  3. Einsteigerfragen
  4. Installation
  5. Neuaufsetzen Beelink Mini S 11. Generation
67 Beiträge 6 Kommentatoren 9.9k Aufrufe 4 Beobachtet
  • S SvenH75
    @dp20eic Hallo, hab schon gesucht, aber bin mir da echt unsicher und möchte nix ganz kaputt mache……
    Hab folgendes gefunden:
    https://forum.proxmox.com/threads/probleme-mit-unstabilen-system.116873/
    Ist das vergleichbar?
    anbei der Log nochmal:
    Jul 09 18:09:04 pve kernel: pcieport 0000:00:1c.O: [0]RxErr
    (First)
    Jul 09 18:09:19 pve kernel: pcieport 0000:00:1c.O: AER: Multiple Corrected error received: 0000:00:1c.O
    Jul 09 18:09:19 pve kernel: pcieport 0000:00:1c.O: PCle Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
    Jul 09 18:09:19 pve kernel: pcieport 0000:00:1c.O: device [8086:4dbe] error status/mask=00000001/00002000
    Jul 09 18:09:19 pve kernel: pcieport 0000:00:1c.O: [0]RxErr
    (First)
    Jul 09 18:14:55 pve kernel: pcieport 0000:00:1c.O: AER: Multiple Corrected error received: 0000:00:1c.0
    Jul 09 18:14:55 pve kernel: pcieport 0000:00:1c.O: PCle Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
    Jul 09 18:14:55 pve kernel: pcieport 0000:00:1c.O: device [8086:4dbe] error status/mask=00000001/00002000
    Jul 09 18:14:55 pve kernel: pcieport 0000:00:1c.O: [0]RxErr
    (First)
    Jul 09 18:17:01 pve CRON[240827]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
    Jul 09 18:17:01 pve CRON[240828]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
    Jul 09 18:17:01 pve CRON[240827]: am_unix(cron:session): session closed for user root
    Jul 09 18:19:11 pve kernel: pcieport 0000:00:1c.O: AER: Multiple Corrected error received: 0000:00:1c.0
    Jul 09 18:19:11 pve kernel: pcieport 0000:00:1c.O: PCle Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
    Jul 09 18:19:11 pve kernel: pcieport 0000:00:1c.O: device [8086:4dbe] error status/mask=00000001/00002000
    Jul 09 18:19:11 pve kernel: pcieport 0000:00:1c.O: [0] RxErr
    (First)
    Jul 09 18:28:51 pve pvedaemon 4225]: <root@pam> successful auth for user 'root@pam'
    Jul 09 18:28:52 pve kernel: pcieport 0000:00:1c.0: AR: Multiple Corrected error received: 0000:01:00.0
    Jul 09 18:28:52 pve kernel: pcieport 0000:00:1c.0: PCle Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
    Jul 09 18:28:52 pve kernel: pcieport 0000:00:1c.O: device [8086:4dbe] error status/mask=00001000/00002000
    Jul 09 18:28:52 pve kernel: pcieport 0000:00:1c.0: [12] Timeout
    Jul 09 18:29:16 pve kernel: pcieport 0000:00:1c.O: AER: Multiple Corrected error received: 0000:00:1c.O
    Jul 09 18:29:16 pve kernel: pcieport 0000:00:1c.O: PCle Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
    Jul 09 18:29:16 pve kernel: pcieport 0000:00:1c.O: device [8086:4dbe] error status/mask=00000001/00002000
    Jul 09 18:29:16 pve kernel: pcieport 0000:00:1c.O: [0]RxErr
    (First)
    crunchipC Abwesend
    crunchipC Abwesend
    @svenh75 sagte in Neuaufsetzen Beelink Mini S 11. Generation:
    https://www.thomas-krenn.com/de/wiki/AER_Multiple_Corrected_error_received_0000:00:1c.4
      SvenH75
      @crunchip okay an das bios komme ich schlecht ran, kann ich auch die Anleitung unter :
      https://websetnet.net/de/troubleshooting-pcie-bus-error-severity-corrected-on-ubuntu-and-linux-mint/
      nutzen?
      klappt leider nicht:
      Starting system upgrade: apt-get dist-upgrade
      Reading package lists... Done
      Calculating upgrade... Done
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Your System is up-to-date
      starting shell
      root@pve:/# sudo gedit /etc/default/grub
      bash: sudo: command not found
      root@pve:/# sudo vi /etc/default/grub
      root@pve:/# #
      • S SvenH75
        (First)
        (First)
        (First)
        (First)
        (First)
        Moin,
        Ja Du und @crunchip ihr habt beide den Workaround gefunden.
        Wie im Link von @crunchip, da gibt es zwei Methoden des Workarounds,
        1. Per BIOS
        • vermute mal, dass das bei den Mini PCs eher nicht so häufig implementiert ist.
        1. per Kernel Bootparameter, das was Du bei Proxmox und auch im Thomas-Krenn Artikel steht.
        Bernd
        • S SvenH75
          nutzen?
          starting shell
          root@pve:/# #
          gedit
          Moin,
          der Editor ist bei Proxmox ≠ Ubuntu, nicht installiert, das ist ein Grafischer Editor.
          Du kannst nano oder vim nutzen.
          Aber bevor Du da mit Root an wichtigen Dateien herumpfuschst, lieber erst mal üben, wie man mit nano und vim umgeht.
          Bernd
          S ? 3 Antworten Letzte Antwort
            gedit
            Moin,
            Bernd
            SvenH75
            @dp20eic ok, vielen dank schon mal..... wird ja spannend
              gedit
              Moin,
              Bernd
              SvenH75
              schrieb am zuletzt editiert von SvenH75
              @dp20eic
              mag nicht
              Linux pve 6.2.16-3-pve #1 SMP PREEMPT_DYNAMIC PVE 6.2.16-3 (2023-06-17T05:58Z) x86_64
              permitted by applicable law.
              Last login: Sun Jul  9 19:41:56 CEST 2023 on pts/3
              root@pve:~# sudo nano /etc/default/grub
              -bash: sudo: command not found
              root@pve:~# sudo vim /etc/default/grub
              root@pve:~#
              oder geht das nicht so in der Konsole?
              • S SvenH75
                @dp20eic
                mag nicht
                root@pve:~#
                @svenh75
                sudo wird verwendet um als Standard-User root-Rechte zu erlangen. Du bist aber bereits als root unterwegs.
                • S SvenH75
                  @dp20eic
                  mag nicht
                  root@pve:~#
                  crunchipC Abwesend
                  crunchipC Abwesend
                  du bist root, weil du direkt auf deinem proxmox bist, daher ohne sudo
                  sudo ist in proxmox gar nicht installiert
                    @svenh75
                    SvenH75
                    @thomas-braun danke, ode sudo geht es......
                    in meiner Datei steht aber in der Zeile:
                    Suchen Sie nach der Zeile, die hat GRUB_CMDLINE_LINUX_DEFAULT = "quiet splash"
                    hinten nur "quiet", also: GRUB_CMDLINE_LINUX_DEFAULT = "quiet"
                    trotzdem nach Anleitung : https://websetnet.net/de/troubleshooting-pcie-bus-error-severity-corrected-on-ubuntu-and-linux-mint/
                      gedit
                      Moin,
                      Bernd
                      @dp20eic sagte in Neuaufsetzen Beelink Mini S 11. Generation:
                      Moin,
                      ich zitiere mich da mal selbst
                      Bitte, mach das nicht, solange Du nicht weißt, was Du da machst, irgendetwas irgendwoher kopieren und nicht wissen, was der Befehl tut, ist nicht gut.
                      Soweit ich das gelesen habe, sind das nur wieder kehrende Meldungen, die tun erst einmal nicht weh.
                      Schreib Dir auf, dass Du da noch eine Baustelle hast und lern erst einmal Dein System kennen, dann geht man erst ans feine Tuning.
                      Bernd
                        Moin,
                        Bernd
                        SvenH75
                        @dp20eic ja, hab noch nix gemacht.....
                        Bin relativ selten per Konsole im Linux unterwegs und da kommt manches erst langsam zurück.... hab in einem Artikel noch gelesen (hatte auch das Problem das System überhaupt nicht mehr erreichbar war) auf Kernel 6.2.16-2 zurück zu gehen über:
                        apt install pve-kernel-6.2.16-2-pve
                        proxmox-boot-tool kernel add 6.2.16-2-pve
                        Kann das Sinn machen?
                        ? crunchipC WalW 3 Antworten Letzte Antwort
                        • S SvenH75
                          Moin,
                          das kann ich Dir auf die Schnelle auch nicht beantworten, sorry.
                          Ich wunder mich, dass ein neues Gerät solche Fehler verursacht, ich kann mir das nur so erklären, dass das BIOS 'ne Macke hat, schauen, ob es da bei beelink etwas Neues gibt, dass das Ding generell eine Macke hat, dann würde ich das Umtauschen.
                          Aber wie gesagt, ich komme gerade erst vom See, und hab mir heute den ganzen Tag die Sonne auf'n Bauch scheinen lassen, bin etwas groggy.
                          Ich muss da auch erst mal etwas tiefer einsteigen, zumal der Artikel bei proxmox aus 2022 war.
                          Bernd
                          • S SvenH75
                            crunchipC Abwesend
                            crunchipC Abwesend
                            möglich
                            theoretisch könntest du auch schauen, ob es für dein bios ein update gibt
                            ansonsten mal die alten logs vor dem Absturz betrachten
                            vllt auch bei der Einrichtung was ungünstig gewählt, z.b zu wenig Ram für proxmox selbst vergeben
                            • S SvenH75
                              WalW Offline
                              WalW Offline
                              Wal
                              schrieb am zuletzt editiert von Wal
                              Das macht keinen Sinn, da es den Fehler schon seit mehreren Monaten(Jahre?) gibt.
                              In der Anleitung wird ja auch ein Backup der Grub Datei gemacht und du kannst ja jederzeit zurück, obwohl die Datei für das booten gebraucht wird also mehrmals überprüfen.
                              Das splash kannst du weglassen.
                              Walter
                              DoorIO-Adapter
                                Moin,
                                Bernd
                                SvenH75
                                beelink
                                Respekt....Durchgehalten :-)
                                ich habe das zurückpielen auf 6.2.16-2 versucht über:
                                Neustart
                                danach zeigt mir das System folgendes:
                                Last login: Sun Jul  9 20:39:43 CEST 2023 on pts/0
                                root@pve:~# proxmox-boot-tool kernel list
                                Manually selected kernels:
                                6.2.16-2-pve
                                Automatically selected kernels:
                                6.2.16-3-pve
                                root@pve:~#
                                Was heißt den manuell und automatisch? Auf welchem Kernel bin ich jetzt?
                                komischerweiße sind die Fehlermeldungen weg .......
                                • S SvenH75
                                  beelink
                                  Neustart
                                  6.2.16-2-pve
                                  6.2.16-3-pve
                                  root@pve:~#
                                  Moin,
                                  uname -a
                                  Bernd
                                  P.S.: immer erst die man page lesen, den Befehl kannte ich noch nicht :)
                                  root@pve:~# proxmox-boot-tool help
                                  USAGE: /usr/sbin/proxmox-boot-tool format <partition> [--force]
                                      format <partition> as EFI system partition. Use --force to format even if <partition> is currently in use.
                                  USAGE: /usr/sbin/proxmox-boot-tool init <partition>
                                      initialize EFI system partition at <partition> for automatic synchronization of pve-kernels and their associated initrds.
                                  USAGE: /usr/sbin/proxmox-boot-tool reinit
                                      reinitialize all configured EFI system partitions from /etc/kernel/proxmox-boot-uuids.
                                  USAGE: /usr/sbin/proxmox-boot-tool clean [--dry-run]
                                      remove no longer existing EFI system partition UUIDs from /etc/kernel/proxmox-boot-uuids. Use --dry-run to only print outdated entries instead of removing them.
                                  USAGE: /usr/sbin/proxmox-boot-tool refresh [--hook <name>]
                                      refresh all configured EFI system partitions. Use --hook to only run the specified hook, omit to run all.
                                  USAGE: /usr/sbin/proxmox-boot-tool kernel <add|remove> <kernel-version>
                                      add/remove pve-kernel with ABI <kernel-version> to list of synced kernels, in addition to automatically selected ones.
                                      NOTE: you need to manually run 'refresh' once you're finished with adding/removing kernels from the list
                                  USAGE: /usr/sbin/proxmox-boot-tool kernel pin <kernel-version> [--next-boot]
                                      pin pve-kernel with ABI <kernel-version> as the default entry to be booted.
                                      with --next-boot sets <kernel-version> only for the next boot.
                                      NOTE: you need to manually run 'refresh' once you're finished with pinning kernels
                                  USAGE: /usr/sbin/proxmox-boot-tool kernel unpin [--next-boot]
                                      unpin removes pinned and next-boot kernel settings.
                                      with --next-boot only removes the pin for the next boot.
                                  USAGE: /usr/sbin/proxmox-boot-tool kernel list
                                      list kernel versions currently selected for inclusion on ESPs.
                                  USAGE: /usr/sbin/proxmox-boot-tool status [--quiet]
                                      Print details about the ESPs configuration. Exits with 0 if any ESP is configured, else with 2.
                                    Moin,
                                    uname -a
                                    Bernd
                                    SvenH75
                                    uname -a
                                    dann wäre es noch der neuste:
                                    root@pve:~# uname -a
                                    Linux pve 6.2.16-3-pve #1 SMP PREEMPT_DYNAMIC PVE 6.2.16-3 (2023-06-17T05:58Z) x86_64 GNU/Linux
                                    root@pve:~#
                                    Der Neustart nach Eingabe :
                                    hat aber sehr lange gedauert, irgendetwas ist wohl passiert, Fehlermeldungen sind auch wieder da...... :-(
                                    ul 09 20:54:54 pve kernel: pcieport 0000:00:1c.0: AER: Multiple Corrected error received: 0000:00:1c.0
                                    Jul 09 20:54:54 pve kernel: pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
                                    Jul 09 20:54:54 pve kernel: pcieport 0000:00:1c.0:   device [8086:4dbe] error status/mask=00000001/00002000
                                    Jul 09 20:54:54 pve kernel: pcieport 0000:00:1c.0:    [ 0] RxErr                  (First)
                                    Jul 09 20:56:28 pve kernel: pcieport 0000:00:1c.0: AER: Multiple Corrected error received: 0000:00:1c.0
                                    Jul 09 20:56:28 pve kernel: pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)
                                    Jul 09 20:56:28 pve kernel: pcieport 0000:00:1c.0:   device [8086:4dbe] error status/mask=00001001/00002000
                                    Jul 09 20:56:28 pve kernel: pcieport 0000:00:1c.0:    [ 0] RxErr                  (First)
                                    Jul 09 20:56:28 pve kernel: pcieport 0000:00:1c.0:    [12] Timeout
                                    Jul 09 20:56:28 pve kernel: pcieport 0000:00:1c.0: AER: Corrected error received: 0000:01:00.0
                                    Jul 09 20:58:15 pve systemd[1]: session-7.scope: Deactivated successfully.
                                    Jul 09 20:58:15 pve systemd-logind[544]: Session 7 logged out. Waiting for processes to exit.
                                    einfach lassen?
                                    • S SvenH75
                                      uname -a
                                      root@pve:~#
                                      einfach lassen?
                                      Moin,
                                      das ist nach dem was ich da aus der man page lese nicht ausreichend.
                                      Du kannst erst einmal versuchen nur für den nächsten Boot den Kernel zu benennen, der genommen werden soll
                                      /usr/sbin/proxmox-boot-tool kernel pin 6.2.16-2-pve --next-boot
                                      Bernd
                                      Edit
                                      Hat die Kiste PCI Express? Steckt da was drin, kann man das im BIOS abschalten?
                                        Moin,
                                        Bernd
                                        Edit
                                        SvenH75
                                        kommt folgendes nach der ersten Zeile: (kann ich die Ordner weglassen?)
                                        Last login: Sun Jul  9 20:52:18 CEST 2023 on pts/0
                                        root@pve:~# proxmox-boot-tool kernel pin 6.2.16-2-pve --next-boot
                                        Setting '6.2.16-2-pve' as grub default entry and running update-grub.
                                        Generating grub configuration file ...
                                        Found linux image: /boot/vmlinuz-6.2.16-3-pve
                                        Found initrd image: /boot/initrd.img-6.2.16-3-pve
                                        Found linux image: /boot/vmlinuz-6.2.16-2-pve
                                        Found initrd image: /boot/initrd.img-6.2.16-2-pve
                                        Found memtest86+ 64bit EFI image: /boot/memtest86+x64.efi
                                        Adding boot menu entry for UEFI Firmware Settings ...
                                        done
                                        Pinned for next boot only.
                                        root@pve:~#
                                        Zweite Zeile?
                                          SvenH75
                                          PCI Express
                                          muss ich morgen mal schauen.....
                                          auf 6.2.16-2 bin ich jetzt, würde ja aber heiße beim nächsten Neustart ist des System dann wieder auf 6.2.16-3, richtig......
                                          Fehlermeldungen sind auch erst mal wieder weg
