  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.3k Aufrufe 40 Beobachtet
    Könnten die Docker-User das skript mal wieder beta-testen?
    (Andere natürlich auch...)
    Hab noch mal was geändert und umgestellt.
    Danke schön!
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #475
    ich kein docker.
    Aber trotzdem:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:29:24 up  3:30,  1 user,  load average: 1.40, 0.97, 1.02
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sun 2023-07-02 21:29:24 CEST
               Universal time: Sun 2023-07-02 19:29:24 UTC
                     RTC time: Sun 2023-07-02 19:29:25
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        4.6G        476M        0.0K        851M        1.1G
    Swap:           974M          0B        974M
    Total:          6.9G        4.6G        1.5G
             5928 M total memory
             4601 M used memory
              330 M active memory
             4794 M inactive memory
              476 M free memory
              107 M buffer memory
              743 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    Filesystem                Type      Size  Used Avail Use% Mounted on
    udev                      devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs                     tmpfs     593M  512K  593M   1% /run
    /dev/sda1                 ext4       31G  7.2G   22G  25% /
    tmpfs                     tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
    //192.168.243.100/1_Sound cifs      238G  120G  118G  51% /mnt
    tmpfs                     tmpfs     593M     0  593M   0% /run/user/1000
    [Sun Jul  2 17:58:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jul  2 17:58:54 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE                    FSTYPE OPTIONS
    /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
    `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    869M    /var/
    371M    /var/cache
    364M    /var/cache/apt
    330M    /var/log
    313M    /var/log/journal/dd59139b4ae040898d227e04f86103f0
    Archived and active journals take up 56.0M in the file system.
    /opt/iobroker/backups:
    380M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1020M   /opt/iobroker/iobroker-data/
    625M    /opt/iobroker/iobroker-data/files
    298M    /opt/iobroker/iobroker-data/files/vis.0
    248M    /opt/iobroker/iobroker-data/files/vis.0/wav
    235M    /opt/iobroker/iobroker-data/sqlite
    235M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
    20M     /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   12
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
    + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
    + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      system.adapter.openligadb.0             : openligadb            : iobroker                                 - disabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bmw"          : 2.5.7    , installed 2.6.0
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "doorio"       : 2.1.4    , installed 2.1.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "libre"        : 0.0.4    , installed 0.0.5
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "musiccast"    : 1.1.0    , installed 1.1.2
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 4.2.0    , installed 6.3.5
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "viessmann"    : 1.4.4    , installed 1.4.4
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 4.3.0    , installed 6.0.1
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.6
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        23378
    States:         19282
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1429       428/sshd: /usr/sbin
    tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       14772      735/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16724      830/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15047      841/io.mqtt.2
    tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       10228      716/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14146      409/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14139      409/iobroker.js-con
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        1454       406/asterisk
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11187      1/init
    tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       10230      709/io.hm-rpc.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22650      1327/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1431       428/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22598      1241/io.simple-api.
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1147       1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14204      563/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20758      1321/io.web.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13155      359/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12243      1/init
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       20474      1214/io.musiccast.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1891       796/io.mihome-vacuu
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        1467       406/asterisk
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        1468       406/asterisk
    udp        0      0 0.0.0.0:37967           0.0.0.0:*                           108        14127      406/asterisk
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15848      890/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15849      890/io.tuya.0
    udp6       0      0 :::53083                :::*                                108        14128      406/asterisk
    udp6       0      0 :::111                  :::*                                0          9730       1/init
    2023-07-02 21:30:00.221  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9518
    2023-07-02 21:30:00.253  - info: javascript.0 (601) script.js.Scripte.System.View_wechseln: View auf 'Temperatur' gewechselt.
    2023-07-02 21:30:00.266  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 86 %.
    2023-07-02 21:30:00.295  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
    2023-07-02 21:30:00.356  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 70 %.
    2023-07-02 21:30:00.374  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
    2023-07-02 21:30:00.482  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 36 %.
    2023-07-02 21:30:00.504  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
    2023-07-02 21:30:04.593  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9546
    2023-07-02 21:30:10.407  - info: host.iobroker instance system.adapter.ical.0 started with pid 9577
    2023-07-02 21:30:12.395  - info: dwd.0 (9518) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:30:14.139  - info: daswetter.0 (9546) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:30:17.501  - info: ical.0 (9577) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.1, js-controller: 4.0.24
    2023-07-02 21:30:18.890  - info: ical.0 (9577) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9d16955e1b026c97c9163f08d34a9/basic.ics
    2023-07-02 21:30:19.637  - info: ical.0 (9577) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgc7cn8ds7lifi58gq97o%40group.calendar.google.com/private-3fcd3288d403e0dd210afc8b4eec7699/basic.ics
    2023-07-02 21:30:20.838  - info: ical.0 (9577) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d61660f2427d2f71024c407325b7c/basic.ics
    2023-07-02 21:30:21.947  - info: dwd.0 (9518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-02 21:30:22.509  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-02 21:30:27.412  - info: ical.0 (9577) Terminated (NO_ERROR): Without reason
    2023-07-02 21:30:28.043  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-07-02 21:30:40.345  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
    2023-07-02 21:30:48.320  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
    2023-07-02 21:30:57.418  - info: daswetter.0 (9546) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-07-02 21:30:57.943  - info: daswetter.0 (9546) cleaned everything up...
    2023-07-02 21:30:57.979  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-23-amd64
    Installation:           kvm
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            5.9G        4.7G        346M        0.0K        857M        950M
    Swap:           974M          0B        974M
    Total:          6.9G        4.7G        1.3G
    Active iob-Instances:   52
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                23378
    States:                 19280
    Size of iob-Database:
    23M     /opt/iobroker/iobroker-data/states.jsonl
    Danke.
      Danke schön!
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #476
      @thomas-braun sagte in iob diag - Skript:
      LXC
      PS: ich weiß schon, was du mir gleich sagen wirst. 106 ;)
                           v.2023-06-20
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container
            Machine ID: b354c482f7cc342776f020ee5ea440c3
               Boot ID: 5ae552d81a2a43a78233355847e6e090
        Virtualization: lxc
      Operating System: Ubuntu 22.04.2 LTS
                Kernel: Linux 5.15.30-2-pve
          Architecture: x86-64
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Vienna (CEST, +0200)
      User-ID:                1001
      X-Server:               false
      Pending OS-Updates:     106
      Pending iob updates:    2
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      MEMORY:
      Mem:             10G        5.4G        3.5G        0.0K        1.1G        4.6G
      Swap:           2.0G        1.4G        670M
      Total:           12G        6.8G        4.2G
      Active iob-Instances:   59
      Active repo(s): Beta (latest)
                              admin                   6.5.9
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                57369
      States:                 51368
      72M     /opt/iobroker/iobroker-data/objects.jsonl
      29M     /opt/iobroker/iobroker-data/objects.json.migrated
      29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      118M    /opt/iobroker/iobroker-data/states.jsonl
      9.4M    /opt/iobroker/iobroker-data/states.json.migrated
      9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      ° Fixer ---> iob fix
      • bahnuhrB bahnuhr
        ich kein docker.
        Aber trotzdem:
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        dieter
        /home/dieter
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           974M          0B        974M
                 5928 M total memory
                 4601 M used memory
                  330 M active memory
                  476 M free memory
                  107 M buffer memory
                  743 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        869M    /var/
        371M    /var/cache
        364M    /var/cache/apt
        330M    /var/log
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        23378
        States:         19282
        Pending Updates: 3
                             v.2023-04-16
        Installation:           kvm
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        MEMORY:
        Swap:           974M          0B        974M
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                23378
        States:                 19280
        #477
        @bahnuhr
        Danke. Aber das skript wie im ersten Posting als Beta von github aus ausführen.
        Du hast die im ioBroker eingepackte Version genommen.
        • NegaleinN Negalein
          LXC
                               v.2023-06-20
                   Chassis: container
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1001
          X-Server:               false
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
          MEMORY:
                                  admin                   6.5.9
          Objects type: jsonl
          States  type: jsonl
          Objects:                57369
          States:                 51368
          #478
          @negalein sagte in iob diag - Skript:
          Danke.
          Aber dann brauch ich ja gar nichts mehr sagen und du hältst die Kiste jetzt einfach selbständig auf aktuellem Stand?
          NegaleinN 2 Antworten Letzte Antwort
            LXC
                                 v.2023-06-20
                     Chassis: container
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               amd64
            User-ID:                1001
            X-Server:               false
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
            MEMORY:
                                    admin                   6.5.9
            Objects type: jsonl
            States  type: jsonl
            Objects:                57369
            States:                 51368
            #479
            nö 108 😂
              Danke.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #480
              bin schon dabei.
              Gleich fertig. :)
                bin schon dabei.
                Gleich fertig. :)
                #481
                @negalein
                Dann bitte nochmal das Skript testen, hab gerade noch was bei github hochgeschoben.
                  Danke.
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #482
                  PS: was mach ich hier?
                  nega@ioBroker:/$ do-release-upgrade
                  Checking for a new Ubuntu release
                  There is no development version of an LTS available.
                  To upgrade to the latest non-LTS development release
                  set Prompt=normal in /etc/update-manager/release-upgrades.
                  nega@ioBroker:/$
                    @negalein
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #483
                                         v.2023-06-21
                             Chassis: container
                             Boot ID: eb405d983fe44b89bb3c508347189c13
                      Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               amd64
                    User-ID:                1001
                    X-Server:               false
                    Pending OS-Updates:     0
                    Nodejs-Installation:    /usr/bin/nodejs         v16.20.1
                                            /usr/bin/node           v16.20.1
                                            /usr/bin/npm            8.19.4
                                            /usr/bin/npx            8.19.4
                    Recommended versions are nodejs 18.16.1 and npm 9.5.1
                    MEMORY:
                    Mem:             10G        4.0G        5.0G        0.0K        1.1G        6.0G
                    Swap:           2.0G          0B        2.0G
                    Total:           12G        4.0G        7.0G
                    Active iob-Instances:   58
                                            admin                   6.5.9
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                55445
                    States:                 50135
                    49M     /opt/iobroker/iobroker-data/objects.jsonl
                    154M    /opt/iobroker/iobroker-data/states.jsonl
                      nega@ioBroker:/$
                      #484
                      Nix! Du willst kein release upgrade machen.
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #485
                        Ah, ok.
                        Gibt also kein neueres?
                          Ah, ok.
                          #486
                          Keine neueres LTS-Release. Das nächste LongTermSupport-Ding kommt im April 2024. Dazwischen sind nur Test-Releases am Start.
                            Ah, ok.
                            #487
                            Aber gut, der Code zur Auswertung von
                            funktioniert also.
                            • bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #488
                              Habe dies gemacht:
                              curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
                              chmod 744 iob_diag
                              ./iob_diag
                              Ist dies jetzt was anderes ?
                              Skript v.2023-06-21
                              *** BASE SYSTEM ***
                                 Static hostname: iobroker
                                       Icon name: computer-vm
                                         Chassis: vm
                                      Machine ID: dd59139b4ae040898d227e04f86103f0
                                         Boot ID: 83384625b8db43beaf0c2c2962e5a98f
                                  Virtualization: kvm
                                Operating System: Debian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 5.10.0-23-amd64
                              model name      : Common KVM processor
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                               21:55:10 up  3:56,  1 user,  load average: 1.39, 1.35, 1.35
                              CPU threads: 8
                                             Local time: Sun 2023-07-02 21:55:10 CEST
                                         Universal time: Sun 2023-07-02 19:55:10 UTC
                                               RTC time: Sun 2023-07-02 19:55:11
                                            NTP service: active
                                        RTC in local TZ: no
                              dieter
                              /home/dieter
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            5.9G        4.7G        379M        0.0K        869M        995M
                              Swap:           974M          0B        974M
                              Total:          6.9G        4.7G        1.4G
                                       5928 M total memory
                                       4680 M used memory
                                        377 M active memory
                                       4841 M inactive memory
                                        378 M free memory
                                        110 M buffer memory
                                        758 M swap cache
                                        974 M total swap
                                          0 M used swap
                                        974 M free swap
                              *** FILESYSTEM ***
                              tmpfs                     tmpfs     593M  516K  593M   1% /run
                              /var:
                              869M    /var/
                              371M    /var/cache
                              364M    /var/cache/apt
                              330M    /var/log
                              1.1G    /opt/iobroker/iobroker-data/
                              32M     /opt/iobroker/iobroker-data/states.jsonl
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Version table:
                              Errors in npm tree: 0
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              No configuration change needed.
                              Multihost discovery server: disabled
                              Discovery authentication:   enabled
                              Persistent activation:      disabled
                              Objects:                    jsonl on 0.0.0.0
                              States:                     jsonl on 0.0.0.0
                              admin:          6.3.5
                              javascript:     7.0.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        23378
                              States:         19280
                              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Reading package lists... Done
                              Pending Updates: 3
                              2023-07-02 21:53:34.067  - info: octoprint.0 (1220) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
                              2023-07-02 21:53:49.579  - info: javascript.0 (601) script.js.Scripte.Licht.Bad_EG: Licht Bad EG ausgeschaltet.
                              2023-07-02 21:54:00.102  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13298, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:54:00", "unix": 1688334840}, "successful": true}
                              2023-07-02 21:54:00.416  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
                              2023-07-02 21:54:18.279  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                              2023-07-02 21:54:50.767  - info: javascript.0 (601) script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
                              2023-07-02 21:54:56.031  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
                              2023-07-02 21:54:56.070  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
                              2023-07-02 21:55:00.113  - info: javascript.0 (601) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
                              2023-07-02 21:55:00.295  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
                              2023-07-02 21:55:00.299  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 86 %.
                              2023-07-02 21:55:00.331  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 70 %.
                              2023-07-02 21:55:00.347  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12556
                              2023-07-02 21:55:00.368  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
                              2023-07-02 21:55:00.461  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 52 %.
                              2023-07-02 21:55:00.487  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
                              2023-07-02 21:55:01.018  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                              2023-07-02 21:55:06.507  - info: dwd.0 (12556) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
                              2023-07-02 21:55:11.266  - info: dwd.0 (12556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2023-07-02 21:55:11.803  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-07-02 21:55:33.536  - info: javascript.0 (601) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
                              2023-07-02 21:56:00.099  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13418, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:56:00", "unix": 1688334960}, "successful": true}
                              2023-07-02 21:56:20.832  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
                              2023-07-02 21:56:23.013  - info: javascript.0 (601) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 296° / Sonne: Elevation: -25.6° / Mond: Azimut: 124° / Mond: Elevation: 32.7°
                              2023-07-02 21:56:40.642  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                                                   v.2023-06-21
                                         Chassis: vm
                                  Virtualization: kvm
                              Installation:           kvm
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            9.5.1
                                                      /usr/bin/npx            9.5.1
                              Recommended versions are nodejs 16.20.1 and npm 8.19.4
                              MEMORY:
                              Mem:            5.9G        4.5G        574M        0.0K        832M        1.2G
                              Swap:           974M        0.0K        974M
                              Total:          6.9G        4.5G        1.5G
                                                      admin                   6.3.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                23378
                              States:                 19280
                              36M     /opt/iobroker/iobroker-data/states.jsonl
                              Danke.
                              • bahnuhrB bahnuhr
                                Habe dies gemacht:
                                chmod 744 iob_diag
                                ./iob_diag
                                Skript v.2023-06-21
                                *** BASE SYSTEM ***
                                           Chassis: vm
                                    Virtualization: kvm
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                CPU threads: 8
                                              NTP service: active
                                          RTC in local TZ: no
                                dieter
                                /home/dieter
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           974M          0B        974M
                                         5928 M total memory
                                         4680 M used memory
                                          377 M active memory
                                          378 M free memory
                                          110 M buffer memory
                                          758 M swap cache
                                          974 M total swap
                                            0 M used swap
                                          974 M free swap
                                *** FILESYSTEM ***
                                /var:
                                869M    /var/
                                371M    /var/cache
                                364M    /var/cache/apt
                                330M    /var/log
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     7.0.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        23378
                                States:         19280
                                Pending Updates: 3
                                                     v.2023-06-21
                                           Chassis: vm
                                    Virtualization: kvm
                                Installation:           kvm
                                Kernel:                 x86_64
                                Userland:               amd64
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            9.5.1
                                                        /usr/bin/npx            9.5.1
                                MEMORY:
                                                        admin                   6.3.5
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                23378
                                States:                 19280
                                #489
                                @bahnuhr sagte in iob diag - Skript:
                                Ja, das ist Skript v.2023-06-21.
                                Danke dir.
                                Mist...
                                Da sollte natürlich 18 und 9 erscheinen...
                                  Danke dir.
                                  Mist...
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #490
                                  dort steht: Multihost discovery server: disabled
                                  Ist das richtig ?
                                  habe multihost
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    Ist das richtig ?
                                    habe multihost
                                    #491
                                    Ist das richtig ?
                                    Ja, das ist richtig.
                                    Ich hab noch keinen Weg gefunden, den Status sicher festzunageln.
                                      Ist das richtig ?
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #492
                                      Und bei diesen Punkten hattest du mal irgendwo was zu mir gesagt.
                                      Wollten wir irgendwann nochmal thematisieren.
                                      Muss ich da nochmal ran?
                                      Danke.
                                      • uweklattU Offline
                                        uweklattU Offline
                                        uweklatt
                                        schrieb am zuletzt editiert von uweklatt
                                        #493
                                        ich nutze hier Docker innerhalb LXC auf Proxmox.
                                        Das Script liefert hier folgende Ausgaben:
                                        *** iob diag is starting up, please wait ***
                                        *** ioBroker Diagnosis ***
                                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                        Just copy and paste the Summary Page, including the  characters at start and end.
                                        It helps us to help you!
                                        Press any key to continue
                                        Skript v.2023-06-21
                                        *** BASE SYSTEM ***
                                        Hardware Vendor : LENOVO
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        Docker          : v8.0.1
                                        Virtualization  : Docker
                                        Kernel          : x86_64
                                        Userland        : amd64
                                         18:58:39 up 32 days, 23:48,  0 users,  load average: 0.32, 0.19, 0.12
                                        CPU threads: 4
                                        Mon Jul  3 16:58:39 UTC 2023
                                        Mon Jul  3 18:58:39 CEST 2023
                                        CEST +0200
                                        Etc/UTC
                                        root
                                        /root
                                        root
                                        X-Server: 	false
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Mem:            7.8G        3.2G        764M         40M        3.8G        4.2G
                                        Swap:           7.8G         21M        7.8G
                                        Total:           15G        3.3G        8.6G
                                                 7824 M total memory
                                                 3242 M used memory
                                                 1453 M active memory
                                                 5083 M inactive memory
                                                  764 M free memory
                                                  661 M buffer memory
                                                 3156 M swap cache
                                                 7835 M total swap
                                                   21 M used swap
                                                 7814 M free swap
                                        *** FILESYSTEM ***
                                        overlay                          overlay   61G  9.0G   49G  16% /
                                        tmpfs                            tmpfs     64M     0   64M   0% /dev
                                        shm                              tmpfs     64M     0   64M   0% /dev/shm
                                        /dev/mapper/pve-vm--100--disk--0 ext4      61G  9.0G   49G  16% /opt/iobroker
                                        tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/asound
                                        tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/acpi
                                        tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/scsi
                                        tmpfs                            tmpfs    3.9G     0  3.9G   0% /sys/firmware
                                        [Wed May 31 19:10:12 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Wed May 31 19:10:13 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                                        [Wed May 31 19:10:21 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Wed May 31 19:10:23 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
                                        [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                        [Fri Jun  2 19:29:53 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                        [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
                                        [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                        [Fri Jun  2 19:40:07 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                                        [Tue Jun 27 11:17:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Tue Jun 27 11:29:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        /opt/iobroker    /dev/mapper/pve-vm--100--disk--0[/iobroker]        ext4   rw,relatime,stripe=16
                                        /etc/resolv.conf /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/resolv.conf] ext4   rw,relatime,stripe=16
                                        /etc/hostname    /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hostname]    ext4   rw,relatime,stripe=16
                                        /etc/hosts       /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hosts]       ext4   rw,relatime,stripe=16
                                        /var:
                                        33M	/var/
                                        31M	/var/lib
                                        18M	/var/lib/apt/lists
                                        18M	/var/lib/apt
                                        13M	/var/lib/dpkg
                                        5.5M	/opt/iobroker/backups/
                                        196M	/opt/iobroker/iobroker-data/
                                        104M	/opt/iobroker/iobroker-data/files
                                        63M	/opt/iobroker/iobroker-data/backup-objects
                                        52M	/opt/iobroker/iobroker-data/files/javascript.admin
                                        34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                        23M	/opt/iobroker/iobroker-data/objects.jsonl
                                        7.2M	/opt/iobroker/iobroker-data/states.jsonl
                                        6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
                                        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                        5.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
                                        /usr/bin/npm 		9.5.1
                                        /usr/bin/npx 		9.5.1
                                        nodejs:
                                          Version table:
                                                500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                    jsonl on 127.0.0.1
                                        States:                     jsonl on 127.0.0.1
                                        admin: 		6.3.5
                                        javascript: 	7.0.3
                                        Adapter State
                                        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                                          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                        + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                                          system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
                                        + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                          system.adapter.info.0                   : info                  : iobroker                                 - disabled
                                          system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
                                        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                          system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
                                        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                                        + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                                          system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                                        + instance is alive
                                        stable        : http://iobroker.live/repo/sources-dist.json
                                        beta          : http://iobroker.live/repo/sources-dist-latest.json
                                        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                        Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
                                        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                                        Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
                                        Objects and States
                                        Objects: 	3398
                                        States: 	3035
                                        Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72780677   532/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72780670   532/iobroker.js-con
                                        tcp        0      0 127.0.0.11:32827        0.0.0.0:*               LISTEN      0          72777013   -
                                        tcp        0      0 192.168.178.223:18998   0.0.0.0:*               LISTEN      1000       72781358   607/io.javascript.0
                                        tcp6       0      0 :::61991                :::*                    LISTEN      1000       72784653   791/io.harmony.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72789074   878/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72780750   554/io.admin.0
                                        udp        0      0 127.0.0.11:56903        0.0.0.0:*                           0          72777012   -
                                        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       72784654   791/io.harmony.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       73940879   34550/io.chromecast
                                        Copy text starting here:
                                        		     v.2023-06-21
                                        model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        Docker          : v8.0.1
                                        Installation: 		Docker
                                        Kernel: 		x86_64
                                        Userland: 		amd64
                                        Timezone: 		Etc/UTC
                                        User-ID: 		0
                                        X-Server: 		false
                                        			/usr/bin/npm 		9.5.1
                                        			/usr/bin/npx 		9.5.1
                                        MEMORY:
                                        Mem:            7.8G        3.3G        753M         40M        3.8G        4.2G
                                        Swap:           7.8G         21M        7.8G
                                        Active iob-Instances: 	14
                                        			admin 			6.3.5
                                        ioBroker Status: 	iobroker is running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects: 		3398
                                        States: 		3035
                                        === Mark text until here for copying ===
                                        Tschau
                                        Uwe
                                        Intel i5/Proxmox/LXC/Docker/ioBroker
                                        DJMarc75D Meister MopperM 2 Antworten Letzte Antwort
                                        • uweklattU uweklatt
                                          Skript v.2023-06-21
                                          *** BASE SYSTEM ***
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          Docker          : v8.0.1
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          CPU threads: 4
                                          CEST +0200
                                          Etc/UTC
                                          root
                                          /root
                                          root
                                          X-Server: 	false
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Swap:           7.8G         21M        7.8G
                                                   7824 M total memory
                                                   3242 M used memory
                                                    764 M free memory
                                                    661 M buffer memory
                                                   3156 M swap cache
                                                   7835 M total swap
                                                     21 M used swap
                                                   7814 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          33M	/var/
                                          31M	/var/lib
                                          18M	/var/lib/apt
                                          13M	/var/lib/dpkg
                                          /usr/bin/npm 		9.5.1
                                          /usr/bin/npx 		9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.3.5
                                          javascript: 	7.0.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects: 	3398
                                          States: 	3035
                                          Pending Updates: 0
                                          		     v.2023-06-21
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          Docker          : v8.0.1
                                          Kernel: 		x86_64
                                          Userland: 		amd64
                                          Timezone: 		Etc/UTC
                                          User-ID: 		0
                                          X-Server: 		false
                                          			/usr/bin/npm 		9.5.1
                                          			/usr/bin/npx 		9.5.1
                                          MEMORY:
                                          Swap:           7.8G         21M        7.8G
                                          			admin 			6.3.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects: 		3398
                                          States: 		3035
                                          Tschau
                                          Uwe
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #494
                                          @uweklatt sagte in iob diag - Skript:
                                          Tschau
                                          und Deine Frage lautet ? Oder war Dein Beitrag nur eine Feststellung ??
                                          Lehrling seit 1975 !!!
