  4. BackItUp - Probleme mit wiederherstellung
    5.3k
79 Beiträge 6 Kommentatoren 7.8k Aufrufe 5 Beobachtet
    @von-cartman
    Die Langfassung von
    iob diag
    bitte. Und mit einem mageren GB an RAM hast du keinen Spielraum da auch noch eine graphische Oberfläche zu betreiben. Abschalten!
    von.cartmanV Offline
    von.cartman
    schrieb am zuletzt editiert von von.cartman
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     08:23:11 up  8:05,  1 user,  load average: 0.05, 0.11, 0.06
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=45.7'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Thu 2023-07-27 08:23:11 CEST
               Universal time: Thu 2023-07-27 06:23:11 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        232M        229M        1.0M        447M        627M
    Swap:            99M          0B         99M
    Total:          1.0G        232M        329M
              909 M total memory
              232 M used memory
              273 M active memory
              291 M inactive memory
              229 M free memory
               76 M buffer memory
              370 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       30G  4.0G   24G  15% /
    devtmpfs       devtmpfs  197M     0  197M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  1.1M  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      91M   16K   91M   1% /run/user/1000
    [Thu Jul 27 00:17:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:92:14:92 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ca500283-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Jul 27 00:17:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jul 27 00:17:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Jul 27 00:17:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    576M    /var/
    262M    /var/cache
    250M    /var/cache/apt
    185M    /var/cache/apt/archives
    123M    /var/lib
    Archived and active journals take up 88.0M in the file system.
    /opt/iobroker/backups:
    4.7M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    35M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.2M    /opt/iobroker/iobroker-data/states.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.1
    /usr/bin/node           v16.20.1
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.1-deb-1nodesource1
      Candidate: 16.20.1-deb-1nodesource1
      Version table:
     *** 16.20.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberryPi-EG                           -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberryPi-EG                           -  enabled
      system.adapter.discovery.0              : discovery             : raspberryPi-EG                           - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Objects and States
    Objects:        136
    States:         96
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13877      482/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15525      525/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14791      484/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14798      484/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15535      525/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13876      482/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15724      590/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13787      341/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15641      435/dhcpcd
    udp        0      0 0.0.0.0:37455           0.0.0.0:*                           108        13789      341/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13918      527/cups-browsed
    udp6       0      0 :::5353                 :::*                                108        13788      341/avahi-daemon: r
    udp6       0      0 :::52284                :::*                                108        13790      341/avahi-daemon: r
    2023-07-27 00:17:23.207  - info: host.raspberryPi-EG connected to Objects and States
    2023-07-27 00:17:23.232  - info: host.raspberryPi-EG added notifications configuration of host
    2023-07-27 00:17:23.802  - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
    2023-07-27 00:17:23.809  - info: host.raspberryPi-EG 3 instances found
    2023-07-27 00:17:23.818  - info: host.raspberryPi-EG starting 2 instances
    2023-07-27 00:17:23.886  - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 590
    2023-07-27 00:17:23.905  - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
    2023-07-27 00:17:23.918  - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
    2023-07-27 00:17:23.930  - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
    2023-07-27 00:17:23.942  - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
    2023-07-27 00:17:23.956  - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
    2023-07-27 00:17:23.969  - info: host.raspberryPi-EG Some obsolete host states deleted.
    2023-07-27 00:17:26.607  - info: admin.0 (590) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 00:17:26.729  - warn: admin.0 (590) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
    2023-07-27 00:17:26.748  - warn: admin.0 (590) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
    2023-07-27 00:17:26.754  - info: admin.0 (590) requesting all states
    2023-07-27 00:17:26.755  - info: admin.0 (590) requesting all objects
    2023-07-27 00:17:27.549  - info: admin.0 (590) received all objects
    2023-07-27 00:17:27.757  - info: admin.0 (590) https server listening on port 8081
    2023-07-27 00:17:27.757  - info: admin.0 (590) Use link "https://localhost:8081" to configure.
    2023-07-27 00:17:27.765  - info: admin.0 (590) Secure socket.io server listening on port 8081
    2023-07-27 00:17:27.825  - warn: admin.0 (590) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
    2023-07-27 00:17:27.874  - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 645
    2023-07-27 00:17:30.065  - info: backitup.0 (645) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
    2023-07-27 00:17:30.199  - info: backitup.0 (645) [iobroker] backup will be activated at 02:40 every 1 day(s)
    iob diag has finished.
    Press any key for a summary
    • von.cartmanV von.cartman
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=45.7'C
      volt=0.9360V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
                909 M total memory
                232 M used memory
                273 M active memory
                229 M free memory
                 76 M buffer memory
                370 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      576M    /var/
      262M    /var/cache
      250M    /var/cache/apt
      123M    /var/lib
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        136
      States:         96
      Pending Updates: 0
      @von-cartman sagte in BackItUp - Probleme mit wiederherstellung:
      Passt doch.
      iobroker add web
      würde ich noch spendieren.
      von.cartmanV 1 Antwort Letzte Antwort
        Passt doch.
        iobroker add web
        von.cartman
        @thomas-braun sagte in BackItUp - Probleme mit wiederherstellung:
        iobroker add web
        vielen dank.
        es funktioniert....
        aber nach wie vor verstehe ich nicht ganz warum?
        ich habe ein Backup wiederhergetllt von einem IOBroker mit mehreren adaptern. Nach wiederherstellung siehe ich die nicht....
          iobroker add web
          vielen dank.
          es funktioniert....
          Hat wohl nicht funktioniert. Ohne Log kann man da aber nichts zu sagen.
            iobroker add web
            vielen dank.
            es funktioniert....
            wie?
            woher kam das Backup?
            und nichts im log?
            sehr wahrscheinlich liegt es an
            aber das ist jetzt nur geraten.
              wie?
              und nichts im log?
              von.cartman
              @homoran sagte in BackItUp - Probleme mit wiederherstellung:
              das kann hinhauen.
              der BackUp ist aus einem 4GB RAM, und der Wiederherstellung TEST hat 1GB RAM
              Ich habe bereit 8GB RASPI bestellt, und versuche es dann noch mal.
              HomoranH ? 2 Antworten Letzte Antwort
                das kann hinhauen.
                das kann hinhauen.
                Was wirklich war steht im log
                • von.cartmanV Offline
                  von.cartman
                  wo finde ich den log
                    von.cartman
                      Seite: Protokolle dort oben den Button herunterladen drücken und das entsprechende Log auswählen
                      siehe auch
                        von.cartman
                        LOG:
                        2023-07-26 21:15:50.978 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 21:15:50.986 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 21:15:50.988 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 21:15:50.989 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
                        2023-07-26 21:15:51.418 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 21:15:51.446 - info: host.raspberryPi-EG Node.js version has changed from unknown to 16.20.1
                        2023-07-26 21:15:51.492 - info: host.raspberryPi-EG Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                        2023-07-26 21:15:51.510 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 21:15:52.071 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 21:15:52.081 - info: host.raspberryPi-EG starting 3 instances
                        2023-07-26 21:15:52.136 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5276
                        2023-07-26 21:15:54.652 - info: admin.0 (5276) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:15:54.701 - info: admin.0 (5276) requesting all states
                        2023-07-26 21:15:54.702 - info: admin.0 (5276) requesting all objects
                        2023-07-26 21:15:54.807 - info: admin.0 (5276) received all objects
                        2023-07-26 21:15:55.042 - info: admin.0 (5276) http server listening on port 8081
                        2023-07-26 21:15:55.043 - info: admin.0 (5276) Use link "http://localhost:8081" to configure.
                        2023-07-26 21:15:55.051 - info: admin.0 (5276) socket.io server listening on port 8081
                        2023-07-26 21:15:55.161 - warn: admin.0 (5276) Repository cannot be read: Active repo - stable
                        2023-07-26 21:15:55.163 - warn: admin.0 (5276) Active repository "stable" cannot be read
                        2023-07-26 21:15:56.110 - info: host.raspberryPi-EG instance system.adapter.discovery.0 started with pid 5299
                        2023-07-26 21:15:58.260 - info: discovery.0 (5299) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:16:00.103 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5318
                        2023-07-26 21:16:02.283 - info: backitup.0 (5318) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:16:02.410 - info: backitup.0 (5318) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 21:16:24.567 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:16:24.772 - info: host.raspberryPi-EG Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-07-26 21:28:13.976 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:29:11.154 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:29:13.048 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:29:38.675 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                        2023-07-26 21:29:38.697 - info: backitup.0 (5318) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:29:38.700 - info: backitup.0 (5318) cleaned everything up...
                        2023-07-26 21:29:38.702 - info: backitup.0 (5318) terminating
                        2023-07-26 21:29:38.703 - info: backitup.0 (5318) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-07-26 21:29:38.734 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                        2023-07-26 21:29:38.751 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:29:39.254 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-07-26 21:29:41.774 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5445
                        2023-07-26 21:29:43.980 - info: backitup.0 (5445) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:29:44.092 - info: backitup.0 (5445) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 21:29:45.886 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:29:56.868 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:29:58.598 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:30:46.595 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                        2023-07-26 21:30:46.603 - info: backitup.0 (5445) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:30:46.606 - info: backitup.0 (5445) cleaned everything up...
                        2023-07-26 21:30:46.608 - info: backitup.0 (5445) terminating
                        2023-07-26 21:30:46.610 - info: backitup.0 (5445) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-07-26 21:30:46.642 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                        2023-07-26 21:30:46.650 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:30:47.202 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-07-26 21:30:49.687 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5493
                        2023-07-26 21:30:51.991 - info: backitup.0 (5493) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:30:52.104 - info: backitup.0 (5493) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 21:31:02.369 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
                        2023-07-26 21:31:41.011 - info: host.raspberryPi-EG received SIGTERM
                        2023-07-26 21:31:41.014 - info: backitup.0 (5493) cleaned everything up...
                        2023-07-26 21:31:41.017 - info: admin.0 (5276) terminating http server on port 8081
                        2023-07-26 21:31:41.013 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                        2023-07-26 21:31:41.013 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=true)
                        2023-07-26 21:31:41.014 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                        2023-07-26 21:31:41.029 - info: backitup.0 (5493) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:31:41.032 - info: admin.0 (5276) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:31:41.037 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                        2023-07-26 21:31:41.037 - info: backitup.0 (5493) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 21:31:41.029 - info: discovery.0 (5299) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:31:41.041 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 send kill signal
                        2023-07-26 21:31:41.042 - info: discovery.0 (5299) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 21:31:41.042 - info: admin.0 (5276) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 21:31:41.042 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                        2023-07-26 21:31:41.605 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 21:31:41.661 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 21:31:41.699 - info: host.raspberryPi-EG instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 21:31:41.700 - info: host.raspberryPi-EG All instances are stopped.
                        2023-07-26 21:31:41.845 - info: host.raspberryPi-EG terminated
                        2023-07-26 21:33:01.981 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 21:33:01.988 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 21:33:01.988 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 21:33:01.990 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
                        2023-07-26 21:33:02.759 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 21:33:02.783 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 21:33:03.189 - info: host.raspberryPi-EG Delete host system.host.raspberryPi-EG
                        2023-07-26 21:33:03.226 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                        2023-07-26 21:33:03.232 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 21:33:03.242 - info: host.raspberryPi-EG starting 2 instances
                        2023-07-26 21:33:03.248 - warn: host.raspberryPi-EG startInstance cannot find adapter "discovery@3.1.0". Try to install it... 1 attempt
                        2023-07-26 21:33:03.249 - info: host.raspberryPi-EG iobroker install discovery@3.1.0 using installedVersion
                        2023-07-26 21:33:03.308 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                        2023-07-26 21:33:03.326 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                        2023-07-26 21:33:03.347 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5737
                        2023-07-26 21:33:03.361 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                        2023-07-26 21:33:03.379 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                        2023-07-26 21:33:03.434 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                        2023-07-26 21:33:03.447 - info: host.raspberryPi-EG Some obsolete host states deleted.
                        2023-07-26 21:33:06.190 - info: admin.0 (5737) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:33:06.328 - info: admin.0 (5737) requesting all states
                        2023-07-26 21:33:06.330 - info: admin.0 (5737) requesting all objects
                        2023-07-26 21:33:07.102 - info: admin.0 (5737) received all objects
                        2023-07-26 21:33:07.307 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5769
                        2023-07-26 21:33:07.316 - info: admin.0 (5737) https server listening on port 8081
                        2023-07-26 21:33:07.317 - info: admin.0 (5737) Use link "https://localhost:8081" to configure.
                        2023-07-26 21:33:07.327 - info: admin.0 (5737) Secure socket.io server listening on port 8081
                        2023-07-26 21:33:07.890 - info: host.raspberryPi-EG iobroker npm-install: NPM version: 8.19.4Installing iobroker.discovery@3.1.0... (System call)
                        2023-07-26 21:33:10.200 - info: backitup.0 (5769) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:33:10.412 - info: backitup.0 (5769) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 21:33:19.509 - info: host.raspberryPi-EG iobroker npm-install:
                        2023-07-26 21:33:19.511 - info: host.raspberryPi-EG iobroker npm-install: added 40 packages in 10s46 packages are looking for funding run `npm fund` for details
                        2023-07-26 21:33:19.546 - info: host.raspberryPi-EG iobroker npm-install: host.raspberryPi-EG install adapter discovery@3.1.0
                        2023-07-26 21:33:19.576 - info: host.raspberryPi-EG iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                        2023-07-26 21:33:19.613 - info: host.raspberryPi-EG iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                        2023-07-26 21:33:19.624 - info: host.raspberryPi-EG iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                        2023-07-26 21:33:19.635 - info: host.raspberryPi-EG iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                        2023-07-26 21:33:19.643 - info: host.raspberryPi-EG iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                        2023-07-26 21:33:19.652 - info: host.raspberryPi-EG iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                        2023-07-26 21:33:19.660 - info: host.raspberryPi-EG iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        2023-07-26 21:33:19.699 - info: host.raspberryPi-EG iobroker npm-install: host.raspberryPi-EG object system.adapter.discovery created/updated
                        2023-07-26 21:33:19.728 - info: host.raspberryPi-EG iobroker npm-install: Update "system.adapter.discovery.0"
                        2023-07-26 21:33:20.789 - info: host.raspberryPi-EG iobroker npm-install: exit 0
                        2023-07-26 21:36:03.742 - info: host.raspberryPi-EG received SIGTERM
                        2023-07-26 21:36:03.746 - info: backitup.0 (5769) cleaned everything up...
                        2023-07-26 21:36:03.746 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                        2023-07-26 21:36:03.747 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=false)
                        2023-07-26 21:36:03.749 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                        2023-07-26 21:36:03.753 - info: admin.0 (5737) terminating https server on port 8081
                        2023-07-26 21:36:03.764 - info: backitup.0 (5769) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:36:03.770 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                        2023-07-26 21:36:03.773 - info: admin.0 (5737) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 21:36:03.778 - info: backitup.0 (5769) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 21:36:03.788 - info: admin.0 (5737) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 21:36:03.809 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                        2023-07-26 21:36:04.353 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 21:36:04.368 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 21:36:04.369 - info: host.raspberryPi-EG All instances are stopped.
                        2023-07-26 21:36:04.588 - info: host.raspberryPi-EG terminated
                        2023-07-26 21:36:13.497 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 21:36:13.504 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 21:36:13.506 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 21:36:13.507 - info: host.raspberryPi-EG ip addresses: fe80::4e85:b5d8:5d31:7a89
                        2023-07-26 21:36:14.798 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 21:36:14.844 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 21:36:16.368 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                        2023-07-26 21:36:16.380 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 21:36:16.394 - info: host.raspberryPi-EG starting 2 instances
                        2023-07-26 21:36:16.504 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 846
                        2023-07-26 21:36:16.522 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                        2023-07-26 21:36:16.615 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                        2023-07-26 21:36:16.639 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                        2023-07-26 21:36:16.660 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                        2023-07-26 21:36:16.681 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                        2023-07-26 21:36:16.712 - info: host.raspberryPi-EG Some obsolete host states deleted.
                        2023-07-26 21:36:20.406 - info: admin.0 (846) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:36:20.452 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1090
                        2023-07-26 21:36:20.626 - info: admin.0 (846) requesting all states
                        2023-07-26 21:36:20.627 - info: admin.0 (846) requesting all objects
                        2023-07-26 21:36:21.729 - info: admin.0 (846) received all objects
                        2023-07-26 21:36:22.062 - info: admin.0 (846) https server listening on port 8081
                        2023-07-26 21:36:22.074 - info: admin.0 (846) Use link "https://localhost:8081" to configure.
                        2023-07-26 21:36:22.091 - info: admin.0 (846) Secure socket.io server listening on port 8081
                        2023-07-26 21:36:23.885 - info: backitup.0 (1090) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:36:24.100 - info: backitup.0 (1090) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 21:40:40.549 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 21:40:40.556 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 21:40:40.557 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 21:40:40.558 - info: host.raspberryPi-EG ip addresses: fe80::4e85:b5d8:5d31:7a89
                        2023-07-26 21:40:41.654 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 21:40:41.814 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 21:40:43.371 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                        2023-07-26 21:40:43.382 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 21:40:43.397 - info: host.raspberryPi-EG starting 2 instances
                        2023-07-26 21:40:43.501 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 831
                        2023-07-26 21:40:43.524 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                        2023-07-26 21:40:43.668 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                        2023-07-26 21:40:43.703 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                        2023-07-26 21:40:43.734 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                        2023-07-26 21:40:43.761 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                        2023-07-26 21:40:43.782 - info: host.raspberryPi-EG Some obsolete host states deleted.
                        2023-07-26 21:40:46.768 - error: admin.0 (831) admin.0 already running
                        2023-07-26 21:40:46.772 - warn: admin.0 (831) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-07-26 21:40:47.342 - error: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-07-26 21:40:47.344 - info: host.raspberryPi-EG Restart adapter system.adapter.admin.0 because enabled
                        2023-07-26 21:40:47.451 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1086
                        2023-07-26 21:40:49.476 - error: backitup.0 (1086) backitup.0 already running
                        2023-07-26 21:40:49.480 - warn: backitup.0 (1086) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-07-26 21:40:50.032 - error: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-07-26 21:40:50.032 - info: host.raspberryPi-EG Restart adapter system.adapter.backitup.0 because enabled
                        2023-07-26 21:43:02.437 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 1319
                        2023-07-26 21:43:04.786 - info: admin.0 (1319) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:43:04.919 - info: admin.0 (1319) requesting all states
                        2023-07-26 21:43:04.920 - info: admin.0 (1319) requesting all objects
                        2023-07-26 21:43:05.296 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1334
                        2023-07-26 21:43:05.707 - info: admin.0 (1319) received all objects
                        2023-07-26 21:43:05.959 - info: admin.0 (1319) https server listening on port 8081
                        2023-07-26 21:43:05.960 - info: admin.0 (1319) Use link "https://localhost:8081" to configure.
                        2023-07-26 21:43:05.990 - info: admin.0 (1319) Secure socket.io server listening on port 8081
                        2023-07-26 21:43:07.837 - info: backitup.0 (1334) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 21:43:07.966 - info: backitup.0 (1334) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 21:46:40.769 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 21:46:40.778 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 21:46:40.780 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 21:46:40.782 - info: host.raspberryPi-EG ip addresses: fe80::4e85:b5d8:5d31:7a89
                        2023-07-26 21:46:42.009 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 21:46:42.051 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 21:46:43.686 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                        2023-07-26 21:46:43.695 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 21:46:43.716 - info: host.raspberryPi-EG starting 2 instances
                        2023-07-26 21:46:43.830 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 852
                        2023-07-26 21:46:43.839 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                        2023-07-26 21:46:43.908 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                        2023-07-26 21:46:43.939 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                        2023-07-26 21:46:43.964 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                        2023-07-26 21:46:43.987 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                        2023-07-26 21:46:44.011 - info: host.raspberryPi-EG Some obsolete host states deleted.
                        2023-07-26 21:46:47.243 - error: admin.0 (852) admin.0 already running
                        2023-07-26 21:46:47.248 - warn: admin.0 (852) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-07-26 21:46:47.788 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1094
                        2023-07-26 21:46:47.830 - error: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-07-26 21:46:47.831 - info: host.raspberryPi-EG Restart adapter system.adapter.admin.0 because enabled
                        2023-07-26 21:46:49.803 - error: backitup.0 (1094) backitup.0 already running
                        2023-07-26 21:46:49.808 - warn: backitup.0 (1094) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        2023-07-26 21:46:50.353 - error: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                        2023-07-26 21:46:50.353 - info: host.raspberryPi-EG Restart adapter system.adapter.backitup.0 because enabled
                        2023-07-26 22:08:20.316 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 1324
                        2023-07-26 22:08:22.675 - info: admin.0 (1324) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 22:08:22.811 - info: admin.0 (1324) requesting all states
                        2023-07-26 22:08:22.814 - info: admin.0 (1324) requesting all objects
                        2023-07-26 22:08:22.817 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1339
                        2023-07-26 22:08:23.762 - info: admin.0 (1324) received all objects
                        2023-07-26 22:08:23.970 - info: admin.0 (1324) https server listening on port 8081
                        2023-07-26 22:08:23.971 - info: admin.0 (1324) Use link "https://localhost:8081" to configure.
                        2023-07-26 22:08:23.985 - info: admin.0 (1324) Secure socket.io server listening on port 8081
                        2023-07-26 22:08:25.453 - info: backitup.0 (1339) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 22:08:25.597 - info: backitup.0 (1339) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 23:12:06.851 - info: host.raspberryPi-EG received SIGTERM
                        2023-07-26 23:12:06.857 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                        2023-07-26 23:12:06.858 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=false)
                        2023-07-26 23:12:06.859 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                        2023-07-26 23:12:06.854 - info: admin.0 (1324) terminating https server on port 8081
                        2023-07-26 23:12:06.856 - info: backitup.0 (1339) cleaned everything up...
                        2023-07-26 23:12:06.872 - info: admin.0 (1324) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 23:12:06.873 - info: backitup.0 (1339) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 23:12:06.875 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                        2023-07-26 23:12:06.883 - info: admin.0 (1324) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 23:12:06.889 - info: backitup.0 (1339) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 23:12:06.917 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                        2023-07-26 23:12:07.446 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 23:12:07.455 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 23:12:07.455 - info: host.raspberryPi-EG All instances are stopped.
                        2023-07-26 23:12:07.544 - info: host.raspberryPi-EG terminated
                        2023-07-26 23:13:06.481 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 23:13:06.488 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 23:13:06.489 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 23:13:06.490 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
                        2023-07-26 23:13:07.142 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 23:13:07.168 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 23:13:07.582 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                        2023-07-26 23:13:07.590 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 23:13:07.600 - info: host.raspberryPi-EG starting 2 instances
                        2023-07-26 23:13:07.649 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 2586
                        2023-07-26 23:13:07.679 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                        2023-07-26 23:13:07.692 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                        2023-07-26 23:13:07.705 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                        2023-07-26 23:13:07.718 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                        2023-07-26 23:13:07.731 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                        2023-07-26 23:13:07.744 - info: host.raspberryPi-EG Some obsolete host states deleted.
                        2023-07-26 23:13:10.083 - info: admin.0 (2586) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 23:13:10.210 - info: admin.0 (2586) requesting all states
                        2023-07-26 23:13:10.211 - info: admin.0 (2586) requesting all objects
                        2023-07-26 23:13:10.816 - info: admin.0 (2586) received all objects
                        2023-07-26 23:13:11.000 - info: admin.0 (2586) https server listening on port 8081
                        2023-07-26 23:13:11.001 - info: admin.0 (2586) Use link "https://localhost:8081" to configure.
                        2023-07-26 23:13:11.009 - info: admin.0 (2586) Secure socket.io server listening on port 8081
                        2023-07-26 23:13:11.636 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 2609
                        2023-07-26 23:13:13.891 - info: backitup.0 (2609) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 23:13:14.001 - info: backitup.0 (2609) [iobroker] backup will be activated at 02:40 every 1 day(s)
                        2023-07-26 23:14:49.079 - info: host.raspberryPi-EG received SIGTERM
                        2023-07-26 23:14:49.089 - info: backitup.0 (2609) cleaned everything up...
                        2023-07-26 23:14:49.083 - info: admin.0 (2586) terminating https server on port 8081
                        2023-07-26 23:14:49.094 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                        2023-07-26 23:14:49.095 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=false)
                        2023-07-26 23:14:49.095 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                        2023-07-26 23:14:49.106 - info: admin.0 (2586) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 23:14:49.105 - info: backitup.0 (2609) Got terminate signal TERMINATE_YOURSELF
                        2023-07-26 23:14:49.110 - info: backitup.0 (2609) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 23:14:49.111 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                        2023-07-26 23:14:49.112 - info: admin.0 (2586) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2023-07-26 23:14:49.152 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                        2023-07-26 23:14:49.674 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 23:14:49.718 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2023-07-26 23:14:49.718 - info: host.raspberryPi-EG All instances are stopped.
                        2023-07-26 23:14:50.147 - info: host.raspberryPi-EG terminated
                        2023-07-26 23:14:52.706 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                        2023-07-26 23:14:52.713 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2023-07-26 23:14:52.714 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                        2023-07-26 23:14:52.715 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
                        2023-07-26 23:14:53.488 - info: host.raspberryPi-EG connected to Objects and States
                        2023-07-26 23:14:53.512 - info: host.raspberryPi-EG added notifications configuration of host
                        2023-07-26 23:14:53.930 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                        2023-07-26 23:14:53.937 - info: host.raspberryPi-EG 3 instances found
                        2023-07-26 23:14:53.946 - info: host.raspberryPi-EG starting 2 instances
                        2023-07-26 23:14:53.996 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 2711
                        2023-07-26 23:14:54.023 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                        2023-07-26 23:14:54.036 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                        2023-07-26 23:14:54.048 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                        2023-07-26 23:14:54.061 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                        2023-07-26 23:14:54.074 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                        2023-07-26 23:14:54.087 - info: host.raspberryPi-EG Some obsolete host states deleted.
                        2023-07-26 23:14:56.490 - info: admin.0 (2711) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 23:14:56.615 - info: admin.0 (2711) requesting all states
                        2023-07-26 23:14:56.617 - info: admin.0 (2711) requesting all objects
                        2023-07-26 23:14:57.321 - info: admin.0 (2711) received all objects
                        2023-07-26 23:14:57.549 - info: admin.0 (2711) https server listening on port 8081
                        2023-07-26 23:14:57.552 - info: admin.0 (2711) Use link "https://localhost:8081" to configure.
                        2023-07-26 23:14:57.562 - info: admin.0 (2711) Secure socket.io server listening on port 8081
                        2023-07-26 23:14:57.983 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 2734
                        2023-07-26 23:15:00.252 - info: backitup.0 (2734) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                        2023-07-26 23:15:00.373 - info: backitup.0 (2734) [iobroker] backup will be activated at 02:40 every 1 day(s)
                          das kann hinhauen.
                          das kann hinhauen.
                          Moin,
                          wirklich Dein Ernst?
                          Versuchst Du auch ein Hefeweizen 0,5 Liter in ein Glas mit 0,1 Liter einzufüllen und Du wunderst Dich nicht, dass es überläuft?
                          Bernd
                            LOG:
                            @von-cartman ich sehe nirgendwo den restore
                            hat der neue Raspi den selben hostnamen und die selbe ip, wie der Spender?
                              von.cartman
                              nein, hat nicht
                                nein, hat nicht
                                @von-cartman dann mach mal iobroker host this
                                was ist denn mit
                                  das kann hinhauen.
                                  Moin,
                                  Bernd
                                  von.cartman
                                  @dp20eic
                                  aber wenn die Flasche zu 85% leer getrunken ist, dann reicht das Glas volkomm
                                  HomoranH von.cartmanV ? 3 Antworten Letzte Antwort
                                    @dp20eic
                                    @dp20eic
                                    falsch!
                                    wenn noch 30% Spülwasser drin sind reicht's erst recht nicht
                                      @dp20eic
                                      von.cartman
                                      @von-cartman
                                      über Spülwasser wa keine rede
                                        @dp20eic
                                        @dp20eic
                                        Moin,
                                        ich bin dann mal raus und trinke lieber 'ne' Flasche Hefeweizen, oder esse einen Fruchtzwerg, hab ich mehr von :)
                                        Bernd
                                          @dp20eic
                                          Moin,
                                          Bernd
                                          von.cartman
                                          @dp20eic
                                          Vielen "DANK" für deine "HILFSBEREITSCHAFT"
