  4. ioBroker-Objekte der piVCCU3 nicht immer richtig
    5.2k
59 Beiträge 3 Kommentatoren 5.9k Aufrufe 2 Beobachtet
    @herrfrodo
    Nein, wenn dein System nicht komplett verfummelt ist kannst du dich am initialen Posting entlang hangeln.
    HerrFrodo
    @thomas-braun Grafana und Influx nutze ich nicht - kann weg
    Wie soll ich das ohne wurschteln machen?
    Wo ein Wille ist, ist auch ein LAN!
    • H HerrFrodo
      @thomas-braun na toll.....soviel zu verwurschtelt.....
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Get:3 https://repos.influxdata.com/debian jessie InRelease [7,038 B]
      Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
      Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
      Err:3 https://repos.influxdata.com/debian jessie InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Err:5 https://packages.grafana.com/oss/deb stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      Fetched 7,038 B in 2s (4,180 B/s)
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian jessie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://repos.influxdata.com/debian/dists/jessie/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      @herrfrodo
      Jessie ist komplett falsch, da gehört Buster in die list-Datei. Das ist wohl 'schon immer falsch' gewesen bei dir. Und dann müssen die Keys für grafana sowie influxdb frisch reingeladen werden. Gibt aber auch dazu Threads von mir.
      Edith:
      sudo rm /etc/apt/sources.list.d/graf*
      sudo rm /etc/apt/sources.list.d/influ*
      sudo apt update
      H 3 Antworten Letzte Antwort
        @herrfrodo
        Edith:
        sudo apt update
        HerrFrodo
        @thomas-braun Viel besser!
        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/graf*
        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influ*
        pi@raspberrypi:~ $ sudo apt update
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
          @herrfrodo
          Edith:
          sudo apt update
          HerrFrodo
          @thomas-braun Damit ist aber Grafana und Influx noch da, gelle.
          Das gockel ich dann in Deinen Threads
            @herrfrodo
            Edith:
            sudo apt update
            HerrFrodo
            pi@raspberrypi:~ $ iob fix
            library: loaded
            Library version=2022-12-09
                Welcome to the ioBroker installation fixer!
                Script version: 2023-04-02
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/5)
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            pi@raspberrypi:~ $ iob start
            • H HerrFrodo
              @herrfrodo sagte in ioBroker-Objekte der piVCCU3 nicht immer richtig:
              Ich dachte du nutzt es nicht?
              sudo apt remove grafana influxdb*
              H 2 Antworten Letzte Antwort
                HerrFrodo
                @thomas-braun Ich nutze es nicht.
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                Jetzt müsste es passen - dank Deiner Hilfe!
                Vielen Dank!
                  HerrFrodo
                  @thomas-braun Hallo!
                  Ich habe ja nun dank Deiner Hilfe mein Raspi-System auf den neuesten Stand bringen können.
                  Bis jetzt kann ich keine Fehler/Probleme feststellen - auch die HM-Adapter laufen gut - habe allerdings "Sentry" immer noch deaktiviert - teste ich mal.
                  Einzig und allein die NFS-Freigabe bzw. das Mounten des Syno-Laufwerkes für den raspiBackup hat nicht funktioniert.
                  Autofs war installiert und die auto.nfs war auch noch wie zuvor.
                  Es schien aber die auto.master nicht zu stimmen.
                  Ich habe dann mit Hilfe von https://darkwolfcave.de/raspberry-pi-nas-freigaben-automatisch-einbinden/
                  die Verbindung geschafft.
                  Keine Ahnung, ob das nun die idealste Lösung ist seinen Raspi täglich zu sichern.
                  Die erzeugte Sicherung auf der Syno wird dann zeitversetzt auf 2 externe Platten geschrieben.
                  Eine dritte Sicherung noch an einem anderen Ort.
                  Wie handhabst Du das?
                  • H HerrFrodo
                    Ich schiebe jede Nacht ein Backitup-Backup auf mein FritzNAS sowie auf GoogleDrive.
                    H 1 Antwort Letzte Antwort
                      HerrFrodo
                      @thomas-braun said in ioBroker-Objekte der piVCCU3 nicht immer richtig:
                      Du meinst Backitup in ioBroker?
                      Und das System, die SD? Wird das nicht gesichert?
                      • H HerrFrodo
                        Nö, warum?
                        Wenn mir das System in Gänze um die Ohren fliegen sollte installiere ich das ohnehin komplett neu und zieh nur das Backup vom iobroker rein.
                          Nö, warum?
                          HerrFrodo
                          Nö, warum?
                          Kaputte SD....Überspannung......
                            Nö, warum?
                            HerrFrodo
                            schrieb am zuletzt editiert von HerrFrodo
                            Aber das dauert doch bis alles installiert ist.
                            Bei mir hat ein Backitup-Backup mal nicht funktioniert - muss gestehen, dass ich das vorher auch noch nie getestet habe und möglicherweise mein System verwurschtelt sein könnte.
                            Ich habe damals ein Image von smartkram genommen, bei dem piVCCU mit dabei war.
                            • H HerrFrodo
                              Stunde vielleicht. Aber dafür schlepp ich auch keinen alten Kram rein.
                                HerrFrodo
                                Stimmt wohl. Kommt bestimmt auch nicht so oft vor.
                                Hast Du auch Homematic?
                                Ist die Nutzung von ioBroker und Hm auf einem System sinnvoll oder besser trennen?
                                Eventuell irgendwas auf der Syno laufen lassen?
                                • H HerrFrodo
                                  @herrfrodo
                                  Hab ich alles nicht im Einsatz.
                                  • H Offline
                                    HerrFrodo
                                    bezüglich Homematic-Adapter habe ich mich wohl etwas zu früh gefreut....
                                    Einige Werte werden wieder nicht in den Objekten aktualisiert aber auf der piVCCU und unter pocketControl richtig angezeigt.
                                    Ich würde nun gerne hier ein Protokoll einfügen.
                                    Wie ist es am sinnvollsten?
                                    Alle 3 hm-rpc Instanzen als Debug zusammen oder einzeln?
                                    Hm-rega mit dabei oder extra?
                                    Besten Dank!
                                    • H HerrFrodo
                                      Besten Dank!
                                      was heisst das genau?
                                      schalte mal Sentry in den Instanzen ab
                                        HerrFrodo
                                        @homoran said in ioBroker-Objekte der piVCCU3 nicht immer richtig:
                                        Die Werte der Objekte in den hm-rpc Instanzen werden dann nicht aktualisiert. Sie bleiben unverändert auf dem zuletzt übertragenen Wert stehen.
                                        Ich hatte gestern noch Sentry deaktiviert und bis jetzt konnte ich noch keinen Fehler feststellen.
                                        Vor dem Upgrade auf Bullseye und node.js 18, hatte ich das auch schonmal gemacht, aber das Problem der nicht-Aktualisierung bestand weiter.
                                        Jetzt scheint es zu gehen - ich behalte das im Auge, und werde berichten.
                                        Besten Dank!
                                          HerrFrodo
                                          @homoran Wie nutzt Du ioBroker und Homematic? Zusammen auf einem Raspi oder getrennt?
                                          Was empfiehlst Du mir?
                                          Danke und Gruß
