  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.3k Aufrufe 40 Beobachtet
  • bahnuhrB bahnuhr
    ich kein docker.
    Aber trotzdem:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:29:24 up  3:30,  1 user,  load average: 1.40, 0.97, 1.02
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sun 2023-07-02 21:29:24 CEST
               Universal time: Sun 2023-07-02 19:29:24 UTC
                     RTC time: Sun 2023-07-02 19:29:25
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        4.6G        476M        0.0K        851M        1.1G
    Swap:           974M          0B        974M
    Total:          6.9G        4.6G        1.5G
             5928 M total memory
             4601 M used memory
              330 M active memory
             4794 M inactive memory
              476 M free memory
              107 M buffer memory
              743 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    Filesystem                Type      Size  Used Avail Use% Mounted on
    udev                      devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs                     tmpfs     593M  512K  593M   1% /run
    /dev/sda1                 ext4       31G  7.2G   22G  25% /
    tmpfs                     tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
    //192.168.243.100/1_Sound cifs      238G  120G  118G  51% /mnt
    tmpfs                     tmpfs     593M     0  593M   0% /run/user/1000
    [Sun Jul  2 17:58:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jul  2 17:58:54 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE                    FSTYPE OPTIONS
    /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
    `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    869M    /var/
    371M    /var/cache
    364M    /var/cache/apt
    330M    /var/log
    313M    /var/log/journal/dd59139b4ae040898d227e04f86103f0
    Archived and active journals take up 56.0M in the file system.
    /opt/iobroker/backups:
    380M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1020M   /opt/iobroker/iobroker-data/
    625M    /opt/iobroker/iobroker-data/files
    298M    /opt/iobroker/iobroker-data/files/vis.0
    248M    /opt/iobroker/iobroker-data/files/vis.0/wav
    235M    /opt/iobroker/iobroker-data/sqlite
    235M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
    20M     /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   12
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
    + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
    + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      system.adapter.openligadb.0             : openligadb            : iobroker                                 - disabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bmw"          : 2.5.7    , installed 2.6.0
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "doorio"       : 2.1.4    , installed 2.1.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "libre"        : 0.0.4    , installed 0.0.5
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "musiccast"    : 1.1.0    , installed 1.1.2
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 4.2.0    , installed 6.3.5
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "viessmann"    : 1.4.4    , installed 1.4.4
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 4.3.0    , installed 6.0.1
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.6
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        23378
    States:         19282
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1429       428/sshd: /usr/sbin
    tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       14772      735/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16724      830/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15047      841/io.mqtt.2
    tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       10228      716/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14146      409/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14139      409/iobroker.js-con
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        1454       406/asterisk
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11187      1/init
    tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       10230      709/io.hm-rpc.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22650      1327/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1431       428/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22598      1241/io.simple-api.
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1147       1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14204      563/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20758      1321/io.web.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13155      359/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12243      1/init
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       20474      1214/io.musiccast.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1891       796/io.mihome-vacuu
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        1467       406/asterisk
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        1468       406/asterisk
    udp        0      0 0.0.0.0:37967           0.0.0.0:*                           108        14127      406/asterisk
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15848      890/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15849      890/io.tuya.0
    udp6       0      0 :::53083                :::*                                108        14128      406/asterisk
    udp6       0      0 :::111                  :::*                                0          9730       1/init
    2023-07-02 21:30:00.221  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9518
    2023-07-02 21:30:00.253  - info: javascript.0 (601) script.js.Scripte.System.View_wechseln: View auf 'Temperatur' gewechselt.
    2023-07-02 21:30:00.266  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 86 %.
    2023-07-02 21:30:00.295  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
    2023-07-02 21:30:00.356  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 70 %.
    2023-07-02 21:30:00.374  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
    2023-07-02 21:30:00.482  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 36 %.
    2023-07-02 21:30:00.504  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
    2023-07-02 21:30:04.593  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9546
    2023-07-02 21:30:10.407  - info: host.iobroker instance system.adapter.ical.0 started with pid 9577
    2023-07-02 21:30:12.395  - info: dwd.0 (9518) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:30:14.139  - info: daswetter.0 (9546) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:30:17.501  - info: ical.0 (9577) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:30:18.890  - info: ical.0 (9577) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9d16955e1b026c97c9163f08d34a9/basic.ics
    2023-07-02 21:30:19.637  - info: ical.0 (9577) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgc7cn8ds7lifi58gq97o%40group.calendar.google.com/private-3fcd3288d403e0dd210afc8b4eec7699/basic.ics
    2023-07-02 21:30:20.838  - info: ical.0 (9577) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d61660f2427d2f71024c407325b7c/basic.ics
    2023-07-02 21:30:21.947  - info: dwd.0 (9518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-02 21:30:22.509  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-02 21:30:27.412  - info: ical.0 (9577) Terminated (NO_ERROR): Without reason
    2023-07-02 21:30:28.043  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-07-02 21:30:40.345  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
    2023-07-02 21:30:48.320  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
    2023-07-02 21:30:57.418  - info: daswetter.0 (9546) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-07-02 21:30:57.943  - info: daswetter.0 (9546) cleaned everything up...
    2023-07-02 21:30:57.979  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-23-amd64
    Installation:           kvm
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            5.9G        4.7G        346M        0.0K        857M        950M
    Swap:           974M          0B        974M
    Total:          6.9G        4.7G        1.3G
    Active iob-Instances:   52
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                23378
    States:                 19280
    Size of iob-Database:
    23M     /opt/iobroker/iobroker-data/states.jsonl
    #477
    @bahnuhr
    Danke. Aber das skript wie im ersten Posting als Beta von github aus ausführen.
    Du hast die im ioBroker eingepackte Version genommen.
    • NegaleinN Negalein
      @thomas-braun sagte in iob diag - Skript:
      (Andere natürlich auch...)
      LXC
      PS: ich weiß schon, was du mir gleich sagen wirst. 106 ;)
                           v.2023-06-20
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container
            Machine ID: b354c482f7cc342776f020ee5ea440c3
               Boot ID: 5ae552d81a2a43a78233355847e6e090
        Virtualization: lxc
      Operating System: Ubuntu 22.04.2 LTS
                Kernel: Linux 5.15.30-2-pve
          Architecture: x86-64
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Vienna (CEST, +0200)
      User-ID:                1001
      X-Server:               false
      Pending OS-Updates:     106
      Pending iob updates:    2
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      MEMORY:
      Mem:             10G        5.4G        3.5G        0.0K        1.1G        4.6G
      Swap:           2.0G        1.4G        670M
      Total:           12G        6.8G        4.2G
      Active iob-Instances:   59
      Active repo(s): Beta (latest)
                              admin                   6.5.9
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                57369
      States:                 51368
      72M     /opt/iobroker/iobroker-data/objects.jsonl
      29M     /opt/iobroker/iobroker-data/objects.json.migrated
      29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      118M    /opt/iobroker/iobroker-data/states.jsonl
      9.4M    /opt/iobroker/iobroker-data/states.json.migrated
      9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      #478
      @negalein sagte in iob diag - Skript:
      Danke.
      Aber dann brauch ich ja gar nichts mehr sagen und du hältst die Kiste jetzt einfach selbständig auf aktuellem Stand?
      NegaleinN 2 Antworten Letzte Antwort
        LXC
                             v.2023-06-20
                 Chassis: container
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1001
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
        MEMORY:
                                admin                   6.5.9
        Objects type: jsonl
        States  type: jsonl
        Objects:                57369
        States:                 51368
        #479
        nö 108 😂
          Danke.
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #480
          bin schon dabei.
          Gleich fertig. :)
          ° Fixer ---> iob fix
            bin schon dabei.
            Gleich fertig. :)
            #481
            @negalein
            Dann bitte nochmal das Skript testen, hab gerade noch was bei github hochgeschoben.
              Danke.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #482
              PS: was mach ich hier?
              nega@ioBroker:/$ do-release-upgrade
              Checking for a new Ubuntu release
              There is no development version of an LTS available.
              To upgrade to the latest non-LTS development release
              set Prompt=normal in /etc/update-manager/release-upgrades.
              nega@ioBroker:/$
                @negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #483
                                     v.2023-06-21
                         Chassis: container
                         Boot ID: eb405d983fe44b89bb3c508347189c13
                  Virtualization: lxc
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               amd64
                User-ID:                1001
                X-Server:               false
                Pending OS-Updates:     0
                Nodejs-Installation:    /usr/bin/nodejs         v16.20.1
                                        /usr/bin/node           v16.20.1
                                        /usr/bin/npm            8.19.4
                                        /usr/bin/npx            8.19.4
                Recommended versions are nodejs 18.16.1 and npm 9.5.1
                MEMORY:
                Mem:             10G        4.0G        5.0G        0.0K        1.1G        6.0G
                Swap:           2.0G          0B        2.0G
                Total:           12G        4.0G        7.0G
                Active iob-Instances:   58
                                        admin                   6.5.9
                Objects type: jsonl
                States  type: jsonl
                Objects:                55445
                States:                 50135
                49M     /opt/iobroker/iobroker-data/objects.jsonl
                154M    /opt/iobroker/iobroker-data/states.jsonl
                  nega@ioBroker:/$
                  #484
                  Nix! Du willst kein release upgrade machen.
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #485
                    Ah, ok.
                    Gibt also kein neueres?
                      Ah, ok.
                      #486
                      Keine neueres LTS-Release. Das nächste LongTermSupport-Ding kommt im April 2024. Dazwischen sind nur Test-Releases am Start.
                        Ah, ok.
                        #487
                        Aber gut, der Code zur Auswertung von
                        funktioniert also.
                        • bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #488
                          Habe dies gemacht:
                          curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
                          chmod 744 iob_diag
                          ./iob_diag
                          Ist dies jetzt was anderes ?
                          Skript v.2023-06-21
                          *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer-vm
                                     Chassis: vm
                                  Machine ID: dd59139b4ae040898d227e04f86103f0
                                     Boot ID: 83384625b8db43beaf0c2c2962e5a98f
                              Virtualization: kvm
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 5.10.0-23-amd64
                          model name      : Common KVM processor
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           21:55:10 up  3:56,  1 user,  load average: 1.39, 1.35, 1.35
                          CPU threads: 8
                                         Local time: Sun 2023-07-02 21:55:10 CEST
                                     Universal time: Sun 2023-07-02 19:55:10 UTC
                                           RTC time: Sun 2023-07-02 19:55:11
                                        NTP service: active
                                    RTC in local TZ: no
                          dieter
                          /home/dieter
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            5.9G        4.7G        379M        0.0K        869M        995M
                          Swap:           974M          0B        974M
                          Total:          6.9G        4.7G        1.4G
                                   5928 M total memory
                                   4680 M used memory
                                    377 M active memory
                                   4841 M inactive memory
                                    378 M free memory
                                    110 M buffer memory
                                    758 M swap cache
                                    974 M total swap
                                      0 M used swap
                                    974 M free swap
                          *** FILESYSTEM ***
                          tmpfs                     tmpfs     593M  516K  593M   1% /run
                          /var:
                          869M    /var/
                          371M    /var/cache
                          364M    /var/cache/apt
                          330M    /var/log
                          1.1G    /opt/iobroker/iobroker-data/
                          32M     /opt/iobroker/iobroker-data/states.jsonl
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          Errors in npm tree: 0
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          No configuration change needed.
                          Multihost discovery server: disabled
                          Discovery authentication:   enabled
                          Persistent activation:      disabled
                          Objects:                    jsonl on 0.0.0.0
                          States:                     jsonl on 0.0.0.0
                          admin:          6.3.5
                          javascript:     7.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        23378
                          States:         19280
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                          Reading package lists... Done
                          Pending Updates: 3
                          2023-07-02 21:53:34.067  - info: octoprint.0 (1220) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
                          2023-07-02 21:53:49.579  - info: javascript.0 (601) script.js.Scripte.Licht.Bad_EG: Licht Bad EG ausgeschaltet.
                          2023-07-02 21:54:00.102  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13298, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:54:00", "unix": 1688334840}, "successful": true}
                          2023-07-02 21:54:00.416  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
                          2023-07-02 21:54:18.279  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                          2023-07-02 21:54:50.767  - info: javascript.0 (601) script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
                          2023-07-02 21:54:56.031  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
                          2023-07-02 21:54:56.070  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
                          2023-07-02 21:55:00.113  - info: javascript.0 (601) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
                          2023-07-02 21:55:00.295  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
                          2023-07-02 21:55:00.299  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 86 %.
                          2023-07-02 21:55:00.331  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 70 %.
                          2023-07-02 21:55:00.347  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12556
                          2023-07-02 21:55:00.368  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
                          2023-07-02 21:55:00.461  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 52 %.
                          2023-07-02 21:55:00.487  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
                          2023-07-02 21:55:01.018  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                          2023-07-02 21:55:06.507  - info: dwd.0 (12556) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
                          2023-07-02 21:55:11.266  - info: dwd.0 (12556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-07-02 21:55:11.803  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-07-02 21:55:33.536  - info: javascript.0 (601) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
                          2023-07-02 21:56:00.099  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13418, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:56:00", "unix": 1688334960}, "successful": true}
                          2023-07-02 21:56:20.832  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
                          2023-07-02 21:56:23.013  - info: javascript.0 (601) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 296° / Sonne: Elevation: -25.6° / Mond: Azimut: 124° / Mond: Elevation: 32.7°
                          2023-07-02 21:56:40.642  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                                               v.2023-06-21
                                     Chassis: vm
                              Virtualization: kvm
                          Installation:           kvm
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.5.1
                                                  /usr/bin/npx            9.5.1
                          Recommended versions are nodejs 16.20.1 and npm 8.19.4
                          MEMORY:
                          Mem:            5.9G        4.5G        574M        0.0K        832M        1.2G
                          Swap:           974M        0.0K        974M
                          Total:          6.9G        4.5G        1.5G
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                23378
                          States:                 19280
                          36M     /opt/iobroker/iobroker-data/states.jsonl
                          Danke.
                          • bahnuhrB bahnuhr
                            Habe dies gemacht:
                            chmod 744 iob_diag
                            ./iob_diag
                            Skript v.2023-06-21
                            *** BASE SYSTEM ***
                                       Chassis: vm
                                Virtualization: kvm
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 8
                                          NTP service: active
                                      RTC in local TZ: no
                            dieter
                            /home/dieter
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           974M          0B        974M
                                     5928 M total memory
                                     4680 M used memory
                                      377 M active memory
                                      378 M free memory
                                      110 M buffer memory
                                      758 M swap cache
                                      974 M total swap
                                        0 M used swap
                                      974 M free swap
                            *** FILESYSTEM ***
                            /var:
                            869M    /var/
                            371M    /var/cache
                            364M    /var/cache/apt
                            330M    /var/log
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.3.5
                            javascript:     7.0.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        23378
                            States:         19280
                            Pending Updates: 3
                                                 v.2023-06-21
                                       Chassis: vm
                                Virtualization: kvm
                            Installation:           kvm
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            9.5.1
                                                    /usr/bin/npx            9.5.1
                            MEMORY:
                                                    admin                   6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                23378
                            States:                 19280
                            #489
                            @bahnuhr sagte in iob diag - Skript:
                            Ja, das ist Skript v.2023-06-21.
                            Danke dir.
                            Mist...
                            Da sollte natürlich 18 und 9 erscheinen...
                              Danke dir.
                              Mist...
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #490
                              dort steht: Multihost discovery server: disabled
                              Ist das richtig ?
                              habe multihost
                              Danke.
                              • bahnuhrB bahnuhr
                                Ist das richtig ?
                                habe multihost
                                #491
                                Ist das richtig ?
                                Ja, das ist richtig.
                                Ich hab noch keinen Weg gefunden, den Status sicher festzunageln.
                                  Ist das richtig ?
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #492
                                  Und bei diesen Punkten hattest du mal irgendwo was zu mir gesagt.
                                  Wollten wir irgendwann nochmal thematisieren.
                                  Muss ich da nochmal ran?
                                  Danke.
                                  • uweklattU Offline
                                    uweklattU Offline
                                    uweklatt
                                    schrieb am zuletzt editiert von uweklatt
                                    #493
                                    ich nutze hier Docker innerhalb LXC auf Proxmox.
                                    Das Script liefert hier folgende Ausgaben:
                                    *** iob diag is starting up, please wait ***
                                    *** ioBroker Diagnosis ***
                                    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                    Just copy and paste the Summary Page, including the  characters at start and end.
                                    It helps us to help you!
                                    Press any key to continue
                                    Skript v.2023-06-21
                                    *** BASE SYSTEM ***
                                    Hardware Vendor : LENOVO
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    Docker          : v8.0.1
                                    Virtualization  : Docker
                                    Kernel          : x86_64
                                    Userland        : amd64
                                     18:58:39 up 32 days, 23:48,  0 users,  load average: 0.32, 0.19, 0.12
                                    CPU threads: 4
                                    Mon Jul  3 16:58:39 UTC 2023
                                    Mon Jul  3 18:58:39 CEST 2023
                                    CEST +0200
                                    Etc/UTC
                                    root
                                    /root
                                    root
                                    X-Server: 	false
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:            7.8G        3.2G        764M         40M        3.8G        4.2G
                                    Swap:           7.8G         21M        7.8G
                                    Total:           15G        3.3G        8.6G
                                             7824 M total memory
                                             3242 M used memory
                                             1453 M active memory
                                             5083 M inactive memory
                                              764 M free memory
                                              661 M buffer memory
                                             3156 M swap cache
                                             7835 M total swap
                                               21 M used swap
                                             7814 M free swap
                                    *** FILESYSTEM ***
                                    overlay                          overlay   61G  9.0G   49G  16% /
                                    tmpfs                            tmpfs     64M     0   64M   0% /dev
                                    shm                              tmpfs     64M     0   64M   0% /dev/shm
                                    /dev/mapper/pve-vm--100--disk--0 ext4      61G  9.0G   49G  16% /opt/iobroker
                                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/asound
                                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/acpi
                                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/scsi
                                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /sys/firmware
                                    [Wed May 31 19:10:12 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                    [Wed May 31 19:10:13 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                                    [Wed May 31 19:10:21 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                    [Wed May 31 19:10:23 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                    [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
                                    [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                    [Fri Jun  2 19:29:53 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                    [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
                                    [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                    [Fri Jun  2 19:40:07 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                    [Tue Jun 27 11:17:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                    [Tue Jun 27 11:29:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                    /opt/iobroker    /dev/mapper/pve-vm--100--disk--0[/iobroker]        ext4   rw,relatime,stripe=16
                                    /etc/resolv.conf /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/resolv.conf] ext4   rw,relatime,stripe=16
                                    /etc/hostname    /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hostname]    ext4   rw,relatime,stripe=16
                                    /etc/hosts       /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hosts]       ext4   rw,relatime,stripe=16
                                    /var:
                                    33M	/var/
                                    31M	/var/lib
                                    18M	/var/lib/apt/lists
                                    18M	/var/lib/apt
                                    13M	/var/lib/dpkg
                                    5.5M	/opt/iobroker/backups/
                                    196M	/opt/iobroker/iobroker-data/
                                    104M	/opt/iobroker/iobroker-data/files
                                    63M	/opt/iobroker/iobroker-data/backup-objects
                                    52M	/opt/iobroker/iobroker-data/files/javascript.admin
                                    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                    23M	/opt/iobroker/iobroker-data/objects.jsonl
                                    7.2M	/opt/iobroker/iobroker-data/states.jsonl
                                    6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
                                    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                    5.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
                                    /usr/bin/npm 		9.5.1
                                    /usr/bin/npx 		9.5.1
                                    nodejs:
                                      Version table:
                                            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                    jsonl on 127.0.0.1
                                    States:                     jsonl on 127.0.0.1
                                    admin: 		6.3.5
                                    javascript: 	7.0.3
                                    Adapter State
                                    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                    + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                                      system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
                                    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                      system.adapter.info.0                   : info                  : iobroker                                 - disabled
                                      system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
                                    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                      system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
                                    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                                    + instance is alive
                                    stable        : http://iobroker.live/repo/sources-dist.json
                                    beta          : http://iobroker.live/repo/sources-dist-latest.json
                                    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                    Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
                                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                                    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
                                    Objects and States
                                    Objects: 	3398
                                    States: 	3035
                                    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72780677   532/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72780670   532/iobroker.js-con
                                    tcp        0      0 127.0.0.11:32827        0.0.0.0:*               LISTEN      0          72777013   -
                                    tcp        0      0 192.168.178.223:18998   0.0.0.0:*               LISTEN      1000       72781358   607/io.javascript.0
                                    tcp6       0      0 :::61991                :::*                    LISTEN      1000       72784653   791/io.harmony.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72789074   878/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72780750   554/io.admin.0
                                    udp        0      0 127.0.0.11:56903        0.0.0.0:*                           0          72777012   -
                                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       72784654   791/io.harmony.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       73940879   34550/io.chromecast
                                    Copy text starting here:
                                    		     v.2023-06-21
                                    model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    Docker          : v8.0.1
                                    Installation: 		Docker
                                    Kernel: 		x86_64
                                    Userland: 		amd64
                                    Timezone: 		Etc/UTC
                                    User-ID: 		0
                                    X-Server: 		false
                                    			/usr/bin/npm 		9.5.1
                                    			/usr/bin/npx 		9.5.1
                                    MEMORY:
                                    Mem:            7.8G        3.3G        753M         40M        3.8G        4.2G
                                    Swap:           7.8G         21M        7.8G
                                    Active iob-Instances: 	14
                                    			admin 			6.3.5
                                    ioBroker Status: 	iobroker is running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		3398
                                    States: 		3035
                                    === Mark text until here for copying ===
                                    Tschau
                                    Uwe
                                    Intel i5/Proxmox/LXC/Docker/ioBroker
                                    DJMarc75D Meister MopperM 2 Antworten Letzte Antwort
                                    • uweklattU uweklatt
                                      Skript v.2023-06-21
                                      *** BASE SYSTEM ***
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Docker          : v8.0.1
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      CPU threads: 4
                                      CEST +0200
                                      Etc/UTC
                                      root
                                      /root
                                      root
                                      X-Server: 	false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Swap:           7.8G         21M        7.8G
                                               7824 M total memory
                                               3242 M used memory
                                                764 M free memory
                                                661 M buffer memory
                                               3156 M swap cache
                                               7835 M total swap
                                                 21 M used swap
                                               7814 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      33M	/var/
                                      31M	/var/lib
                                      18M	/var/lib/apt
                                      13M	/var/lib/dpkg
                                      /usr/bin/npm 		9.5.1
                                      /usr/bin/npx 		9.5.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin: 		6.3.5
                                      javascript: 	7.0.3
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects: 	3398
                                      States: 	3035
                                      Pending Updates: 0
                                      		     v.2023-06-21
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Docker          : v8.0.1
                                      Kernel: 		x86_64
                                      Userland: 		amd64
                                      Timezone: 		Etc/UTC
                                      User-ID: 		0
                                      X-Server: 		false
                                      			/usr/bin/npm 		9.5.1
                                      			/usr/bin/npx 		9.5.1
                                      MEMORY:
                                      Swap:           7.8G         21M        7.8G
                                      			admin 			6.3.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects: 		3398
                                      States: 		3035
                                      Tschau
                                      Uwe
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #494
                                      @uweklatt sagte in iob diag - Skript:
                                      Tschau
                                      und Deine Frage lautet ? Oder war Dein Beitrag nur eine Feststellung ??
                                      Lehrling seit 1975 !!!
                                      • DJMarc75D DJMarc75
                                        Tschau
                                        #495
                                        @djmarc75 sagte in iob diag - Skript:
                                        Keine Frage, das war nur ein Test der Beta-Version des Skripts.
                                        @uweklatt Danke schön!
                                        DJMarc75D B 2 Antworten Letzte Antwort
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #496
                                          Dann entschuldige ich mich natürlich ! ... bei @uweklatt
                                          uweklattU 1 Antwort Letzte Antwort
