  4. BackItUp - Probleme mit wiederherstellung
    5.3k
79 Beiträge 6 Kommentatoren 7.8k Aufrufe 5 Beobachtet
  • von.cartmanV Offline
    von.cartman
    @homoran sagte in BackItUp - Probleme mit wiederherstellung:
    Was wirklich war steht im log
    wo finde ich den log
      von.cartman
      • von.cartmanV von.cartman
        @von-cartman sagte in BackItUp - Probleme mit wiederherstellung:
        Seite: Protokolle dort oben den Button herunterladen drücken und das entsprechende Log auswählen
        siehe auch
          von.cartman
          LOG:
          2023-07-26 21:15:50.978 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 21:15:50.986 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 21:15:50.988 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 21:15:50.989 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
          2023-07-26 21:15:51.418 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 21:15:51.446 - info: host.raspberryPi-EG Node.js version has changed from unknown to 16.20.1
          2023-07-26 21:15:51.492 - info: host.raspberryPi-EG Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
          2023-07-26 21:15:51.510 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 21:15:52.071 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 21:15:52.081 - info: host.raspberryPi-EG starting 3 instances
          2023-07-26 21:15:52.136 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5276
          2023-07-26 21:15:54.652 - info: admin.0 (5276) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:15:54.701 - info: admin.0 (5276) requesting all states
          2023-07-26 21:15:54.702 - info: admin.0 (5276) requesting all objects
          2023-07-26 21:15:54.807 - info: admin.0 (5276) received all objects
          2023-07-26 21:15:55.042 - info: admin.0 (5276) http server listening on port 8081
          2023-07-26 21:15:55.043 - info: admin.0 (5276) Use link "http://localhost:8081" to configure.
          2023-07-26 21:15:55.051 - info: admin.0 (5276) socket.io server listening on port 8081
          2023-07-26 21:15:55.161 - warn: admin.0 (5276) Repository cannot be read: Active repo - stable
          2023-07-26 21:15:55.163 - warn: admin.0 (5276) Active repository "stable" cannot be read
          2023-07-26 21:15:56.110 - info: host.raspberryPi-EG instance system.adapter.discovery.0 started with pid 5299
          2023-07-26 21:15:58.260 - info: discovery.0 (5299) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:16:00.103 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5318
          2023-07-26 21:16:02.283 - info: backitup.0 (5318) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:16:02.410 - info: backitup.0 (5318) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 21:16:24.567 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:16:24.772 - info: host.raspberryPi-EG Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2023-07-26 21:28:13.976 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:29:11.154 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:29:13.048 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:29:38.675 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-26 21:29:38.697 - info: backitup.0 (5318) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:29:38.700 - info: backitup.0 (5318) cleaned everything up...
          2023-07-26 21:29:38.702 - info: backitup.0 (5318) terminating
          2023-07-26 21:29:38.703 - info: backitup.0 (5318) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-07-26 21:29:38.734 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
          2023-07-26 21:29:38.751 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:29:39.254 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-07-26 21:29:41.774 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5445
          2023-07-26 21:29:43.980 - info: backitup.0 (5445) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:29:44.092 - info: backitup.0 (5445) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 21:29:45.886 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:29:56.868 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:29:58.598 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:30:46.595 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-26 21:30:46.603 - info: backitup.0 (5445) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:30:46.606 - info: backitup.0 (5445) cleaned everything up...
          2023-07-26 21:30:46.608 - info: backitup.0 (5445) terminating
          2023-07-26 21:30:46.610 - info: backitup.0 (5445) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-07-26 21:30:46.642 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
          2023-07-26 21:30:46.650 - info: admin.0 (5276) <== Disconnect system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:30:47.202 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-07-26 21:30:49.687 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5493
          2023-07-26 21:30:51.991 - info: backitup.0 (5493) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:30:52.104 - info: backitup.0 (5493) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 21:31:02.369 - info: admin.0 (5276) ==> Connected system.user.admin from ::ffff:192.168.0.55
          2023-07-26 21:31:41.011 - info: host.raspberryPi-EG received SIGTERM
          2023-07-26 21:31:41.014 - info: backitup.0 (5493) cleaned everything up...
          2023-07-26 21:31:41.017 - info: admin.0 (5276) terminating http server on port 8081
          2023-07-26 21:31:41.013 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-07-26 21:31:41.013 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=true)
          2023-07-26 21:31:41.014 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-26 21:31:41.029 - info: backitup.0 (5493) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:31:41.032 - info: admin.0 (5276) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:31:41.037 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
          2023-07-26 21:31:41.037 - info: backitup.0 (5493) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 21:31:41.029 - info: discovery.0 (5299) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:31:41.041 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 send kill signal
          2023-07-26 21:31:41.042 - info: discovery.0 (5299) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 21:31:41.042 - info: admin.0 (5276) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 21:31:41.042 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
          2023-07-26 21:31:41.605 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 21:31:41.661 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 21:31:41.699 - info: host.raspberryPi-EG instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 21:31:41.700 - info: host.raspberryPi-EG All instances are stopped.
          2023-07-26 21:31:41.845 - info: host.raspberryPi-EG terminated
          2023-07-26 21:33:01.981 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 21:33:01.988 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 21:33:01.988 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 21:33:01.990 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
          2023-07-26 21:33:02.759 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 21:33:02.783 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 21:33:03.189 - info: host.raspberryPi-EG Delete host system.host.raspberryPi-EG
          2023-07-26 21:33:03.226 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
          2023-07-26 21:33:03.232 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 21:33:03.242 - info: host.raspberryPi-EG starting 2 instances
          2023-07-26 21:33:03.248 - warn: host.raspberryPi-EG startInstance cannot find adapter "discovery@3.1.0". Try to install it... 1 attempt
          2023-07-26 21:33:03.249 - info: host.raspberryPi-EG iobroker install discovery@3.1.0 using installedVersion
          2023-07-26 21:33:03.308 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
          2023-07-26 21:33:03.326 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
          2023-07-26 21:33:03.347 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5737
          2023-07-26 21:33:03.361 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
          2023-07-26 21:33:03.379 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
          2023-07-26 21:33:03.434 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
          2023-07-26 21:33:03.447 - info: host.raspberryPi-EG Some obsolete host states deleted.
          2023-07-26 21:33:06.190 - info: admin.0 (5737) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:33:06.328 - info: admin.0 (5737) requesting all states
          2023-07-26 21:33:06.330 - info: admin.0 (5737) requesting all objects
          2023-07-26 21:33:07.102 - info: admin.0 (5737) received all objects
          2023-07-26 21:33:07.307 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5769
          2023-07-26 21:33:07.316 - info: admin.0 (5737) https server listening on port 8081
          2023-07-26 21:33:07.317 - info: admin.0 (5737) Use link "https://localhost:8081" to configure.
          2023-07-26 21:33:07.327 - info: admin.0 (5737) Secure socket.io server listening on port 8081
          2023-07-26 21:33:07.890 - info: host.raspberryPi-EG iobroker npm-install: NPM version: 8.19.4Installing iobroker.discovery@3.1.0... (System call)
          2023-07-26 21:33:10.200 - info: backitup.0 (5769) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:33:10.412 - info: backitup.0 (5769) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 21:33:19.509 - info: host.raspberryPi-EG iobroker npm-install:
          2023-07-26 21:33:19.511 - info: host.raspberryPi-EG iobroker npm-install: added 40 packages in 10s46 packages are looking for funding run `npm fund` for details
          2023-07-26 21:33:19.546 - info: host.raspberryPi-EG iobroker npm-install: host.raspberryPi-EG install adapter discovery@3.1.0
          2023-07-26 21:33:19.576 - info: host.raspberryPi-EG iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
          2023-07-26 21:33:19.613 - info: host.raspberryPi-EG iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
          2023-07-26 21:33:19.624 - info: host.raspberryPi-EG iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
          2023-07-26 21:33:19.635 - info: host.raspberryPi-EG iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
          2023-07-26 21:33:19.643 - info: host.raspberryPi-EG iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
          2023-07-26 21:33:19.652 - info: host.raspberryPi-EG iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
          2023-07-26 21:33:19.660 - info: host.raspberryPi-EG iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
          2023-07-26 21:33:19.699 - info: host.raspberryPi-EG iobroker npm-install: host.raspberryPi-EG object system.adapter.discovery created/updated
          2023-07-26 21:33:19.728 - info: host.raspberryPi-EG iobroker npm-install: Update "system.adapter.discovery.0"
          2023-07-26 21:33:20.789 - info: host.raspberryPi-EG iobroker npm-install: exit 0
          2023-07-26 21:36:03.742 - info: host.raspberryPi-EG received SIGTERM
          2023-07-26 21:36:03.746 - info: backitup.0 (5769) cleaned everything up...
          2023-07-26 21:36:03.746 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-07-26 21:36:03.747 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=false)
          2023-07-26 21:36:03.749 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-26 21:36:03.753 - info: admin.0 (5737) terminating https server on port 8081
          2023-07-26 21:36:03.764 - info: backitup.0 (5769) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:36:03.770 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
          2023-07-26 21:36:03.773 - info: admin.0 (5737) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 21:36:03.778 - info: backitup.0 (5769) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 21:36:03.788 - info: admin.0 (5737) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 21:36:03.809 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
          2023-07-26 21:36:04.353 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 21:36:04.368 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 21:36:04.369 - info: host.raspberryPi-EG All instances are stopped.
          2023-07-26 21:36:04.588 - info: host.raspberryPi-EG terminated
          2023-07-26 21:36:13.497 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 21:36:13.504 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 21:36:13.506 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 21:36:13.507 - info: host.raspberryPi-EG ip addresses: fe80::4e85:b5d8:5d31:7a89
          2023-07-26 21:36:14.798 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 21:36:14.844 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 21:36:16.368 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
          2023-07-26 21:36:16.380 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 21:36:16.394 - info: host.raspberryPi-EG starting 2 instances
          2023-07-26 21:36:16.504 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 846
          2023-07-26 21:36:16.522 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
          2023-07-26 21:36:16.615 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
          2023-07-26 21:36:16.639 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
          2023-07-26 21:36:16.660 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
          2023-07-26 21:36:16.681 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
          2023-07-26 21:36:16.712 - info: host.raspberryPi-EG Some obsolete host states deleted.
          2023-07-26 21:36:20.406 - info: admin.0 (846) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:36:20.452 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1090
          2023-07-26 21:36:20.626 - info: admin.0 (846) requesting all states
          2023-07-26 21:36:20.627 - info: admin.0 (846) requesting all objects
          2023-07-26 21:36:21.729 - info: admin.0 (846) received all objects
          2023-07-26 21:36:22.062 - info: admin.0 (846) https server listening on port 8081
          2023-07-26 21:36:22.074 - info: admin.0 (846) Use link "https://localhost:8081" to configure.
          2023-07-26 21:36:22.091 - info: admin.0 (846) Secure socket.io server listening on port 8081
          2023-07-26 21:36:23.885 - info: backitup.0 (1090) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:36:24.100 - info: backitup.0 (1090) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 21:40:40.549 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 21:40:40.556 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 21:40:40.557 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 21:40:40.558 - info: host.raspberryPi-EG ip addresses: fe80::4e85:b5d8:5d31:7a89
          2023-07-26 21:40:41.654 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 21:40:41.814 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 21:40:43.371 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
          2023-07-26 21:40:43.382 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 21:40:43.397 - info: host.raspberryPi-EG starting 2 instances
          2023-07-26 21:40:43.501 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 831
          2023-07-26 21:40:43.524 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
          2023-07-26 21:40:43.668 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
          2023-07-26 21:40:43.703 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
          2023-07-26 21:40:43.734 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
          2023-07-26 21:40:43.761 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
          2023-07-26 21:40:43.782 - info: host.raspberryPi-EG Some obsolete host states deleted.
          2023-07-26 21:40:46.768 - error: admin.0 (831) admin.0 already running
          2023-07-26 21:40:46.772 - warn: admin.0 (831) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2023-07-26 21:40:47.342 - error: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2023-07-26 21:40:47.344 - info: host.raspberryPi-EG Restart adapter system.adapter.admin.0 because enabled
          2023-07-26 21:40:47.451 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1086
          2023-07-26 21:40:49.476 - error: backitup.0 (1086) backitup.0 already running
          2023-07-26 21:40:49.480 - warn: backitup.0 (1086) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2023-07-26 21:40:50.032 - error: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2023-07-26 21:40:50.032 - info: host.raspberryPi-EG Restart adapter system.adapter.backitup.0 because enabled
          2023-07-26 21:43:02.437 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 1319
          2023-07-26 21:43:04.786 - info: admin.0 (1319) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:43:04.919 - info: admin.0 (1319) requesting all states
          2023-07-26 21:43:04.920 - info: admin.0 (1319) requesting all objects
          2023-07-26 21:43:05.296 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1334
          2023-07-26 21:43:05.707 - info: admin.0 (1319) received all objects
          2023-07-26 21:43:05.959 - info: admin.0 (1319) https server listening on port 8081
          2023-07-26 21:43:05.960 - info: admin.0 (1319) Use link "https://localhost:8081" to configure.
          2023-07-26 21:43:05.990 - info: admin.0 (1319) Secure socket.io server listening on port 8081
          2023-07-26 21:43:07.837 - info: backitup.0 (1334) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 21:43:07.966 - info: backitup.0 (1334) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 21:46:40.769 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 21:46:40.778 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 21:46:40.780 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 21:46:40.782 - info: host.raspberryPi-EG ip addresses: fe80::4e85:b5d8:5d31:7a89
          2023-07-26 21:46:42.009 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 21:46:42.051 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 21:46:43.686 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
          2023-07-26 21:46:43.695 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 21:46:43.716 - info: host.raspberryPi-EG starting 2 instances
          2023-07-26 21:46:43.830 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 852
          2023-07-26 21:46:43.839 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
          2023-07-26 21:46:43.908 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
          2023-07-26 21:46:43.939 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
          2023-07-26 21:46:43.964 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
          2023-07-26 21:46:43.987 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
          2023-07-26 21:46:44.011 - info: host.raspberryPi-EG Some obsolete host states deleted.
          2023-07-26 21:46:47.243 - error: admin.0 (852) admin.0 already running
          2023-07-26 21:46:47.248 - warn: admin.0 (852) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2023-07-26 21:46:47.788 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1094
          2023-07-26 21:46:47.830 - error: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2023-07-26 21:46:47.831 - info: host.raspberryPi-EG Restart adapter system.adapter.admin.0 because enabled
          2023-07-26 21:46:49.803 - error: backitup.0 (1094) backitup.0 already running
          2023-07-26 21:46:49.808 - warn: backitup.0 (1094) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2023-07-26 21:46:50.353 - error: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2023-07-26 21:46:50.353 - info: host.raspberryPi-EG Restart adapter system.adapter.backitup.0 because enabled
          2023-07-26 22:08:20.316 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 1324
          2023-07-26 22:08:22.675 - info: admin.0 (1324) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 22:08:22.811 - info: admin.0 (1324) requesting all states
          2023-07-26 22:08:22.814 - info: admin.0 (1324) requesting all objects
          2023-07-26 22:08:22.817 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 1339
          2023-07-26 22:08:23.762 - info: admin.0 (1324) received all objects
          2023-07-26 22:08:23.970 - info: admin.0 (1324) https server listening on port 8081
          2023-07-26 22:08:23.971 - info: admin.0 (1324) Use link "https://localhost:8081" to configure.
          2023-07-26 22:08:23.985 - info: admin.0 (1324) Secure socket.io server listening on port 8081
          2023-07-26 22:08:25.453 - info: backitup.0 (1339) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 22:08:25.597 - info: backitup.0 (1339) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 23:12:06.851 - info: host.raspberryPi-EG received SIGTERM
          2023-07-26 23:12:06.857 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-07-26 23:12:06.858 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=false)
          2023-07-26 23:12:06.859 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-26 23:12:06.854 - info: admin.0 (1324) terminating https server on port 8081
          2023-07-26 23:12:06.856 - info: backitup.0 (1339) cleaned everything up...
          2023-07-26 23:12:06.872 - info: admin.0 (1324) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 23:12:06.873 - info: backitup.0 (1339) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 23:12:06.875 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
          2023-07-26 23:12:06.883 - info: admin.0 (1324) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 23:12:06.889 - info: backitup.0 (1339) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 23:12:06.917 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
          2023-07-26 23:12:07.446 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 23:12:07.455 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 23:12:07.455 - info: host.raspberryPi-EG All instances are stopped.
          2023-07-26 23:12:07.544 - info: host.raspberryPi-EG terminated
          2023-07-26 23:13:06.481 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 23:13:06.488 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 23:13:06.489 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 23:13:06.490 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
          2023-07-26 23:13:07.142 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 23:13:07.168 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 23:13:07.582 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
          2023-07-26 23:13:07.590 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 23:13:07.600 - info: host.raspberryPi-EG starting 2 instances
          2023-07-26 23:13:07.649 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 2586
          2023-07-26 23:13:07.679 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
          2023-07-26 23:13:07.692 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
          2023-07-26 23:13:07.705 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
          2023-07-26 23:13:07.718 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
          2023-07-26 23:13:07.731 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
          2023-07-26 23:13:07.744 - info: host.raspberryPi-EG Some obsolete host states deleted.
          2023-07-26 23:13:10.083 - info: admin.0 (2586) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 23:13:10.210 - info: admin.0 (2586) requesting all states
          2023-07-26 23:13:10.211 - info: admin.0 (2586) requesting all objects
          2023-07-26 23:13:10.816 - info: admin.0 (2586) received all objects
          2023-07-26 23:13:11.000 - info: admin.0 (2586) https server listening on port 8081
          2023-07-26 23:13:11.001 - info: admin.0 (2586) Use link "https://localhost:8081" to configure.
          2023-07-26 23:13:11.009 - info: admin.0 (2586) Secure socket.io server listening on port 8081
          2023-07-26 23:13:11.636 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 2609
          2023-07-26 23:13:13.891 - info: backitup.0 (2609) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 23:13:14.001 - info: backitup.0 (2609) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-26 23:14:49.079 - info: host.raspberryPi-EG received SIGTERM
          2023-07-26 23:14:49.089 - info: backitup.0 (2609) cleaned everything up...
          2023-07-26 23:14:49.083 - info: admin.0 (2586) terminating https server on port 8081
          2023-07-26 23:14:49.094 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-07-26 23:14:49.095 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=false)
          2023-07-26 23:14:49.095 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-07-26 23:14:49.106 - info: admin.0 (2586) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 23:14:49.105 - info: backitup.0 (2609) Got terminate signal TERMINATE_YOURSELF
          2023-07-26 23:14:49.110 - info: backitup.0 (2609) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 23:14:49.111 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
          2023-07-26 23:14:49.112 - info: admin.0 (2586) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2023-07-26 23:14:49.152 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
          2023-07-26 23:14:49.674 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 23:14:49.718 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2023-07-26 23:14:49.718 - info: host.raspberryPi-EG All instances are stopped.
          2023-07-26 23:14:50.147 - info: host.raspberryPi-EG terminated
          2023-07-26 23:14:52.706 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
          2023-07-26 23:14:52.713 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-07-26 23:14:52.714 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
          2023-07-26 23:14:52.715 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:7fc8:76c:6b00:a2e3 fe80::4e85:b5d8:5d31:7a89 192.168.0.71 fdf9:87b2:c3b6:40c6:e105:fdee:2365:338f fe80::6e6:2044:ded3:b232
          2023-07-26 23:14:53.488 - info: host.raspberryPi-EG connected to Objects and States
          2023-07-26 23:14:53.512 - info: host.raspberryPi-EG added notifications configuration of host
          2023-07-26 23:14:53.930 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
          2023-07-26 23:14:53.937 - info: host.raspberryPi-EG 3 instances found
          2023-07-26 23:14:53.946 - info: host.raspberryPi-EG starting 2 instances
          2023-07-26 23:14:53.996 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 2711
          2023-07-26 23:14:54.023 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
          2023-07-26 23:14:54.036 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
          2023-07-26 23:14:54.048 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
          2023-07-26 23:14:54.061 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
          2023-07-26 23:14:54.074 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
          2023-07-26 23:14:54.087 - info: host.raspberryPi-EG Some obsolete host states deleted.
          2023-07-26 23:14:56.490 - info: admin.0 (2711) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 23:14:56.615 - info: admin.0 (2711) requesting all states
          2023-07-26 23:14:56.617 - info: admin.0 (2711) requesting all objects
          2023-07-26 23:14:57.321 - info: admin.0 (2711) received all objects
          2023-07-26 23:14:57.549 - info: admin.0 (2711) https server listening on port 8081
          2023-07-26 23:14:57.552 - info: admin.0 (2711) Use link "https://localhost:8081" to configure.
          2023-07-26 23:14:57.562 - info: admin.0 (2711) Secure socket.io server listening on port 8081
          2023-07-26 23:14:57.983 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 2734
          2023-07-26 23:15:00.252 - info: backitup.0 (2734) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
          2023-07-26 23:15:00.373 - info: backitup.0 (2734) [iobroker] backup will be activated at 02:40 every 1 day(s)
            einem mageren GB an RAM
            das kann hinhauen.
            der BackUp ist aus einem 4GB RAM, und der Wiederherstellung TEST hat 1GB RAM
            Ich habe bereit 8GB RASPI bestellt, und versuche es dann noch mal.
            das kann hinhauen.
            Moin,
            wirklich Dein Ernst?
            Versuchst Du auch ein Hefeweizen 0,5 Liter in ein Glas mit 0,1 Liter einzufüllen und Du wunderst Dich nicht, dass es überläuft?
            Bernd
            von.cartmanV 1 Antwort Letzte Antwort
              LOG:
              @von-cartman ich sehe nirgendwo den restore
              hat der neue Raspi den selben hostnamen und die selbe ip, wie der Spender?
                von.cartman
                nein, hat nicht
                  nein, hat nicht
                  @von-cartman dann mach mal iobroker host this
                  was ist denn mit
                    das kann hinhauen.
                    Moin,
                    Bernd
                    von.cartman
                    schrieb am zuletzt editiert von von.cartman
                    @dp20eic
                    aber wenn die Flasche zu 85% leer getrunken ist, dann reicht das Glas volkomm
                    HomoranH von.cartmanV ? 3 Antworten Letzte Antwort
                      @dp20eic
                      @dp20eic
                      falsch!
                      wenn noch 30% Spülwasser drin sind reicht's erst recht nicht
                        @dp20eic
                        von.cartman
                        @von-cartman
                        über Spülwasser wa keine rede
                          @dp20eic
                          @dp20eic
                          Moin,
                          ich bin dann mal raus und trinke lieber 'ne' Flasche Hefeweizen, oder esse einen Fruchtzwerg, hab ich mehr von :)
                          Bernd
                            @dp20eic
                            Moin,
                            Bernd
                            von.cartman
                            @dp20eic
                            Vielen "DANK" für deine "HILFSBEREITSCHAFT"
                              was ist denn mit
                              von.cartman
                              ich mache noch ein neuen Versuch.
                              ich halte den laufenden ioBroker (Spender) an
                              dann versuche ich auf dem Emfänger den BackUp einzuspiellen und werde hier noch mal die LOGs presentieren
                                von.cartman
                                @von-cartman
                                Versuch an einer frische IOB Instalation
                                log:
                                2023-07-27 11:42:29.444 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                                2023-07-27 11:42:29.450 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                2023-07-27 11:42:29.451 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                                2023-07-27 11:42:29.452 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:904:57bf:8a9a:40c9 fe80::6f9e:d1a7:4432:627b 192.168.0.71 fdf9:87b2:c3b6:40c6:1782:e626:ec0e:b9f8 fe80::69d:2a37:a967:9aae
                                2023-07-27 11:42:29.852 - info: host.raspberryPi-EG connected to Objects and States
                                2023-07-27 11:42:29.885 - info: host.raspberryPi-EG Node.js version has changed from unknown to 16.20.1
                                2023-07-27 11:42:29.931 - info: host.raspberryPi-EG Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                2023-07-27 11:42:29.949 - info: host.raspberryPi-EG added notifications configuration of host
                                2023-07-27 11:42:30.517 - info: host.raspberryPi-EG 3 instances found
                                2023-07-27 11:42:30.526 - info: host.raspberryPi-EG starting 3 instances
                                2023-07-27 11:42:30.580 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5282
                                2023-07-27 11:42:33.124 - info: admin.0 (5282) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:42:33.173 - info: admin.0 (5282) requesting all states
                                2023-07-27 11:42:33.174 - info: admin.0 (5282) requesting all objects
                                2023-07-27 11:42:33.275 - info: admin.0 (5282) received all objects
                                2023-07-27 11:42:33.514 - info: admin.0 (5282) http server listening on port 8081
                                2023-07-27 11:42:33.515 - info: admin.0 (5282) Use link "http://localhost:8081" to configure.
                                2023-07-27 11:42:33.523 - info: admin.0 (5282) socket.io server listening on port 8081
                                2023-07-27 11:42:33.602 - warn: admin.0 (5282) Repository cannot be read: Active repo - stable
                                2023-07-27 11:42:33.603 - warn: admin.0 (5282) Active repository "stable" cannot be read
                                2023-07-27 11:42:34.553 - info: host.raspberryPi-EG instance system.adapter.discovery.0 started with pid 5305
                                2023-07-27 11:42:36.689 - info: discovery.0 (5305) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:42:38.578 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5338
                                2023-07-27 11:42:40.776 - info: backitup.0 (5338) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:42:40.902 - info: backitup.0 (5338) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                2023-07-27 11:43:27.399 - info: admin.0 (5282) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:43:27.544 - info: host.raspberryPi-EG Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2023-07-27 11:45:01.867 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                                2023-07-27 11:45:01.886 - info: admin.0 (5282) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:45:01.897 - info: admin.0 (5282) terminating http server on port 8081
                                2023-07-27 11:45:01.909 - info: admin.0 (5282) terminating
                                2023-07-27 11:45:01.912 - info: admin.0 (5282) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-07-27 11:45:01.925 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                                2023-07-27 11:45:02.465 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2023-07-27 11:45:04.957 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 5368
                                2023-07-27 11:45:07.265 - info: admin.0 (5368) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:45:07.314 - info: admin.0 (5368) requesting all states
                                2023-07-27 11:45:07.315 - info: admin.0 (5368) requesting all objects
                                2023-07-27 11:45:07.924 - info: admin.0 (5368) received all objects
                                2023-07-27 11:45:08.278 - info: admin.0 (5368) http server listening on port 8081
                                2023-07-27 11:45:08.279 - info: admin.0 (5368) Use link "http://localhost:8081" to configure.
                                2023-07-27 11:45:08.288 - info: admin.0 (5368) socket.io server listening on port 8081
                                2023-07-27 11:45:09.553 - info: admin.0 (5368) failed connection to socket.io from ::ffff:192.168.0.55: Passport was not initialized
                                2023-07-27 11:45:15.798 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:45:21.863 - info: discovery.0 (5305) Discovering devices with a HF-LPB100 chipset...
                                2023-07-27 11:45:21.906 - info: discovery.0 (5305) Discovering mDNS devices...
                                2023-07-27 11:45:21.916 - info: discovery.0 (5305) Discovering ping devices...
                                2023-07-27 11:45:22.104 - info: discovery.0 (5305) Discovering UPnP devices...
                                2023-07-27 11:45:22.112 - info: discovery.0 (5305) Discovering wifi-mi-light devices...
                                2023-07-27 11:45:22.174 - warn: discovery.0 (5305) tr-064.0 not installed
                                2023-07-27 11:45:22.175 - info: discovery.0 (5305) Done discovering tr064 devices. 0 packages received
                                2023-07-27 11:45:24.115 - info: discovery.0 (5305) Done discovering wifi-mi-light devices. 0 packages received
                                2023-07-27 11:45:26.945 - info: discovery.0 (5305) Done discovering udp devices. 1 packages received
                                2023-07-27 11:45:31.868 - info: discovery.0 (5305) Done discovering HF-LPB100 devices. 0 packages received
                                2023-07-27 11:45:36.914 - info: discovery.0 (5305) Done discovering mdns devices. 307 packages received
                                2023-07-27 11:45:37.110 - info: discovery.0 (5305) Done discovering upnp devices. 50 packages received
                                2023-07-27 11:45:48.610 - info: discovery.0 (5305) Done discovering ping devices. 54 packages received
                                2023-07-27 11:45:52.273 - info: discovery.0 (5305) Found 78 addresses
                                2023-07-27 11:50:27.041 - info: discovery.0 (5305) openknx adapter already present for IP 192.168.0.8
                                2023-07-27 11:50:27.044 - info: discovery.0 (5305) openknx adapter already present for IP 192.168.0.9
                                2023-07-27 11:50:37.178 - info: discovery.0 (5305) Discovery finished. Found new or modified 15 instances
                                2023-07-27 11:50:37.344 - info: discovery.0 (5305) Discovery finished
                                2023-07-27 11:51:12.556 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:51:30.950 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2023-07-27 11:51:30.965 - info: backitup.0 (5338) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:51:30.969 - info: backitup.0 (5338) cleaned everything up...
                                2023-07-27 11:51:30.970 - info: backitup.0 (5338) terminating
                                2023-07-27 11:51:30.972 - info: backitup.0 (5338) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-07-27 11:51:31.004 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                                2023-07-27 11:51:31.031 - info: admin.0 (5368) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:51:31.520 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2023-07-27 11:51:34.038 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5885
                                2023-07-27 11:51:36.188 - info: backitup.0 (5885) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:51:36.295 - info: backitup.0 (5885) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                2023-07-27 11:51:38.356 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:51:49.127 - info: admin.0 (5368) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:51:52.030 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:52:38.182 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2023-07-27 11:52:38.199 - info: backitup.0 (5885) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:52:38.203 - info: backitup.0 (5885) cleaned everything up...
                                2023-07-27 11:52:38.206 - info: backitup.0 (5885) terminating
                                2023-07-27 11:52:38.211 - info: backitup.0 (5885) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-07-27 11:52:38.237 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                                2023-07-27 11:52:38.256 - info: admin.0 (5368) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:52:38.751 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2023-07-27 11:52:41.262 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 5972
                                2023-07-27 11:52:43.412 - info: backitup.0 (5972) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:52:43.521 - info: backitup.0 (5972) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                2023-07-27 11:52:49.433 - info: admin.0 (5368) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:54:07.600 - info: host.raspberryPi-EG received SIGTERM
                                2023-07-27 11:54:07.605 - info: admin.0 (5368) terminating http server on port 8081
                                2023-07-27 11:54:07.601 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                                2023-07-27 11:54:07.602 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=true)
                                2023-07-27 11:54:07.603 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2023-07-27 11:54:07.603 - info: backitup.0 (5972) cleaned everything up...
                                2023-07-27 11:54:07.620 - info: discovery.0 (5305) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:54:07.621 - info: admin.0 (5368) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:54:07.621 - info: backitup.0 (5972) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:54:07.625 - info: discovery.0 (5305) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2023-07-27 11:54:07.627 - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                                2023-07-27 11:54:07.629 - info: backitup.0 (5972) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2023-07-27 11:54:07.630 - info: admin.0 (5368) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2023-07-27 11:54:07.636 - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 send kill signal
                                2023-07-27 11:54:07.637 - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                                2023-07-27 11:54:08.200 - info: host.raspberryPi-EG instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2023-07-27 11:54:08.210 - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2023-07-27 11:54:08.256 - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2023-07-27 11:54:08.256 - info: host.raspberryPi-EG All instances are stopped.
                                2023-07-27 11:54:08.437 - info: host.raspberryPi-EG terminated
                                2023-07-27 11:55:04.499 - info: host.raspberryPi-EG iobroker.js-controller version 4.0.24 js-controller starting
                                2023-07-27 11:55:04.506 - info: host.raspberryPi-EG Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                2023-07-27 11:55:04.507 - info: host.raspberryPi-EG hostname: raspberryPi-EG, node: v16.20.1
                                2023-07-27 11:55:04.508 - info: host.raspberryPi-EG ip addresses: 192.168.0.69 fdf9:87b2:c3b6:40c6:904:57bf:8a9a:40c9 fe80::6f9e:d1a7:4432:627b 192.168.0.71 fdf9:87b2:c3b6:40c6:1782:e626:ec0e:b9f8 fe80::69d:2a37:a967:9aae
                                2023-07-27 11:55:05.177 - info: host.raspberryPi-EG connected to Objects and States
                                2023-07-27 11:55:05.206 - info: host.raspberryPi-EG added notifications configuration of host
                                2023-07-27 11:55:05.625 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeCurrent"
                                2023-07-27 11:55:05.632 - info: host.raspberryPi-EG 3 instances found
                                2023-07-27 11:55:05.642 - info: host.raspberryPi-EG starting 3 instances
                                2023-07-27 11:55:05.697 - info: host.raspberryPi-EG instance system.adapter.admin.0 started with pid 6074
                                2023-07-27 11:55:05.723 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewest"
                                2023-07-27 11:55:05.735 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.nodeNewestNext"
                                2023-07-27 11:55:05.748 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmCurrent"
                                2023-07-27 11:55:05.761 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewest"
                                2023-07-27 11:55:05.774 - info: host.raspberryPi-EG Delete state "system.host.raspberryPi-EG.versions.npmNewestNext"
                                2023-07-27 11:55:05.787 - info: host.raspberryPi-EG Some obsolete host states deleted.
                                2023-07-27 11:55:08.298 - info: admin.0 (6074) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:55:08.347 - info: admin.0 (6074) requesting all states
                                2023-07-27 11:55:08.348 - info: admin.0 (6074) requesting all objects
                                2023-07-27 11:55:09.007 - info: admin.0 (6074) received all objects
                                2023-07-27 11:55:09.531 - info: admin.0 (6074) http server listening on port 8081
                                2023-07-27 11:55:09.533 - info: admin.0 (6074) Use link "http://localhost:8081" to configure.
                                2023-07-27 11:55:09.544 - info: admin.0 (6074) socket.io server listening on port 8081
                                2023-07-27 11:55:09.691 - info: host.raspberryPi-EG instance system.adapter.discovery.0 started with pid 6097
                                2023-07-27 11:55:11.922 - info: discovery.0 (6097) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:55:13.668 - info: host.raspberryPi-EG instance system.adapter.backitup.0 started with pid 6116
                                2023-07-27 11:55:15.838 - info: backitup.0 (6116) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.1, js-controller: 4.0.24
                                2023-07-27 11:55:15.891 - error: backitup.0 (6116) [ERROR] [iobroker] <--- Last few GCs --->
                                2023-07-27 11:55:15.892 - error: backitup.0 (6116) [ERROR] [iobroker] [6006:0x478e050] 29464 ms: Mark-sweep 199.9 (205.7) -> 198.7 (202.2) MB, 37.4 / 0.1 ms (+ 0.1 ms in 1 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 5456 ms) (average mu = 0.994, current mu = 0.994) external memory [6006:0x478e050] 37010 ms: Mark-sweep (reduce) 369.0 (371.6) -> 368.6 (371.1) MB, 141.4 / 0.0 ms (+ 3.6 ms in 7 steps since start of marking, biggest step 0.9 ms, walltime since start of marking 5867 ms) (average mu = 0.985, current mu = 0.981) alloca
                                2023-07-27 11:55:15.892 - error: backitup.0 (6116) [ERROR] [iobroker] <--- JS stacktrace --->
                                2023-07-27 11:55:15.893 - error: backitup.0 (6116) [ERROR] [iobroker] FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                2023-07-27 11:55:16.022 - info: backitup.0 (6116) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                2023-07-27 11:55:36.133 - info: admin.0 (6074) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:55:38.025 - info: admin.0 (6074) ==> Connected system.user.admin from ::ffff:192.168.0.55
                                2023-07-27 11:55:41.021 - info: admin.0 (6074) <== Disconnect system.user.admin from ::ffff:192.168.0.55
                                iob diag:
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Model           : Raspberry Pi 4 Model B Rev 1.5
                                Architecture    : aarch64
                                Docker          : false
                                Virtualization  : none
                                Distributor ID: Raspbian
                                Description:    Raspbian GNU/Linux 11 (bullseye)
                                Release:        11
                                Codename:       bullseye
                                PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                NAME="Raspbian GNU/Linux"
                                VERSION_ID="11"
                                VERSION="11 (bullseye)"
                                VERSION_CODENAME=bullseye
                                ID=raspbian
                                ID_LIKE=debian
                                HOME_URL="http://www.raspbian.org/"
                                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                Systemuptime and Load:
                                 11:58:27 up 19 min,  3 users,  load average: 0.06, 0.34, 0.34
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                Other values than 0x0 hint to temperature/voltage problems
                                temp=48.7'C
                                volt=0.9360V
                                *** Time and Time Zones ***
                                               Local time: Thu 2023-07-27 11:58:27 CEST
                                           Universal time: Thu 2023-07-27 09:58:27 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** User and Groups ***
                                pi
                                /home/pi
                                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
                                *** X-Server-Setup ***
                                X-Server:       true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            909M         92M        514M         18M        302M        734M
                                Swap:            99M         99M        0.0K
                                Total:          1.0G        191M        515M
                                          909 M total memory
                                           92 M used memory
                                          109 M active memory
                                          136 M inactive memory
                                          514 M free memory
                                           15 M buffer memory
                                          287 M swap cache
                                           99 M total swap
                                           99 M used swap
                                            0 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       30G  4.3G   24G  16% /
                                devtmpfs       devtmpfs  197M     0  197M   0% /dev
                                tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                tmpfs          tmpfs     182M  1.2M  181M   1% /run
                                /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                                tmpfs          tmpfs      91M   24K   91M   1% /run/user/1000
                                [Thu Jul 27 11:38:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:92:14:92 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c8e5e6e4-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Thu Jul 27 11:38:51 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Thu Jul 27 11:38:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Thu Jul 27 11:38:53 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                TARGET  SOURCE         FSTYPE OPTIONS
                                /       /dev/mmcblk0p2 ext4   rw,noatime
                                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                533M    /var/
                                262M    /var/cache
                                250M    /var/cache/apt
                                185M    /var/cache/apt/archives
                                123M    /var/lib
                                Archived and active journals take up 48.0M in the file system.
                                /opt/iobroker/backups:
                                74M     /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                19M     /opt/iobroker/iobroker-data/
                                15M     /opt/iobroker/iobroker-data/files
                                13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                4.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v16.20.1
                                /usr/bin/node           v16.20.1
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
                                nodejs:
                                  Installed: 16.20.1-deb-1nodesource1
                                  Candidate: 16.20.1-deb-1nodesource1
                                  Version table:
                                 *** 16.20.1-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                     12.22.12~dfsg-1~deb11u4 500
                                No problems detected
                                *** ioBroker-Installation ***
                                ioBroker Status
                                iobroker is not running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                admin:          6.3.5
                                javascript:     "javascript" not found
                                Adapters from github:   0
                                Adapter State
                                  system.adapter.admin.0                  : admin                 : raspberryPi-EG                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.backitup.0               : backitup              : raspberryPi-EG                           -  enabled
                                  system.adapter.discovery.0              : discovery             : raspberryPi-EG                           -  enabled
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): stable
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                Objects and States
                                Objects:        143
                                States:         108
                                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          897        479/cupsd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13123      533/sshd: /usr/sbin
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          13125      533/sshd: /usr/sbin
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          896        479/cupsd
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15781      430/dhcpcd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13108      516/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12907      340/avahi-daemon: r
                                udp        0      0 0.0.0.0:33738           0.0.0.0:*                           108        12909      340/avahi-daemon: r
                                udp6       0      0 :::46193                :::*                                108        12910      340/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        12908      340/avahi-daemon: r
                                2023-07-27 11:56:48.790  - info: backitup.0 (6116) cleaned everything up...
                                2023-07-27 11:56:48.791  - info: admin.0 (6074) terminating http server on port 8081
                                2023-07-27 11:56:48.792  - info: host.raspberryPi-EG received SIGTERM
                                2023-07-27 11:56:48.803  - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 (force=false, process=true)
                                2023-07-27 11:56:48.804  - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 (force=false, process=true)
                                2023-07-27 11:56:48.806  - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2023-07-27 11:56:48.825  - info: admin.0 (6074) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:56:48.827  - info: backitup.0 (6116) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:56:48.826  - info: discovery.0 (6097) Got terminate signal TERMINATE_YOURSELF
                                2023-07-27 11:56:48.832  - info: discovery.0 (6097) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2023-07-27 11:56:48.835  - info: admin.0 (6074) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2023-07-27 11:56:48.835  - info: backitup.0 (6116) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2023-07-27 11:56:48.836  - info: host.raspberryPi-EG stopInstance system.adapter.admin.0 send kill signal
                                2023-07-27 11:56:48.840  - info: host.raspberryPi-EG stopInstance system.adapter.discovery.0 send kill signal
                                2023-07-27 11:56:48.841  - info: host.raspberryPi-EG stopInstance system.adapter.backitup.0 send kill signal
                                2023-07-27 11:56:49.419  - info: host.raspberryPi-EG instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2023-07-27 11:56:49.467  - info: host.raspberryPi-EG instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2023-07-27 11:56:49.505  - info: host.raspberryPi-EG instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2023-07-27 11:56:49.505  - info: host.raspberryPi-EG All instances are stopped.
                                2023-07-27 11:56:49.651  - info: host.raspberryPi-EG terminated
                                iob diag has finished.
                                Press any key for a summary
                                  @von-cartman
                                  @von-cartman
                                  doch! aka Desktop
                                    @von-cartman
                                    log:
                                    iob diag:
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=48.7'C
                                    volt=0.9360V
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       true
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M         99M        0.0K
                                              909 M total memory
                                               92 M used memory
                                              109 M active memory
                                              514 M free memory
                                               15 M buffer memory
                                              287 M swap cache
                                               99 M total swap
                                               99 M used swap
                                                0 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    533M    /var/
                                    262M    /var/cache
                                    250M    /var/cache/apt
                                    123M    /var/lib
                                    /usr/bin/npm            8.19.4
                                    /usr/bin/npx            8.19.4
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        143
                                    States:         108
                                    Pending Updates: 0
                                    @von-cartman sagte in BackItUp - Probleme mit wiederherstellung:
                                    braucht's noch mehr?
                                    Dein RAM reicht nicht.
                                    zu viel Spülwasser im Glas!
                                    wie groß ist das Backup?
                                    Instanz von backitup auf debug stellen!
                                    da ist wieder nichts vom restore zu sehen
                                    von.cartmanV ? 4 Antworten Letzte Antwort
                                      von.cartmanV Offline
                                      von.cartman
                                      Ok. Vielen DANK
                                      Dann muss ich wohl warten bis der 8GB ankommt.
                                      • von.cartmanV von.cartman
                                        Ok. Vielen DANK
                                        Vielen DANK
                                        gib lieber Antworten
                                          von.cartman
                                          @homoran sagte in BackItUp - Probleme mit wiederherstellung:
                                          75 MB
