deb-1nodesource1
      Version table:
     *** 20.5.1-deb-1nodesource1 100
         18.17.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
    Nothing to do, your installation is using the correct paths.
    You are running nodejs v20.5.1. Do you want to install recommended version ?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    ca-certificates is already the newest version (20210119).
    curl is already the newest version (7.74.0-1.3+deb11u7).
    gnupg is already the newest version (2.2.27-2+deb11u2).
    0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
    *** Creating new /etc/apt/sources.list.d/nodesource.list
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    *** These repos are active after the adjustments:
    Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5161 B]
    Fetched 17.3 kB in 1s (16.9 kB/s)
    Installing the recommended nodejs version now!
    Exact recommended version unknown, installing a fallback!
    The following packages will be DOWNGRADED:
      nodejs
    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 2 not upgraded.
    Need to get 26.7 MB of archives.
    After this operation, 6614 kB disk space will be freed.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.0-1nodesource1 [26.7 MB]
    Fetched 26.7 MB in 5s (5830 kB/s)
    dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
    (Reading database ... 123973 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.0-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
    Setting up nodejs (18.17.0-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    Updating fallback to latest nodejs v18 release
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Calculating upgrade... Done
    The following packages have been kept back:
      libudev1 udev
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
    After this operation, 7168 B of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.1-1nodesource1 [26.7 MB]
    Fetched 26.7 MB in 3s (8606 kB/s)
    apt-listchanges: Changelogs werden gelesen...
    (Reading database ... 124040 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.1-1nodesource1_armhf.deb ...
    Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
    Setting up nodejs (18.17.1-1nodesource1) ...
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
     thomas@rpizigbee:~ $ nodejs -v
    v18.17.1
    Proxmox und HA ...
      @meister-mopper
      /usr/bin/npm            9.8.0
      /usr/bin/npx            9.8.0
      nodejs:
        Version table:
        nodejs
        libudev1 udev
        nodejs
      v18.17.1
      Thomas BraunT
      Thomas BraunT
      @meister-mopper
      Prima! So soll es aussehen! Ich denke der Code ist dann soweit gediehen für ein Release.
      Mag noch jemand mit einem LXC herumtesten?
        @meister-mopper
        M
        M
        MCU
        @thomas-braun LXC-Container
        Recommended nodejs-version is: 18.17.1
        Checking your installation now. Please be patient!
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        nodejs:
          Installed: 18.17.1-1nodesource1
          Candidate: 18.17.1-1nodesource1
          Version table:
         *** 18.17.1-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.13.0+dfsg1-1 500
                500 http://ftp.debian.org/debian bookworm/main amd64 Packages
        Nothing to do, your installed version is the recommended one.
        • M MCU
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Thomas BraunT
          Thomas BraunT
          @mcu sagte in iob node fix - Skript:
          Nothing to do
          Hm. Der Codepart war einfach... ;-) Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
          M M 2 Antworten Letzte Antwort
            Nothing to do
            M
            M
            mrjeschke
            nodejs 20 sieht bei mir im LXC-Container so aus.
            /usr/bin/npm            9.8.0
            /usr/bin/npx            9.8.0
            nodejs:
              Version table:
             *** 20.5.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
            You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
            find: '/lost+found': Permission denied
            lxc
            Hit:2 http://security.debian.org bookworm-security InRelease
            ca-certificates is already the newest version (20230311).
            curl is already the newest version (7.88.1-10+deb12u1).
            gnupg is already the newest version (2.2.40-1.1).
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
            Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
            Fetched 17.3 kB in 0s (38.4 kB/s)
            ./iob_node_update: line 275: [: : integer expression expected
              nodejs
            0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
            Need to get 29.4 MB of archives.
            After this operation, 5249 kB disk space will be freed.
            Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
            Fetched 29.4 MB in 2s (13.2 MB/s)
            (Reading database ... 37746 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
            Processing triggers for man-db (2.11.2-2) ...
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              nodejs
            1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
            Fetched 29.4 MB in 1s (43.5 MB/s)
            apt-listchanges: Reading changelogs...
            (Reading database ... 37813 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
            ./iob_node_update: line 300: [: : integer expression expected
            *** You need to manually restart your container now! ***
            We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
            maik@iobtest:~$
              Nothing to do
              M
              M
              MCU
              @thomas-braun Frisch aufgesetzter LXC mit nodejs 16 ohne ioBroker.
              /usr/bin/nodejs         v16.20.2
              /usr/bin/node           v16.20.2
              /usr/bin/npm            8.19.4
              /usr/bin/npx            8.19.4
              /usr/bin/corepack       0.17.0
              nodejs:
                Installed: 16.20.2-deb-1nodesource1
                Candidate: 16.20.2-deb-1nodesource1
                Version table:
               *** 16.20.2-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                      500 http://security.debian.org bullseye-security/main amd64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://ftp.debian.org/debian bullseye/main amd64 Packages
              You are running nodejs v16.20.2. Do you want to install recommended version ?
              [sudo] password for prox:
              lxc
              ./iob_node_update: line 248: iob: command not found
              Hit:1 http://ftp.debian.org/debian bullseye InRelease
              Hit:2 http://security.debian.org bullseye-security InRelease
              Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
              Hit:1 http://security.debian.org bullseye-security InRelease
              Hit:2 http://ftp.debian.org/debian bullseye InRelease
              Fetched 17.3 kB in 0s (57.5 kB/s)
                nodejs
              After this operation, 60.4 MB of additional disk space will be used.
              Fetched 29.4 MB in 1s (21.7 MB/s)
              (Reading database ... 22654 files and directories currently installed.)
              Unpacking nodejs (18.17.0-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                nodejs
              Fetched 29.4 MB in 1s (41.9 MB/s)
              (Reading database ... 25141 files and directories currently installed.)
              nodejs is already the newest version (18.17.1-1nodesource1).
              • M MCU
                /usr/bin/npm            8.19.4
                /usr/bin/npx            8.19.4
                nodejs:
                  Version table:
                lxc
                  nodejs
                  nodejs
                ohne ioBroker.
                dann kennt er natürlich (?) die empfohlene Version nicht
                @Thomas-Braun
                was tut er dann?
                M Thomas BraunT 2 Antworten Letzte Antwort
                • M mrjeschke
                  /usr/bin/npm            9.8.0
                  /usr/bin/npx            9.8.0
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  lxc
                    nodejs
                    nodejs
                  maik@iobtest:~$
                  Thomas BraunT
                  Thomas BraunT
                  #66
                  @mrjeschke sagte in iob node fix - Skript:
                  Gut, der muss auch noch geprunt werden.
                  Nanu?
                  Muss ich schauen.
                  Thx! Ich verzieh mich in die Code-Küche und brutzel noch was...
                    ohne ioBroker.
                    @Thomas-Braun
                    was tut er dann?
                    M
                    M
                    MCU
                    #67
                    @homoran Ich hab dann mit y bestätigt und er hat dann die v18 installiert.
                      ohne ioBroker.
                      @Thomas-Braun
                      was tut er dann?
                      Thomas BraunT
                      Thomas BraunT
                      #68
                      @homoran sagte in iob node fix - Skript:
                      was tut er dann?
                      Dann geht es auf die neueste Version aus dem 18er-Zweig. Oder welcher nodejs-Entwicklungszweig auch immer gerade empfohlen wird. Der muss allerdings immer händisch im skript gesetzt werden, wenn sich die generelle Empfehlung ändert.
                      NODE_MAJOR=18           #recommended major nodejs version for ioBroker, please adjust if the recommendation changes
                      • M MCU
                        #69
                        hab ich auch gesehen, aber wieso?
                        hier
                        gibt er die recommended version komplett an.
                        bei dir steht da (erwartungsgemäß) nichts
                        edit: Hat sich mit Thomas' Antwort geklärt
                          hier
                          Thomas BraunT
                          Thomas BraunT
                          #70
                          bei dir steht da nichts
                          Bei @mrjeschke konnte die empfohlene Version auch direkt aus den iob-States gelesen werden.
                          Wenn es aber ein slave ist oder die Datenbank (noch) nicht geladen ist, dann greift der Fallback-Code.
                          So oder so soll am Ende immer die aktuellste Version aus dem empfohlenen Zweig installiert sein (inkl. aktuellem Schlüssel und aktueller, unverfrickelter nodesource.list)
                          Ich hatte überlegt, die Version auswählbar zu machen, hab mich aber dann dagegen entschieden.
                            #71
                            @thomas-braun alles gut!
                            Damit hast du jetzt auch den Fallback verifiziert.
                            ich hatte mich nur gefragt woher bei nicht vorhandener Empfehlung jetztcdue v18 kam.
                            Aber du denkst anscheinend an allem!
                              Thomas BraunT
                              Thomas BraunT
                              #72
                              Den konnte ich hier lokal schon ausgiebig testen. Hab mein Test-System mit diversen krummen Konstellationen malträtiert und das skript immer aufräumen lassen. :-)
                              Intern nenne ich es auch 'die nodejs-Putze'. :-D
                              • M mrjeschke
                                /usr/bin/npm            9.8.0
                                /usr/bin/npx            9.8.0
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                lxc
                                  nodejs
                                  nodejs
                                maik@iobtest:~$
                                Thomas BraunT
                                Thomas BraunT
                                #73
                                @mrjeschke
                                Bitte nochmal von einer nodejs@20 aus mit frischem Skript aufräumen lassen.
                                  @mrjeschke
                                  M
                                  M
                                  mrjeschke
                                  #74
                                  ioBroker nodejs fixer 2023-09-07
                                  /usr/bin/nodejs         v20.6.0
                                  /usr/bin/node           v20.6.0
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Installed: 20.6.0-1nodesource1
                                    Candidate: 20.6.0-1nodesource1
                                    Version table:
                                   *** 20.6.0-1nodesource1 500
                                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                       20.5.1-1nodesource1 500
                                       20.5.0-1nodesource1 500
                                       20.4.0-1nodesource1 500
                                       20.3.1-1nodesource1 500
                                       20.3.0-1nodesource1 500
                                       20.2.0-1nodesource1 500
                                       20.1.0-1nodesource1 500
                                       20.0.0-1nodesource1 500
                                       18.13.0+dfsg1-1 500
                                  The following packages were automatically installed and are no longer required:
                                    libc-ares2 node-busboy node-cjs-module-lexer node-undici node-xtend
                                  Use 'sudo apt autoremove' to remove them.
                                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:3 http://security.debian.org bookworm-security InRelease
                                  Fetched 17.3 kB in 1s (27.1 kB/s)
                                    nodejs
                                  Need to get 0 B/29.4 MB of archives.
                                  After this operation, 5746 kB disk space will be freed.
                                  dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
                                  (Reading database ... 38007 files and directories currently installed.)
                                  Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
                                  maik@iobtest:~$
                                  • M mrjeschke
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                      nodejs
                                    maik@iobtest:~$
                                    Thomas BraunT
                                    Thomas BraunT
                                    #75
                                    Da hast du aber mal die dfsg-Version von nodejs installiert gehabt... Die kommt nämlich mit diesen jetzt obsoleten Paketen angeschleppt.
                                    Aber das Skript selber schaut jetzt gut aus.
                                      M
                                      M
                                      mrjeschke
                                      #76
                                      Hier noch die Version mit einer ganz frischen Installation.
                                      Habe ich Gestern nicht mehr geschafft, da ich Nachtschicht hatte.
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      You are running nodejs v20.6.0. Do you want to install recommended version 18.17.1?
                                      lxc
                                      Fetched 17.3 kB in 1s (27.3 kB/s)
                                        nodejs
                                      Fetched 29.4 MB in 1s (31.3 MB/s)
                                      (Reading database ... 37784 files and directories currently installed.)
                                      maik@iobtest2:~$
                                      • M mrjeschke
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        lxc
                                          nodejs
                                        maik@iobtest2:~$
                                        Thomas BraunT
                                        Thomas BraunT
                                        #77
                                        Vielen Dank für das Beta-Testing!
                                        Habe jetzt gestern noch ein pinning auf das nodesoure-Repo gelegt, das muss aber nicht getestet werden.
                                        PR gegen den ioBroker ist gestellt. Mal schauen wie schnell das im upstream landet.
                                          M
                                          M
                                          MCU
                                          #78
                                          @thomas-braun Wenn irgendwann die empfohlene Version die 20 wäre, dann brauch ich nur
                                          NODE_MAJOR=20
                                          zu setzen und lasse dann
                                          iob_node_update
                                          laufen?
                                          83.9k
