  4. Test Adapter Bosch ebik connect / flow
    6.8k
208 Beiträge 41 Kommentatoren 59.1k Aufrufe 46 Beobachtet
  • L lindi200000
    @zec ich Habe das Bosch Smart System mit Kiox 300, da geht kein Bosch Connect, sondern nur Bosch Flow.
    Z Offline
    Z Offline
    Zec
    @lindi200000 verstehe ich.
    Wäre schön, wenn man für beide Systeme die Akkuanzeige integrieren kann. :)
    Z 1 Antwort Letzte Antwort
    • Z Zec
      Z Offline
      Z Offline
      Zec
      Ich habe Bosch angeschrieben, ob der Akkustand kurzfristig zum Onlineportal übertragen werden könnte.
      Folgende Antwort habe ich soeben erhalten:
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @tombox
        seit heute im log:
        host.iobroker
        2023-06-06 21:08:05.472	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'replace')
        host.iobroker
        2023-06-06 21:08:05.470	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        bosch-ebike.0
        2023-06-06 21:08:04.273	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        bosch-ebike.0
        2023-06-06 21:08:04.270	info	terminating
        bosch-ebike.0
        2023-06-06 21:08:04.228	error	Cannot read properties of undefined (reading 'replace')
        bosch-ebike.0
        2023-06-06 21:08:04.227	error	TypeError: Cannot read properties of undefined (reading 'replace') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        bosch-ebike.0
        2023-06-06 21:08:04.218	error	unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
        bosch-ebike.0
        2023-06-06 21:08:04.217	error	Unhandled promise rejection. This error originated either by throwing inside of an asyn
        Instanz bleibt rot.
        Ist ein Problem bekannt ?
        Danke.
        T draexlerD 2 Antworten Letzte Antwort
        • bahnuhrB bahnuhr
          @tombox
          seit heute im log:
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          Instanz bleibt rot.
          tombox
          @bahnuhr singleKey Umstellung von Bosch müsste man anpassen
          • bahnuhrB bahnuhr
            @tombox
            seit heute im log:
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            bosch-ebike.0
            bosch-ebike.0
            bosch-ebike.0
            bosch-ebike.0
            bosch-ebike.0
            bosch-ebike.0
            Instanz bleibt rot.
            draexlerD Offline
            draexlerD Offline
            draexler
            @bahnuhr Schließe mich mal an
            • T tombox
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @tombox
              Bist du dran.
              Danke.
              • bahnuhrB bahnuhr
                @tombox
                Bist du dran.
                tombox
                @bahnuhr noch nicht habe erst in 1-2 Wochen zeit
                bahnuhrB 2 Antworten Letzte Antwort
                • T tombox
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @tombox sagte in Test Adapter Bosch ebik connect / flow:
                  alles klar.
                  wenn ich helfen kann sag Bescheid
                  Danke.
                  • T tombox
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @tombox
                    konntest du schon etwas umsetzen ?
                    Danke.
                    • bahnuhrB bahnuhr
                      @tombox
                      tombox
                      @bahnuhr Nein leider gerade keine zeit
                      • T tombox
                        @bahnuhr schon die 0.03 probiert?
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @tombox
                        Guten Morgen,
                        sag mal Bescheid ob ich dich da irgendwie unterstützen kann.
                        mfg
                        Dieter
                        Danke.
                        • I Offline
                          I Offline
                          IOMax
                          Ich freue mich auch schon darauf, wenn es wieder funktioniert. Ich teste auch gerne.
                            backfisch88
                            gibts hierzu schon news?
                            • T tombox
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              Ist @tombox im Urlaub ?
                              oder krank?
                              oder kommt zu diesem Adapter momentan einfach nicht.
                              Hat da irgendwer Infos?
                              Danke.
                                tombox
                                Bitte mal die github version testen ob der login für flow wieder geht
                                ste_gleiS bahnuhrB 2 Antworten Letzte Antwort
                                • T tombox
                                  ste_gleiS Offline
                                  ste_gleiS Offline
                                  ste_glei
                                  funktioniert wieder
                                  danke
                                  • T tombox
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @tombox
                                    Danke, super klappt wieder.
                                    Danke.
                                      backfisch88
                                      läuft wieder! besten dank!
                                      • Marco StiegM Offline
                                        Marco Stieg
                                        Hallo zusammen.
                                        Hat schon jemand die Problematik gelöst, dass die Zeit in Bewegung immer eine Stunde zuviel ausgibt?
                                          Marcus007
                                          Wird an dem Adapter noch was gemacht?
                                          Gruss Marcus
