  4. Neuer Robonect HX Adapter
    6.0k
robonectgardenahusqvarnamährobotergarten
467 Beiträge 58 Kommentatoren 166.0k Aufrufe 42 Beobachtet
  • M michael 1975
    @grizzelbee
    NodeJS:18.16.0
    Js controller:4.0.24
    Admin:6.3.5
    Robonect:
    Konfig
    ct.0
    2023-08-18 21:30:40.859 debug doRegularPoll: false
    robonect.0
    2023-08-18 21:30:40.859 debug currentStatus: 17
    robonect.0
    2023-08-18 21:30:40.858 debug isRestTime: false
    robonect.0
    2023-08-18 21:30:40.858 debug pollType: Initial
    robonect.0
    2023-08-18 21:30:40.858 debug Data from poll: {"name":"Charly","id":"C14124","status":{"status":17,"distance":0,"stopped":false,"dooropen":false,"duration":17,"mode":0,"battery":99,"hours":2272},"timer":{"status":2,"next":{"date":"2023-08-18","time":"22:00:00","unix":1692396000}},"blades":{"quality":90,"hours":8,"days":7},"wlan":{"signal":-67},"health":{"temperature":34,"humidity":44},"clock":{"date":"2023-08-18","time":"21:30:39","unix":1692394239},"successful":true}
    robonect.0
    2023-08-18 21:30:40.858 debug API call to [http://192.168.178.193/api/json?user=xxxxxx&pass=xxxx&cmd=] with command [status] - done!
    robonect.0
    2023-08-18 21:30:40.856 debug {"name":"Charly","id":"C14124","status":{"status":17,"distance":0,"stopped":false,"dooropen":false,"duration":17,"mode":0,"battery":99,"hours":2272},"timer":{"status":2,"next":{"date":"2023-08-18","time":"22:00:00","unix":1692396000}},"blades":{"quality":90,"hours":8,"days":7},"wlan":{"signal":-67},"health":{"temperature":34,"humidity":44},"clock":{"date":"2023-08-18","time":"21:30:39","unix":1692394239},"successful":true}
    robonect.0
    2023-08-18 21:30:40.801 debug API call to [http://192.168.178.193/api/json?user=xxxxx&pass=xxxx&cmd=] with command [status] started
    robonect.0
    2023-08-18 21:30:40.801 debug Polling started
    robonect.0
    2023-08-18 21:30:38.381 info Rest period 2 not configured. Period will be ignored.
    robonect.0
    2023-08-18 21:30:38.381 info Rest period 1 not configured. Period will be ignored.
    robonect.0
    2023-08-18 21:30:38.364 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.robonect, node: v18.16.0, js-controller: 4.0.24
    robonect.0
    2023-08-18 21:30:32.719 debug Plugin sentry Initialize Plugin (enabled=true)
    robonect.0
    2023-08-18 21:29:48.791 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
    robonect.0
    2023-08-18 21:29:48.791 debug Plugin sentry destroyed
    robonect.0
    2023-08-18 21:29:48.791 info terminating
    robonect.0
    2023-08-18 21:29:48.790 info cleaned everything up...
    robonect.0
    2023-08-18 21:29:48.783 error Something went wrong
    robonect.0
    2023-08-18 21:29:48.783 error Error: Something went wrong at /opt/iobroker/node_modules/iobroker.robonect/main.js:409:35 at processTicksAndRejections (node:internal/process/task_queues:95:5)
    robonect.0
    2023-08-18 21:29:48.780 error unhandled promise rejection: Something went wrong
    robonect.0
    2023-08-18 21:29:48.780 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    robonect.0
    2023-08-18 21:29:48.779 error Axios says: Error: Something went wrong
    robonect.0
    2023-08-18 21:29:48.779 debug "{"door": {"enabled": true, "state": {"open": false, "close": true}, "open": false, "close": false}, "arrested": false}, "successful": true}"
    robonect.0
    2023-08-18 21:29:48.739 debug API call to [http://192.168.178.193/api/json?user=xxxxx&pass=xxxxx&cmd=] with command [door] started
    robonect.0
    2023-08-18 21:29:48.739 debug API call to [http://192.168.178.193/api/json?user=xxxxx&pass=xxxxx&cmd=] with command [battery] - done!
    robonect.0
    2023-08-18 21:29:48.738 debug {"batteries":[{"id":0,"charge":99,"voltage":20475,"current":0,"temperature":271,"capacity":{"full":1600,"remaining":1599}}],"successful":true}
    robonect.0
    2023-08-18 21:29:44.647 debug API call to [http://192.168.178.193/api/json?user=xxxxxx&pass=xxxxxx&cmd=] with command [battery] started
    robonect.0
    2023-08-18 21:29:44.647 debug doRegularPoll: false
    robonect.0
    2023-08-18 21:29:44.647 debug currentStatus: 17
    robonect.0
    2023-08-18 21:29:44.647 debug isRestTime: false
    robonect.0
    2023-08-18 21:29:44.646 debug pollType: Initial
    robonect.0
    2023-08-18 21:29:44.646 debug Data from poll: {"name":"Charly","id":"C14124","status":{"status":17,"distance":0,"stopped":false,"dooropen":false,"duration":6363,"mode":0,"battery":99,"hours":2272},"timer":{"status":2,"next":{"date":"2023-08-18","time":"22:00:00","unix":1692396000}},"blades":{"quality":90,"hours":8,"days":7},"wlan":{"signal":-67},"health":{"temperature":34,"humidity":44},"clock":{"date":"2023-08-18","time":"21:29:44","unix":1692394184},"successful":true}
    robonect.0
    2023-08-18 21:29:44.646 debug API call to [http://192.168.178.193/api/json?user=xxxxx&pass=xxxxx&cmd=] with command [status] - done!
    robonect.0
    2023-08-18 21:29:44.644 debug {"name":"Charly","id":"C14124","status":{"status":17,"distance":0,"stopped":false,"dooropen":false,"duration":6363,"mode":0,"battery":99,"hours":2272},"timer":{"status":2,"next":{"date":"2023-08-18","time":"22:00:00","unix":1692396000}},"blades":{"quality":90,"hours":8,"days":7},"wlan":{"signal":-67},"health":{"temperature":34,"humidity":44},"clock":{"date":"2023-08-18","time":"21:29:44","unix":1692394184},"successful":true}
    robonect.0
    2023-08-18 21:29:44.591 debug API call to [http://192.168.178.193/api/json?user=xxxxx&pass=xxxxx&cmd=] with command [status] started
    robonect.0
    2023-08-18 21:29:44.591 debug Polling started
    robonect.0
    2023-08-18 21:29:42.648 info Rest period 2 not configured. Period will be ignored.
    robonect.0
    2023-08-18 21:29:42.648 info Rest period 1 not configured. Period will be ignored.
    robonect.0
    2023-08-18 21:29:42.634 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.robonect, node: v18.16.0, js-controller: 4.0.24
    robonect.0
    2023-08-18 21:29:41.007 debug Plugin sentry Initialize Plugin (enabled=true)
    robonect.0
    2023-08-18 21:29:39.380 debug States connected to redis: 127.0.0.1:9000
    robonect.0
    2023-08-18 21:29:39.045 debug States create User PubSub Client
    robonect.0
    2023-08-18 21:29:39.045 debug States create System PubSub Client
    robonect.0
    2023-08-18 21:29:38.797 debug Redis States: Use Redis connection: 127.0.0.1:9000
    robonect.0
    2023-08-18 21:29:38.468 debug Objects connected to redis: 127.0.0.1:9001
    robonect.0
    2023-08-18 21:29:38.439 debug Objects client initialize lua scripts
    robonect.0
    2023-08-18 21:29:37.893 debug Objects create User PubSub Client
    robonect.0
    2023-08-18 21:29:37.892 debug Objects create System PubSub Client
    robonect.0
    2023-08-18 21:29:37.856 debug Objects client ready ... initialize now
    robonect.0
    2023-08-18 21:29:37.614 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
    Passt das
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    #373
    @michael-1975
    Hmm. Leider sieht man im Debug Log jetzt die Exception nicht. Aber aufgrund deiner Config habe ich eine erste Vermutung:
    Bei mir ist es so, dass ich keine Infos z.B. zum GPS abfragen kann. Dann passieren auch komische Dinge. Das hat auch der alte Adapter schon so gemacht - aber wie auch immer - guck mal bitte bei der Exception etwas genauer hin - da solltest Du einen Hinweis finden, welche Abfrage kaputt gegangen ist und die musst Du dann in der Config ausschalten.
    Bei mir sieht das so aus:
    GPS hat mein Gardena R40Li nicht, Garagentor habe ich auch keins und das Wetter habe ich nicht konfiguriert. Deshalb frage ich die auch nicht ab.
    Und dann werde ich mich mal dransetzen und die Exceptions besser abfangen ... ;)
    wäre ja blöd wenn der Adapter jetzt schon fertig gewesen wäre. ;)
    • GrizzelbeeG Grizzelbee
      @michael-1975
      michael 1975
      #374
      @grizzelbee also mit deinen Einstellungen sieht erstmal gut aus Garagentor habe ich aber wenn ich das Abfrage fängt er gleich an rumzuzicken.
      Wenn du was brauchst von mir sag bescheid bin zwar nicht der Profi aber wenn ich helfen kann dann gerne.
      Gruß Michael
      Bin das Wochenende allerdings nicht soviel am Rechner
      D GrizzelbeeG 2 Antworten Letzte Antwort
      • M michael 1975
        Gruß Michael
        darkiop
        #375
        @grizzelbee sagte in Neuer Robonect HX Adapter:
        Danke das du den Adapter etwas pflegst!
        Planst du auch eine Erweiterung bzgl. des Schreiben von Timer Daten über den Adapter? Aktuell werden die darüber nur ausgelesen.
        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
        • M michael 1975
          Gruß Michael
          GrizzelbeeG Offline
          GrizzelbeeG Offline
          Grizzelbee
          #376
          @michael-1975 sagte in Neuer Robonect HX Adapter:
          Ich nehme erst einmal GPS für die erste Analyse, weil ich das lokal testen kann und dann gucken wir uns das Garagentor an. Vielleicht ist die Ursache für die Exception ja die Selbe.
          Ich melde mich dann wieder.
          @darkiop sagte in Neuer Robonect HX Adapter:
          Da habe ich noch gar keine genauen Pläne für. Mir war es zunächst wichtig das der Adapter überhaupt wieder läuft (weil ich ihn auch selbst nutzen will) - und dann schauen wir, wie sich die Dinge entwickeln. Ich habe auch noch gar keinen richtigen Überblick was funktioniert und was nicht. Ich brauche ja selber nur einen Bruchteil der Funktionalitäten. Im Zweifel: Bitte einfach einen Issue auf Github öffnen, damit die Anfrage oder der Bug nicht vergessen wird.
            darkiop
            #377
            @grizzelbee
            Nur ne Idee - so oft stellt man den Timer ja auch nicht um.
            Den Fehler mit der Abfrage des Tor Status kann ich bestätigen und habs im bestehenden issue ergänzt: https://github.com/Grizzelbee/ioBroker.robonect/issues/12
            GrizzelbeeG 1 Antwort Letzte Antwort
            • D darkiop
              @grizzelbee
              GrizzelbeeG Offline
              GrizzelbeeG Offline
              Grizzelbee
              #378
              @darkiop , @michael-1975
              So. Ich habe gerade eben die v1.0.4 veröffentlicht, in der ich das Error-Handling noch einmal erweitert habe.
              Allerdings sehe ich in Sentry immer noch einen komischen Fehler, den ich so nicht nachvollziehen kann.
              Ich möchte also noch einmal jeden bitten, der die aktuelle Version testet, mir alle Probleme/Fehlermeldungen mit einem DEBUG-Log entweder hier oder auf Github zur Verfügung zu stellen.
              Ansonsten sollte eigentlich soweit alles laufen - incl. Garagentor und Erweiterungen. Also gerne das Polling ggf. wieder einschalten.
              viele Grüße
              grizzelbee
              LatziL 1 Antwort Letzte Antwort
                viele Grüße
                grizzelbee
                LatziL Online
                LatziL Online
                Latzi
                #379
                ich hab soeben die v1.0.5 angeboten bekommen und auch installiert, funktioniert bei mir problemlos (keine Garage, kein GPS, ...) 👍
                  michael 1975
                  #380
                  habe auch die 1.0.5 installiert läuft nur das Garagentor zeigt noch nicht an.
                  aber der Adapter stürzt nicht mehr ab
                  • QuarkmaxQ Offline
                    QuarkmaxQ Offline
                    Quarkmax
                    #381
                    @Grizzelbee
                    Danke für die Weiterentwicklung des Adapters. Kannst Du mal bitte schauen, z.B. die VOLTAGE und TEMPERATUR der Batterie wird nur als volle Zahl angezeigt, keine Nachkommastellen mehr. Der Adapter teilt nicht mehr durch 1000 (VOLTAGE) oder 10 (TEMP).
                    • M michael 1975
                      GrizzelbeeG Offline
                      GrizzelbeeG Offline
                      Grizzelbee
                      schrieb am zuletzt editiert von Grizzelbee
                      #382
                      @michael-1975
                      schaue ich mir an:
                      https://github.com/Grizzelbee/ioBroker.robonect/issues/17
                      Ich habe das jetzt so abgedichtet, dass ich eigentlich auch keine Abstürze mehr erwarte. Fehler und Warnings allerdings schon. Die, wie bereits gesagt, bitte melden. Speziell beim Garagentor geht bei Dir ja noch etwas schief, was ich bei mir anscheinend nicht reproduzieren kann.
                      EDIT
                      Bist Du dir sicher das Du die Garage im Robonect aktiviert hast und die Daten auch pollst (->Config)?
                      Wenn ich die Garage im Robonect aktiviere bekomme ich Daten:
                      @quarkmax sagte in Neuer Robonect HX Adapter:
                      Japp. Sehe ich mir ebenfalls an:
                      https://github.com/Grizzelbee/ioBroker.robonect/issues/18
                      QuarkmaxQ 1 Antwort Letzte Antwort
                        @michael-1975
                        schaue ich mir an:
                        EDIT
                        QuarkmaxQ Offline
                        QuarkmaxQ Offline
                        Quarkmax
                        #383
                        @grizzelbee
                        mit 1.1.0 werden die angefragten Werte vollumfänglich angezeigt. Dankeschön 👍
                        • afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          schrieb am zuletzt editiert von afuerhoff
                          #384
                          Hallo, ich habe ein Problem mit v1.1.5. Ich kann mein Passwort nicht eingeben. Der Speicher Button ist disabled. Wenn ich das letzte Zeichen lösche oder auch eins mittendrin, dann funktioniert das Speichern.
                          Passwort ist 11 Zeichen lang, Groß/Kleinbuchstaben, Sonderzeichen und Zahlen. In der 0.x Version funktionierte noch alles korrekt.
                          mcm1957M GrizzelbeeG 2 Antworten Letzte Antwort
                          • afuerhoffA afuerhoff
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #385
                            @afuerhoff
                            Wenn du hier keine Lösung bekommst erstell bitte ein issue. Gib bitte auch due version v ad.in u js-co triller an. Kann nämlich auch ein Problem im admin sein. Muss man sich ansehn
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                            • LongbowL Offline
                              LongbowL Offline
                              Longbow
                              #386
                              Hallo
                              ich habe die Version V1.1.5, aber bei jeder Version die ich nehme, bekomme ich die Fehlermeldung:
                              robonect.0
                              24667	2023-09-27 20:06:29.057	warn	No connection to lawn mower. Check network connection.
                              Ich komme aber über den Link im iobroker auf die Web-Überfläche von dem Robonect.
                              Aber ich bekomme keine Daten aus gelesen, an was kann das liegen?
                                GrizzelbeeG Offline
                                GrizzelbeeG Offline
                                Grizzelbee
                                #387
                                @afuerhoff sagte in Neuer Robonect HX Adapter:
                                Das ist dann auch schon das Problem.
                                Ich habe das Update für den Adapter hauptsächlich deswegen geschrieben weil ich genau dieses Problem mit der v0.1.4 hatte.
                                Ich hatte ebenfalls Sonderzeichen wie z.B. §$# im Passwort und habe den Adapter (v0.1.4) nicht ans Laufen bekommen.
                                Während der Entwicklung habe ich dann herausgefunden, das die Sonderzeichen im Passwort das Problem sind.
                                Die gehen irgendwie bei der Übertragung an den robonect kaputt und verhindern den Login. Ich verstehe nur nicht warum.
                                Ich nehme das Passwort direkt aus der Konfig, stecke es in einen String und den schicke ich über Axios per http-request an den Robonect.
                                In meinem Fall funktionierte es erst dann als das Passwort nur noch aus Groß- und Kleinbuchstaben und Zahlen bestand - das hätte vermutlich auch schon mit der 0.1.4 funktioniert.
                                Wenn jemand eine Idee hat woran das liegen könnte: Immer her damit. Ich teste das gerne.
                                Die einzige Idee, die ich noch habe wäre das Passwort auf Sonderzeichen zu durchsuchen und die dann zu escapen. Aber keine Ahnung ob das was bringt.
                                @longbow sagte in Neuer Robonect HX Adapter:
                                Hmmm. Der Adapter pingt den Robonect bevor er einen Request sendet. In deinem Fall geht dieser ping schief. Das kann unterschiedliche Gründe (Firewall, ...) haben.
                                Das liegt also weniger am Adapter als an deiner Netzwerk-Konfiguration.
                                Können wir aber gerne gemeinsam rausknoblen. Der Ping ist aber der erste Ansatzpunkt.
                                Off Topic: @Longbow Schiesst Du tatsächlich Langbogen?
                                LongbowL 1 Antwort Letzte Antwort
                                  LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  #388
                                  @grizzelbee
                                  ja ist mein Spitzname/ Benutzername in Forum. Kommt vom Helikopter Apache Longbow;-)
                                  wie bekomme ich das mit dem Ping hin? Bin da neuling was das an geht. iobroker läuft in einem LXC !
                                  • LongbowL Longbow
                                    @grizzelbee
                                    GrizzelbeeG Offline
                                    GrizzelbeeG Offline
                                    Grizzelbee
                                    #389
                                    Naja, zuerst solltest Du versuchen ob du aus deinem ioBroker Container heraus den robonect pingen kannst - also von der Konsole aus ein ping IP-des-Robonect absetzen kannst. Wenn der nicht funktioniert ist die Netzwerk- (Stichwort: Brigde) Konfig nicht okay. Da kann ich aber nur bedingt weiter helfen. Ich selbst nutze keine Container - unter anderem deswegen.
                                    • LongbowL Offline
                                      LongbowL Offline
                                      Longbow
                                      #390
                                      @grizzelbee
                                      Danke für den Tipp, also denke das mit dem Pung klappt.
                                      Hier ein Log
                                      64 bytes from 192.168.178.7: icmp_seq=1 ttl=128 time=60.2 ms
                                      64 bytes from 192.168.178.7: icmp_seq=2 ttl=128 time=28.2 ms
                                      64 bytes from 192.168.178.7: icmp_seq=3 ttl=128 time=24.5 ms
                                      64 bytes from 192.168.178.7: icmp_seq=4 ttl=128 time=27.8 ms
                                      64 bytes from 192.168.178.7: icmp_seq=5 ttl=128 time=37.3 ms
                                      64 bytes from 192.168.178.7: icmp_seq=6 ttl=128 time=5.46 ms
                                      64 bytes from 192.168.178.7: icmp_seq=7 ttl=128 time=14.8 ms
                                      64 bytes from 192.168.178.7: icmp_seq=8 ttl=128 time=35.5 ms
                                      64 bytes from 192.168.178.7: icmp_seq=9 ttl=128 time=7.95 ms
                                      64 bytes from 192.168.178.7: icmp_seq=10 ttl=128 time=8.51 ms
                                      64 bytes from 192.168.178.7: icmp_seq=11 ttl=128 time=44.2 ms
                                      64 bytes from 192.168.178.7: icmp_seq=12 ttl=128 time=7.22 ms
                                      64 bytes from 192.168.178.7: icmp_seq=13 ttl=128 time=7.39 ms
                                      Kennst sich jemandes mit dem LXC aus? Der mit helfen kann?
                                      Chris_71C 1 Antwort Letzte Antwort
                                      • LongbowL Longbow
                                        @grizzelbee
                                        Hier ein Log
                                        Chris_71C Offline
                                        Chris_71C Offline
                                        Chris_71
                                        #391
                                        @grizzelbee
                                        Ich nutze den OUT2 über API um LEDs am Mäher einzuschalten. Die Funktion scheint auch gegeben zu sein nur im Protokoll erscheint immer folgender Fehler:
                                        • LongbowL Offline
                                          LongbowL Offline
                                          Longbow
                                          #392
                                          Hat niemandes eine Idee, wo dran es liegen kann, das ich den Robo an pingen kann, auf die Web-Oberfläche zu greifen kann, aber der Adapter nicht den robo finde, spricht kein Kontakt hat?
