  4. js-controller lässts sich nicht updaten
    5.3k
42 Beiträge 5 Kommentatoren 5.0k Aufrufe 4 Beobachtet
  • S subman82
    @thomas-braun said in js-controller lässts sich nicht updaten:
    @subman82
    iob diag
    in der Langfassung sagt?
    muss es teilen, sonst bekomme ich es nicht hochgeladen.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     16:02:27 up 24 min,  1 user,  load average: 0.50, 0.78, 0.87
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=50.1'C
    volt=0.8813V
    *** Time and Time Zones ***
                   Local time: Fri 2023-08-04 16:02:27 CEST
               Universal time: Fri 2023-08-04 14:02:27 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        759M        2.6G        8.0M        522M        2.9G
    Swap:           99M          0B         99M
    Total:         3.9G        759M        2.7G
             3838 M total memory
              759 M used memory
              288 M active memory
              897 M inactive memory
             2556 M free memory
               86 M buffer memory
              436 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  5.7G   23G  21% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    /dev/sda1      exfat     115G  297M  115G   1% /media/usbstick
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Fri Aug  4 15:38:00 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x        1080M@60D smsc95xx.macaddr=DC:A6:32:1D:ED:20 vc_mem.mem_base=0x3ec00000 vc_mem.m        em_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=        PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Aug  4 15:38:01 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
    [Fri Aug  4 15:38:01 2023] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
    [Fri Aug  4 15:38:05 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Aug  4 15:38:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Opts: (null)
    [Fri Aug  4 15:38:05 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
    [Fri Aug  4 15:38:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET            SOURCE         FSTYPE OPTIONS
    /                 /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf     none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepa        ge=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbstick /dev/sda1      exfat  rw,noatime,uid=1001,gid=1001,fmask=0022,        dmask=0022,iocharset=utf8,errors=remount-ro
    /var:
    392M    /var/
    191M    /var/cache
    185M    /var/cache/apt
    126M    /var/cache/apt/archives
    95M     /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    323M    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    341M    /opt/iobroker/iobroker-data/
    158M    /opt/iobroker/iobroker-data/files
    112M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/scenes.admin/static
    48M     /opt/iobroker/iobroker-data/objects.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chun        k.js.map
    8.2M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.979c3ea7.chun        k.js.map
    7.7M    /opt/iobroker/iobroker-data/objects.json.migrated
    7.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    javascript:     6.1.4
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @subman82 sagte in js-controller lässts sich nicht updaten:
    ach komm - die komplette Ausgabe markieren und hier in Codetags posten... und zieh Dein Fenster von Deiner Konsole mal breiter !
    Lehrling seit 1975 !!!
      @subman82
      iob diag
      subman82
      @subman82
      iob diag
      Teil 2
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modul        es/@abandonware/bluetooth-hci-socket
      npm ERR! extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware        /noble
      npm ERR! extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/        jsonl-db
      npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
      npm ERR! extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alc        alzone/proper-lockfile
      npm ERR! extraneous: @apollon/iobroker-tools@ /opt/iobroker/node_modules/@apollo        n/iobroker-tools
      npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
      npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnos        tics
      npm ERR! extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust        /winston-seq
      npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/d        rive
      npm ERR! extraneous: @harmonyhub/discover@ /opt/iobroker/node_modules/@harmonyhu        b/discover
      npm ERR! extraneous: @homebridge/ciao@ /opt/iobroker/node_modules/@homebridge/ci        ao
      npm ERR! extraneous: @homebridge/dbus-native@0.4.2 /opt/iobroker/node_modules/@h        omebridge/dbus-native
      npm ERR! extraneous: @homebridge/long@5.2.1 /opt/iobroker/node_modules/@homebrid        ge/long
      npm ERR! extraneous: @homebridge/put@0.0.8 /opt/iobroker/node_modules/@homebridg        e/put
      npm ERR! extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroke        r/adapter-core
      npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-        base
      npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobr        oker/db-objects-file
      npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iob        roker/db-objects-jsonl
      npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iob        roker/db-objects-redis
      npm ERR! extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobro        ker/db-states-file
      npm ERR! extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobr        oker/db-states-jsonl
      npm ERR! extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobr        oker/db-states-redis
      npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules        /@iobroker/js-controller-adapter
      npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@io        broker/js-controller-cli
      npm ERR! extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modul        es/@iobroker/js-controller-common-db
      npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/        @iobroker/js-controller-common
      npm ERR! extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker        /plugin-base
      npm ERR! extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobrok        er/plugin-sentry
      npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobro        ker/socket-classes
      npm ERR! extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leicht        gewicht/ip-codec
      npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/no        de-pre-gyp
      npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@pro        tobufjs/aspromise
      npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@proto        bufjs/inquire
      npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
      npm ERR! extraneous: @root/asn1@ /opt/iobroker/node_modules/@root/asn1
      npm ERR! extraneous: @root/csr@ /opt/iobroker/node_modules/@root/csr
      npm ERR! extraneous: @root/encoding@ /opt/iobroker/node_modules/@root/encoding
      npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/g        reenlock-express
      npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
      npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
      npm ERR! extraneous: @root/pem@ /opt/iobroker/node_modules/@root/pem
      npm ERR! extraneous: @root/request@ /opt/iobroker/node_modules/@root/request
      npm ERR! extraneous: @root/x509@ /opt/iobroker/node_modules/@root/x509
      npm ERR! extraneous: @sentry/browser@5.12.1 /opt/iobroker/node_modules/@sentry/b        rowser
      npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
      npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
      npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/in        tegrations
      npm ERR! extraneous: @sentry/minimal@ /opt/iobroker/node_modules/@sentry/minimal
      npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
      npm ERR! extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
      npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
      npm ERR! extraneous: @serialport/binding-abstract@ /opt/iobroker/node_modules/@s        erialport/binding-abstract
      npm ERR! extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@seria        lport/binding-mock
      npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@seria        lport/bindings-cpp
      npm ERR! extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/        @serialport/bindings-interface
      npm ERR! extraneous: @serialport/bindings@ /opt/iobroker/node_modules/@serialpor        t/bindings
      npm ERR! extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/        @serialport/parser-byte-length
      npm ERR! extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@seri        alport/parser-cctalk
      npm ERR! extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@s        erialport/parser-delimiter
      npm ERR! extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_m        odules/@serialport/parser-inter-byte-timeout
      npm ERR! extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_module        s/@serialport/parser-packet-length
      npm ERR! extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@se        rialport/parser-readline
      npm ERR! extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@seria        lport/parser-ready
      npm ERR! extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@seria        lport/parser-regex
      npm ERR! extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules        /@serialport/parser-slip-encoder
      npm ERR! extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/        @serialport/parser-spacepacket
      npm ERR! extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/        stream
      npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindreso        rhus/is
      npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modul        es/@socket.io/component-emitter
      npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szm        arczak/http-timer
      npm ERR! extraneous: @tuyapi/cloud@0.6.1 /opt/iobroker/node_modules/@tuyapi/clou        d
      npm ERR! extraneous: @types/babel-types@7.0.11 /opt/iobroker/node_modules/@types        /babel-types
      npm ERR! extraneous: @types/bl@ /opt/iobroker/node_modules/@types/bl
      npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@        types/cacheable-request
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/ca        seless
      npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/@types/cookie
      npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
      npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/@types/iobroker
      npm ERR! extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
      npm ERR! extraneous: @types/readable-stream@2.3.15 /opt/iobroker/node_modules/@t        ypes/readable-stream
      npm ERR! extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types        /responselike
      npm ERR! extraneous: @types/retry@0.12.0 /opt/iobroker/node_modules/@types/retry
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types        /tough-cookie
      npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
      npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-con        troller
      npm ERR! extraneous: acme-http-01-standalone@ /opt/iobroker/node_modules/acme-ht        tp-01-standalone
      npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
      npm ERR! extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
      npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
      npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shar        ed
      npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
      npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
      npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-y        et
      npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuf        fer.slice
      npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/asn1
      npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limite        r
      npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
      npm ERR! extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authentic        ate-pam
      npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobin        d-decorator
      npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/availabl        e-typed-arrays
      npm ERR! extraneous: aws4@ /opt/iobroker/node_modules/aws4
      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/axios
      npm ERR! extraneous: b4a@1.6.1 /opt/iobroker/node_modules/b4a
      npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
      npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-        arraybuffer
      npm ERR! extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
      npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
      npm ERR! extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
      npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extens        ions
      npm ERR! extraneous: bl@ /opt/iobroker/node_modules/bl
      npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
      npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
      npm ERR! extraneous: bonjour-hap@ /opt/iobroker/node_modules/bonjour-hap
      npm ERR! extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
      npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-exp        ansion
      npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
      npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/buffer
      npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
      npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable        -lookup
      npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheabl        e-request
      npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
      npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
      npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
      npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
      npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
      npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
      npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-respo        nse
      npm ERR! extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-sl        ot
      npm ERR! extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
      npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
      npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-a        t
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! extraneous: coiot-coap@ /opt/iobroker/node_modules/coiot-coap
      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-suppor        t
      npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/colors
      npm ERR! extraneous: commander@ /opt/iobroker/node_modules/commander
      npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
      npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-b        ind
      npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/componen        t-emitter
      npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/componen        t-inherit
      npm ERR! extraneous: compressible@ /opt/iobroker/node_modules/compressible
      npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
      npm ERR! extraneous: concat-stream@2.0.0 /opt/iobroker/node_modules/concat-strea        m
      npm ERR! extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
      npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/co        nsole-control-strings
      npm ERR! extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
      npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
      npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
      npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
      npm ERR! extraneous: crypto-js@4.1.1 /opt/iobroker/node_modules/crypto-js
      npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
      npm ERR! extraneous: debounce@ /opt/iobroker/node_modules/debounce
      npm ERR! extraneous: decache@ /opt/iobroker/node_modules/decache
      npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
      npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decomp        ress-response
      npm ERR! extraneous: deep-equal@ /opt/iobroker/node_modules/deep-equal
      npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
      npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/define-proper        ties
      npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
      npm ERR! extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
      npm ERR! extraneous: dev-null@0.1.1 /opt/iobroker/node_modules/dev-null
      npm ERR! extraneous: dijkstrajs@ /opt/iobroker/node_modules/dijkstrajs
      npm ERR! extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
      npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
      npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
      npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
      npm ERR! extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
      npm ERR! extraneous: encode-utf8@1.0.3 /opt/iobroker/node_modules/encode-utf8
      npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-clie        nt
      npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-pars        er
      npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
      npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
      npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
      npm ERR! extraneous: es-get-iterator@ /opt/iobroker/node_modules/es-get-iterator
      npm ERR! extraneous: es-to-primitive@ /opt/iobroker/node_modules/es-to-primitive
      npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisif        y
      npm ERR! extraneous: esbuild@ /opt/iobroker/node_modules/esbuild
      npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/escalade
      npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-ta        rget-shim
      npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/eventemitter3
      npm ERR! extraneous: events@3.3.0 /opt/iobroker/node_modules/events
      npm ERR! extraneous: execa@ /opt/iobroker/node_modules/execa
      npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-file        upload
      npm ERR! extraneous: express-session@ /opt/iobroker/node_modules/express-session
      npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
      npm ERR! extraneous: fast-deep-equal@ /opt/iobroker/node_modules/fast-deep-equal
      npm ERR! extraneous: fast-fifo@1.1.0 /opt/iobroker/node_modules/fast-fifo
      npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast        -json-stable-stringify
      npm ERR! extraneous: fast-srp-hap@ /opt/iobroker/node_modules/fast-srp-hap
      npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
      npm ERR! extraneous: fastseries@ /opt/iobroker/node_modules/fastseries
      npm ERR! extraneous: fecha@ /opt/iobroker/node_modules/fecha
      npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream        -rotator
      npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
      npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
      npm ERR! extraneous: form-data@ /opt/iobroker/node_modules/form-data
      npm ERR! extraneous: fs-extra@7.0.1 /opt/iobroker/node_modules/fs-extra
      npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
      npm ERR! extraneous: ftp@ /opt/iobroker/node_modules/ftp
      npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/functio        n.prototype.name
      npm ERR! extraneous: functions-have-names@ /opt/iobroker/node_modules/functions-        have-names
      npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
      npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/gauge
      npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/gaxios
      npm ERR! extraneous: gcp-metadata@ /opt/iobroker/node_modules/gcp-metadata
      npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller        -file
      npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/get-intrinsic
      npm ERR! extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ss        l-certificate
      npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/get-stream
      npm ERR! extraneous: get-symbol-description@ /opt/iobroker/node_modules/get-symb        ol-description
      npm ERR! extraneous: glob@ /opt/iobroker/node_modules/glob
      npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth        -library
      npm ERR! extraneous: google-p12-pem@ /opt/iobroker/node_modules/google-p12-pem
      npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-co        mmon
      npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
      npm ERR! extraneous: got@11.8.6 /opt/iobroker/node_modules/got
      npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/graceful-fs
      npm ERR! extraneous: greenlock-express@ /opt/iobroker/node_modules/greenlock-exp        ress
      npm ERR! extraneous: greenlock-store-fs@ /opt/iobroker/node_modules/greenlock-st        ore-fs
      npm ERR! extraneous: gtoken@ /opt/iobroker/node_modules/gtoken
      npm ERR! extraneous: hap-controller@ /opt/iobroker/node_modules/hap-controller
      npm ERR! extraneous: hap-nodejs@ /opt/iobroker/node_modules/hap-nodejs
      npm ERR! extraneous: har-validator@ /opt/iobroker/node_modules/har-validator
      npm ERR! extraneous: harmonyhubws@1.0.6 /opt/iobroker/node_modules/harmonyhubws
      npm ERR! extraneous: has-bigints@ /opt/iobroker/node_modules/has-bigints
      npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
      npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
      npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/has-pr        operty-descriptors
      npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/has-symbols
      npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/has-tostringtag
      npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
      npm ERR! extraneous: help-me@ /opt/iobroker/node_modules/help-me
      npm ERR! extraneous: hexy@0.2.11 /opt/iobroker/node_modules/hexy
      npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/hosted-git-info
      npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-        proxy
      npm ERR! extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrappe        r
      npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/https-proxy-a        gent
      npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/human-signals
      npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
      npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
      npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
      npm ERR! extraneous: internal-slot@ /opt/iobroker/node_modules/internal-slot
      npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
      npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
      npm ERR! invalid: iobroker.backitup@2.6.19 /opt/iobroker/node_modules/iobroker.b        ackitup
      npm ERR! extraneous: iobroker.device-reminder@1.2.9 /opt/iobroker/node_modules/i        obroker.device-reminder
      npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.d        iscovery
      npm ERR! extraneous: iobroker.harmony@1.2.2 /opt/iobroker/node_modules/iobroker.        harmony
      npm ERR! extraneous: iobroker.hue@3.7.1 /opt/iobroker/node_modules/iobroker.hue
      npm ERR! extraneous: iobroker.info@1.9.26 /opt/iobroker/node_modules/iobroker.in        fo
      npm ERR! extraneous: iobroker.javascript@6.1.4 /opt/iobroker/node_modules/iobrok        er.javascript
      npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobro        ker.js-controller
      npm ERR! extraneous: iobroker.mihome-vacuum@3.9.5 /opt/iobroker/node_modules/iob        roker.mihome-vacuum
      npm ERR! extraneous: iobroker.mihome@1.4.0 /opt/iobroker/node_modules/iobroker.m        ihome
      npm ERR! extraneous: iobroker.mqtt@4.0.7 /opt/iobroker/node_modules/iobroker.mqt        t
      npm ERR! extraneous: iobroker.scenes@2.3.9 /opt/iobroker/node_modules/iobroker.s        cenes
      npm ERR! extraneous: iobroker.shelly@6.3.1 /opt/iobroker/node_modules/iobroker.s        helly
      npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobrok        er.simple-api
      npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker        .socketio
      npm ERR! extraneous: iobroker.terminal@1.0.0 /opt/iobroker/node_modules/iobroker        .terminal
      npm ERR! extraneous: iobroker.tuya@3.13.1 /opt/iobroker/node_modules/iobroker.tu        ya
      npm ERR! extraneous: iobroker.vis@1.4.16 /opt/iobroker/node_modules/iobroker.vis
      npm ERR! extraneous: iobroker.web@4.3.0 /opt/iobroker/node_modules/iobroker.web
      npm ERR! extraneous: iobroker.ws.server@ /opt/iobroker/node_modules/iobroker.ws.        server
      npm ERR! extraneous: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
      npm ERR! extraneous: iobroker.yahka@0.17.0 /opt/iobroker/node_modules/iobroker.y        ahka
      npm ERR! extraneous: iobroker.zigbee@1.8.10 /opt/iobroker/node_modules/iobroker.        zigbee
      npm ERR! extraneous: iobroker@2.0.3 /opt/iobroker/node_modules/iobroker
      npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
      npm ERR! extraneous: ip@ /opt/iobroker/node_modules/ip
      npm ERR! extraneous: is-arguments@ /opt/iobroker/node_modules/is-arguments
      npm ERR! extraneous: is-array-buffer@3.0.2 /opt/iobroker/node_modules/is-array-b        uffer
      npm ERR! extraneous: is-bigint@ /opt/iobroker/node_modules/is-bigint
      npm ERR! extraneous: is-boolean-object@ /opt/iobroker/node_modules/is-boolean-ob        ject
      npm ERR! extraneous: is-callable@ /opt/iobroker/node_modules/is-callable
      npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/is-core-module
      npm ERR! extraneous: is-date-object@ /opt/iobroker/node_modules/is-date-object
      npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/is-genera        tor-function
      npm ERR! extraneous: is-map@ /opt/iobroker/node_modules/is-map
      npm ERR! extraneous: is-nan@ /opt/iobroker/node_modules/is-nan
      npm ERR! extraneous: is-negative-zero@ /opt/iobroker/node_modules/is-negative-ze        ro
      npm ERR! extraneous: is-number-object@ /opt/iobroker/node_modules/is-number-obje        ct
      npm ERR! extraneous: is-plain-obj@2.1.0 /opt/iobroker/node_modules/is-plain-obj
      npm ERR! extraneous: is-regex@ /opt/iobroker/node_modules/is-regex
      npm ERR! extraneous: is-set@ /opt/iobroker/node_modules/is-set
      npm ERR! extraneous: is-shared-array-buffer@ /opt/iobroker/node_modules/is-share        d-array-buffer
      npm ERR! extraneous: is-string@ /opt/iobroker/node_modules/is-string
      npm ERR! extraneous: is-symbol@ /opt/iobroker/node_modules/is-symbol
      npm ERR! extraneous: is-typed-array@ /opt/iobroker/node_modules/is-typed-array
      npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
      npm ERR! extraneous: is-weakmap@ /opt/iobroker/node_modules/is-weakmap
      npm ERR! extraneous: is-weakref@ /opt/iobroker/node_modules/is-weakref
      npm ERR! extraneous: is-weakset@ /opt/iobroker/node_modules/is-weakset
      npm ERR! extraneous: isarray@2.0.5 /opt/iobroker/node_modules/isarray
      npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/js-sdsl
      npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
      npm ERR! extraneous: json-bigint@ /opt/iobroker/node_modules/json-bigint
      npm ERR! extraneous: json-schema@ /opt/iobroker/node_modules/json-schema
      npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
      npm ERR! extraneous: jsonfile@4.0.0 /opt/iobroker/node_modules/jsonfile
      npm ERR! extraneous: jsprim@ /opt/iobroker/node_modules/jsprim
      npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
      npm ERR! extraneous: jws@ /opt/iobroker/node_modules/jws
      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
      npm ERR! extraneous: layerr@ /opt/iobroker/node_modules/layerr
      npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
      npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
      npm ERR! extraneous: libsodium-wrappers@ /opt/iobroker/node_modules/libsodium-wr        appers
      npm ERR! extraneous: libsodium@ /opt/iobroker/node_modules/libsodium
      npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
      npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-f        ile
      npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
      npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/locate-path
      npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/lodash
      npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
      npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-k        eys
      npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
      npm ERR! extraneous: macaddress@ /opt/iobroker/node_modules/macaddress
      npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
      npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
      npm ERR! extraneous: mime-db@ /opt/iobroker/node_modules/mime-db
      npm ERR! extraneous: mime@ /opt/iobroker/node_modules/mime
      npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-respo        nse
      npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/minimatch
      npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
      npm ERR! extraneous: minipass@ /opt/iobroker/node_modules/minipass
      npm ERR! extraneous: minizlib@ /opt/iobroker/node_modules/minizlib
      npm ERR! extraneous: mixin-deep@2.0.1 /opt/iobroker/node_modules/mixin-deep
      npm ERR! extraneous: mkdirp@ /opt/iobroker/node_modules/mkdirp
      npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
      npm ERR! extraneous: mqtt-connection@ /opt/iobroker/node_modules/mqtt-connection
      npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
      npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
      npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_module        s/multicast-dns-service-types
      npm ERR! extraneous: multicast-dns@ /opt/iobroker/node_modules/multicast-dns
      npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
      npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
      npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/negotiator
      npm ERR! extraneous: nested-property@ /opt/iobroker/node_modules/nested-property
      npm ERR! extraneous: netmask@ /opt/iobroker/node_modules/netmask
      npm ERR! extraneous: node-abi@ /opt/iobroker/node_modules/node-abi
      npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
      npm ERR! extraneous: node-fetch@ /opt/iobroker/node_modules/node-fetch
      npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
      npm ERR! extraneous: node-gyp-build@ /opt/iobroker/node_modules/node-gyp-build
      npm ERR! extraneous: node-hue-api@ /opt/iobroker/node_modules/node-hue-api
      npm ERR! extraneous: node-inspect@ /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
      npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-clie        nt
      npm ERR! extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
      npm ERR! extraneous: node-schedule@ /opt/iobroker/node_modules/node-schedule
      npm ERR! extraneous: node-ssdp@ /opt/iobroker/node_modules/node-ssdp
      npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/nopt
      npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/nor        malize-package-data
      npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-ur        l
      npm ERR! extraneous: npmlog@ /opt/iobroker/node_modules/npmlog
      npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocat        or
      npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-na        n
      npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assig        n
      npm ERR! extraneous: object-hash@ /opt/iobroker/node_modules/object-hash
      npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
      npm ERR! extraneous: object-is@ /opt/iobroker/node_modules/object-is
      npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
      npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
      npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temp        erature-sensor
      npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
      npm ERR! extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
      npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
      npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/p-locate
      npm ERR! extraneous: p-queue@ /opt/iobroker/node_modules/p-queue
      npm ERR! extraneous: p-retry@4.6.2 /opt/iobroker/node_modules/p-retry
      npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-timeout
      npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
      npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
      npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
      npm ERR! extraneous: parseqs@ /opt/iobroker/node_modules/parseqs
      npm ERR! extraneous: parseuri@0.0.6 /opt/iobroker/node_modules/parseuri
      npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
      npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
      npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-a        bsolute
      npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
      npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
      npm ERR! extraneous: picocolors@ /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/picomatch
      npm ERR! extraneous: pidtree@ /opt/iobroker/node_modules/pidtree
      npm ERR! extraneous: pidusage@ /opt/iobroker/node_modules/pidusage
      npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
      npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-prom        ise
      npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
      npm ERR! extraneous: pngjs@ /opt/iobroker/node_modules/pngjs
      npm ERR! extraneous: prebuild-install@ /opt/iobroker/node_modules/prebuild-insta        ll
      npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
      npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
      npm ERR! extraneous: proper-lockfile@4.1.2 /opt/iobroker/node_modules/proper-loc        kfile
      npm ERR! extraneous: psl@ /opt/iobroker/node_modules/psl
      npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
      npm ERR! extraneous: qrcode@ /opt/iobroker/node_modules/qrcode
      npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
      npm ERR! extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
      npm ERR! extraneous: randomatic@3.1.1 /opt/iobroker/node_modules/randomatic
      npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
      npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
      npm ERR! extraneous: redirect-https@ /opt/iobroker/node_modules/redirect-https
      npm ERR! extraneous: redis-commands@ /opt/iobroker/node_modules/redis-commands
      npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.p        rototype.flags
      npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
      npm ERR! extraneous: request-promise-core@ /opt/iobroker/node_modules/request-pr        omise-core
      npm ERR! extraneous: request-promise-native@ /opt/iobroker/node_modules/request-        promise-native
      npm ERR! extraneous: request@ /opt/iobroker/node_modules/request
      npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/requ        ire-main-filename
      npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
      npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
      npm ERR! extraneous: rfdc@ /opt/iobroker/node_modules/rfdc
      npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/rimraf
      npm ERR! extraneous: safe-stable-stringify@ /opt/iobroker/node_modules/safe-stab        le-stringify
      npm ERR! extraneous: sax@1.2.4 /opt/iobroker/node_modules/sax
      npm ERR! extraneous: semaphore@1.1.0 /opt/iobroker/node_modules/semaphore
      npm ERR! extraneous: semver@5.7.1 /opt/iobroker/node_modules/semver
      npm ERR! extraneous: send@ /opt/iobroker/node_modules/send
      npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
      npm ERR! extraneous: serialport@ /opt/iobroker/node_modules/serialport
      npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
      npm ERR! extraneous: shelly-iot@ /opt/iobroker/node_modules/shelly-iot
      npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/side-channel
      npm ERR! extraneous: simple-concat@ /opt/iobroker/node_modules/simple-concat
      npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
      npm ERR! extraneous: slip@1.0.2 /opt/iobroker/node_modules/slip
      npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.i        o-adapter
      npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-clie        nt
      npm ERR! extraneous: socket.io-parser@3.4.1 /opt/iobroker/node_modules/socket.io        -parser
      npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/socket.io
      npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-k        eys-recursive
      npm ERR! extraneous: sort-keys@4.2.0 /opt/iobroker/node_modules/sort-keys
      npm ERR! extraneous: sorted-array-functions@ /opt/iobroker/node_modules/sorted-a        rray-functions
      npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/source-map-s        upport
      npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/spdx-correct
      npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-excep        tions
      npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/spdx-expr        ession-parse
      npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-lic        ense-ids
      npm ERR! extraneous: split2@ /opt/iobroker/node_modules/split2
      npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
      npm ERR! extraneous: standard-as-callback@ /opt/iobroker/node_modules/standard-a        s-callback
      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/statuses
      npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-        require
      npm ERR! extraneous: stop-iteration-iterator@1.0.0 /opt/iobroker/node_modules/st        op-iteration-iterator
      npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/stream-shift
      npm ERR! extraneous: streamsearch@ /opt/iobroker/node_modules/streamsearch
      npm ERR! extraneous: streamx@2.13.2 /opt/iobroker/node_modules/streamx
      npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string        .prototype.trimend
      npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/stri        ng.prototype.trimstart
      npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
      npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-        json-comments
      npm ERR! extraneous: strnum@ /opt/iobroker/node_modules/strnum
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules        /supports-preserve-symlinks-flag
      npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminforma        tion
      npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
      npm ERR! extraneous: tar-stream@ /opt/iobroker/node_modules/tar-stream
      npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
      npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
      npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
      npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
      npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
      npm ERR! extraneous: thunky@1.1.0 /opt/iobroker/node_modules/thunky
      npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
      npm ERR! extraneous: treemap-js@1.2.1 /opt/iobroker/node_modules/treemap-js
      npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/tslib
      npm ERR! extraneous: tuyapi@ /opt/iobroker/node_modules/tuyapi
      npm ERR! extraneous: tweetnacl@ /opt/iobroker/node_modules/tweetnacl
      npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
      npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
      npm ERR! extraneous: ultron@1.1.1 /opt/iobroker/node_modules/ultron
      npm ERR! extraneous: unbox-primitive@ /opt/iobroker/node_modules/unbox-primitive
      npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/universalify
      npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram
      npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
      npm ERR! extraneous: url-parse@ /opt/iobroker/node_modules/url-parse
      npm ERR! extraneous: usb@ /opt/iobroker/node_modules/usb
      npm ERR! extraneous: util@ /opt/iobroker/node_modules/util
      npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/uuid
      npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modul        es/validate-npm-package-license
      npm ERR! extraneous: virtual-tsc@ /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: vows@ /opt/iobroker/node_modules/vows
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
      npm ERR! extraneous: websocket-stream@ /opt/iobroker/node_modules/websocket-stre        am
      npm ERR! extraneous: which-boxed-primitive@ /opt/iobroker/node_modules/which-box        ed-primitive
      npm ERR! extraneous: which-collection@ /opt/iobroker/node_modules/which-collecti        on
      npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
      npm ERR! extraneous: which-typed-array@ /opt/iobroker/node_modules/which-typed-a        rray
      npm ERR! extraneous: which@ /opt/iobroker/node_modules/which
      npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
      npm ERR! extraneous: winston-daily-rotate-file@ /opt/iobroker/node_modules/winst        on-daily-rotate-file
      npm ERR! extraneous: winston-seq-updated@ /opt/iobroker/node_modules/winston-seq        -updated
      npm ERR! extraneous: winston-syslog@ /opt/iobroker/node_modules/winston-syslog
      npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-trans        port
        @subman82
        iob diag
        subman82
        @subman82
        iob diag
        Teil3
        npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
        npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
        npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
        npm ERR! extraneous: xml2js@ /opt/iobroker/node_modules/xml2js
        npm ERR! extraneous: xmlbuilder@ /opt/iobroker/node_modules/xmlbuilder
        npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttpreque        st-ssl
        npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
        npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
        npm ERR! extraneous: yallist@ /opt/iobroker/node_modules/yallist
        npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/yargs-parser
        npm ERR! extraneous: yargs@7.1.2 /opt/iobroker/node_modules/yargs
        npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
        npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigb        ee-herdsman-converters
        npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
        npm ERR! extraneous: zlib@ /opt/iobroker/node_modules/zlib
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-08        -04T14_02_48_865Z-debug-0.log
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
        + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
        + system.adapter.harmony.0                : harmony               : raspberrypi        -  enabled
        + system.adapter.hue.0                    : hue                   : raspberrypi        -  enabled, port: 80
        + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi        -  enabled, port: 54321
        + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi        -  enabled, port: 54321
        + system.adapter.mihome-vacuum.3          : mihome-vacuum         : raspberrypi        -  enabled, port: 54321
        + system.adapter.scenes.0                 : scenes                : raspberrypi        -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : raspberrypi        -  enabled, port: 8088, bind: 0.0.0.0, run as: admi        n
        + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
        + system.adapter.yahka.0                  : yahka                 : raspberrypi        -  enabled
          system.adapter.zigbee.0                 : zigbee                : raspberrypi        - disabled, port: /dev/serial/by-id/usb-Texas_Instr        uments_TI_CC2531_USB_CDC___0X00124B001CDD2589-if00
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "hue"          : 3.9.3    , installed 3.7.1  [Updatable]
        Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
        Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
        Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
        Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
        Adapter    "yahka"        : 0.17.0   , installed 0.17.0
        Adapter    "zigbee"       : 1.8.21   , installed 1.8.10 [Updatable]
        Objects and States
        Objects:        3649
        States:         2992
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          17832      815/sshd
        tcp        0      0 127.0.0.1:36391         0.0.0.0:*               LISTEN        1001       19328      1443/io.yahka.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       19576      803/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       18022      803/iobroker.js-con
        tcp6       0      0 :::8081                 :::*                    LISTEN        1001       19734      1099/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN        1001       18397      1462/io.web.0
        tcp6       0      0 ::1:3350                :::*                    LISTEN        0          17850      828/xrdp-sesman
        tcp6       0      0 :::22                   :::*                    LISTEN        0          17834      815/sshd
        tcp6       0      0 :::45655                :::*                    LISTEN        1001       20005      1443/io.yahka.0
        tcp6       0      0 :::8088                 :::*                    LISTEN        1001       20573      1477/io.terminal.0
        tcp6       0      0 :::3389                 :::*                    LISTEN        109        17973      838/xrdp
        tcp6       0      0 :::61991                :::*                    LISTEN        1001       21551      1515/io.harmony.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*        1001       19912      1326/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*        1001       19913      1326/io.tuya.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*        1001       21552      1515/io.harmony.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*        1001       19180      1293/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*        0          13962      776/dhcpcd
        udp        0      0 0.0.0.0:53421           0.0.0.0:*        1001       19863      1257/io.mihome-vacu
        udp        0      0 0.0.0.0:53422           0.0.0.0:*        1001       19809      1200/io.mihome-vacu
        udp        0      0 0.0.0.0:53423           0.0.0.0:*        1001       17228      1356/io.mihome-vacu
        udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        16202      405/avahi-daemon: r
        udp        0      0 0.0.0.0:50965           0.0.0.0:*        108        16204      405/avahi-daemon: r
        udp6       0      0 :::546                  :::*        0          14068      776/dhcpcd
        udp6       0      0 :::5353                 :::*        108        16203      405/avahi-daemon: r
        udp6       0      0 :::59767                :::*        108        16205      405/avahi-daemon: r
        2023-08-04 15:56:04.651  - info: tuya.0 (1326) bf66b065e83070ea19sf28 Init with        IP=192.168.178.115, Key=c23d4c3e93980fc5, Version=3.3
        2023-08-04 15:56:17.268  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Connect l        ocally to device
        2023-08-04 15:56:17.269  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq Init with        IP=192.168.178.101, Key=cf54c395f378ab9d, Version=3.3
        2023-08-04 15:56:49.782  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 15:57:02.582  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.101:6668
        2023-08-04 15:57:12.901  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 15:57:25.702  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.101:6668
        2023-08-04 15:57:56.022  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 15:58:08.822  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.101:6668
        2023-08-04 15:59:11.942  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (7): connect EHOSTUNREACH 192.168.178.101:6668
        2023-08-04 15:59:38.451  - info: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Connect l        ocally to device
        2023-08-04 15:59:38.452  - info: tuya.0 (1326) bf6f0250c5ef2fb014cm6f Init with        IP=192.168.178.112, Key=796c7530b906c459, Version=3.3
        2023-08-04 15:59:39.782  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 16:00:02.903  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 16:00:23.782  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.112:6668
        2023-08-04 16:00:46.022  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 16:00:46.902  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.112:6668
        2023-08-04 16:01:30.022  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.112:6668
        2023-08-04 16:01:37.379  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Connect l        ocally to device
        2023-08-04 16:01:37.380  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq Init with        IP=192.168.178.101, Key=cf54c395f378ab9d, Version=3.3
        2023-08-04 16:01:49.143  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (7): connect EHOSTUNREACH 192.168.178.115:6668
        2023-08-04 16:02:22.742  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.101:6668
        2023-08-04 16:02:33.142  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (7): connect EHOSTUNREACH 192.168.178.112:6668
        2023-08-04 16:02:45.862  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.101:6668
        2023-08-04 16:03:28.981  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.101:6668
        • S subman82
          @subman82
          iob diag
          Teil3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        3649
          States:         2992
          Pending Updates: 1
          @subman82
          Da hat es den npm tree zerzaust. Bei den ganzen ERRs auch kein Wunder das die Ausgabe so lang ist.
          cd /opt/iobroker
          npm prune
          npm ls
          S 2 Antworten Letzte Antwort
          • DJMarc75D DJMarc75
            subman82
            @djmarc75 said in js-controller lässts sich nicht updaten:
            Ich hatte putty auf die gesamte Bildschirmgröße gezogen,komisch.
            Ich muss jetzt leider los, ich schau später nochmal hier rein und schau mal wie ich das OS aktualisiert bekomme.
            Die Adapter habe ich auch trotz Cache löschen und Neustart nicht aktualisiert bekommen.
            Vielen Dank für eure Hilfe schon mal und sorry, dass ich so unerfahren mit iobroker und schreiben in Foren bin.
            Bis später .
            • S subman82
              Bis später .
              schreiben in Foren
              kann man lernen!
              Bitte lesen und befolgen
                @subman82
                cd /opt/iobroker
                npm prune
                npm ls
                subman82
                @subman82
                cd /opt/iobroker
                npm prune
                npm ls
                Das Ergebnis ist wieder sehr lang daher wieder mehrer Teile.
                pi@raspberrypi:~ $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ npm prune
                npm ERR! builtins is not a function
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-06T14_37_56_241Z-debug-0.log
                pi@raspberrypi:/opt/iobroker $ npm ls
                npm ERR! extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                npm ERR! extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
                npm ERR! extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
                npm ERR! extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                npm ERR! extraneous: @apollon/iobroker-tools@ /opt/iobroker/node_modules/@apollon/iobroker-tools
                npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
                npm ERR! extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
                npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/drive
                npm ERR! extraneous: @harmonyhub/discover@ /opt/iobroker/node_modules/@harmonyhub/discover
                npm ERR! extraneous: @homebridge/ciao@ /opt/iobroker/node_modules/@homebridge/ciao
                npm ERR! extraneous: @homebridge/dbus-native@0.4.2 /opt/iobroker/node_modules/@homebridge/dbus-native
                npm ERR! extraneous: @homebridge/long@5.2.1 /opt/iobroker/node_modules/@homebridge/long
                npm ERR! extraneous: @homebridge/put@0.0.8 /opt/iobroker/node_modules/@homebridge/put
                npm ERR! extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
                npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                npm ERR! extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                npm ERR! extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                npm ERR! extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                npm ERR! extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                npm ERR! extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
                npm ERR! extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
                npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
                npm ERR! extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
                npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
                npm ERR! extraneous: @sentry/browser@5.12.1 /opt/iobroker/node_modules/@sentry/browser
                npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
                npm ERR! extraneous: @serialport/binding-abstract@ /opt/iobroker/node_modules/@serialport/binding-abstract
                npm ERR! extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
                npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
                npm ERR! extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
                npm ERR! extraneous: @serialport/bindings@ /opt/iobroker/node_modules/@serialport/bindings
                npm ERR! extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
                npm ERR! extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
                npm ERR! extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
                npm ERR! extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-        timeout
                npm ERR! extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
                npm ERR! extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
                npm ERR! extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
                npm ERR! extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
                npm ERR! extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                npm ERR! extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
                npm ERR! extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
                npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
                npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                npm ERR! extraneous: @tuyapi/cloud@0.6.1 /opt/iobroker/node_modules/@tuyapi/cloud
                npm ERR! extraneous: @types/babel-types@7.0.11 /opt/iobroker/node_modules/@types/babel-types
                npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                npm ERR! extraneous: @types/readable-stream@2.3.15 /opt/iobroker/node_modules/@types/readable-stream
                npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
                npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                npm ERR! extraneous: acme-http-01-standalone@ /opt/iobroker/node_modules/acme-http-01-standalone
                npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
                npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
                npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
                npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
                npm ERR! extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
                npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
                npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-arraybuffer
                npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
                npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
                npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                npm ERR! extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
                npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
                npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                npm ERR! extraneous: concat-stream@2.0.0 /opt/iobroker/node_modules/concat-stream
                npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decompress-response
                npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
                npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
                npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
                npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
                npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast-json-stable-stringify
                npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream-rotator
                npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/function.prototype.name
                npm ERR! extraneous: functions-have-names@ /opt/iobroker/node_modules/functions-have-names
                npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                npm ERR! extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                npm ERR! extraneous: get-symbol-description@ /opt/iobroker/node_modules/get-symbol-description
                npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
                npm ERR! extraneous: greenlock-express@ /opt/iobroker/node_modules/greenlock-express
                npm ERR! extraneous: greenlock-store-fs@ /opt/iobroker/node_modules/greenlock-store-fs
                npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/has-property-descriptors
                npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-proxy
                npm ERR! extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/https-proxy-agent
                npm ERR! invalid: iobroker.backitup@2.6.19 /opt/iobroker/node_modules/iobroker.backitup
                npm ERR! extraneous: iobroker.device-reminder@1.2.9 /opt/iobroker/node_modules/iobroker.device-reminder
                npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                npm ERR! extraneous: iobroker.harmony@1.2.2 /opt/iobroker/node_modules/iobroker.harmony
                npm ERR! extraneous: iobroker.info@1.9.26 /opt/iobroker/node_modules/iobroker.info
                npm ERR! extraneous: iobroker.javascript@6.1.4 /opt/iobroker/node_modules/iobroker.javascript
                npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! extraneous: iobroker.mihome-vacuum@3.9.5 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                npm ERR! extraneous: iobroker.mihome@1.4.0 /opt/iobroker/node_modules/iobroker.mihome
                npm ERR! extraneous: iobroker.mqtt@4.0.7 /opt/iobroker/node_modules/iobroker.mqtt
                npm ERR! extraneous: iobroker.scenes@2.3.9 /opt/iobroker/node_modules/iobroker.scenes
                npm ERR! extraneous: iobroker.shelly@6.3.1 /opt/iobroker/node_modules/iobroker.shelly
                npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobroker.simple-api
                npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
                npm ERR! extraneous: iobroker.terminal@1.0.0 /opt/iobroker/node_modules/iobroker.terminal
                npm ERR! extraneous: iobroker.tuya@3.13.1 /opt/iobroker/node_modules/iobroker.tuya
                npm ERR! extraneous: iobroker.ws.server@ /opt/iobroker/node_modules/iobroker.ws.server
                npm ERR! extraneous: iobroker.yahka@0.17.0 /opt/iobroker/node_modules/iobroker.yahka
                npm ERR! extraneous: iobroker.zigbee@1.8.10 /opt/iobroker/node_modules/iobroker.zigbee
                npm ERR! extraneous: is-array-buffer@3.0.2 /opt/iobroker/node_modules/is-array-buffer
                npm ERR! extraneous: is-boolean-object@ /opt/iobroker/node_modules/is-boolean-object
                npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/is-generator-function
                npm ERR! extraneous: is-negative-zero@ /opt/iobroker/node_modules/is-negative-zero
                npm ERR! extraneous: is-number-object@ /opt/iobroker/node_modules/is-number-object
                npm ERR! extraneous: is-shared-array-buffer@ /opt/iobroker/node_modules/is-shared-array-buffer
                npm ERR! extraneous: libsodium-wrappers@ /opt/iobroker/node_modules/libsodium-wrappers
                npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
                npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
                npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
                npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
                npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocator
                npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
                npm ERR! extraneous: prebuild-install@ /opt/iobroker/node_modules/prebuild-install
                npm ERR! extraneous: proper-lockfile@4.1.2 /opt/iobroker/node_modules/proper-lockfile
                npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.prototype.flags
                npm ERR! extraneous: request-promise-core@ /opt/iobroker/node_modules/request-promise-core
                npm ERR! extraneous: request-promise-native@ /opt/iobroker/node_modules/request-promise-native
                npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                npm ERR! extraneous: safe-stable-stringify@ /opt/iobroker/node_modules/safe-stable-stringify
                npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
                npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-client
                npm ERR! extraneous: socket.io-parser@3.4.1 /opt/iobroker/node_modules/socket.io-parser
                npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-keys-recursive
                npm ERR! extraneous: sorted-array-functions@ /opt/iobroker/node_modules/sorted-array-functions
                npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/source-map-support
                npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/spdx-expression-parse
                npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-license-ids
                npm ERR! extraneous: standard-as-callback@ /opt/iobroker/node_modules/standard-as-callback
                npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                npm ERR! extraneous: stop-iteration-iterator@1.0.0 /opt/iobroker/node_modules/stop-iteration-iterator
                npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string.prototype.trimend
                npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/string.prototype.trimstart
                npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                npm ERR! extraneous: websocket-stream@ /opt/iobroker/node_modules/websocket-stream
                npm ERR! extraneous: which-boxed-primitive@ /opt/iobroker/node_modules/which-boxed-primitive
                npm ERR! extraneous: which-collection@ /opt/iobroker/node_modules/which-collection
                npm ERR! extraneous: which-typed-array@ /opt/iobroker/node_modules/which-typed-array
                npm ERR! extraneous: winston-daily-rotate-file@ /opt/iobroker/node_modules/winston-daily-rotate-file
                npm ERR! extraneous: winston-seq-updated@ /opt/iobroker/node_modules/winston-seq-updated
                npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-transport
                npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttprequest-ssl
                npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
                  @subman82
                  cd /opt/iobroker
                  npm prune
                  npm ls
                  subman82
                  @thomas-braun said in js-controller lässts sich nicht updaten:
                  @subman82
                  cd /opt/iobroker
                  npm prune
                  npm ls
                  Teil2 von2
                  iobroker.inst@3.0.0 /opt/iobroker
                  ├── @abandonware/bluetooth-hci-socket@ extraneous
                  ├── @abandonware/noble@ extraneous
                  ├── @alcalzone/jsonl-db@ extraneous
                  ├── @alcalzone/pak@ extraneous
                  ├── @alcalzone/proper-lockfile@ extraneous
                  ├── @apollon/iobroker-tools@ extraneous
                  ├── @colors/colors@ extraneous
                  ├── @dabh/diagnostics@ extraneous
                  ├── @datalust/winston-seq@ extraneous
                  ├── @googleapis/drive@ extraneous
                  ├── @harmonyhub/discover@ extraneous
                  ├── @homebridge/ciao@ extraneous
                  ├── @homebridge/dbus-native@0.4.2 extraneous
                  ├── @homebridge/long@5.2.1 extraneous
                  ├── @homebridge/put@0.0.8 extraneous
                  ├── @iobroker/adapter-core@ extraneous
                  ├── @iobroker/db-base@ extraneous
                  ├── @iobroker/db-objects-file@ extraneous
                  ├── @iobroker/db-objects-jsonl@ extraneous
                  ├── @iobroker/db-objects-redis@ extraneous
                  ├── @iobroker/db-states-file@ extraneous
                  ├── @iobroker/db-states-jsonl@ extraneous
                  ├── @iobroker/db-states-redis@ extraneous
                  ├── @iobroker/js-controller-adapter@ extraneous
                  ├── @iobroker/js-controller-cli@ extraneous
                  ├── @iobroker/js-controller-common-db@ extraneous
                  ├── @iobroker/js-controller-common@ extraneous
                  ├── @iobroker/plugin-base@ extraneous
                  ├── @iobroker/plugin-sentry@ extraneous
                  ├── @iobroker/socket-classes@ extraneous
                  ├── @leichtgewicht/ip-codec@ extraneous
                  ├── @mapbox/node-pre-gyp@ extraneous
                  ├── @protobufjs/aspromise@1.1.2 extraneous
                  ├── @protobufjs/inquire@1.1.0 extraneous
                  ├── @root/acme@ extraneous
                  ├── @root/asn1@ extraneous
                  ├── @root/csr@ extraneous
                  ├── @root/encoding@ extraneous
                  ├── @root/greenlock-express@ extraneous
                  ├── @root/greenlock@ extraneous
                  ├── @root/keypairs@ extraneous
                  ├── @root/pem@ extraneous
                  ├── @root/request@ extraneous
                  ├── @root/x509@ extraneous
                  ├── @sentry/browser@5.12.1 extraneous
                  ├── @sentry/core@ extraneous
                  ├── @sentry/hub@ extraneous
                  ├── @sentry/integrations@ extraneous
                  ├── @sentry/minimal@ extraneous
                  ├── @sentry/node@ extraneous
                  ├── @sentry/types@ extraneous
                  ├── @sentry/utils@ extraneous
                  ├── @serialport/binding-abstract@ extraneous
                  ├── @serialport/binding-mock@ extraneous
                  ├── @serialport/bindings-cpp@ extraneous
                  ├── @serialport/bindings-interface@ extraneous
                  ├── @serialport/bindings@ extraneous
                  ├── @serialport/parser-byte-length@ extraneous
                  ├── @serialport/parser-cctalk@ extraneous
                  ├── @serialport/parser-delimiter@ extraneous
                  ├── @serialport/parser-inter-byte-timeout@ extraneous
                  ├── @serialport/parser-packet-length@ extraneous
                  ├── @serialport/parser-readline@ extraneous
                  ├── @serialport/parser-ready@ extraneous
                  ├── @serialport/parser-regex@ extraneous
                  ├── @serialport/parser-slip-encoder@ extraneous
                  ├── @serialport/parser-spacepacket@ extraneous
                  ├── @serialport/stream@ extraneous
                  ├── @sindresorhus/is@4.6.0 extraneous
                  ├── @socket.io/component-emitter@3.1.0 extraneous
                  ├── @szmarczak/http-timer@4.0.6 extraneous
                  ├── @tuyapi/cloud@0.6.1 extraneous
                  ├── @types/babel-types@7.0.11 extraneous
                  ├── @types/bl@ extraneous
                  ├── @types/cacheable-request@6.0.3 extraneous
                  ├── @types/caseless@0.12.2 extraneous
                  ├── @types/cookie@ extraneous
                  ├── @types/cors@ extraneous
                  ├── @types/iobroker@ extraneous
                  ├── @types/keyv@3.1.4 extraneous
                  ├── @types/readable-stream@2.3.15 extraneous
                  ├── @types/request@ extraneous
                  ├── @types/responselike@1.0.0 extraneous
                  ├── @types/retry@0.12.0 extraneous
                  ├── @types/tough-cookie@4.0.2 extraneous
                  ├── abbrev@1.1.1 extraneous
                  ├── abort-controller@3.0.0 extraneous
                  ├── acme-http-01-standalone@ extraneous
                  ├── after@0.8.2 extraneous
                  ├── agent-base@ extraneous
                  ├── ajv@ extraneous
                  ├── alcalzone-shared@ extraneous
                  ├── any-promise@1.3.0 extraneous
                  ├── aproba@2.0.0 extraneous
                  ├── are-we-there-yet@ extraneous
                  ├── arraybuffer.slice@0.0.7 extraneous
                  ├── asn1@ extraneous
                  ├── async-limiter@1.0.1 extraneous
                  ├── async@ extraneous
                  ├── authenticate-pam@1.0.5 extraneous
                  ├── autobind-decorator@2.4.0 extraneous
                  ├── available-typed-arrays@ extraneous
                  ├── aws4@ extraneous
                  ├── axios@ extraneous
                  ├── b4a@1.6.1 extraneous
                  ├── backo2@1.0.2 extraneous
                  ├── base64-arraybuffer@0.1.4 extraneous
                  ├── base64-js@ extraneous
                  ├── base64id@2.0.0 extraneous
                  ├── bignumber.js@ extraneous
                  ├── binary-extensions@ extraneous
                  ├── bl@ extraneous
                  ├── blob@0.0.5 extraneous
                  ├── body-parser@ extraneous
                  ├── bonjour-hap@ extraneous
                  ├── bottleneck@2.19.5 extraneous
                  ├── brace-expansion@1.1.11 extraneous
                  ├── buffer-crc32@0.2.13 extraneous
                  ├── buffer@ extraneous
                  ├── busboy@ extraneous
                  ├── cacheable-lookup@5.0.4 extraneous
                  ├── cacheable-request@7.0.2 extraneous
                  ├── call-bind@ extraneous
                  ├── camelcase@3.0.0 extraneous
                  ├── canvas@ extraneous
                  ├── capitalize@2.0.4 extraneous
                  ├── chokidar@ extraneous
                  ├── cliui@3.2.0 extraneous
                  ├── clone-response@1.0.3 extraneous
                  ├── cluster-key-slot@ extraneous
                  ├── coap-packet@1.1.1 extraneous
                  ├── coap@ extraneous
                  ├── code-point-at@1.1.0 extraneous
                  ├── coffeescript@1.12.7 extraneous
                  ├── coiot-coap@ extraneous
                  ├── color-support@1.1.3 extraneous
                  ├── colors@1.4.0 extraneous
                  ├── commander@ extraneous
                  ├── commist@1.1.0 extraneous
                  ├── component-bind@1.0.0 extraneous
                  ├── component-emitter@1.3.0 extraneous
                  ├── component-inherit@0.0.3 extraneous
                  ├── compressible@ extraneous
                  ├── concat-map@0.0.1 extraneous
                  ├── concat-stream@2.0.0 extraneous
                  ├── connect@3.7.0 extraneous
                  ├── console-control-strings@1.1.0 extraneous
                  ├── core-util-is@ extraneous
                  ├── cors@2.8.5 extraneous
                  ├── cron-parser@ extraneous
                  ├── cross-spawn@ extraneous
                  ├── crypto-js@4.1.1 extraneous
                  ├── crypto@1.0.1 extraneous
                  ├── debounce@ extraneous
                  ├── decache@ extraneous
                  ├── decamelize@1.2.0 extraneous
                  ├── decompress-response@4.2.1 extraneous
                  ├── deep-equal@ extraneous
                  ├── deep-extend@0.6.0 extraneous
                  ├── define-properties@ extraneous
                  ├── delegates@1.0.0 extraneous
                  ├── detect-libc@ extraneous
                  ├── dev-null@0.1.1 extraneous
                  ├── dijkstrajs@ extraneous
                  ├── dns-packet@ extraneous
                  ├── dropbox-v2-api@ extraneous
                  ├── duplexer@ extraneous
                  ├── duplexify@ extraneous
                  ├── ecc-jsbn@ extraneous
                  ├── encode-utf8@1.0.3 extraneous
                  ├── engine.io-client@ extraneous
                  ├── engine.io-parser@ extraneous
                  ├── engine.io@ extraneous
                  ├── error-ex@1.3.2 extraneous
                  ├── es-abstract@ extraneous
                  ├── es-get-iterator@ extraneous
                  ├── es-to-primitive@ extraneous
                  ├── es6-promisify@5.0.0 extraneous
                  ├── esbuild@ extraneous
                  ├── escalade@ extraneous
                  ├── event-target-shim@5.0.1 extraneous
                  ├── eventemitter3@ extraneous
                  ├── events@3.3.0 extraneous
                  ├── execa@ extraneous
                  ├── express-fileupload@ extraneous
                  ├── express-session@ extraneous
                  ├── express@ extraneous
                  ├── fast-deep-equal@ extraneous
                  ├── fast-fifo@1.1.0 extraneous
                  ├── fast-json-stable-stringify@ extraneous
                  ├── fast-srp-hap@ extraneous
                  ├── fast-xml-parser@ extraneous
                  ├── fastseries@ extraneous
                  ├── fecha@ extraneous
                  ├── file-stream-rotator@ extraneous
                  ├── find-up@1.1.2 extraneous
                  ├── for-each@0.3.3 extraneous
                  ├── form-data@ extraneous
                  ├── fs-extra@7.0.1 extraneous
                  ├── fs.realpath@1.0.0 extraneous
                  ├── ftp@ extraneous
                  ├── function.prototype.name@ extraneous
                  ├── functions-have-names@ extraneous
                  ├── futoin-hkdf@1.4.3 extraneous
                  ├── gauge@ extraneous
                  ├── gaxios@ extraneous
                  ├── gcp-metadata@ extraneous
                  ├── get-caller-file@1.0.3 extraneous
                  ├── get-intrinsic@ extraneous
                  ├── get-ssl-certificate@2.3.3 extraneous
                  ├── get-stream@ extraneous
                  ├── get-symbol-description@ extraneous
                  ├── glob@ extraneous
                  ├── google-auth-library@ extraneous
                  ├── google-p12-pem@ extraneous
                  ├── googleapis-common@ extraneous
                  ├── gopd@1.0.1 extraneous
                  ├── got@11.8.6 extraneous
                  ├── graceful-fs@ extraneous
                  ├── greenlock-express@ extraneous
                  ├── greenlock-store-fs@ extraneous
                  ├── gtoken@ extraneous
                  ├── hap-controller@ extraneous
                  ├── hap-nodejs@ extraneous
                  ├── har-validator@ extraneous
                  ├── harmonyhubws@1.0.6 extraneous
                  ├── has-bigints@ extraneous
                  ├── has-binary2@1.0.3 extraneous
                  ├── has-cors@1.1.0 extraneous
                  ├── has-property-descriptors@ extraneous
                  ├── has-symbols@ extraneous
                  ├── has-tostringtag@ extraneous
                  ├── has-unicode@2.0.1 extraneous
                  ├── help-me@ extraneous
                  ├── hexy@0.2.11 extraneous
                  ├── hosted-git-info@ extraneous
                  ├── http-mitm-proxy@0.9.0 extraneous
                  ├── http2-wrapper@1.0.3 extraneous
                  ├── https-proxy-agent@ extraneous
                  ├── human-signals@ extraneous
                  ├── indexof@0.0.1 extraneous
                  ├── inflight@1.0.6 extraneous
                  ├── ini@1.3.8 extraneous
                  ├── internal-slot@ extraneous
                  ├── invert-kv@1.0.0 extraneous
                  ├── iobroker.admin@6.3.5 invalid: "stable" from the root project
                  ├── iobroker.backitup@2.6.19 invalid: "stable" from the root project
                  ├── iobroker.device-reminder@1.2.9 extraneous
                  ├── iobroker.discovery@3.1.0 invalid: "stable" from the root project
                  ├── iobroker.harmony@1.2.2 extraneous
                  ├── iobroker.hue@3.7.1 extraneous
                  ├── iobroker.info@1.9.26 extraneous
                  ├── iobroker.javascript@6.1.4 extraneous
                  ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
                  ├── iobroker.mihome-vacuum@3.9.5 extraneous
                  ├── iobroker.mihome@1.4.0 extraneous
                  ├── iobroker.mqtt@4.0.7 extraneous
                  ├── iobroker.scenes@2.3.9 extraneous
                  ├── iobroker.shelly@6.3.1 extraneous
                  ├── iobroker.simple-api@2.7.2 extraneous
                  ├── iobroker.socketio@4.2.0 extraneous
                  ├── iobroker.terminal@1.0.0 extraneous
                  ├── iobroker.tuya@3.13.1 extraneous
                  ├── iobroker.vis@1.4.16 extraneous
                  ├── iobroker.web@4.3.0 extraneous
                  ├── iobroker.ws.server@ extraneous
                  ├── iobroker.ws@ extraneous
                  ├── iobroker.yahka@0.17.0 extraneous
                  ├── iobroker.zigbee@1.8.10 extraneous
                  ├── iobroker@2.0.3 extraneous
                  ├── ioredis@ extraneous
                  ├── ip@ extraneous
                  ├── is-arguments@ extraneous
                  ├── is-array-buffer@3.0.2 extraneous
                  ├── is-bigint@ extraneous
                  ├── is-boolean-object@ extraneous
                  ├── is-callable@ extraneous
                  ├── is-core-module@ extraneous
                  ├── is-date-object@ extraneous
                  ├── is-generator-function@ extraneous
                  ├── is-map@ extraneous
                  ├── is-nan@ extraneous
                  ├── is-negative-zero@ extraneous
                  ├── is-number-object@ extraneous
                  ├── is-plain-obj@2.1.0 extraneous
                  ├── is-regex@ extraneous
                  ├── is-set@ extraneous
                  ├── is-shared-array-buffer@ extraneous
                  ├── is-string@ extraneous
                  ├── is-symbol@ extraneous
                  ├── is-typed-array@ extraneous
                  ├── is-utf8@0.2.1 extraneous
                  ├── is-weakmap@ extraneous
                  ├── is-weakref@ extraneous
                  ├── is-weakset@ extraneous
                  ├── isarray@2.0.5 extraneous
                  ├── js-sdsl@ extraneous
                  ├── jshashes@1.0.8 extraneous
                  ├── json-bigint@ extraneous
                  ├── json-schema@ extraneous
                  ├── jsonata@ extraneous
                  ├── jsonc-parser@ extraneous
                  ├── jsonfile@4.0.0 extraneous
                  ├── jsprim@ extraneous
                  ├── jszip@ extraneous
                  ├── jws@ extraneous
                  ├── kind-of@6.0.3 extraneous
                  ├── layerr@ extraneous
                  ├── lcid@1.0.0 extraneous
                  ├── leven@2.1.0 extraneous
                  ├── libsodium-wrappers@ extraneous
                  ├── libsodium@ extraneous
                  ├── lie@3.3.0 extraneous
                  ├── load-json-file@1.1.0 extraneous
                  ├── localforage@ extraneous
                  ├── locate-path@5.0.0 extraneous
                  ├── lodash@ extraneous
                  ├── logform@ extraneous
                  ├── lowercase-keys@2.0.0 extraneous
                  ├── luxon@ extraneous
                  ├── macaddress@ extraneous
                  ├── make-dir@3.1.0 extraneous
                  ├── math-random@1.0.4 extraneous
                  ├── mime-db@ extraneous
                  ├── mime@ extraneous
                  ├── mimic-response@2.1.0 extraneous
                  ├── minimatch@ extraneous
                  ├── minimist@ extraneous
                  ├── minipass@ extraneous
                  ├── minizlib@ extraneous
                  ├── mixin-deep@2.0.1 extraneous
                  ├── mkdirp@ extraneous
                  ├── moment@ extraneous
                  ├── mqtt-connection@ extraneous
                  ├── mqtt-packet@ extraneous
                  ├── mqtt@ extraneous
                  ├── multicast-dns-service-types@1.1.0 extraneous
                  ├── multicast-dns@ extraneous
                  ├── mz@2.7.0 extraneous
                  ├── nan@ extraneous
                  ├── negotiator@ extraneous
                  ├── nested-property@ extraneous
                  ├── netmask@ extraneous
                  ├── node-abi@ extraneous
                  ├── node-addon-api@ extraneous
                  ├── node-fetch@ extraneous
                  ├── node-forge@ extraneous
                  ├── node-gyp-build@ extraneous
                  ├── node-hue-api@ extraneous
                  ├── node-inspect@ extraneous
                  ├── node-persist@0.0.11 extraneous
                  ├── node-rest-client@ extraneous
                  ├── node-rsa@1.1.1 extraneous
                  ├── node-schedule@ extraneous
                  ├── node-ssdp@ extraneous
                  ├── nopt@ extraneous
                  ├── normalize-package-data@2.5.0 extraneous
                  ├── normalize-url@6.1.0 extraneous
                  ├── npmlog@ extraneous
                  ├── number-allocator@ extraneous
                  ├── number-is-nan@1.0.1 extraneous
                  ├── object-assign@4.1.1 extraneous
                  ├── object-hash@ extraneous
                  ├── object-inspect@ extraneous
                  ├── object-is@ extraneous
                  ├── object.assign@ extraneous
                  ├── os-locale@1.4.0 extraneous
                  ├── osx-temperature-sensor@ extraneous
                  ├── p-cancelable@2.1.1 extraneous
                  ├── p-finally@1.0.0 extraneous
                  ├── p-limit@2.3.0 extraneous
                  ├── p-locate@4.1.0 extraneous
                  ├── p-queue@ extraneous
                  ├── p-retry@4.6.2 extraneous
                  ├── p-timeout@3.2.0 extraneous
                  ├── p-try@2.2.0 extraneous
                  ├── pako@ extraneous
                  ├── parse-json@2.2.0 extraneous
                  ├── parseqs@ extraneous
                  ├── parseuri@0.0.6 extraneous
                  ├── passport@ extraneous
                  ├── path-exists@2.1.0 extraneous
                  ├── path-is-absolute@1.0.1 extraneous
                  ├── path-parse@1.0.7 extraneous
                  ├── path-type@1.1.0 extraneous
                  ├── picocolors@ extraneous
                  ├── picomatch@ extraneous
                  ├── pidtree@ extraneous
                  ├── pidusage@ extraneous
                  ├── pify@2.3.0 extraneous
                  ├── pinkie-promise@2.0.1 extraneous
                  ├── pinkie@2.0.4 extraneous
                  ├── pngjs@ extraneous
                  ├── prebuild-install@ extraneous
                  ├── process@0.11.10 extraneous
                  ├── prompt@ extraneous
                  ├── proper-lockfile@4.1.2 extraneous
                  ├── psl@ extraneous
                  ├── q@1.1.2 extraneous
                  ├── qrcode@ extraneous
                  ├── qs@ extraneous
                  ├── queue-tick@1.0.1 extraneous
                  ├── randomatic@3.1.1 extraneous
                  ├── read-pkg-up@1.0.1 extraneous
                  ├── read-pkg@1.1.0 extraneous
                  ├── redirect-https@ extraneous
                  ├── redis-commands@ extraneous
                  ├── regexp.prototype.flags@ extraneous
                  ├── reinterval@1.1.0 extraneous
                  ├── request-promise-core@ extraneous
                  ├── request-promise-native@ extraneous
                  ├── request@ extraneous
                  ├── require-main-filename@1.0.1 extraneous
                  ├── resolve@ extraneous
                  ├── responselike@2.0.1 extraneous
                  ├── rfdc@ extraneous
                  ├── rimraf@ extraneous
                  ├── safe-stable-stringify@ extraneous
                  ├── sax@1.2.4 extraneous
                  ├── semaphore@1.1.0 extraneous
                  ├── semver@5.7.1 extraneous
                  ├── send@ extraneous
                  ├── seq-logging@ extraneous
                  ├── serialport@ extraneous
                  ├── set-blocking@2.0.0 extraneous
                  ├── shelly-iot@ extraneous
                  ├── side-channel@ extraneous
                  ├── simple-concat@ extraneous
                  ├── simple-get@3.1.1 extraneous
                  ├── slip@1.0.2 extraneous
                  ├── socket.io-adapter@1.1.2 extraneous
                  ├── socket.io-client@ extraneous
                  ├── socket.io-parser@3.4.1 extraneous
                  ├── socket.io@ extraneous
                  ├── sort-keys-recursive@2.1.8 extraneous
                  ├── sort-keys@4.2.0 extraneous
                  ├── sorted-array-functions@ extraneous
                  ├── source-map-support@ extraneous
                  ├── spdx-correct@ extraneous
                  ├── spdx-exceptions@2.3.0 extraneous
                  ├── spdx-expression-parse@ extraneous
                  ├── spdx-license-ids@3.0.12 extraneous
                  ├── split2@ extraneous
                  ├── sshpk@ extraneous
                  ├── standard-as-callback@ extraneous
                  ├── statuses@ extraneous
                  ├── stealthy-require@1.1.1 extraneous
                  ├── stop-iteration-iterator@1.0.0 extraneous
                  ├── stream-shift@ extraneous
                  ├── streamsearch@ extraneous
                  ├── streamx@2.13.2 extraneous
                  ├── string.prototype.trimend@ extraneous
                  ├── string.prototype.trimstart@ extraneous
                  ├── strip-bom@2.0.0 extraneous
                  ├── strip-json-comments@2.0.1 extraneous
                  ├── strnum@ extraneous
                  ├── suncalc2@1.8.1 extraneous
                  ├── supports-preserve-symlinks-flag@ extraneous
                  ├── systeminformation@ extraneous
                  ├── tar-fs@ extraneous
                  ├── tar-stream@ extraneous
                  ├── tar@ extraneous
                  ├── tcp-ping@0.1.1 extraneous
                  ├── thenify-all@1.6.0 extraneous
                  ├── thenify@3.3.1 extraneous
                  ├── through2@2.0.5 extraneous
                  ├── thunky@1.1.0 extraneous
                  ├── to-array@0.1.4 extraneous
                  ├── treemap-js@1.2.1 extraneous
                  ├── tslib@ extraneous
                  ├── tuyapi@ extraneous
                  ├── tweetnacl@ extraneous
                  ├── typedarray@0.0.6 extraneous
                  ├── typescript@ extraneous
                  ├── uid-number@0.0.6 extraneous
                  ├── ultron@1.1.1 extraneous
                  ├── unbox-primitive@ extraneous
                  ├── universalify@0.1.2 extraneous
                  ├── unix-dgram@ extraneous
                  ├── uri-js@ extraneous
                  ├── url-parse@ extraneous
                  ├── usb@ extraneous
                  ├── util@ extraneous
                  ├── uuid@ extraneous
                  ├── validate-npm-package-license@3.0.4 extraneous
                  ├── virtual-tsc@ extraneous
                  ├── vows@ extraneous
                  ├── wake_on_lan@1.0.0 extraneous
                  ├── webdav@ extraneous
                  ├── websocket-stream@ extraneous
                  ├── which-boxed-primitive@ extraneous
                  ├── which-collection@ extraneous
                  ├── which-module@1.0.0 extraneous
                  ├── which-typed-array@ extraneous
                  ├── which@ extraneous
                  ├── wide-align@1.1.5 extraneous
                  ├── winston-daily-rotate-file@ extraneous
                  ├── winston-seq-updated@ extraneous
                  ├── winston-syslog@ extraneous
                  ├── winston-transport@ extraneous
                  ├── winston@ extraneous
                  ├── wrap-ansi@2.1.0 extraneous
                  ├── ws@ extraneous
                  ├── xml2js@ extraneous
                  ├── xmlbuilder@ extraneous
                  ├── xmlhttprequest-ssl@ extraneous
                  ├── xtend@4.0.2 extraneous
                  ├── y18n@3.2.2 extraneous
                  ├── yallist@ extraneous
                  ├── yargs-parser@ extraneous
                  ├── yargs@7.1.2 extraneous
                  ├── yeast@0.1.2 extraneous
                  ├── zigbee-herdsman-converters@ extraneous
                  ├── zigbee-herdsman@ extraneous
                  └── zlib@ extraneous
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-06T14_38_13_261Z-debug-0.log
                    @subman82 sagte in js-controller lässts sich nicht updaten:
                    buster
                    ist das der Grund für die inkompatibilität?
                    Das OS ist vollkommen veraltet. Wir sind da bereits bei v12
                    subman82
                    @homoran said in js-controller lässts sich nicht updaten:
                    buster
                    Ich habe heute versucht das Betriebssystem upzudaten von Buster zu bullseye um dann weiter upzudaten.
                    Vorher hab ich mit WIN32 ein Image von meiner sd-Karte erstellt (das hat glaube ich sogar geklappt)
                    Nachdem ich in nano die listen von buster zu bullseye geändert habe, kamen jedoch Fehlermeldungen und ich hab
                    mich dann nicht getraut weiter fortzufahren. Ich habe die ANleitung hier verwendet:
                    https://schroederdennis.de/tutorial-howto/debian-10-buster-auf-debian-11-bullseye-linux-updaten-anleitung/
                    Oder welche könnt ihr mir empfehlen? Kann ich auch direkt auf die aktuelle OS Version updaten?
                    pi@raspberrypi:~ $  sudo nano /^C
                    pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list
                    pi@raspberrypi:~ $ ^C
                    pi@raspberrypi:~ $ sudo apt update
                    Holen:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                    Ign:2 http://security.debian.org/debian-security bullseye-seCurity InRelease
                    Fehl:3 http://security.debian.org/debian-security bullseye-seCurity Release
                      404  Not Found [IP: 2a04:4e42:8d::644 80]
                    Holen:4 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                    OK:5 https://deb.nodesource.com/node_18.x buster InRelease
                    OK:6 http://archive.raspberrypi.org/debian buster InRelease
                    Fehl:1 http://deb.debian.org/debian bullseye InRelease
                      Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PU        BKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
                    Fehl:4 http://deb.debian.org/debian bullseye-updates InRelease
                      Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PU        BKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                    E: Das Depot »http://security.debian.org/debian-security bullseye-seCurity Release« enthält keine Release-Datei.
                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standa        rdmäßig deaktiviert.
                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite        apt-secure(8).
                    W: GPG-Fehler: http://deb.debian.org/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werd        en, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUB        KEY 605C66F00D6C9793
                    E: Das Depot »http://deb.debian.org/debian bullseye InRelease« ist nicht signiert.
                    W: GPG-Fehler: http://deb.debian.org/debian bullseye-updates InRelease: Die folgenden Signaturen konnten nicht überpr        üft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E13        1
                    E: Das Depot »http://deb.debian.org/debian bullseye-updates InRelease« ist nicht signiert.
                    • S subman82
                      buster
                      bullseye-seCurity
                      Das dürfte schon mal ein Typo sein.
                      Das System ist an so vielen Stellen krumm und schief, ich würde es neuinstallieren. Ist weniger Arbeit als dadran herumzuflicken.
                      64bit 'Bullseye' Lite
                      • S subman82
                        buster
                        warum was externes?
                        https://forum.iobroker.net/post/667685
                          warum was externes?
                          subman82
                          @homoran warum was externes?
                          gegoogelt und da gabs ein Video zu....die Verzweiflung ist halt groß:/
                          @homoran : bzgl: https://forum.iobroker.net/post/667685
                          Da ich das System noch nie installiert habe, wäre eine Neuinstallation für mich auch nicht mal so eben gemacht.
                          Wie man merkt , bin ich froh wenn ich den Laptop an bekomme ohne das Internet zu löschen.
                          Ich hab es jetzt nochmal mit deinem Link versucht, scheitere aber schon am ersten Schritt die Links in die Verzeichnisse zu packen,damit mit dem Befehl sudo apt update das richtige in Gang gesetzt wird.
                          über "sudo nano /etc/apt/sources.list " müsste ich doch das hier hinterlegen oder?
                          Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                          Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
                          E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
                          N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
                          Do you want to accept these changes and continue updating from this repository? [y/N]
                          wobei ich dann nicht weiss wo ich mit deb... beginne oder # oder #deb-src oder was auch immer.
                          Ich habe meine jetzige Buster Version dann mit sudo apt update mit dem alten Eintrag upgedated.
                          deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                          # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                          und anschließend folgendes in die "sudo nano /etc/apt/sources.list " neu eingetragen:
                          deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                          #Uncomment line below then 'apt-get update' to enable 'apt-get source'
                          #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                          Das hat aber auch nicht geklappt, da sich im ersten Link noch etwas von Buster gezogen wird:
                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                          Aktualisierung für 566 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                          Ich werd mir wohl mal ein zweites Raspberry kaufen und versuchen es selber zu installieren,damit ich das mal lerne.
                          Vielen Dank soweit schon mal!!
                          Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                          • S subman82
                            Wie kommt denn das aktuelle Konstrukt auf die Kiste?
                            • S subman82
                              sudo apt update
                              funktioniert aus jedem Verzeichnis heraus.
                              Mit den sed-Kommandos stellt man alles rekursiv auf bullseye um. Setzt allerdings eine saubere Grundlage voraus.
                              Und mit dem ganzen Zauber kommst du dann immer noch nicht auf eine 64bit-Version, das geht nur über eine Neuinstallation, weswegen genau das meine Empfehlung an der Stelle ist.
                                subman82
                                Kann man fertig im Internet kaufen, dann müssen nur noch die Adapter runtergeladen und
                                entsprechend eingestellt werden. Das hab ich noch hinbekommen. Soweit läuft alles noch aber
                                ich möchte es halt aktualisieren und was für ein Chaos ich im System veranstaltet habe, habt ihr ja schon gesehen.
                                • S subman82
                                  • Betriebssystem installieren
                                  • curl -sLf https://iobroker.net/install.sh | bash - ausführen
                                  feddisch!
                                    sudo apt update
                                    subman82
                                    sudo apt update
                                    Ah ok, dass mit der 64bit Version hab ich jetzt erst verstanden. Dann versuch ich es mit einer zweiten Raspberry mal selber.
                                    Wenn ich alles zusammen habe such ich im Forum nach der Anleitung und wie ich den ganzen iobroker-Kram implementiert bekomme. Das sollte klappen oder muss ich das dann auch alles neu machen?
                                    • S subman82
                                      sudo apt update
                                      @subman82
                                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                        feddisch!
                                        subman82
                                        feddisch!
                                        Ich meine das Rasbian oder werfe ich jetzt alles durcheinander?
                                        Und dann ist die Frage ob ich meine ganzen Einstellungen von den Adaptern über Backitup drauf bekomme.
                                        Irgendwie habe ich es geschafft dass regelmässig Backups gemacht werden, aber ich hab noch nicht geschaut wie ich die aufgespielt bekomme und was da alles aufgespielt wird. Muss ich dann mal hier nachlesen und ausprobieren.
                                        • S subman82
                                          feddisch!
                                          Das ist der Zweck eines Backups.
