  4. js-controller lässts sich nicht updaten
    5.3k
42 Beiträge 5 Kommentatoren 5.0k Aufrufe 4 Beobachtet
  • S subman82
    @thomas-braun said in js-controller lässts sich nicht updaten:
    @subman82
    iob diag
    in der Langfassung sagt?
    muss es teilen, sonst bekomme ich es nicht hochgeladen.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     16:02:27 up 24 min,  1 user,  load average: 0.50, 0.78, 0.87
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=50.1'C
    volt=0.8813V
    *** Time and Time Zones ***
                   Local time: Fri 2023-08-04 16:02:27 CEST
               Universal time: Fri 2023-08-04 14:02:27 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        759M        2.6G        8.0M        522M        2.9G
    Swap:           99M          0B         99M
    Total:         3.9G        759M        2.7G
             3838 M total memory
              759 M used memory
              288 M active memory
              897 M inactive memory
             2556 M free memory
               86 M buffer memory
              436 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  5.7G   23G  21% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    /dev/sda1      exfat     115G  297M  115G   1% /media/usbstick
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Fri Aug  4 15:38:00 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x        1080M@60D smsc95xx.macaddr=DC:A6:32:1D:ED:20 vc_mem.mem_base=0x3ec00000 vc_mem.m        em_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=        PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Aug  4 15:38:01 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
    [Fri Aug  4 15:38:01 2023] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
    [Fri Aug  4 15:38:05 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Aug  4 15:38:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Opts: (null)
    [Fri Aug  4 15:38:05 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
    [Fri Aug  4 15:38:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET            SOURCE         FSTYPE OPTIONS
    /                 /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf     none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepa        ge=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbstick /dev/sda1      exfat  rw,noatime,uid=1001,gid=1001,fmask=0022,        dmask=0022,iocharset=utf8,errors=remount-ro
    /var:
    392M    /var/
    191M    /var/cache
    185M    /var/cache/apt
    126M    /var/cache/apt/archives
    95M     /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    323M    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    341M    /opt/iobroker/iobroker-data/
    158M    /opt/iobroker/iobroker-data/files
    112M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/scenes.admin/static
    48M     /opt/iobroker/iobroker-data/objects.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chun        k.js.map
    8.2M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.979c3ea7.chun        k.js.map
    7.7M    /opt/iobroker/iobroker-data/objects.json.migrated
    7.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    javascript:     6.1.4
    @subman82 sagte in js-controller lässts sich nicht updaten:
    buster
    ist das der Grund für die inkompatibilität?
    Das OS ist vollkommen veraltet. Wir sind da bereits bei v12
    • S subman82
      @subman82
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=50.1'C
      volt=0.8813V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               3838 M total memory
                759 M used memory
                288 M active memory
               2556 M free memory
                 86 M buffer memory
                436 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      392M    /var/
      191M    /var/cache
      185M    /var/cache/apt
      95M     /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      ach komm - die komplette Ausgabe markieren und hier in Codetags posten... und zieh Dein Fenster von Deiner Konsole mal breiter !
      Lehrling seit 1975 !!!
        @subman82
        iob diag
        subman82
        @subman82
        iob diag
        Teil 2
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modul        es/@abandonware/bluetooth-hci-socket
        npm ERR! extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware        /noble
        npm ERR! extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/        jsonl-db
        npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
        npm ERR! extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alc        alzone/proper-lockfile
        npm ERR! extraneous: @apollon/iobroker-tools@ /opt/iobroker/node_modules/@apollo        n/iobroker-tools
        npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
        npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnos        tics
        npm ERR! extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust        /winston-seq
        npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/d        rive
        npm ERR! extraneous: @harmonyhub/discover@ /opt/iobroker/node_modules/@harmonyhu        b/discover
        npm ERR! extraneous: @homebridge/ciao@ /opt/iobroker/node_modules/@homebridge/ci        ao
        npm ERR! extraneous: @homebridge/dbus-native@0.4.2 /opt/iobroker/node_modules/@h        omebridge/dbus-native
        npm ERR! extraneous: @homebridge/long@5.2.1 /opt/iobroker/node_modules/@homebrid        ge/long
        npm ERR! extraneous: @homebridge/put@0.0.8 /opt/iobroker/node_modules/@homebridg        e/put
        npm ERR! extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroke        r/adapter-core
        npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-        base
        npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobr        oker/db-objects-file
        npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iob        roker/db-objects-jsonl
        npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iob        roker/db-objects-redis
        npm ERR! extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobro        ker/db-states-file
        npm ERR! extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobr        oker/db-states-jsonl
        npm ERR! extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobr        oker/db-states-redis
        npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules        /@iobroker/js-controller-adapter
        npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@io        broker/js-controller-cli
        npm ERR! extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modul        es/@iobroker/js-controller-common-db
        npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/        @iobroker/js-controller-common
        npm ERR! extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker        /plugin-base
        npm ERR! extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobrok        er/plugin-sentry
        npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobro        ker/socket-classes
        npm ERR! extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leicht        gewicht/ip-codec
        npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/no        de-pre-gyp
        npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@pro        tobufjs/aspromise
        npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@proto        bufjs/inquire
        npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
        npm ERR! extraneous: @root/asn1@ /opt/iobroker/node_modules/@root/asn1
        npm ERR! extraneous: @root/csr@ /opt/iobroker/node_modules/@root/csr
        npm ERR! extraneous: @root/encoding@ /opt/iobroker/node_modules/@root/encoding
        npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/g        reenlock-express
        npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
        npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
        npm ERR! extraneous: @root/pem@ /opt/iobroker/node_modules/@root/pem
        npm ERR! extraneous: @root/request@ /opt/iobroker/node_modules/@root/request
        npm ERR! extraneous: @root/x509@ /opt/iobroker/node_modules/@root/x509
        npm ERR! extraneous: @sentry/browser@5.12.1 /opt/iobroker/node_modules/@sentry/b        rowser
        npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
        npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
        npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/in        tegrations
        npm ERR! extraneous: @sentry/minimal@ /opt/iobroker/node_modules/@sentry/minimal
        npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
        npm ERR! extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
        npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
        npm ERR! extraneous: @serialport/binding-abstract@ /opt/iobroker/node_modules/@s        erialport/binding-abstract
        npm ERR! extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@seria        lport/binding-mock
        npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@seria        lport/bindings-cpp
        npm ERR! extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/        @serialport/bindings-interface
        npm ERR! extraneous: @serialport/bindings@ /opt/iobroker/node_modules/@serialpor        t/bindings
        npm ERR! extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/        @serialport/parser-byte-length
        npm ERR! extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@seri        alport/parser-cctalk
        npm ERR! extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@s        erialport/parser-delimiter
        npm ERR! extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_m        odules/@serialport/parser-inter-byte-timeout
        npm ERR! extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_module        s/@serialport/parser-packet-length
        npm ERR! extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@se        rialport/parser-readline
        npm ERR! extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@seria        lport/parser-ready
        npm ERR! extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@seria        lport/parser-regex
        npm ERR! extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules        /@serialport/parser-slip-encoder
        npm ERR! extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/        @serialport/parser-spacepacket
        npm ERR! extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/        stream
        npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindreso        rhus/is
        npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modul        es/@socket.io/component-emitter
        npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szm        arczak/http-timer
        npm ERR! extraneous: @tuyapi/cloud@0.6.1 /opt/iobroker/node_modules/@tuyapi/clou        d
        npm ERR! extraneous: @types/babel-types@7.0.11 /opt/iobroker/node_modules/@types        /babel-types
        npm ERR! extraneous: @types/bl@ /opt/iobroker/node_modules/@types/bl
        npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@        types/cacheable-request
        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/ca        seless
        npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/@types/cookie
        npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
        npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/@types/iobroker
        npm ERR! extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
        npm ERR! extraneous: @types/readable-stream@2.3.15 /opt/iobroker/node_modules/@t        ypes/readable-stream
        npm ERR! extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types        /responselike
        npm ERR! extraneous: @types/retry@0.12.0 /opt/iobroker/node_modules/@types/retry
        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types        /tough-cookie
        npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
        npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-con        troller
        npm ERR! extraneous: acme-http-01-standalone@ /opt/iobroker/node_modules/acme-ht        tp-01-standalone
        npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
        npm ERR! extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
        npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
        npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shar        ed
        npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
        npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
        npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-y        et
        npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuf        fer.slice
        npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/asn1
        npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limite        r
        npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
        npm ERR! extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authentic        ate-pam
        npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobin        d-decorator
        npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/availabl        e-typed-arrays
        npm ERR! extraneous: aws4@ /opt/iobroker/node_modules/aws4
        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/axios
        npm ERR! extraneous: b4a@1.6.1 /opt/iobroker/node_modules/b4a
        npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
        npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-        arraybuffer
        npm ERR! extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
        npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
        npm ERR! extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
        npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extens        ions
        npm ERR! extraneous: bl@ /opt/iobroker/node_modules/bl
        npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
        npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
        npm ERR! extraneous: bonjour-hap@ /opt/iobroker/node_modules/bonjour-hap
        npm ERR! extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
        npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-exp        ansion
        npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
        npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/buffer
        npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
        npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable        -lookup
        npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheabl        e-request
        npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
        npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
        npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
        npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
        npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
        npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
        npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-respo        nse
        npm ERR! extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-sl        ot
        npm ERR! extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
        npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
        npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-a        t
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! extraneous: coiot-coap@ /opt/iobroker/node_modules/coiot-coap
        npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-suppor        t
        npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/colors
        npm ERR! extraneous: commander@ /opt/iobroker/node_modules/commander
        npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
        npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-b        ind
        npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/componen        t-emitter
        npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/componen        t-inherit
        npm ERR! extraneous: compressible@ /opt/iobroker/node_modules/compressible
        npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
        npm ERR! extraneous: concat-stream@2.0.0 /opt/iobroker/node_modules/concat-strea        m
        npm ERR! extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
        npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/co        nsole-control-strings
        npm ERR! extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
        npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
        npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
        npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
        npm ERR! extraneous: crypto-js@4.1.1 /opt/iobroker/node_modules/crypto-js
        npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
        npm ERR! extraneous: debounce@ /opt/iobroker/node_modules/debounce
        npm ERR! extraneous: decache@ /opt/iobroker/node_modules/decache
        npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
        npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decomp        ress-response
        npm ERR! extraneous: deep-equal@ /opt/iobroker/node_modules/deep-equal
        npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
        npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/define-proper        ties
        npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
        npm ERR! extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
        npm ERR! extraneous: dev-null@0.1.1 /opt/iobroker/node_modules/dev-null
        npm ERR! extraneous: dijkstrajs@ /opt/iobroker/node_modules/dijkstrajs
        npm ERR! extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
        npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
        npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
        npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
        npm ERR! extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
        npm ERR! extraneous: encode-utf8@1.0.3 /opt/iobroker/node_modules/encode-utf8
        npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-clie        nt
        npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-pars        er
        npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
        npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
        npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
        npm ERR! extraneous: es-get-iterator@ /opt/iobroker/node_modules/es-get-iterator
        npm ERR! extraneous: es-to-primitive@ /opt/iobroker/node_modules/es-to-primitive
        npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisif        y
        npm ERR! extraneous: esbuild@ /opt/iobroker/node_modules/esbuild
        npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/escalade
        npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-ta        rget-shim
        npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/eventemitter3
        npm ERR! extraneous: events@3.3.0 /opt/iobroker/node_modules/events
        npm ERR! extraneous: execa@ /opt/iobroker/node_modules/execa
        npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-file        upload
        npm ERR! extraneous: express-session@ /opt/iobroker/node_modules/express-session
        npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
        npm ERR! extraneous: fast-deep-equal@ /opt/iobroker/node_modules/fast-deep-equal
        npm ERR! extraneous: fast-fifo@1.1.0 /opt/iobroker/node_modules/fast-fifo
        npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast        -json-stable-stringify
        npm ERR! extraneous: fast-srp-hap@ /opt/iobroker/node_modules/fast-srp-hap
        npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
        npm ERR! extraneous: fastseries@ /opt/iobroker/node_modules/fastseries
        npm ERR! extraneous: fecha@ /opt/iobroker/node_modules/fecha
        npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream        -rotator
        npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
        npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
        npm ERR! extraneous: form-data@ /opt/iobroker/node_modules/form-data
        npm ERR! extraneous: fs-extra@7.0.1 /opt/iobroker/node_modules/fs-extra
        npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
        npm ERR! extraneous: ftp@ /opt/iobroker/node_modules/ftp
        npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/functio        n.prototype.name
        npm ERR! extraneous: functions-have-names@ /opt/iobroker/node_modules/functions-        have-names
        npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
        npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/gauge
        npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/gaxios
        npm ERR! extraneous: gcp-metadata@ /opt/iobroker/node_modules/gcp-metadata
        npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller        -file
        npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/get-intrinsic
        npm ERR! extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ss        l-certificate
        npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/get-stream
        npm ERR! extraneous: get-symbol-description@ /opt/iobroker/node_modules/get-symb        ol-description
        npm ERR! extraneous: glob@ /opt/iobroker/node_modules/glob
        npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth        -library
        npm ERR! extraneous: google-p12-pem@ /opt/iobroker/node_modules/google-p12-pem
        npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-co        mmon
        npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
        npm ERR! extraneous: got@11.8.6 /opt/iobroker/node_modules/got
        npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/graceful-fs
        npm ERR! extraneous: greenlock-express@ /opt/iobroker/node_modules/greenlock-exp        ress
        npm ERR! extraneous: greenlock-store-fs@ /opt/iobroker/node_modules/greenlock-st        ore-fs
        npm ERR! extraneous: gtoken@ /opt/iobroker/node_modules/gtoken
        npm ERR! extraneous: hap-controller@ /opt/iobroker/node_modules/hap-controller
        npm ERR! extraneous: hap-nodejs@ /opt/iobroker/node_modules/hap-nodejs
        npm ERR! extraneous: har-validator@ /opt/iobroker/node_modules/har-validator
        npm ERR! extraneous: harmonyhubws@1.0.6 /opt/iobroker/node_modules/harmonyhubws
        npm ERR! extraneous: has-bigints@ /opt/iobroker/node_modules/has-bigints
        npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
        npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
        npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/has-pr        operty-descriptors
        npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/has-symbols
        npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/has-tostringtag
        npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
        npm ERR! extraneous: help-me@ /opt/iobroker/node_modules/help-me
        npm ERR! extraneous: hexy@0.2.11 /opt/iobroker/node_modules/hexy
        npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/hosted-git-info
        npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-        proxy
        npm ERR! extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrappe        r
        npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/https-proxy-a        gent
        npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/human-signals
        npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
        npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
        npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
        npm ERR! extraneous: internal-slot@ /opt/iobroker/node_modules/internal-slot
        npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
        npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
        npm ERR! invalid: iobroker.backitup@2.6.19 /opt/iobroker/node_modules/iobroker.b        ackitup
        npm ERR! extraneous: iobroker.device-reminder@1.2.9 /opt/iobroker/node_modules/i        obroker.device-reminder
        npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.d        iscovery
        npm ERR! extraneous: iobroker.harmony@1.2.2 /opt/iobroker/node_modules/iobroker.        harmony
        npm ERR! extraneous: iobroker.hue@3.7.1 /opt/iobroker/node_modules/iobroker.hue
        npm ERR! extraneous: iobroker.info@1.9.26 /opt/iobroker/node_modules/iobroker.in        fo
        npm ERR! extraneous: iobroker.javascript@6.1.4 /opt/iobroker/node_modules/iobrok        er.javascript
        npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobro        ker.js-controller
        npm ERR! extraneous: iobroker.mihome-vacuum@3.9.5 /opt/iobroker/node_modules/iob        roker.mihome-vacuum
        npm ERR! extraneous: iobroker.mihome@1.4.0 /opt/iobroker/node_modules/iobroker.m        ihome
        npm ERR! extraneous: iobroker.mqtt@4.0.7 /opt/iobroker/node_modules/iobroker.mqt        t
        npm ERR! extraneous: iobroker.scenes@2.3.9 /opt/iobroker/node_modules/iobroker.s        cenes
        npm ERR! extraneous: iobroker.shelly@6.3.1 /opt/iobroker/node_modules/iobroker.s        helly
        npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobrok        er.simple-api
        npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker        .socketio
        npm ERR! extraneous: iobroker.terminal@1.0.0 /opt/iobroker/node_modules/iobroker        .terminal
        npm ERR! extraneous: iobroker.tuya@3.13.1 /opt/iobroker/node_modules/iobroker.tu        ya
        npm ERR! extraneous: iobroker.vis@1.4.16 /opt/iobroker/node_modules/iobroker.vis
        npm ERR! extraneous: iobroker.web@4.3.0 /opt/iobroker/node_modules/iobroker.web
        npm ERR! extraneous: iobroker.ws.server@ /opt/iobroker/node_modules/iobroker.ws.        server
        npm ERR! extraneous: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
        npm ERR! extraneous: iobroker.yahka@0.17.0 /opt/iobroker/node_modules/iobroker.y        ahka
        npm ERR! extraneous: iobroker.zigbee@1.8.10 /opt/iobroker/node_modules/iobroker.        zigbee
        npm ERR! extraneous: iobroker@2.0.3 /opt/iobroker/node_modules/iobroker
        npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
        npm ERR! extraneous: ip@ /opt/iobroker/node_modules/ip
        npm ERR! extraneous: is-arguments@ /opt/iobroker/node_modules/is-arguments
        npm ERR! extraneous: is-array-buffer@3.0.2 /opt/iobroker/node_modules/is-array-b        uffer
        npm ERR! extraneous: is-bigint@ /opt/iobroker/node_modules/is-bigint
        npm ERR! extraneous: is-boolean-object@ /opt/iobroker/node_modules/is-boolean-ob        ject
        npm ERR! extraneous: is-callable@ /opt/iobroker/node_modules/is-callable
        npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/is-core-module
        npm ERR! extraneous: is-date-object@ /opt/iobroker/node_modules/is-date-object
        npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/is-genera        tor-function
        npm ERR! extraneous: is-map@ /opt/iobroker/node_modules/is-map
        npm ERR! extraneous: is-nan@ /opt/iobroker/node_modules/is-nan
        npm ERR! extraneous: is-negative-zero@ /opt/iobroker/node_modules/is-negative-ze        ro
        npm ERR! extraneous: is-number-object@ /opt/iobroker/node_modules/is-number-obje        ct
        npm ERR! extraneous: is-plain-obj@2.1.0 /opt/iobroker/node_modules/is-plain-obj
        npm ERR! extraneous: is-regex@ /opt/iobroker/node_modules/is-regex
        npm ERR! extraneous: is-set@ /opt/iobroker/node_modules/is-set
        npm ERR! extraneous: is-shared-array-buffer@ /opt/iobroker/node_modules/is-share        d-array-buffer
        npm ERR! extraneous: is-string@ /opt/iobroker/node_modules/is-string
        npm ERR! extraneous: is-symbol@ /opt/iobroker/node_modules/is-symbol
        npm ERR! extraneous: is-typed-array@ /opt/iobroker/node_modules/is-typed-array
        npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
        npm ERR! extraneous: is-weakmap@ /opt/iobroker/node_modules/is-weakmap
        npm ERR! extraneous: is-weakref@ /opt/iobroker/node_modules/is-weakref
        npm ERR! extraneous: is-weakset@ /opt/iobroker/node_modules/is-weakset
        npm ERR! extraneous: isarray@2.0.5 /opt/iobroker/node_modules/isarray
        npm ERR! extraneous: js-sdsl@ /opt/iobroker/node_modules/js-sdsl
        npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
        npm ERR! extraneous: json-bigint@ /opt/iobroker/node_modules/json-bigint
        npm ERR! extraneous: json-schema@ /opt/iobroker/node_modules/json-schema
        npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
        npm ERR! extraneous: jsonfile@4.0.0 /opt/iobroker/node_modules/jsonfile
        npm ERR! extraneous: jsprim@ /opt/iobroker/node_modules/jsprim
        npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
        npm ERR! extraneous: jws@ /opt/iobroker/node_modules/jws
        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
        npm ERR! extraneous: layerr@ /opt/iobroker/node_modules/layerr
        npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
        npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
        npm ERR! extraneous: libsodium-wrappers@ /opt/iobroker/node_modules/libsodium-wr        appers
        npm ERR! extraneous: libsodium@ /opt/iobroker/node_modules/libsodium
        npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
        npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-f        ile
        npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
        npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/locate-path
        npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/lodash
        npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
        npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-k        eys
        npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
        npm ERR! extraneous: macaddress@ /opt/iobroker/node_modules/macaddress
        npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
        npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
        npm ERR! extraneous: mime-db@ /opt/iobroker/node_modules/mime-db
        npm ERR! extraneous: mime@ /opt/iobroker/node_modules/mime
        npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-respo        nse
        npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/minimatch
        npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
        npm ERR! extraneous: minipass@ /opt/iobroker/node_modules/minipass
        npm ERR! extraneous: minizlib@ /opt/iobroker/node_modules/minizlib
        npm ERR! extraneous: mixin-deep@2.0.1 /opt/iobroker/node_modules/mixin-deep
        npm ERR! extraneous: mkdirp@ /opt/iobroker/node_modules/mkdirp
        npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
        npm ERR! extraneous: mqtt-connection@ /opt/iobroker/node_modules/mqtt-connection
        npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
        npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
        npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_module        s/multicast-dns-service-types
        npm ERR! extraneous: multicast-dns@ /opt/iobroker/node_modules/multicast-dns
        npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
        npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
        npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/negotiator
        npm ERR! extraneous: nested-property@ /opt/iobroker/node_modules/nested-property
        npm ERR! extraneous: netmask@ /opt/iobroker/node_modules/netmask
        npm ERR! extraneous: node-abi@ /opt/iobroker/node_modules/node-abi
        npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
        npm ERR! extraneous: node-fetch@ /opt/iobroker/node_modules/node-fetch
        npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
        npm ERR! extraneous: node-gyp-build@ /opt/iobroker/node_modules/node-gyp-build
        npm ERR! extraneous: node-hue-api@ /opt/iobroker/node_modules/node-hue-api
        npm ERR! extraneous: node-inspect@ /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
        npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-clie        nt
        npm ERR! extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
        npm ERR! extraneous: node-schedule@ /opt/iobroker/node_modules/node-schedule
        npm ERR! extraneous: node-ssdp@ /opt/iobroker/node_modules/node-ssdp
        npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/nopt
        npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/nor        malize-package-data
        npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-ur        l
        npm ERR! extraneous: npmlog@ /opt/iobroker/node_modules/npmlog
        npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocat        or
        npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-na        n
        npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assig        n
        npm ERR! extraneous: object-hash@ /opt/iobroker/node_modules/object-hash
        npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
        npm ERR! extraneous: object-is@ /opt/iobroker/node_modules/object-is
        npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
        npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
        npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temp        erature-sensor
        npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
        npm ERR! extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
        npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
        npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/p-locate
        npm ERR! extraneous: p-queue@ /opt/iobroker/node_modules/p-queue
        npm ERR! extraneous: p-retry@4.6.2 /opt/iobroker/node_modules/p-retry
        npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-timeout
        npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
        npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
        npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
        npm ERR! extraneous: parseqs@ /opt/iobroker/node_modules/parseqs
        npm ERR! extraneous: parseuri@0.0.6 /opt/iobroker/node_modules/parseuri
        npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
        npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
        npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-a        bsolute
        npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
        npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
        npm ERR! extraneous: picocolors@ /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/picomatch
        npm ERR! extraneous: pidtree@ /opt/iobroker/node_modules/pidtree
        npm ERR! extraneous: pidusage@ /opt/iobroker/node_modules/pidusage
        npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
        npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-prom        ise
        npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
        npm ERR! extraneous: pngjs@ /opt/iobroker/node_modules/pngjs
        npm ERR! extraneous: prebuild-install@ /opt/iobroker/node_modules/prebuild-insta        ll
        npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
        npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
        npm ERR! extraneous: proper-lockfile@4.1.2 /opt/iobroker/node_modules/proper-loc        kfile
        npm ERR! extraneous: psl@ /opt/iobroker/node_modules/psl
        npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
        npm ERR! extraneous: qrcode@ /opt/iobroker/node_modules/qrcode
        npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
        npm ERR! extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
        npm ERR! extraneous: randomatic@3.1.1 /opt/iobroker/node_modules/randomatic
        npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
        npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
        npm ERR! extraneous: redirect-https@ /opt/iobroker/node_modules/redirect-https
        npm ERR! extraneous: redis-commands@ /opt/iobroker/node_modules/redis-commands
        npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.p        rototype.flags
        npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
        npm ERR! extraneous: request-promise-core@ /opt/iobroker/node_modules/request-pr        omise-core
        npm ERR! extraneous: request-promise-native@ /opt/iobroker/node_modules/request-        promise-native
        npm ERR! extraneous: request@ /opt/iobroker/node_modules/request
        npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/requ        ire-main-filename
        npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
        npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
        npm ERR! extraneous: rfdc@ /opt/iobroker/node_modules/rfdc
        npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/rimraf
        npm ERR! extraneous: safe-stable-stringify@ /opt/iobroker/node_modules/safe-stab        le-stringify
        npm ERR! extraneous: sax@1.2.4 /opt/iobroker/node_modules/sax
        npm ERR! extraneous: semaphore@1.1.0 /opt/iobroker/node_modules/semaphore
        npm ERR! extraneous: semver@5.7.1 /opt/iobroker/node_modules/semver
        npm ERR! extraneous: send@ /opt/iobroker/node_modules/send
        npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
        npm ERR! extraneous: serialport@ /opt/iobroker/node_modules/serialport
        npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
        npm ERR! extraneous: shelly-iot@ /opt/iobroker/node_modules/shelly-iot
        npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/side-channel
        npm ERR! extraneous: simple-concat@ /opt/iobroker/node_modules/simple-concat
        npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
        npm ERR! extraneous: slip@1.0.2 /opt/iobroker/node_modules/slip
        npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.i        o-adapter
        npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-clie        nt
        npm ERR! extraneous: socket.io-parser@3.4.1 /opt/iobroker/node_modules/socket.io        -parser
        npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/socket.io
        npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-k        eys-recursive
        npm ERR! extraneous: sort-keys@4.2.0 /opt/iobroker/node_modules/sort-keys
        npm ERR! extraneous: sorted-array-functions@ /opt/iobroker/node_modules/sorted-a        rray-functions
        npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/source-map-s        upport
        npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/spdx-correct
        npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-excep        tions
        npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/spdx-expr        ession-parse
        npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-lic        ense-ids
        npm ERR! extraneous: split2@ /opt/iobroker/node_modules/split2
        npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
        npm ERR! extraneous: standard-as-callback@ /opt/iobroker/node_modules/standard-a        s-callback
        npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/statuses
        npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-        require
        npm ERR! extraneous: stop-iteration-iterator@1.0.0 /opt/iobroker/node_modules/st        op-iteration-iterator
        npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/stream-shift
        npm ERR! extraneous: streamsearch@ /opt/iobroker/node_modules/streamsearch
        npm ERR! extraneous: streamx@2.13.2 /opt/iobroker/node_modules/streamx
        npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string        .prototype.trimend
        npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/stri        ng.prototype.trimstart
        npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
        npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-        json-comments
        npm ERR! extraneous: strnum@ /opt/iobroker/node_modules/strnum
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules        /supports-preserve-symlinks-flag
        npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminforma        tion
        npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
        npm ERR! extraneous: tar-stream@ /opt/iobroker/node_modules/tar-stream
        npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
        npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
        npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
        npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
        npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
        npm ERR! extraneous: thunky@1.1.0 /opt/iobroker/node_modules/thunky
        npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
        npm ERR! extraneous: treemap-js@1.2.1 /opt/iobroker/node_modules/treemap-js
        npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/tslib
        npm ERR! extraneous: tuyapi@ /opt/iobroker/node_modules/tuyapi
        npm ERR! extraneous: tweetnacl@ /opt/iobroker/node_modules/tweetnacl
        npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
        npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
        npm ERR! extraneous: ultron@1.1.1 /opt/iobroker/node_modules/ultron
        npm ERR! extraneous: unbox-primitive@ /opt/iobroker/node_modules/unbox-primitive
        npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/universalify
        npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram
        npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
        npm ERR! extraneous: url-parse@ /opt/iobroker/node_modules/url-parse
        npm ERR! extraneous: usb@ /opt/iobroker/node_modules/usb
        npm ERR! extraneous: util@ /opt/iobroker/node_modules/util
        npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/uuid
        npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modul        es/validate-npm-package-license
        npm ERR! extraneous: virtual-tsc@ /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: vows@ /opt/iobroker/node_modules/vows
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
        npm ERR! extraneous: websocket-stream@ /opt/iobroker/node_modules/websocket-stre        am
        npm ERR! extraneous: which-boxed-primitive@ /opt/iobroker/node_modules/which-box        ed-primitive
        npm ERR! extraneous: which-collection@ /opt/iobroker/node_modules/which-collecti        on
        npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
        npm ERR! extraneous: which-typed-array@ /opt/iobroker/node_modules/which-typed-a        rray
        npm ERR! extraneous: which@ /opt/iobroker/node_modules/which
        npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
        npm ERR! extraneous: winston-daily-rotate-file@ /opt/iobroker/node_modules/winst        on-daily-rotate-file
        npm ERR! extraneous: winston-seq-updated@ /opt/iobroker/node_modules/winston-seq        -updated
        npm ERR! extraneous: winston-syslog@ /opt/iobroker/node_modules/winston-syslog
        npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-trans        port
          @subman82
          iob diag
          subman82
          @subman82
          iob diag
          Teil3
          npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
          npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
          npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
          npm ERR! extraneous: xml2js@ /opt/iobroker/node_modules/xml2js
          npm ERR! extraneous: xmlbuilder@ /opt/iobroker/node_modules/xmlbuilder
          npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttpreque        st-ssl
          npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
          npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
          npm ERR! extraneous: yallist@ /opt/iobroker/node_modules/yallist
          npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/yargs-parser
          npm ERR! extraneous: yargs@7.1.2 /opt/iobroker/node_modules/yargs
          npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
          npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigb        ee-herdsman-converters
          npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
          npm ERR! extraneous: zlib@ /opt/iobroker/node_modules/zlib
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-08        -04T14_02_48_865Z-debug-0.log
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
          + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
          + system.adapter.harmony.0                : harmony               : raspberrypi        -  enabled
          + system.adapter.hue.0                    : hue                   : raspberrypi        -  enabled, port: 80
          + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi        -  enabled, port: 54321
          + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi        -  enabled, port: 54321
          + system.adapter.mihome-vacuum.3          : mihome-vacuum         : raspberrypi        -  enabled, port: 54321
          + system.adapter.scenes.0                 : scenes                : raspberrypi        -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.terminal.0               : terminal              : raspberrypi        -  enabled, port: 8088, bind: 0.0.0.0, run as: admi        n
          + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
          + system.adapter.yahka.0                  : yahka                 : raspberrypi        -  enabled
            system.adapter.zigbee.0                 : zigbee                : raspberrypi        - disabled, port: /dev/serial/by-id/usb-Texas_Instr        uments_TI_CC2531_USB_CDC___0X00124B001CDD2589-if00
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "hue"          : 3.9.3    , installed 3.7.1  [Updatable]
          Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
          Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
          Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
          Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
          Adapter    "yahka"        : 0.17.0   , installed 0.17.0
          Adapter    "zigbee"       : 1.8.21   , installed 1.8.10 [Updatable]
          Objects and States
          Objects:        3649
          States:         2992
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
          Reading package lists...
          Pending Updates: 1
          *** Listening Ports ***
          Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          17832      815/sshd
          tcp        0      0 127.0.0.1:36391         0.0.0.0:*               LISTEN        1001       19328      1443/io.yahka.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       19576      803/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       18022      803/iobroker.js-con
          tcp6       0      0 :::8081                 :::*                    LISTEN        1001       19734      1099/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN        1001       18397      1462/io.web.0
          tcp6       0      0 ::1:3350                :::*                    LISTEN        0          17850      828/xrdp-sesman
          tcp6       0      0 :::22                   :::*                    LISTEN        0          17834      815/sshd
          tcp6       0      0 :::45655                :::*                    LISTEN        1001       20005      1443/io.yahka.0
          tcp6       0      0 :::8088                 :::*                    LISTEN        1001       20573      1477/io.terminal.0
          tcp6       0      0 :::3389                 :::*                    LISTEN        109        17973      838/xrdp
          tcp6       0      0 :::61991                :::*                    LISTEN        1001       21551      1515/io.harmony.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*        1001       19912      1326/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*        1001       19913      1326/io.tuya.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*        1001       21552      1515/io.harmony.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*        1001       19180      1293/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*        0          13962      776/dhcpcd
          udp        0      0 0.0.0.0:53421           0.0.0.0:*        1001       19863      1257/io.mihome-vacu
          udp        0      0 0.0.0.0:53422           0.0.0.0:*        1001       19809      1200/io.mihome-vacu
          udp        0      0 0.0.0.0:53423           0.0.0.0:*        1001       17228      1356/io.mihome-vacu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        16202      405/avahi-daemon: r
          udp        0      0 0.0.0.0:50965           0.0.0.0:*        108        16204      405/avahi-daemon: r
          udp6       0      0 :::546                  :::*        0          14068      776/dhcpcd
          udp6       0      0 :::5353                 :::*        108        16203      405/avahi-daemon: r
          udp6       0      0 :::59767                :::*        108        16205      405/avahi-daemon: r
          2023-08-04 15:56:04.651  - info: tuya.0 (1326) bf66b065e83070ea19sf28 Init with        IP=192.168.178.115, Key=c23d4c3e93980fc5, Version=3.3
          2023-08-04 15:56:17.268  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Connect l        ocally to device
          2023-08-04 15:56:17.269  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq Init with        IP=192.168.178.101, Key=cf54c395f378ab9d, Version=3.3
          2023-08-04 15:56:49.782  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 15:57:02.582  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.101:6668
          2023-08-04 15:57:12.901  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 15:57:25.702  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.101:6668
          2023-08-04 15:57:56.022  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 15:58:08.822  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.101:6668
          2023-08-04 15:59:11.942  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (7): connect EHOSTUNREACH 192.168.178.101:6668
          2023-08-04 15:59:38.451  - info: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Connect l        ocally to device
          2023-08-04 15:59:38.452  - info: tuya.0 (1326) bf6f0250c5ef2fb014cm6f Init with        IP=192.168.178.112, Key=796c7530b906c459, Version=3.3
          2023-08-04 15:59:39.782  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 16:00:02.903  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 16:00:23.782  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.112:6668
          2023-08-04 16:00:46.022  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 16:00:46.902  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.112:6668
          2023-08-04 16:01:30.022  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.112:6668
          2023-08-04 16:01:37.379  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Connect l        ocally to device
          2023-08-04 16:01:37.380  - info: tuya.0 (1326) bfc551cba1c03ec73d5cjq Init with        IP=192.168.178.101, Key=cf54c395f378ab9d, Version=3.3
          2023-08-04 16:01:49.143  - warn: tuya.0 (1326) bf66b065e83070ea19sf28: Error on        Reconnect (7): connect EHOSTUNREACH 192.168.178.115:6668
          2023-08-04 16:02:22.742  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (1): connect EHOSTUNREACH 192.168.178.101:6668
          2023-08-04 16:02:33.142  - warn: tuya.0 (1326) bf6f0250c5ef2fb014cm6f: Error on        Reconnect (7): connect EHOSTUNREACH 192.168.178.112:6668
          2023-08-04 16:02:45.862  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (3): connect EHOSTUNREACH 192.168.178.101:6668
          2023-08-04 16:03:28.981  - warn: tuya.0 (1326) bfc551cba1c03ec73d5cjq: Error on        Reconnect (5): connect EHOSTUNREACH 192.168.178.101:6668
          • S subman82
            @subman82
            iob diag
            Teil3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        3649
            States:         2992
            Pending Updates: 1
            @subman82
            Da hat es den npm tree zerzaust. Bei den ganzen ERRs auch kein Wunder das die Ausgabe so lang ist.
            cd /opt/iobroker
            npm prune
            npm ls
            S 2 Antworten Letzte Antwort
            • DJMarc75D DJMarc75
              subman82
              @djmarc75 said in js-controller lässts sich nicht updaten:
              Ich hatte putty auf die gesamte Bildschirmgröße gezogen,komisch.
              Ich muss jetzt leider los, ich schau später nochmal hier rein und schau mal wie ich das OS aktualisiert bekomme.
              Die Adapter habe ich auch trotz Cache löschen und Neustart nicht aktualisiert bekommen.
              Vielen Dank für eure Hilfe schon mal und sorry, dass ich so unerfahren mit iobroker und schreiben in Foren bin.
              Bis später .
              • S subman82
                Bis später .
                schreiben in Foren
                kann man lernen!
                Bitte lesen und befolgen
                  @subman82
                  cd /opt/iobroker
                  npm prune
                  npm ls
                  subman82
                  @subman82
                  cd /opt/iobroker
                  npm prune
                  npm ls
                  Das Ergebnis ist wieder sehr lang daher wieder mehrer Teile.
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ npm prune
                  npm ERR! builtins is not a function
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-06T14_37_56_241Z-debug-0.log
                  pi@raspberrypi:/opt/iobroker $ npm ls
                  npm ERR! extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                  npm ERR! extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
                  npm ERR! extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
                  npm ERR! extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                  npm ERR! extraneous: @apollon/iobroker-tools@ /opt/iobroker/node_modules/@apollon/iobroker-tools
                  npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
                  npm ERR! extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
                  npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/drive
                  npm ERR! extraneous: @harmonyhub/discover@ /opt/iobroker/node_modules/@harmonyhub/discover
                  npm ERR! extraneous: @homebridge/ciao@ /opt/iobroker/node_modules/@homebridge/ciao
                  npm ERR! extraneous: @homebridge/dbus-native@0.4.2 /opt/iobroker/node_modules/@homebridge/dbus-native
                  npm ERR! extraneous: @homebridge/long@5.2.1 /opt/iobroker/node_modules/@homebridge/long
                  npm ERR! extraneous: @homebridge/put@0.0.8 /opt/iobroker/node_modules/@homebridge/put
                  npm ERR! extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
                  npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                  npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                  npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                  npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                  npm ERR! extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                  npm ERR! extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                  npm ERR! extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                  npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                  npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                  npm ERR! extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                  npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                  npm ERR! extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
                  npm ERR! extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
                  npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
                  npm ERR! extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
                  npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                  npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                  npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                  npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
                  npm ERR! extraneous: @sentry/browser@5.12.1 /opt/iobroker/node_modules/@sentry/browser
                  npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
                  npm ERR! extraneous: @serialport/binding-abstract@ /opt/iobroker/node_modules/@serialport/binding-abstract
                  npm ERR! extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
                  npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
                  npm ERR! extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
                  npm ERR! extraneous: @serialport/bindings@ /opt/iobroker/node_modules/@serialport/bindings
                  npm ERR! extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
                  npm ERR! extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
                  npm ERR! extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
                  npm ERR! extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-        timeout
                  npm ERR! extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
                  npm ERR! extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
                  npm ERR! extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
                  npm ERR! extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
                  npm ERR! extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                  npm ERR! extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
                  npm ERR! extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
                  npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                  npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
                  npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                  npm ERR! extraneous: @tuyapi/cloud@0.6.1 /opt/iobroker/node_modules/@tuyapi/cloud
                  npm ERR! extraneous: @types/babel-types@7.0.11 /opt/iobroker/node_modules/@types/babel-types
                  npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                  npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                  npm ERR! extraneous: @types/readable-stream@2.3.15 /opt/iobroker/node_modules/@types/readable-stream
                  npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
                  npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                  npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                  npm ERR! extraneous: acme-http-01-standalone@ /opt/iobroker/node_modules/acme-http-01-standalone
                  npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
                  npm ERR! extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
                  npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
                  npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
                  npm ERR! extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                  npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
                  npm ERR! extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
                  npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-arraybuffer
                  npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
                  npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                  npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                  npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
                  npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                  npm ERR! extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
                  npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                  npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                  npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                  npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
                  npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                  npm ERR! extraneous: concat-stream@2.0.0 /opt/iobroker/node_modules/concat-stream
                  npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                  npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decompress-response
                  npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
                  npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
                  npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
                  npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                  npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                  npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
                  npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast-json-stable-stringify
                  npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream-rotator
                  npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/function.prototype.name
                  npm ERR! extraneous: functions-have-names@ /opt/iobroker/node_modules/functions-have-names
                  npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                  npm ERR! extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                  npm ERR! extraneous: get-symbol-description@ /opt/iobroker/node_modules/get-symbol-description
                  npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                  npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
                  npm ERR! extraneous: greenlock-express@ /opt/iobroker/node_modules/greenlock-express
                  npm ERR! extraneous: greenlock-store-fs@ /opt/iobroker/node_modules/greenlock-store-fs
                  npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/has-property-descriptors
                  npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-proxy
                  npm ERR! extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                  npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/https-proxy-agent
                  npm ERR! invalid: iobroker.backitup@2.6.19 /opt/iobroker/node_modules/iobroker.backitup
                  npm ERR! extraneous: iobroker.device-reminder@1.2.9 /opt/iobroker/node_modules/iobroker.device-reminder
                  npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                  npm ERR! extraneous: iobroker.harmony@1.2.2 /opt/iobroker/node_modules/iobroker.harmony
                  npm ERR! extraneous: iobroker.info@1.9.26 /opt/iobroker/node_modules/iobroker.info
                  npm ERR! extraneous: iobroker.javascript@6.1.4 /opt/iobroker/node_modules/iobroker.javascript
                  npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
                  npm ERR! extraneous: iobroker.mihome-vacuum@3.9.5 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                  npm ERR! extraneous: iobroker.mihome@1.4.0 /opt/iobroker/node_modules/iobroker.mihome
                  npm ERR! extraneous: iobroker.mqtt@4.0.7 /opt/iobroker/node_modules/iobroker.mqtt
                  npm ERR! extraneous: iobroker.scenes@2.3.9 /opt/iobroker/node_modules/iobroker.scenes
                  npm ERR! extraneous: iobroker.shelly@6.3.1 /opt/iobroker/node_modules/iobroker.shelly
                  npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobroker.simple-api
                  npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
                  npm ERR! extraneous: iobroker.terminal@1.0.0 /opt/iobroker/node_modules/iobroker.terminal
                  npm ERR! extraneous: iobroker.tuya@3.13.1 /opt/iobroker/node_modules/iobroker.tuya
                  npm ERR! extraneous: iobroker.ws.server@ /opt/iobroker/node_modules/iobroker.ws.server
                  npm ERR! extraneous: iobroker.yahka@0.17.0 /opt/iobroker/node_modules/iobroker.yahka
                  npm ERR! extraneous: iobroker.zigbee@1.8.10 /opt/iobroker/node_modules/iobroker.zigbee
                  npm ERR! extraneous: is-array-buffer@3.0.2 /opt/iobroker/node_modules/is-array-buffer
                  npm ERR! extraneous: is-boolean-object@ /opt/iobroker/node_modules/is-boolean-object
                  npm ERR! extraneous: is-generator-function@ /opt/iobroker/node_modules/is-generator-function
                  npm ERR! extraneous: is-negative-zero@ /opt/iobroker/node_modules/is-negative-zero
                  npm ERR! extraneous: is-number-object@ /opt/iobroker/node_modules/is-number-object
                  npm ERR! extraneous: is-shared-array-buffer@ /opt/iobroker/node_modules/is-shared-array-buffer
                  npm ERR! extraneous: libsodium-wrappers@ /opt/iobroker/node_modules/libsodium-wrappers
                  npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
                  npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                  npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
                  npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                  npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
                  npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
                  npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                  npm ERR! extraneous: number-allocator@ /opt/iobroker/node_modules/number-allocator
                  npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                  npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                  npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                  npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                  npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
                  npm ERR! extraneous: prebuild-install@ /opt/iobroker/node_modules/prebuild-install
                  npm ERR! extraneous: proper-lockfile@4.1.2 /opt/iobroker/node_modules/proper-lockfile
                  npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.prototype.flags
                  npm ERR! extraneous: request-promise-core@ /opt/iobroker/node_modules/request-promise-core
                  npm ERR! extraneous: request-promise-native@ /opt/iobroker/node_modules/request-promise-native
                  npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                  npm ERR! extraneous: safe-stable-stringify@ /opt/iobroker/node_modules/safe-stable-stringify
                  npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
                  npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-client
                  npm ERR! extraneous: socket.io-parser@3.4.1 /opt/iobroker/node_modules/socket.io-parser
                  npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-keys-recursive
                  npm ERR! extraneous: sorted-array-functions@ /opt/iobroker/node_modules/sorted-array-functions
                  npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/source-map-support
                  npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                  npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/spdx-expression-parse
                  npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-license-ids
                  npm ERR! extraneous: standard-as-callback@ /opt/iobroker/node_modules/standard-as-callback
                  npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                  npm ERR! extraneous: stop-iteration-iterator@1.0.0 /opt/iobroker/node_modules/stop-iteration-iterator
                  npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string.prototype.trimend
                  npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/string.prototype.trimstart
                  npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                  npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                  npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                  npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                  npm ERR! extraneous: websocket-stream@ /opt/iobroker/node_modules/websocket-stream
                  npm ERR! extraneous: which-boxed-primitive@ /opt/iobroker/node_modules/which-boxed-primitive
                  npm ERR! extraneous: which-collection@ /opt/iobroker/node_modules/which-collection
                  npm ERR! extraneous: which-typed-array@ /opt/iobroker/node_modules/which-typed-array
                  npm ERR! extraneous: winston-daily-rotate-file@ /opt/iobroker/node_modules/winston-daily-rotate-file
                  npm ERR! extraneous: winston-seq-updated@ /opt/iobroker/node_modules/winston-seq-updated
                  npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-transport
                  npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttprequest-ssl
                  npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
                    @subman82
                    cd /opt/iobroker
                    npm prune
                    npm ls
                    subman82
                    @thomas-braun said in js-controller lässts sich nicht updaten:
                    @subman82
                    cd /opt/iobroker
                    npm prune
                    npm ls
                    Teil2 von2
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├── @abandonware/bluetooth-hci-socket@ extraneous
                    ├── @abandonware/noble@ extraneous
                    ├── @alcalzone/jsonl-db@ extraneous
                    ├── @alcalzone/pak@ extraneous
                    ├── @alcalzone/proper-lockfile@ extraneous
                    ├── @apollon/iobroker-tools@ extraneous
                    ├── @colors/colors@ extraneous
                    ├── @dabh/diagnostics@ extraneous
                    ├── @datalust/winston-seq@ extraneous
                    ├── @googleapis/drive@ extraneous
                    ├── @harmonyhub/discover@ extraneous
                    ├── @homebridge/ciao@ extraneous
                    ├── @homebridge/dbus-native@0.4.2 extraneous
                    ├── @homebridge/long@5.2.1 extraneous
                    ├── @homebridge/put@0.0.8 extraneous
                    ├── @iobroker/adapter-core@ extraneous
                    ├── @iobroker/db-base@ extraneous
                    ├── @iobroker/db-objects-file@ extraneous
                    ├── @iobroker/db-objects-jsonl@ extraneous
                    ├── @iobroker/db-objects-redis@ extraneous
                    ├── @iobroker/db-states-file@ extraneous
                    ├── @iobroker/db-states-jsonl@ extraneous
                    ├── @iobroker/db-states-redis@ extraneous
                    ├── @iobroker/js-controller-adapter@ extraneous
                    ├── @iobroker/js-controller-cli@ extraneous
                    ├── @iobroker/js-controller-common-db@ extraneous
                    ├── @iobroker/js-controller-common@ extraneous
                    ├── @iobroker/plugin-base@ extraneous
                    ├── @iobroker/plugin-sentry@ extraneous
                    ├── @iobroker/socket-classes@ extraneous
                    ├── @leichtgewicht/ip-codec@ extraneous
                    ├── @mapbox/node-pre-gyp@ extraneous
                    ├── @protobufjs/aspromise@1.1.2 extraneous
                    ├── @protobufjs/inquire@1.1.0 extraneous
                    ├── @root/acme@ extraneous
                    ├── @root/asn1@ extraneous
                    ├── @root/csr@ extraneous
                    ├── @root/encoding@ extraneous
                    ├── @root/greenlock-express@ extraneous
                    ├── @root/greenlock@ extraneous
                    ├── @root/keypairs@ extraneous
                    ├── @root/pem@ extraneous
                    ├── @root/request@ extraneous
                    ├── @root/x509@ extraneous
                    ├── @sentry/browser@5.12.1 extraneous
                    ├── @sentry/core@ extraneous
                    ├── @sentry/hub@ extraneous
                    ├── @sentry/integrations@ extraneous
                    ├── @sentry/minimal@ extraneous
                    ├── @sentry/node@ extraneous
                    ├── @sentry/types@ extraneous
                    ├── @sentry/utils@ extraneous
                    ├── @serialport/binding-abstract@ extraneous
                    ├── @serialport/binding-mock@ extraneous
                    ├── @serialport/bindings-cpp@ extraneous
                    ├── @serialport/bindings-interface@ extraneous
                    ├── @serialport/bindings@ extraneous
                    ├── @serialport/parser-byte-length@ extraneous
                    ├── @serialport/parser-cctalk@ extraneous
                    ├── @serialport/parser-delimiter@ extraneous
                    ├── @serialport/parser-inter-byte-timeout@ extraneous
                    ├── @serialport/parser-packet-length@ extraneous
                    ├── @serialport/parser-readline@ extraneous
                    ├── @serialport/parser-ready@ extraneous
                    ├── @serialport/parser-regex@ extraneous
                    ├── @serialport/parser-slip-encoder@ extraneous
                    ├── @serialport/parser-spacepacket@ extraneous
                    ├── @serialport/stream@ extraneous
                    ├── @sindresorhus/is@4.6.0 extraneous
                    ├── @socket.io/component-emitter@3.1.0 extraneous
                    ├── @szmarczak/http-timer@4.0.6 extraneous
                    ├── @tuyapi/cloud@0.6.1 extraneous
                    ├── @types/babel-types@7.0.11 extraneous
                    ├── @types/bl@ extraneous
                    ├── @types/cacheable-request@6.0.3 extraneous
                    ├── @types/caseless@0.12.2 extraneous
                    ├── @types/cookie@ extraneous
                    ├── @types/cors@ extraneous
                    ├── @types/iobroker@ extraneous
                    ├── @types/keyv@3.1.4 extraneous
                    ├── @types/readable-stream@2.3.15 extraneous
                    ├── @types/request@ extraneous
                    ├── @types/responselike@1.0.0 extraneous
                    ├── @types/retry@0.12.0 extraneous
                    ├── @types/tough-cookie@4.0.2 extraneous
                    ├── abbrev@1.1.1 extraneous
                    ├── abort-controller@3.0.0 extraneous
                    ├── acme-http-01-standalone@ extraneous
                    ├── after@0.8.2 extraneous
                    ├── agent-base@ extraneous
                    ├── ajv@ extraneous
                    ├── alcalzone-shared@ extraneous
                    ├── any-promise@1.3.0 extraneous
                    ├── aproba@2.0.0 extraneous
                    ├── are-we-there-yet@ extraneous
                    ├── arraybuffer.slice@0.0.7 extraneous
                    ├── asn1@ extraneous
                    ├── async-limiter@1.0.1 extraneous
                    ├── async@ extraneous
                    ├── authenticate-pam@1.0.5 extraneous
                    ├── autobind-decorator@2.4.0 extraneous
                    ├── available-typed-arrays@ extraneous
                    ├── aws4@ extraneous
                    ├── axios@ extraneous
                    ├── b4a@1.6.1 extraneous
                    ├── backo2@1.0.2 extraneous
                    ├── base64-arraybuffer@0.1.4 extraneous
                    ├── base64-js@ extraneous
                    ├── base64id@2.0.0 extraneous
                    ├── bignumber.js@ extraneous
                    ├── binary-extensions@ extraneous
                    ├── bl@ extraneous
                    ├── blob@0.0.5 extraneous
                    ├── body-parser@ extraneous
                    ├── bonjour-hap@ extraneous
                    ├── bottleneck@2.19.5 extraneous
                    ├── brace-expansion@1.1.11 extraneous
                    ├── buffer-crc32@0.2.13 extraneous
                    ├── buffer@ extraneous
                    ├── busboy@ extraneous
                    ├── cacheable-lookup@5.0.4 extraneous
                    ├── cacheable-request@7.0.2 extraneous
                    ├── call-bind@ extraneous
                    ├── camelcase@3.0.0 extraneous
                    ├── canvas@ extraneous
                    ├── capitalize@2.0.4 extraneous
                    ├── chokidar@ extraneous
                    ├── cliui@3.2.0 extraneous
                    ├── clone-response@1.0.3 extraneous
                    ├── cluster-key-slot@ extraneous
                    ├── coap-packet@1.1.1 extraneous
                    ├── coap@ extraneous
                    ├── code-point-at@1.1.0 extraneous
                    ├── coffeescript@1.12.7 extraneous
                    ├── coiot-coap@ extraneous
                    ├── color-support@1.1.3 extraneous
                    ├── colors@1.4.0 extraneous
                    ├── commander@ extraneous
                    ├── commist@1.1.0 extraneous
                    ├── component-bind@1.0.0 extraneous
                    ├── component-emitter@1.3.0 extraneous
                    ├── component-inherit@0.0.3 extraneous
                    ├── compressible@ extraneous
                    ├── concat-map@0.0.1 extraneous
                    ├── concat-stream@2.0.0 extraneous
                    ├── connect@3.7.0 extraneous
                    ├── console-control-strings@1.1.0 extraneous
                    ├── core-util-is@ extraneous
                    ├── cors@2.8.5 extraneous
                    ├── cron-parser@ extraneous
                    ├── cross-spawn@ extraneous
                    ├── crypto-js@4.1.1 extraneous
                    ├── crypto@1.0.1 extraneous
                    ├── debounce@ extraneous
                    ├── decache@ extraneous
                    ├── decamelize@1.2.0 extraneous
                    ├── decompress-response@4.2.1 extraneous
                    ├── deep-equal@ extraneous
                    ├── deep-extend@0.6.0 extraneous
                    ├── define-properties@ extraneous
                    ├── delegates@1.0.0 extraneous
                    ├── detect-libc@ extraneous
                    ├── dev-null@0.1.1 extraneous
                    ├── dijkstrajs@ extraneous
                    ├── dns-packet@ extraneous
                    ├── dropbox-v2-api@ extraneous
                    ├── duplexer@ extraneous
                    ├── duplexify@ extraneous
                    ├── ecc-jsbn@ extraneous
                    ├── encode-utf8@1.0.3 extraneous
                    ├── engine.io-client@ extraneous
                    ├── engine.io-parser@ extraneous
                    ├── engine.io@ extraneous
                    ├── error-ex@1.3.2 extraneous
                    ├── es-abstract@ extraneous
                    ├── es-get-iterator@ extraneous
                    ├── es-to-primitive@ extraneous
                    ├── es6-promisify@5.0.0 extraneous
                    ├── esbuild@ extraneous
                    ├── escalade@ extraneous
                    ├── event-target-shim@5.0.1 extraneous
                    ├── eventemitter3@ extraneous
                    ├── events@3.3.0 extraneous
                    ├── execa@ extraneous
                    ├── express-fileupload@ extraneous
                    ├── express-session@ extraneous
                    ├── express@ extraneous
                    ├── fast-deep-equal@ extraneous
                    ├── fast-fifo@1.1.0 extraneous
                    ├── fast-json-stable-stringify@ extraneous
                    ├── fast-srp-hap@ extraneous
                    ├── fast-xml-parser@ extraneous
                    ├── fastseries@ extraneous
                    ├── fecha@ extraneous
                    ├── file-stream-rotator@ extraneous
                    ├── find-up@1.1.2 extraneous
                    ├── for-each@0.3.3 extraneous
                    ├── form-data@ extraneous
                    ├── fs-extra@7.0.1 extraneous
                    ├── fs.realpath@1.0.0 extraneous
                    ├── ftp@ extraneous
                    ├── function.prototype.name@ extraneous
                    ├── functions-have-names@ extraneous
                    ├── futoin-hkdf@1.4.3 extraneous
                    ├── gauge@ extraneous
                    ├── gaxios@ extraneous
                    ├── gcp-metadata@ extraneous
                    ├── get-caller-file@1.0.3 extraneous
                    ├── get-intrinsic@ extraneous
                    ├── get-ssl-certificate@2.3.3 extraneous
                    ├── get-stream@ extraneous
                    ├── get-symbol-description@ extraneous
                    ├── glob@ extraneous
                    ├── google-auth-library@ extraneous
                    ├── google-p12-pem@ extraneous
                    ├── googleapis-common@ extraneous
                    ├── gopd@1.0.1 extraneous
                    ├── got@11.8.6 extraneous
                    ├── graceful-fs@ extraneous
                    ├── greenlock-express@ extraneous
                    ├── greenlock-store-fs@ extraneous
                    ├── gtoken@ extraneous
                    ├── hap-controller@ extraneous
                    ├── hap-nodejs@ extraneous
                    ├── har-validator@ extraneous
                    ├── harmonyhubws@1.0.6 extraneous
                    ├── has-bigints@ extraneous
                    ├── has-binary2@1.0.3 extraneous
                    ├── has-cors@1.1.0 extraneous
                    ├── has-property-descriptors@ extraneous
                    ├── has-symbols@ extraneous
                    ├── has-tostringtag@ extraneous
                    ├── has-unicode@2.0.1 extraneous
                    ├── help-me@ extraneous
                    ├── hexy@0.2.11 extraneous
                    ├── hosted-git-info@ extraneous
                    ├── http-mitm-proxy@0.9.0 extraneous
                    ├── http2-wrapper@1.0.3 extraneous
                    ├── https-proxy-agent@ extraneous
                    ├── human-signals@ extraneous
                    ├── indexof@0.0.1 extraneous
                    ├── inflight@1.0.6 extraneous
                    ├── ini@1.3.8 extraneous
                    ├── internal-slot@ extraneous
                    ├── invert-kv@1.0.0 extraneous
                    ├── iobroker.admin@6.3.5 invalid: "stable" from the root project
                    ├── iobroker.backitup@2.6.19 invalid: "stable" from the root project
                    ├── iobroker.device-reminder@1.2.9 extraneous
                    ├── iobroker.discovery@3.1.0 invalid: "stable" from the root project
                    ├── iobroker.harmony@1.2.2 extraneous
                    ├── iobroker.hue@3.7.1 extraneous
                    ├── iobroker.info@1.9.26 extraneous
                    ├── iobroker.javascript@6.1.4 extraneous
                    ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
                    ├── iobroker.mihome-vacuum@3.9.5 extraneous
                    ├── iobroker.mihome@1.4.0 extraneous
                    ├── iobroker.mqtt@4.0.7 extraneous
                    ├── iobroker.scenes@2.3.9 extraneous
                    ├── iobroker.shelly@6.3.1 extraneous
                    ├── iobroker.simple-api@2.7.2 extraneous
                    ├── iobroker.socketio@4.2.0 extraneous
                    ├── iobroker.terminal@1.0.0 extraneous
                    ├── iobroker.tuya@3.13.1 extraneous
                    ├── iobroker.vis@1.4.16 extraneous
                    ├── iobroker.web@4.3.0 extraneous
                    ├── iobroker.ws.server@ extraneous
                    ├── iobroker.ws@ extraneous
                    ├── iobroker.yahka@0.17.0 extraneous
                    ├── iobroker.zigbee@1.8.10 extraneous
                    ├── iobroker@2.0.3 extraneous
                    ├── ioredis@ extraneous
                    ├── ip@ extraneous
                    ├── is-arguments@ extraneous
                    ├── is-array-buffer@3.0.2 extraneous
                    ├── is-bigint@ extraneous
                    ├── is-boolean-object@ extraneous
                    ├── is-callable@ extraneous
                    ├── is-core-module@ extraneous
                    ├── is-date-object@ extraneous
                    ├── is-generator-function@ extraneous
                    ├── is-map@ extraneous
                    ├── is-nan@ extraneous
                    ├── is-negative-zero@ extraneous
                    ├── is-number-object@ extraneous
                    ├── is-plain-obj@2.1.0 extraneous
                    ├── is-regex@ extraneous
                    ├── is-set@ extraneous
                    ├── is-shared-array-buffer@ extraneous
                    ├── is-string@ extraneous
                    ├── is-symbol@ extraneous
                    ├── is-typed-array@ extraneous
                    ├── is-utf8@0.2.1 extraneous
                    ├── is-weakmap@ extraneous
                    ├── is-weakref@ extraneous
                    ├── is-weakset@ extraneous
                    ├── isarray@2.0.5 extraneous
                    ├── js-sdsl@ extraneous
                    ├── jshashes@1.0.8 extraneous
                    ├── json-bigint@ extraneous
                    ├── json-schema@ extraneous
                    ├── jsonata@ extraneous
                    ├── jsonc-parser@ extraneous
                    ├── jsonfile@4.0.0 extraneous
                    ├── jsprim@ extraneous
                    ├── jszip@ extraneous
                    ├── jws@ extraneous
                    ├── kind-of@6.0.3 extraneous
                    ├── layerr@ extraneous
                    ├── lcid@1.0.0 extraneous
                    ├── leven@2.1.0 extraneous
                    ├── libsodium-wrappers@ extraneous
                    ├── libsodium@ extraneous
                    ├── lie@3.3.0 extraneous
                    ├── load-json-file@1.1.0 extraneous
                    ├── localforage@ extraneous
                    ├── locate-path@5.0.0 extraneous
                    ├── lodash@ extraneous
                    ├── logform@ extraneous
                    ├── lowercase-keys@2.0.0 extraneous
                    ├── luxon@ extraneous
                    ├── macaddress@ extraneous
                    ├── make-dir@3.1.0 extraneous
                    ├── math-random@1.0.4 extraneous
                    ├── mime-db@ extraneous
                    ├── mime@ extraneous
                    ├── mimic-response@2.1.0 extraneous
                    ├── minimatch@ extraneous
                    ├── minimist@ extraneous
                    ├── minipass@ extraneous
                    ├── minizlib@ extraneous
                    ├── mixin-deep@2.0.1 extraneous
                    ├── mkdirp@ extraneous
                    ├── moment@ extraneous
                    ├── mqtt-connection@ extraneous
                    ├── mqtt-packet@ extraneous
                    ├── mqtt@ extraneous
                    ├── multicast-dns-service-types@1.1.0 extraneous
                    ├── multicast-dns@ extraneous
                    ├── mz@2.7.0 extraneous
                    ├── nan@ extraneous
                    ├── negotiator@ extraneous
                    ├── nested-property@ extraneous
                    ├── netmask@ extraneous
                    ├── node-abi@ extraneous
                    ├── node-addon-api@ extraneous
                    ├── node-fetch@ extraneous
                    ├── node-forge@ extraneous
                    ├── node-gyp-build@ extraneous
                    ├── node-hue-api@ extraneous
                    ├── node-inspect@ extraneous
                    ├── node-persist@0.0.11 extraneous
                    ├── node-rest-client@ extraneous
                    ├── node-rsa@1.1.1 extraneous
                    ├── node-schedule@ extraneous
                    ├── node-ssdp@ extraneous
                    ├── nopt@ extraneous
                    ├── normalize-package-data@2.5.0 extraneous
                    ├── normalize-url@6.1.0 extraneous
                    ├── npmlog@ extraneous
                    ├── number-allocator@ extraneous
                    ├── number-is-nan@1.0.1 extraneous
                    ├── object-assign@4.1.1 extraneous
                    ├── object-hash@ extraneous
                    ├── object-inspect@ extraneous
                    ├── object-is@ extraneous
                    ├── object.assign@ extraneous
                    ├── os-locale@1.4.0 extraneous
                    ├── osx-temperature-sensor@ extraneous
                    ├── p-cancelable@2.1.1 extraneous
                    ├── p-finally@1.0.0 extraneous
                    ├── p-limit@2.3.0 extraneous
                    ├── p-locate@4.1.0 extraneous
                    ├── p-queue@ extraneous
                    ├── p-retry@4.6.2 extraneous
                    ├── p-timeout@3.2.0 extraneous
                    ├── p-try@2.2.0 extraneous
                    ├── pako@ extraneous
                    ├── parse-json@2.2.0 extraneous
                    ├── parseqs@ extraneous
                    ├── parseuri@0.0.6 extraneous
                    ├── passport@ extraneous
                    ├── path-exists@2.1.0 extraneous
                    ├── path-is-absolute@1.0.1 extraneous
                    ├── path-parse@1.0.7 extraneous
                    ├── path-type@1.1.0 extraneous
                    ├── picocolors@ extraneous
                    ├── picomatch@ extraneous
                    ├── pidtree@ extraneous
                    ├── pidusage@ extraneous
                    ├── pify@2.3.0 extraneous
                    ├── pinkie-promise@2.0.1 extraneous
                    ├── pinkie@2.0.4 extraneous
                    ├── pngjs@ extraneous
                    ├── prebuild-install@ extraneous
                    ├── process@0.11.10 extraneous
                    ├── prompt@ extraneous
                    ├── proper-lockfile@4.1.2 extraneous
                    ├── psl@ extraneous
                    ├── q@1.1.2 extraneous
                    ├── qrcode@ extraneous
                    ├── qs@ extraneous
                    ├── queue-tick@1.0.1 extraneous
                    ├── randomatic@3.1.1 extraneous
                    ├── read-pkg-up@1.0.1 extraneous
                    ├── read-pkg@1.1.0 extraneous
                    ├── redirect-https@ extraneous
                    ├── redis-commands@ extraneous
                    ├── regexp.prototype.flags@ extraneous
                    ├── reinterval@1.1.0 extraneous
                    ├── request-promise-core@ extraneous
                    ├── request-promise-native@ extraneous
                    ├── request@ extraneous
                    ├── require-main-filename@1.0.1 extraneous
                    ├── resolve@ extraneous
                    ├── responselike@2.0.1 extraneous
                    ├── rfdc@ extraneous
                    ├── rimraf@ extraneous
                    ├── safe-stable-stringify@ extraneous
                    ├── sax@1.2.4 extraneous
                    ├── semaphore@1.1.0 extraneous
                    ├── semver@5.7.1 extraneous
                    ├── send@ extraneous
                    ├── seq-logging@ extraneous
                    ├── serialport@ extraneous
                    ├── set-blocking@2.0.0 extraneous
                    ├── shelly-iot@ extraneous
                    ├── side-channel@ extraneous
                    ├── simple-concat@ extraneous
                    ├── simple-get@3.1.1 extraneous
                    ├── slip@1.0.2 extraneous
                    ├── socket.io-adapter@1.1.2 extraneous
                    ├── socket.io-client@ extraneous
                    ├── socket.io-parser@3.4.1 extraneous
                    ├── socket.io@ extraneous
                    ├── sort-keys-recursive@2.1.8 extraneous
                    ├── sort-keys@4.2.0 extraneous
                    ├── sorted-array-functions@ extraneous
                    ├── source-map-support@ extraneous
                    ├── spdx-correct@ extraneous
                    ├── spdx-exceptions@2.3.0 extraneous
                    ├── spdx-expression-parse@ extraneous
                    ├── spdx-license-ids@3.0.12 extraneous
                    ├── split2@ extraneous
                    ├── sshpk@ extraneous
                    ├── standard-as-callback@ extraneous
                    ├── statuses@ extraneous
                    ├── stealthy-require@1.1.1 extraneous
                    ├── stop-iteration-iterator@1.0.0 extraneous
                    ├── stream-shift@ extraneous
                    ├── streamsearch@ extraneous
                    ├── streamx@2.13.2 extraneous
                    ├── string.prototype.trimend@ extraneous
                    ├── string.prototype.trimstart@ extraneous
                    ├── strip-bom@2.0.0 extraneous
                    ├── strip-json-comments@2.0.1 extraneous
                    ├── strnum@ extraneous
                    ├── suncalc2@1.8.1 extraneous
                    ├── supports-preserve-symlinks-flag@ extraneous
                    ├── systeminformation@ extraneous
                    ├── tar-fs@ extraneous
                    ├── tar-stream@ extraneous
                    ├── tar@ extraneous
                    ├── tcp-ping@0.1.1 extraneous
                    ├── thenify-all@1.6.0 extraneous
                    ├── thenify@3.3.1 extraneous
                    ├── through2@2.0.5 extraneous
                    ├── thunky@1.1.0 extraneous
                    ├── to-array@0.1.4 extraneous
                    ├── treemap-js@1.2.1 extraneous
                    ├── tslib@ extraneous
                    ├── tuyapi@ extraneous
                    ├── tweetnacl@ extraneous
                    ├── typedarray@0.0.6 extraneous
                    ├── typescript@ extraneous
                    ├── uid-number@0.0.6 extraneous
                    ├── ultron@1.1.1 extraneous
                    ├── unbox-primitive@ extraneous
                    ├── universalify@0.1.2 extraneous
                    ├── unix-dgram@ extraneous
                    ├── uri-js@ extraneous
                    ├── url-parse@ extraneous
                    ├── usb@ extraneous
                    ├── util@ extraneous
                    ├── uuid@ extraneous
                    ├── validate-npm-package-license@3.0.4 extraneous
                    ├── virtual-tsc@ extraneous
                    ├── vows@ extraneous
                    ├── wake_on_lan@1.0.0 extraneous
                    ├── webdav@ extraneous
                    ├── websocket-stream@ extraneous
                    ├── which-boxed-primitive@ extraneous
                    ├── which-collection@ extraneous
                    ├── which-module@1.0.0 extraneous
                    ├── which-typed-array@ extraneous
                    ├── which@ extraneous
                    ├── wide-align@1.1.5 extraneous
                    ├── winston-daily-rotate-file@ extraneous
                    ├── winston-seq-updated@ extraneous
                    ├── winston-syslog@ extraneous
                    ├── winston-transport@ extraneous
                    ├── winston@ extraneous
                    ├── wrap-ansi@2.1.0 extraneous
                    ├── ws@ extraneous
                    ├── xml2js@ extraneous
                    ├── xmlbuilder@ extraneous
                    ├── xmlhttprequest-ssl@ extraneous
                    ├── xtend@4.0.2 extraneous
                    ├── y18n@3.2.2 extraneous
                    ├── yallist@ extraneous
                    ├── yargs-parser@ extraneous
                    ├── yargs@7.1.2 extraneous
                    ├── yeast@0.1.2 extraneous
                    ├── zigbee-herdsman-converters@ extraneous
                    ├── zigbee-herdsman@ extraneous
                    └── zlib@ extraneous
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-06T14_38_13_261Z-debug-0.log
                      @subman82 sagte in js-controller lässts sich nicht updaten:
                      buster
                      ist das der Grund für die inkompatibilität?
                      Das OS ist vollkommen veraltet. Wir sind da bereits bei v12
                      subman82
                      @homoran said in js-controller lässts sich nicht updaten:
                      buster
                      Ich habe heute versucht das Betriebssystem upzudaten von Buster zu bullseye um dann weiter upzudaten.
                      Vorher hab ich mit WIN32 ein Image von meiner sd-Karte erstellt (das hat glaube ich sogar geklappt)
                      Nachdem ich in nano die listen von buster zu bullseye geändert habe, kamen jedoch Fehlermeldungen und ich hab
                      mich dann nicht getraut weiter fortzufahren. Ich habe die ANleitung hier verwendet:
                      https://schroederdennis.de/tutorial-howto/debian-10-buster-auf-debian-11-bullseye-linux-updaten-anleitung/
                      Oder welche könnt ihr mir empfehlen? Kann ich auch direkt auf die aktuelle OS Version updaten?
                      pi@raspberrypi:~ $  sudo nano /^C
                      pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list
                      pi@raspberrypi:~ $ ^C
                      pi@raspberrypi:~ $ sudo apt update
                      Holen:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                      Ign:2 http://security.debian.org/debian-security bullseye-seCurity InRelease
                      Fehl:3 http://security.debian.org/debian-security bullseye-seCurity Release
                        404  Not Found [IP: 2a04:4e42:8d::644 80]
                      Holen:4 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                      OK:5 https://deb.nodesource.com/node_18.x buster InRelease
                      OK:6 http://archive.raspberrypi.org/debian buster InRelease
                      Fehl:1 http://deb.debian.org/debian bullseye InRelease
                        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PU        BKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
                      Fehl:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PU        BKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                      E: Das Depot »http://security.debian.org/debian-security bullseye-seCurity Release« enthält keine Release-Datei.
                      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standa        rdmäßig deaktiviert.
                      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite        apt-secure(8).
                      W: GPG-Fehler: http://deb.debian.org/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werd        en, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUB        KEY 605C66F00D6C9793
                      E: Das Depot »http://deb.debian.org/debian bullseye InRelease« ist nicht signiert.
                      W: GPG-Fehler: http://deb.debian.org/debian bullseye-updates InRelease: Die folgenden Signaturen konnten nicht überpr        üft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E13        1
                      E: Das Depot »http://deb.debian.org/debian bullseye-updates InRelease« ist nicht signiert.
                      • S subman82
                        buster
                        bullseye-seCurity
                        Das dürfte schon mal ein Typo sein.
                        Das System ist an so vielen Stellen krumm und schief, ich würde es neuinstallieren. Ist weniger Arbeit als dadran herumzuflicken.
                        64bit 'Bullseye' Lite
                        • S subman82
                          buster
                          warum was externes?
                          https://forum.iobroker.net/post/667685
                            warum was externes?
                            subman82
                            @homoran warum was externes?
                            gegoogelt und da gabs ein Video zu....die Verzweiflung ist halt groß:/
                            @homoran : bzgl: https://forum.iobroker.net/post/667685
                            Da ich das System noch nie installiert habe, wäre eine Neuinstallation für mich auch nicht mal so eben gemacht.
                            Wie man merkt , bin ich froh wenn ich den Laptop an bekomme ohne das Internet zu löschen.
                            Ich hab es jetzt nochmal mit deinem Link versucht, scheitere aber schon am ersten Schritt die Links in die Verzeichnisse zu packen,damit mit dem Befehl sudo apt update das richtige in Gang gesetzt wird.
                            über "sudo nano /etc/apt/sources.list " müsste ich doch das hier hinterlegen oder?
                            Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                            Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
                            E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
                            N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
                            Do you want to accept these changes and continue updating from this repository? [y/N]
                            wobei ich dann nicht weiss wo ich mit deb... beginne oder # oder #deb-src oder was auch immer.
                            Ich habe meine jetzige Buster Version dann mit sudo apt update mit dem alten Eintrag upgedated.
                            deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                            # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                            und anschließend folgendes in die "sudo nano /etc/apt/sources.list " neu eingetragen:
                            deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                            #Uncomment line below then 'apt-get update' to enable 'apt-get source'
                            #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                            Das hat aber auch nicht geklappt, da sich im ersten Link noch etwas von Buster gezogen wird:
                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                            Aktualisierung für 566 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                            Ich werd mir wohl mal ein zweites Raspberry kaufen und versuchen es selber zu installieren,damit ich das mal lerne.
                            Vielen Dank soweit schon mal!!
                            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                            • S subman82
                              Wie kommt denn das aktuelle Konstrukt auf die Kiste?
                              • S subman82
                                sudo apt update
                                funktioniert aus jedem Verzeichnis heraus.
                                Mit den sed-Kommandos stellt man alles rekursiv auf bullseye um. Setzt allerdings eine saubere Grundlage voraus.
                                Und mit dem ganzen Zauber kommst du dann immer noch nicht auf eine 64bit-Version, das geht nur über eine Neuinstallation, weswegen genau das meine Empfehlung an der Stelle ist.
                                  subman82
                                  Kann man fertig im Internet kaufen, dann müssen nur noch die Adapter runtergeladen und
                                  entsprechend eingestellt werden. Das hab ich noch hinbekommen. Soweit läuft alles noch aber
                                  ich möchte es halt aktualisieren und was für ein Chaos ich im System veranstaltet habe, habt ihr ja schon gesehen.
                                  • S subman82
                                    • Betriebssystem installieren
                                    • curl -sLf https://iobroker.net/install.sh | bash - ausführen
                                    feddisch!
                                      sudo apt update
                                      subman82
                                      sudo apt update
                                      Ah ok, dass mit der 64bit Version hab ich jetzt erst verstanden. Dann versuch ich es mit einer zweiten Raspberry mal selber.
                                      Wenn ich alles zusammen habe such ich im Forum nach der Anleitung und wie ich den ganzen iobroker-Kram implementiert bekomme. Das sollte klappen oder muss ich das dann auch alles neu machen?
                                      • S subman82
                                        sudo apt update
                                        @subman82
                                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                          feddisch!
                                          subman82
                                          feddisch!
                                          Ich meine das Rasbian oder werfe ich jetzt alles durcheinander?
                                          Und dann ist die Frage ob ich meine ganzen Einstellungen von den Adaptern über Backitup drauf bekomme.
                                          Irgendwie habe ich es geschafft dass regelmässig Backups gemacht werden, aber ich hab noch nicht geschaut wie ich die aufgespielt bekomme und was da alles aufgespielt wird. Muss ich dann mal hier nachlesen und ausprobieren.
