  4. Test Adapter Bosch ebik connect / flow
208 Beiträge 41 Kommentatoren 59.2k Aufrufe 46 Beobachtet
  • bahnuhrB bahnuhr
    @tombox
    seit heute im log:
    host.iobroker
    2023-06-06 21:08:05.472	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    2023-06-06 21:08:05.471	error	Caught by controller[0]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
    host.iobroker
    2023-06-06 21:08:05.471	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iobroker
    2023-06-06 21:08:05.471	error	Caught by controller[0]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51)
    host.iobroker
    2023-06-06 21:08:05.471	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'replace')
    host.iobroker
    2023-06-06 21:08:05.470	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    bosch-ebike.0
    2023-06-06 21:08:04.273	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    bosch-ebike.0
    2023-06-06 21:08:04.270	info	terminating
    bosch-ebike.0
    2023-06-06 21:08:04.228	error	Cannot read properties of undefined (reading 'replace')
    bosch-ebike.0
    2023-06-06 21:08:04.227	error	TypeError: Cannot read properties of undefined (reading 'replace') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
    bosch-ebike.0
    2023-06-06 21:08:04.218	error	unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
    bosch-ebike.0
    2023-06-06 21:08:04.217	error	Unhandled promise rejection. This error originated either by throwing inside of an asyn
    Instanz bleibt rot.
    Ist ein Problem bekannt ?
    draexlerD Offline
    draexlerD Offline
    draexler
    @bahnuhr Schließe mich mal an
    • T tombox
      @bahnuhr singleKey Umstellung von Bosch müsste man anpassen
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @tombox
      Bist du dran.
      Danke.
      • bahnuhrB bahnuhr
        @tombox
        Bist du dran.
        tombox
        @bahnuhr noch nicht habe erst in 1-2 Wochen zeit
        bahnuhrB 2 Antworten Letzte Antwort
        • T tombox
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @tombox sagte in Test Adapter Bosch ebik connect / flow:
          alles klar.
          wenn ich helfen kann sag Bescheid
          Danke.
          • T tombox
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @tombox
            konntest du schon etwas umsetzen ?
            Danke.
            • bahnuhrB bahnuhr
              @tombox
              tombox
              @bahnuhr Nein leider gerade keine zeit
              • T tombox
                @bahnuhr schon die 0.03 probiert?
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @tombox
                Guten Morgen,
                sag mal Bescheid ob ich dich da irgendwie unterstützen kann.
                mfg
                Dieter
                Danke.
                • I Offline
                  I Offline
                  IOMax
                  Ich freue mich auch schon darauf, wenn es wieder funktioniert. Ich teste auch gerne.
                    backfisch88
                    gibts hierzu schon news?
                    • T tombox
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      Ist @tombox im Urlaub ?
                      oder krank?
                      oder kommt zu diesem Adapter momentan einfach nicht.
                      Hat da irgendwer Infos?
                      Danke.
                        tombox
                        Bitte mal die github version testen ob der login für flow wieder geht
                        ste_gleiS bahnuhrB 2 Antworten Letzte Antwort
                        • T tombox
                          ste_gleiS Offline
                          ste_gleiS Offline
                          ste_glei
                          funktioniert wieder
                          danke
                          • T tombox
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @tombox
                            Danke, super klappt wieder.
                            Danke.
                              backfisch88
                              läuft wieder! besten dank!
                              • Marco StiegM Offline
                                Marco Stieg
                                Hallo zusammen.
                                Hat schon jemand die Problematik gelöst, dass die Zeit in Bewegung immer eine Stunde zuviel ausgibt?
                                  Marcus007
                                  Wird an dem Adapter noch was gemacht?
                                  Gruss Marcus
                                  • M Marcus007
                                    Gruss Marcus
                                    tombox
                                    @marcus007 ja bitte beta channel von iobroker verwenden
                                    draexlerD 1 Antwort Letzte Antwort
                                    • T tombox
                                      draexlerD Offline
                                      draexlerD Offline
                                      draexler
                                      @tombox Seit heute (evtl. auch schon länger) wird der Adapter nicht mehr grün:
                                      Das ist im LOG:
                                      	2023-12-01 18:46:34.962	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      host.iobroker
                                      2023-12-01 18:46:34.962	error	Caught by controller[0]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                                      host.iobroker
                                      2023-12-01 18:46:34.962	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      host.iobroker
                                      2023-12-01 18:46:34.961	error	Caught by controller[0]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41)
                                      host.iobroker
                                      2023-12-01 18:46:34.961	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'value')
                                      host.iobroker
                                      2023-12-01 18:46:34.960	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      bosch-ebike.0
                                      2023-12-01 18:46:34.339	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      bosch-ebike.0
                                      2023-12-01 18:46:34.313	error	Cannot read properties of undefined (reading 'value')
                                      bosch-ebike.0
                                      2023-12-01 18:46:34.312	error	TypeError: Cannot read properties of undefined (reading 'value') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
                                      bosch-ebike.0
                                      2023-12-01 18:46:34.310	error	unhandled promise rejection: Cannot read properties of undefined (reading 'value')
                                      bosch-ebike.0
                                      2023-12-01 18:46:34.308	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      admin.0
                                      2023-12-01 18:45:36.024	warn	bosch-ebike has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
                                      • draexlerD draexler
                                        Das ist im LOG:
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        bosch-ebike.0
                                        bosch-ebike.0
                                        bosch-ebike.0
                                        bosch-ebike.0
                                        bosch-ebike.0
                                        admin.0
                                        @draexler
                                        iobroker und nodejs sind auf dem letzten Stand?
                                        Auf welchem?
                                        iob diag
                                        anschauen.
                                          @draexler
                                          Auf welchem?
                                          iob diag
                                          anschauen.
                                          draexlerD Offline
                                          draexlerD Offline
                                          draexler
                                          schrieb am zuletzt editiert von draexler
                                          @thomas-braun: Jetzt wo du so schreibst mit der nodejs..
                                          Das habe ich heute morgen mit:
                                          curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update > iob_node_update
                                          chmod 744 iob_node_update
                                          /iob_node_update
                                          geupdatet und evtl. funktioniert es seit dem nicht mehr.
                                          hier das iob diag:
        v.2023-10-10
                                             Static hostname: iobroker
                                                   Icon name: computer-vm
                                                     Chassis: vm
                                              Virtualization: kvm
                                            Operating System: Debian GNU/Linux 11 (bullseye)
                                                      Kernel: Linux 5.10.0-26-amd64
                                                Architecture: x86-64
                                          Installation:           kvm
                                          Kernel:                 x86_64
                                          Userland:               amd64
                                          Timezone:               Europe/Berlin (CET, +0100)
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Pending iob updates:    0
                                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
                                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                          MEMORY:
                                          Mem:            7.9G        4.8G        2.1G        0.0K        1.0G        2.9G
                                          Swap:           974M          0B        974M
                                          Total:          8.9G        4.8G        3.1G
                                          Active iob-Instances:   57
                                          ioBroker Core:          js-controller           5.0.16
        admin                   6.12.0
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                27161
                                          States:                 21499
                                          Size of iob-Database:
                                          37M     /opt/iobroker/iobroker-data/objects.jsonl
                                          35M     /opt/iobroker/iobroker-data/states.jsonl
