  4. Huawei Sun2000 & ioBroker via JS script funktioniert
    apollon77A
481 Beiträge 62 Kommentatoren 186.8k Aufrufe 63 Beobachtet
  • S spooky82
    EDIT: Hat sich erledigt: Ich habe javascript.3 genutzt - daher kam der Fehler - stupid me :-(
    @chris_b Hi, ich habe auch soeben das Skript aktiviert und erhalte folgende Fehler:
    18:45:06.075	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:369:23)
    18:45:06.075	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.075	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:370:9)
    18:45:06.076	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:374:22)
    18:45:06.076	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.077	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:379:66)
    18:45:06.077	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.077	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:380:9)
    18:45:06.079	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:383:60)
    18:45:06.079	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.084	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:384:9)
    18:45:06.084	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.084	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:385:9)
    18:45:06.085	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.085	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:388:66)
    18:45:06.086	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:391:65)
    18:45:06.086	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.087	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:394:65)
    18:45:06.087	warn	javascript.3 (26162) at Object.<anonymous> (script.js.PV_auslesen.Huawei_WR_auslesen_V2:413:9)
    18:45:06.087	warn	javascript.3 (26162) at ProcessData (script.js.PV_auslesen.Huawei_WR_auslesen_V2:395:65)
    Hast du eine Idee, woran das liegen könnte?
    Die Datenpunkte werden noch erzeugt, danach passiert nichts mehr, außer diese Warnungen.
    Danke schön.
    C
    C
    Chris_B
    #231
    @spooky82 Ja, das wurde oben auch schon bemerkt. Das Skript enthält 'hard-coded' javascript.0 (also Instanz null). Das könnte (und sollte) man besser machen... Gruss
    • J juggi1962
      @juggi1962 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
      @chris_b sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
      @melonea Siehe soeben gepostet von mir.
      Achtung: Connection Funktion eingebaut, aber nicht automatischer reconnect, da das bei mir nicht funktioniert hat.
      Zum Einbinden wie oben beschrieben vorgehen.
      Ich hoffe, das hilft. Gruss
      Hmmm, da ich in der Materie ein kompletter neuling bin, wie bringe ich den automatischen reconnect dann zum laufen, oder verstehe ich da was falsch? Muss ich im Skript was umstellen, damit das automatisch geht?
      Sorry für meine blöden Fargen.
      Danke für deine Bemühungen, Gruß Jürgen.
      Hallo @Chris_b
      Hab das Skript erfolgreich installiert aber leider sind folgende Fehler nach gut einer halben Stunde Laufzeit aufgetreten
      javascript.0
      2023-07-24 16:36:50.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:47.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:44.395	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:41.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:38.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:35.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:32.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:29.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:26.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:23.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:20.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:17.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:14.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:11.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:08.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:05.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:36:02.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:59.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:56.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:53.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:50.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:47.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:44.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:41.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:38.394	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:35.392	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:32.392	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:29.391	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:26.391	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:23.393	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:20.392	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:17.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:14.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:11.391	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:08.391	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:05.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:35:02.391	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:59.391	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:56.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:53.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:50.389	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:47.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:44.389	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:41.390	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:38.389	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38200 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:35.388	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:32.389	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:29.388	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:26.387	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:23.386	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38400 from id: 1 with error: undefined
      javascript.0
      2023-07-24 16:34:20.387	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000: Error received reading address 38300 from id: 1 with error: undefined
      Nach neustart ging es wieder. Das ist mein Problem das ich seit anfang an habe.
      Mit dem einfacheren Skript wo aber die Batterie und alles was neu von dir ist fehlt ging es da sich das Skript immer wieder neu verbunden hat.
      // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
      // If you like this code, feel free to buy me a beer ...
      // Have fun with it! der Kachel
      // @ts-ignore
      var modbusRTU = require("modbus-serial");
      var client = new modbusRTU();
      var modbusErrorMessages = [
          "Unknown error",
          "Illegal function (device does not support this read/write function)",
          "Illegal data address (register not supported by device)",
          "Illegal data value (value cannot be written to this register)",
          "Slave device failure (device reports internal error)",
          "Acknowledge (requested data will be available later)",
          // "Slave device busy (retry request again later)"
      // Enter your inverter modbus IP and port here:
      const modbusHost = "192.168.1.7";
      const modbusPort = 502;
      // Enter the Modbus-IDs of your Sun2000 inverters here:
      const modbusID = [1];
      // On which Modbus-ID can we reach the power meter? (via Sun2000!)
      const powerMeterID = 0;
      // Connect to modbus client
      ConnectModbus();
      // These register spaces need to be read:
      const registerSpacesToReadContinuously = [[37100, 114],[32000, 116]];
      var registerSpacesToReadContinuouslyPtr = 0;
      var globalDataBuffer = new Array(1);
      globalDataBuffer[0] = new Array(50000); // not optimized....
      // Some helper functions:
      function ReadUnsignedInt16(array) {
          var value = array[0];
          return value;
      function ReadUnsignedInt32(array) {
          var value = array[0] * 256 * 256 + array[1];
          return value;
      function ReadSignedInt16(array) {
          var value = 0;
          if (array[0] > 32767)
              value = array[0] - 65535;
          else
              value = array[0];
          return value;
      function ReadSignedInt32(array) {
          var value = 0;
          for (var i = 0; i < 2; i++) {
              value = (value << 16) | array[i];
          return value;
      function GetU16(dataarray, index) {
          var value = ReadUnsignedInt16(dataarray.slice(index, index+1));
          return value;
      function GetU32(dataarray, index) {
          var value = ReadUnsignedInt32(dataarray.slice(index, index+2));
          return value;
      function GetI16(dataarray, index) {
          var value = ReadSignedInt16(dataarray.slice(index, index+1));
          return value;
      function GetI32(dataarray, index) {
          var value = ReadSignedInt32(dataarray.slice(index, index+2));
          return value;
      function GetString(dataarray, index, length) {
          var shortarray = dataarray.slice(index, index+length);
          var bytearray = [];
          for(var i = 0; i < length; i++) {
              bytearray.push(dataarray[index+i] >> 8);
              bytearray.push(dataarray[index+i] & 0xff);
          var value =  String.fromCharCode.apply(null, bytearray);
          return value;
      function GetZeroTerminatedString(dataarray, index, length) {
          var bytearray = [];
          var value2 = new String(value).trim();
          return value2;
      // Funktion zum Herstellen einer Modbus-Verbindung
      function ConnectModbus() {
          console.log("Init connection to: " + modbusHost +":" + modbusPort);
          // set requests parameters
          client.setTimeout (10000);
          // try to connect
          client.connectTCP (modbusHost, { port: modbusPort })
              .then(function()
                  console.log("Connected, wait for reading...");
              .catch(function(e)
                  console.log(e);
      // Funktion zum Anlegen und Beschreiben eines Datenpunkts
      function ForceSetState(objectname, value, options) {
          if(!existsState("javascript.0." + objectname))      createState(objectname, value, options);
          else                                                setState(objectname, value);
      // Functions to map registers into ioBreaker objects:
      function ProcessPowerMeterStatus() {
          ForceSetState("Solarpower.Huawei.Meter.Status",                     GetU16(globalDataBuffer[powerMeterID], 37100),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL1",                  GetI32(globalDataBuffer[powerMeterID], 37101) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL2",                  GetI32(globalDataBuffer[powerMeterID], 37103) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL3",                  GetI32(globalDataBuffer[powerMeterID], 37105) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.CurrentL1",                  GetI32(globalDataBuffer[powerMeterID], 37107) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Meter.CurrentL2",                  GetI32(globalDataBuffer[powerMeterID], 37109) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Meter.CurrentL3",                  GetI32(globalDataBuffer[powerMeterID], 37111) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePower",                GetI32(globalDataBuffer[powerMeterID], 37113) / 1,      {name: "", unit: "W"});
          ForceSetState("Solarpower.Huawei.Meter.ReactivePower",              GetI32(globalDataBuffer[powerMeterID], 37115) / 1,      {name: "", unit: "Var"});
          ForceSetState("Solarpower.Huawei.Meter.PowerFactor",                GetI16(globalDataBuffer[powerMeterID], 37117) / 1000,   {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Meter.GridFrequency",              GetI16(globalDataBuffer[powerMeterID], 37118) / 100,    {name: "", unit: "Hz"});
          ForceSetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",       GetI32(globalDataBuffer[powerMeterID], 37119) / 100,    {name: "", unit: "kWh"});
          ForceSetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",        GetI32(globalDataBuffer[powerMeterID], 37121) / 100,    {name: "", unit: "kWh"});
          ForceSetState("Solarpower.Huawei.Meter.AccumulatedReactivePower",   GetI32(globalDataBuffer[powerMeterID], 37123) / 100,    {name: "", unit: "kVarh"});
          //ForceSetState("Solarpower.Huawei.Meter.MeterType",                  GetU16(globalDataBuffer[powerMeterID], 37125),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL1-L2",               GetI32(globalDataBuffer[powerMeterID], 37126) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL2-L3",               GetI32(globalDataBuffer[powerMeterID], 37128) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL3-L1",               GetI32(globalDataBuffer[powerMeterID], 37130) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePowerL1",              GetI32(globalDataBuffer[powerMeterID], 37132) / 1,      {name: "", unit: "W"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePowerL2",              GetI32(globalDataBuffer[powerMeterID], 37134) / 1,      {name: "", unit: "W"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePowerL3",              GetI32(globalDataBuffer[powerMeterID], 37136) / 1,      {name: "", unit: "W"});
          //ForceSetState("Solarpower.Huawei.Meter.MeterModel",                 GetU16(globalDataBuffer[powerMeterID], 37138),          {name: "", unit: ""});
      function ProcessInverterStatus(id) {
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".State1",                   GetU16(globalDataBuffer[id-1], 32000),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".State2",                   GetU16(globalDataBuffer[id-1], 32002),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".State3",                   GetU32(globalDataBuffer[id-1], 32003),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm1",                   GetU16(globalDataBuffer[id-1], 32008),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm2",                   GetU16(globalDataBuffer[id-1], 32009),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm3",                   GetU16(globalDataBuffer[id-1], 32010),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",         GetI16(globalDataBuffer[id-1], 32016) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",         GetI16(globalDataBuffer[id-1], 32017) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",         GetI16(globalDataBuffer[id-1], 32018) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",         GetI16(globalDataBuffer[id-1], 32019) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Voltage",         GetI16(globalDataBuffer[id-1], 32020) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Current",         GetI16(globalDataBuffer[id-1], 32021) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Voltage",         GetI16(globalDataBuffer[id-1], 32022) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Current",         GetI16(globalDataBuffer[id-1], 32023) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".InputPower",               GetI32(globalDataBuffer[id-1], 32064) / 1000,   {name: "", unit: "kW"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",       GetU16(globalDataBuffer[id-1], 32066) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",       GetU16(globalDataBuffer[id-1], 32067) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",       GetU16(globalDataBuffer[id-1], 32068) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",          GetU16(globalDataBuffer[id-1], 32069) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",          GetU16(globalDataBuffer[id-1], 32070) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",          GetU16(globalDataBuffer[id-1], 32071) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",          GetI32(globalDataBuffer[id-1], 32072) / 1000,   {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",          GetI32(globalDataBuffer[id-1], 32074) / 1000,   {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",          GetI32(globalDataBuffer[id-1], 32076) / 1000,   {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",       GetI32(globalDataBuffer[id-1], 32078) / 1000,   {name: "", unit: "kW"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",              GetI32(globalDataBuffer[id-1], 32080) / 1000,   {name: "", unit: "kW"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",            GetI32(globalDataBuffer[id-1], 32082) / 1000,   {name: "", unit: "kVar"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",              GetI16(globalDataBuffer[id-1], 32084) / 1000,   {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",            GetU16(globalDataBuffer[id-1], 32085) / 100,    {name: "", unit: "Hz"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",               GetU16(globalDataBuffer[id-1], 32086) / 100,    {name: "", unit: "%"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",      GetI16(globalDataBuffer[id-1], 32087) / 10,     {name: "", unit: "°C"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",     GetU16(globalDataBuffer[id-1], 32088) / 1000,   {name: "", unit: "MOhm"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",             GetU16(globalDataBuffer[id-1], 32089),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                GetU16(globalDataBuffer[id-1], 32090),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",              String(new Date(GetU32(globalDataBuffer[id-1], 32091)*1000)),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",             String(new Date(GetU32(globalDataBuffer[id-1], 32093)*1000)),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   GetU32(globalDataBuffer[id-1], 32106) / 100,          {name: "", unit: "kWh"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",         GetU32(globalDataBuffer[id-1], 32114) / 100,          {name: "", unit: "kWh"});
      function ReadRegisterSpace(id, address, length) {
          client.setID(modbusID[id-1]);
          client.readHoldingRegisters(address, length, function(err, data) {
              if (err) {
                  if (err.modbusCode == null) {
                      console.warn("Lost connection to client. Trying to reconnect...");
                      ConnectModbus();
                  else console.warn("Error received reading address " + address + " from id: " + modbusID[id-1] + " with error: " + err.modbusCode);
              else
                  console.debug("Read data from id/address " + modbusID[id-1] + "/" + address + "\nData is: " + data.data);
                      globalDataBuffer[id-1][address+i] = data.data[i];
      function ProcessData() {
          //console.log("Processing new data...");
          for(var i = 1; i <= modbusID.length; i++) {
              ProcessInverterStatus(i);
          ProcessPowerMeterStatus();
          //console.log("Processing done!");
      // This is the main function triggering a  read via modbus-tcp every two seconds.
      // Processing of data is triggered as soon as one complete set of registers is copied.
      var triggerprocessing = 0;
      var currentinverter = 1;
      setInterval(function() {
          if(triggerprocessing == 1) {
              ProcessData();
          //console.log("Triggering read of inverter " + currentinverter + " at address " + registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0] + " with length " +  registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
          ReadRegisterSpace(currentinverter, registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0], registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
          registerSpacesToReadContinuouslyPtr++;
          if(registerSpacesToReadContinuouslyPtr >= registerSpacesToReadContinuously.length) {
              currentinverter++
              if(currentinverter > modbusID.length){
                  triggerprocessing = 1;
      }, 4000);
      Kann man den Teil // Funktion zum Herstellen einer Modbus-Verbindung, von dem alten Skript irgend wie auch in das Neue bringen oder wäre der automatische reconnect das Selbe.
      Bitte um Hilfe, Gruß Jürgen
      C
      C
      Chris_B
      #232
      @juggi1962 Sorry Jürgen, das ist etwas länger zum Beschreiben. Versuche später einmal zu antworten...
      • R R4
        @chris_b
        PS: Siehe auch
        LUNA2000-(5-30)-S0 Benutzerhandbuch (Ausgabe 13)
        Insbesondere Kapitel "8.5 Speicher mit niedrigem SOC"
        --> SoC unter 5% sollte vermieden werden
        C
        C
        Chris_B
        #233
        @r4 Sorry, ich habe eine blöde Frage: Wo finde ich den Wert für das Minimum SoC. Dein Tip war ja, diesen Wert von 0% auf 5% oder 10% zu erhöhen. Gruss, Christian
        R 1 Antwort Letzte Antwort
        • C Chris_B
          J
          J
          juggi1962
          #234
          Hallo Christian.
          Ja das wäre super, denn so wie du es jetzt hast funktionierts bei mir leider immer nur kurz und dann geht's erst wieder nach Neustart.
          Vielleicht kannst du mir das in deinem Skript umschreiben, ich hab leider keine Ahnung von JS.
          Danke und Gruß Jürgen
          • C Chris_B
            R
            R
            R4
            #235
            Die Daten liest du noch nicht aus bei dir:
            forcesetState("Solarpower.Huawei.Inverter.Battery.ChargingCutoffCapacity",  getU16(GlobalDataBuffer, 47081) / 10, {name: "", unit: "%"});
            forcesetState("Solarpower.Huawei.Inverter.Battery.DischargeCutoffCapacity", getU16(GlobalDataBuffer, 47082) / 10, {name: "", unit: "%"});
            In FusionSolar wäre das dann:
            C 1 Antwort Letzte Antwort
            • R R4
              C
              C
              Chris_B
              #236
              @r4 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
              OK, danke. Steht ja in der Huawei Modbus Beschreibung; hätte ich auch selbst finden können. Vielen Dank. Ist implementiert un läuft problemlos. Ist bei mir auf 15% und 100% gesetzt, also durchaus sinnvoll.
              • K Kachel
                Die Modbus-Ansteuerung vom Huawei Sun2000 Wechselrichter ist über TCP etwas speziell, da nach öffnen des TCP-Ports noch eine Pause eingehalten werden muss, da sonst keine Daten zurück geliefert werden. Auch wird nicht jede Modbus-TCP-Anfrage mit den angeforderten Registern beantwortet. Daher funktioniert die Kommunikation über den normalen Modbus-Adapter im ioBroker nicht.
                Um die verfügbaren Register in den ioBroker zu bekommen hab ich ein js-script geschrieben, dass die Abfrage der Register über TCP macht und die Daten entsprechend parsed. Man braucht dafür im IOBroker nur die ScriptEngine und muss in deren Settings noch die modbus-serial hinzufügen. Danach legt das Script einen großen Satz an Objekten an und aktualisiert die regelmäßig (ca. 2x die Minute). Es werden nur Register gelesen - das Schreiben von Registern ist nicht eingebaut (und bei mir gerade auch nicht nötig). Damit die Netzwerkpakete möglichst groß sind werden die Registern in Blöcken abgefragt.
                Wer möchte kann das Script gerne nutzen. . Einfach IP, Batteriekonfiguration und die Modbus-IDs eintragen und ausführen. Wer es ändern möchte darf dies auch gerne tun - es freut aber sicher alle ioBroker-Nutzer wenn ihr Änderungen auch wieder veröffentlicht.
                Falls jemand noch eine Idee hat, wie man den Huawei File-transfer über Modbus implementieren kann (mit deren speziellem function-code 0x41), würde ich mich freuen. Der fehlt leider damit die Optimierer ihre Echtzeit-Daten in den IOBroker liefern können...
                der Kachel
                var ModbusRTU = require("modbus-serial");
                var client = new ModbusRTU();
                    "Unknown error",
                // open connection to a tcp line
                client.setTimeout(10000);
                client.connectTCP("$$$ADD.YOUR.IP.HERE$$$", { port: 502 });
                const ModBusIDs = [16, 1];
                const PowerMeterID = 0;
                // Enter your battery stack setup. 2 dimensional array.
                // e.g. [[3, 2], [3, 0]] means:
                // First inverter has two battery stacks with 3 + 2 battery modules
                // while second inverter has only one battery stack with 3 battery modules
                const BatteryUnits = [[3, 0], [3, 0]];
                const RegisterSpacesToReadContinuously = [[30000, 81], [37100, 114], [32000, 116], [37000, 68],  [37700, 100], [37800, 100], [38200, 100], [38300, 100], [38400, 100], [35300, 40]];
                var RegisterSpacesToReadContinuouslyPtr = 0;
                var GlobalDataBuffer = new Array(2);
                for(var i=0; i<ModBusIDs.length; i++) {
                    GlobalDataBuffer[i] = new Array(50000); // not optimized....
                function readUnsignedInt16(array) {
                    return value;
                function readUnsignedInt32(array) {
                    return value;
                function readSignedInt16(array) {
                    var value = 0;
                    else
                        value = array[0];
                    return value;
                function readSignedInt32(array) {
                    var value = 0;
                    return value;
                function getU16(dataarray, index) {
                    var value = readUnsignedInt16(dataarray.slice(index, index+1));
                    return value;
                function getU32(dataarray, index) {
                    var value = readUnsignedInt32(dataarray.slice(index, index+2));
                    return value;
                function getI16(dataarray, index) {
                    var value = readSignedInt16(dataarray.slice(index, index+1));
                    return value;
                function getI32(dataarray, index) {
                    var value = readSignedInt32(dataarray.slice(index, index+2));
                    return value;
                function getString(dataarray, index, length) {
                    var bytearray = [];
                    return value;
                function getZeroTerminatedString(dataarray, index, length) {
                    var bytearray = [];
                    return value2;
                function forcesetState(objectname, value, options) {
                    if(!existsState(objectname)) {
                    else {
                function processOptimizers(id) {
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
                function processInverterPowerAdjustments(id) {
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
                function processBattery(id) {
                    // Battery registers 1-15 (Stack 1 related)
                    if(BatteryUnits[id-1][0] > 0) {
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",            getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",       getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",    getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",            getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",             getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                    // Battery registers 16+17 (Storage-related)
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",             getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
                    // Battery register 18-20 (Stack 1 related)
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
                    // Battery register 21-31 (Stack 2 related)
                    if(BatteryUnits[id-1][1] > 0) {
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
                    // Battery register 32-41 (Storage related)
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
                    // Battery registers 42+43 (Battery stack related)
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
                    // Registers 44 to 98: (Battery pack related)
                    for(var i = 1; i <= 2; i++){
                        if(BatteryUnits[id-1][i-1] >= 0) {
                            for(var j = 1; j <= BatteryUnits[id-1][i-1]; j++) {
                                //[[38200, 38242, 38284] [38326, 38368, 38410]]; (+42 for each battery pack, +126 for each stack)
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                                // [[38452, 38454, 38456][38458, 38460, 38462]] ( +2 for each pack, +6 for each stack)
                                createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                                createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                    // Battery registers 110-141 are not supported by this script yet!
                    forcesetState("Solarpower.Huawei.Meter.Status",          getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Meter.VoltageL1",        getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Meter.VoltageL2",        getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Meter.VoltageL3",        getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Meter.CurrentL1",        getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Meter.CurrentL2",        getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Meter.CurrentL3",        getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Meter.ActivePower",     getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
                    forcesetState("Solarpower.Huawei.Meter.ReactivePower",   getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
                    forcesetState("Solarpower.Huawei.Meter.PowerFactor",     getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Meter.GridFrequency",   getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
                    forcesetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
                    forcesetState("Solarpower.Huawei.Meter.MeterType",       getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Meter.VoltageL1-L2",       getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Meter.VoltageL2-L3",       getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Meter.VoltageL3-L1",       getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Meter.ActivePowerL1",    getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
                    forcesetState("Solarpower.Huawei.Meter.ActivePowerL2",    getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
                    forcesetState("Solarpower.Huawei.Meter.ActivePowerL3",    getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
                    forcesetState("Solarpower.Huawei.Meter.MeterModel",      getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
                function processInverterStatus(id) {
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",          getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
                function ProcessDeviceInfo(id) {
                    // Note: Manual says its quantitiy is 15, but that is the number (+1) of 8bit characters
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
                    forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
                function readRegisterSpace(id, address, length) {
                    client.setID(ModBusIDs[id-1]);
                        if (err) {
                            console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
                        else
                            console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                                GlobalDataBuffer[id-1][address+i] = data.data[i];
                function processData() {
                    for(var i = 1; i <= ModBusIDs.length; i++) {
                        ProcessDeviceInfo(i);
                        processInverterStatus(i);
                        processBattery(i);
                        processInverterPowerAdjustments(i);
                        processOptimizers(i);
                        processData();
                    console.log("Triggering read of inverter " + currentinverter + " at address " + RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0] + " with length " +  RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
                    readRegisterSpace(currentinverter, RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0], RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
                    RegisterSpacesToReadContinuouslyPtr++;
                    if(RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length) {
                        currentinverter++
                        if(currentinverter > ModBusIDs.length){
                }, 2000);
                R
                R
                rainereglinsky
                schrieb am zuletzt editiert von rainereglinsky
                #237
                @kachel
                Hallo, bin neue in der iobroker Welt. Habe eine Huawei Sun2000-8KTL-M1 mit 5 KWH Luna Batterie.
                Habe das Skript laufen, es kommen jetzt auch keine Fehlermeldungen mehr, nur ein paar Warnungen.
                2023-07-28 14:27:23.369 - info: javascript.0 (11528) script.js.Huawei: Processing new data...
                2023-07-28 14:27:23.373 - info: javascript.0 (11528) script.js.Huawei: Processing done!
                2023-07-28 14:27:23.373 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 30000 with length 81
                2023-07-28 14:27:25.378 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37100 with length 114
                2023-07-28 14:27:27.391 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 32000 with length 116
                2023-07-28 14:27:29.402 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37000 with length 68
                2023-07-28 14:27:31.416 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37700 with length 100
                2023-07-28 14:27:33.422 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37800 with length 100
                2023-07-28 14:27:35.427 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 38200 with length 100
                2023-07-28 14:27:35.433 - warn: javascript.0 (11528) script.js.Huawei: Error received reading address 38200 from id: 1 with error: Slave device busy (retry request again later)
                2023-07-28 14:27:37.440 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 38300 with length 100
                2023-07-28 14:27:39.454 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 38400 with length 100
                2023-07-28 14:27:39.458 - warn: javascript.0 (11528) script.js.Huawei: Error received reading address 38400 from id: 1 with error: Slave device busy (retry request again later)
                2023-07-28 14:27:41.464 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 35300 with length 40
                2023-07-28 14:27:43.465 - info: javascript.0 (11528) script.js.Huawei: Processing new data...
                2023-07-28 14:27:43.469 - info: javascript.0 (11528) script.js.Huawei: Processing done!
                2023-07-28 14:27:43.469 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 30000 with length 81
                2023-07-28 14:27:45.465 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37100 with length 114
                2023-07-28 14:27:47.474 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 32000 with length 116
                2023-07-28 14:27:49.477 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37000 with length 68
                2023-07-28 14:27:51.485 - info: javascript.0 (11528) script.js.Huawei: Triggering read of inverter 1 at address 37700 with length 100
                hier meine Eingaben:
                "Unknown error",
                client.connectTCP("192.168.178.64", { port: 502 });
                const ModBusIDs = [1];
                const PowerMeterID = [0];
                const BatteryUnits = [[1, 0], [0, 0]];
                Leider werden in den Objekten keine Werte angezeigt - alles Null.
                Mit der BOPV.info Software habe ich jedoch einige Werte bekommen, ist jedoch nicht mein Ding.
                Hat jemand einen Tipp?
                • R rainereglinsky
                  @kachel
                  "Unknown error",
                  C
                  C
                  Chris_B
                  #238
                  @rainereglinsky Die meisten Meldungen sind ja nur Informationen, sind also OK. Die Warnungen kommen auch bei mir 'manchmal' (bei mir jeden Tag 'einige', bspw. 10, es können aber auch einmal mehr sein). Solange sich das in diesem Rahmen hält würde ich es ignorieren - für besseren Input bin ich aber offen.
                  Ich poste etwas später eine optimierte Version des KSripts. Bin gerade noch am Testen.
                  Gruss, Christian
                  • C Chris_B
                    Gruss, Christian
                    C
                    C
                    Chris_B
                    #239
                    Neue Version meines Skripts mit einigen Optimierungen!
                    @R4 Ich habe endlich den Array etwas optimiert. Anstelle von 50'000 Elementen ist er nun 'nur' noch 18'000 Elemente gross. Also Faktor 3 besser. Könnte man nochmals verbessern, es werden ja nur kanpp 1'000 Elemente wirklich verwendet. Lass ich aber jetzt.
                    @juggi1962 Ich habe die reconnect Funkion für Dich nun eingebaut. Ist im Code aber 'auskommentiert'. Um ihn zu aktivieren in den Zeilen 392 bis 395 jeweils das // ganz vorne löschen. Dann wird ein reconnect über den Aufruf von ConnectModbus() durchgeführt
                    Verbesserungen in dieser Version des Skripts:
                    1. Array-Struktur optimiert (Faktor 3 kleiner).
                    2. Es werden neu auch die "Battery Charging / Discharging Cutoff Capacities" gelesen (danke für den Tip @R4 ).
                    3. Funktionsumbenennungen zur Verbesserung der Lesbarkeit (zumindest für mich).
                    4. Reconnect Modbus Funktion 'auskommentiert' vorhanden, kann individuell aktiviert werden.
                    Hier ein Link zum Download des Skripts (Sun2000V2.js):
                    https://1drv.ms/u/s!AuJox5uVBmw-tE6KLGmyPFJhazS4?e=PBfTXh
                    Gruss, Christian
                    bahnuhrB J L 4 Antworten Letzte Antwort
                    • C Chris_B
                      Gruss, Christian
                      bahnuhrB
                      bahnuhrB
                      bahnuhr
                      #240
                      @chris_b
                      Warum externer Link.
                      Stell es doch gleich hier rein.
                      Danke.
                      • bahnuhrB bahnuhr
                        @chris_b
                        C
                        C
                        Chris_B
                        #241
                        @bahnuhr Der Grund dafür: Beim 'Code' Makro gibt es Probleme bei grossen Skripts, es werden '{1}' eingefügt. Erklärung siehe weiter oben in diesem thread. Bei einem externen Link passiert das nicht.
                        Ich möchte mein Skript nicht extra so abändern, dass das nicht passiert. Ich frage mich, wieso das Code Makro nicht korrigiert wird.
                        Falls Du eine Lösung weisst bin ich froh...
                        Gruss
                        • R
                          R
                          rainereglinsky
                          #242
                          Danke für das neue Script. Habe es eingebaut, bekomme aber massive Fehlermeldungen.
                          2023-07-29 13:28:44.166 - info: admin.0 (3692) ==> Connected system.user.admin from ::1
                          2023-07-29 13:28:46.771 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 javascript
                          2023-07-29 13:29:00.017 - warn: javascript.0 (7268) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                          2023-07-29 13:29:15.203 - error: javascript.0 (7268) script.js.Huawei: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) script.js.Huawei: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC", (err, state) => { ... });
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) Error in callback: TypeError: Cannot read properties of undefined (reading 'val')
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) at ProcessData (script.js.Huawei:425:120)
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) at Object. (script.js.Huawei:503:13)
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) at listOnTimeout (node:internal/timers:569:17)
                          2023-07-29 13:29:15.204 - error: javascript.0 (7268) at processTimers (node:internal/timers:512:7)
                          2023-07-29 13:29:44.291 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 admin
                          2023-07-29 13:29:44.296 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 admin
                          2023-07-29 13:29:53.494 - info: admin.0 (3692) ==> Connected system.user.admin from ::1
                          2023-07-29 13:29:59.655 - info: admin.0 (3692) ==> Connected system.user.admin from ::1
                          2023-07-29 13:30:00.020 - warn: javascript.0 (7268) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                          2023-07-29 13:30:02.417 - info: admin.0 (3692) <== Disconnect system.user.admin from ::1 javascript
                          2023-07-29 13:30:05.292 - error: javascript.0 (7268) script.js.Huawei: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
                          2023-07-29 13:30:05.292 - error: javascript.0 (7268) script.js.Huawei: Please disable that setting or use "getState" with a callback, e.g.: getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC", (err, state) => { ... });
                          2023-07-29 13:30:05.293 - error: javascript.0 (7268) Error in callback: TypeError: Cannot read properties of undefined (reading 'val')
                          2023-07-29 13:30:05.293 - error: javascript.0 (7268) at ProcessData (script.js.Huawei:425:120)
                          2023-07-29 13:30:05.293 - error: javascript.0 (7268) at Object. (script.js.Huawei:503:13)
                          2023-07-29 13:30:05.293 - error: javascript.0 (7268) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                          2023-07-29 13:30:05.293 - error: javascript.0 (7268) at listOnTimeout (node:internal/timers:569:17)
                          2023-07-29 13:30:05.293 - error: javascript.0 (7268) at processTimers (node:internal/timers:512:7)
                          Muss die PowerMeterID in eckigen Klammern stehen (wie ModbusID) oder ohne Klammern wie im Script? Ist die ID "0" richtig?
                          Habe mit PowerMeterID =0 oder [0] die gleichen Ergebnisse in den Objekten
                          Alles "NULL" (erst grün, dann rot.
                          Danke vorab für die Hilfe
                          • R rainereglinsky
                            C
                            C
                            Chris_B
                            #243
                            @rainereglinsky
                            1. Bei PowerMeterID: Keine eckigen Klammern. Das ist kein Array, nur eine Zahl.
                            2. Ich denke irgend etwas in Deinen Javascript Settings auf iobroker ist nicht in Ordnung; Du hast ganz komische Fehlermeldungen. Versuch einmal folgendes: Unter den Einstellungen des Javascript Adapters "Nicht alle Zustände beim Start abonnieren" NICHT auswählen (d.h. nicht selektiert).
                              Gruss
                            • C Chris_B
                              Gruss, Christian
                              J
                              J
                              juggi1962
                              #244
                              Hallo Christian vielen Dank, werde ich heute noch testen.
                              Gruß Jürgen
                              • C Chris_B
                                @rainereglinsky
                                  Gruss
                                R
                                R
                                rainereglinsky
                                #245
                                @chris_b
                                Danke für die Info, habe ich gemacht, - Fehler sind weg, dafür hunderte Warnungen. hier nur ein Teil....
                                2023-07-30 17:41:28.939 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC" not found (3) states[id]=null
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:425:24)
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
                                2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.BatteryOverview, state={"val":"null%","ack":false,"ts":1690731688940,"q":0,"from":"system.adapter.javascript.1","lc":1690731688940,"c":"script.js.Huawei"})
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.BatteryOverview, state={"val":"null%","ack":false,"ts":1690731688940,"q":0,"from":"system.adapter.javascript.1","lc":1690731688940,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.InputPower, timerId=undefined) => not found
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.InputPower" not found (3) states[id]=null
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:430:22)
                                2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Derived.PeakPanelPower, timerId=undefined) => {"val":null,"ack":true}
                                2023-07-30 17:41:28.940 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.ActivePower, timerId=undefined) => not found
                                2023-07-30 17:41:28.940 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.ActivePower" not found (3) states[id]=null
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:435:66)
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
                                2023-07-30 17:41:28.941 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Meter.ActivePower, timerId=undefined) => not found
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Meter.ActivePower" not found (3) states[id]=null
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:436:9)
                                2023-07-30 17:41:28.941 - info: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.HouseConsumption, state={"val":0,"ack":false,"ts":1690731688941,"q":0,"from":"system.adapter.javascript.1","lc":1690731688941,"c":"script.js.Huawei"})
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) script.js.Huawei: setForeignState(id=javascript.0.Solarpower.Derived.HouseConsumption, state={"val":0,"ack":false,"ts":1690731688941,"q":0,"from":"system.adapter.javascript.1","lc":1690731688941,"c":"script.js.Huawei"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                2023-07-30 17:41:28.941 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield, timerId=undefined) => not found
                                2023-07-30 17:41:28.941 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield" not found (3) states[id]=null
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:439:60)
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
                                2023-07-30 17:41:28.942 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity, timerId=undefined) => not found
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity" not found (3) states[id]=null
                                2023-07-30 17:41:28.942 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:440:9)
                                2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
                                2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                                2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
                                2023-07-30 17:41:28.943 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
                                2023-07-30 17:41:28.943 - info: javascript.1 (10152) script.js.Huawei: getState(id=javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity, timerId=undefined) => not found
                                2023-07-30 17:41:28.943 - warn: javascript.1 (10152) getState "javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity" not found (3) states[id]=null
                                2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at ProcessData (script.js.Huawei:441:9)
                                2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at Object. (script.js.Huawei:503:13)
                                2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at Timeout._onTimeout (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:2723:34)
                                2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at listOnTimeout (node:internal/timers:569:17)
                                2023-07-30 17:41:28.944 - warn: javascript.1 (10152) at processTimers (node:internal/timers:512:7)
                                Scheinbar werden die Variablen nicht gefunden. Nochmal zur PowerMeterID. Ist die immer "0" oder wo finde ich den wert in der Anlage?
                                Danke vorab.
                                • C Chris_B
                                  Gruss, Christian
                                  J
                                  J
                                  juggi1962
                                  #246
                                  Gruss, Christian
                                  Hallo Christian.
                                  Wollte dir nur mitteilen, dass dein Skript mit aktiviertem Reconnect Modbus seit gestern Abend ohne Probleme läuft.
                                  Hatte auch nur 2-3 Trying to reconnect Warnungen.
                                  Was mir aber bei meinem alten Skript mit reconnect ohne Batterie Abfrage aufgefallen ist,
                                  dass wenn dauernd Warnungen von Trying to reconnect kommen, hat ein neustart des JS Adapters geholfen.
                                  Vielleicht hilft das bei dir auch, da du ja geschrieben hast, dass du andauernd Fehlermeldungen bekommst,
                                  wenn reconnect an ist.
                                  Danke noch mal für deine super Arbeit und Hilfe.
                                  Gruß aus Tirol Jürgen.
                                  • J juggi1962
                                    Gruss, Christian
                                    Hallo Christian.
                                    C
                                    C
                                    Chris_B
                                    #247
                                    @juggi1962 Danke, für das positive Feedback. Ich werde das evtl. auch nochmals versuchen.
                                    Gruss aus Zürich, Christian
                                    • R rainereglinsky
                                      @chris_b
                                      Danke vorab.
                                      C
                                      C
                                      Chris_B
                                      #248
                                      @rainereglinsky Hallo Rainer - hier ist die Antwort vermutlich relativ einfach:
                                      Bei Dir scheint alles auf der Instanz javascript.1 zu laufen. Das ist (glaube ich zumindest) nicht sehr üblich. Normalerweise läuft das in der Instanz javascript.0.
                                      Das Skript passt sich da nicht automatisch an.
                                      Zwei Möglichkeiten: Entweder änderst Du das auf die javascript.0 Instanz; oder Du änderst im Skript alle momentan 57 Orte auf javascript.1 ab. Bevorzugen würde ich Ersteres.
                                      Gruss, Christian
                                      M R 2 Antworten Letzte Antwort
                                      • C Chris_B
                                        Gruss, Christian
                                        M
                                        M
                                        meloneA
                                        #249
                                        @chris_b ev solltest du dafür eine Zeile in der Scriptbeschreibung einfügen. Dieses Szenario kommt ggf noch öfters, z.B. wenn man über eine weitere iObroker Instanz auf einem Raspberry und sich direkt mit dem Wlan des Wechselrichters verbindet. In dem Fall muss man bei halbwegs aktueller Firmware auch den Port auf 6607 ändern. Diese Variante ist deutlich stabiler als der Dongle, insbesondere wenn man häufiger die Daten abfragt.
                                        Vielleicht würde sich auch anbieten das Script und eine Doku auf Github zu stellen. Ich kann ggf gerne ein paar Zeilen für die Dokumentation beitragen.
                                        • M meloneA
                                          C
                                          C
                                          Chris_B
                                          #250
                                          @melonea @melonea Guter Punkt. Dazu folgendes:
                                          1. Ich denke, ich erweitere das Skript so, dass nur an einem Ort die javascript Instanz gesetzt wird, das macht Änderungen einfacher.
                                          2. Weisst Du, wie ich im Skript die Javascript-Instanz-Nummer abfragen kann? Dann würde ich das ins Skript einbauen. Dann wäre das Problem komplett gelöst.
                                          3. Das mit Github ist eine gute Idee. Arbeitest Du via VSCode zur Entwicklung von Code? Ich habe das einmal installiert und hatte dann ziemliche Probleme. Geht das bei Dir gut? Ich würde das gerne in Sachen Code-Versionierung tun, damit ist es dann auch schnell auf Github.
                                            Gruss, Christian
                                          83.9k
