  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.4k Aufrufe 40 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #488
    Habe dies gemacht:
    curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
    chmod 744 iob_diag
    ./iob_diag
    Ist dies jetzt was anderes ?
    Skript v.2023-06-21
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
            Machine ID: dd59139b4ae040898d227e04f86103f0
               Boot ID: 83384625b8db43beaf0c2c2962e5a98f
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-23-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:55:10 up  3:56,  1 user,  load average: 1.39, 1.35, 1.35
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sun 2023-07-02 21:55:10 CEST
               Universal time: Sun 2023-07-02 19:55:10 UTC
                     RTC time: Sun 2023-07-02 19:55:11
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        4.7G        379M        0.0K        869M        995M
    Swap:           974M          0B        974M
    Total:          6.9G        4.7G        1.4G
             5928 M total memory
             4680 M used memory
              377 M active memory
             4841 M inactive memory
              378 M free memory
              110 M buffer memory
              758 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    Filesystem                Type      Size  Used Avail Use% Mounted on
    udev                      devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs                     tmpfs     593M  516K  593M   1% /run
    /dev/sda1                 ext4       31G  7.2G   22G  25% /
    tmpfs                     tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
    //192.168.243.100/1_Sound cifs      238G  120G  118G  51% /mnt
    tmpfs                     tmpfs     593M     0  593M   0% /run/user/1000
    [Sun Jul  2 17:58:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jul  2 17:58:54 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE                    FSTYPE OPTIONS
    /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
    `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bs
    /var:
    869M    /var/
    371M    /var/cache
    364M    /var/cache/apt
    330M    /var/log
    313M    /var/log/journal/dd59139b4ae040898d227e04f86103f0
    Archived and active journals take up 56.0M in the file system.
    /opt/iobroker/backups:
    380M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    625M    /opt/iobroker/iobroker-data/files
    298M    /opt/iobroker/iobroker-data/files/vis.0
    248M    /opt/iobroker/iobroker-data/files/vis.0/wav
    235M    /opt/iobroker/iobroker-data/sqlite
    235M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
    32M     /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   12
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
    + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
    + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      system.adapter.openligadb.0             : openligadb            : iobroker                                 - disabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bmw"          : 2.5.7    , installed 2.6.0
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "doorio"       : 2.1.4    , installed 2.1.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "libre"        : 0.0.4    , installed 0.0.5
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "musiccast"    : 1.1.0    , installed 1.1.2
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 4.2.0    , installed 6.3.5
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "viessmann"    : 1.4.4    , installed 1.4.4
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 4.3.0    , installed 6.0.1
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.6
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        23378
    States:         19280
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists... Done
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1429       428/sshd: /usr/sbin
    tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       14772      735/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16724      830/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15047      841/io.mqtt.2
    tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       10228      716/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14146      409/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14139      409/iobroker.js-con
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        1454       406/asterisk
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11187      1/init
    tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       10230      709/io.hm-rpc.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22650      1327/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1431       428/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22598      1241/io.simple-api.
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1147       1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14204      563/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20758      1321/io.web.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13155      359/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12243      1/init
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       20474      1214/io.musiccast.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1891       796/io.mihome-vacuu
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        1467       406/asterisk
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        1468       406/asterisk
    udp        0      0 0.0.0.0:37967           0.0.0.0:*                           108        14127      406/asterisk
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15848      890/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15849      890/io.tuya.0
    udp6       0      0 :::53083                :::*                                108        14128      406/asterisk
    udp6       0      0 :::111                  :::*                                0          9730       1/init
    2023-07-02 21:53:34.067  - info: octoprint.0 (1220) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
    2023-07-02 21:53:49.579  - info: javascript.0 (601) script.js.Scripte.Licht.Bad_EG: Licht Bad EG ausgeschaltet.
    2023-07-02 21:54:00.102  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13298, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:54:00", "unix": 1688334840}, "successful": true}
    2023-07-02 21:54:00.416  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
    2023-07-02 21:54:18.279  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
    2023-07-02 21:54:50.767  - info: javascript.0 (601) script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
    2023-07-02 21:54:56.031  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
    2023-07-02 21:54:56.070  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
    2023-07-02 21:55:00.113  - info: javascript.0 (601) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
    2023-07-02 21:55:00.295  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
    2023-07-02 21:55:00.299  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 86 %.
    2023-07-02 21:55:00.331  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 70 %.
    2023-07-02 21:55:00.347  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12556
    2023-07-02 21:55:00.368  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
    2023-07-02 21:55:00.461  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 52 %.
    2023-07-02 21:55:00.487  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
    2023-07-02 21:55:01.018  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
    2023-07-02 21:55:06.507  - info: dwd.0 (12556) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:55:11.266  - info: dwd.0 (12556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-02 21:55:11.803  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-02 21:55:33.536  - info: javascript.0 (601) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
    2023-07-02 21:56:00.099  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13418, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:56:00", "unix": 1688334960}, "successful": true}
    2023-07-02 21:56:20.832  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
    2023-07-02 21:56:23.013  - info: javascript.0 (601) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 296° / Sonne: Elevation: -25.6° / Mond: Azimut: 124° / Mond: Elevation: 32.7°
    2023-07-02 21:56:40.642  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
    iob diag has finished.
    Press any key for a summary
                         v.2023-06-21
               Chassis: vm
        Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 16.20.1 and npm 8.19.4
    MEMORY:
    Mem:            5.9G        4.5G        574M        0.0K        832M        1.2G
    Swap:           974M        0.0K        974M
    Total:          6.9G        4.5G        1.5G
    Active iob-Instances:   52
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                23378
    States:                 19280
    Size of iob-Database:
    36M     /opt/iobroker/iobroker-data/states.jsonl
    Danke.
    • bahnuhrB bahnuhr
      Habe dies gemacht:
      chmod 744 iob_diag
      ./iob_diag
      Skript v.2023-06-21
      *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      dieter
      /home/dieter
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           974M          0B        974M
               5928 M total memory
               4680 M used memory
                377 M active memory
                378 M free memory
                110 M buffer memory
                758 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      869M    /var/
      371M    /var/cache
      364M    /var/cache/apt
      330M    /var/log
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        23378
      States:         19280
      Pending Updates: 3
                           v.2023-06-21
                 Chassis: vm
          Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                23378
      States:                 19280
      #489
      @bahnuhr sagte in iob diag - Skript:
      Ja, das ist Skript v.2023-06-21.
      Danke dir.
      Mist...
      Da sollte natürlich 18 und 9 erscheinen...
        Danke dir.
        Mist...
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #490
        dort steht: Multihost discovery server: disabled
        Ist das richtig ?
        habe multihost
        Danke.
        • bahnuhrB bahnuhr
          Ist das richtig ?
          habe multihost
          #491
          Ist das richtig ?
          Ja, das ist richtig.
          Ich hab noch keinen Weg gefunden, den Status sicher festzunageln.
            Ist das richtig ?
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #492
            Und bei diesen Punkten hattest du mal irgendwo was zu mir gesagt.
            Wollten wir irgendwann nochmal thematisieren.
            Muss ich da nochmal ran?
            Danke.
            • uweklattU Offline
              uweklattU Offline
              uweklatt
              schrieb am zuletzt editiert von uweklatt
              #493
              ich nutze hier Docker innerhalb LXC auf Proxmox.
              Das Script liefert hier folgende Ausgaben:
              *** iob diag is starting up, please wait ***
              *** ioBroker Diagnosis ***
              Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
              The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
              Just copy and paste the Summary Page, including the  characters at start and end.
              It helps us to help you!
              Press any key to continue
              Skript v.2023-06-21
              *** BASE SYSTEM ***
              Hardware Vendor : LENOVO
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v8.0.1
              Virtualization  : Docker
              Kernel          : x86_64
              Userland        : amd64
               18:58:39 up 32 days, 23:48,  0 users,  load average: 0.32, 0.19, 0.12
              CPU threads: 4
              Mon Jul  3 16:58:39 UTC 2023
              Mon Jul  3 18:58:39 CEST 2023
              CEST +0200
              Etc/UTC
              root
              /root
              root
              X-Server: 	false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            7.8G        3.2G        764M         40M        3.8G        4.2G
              Swap:           7.8G         21M        7.8G
              Total:           15G        3.3G        8.6G
                       7824 M total memory
                       3242 M used memory
                       1453 M active memory
                       5083 M inactive memory
                        764 M free memory
                        661 M buffer memory
                       3156 M swap cache
                       7835 M total swap
                         21 M used swap
                       7814 M free swap
              *** FILESYSTEM ***
              overlay                          overlay   61G  9.0G   49G  16% /
              tmpfs                            tmpfs     64M     0   64M   0% /dev
              shm                              tmpfs     64M     0   64M   0% /dev/shm
              /dev/mapper/pve-vm--100--disk--0 ext4      61G  9.0G   49G  16% /opt/iobroker
              tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/asound
              tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/acpi
              tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/scsi
              tmpfs                            tmpfs    3.9G     0  3.9G   0% /sys/firmware
              [Wed May 31 19:10:12 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Wed May 31 19:10:13 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
              [Wed May 31 19:10:21 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Wed May 31 19:10:23 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
              [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
              [Fri Jun  2 19:29:53 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
              [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
              [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
              [Fri Jun  2 19:40:07 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
              [Tue Jun 27 11:17:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Tue Jun 27 11:29:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              /opt/iobroker    /dev/mapper/pve-vm--100--disk--0[/iobroker]        ext4   rw,relatime,stripe=16
              /etc/resolv.conf /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/resolv.conf] ext4   rw,relatime,stripe=16
              /etc/hostname    /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hostname]    ext4   rw,relatime,stripe=16
              /etc/hosts       /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hosts]       ext4   rw,relatime,stripe=16
              /var:
              33M	/var/
              31M	/var/lib
              18M	/var/lib/apt/lists
              18M	/var/lib/apt
              13M	/var/lib/dpkg
              5.5M	/opt/iobroker/backups/
              196M	/opt/iobroker/iobroker-data/
              104M	/opt/iobroker/iobroker-data/files
              63M	/opt/iobroker/iobroker-data/backup-objects
              52M	/opt/iobroker/iobroker-data/files/javascript.admin
              34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              23M	/opt/iobroker/iobroker-data/objects.jsonl
              7.2M	/opt/iobroker/iobroker-data/states.jsonl
              6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
              6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              5.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
              /usr/bin/npm 		9.5.1
              /usr/bin/npx 		9.5.1
              nodejs:
                Version table:
                      500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Objects:                    jsonl on 127.0.0.1
              States:                     jsonl on 127.0.0.1
              admin: 		6.3.5
              javascript: 	7.0.3
              Adapter State
              + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
              + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
              + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                system.adapter.info.0                   : info                  : iobroker                                 - disabled
                system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
              + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
              + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
              + instance is alive
              stable        : http://iobroker.live/repo/sources-dist.json
              beta          : http://iobroker.live/repo/sources-dist-latest.json
              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
              Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
              Adapter    "openweathermap": 0.3.9   , installed 0.3.9
              Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
              Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
              Objects and States
              Objects: 	3398
              States: 	3035
              Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
              Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72780677   532/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72780670   532/iobroker.js-con
              tcp        0      0 127.0.0.11:32827        0.0.0.0:*               LISTEN      0          72777013   -
              tcp        0      0 192.168.178.223:18998   0.0.0.0:*               LISTEN      1000       72781358   607/io.javascript.0
              tcp6       0      0 :::61991                :::*                    LISTEN      1000       72784653   791/io.harmony.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72789074   878/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72780750   554/io.admin.0
              udp        0      0 127.0.0.11:56903        0.0.0.0:*                           0          72777012   -
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       72784654   791/io.harmony.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       73940879   34550/io.chromecast
              Copy text starting here:
              		     v.2023-06-21
              model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v8.0.1
              Installation: 		Docker
              Kernel: 		x86_64
              Userland: 		amd64
              Timezone: 		Etc/UTC
              User-ID: 		0
              X-Server: 		false
              Pending OS-Updates: 	0
              			/usr/bin/npm 		9.5.1
              			/usr/bin/npx 		9.5.1
              MEMORY:
              Mem:            7.8G        3.3G        753M         40M        3.8G        4.2G
              Swap:           7.8G         21M        7.8G
              Active iob-Instances: 	14
              			admin 			6.3.5
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              Objects: 		3398
              States: 		3035
              === Mark text until here for copying ===
              Tschau
              Uwe
              Intel i5/Proxmox/LXC/Docker/ioBroker
              DJMarc75D Meister MopperM 2 Antworten Letzte Antwort
              • uweklattU uweklatt
                Skript v.2023-06-21
                *** BASE SYSTEM ***
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v8.0.1
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 4
                CEST +0200
                Etc/UTC
                root
                /root
                root
                X-Server: 	false
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:           7.8G         21M        7.8G
                         7824 M total memory
                         3242 M used memory
                          764 M free memory
                          661 M buffer memory
                         3156 M swap cache
                         7835 M total swap
                           21 M used swap
                         7814 M free swap
                *** FILESYSTEM ***
                /var:
                33M	/var/
                31M	/var/lib
                18M	/var/lib/apt
                13M	/var/lib/dpkg
                /usr/bin/npm 		9.5.1
                /usr/bin/npx 		9.5.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		6.3.5
                javascript: 	7.0.3
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	3398
                States: 	3035
                Pending Updates: 0
                		     v.2023-06-21
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v8.0.1
                Kernel: 		x86_64
                Userland: 		amd64
                Timezone: 		Etc/UTC
                User-ID: 		0
                X-Server: 		false
                			/usr/bin/npm 		9.5.1
                			/usr/bin/npx 		9.5.1
                MEMORY:
                Swap:           7.8G         21M        7.8G
                			admin 			6.3.5
                Objects type: jsonl
                States  type: jsonl
                Objects: 		3398
                States: 		3035
                Tschau
                Uwe
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #494
                @uweklatt sagte in iob diag - Skript:
                Tschau
                und Deine Frage lautet ? Oder war Dein Beitrag nur eine Feststellung ??
                Lehrling seit 1975 !!!
                • DJMarc75D DJMarc75
                  Tschau
                  #495
                  @djmarc75 sagte in iob diag - Skript:
                  Keine Frage, das war nur ein Test der Beta-Version des Skripts.
                  @uweklatt Danke schön!
                  DJMarc75D B 2 Antworten Letzte Antwort
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #496
                    @thomas-braun sagte in iob diag - Skript:
                    Dann entschuldige ich mich natürlich ! ... bei @uweklatt
                    uweklattU 1 Antwort Letzte Antwort
                      uweklattU Offline
                      uweklattU Offline
                      uweklatt
                      #497
                      @djmarc75 🍻
                        Skript v.2023-06-21
                        *** BASE SYSTEM ***
                        Kernel          : x86_64
                        Userland        : amd64
                        Docker          : v8.0.1
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                        CEST +0200
                        Etc/UTC
                        root
                        /root
                        root
                        X-Server: 	false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:           7.8G         21M        7.8G
                                 7824 M total memory
                                 3242 M used memory
                                  764 M free memory
                                  661 M buffer memory
                                 3156 M swap cache
                                 7835 M total swap
                                   21 M used swap
                                 7814 M free swap
                        *** FILESYSTEM ***
                        /var:
                        33M	/var/
                        31M	/var/lib
                        18M	/var/lib/apt
                        13M	/var/lib/dpkg
                        /usr/bin/npm 		9.5.1
                        /usr/bin/npx 		9.5.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin: 		6.3.5
                        javascript: 	7.0.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects: 	3398
                        States: 	3035
                        Pending Updates: 0
                        		     v.2023-06-21
                        Kernel          : x86_64
                        Userland        : amd64
                        Docker          : v8.0.1
                        Kernel: 		x86_64
                        Userland: 		amd64
                        Timezone: 		Etc/UTC
                        User-ID: 		0
                        X-Server: 		false
                        			/usr/bin/npm 		9.5.1
                        			/usr/bin/npx 		9.5.1
                        MEMORY:
                        Swap:           7.8G         21M        7.8G
                        			admin 			6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		3398
                        States: 		3035
                        Tschau
                        Uwe
                        Meister MopperM Online
                        Meister Mopper
                        #498
                        Warum wird das noch immer gemacht, wo doch selbst Proxmox aus Sicherheitsgründen eine docker Umgebung in einer VM empfiehlt.
                        Ja, es läuft auch im LXC, aber :man-shrugging: 😬
                        Proxmox und HA ...
                          uweklattU Offline
                          uweklattU Offline
                          uweklatt
                          #499
                          @meister-mopper
                          ...weil es resourcensparender ist.
                          Tschau
                          Uwe
                            bommel_030
                            #500
                            Neben vielen anderen hübschen Dingen erfährt man ja auch
                            Adapters from github:   8
                            Kannst du in deinem Skript auch einbauen, dass die betroffenen Adapter namentlich erwähnt werden? Oder hast du nen Hinweis wo ich das rausfinde?
                            • B bommel_030
                              #501
                              @bommel_030 sagte in iob diag - Skript:
                              Könnte ich. Hab ich aber bewusst nicht, damit die Liste nicht so lang wird.
                              cd /opt/iobroker && npm ls | grep github
                              schmeißt dir die raus.
                                Stmiko
                                #502
                                cooles script, aber:
                                Wenn ich 'iob diag' eingebe passiert nichts. Muss ich das script händisch nachinstallieren?
                                Der installation_fixer hats auch nicht geheilt?
                                curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh funktioniert :)
                                Lg
                                iobroker auf Intel NUC mit Proxmox LXC und Raspi3+
                                • S Stmiko
                                  Lg
                                  #503
                                  @stmiko
                                  In welcher Umgebung rufst du das auf?
                                  Kannst ja den Output aus dem manuellen Aufruf verwenden...
                                    @stmiko
                                    Stmiko
                                    #504
                                    @thomas-braun Ist ein Proxmox LXC mit Debian:
                                                         v.2023-04-16
                                    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                    Kernel:                 6.2.16-4-pve
                                    Installation:           lxc
                                    Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                                    Timezone:
                                    User-ID:                0
                                    X-Server:               false
                                                            /usr/bin/npm            9.5.1
                                                            /usr/bin/npx            9.5.1
                                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                                    MEMORY:
                                    Mem:            8.2G        2.8G        2.6G        0.0K        2.8G        5.4G
                                    Swap:             0B          0B          0B
                                    Total:          8.2G        2.8G        2.6G
                                    Active iob-Instances:   28
                                    Active repo(s): beta
                                    ioBroker Core:          js-controller           5.0.8
                                                            admin                   6.6.0
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : LXC-Debian10                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      system.adapter.vis-material-webfont.0   : vis-material-webfont  : LXC-Debian10                             -  enabled
                                    + system.adapter.web.0                    : web                   : LXC-Debian10                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    Objects:                36921
                                    States:                 27584
                                    30M     /opt/iobroker/iobroker-data/objects.jsonl
                                    18M     /opt/iobroker/iobroker-data/objects.json.migrated
                                    18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    8.0M    /opt/iobroker/iobroker-data/states.jsonl
                                    3.7M    /opt/iobroker/iobroker-data/states.json.migrated
                                    3.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    • S Stmiko
                                                           v.2023-04-16
                                      Installation:           lxc
                                      Timezone:
                                      User-ID:                0
                                      X-Server:               false
                                                              /usr/bin/npm            9.5.1
                                                              /usr/bin/npx            9.5.1
                                      MEMORY:
                                      Swap:             0B          0B          0B
                                                              admin                   6.6.0
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                36921
                                      States:                 27584
                                      #505
                                      @stmiko sagte in iob diag - Skript:
                                      Und root shell. Lass den Mist bleiben.
                                        Stmiko
                                        #506
                                        @thomas-braun bin halt ein fauler Hund.....:)
                                        Liegt es am root?
                                        R Thomas BraunT 2 Antworten Letzte Antwort
                                        • S Stmiko
                                          Liegt es am root?
                                          reutli
                                          #507
                                          Das hat nichts mit "faul" sondern "fahrlässig" bis "lebensmüde" zu tun!
                                          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                          *Wer freundlich ist, dem wird freundlich geholfen *
