  4. [Problem] Harmony stürzt regelmäßig ab
55 Beiträge 17 Kommentatoren 12.6k Aufrufe
    thronis
    Vielen Dank habe es hin bekommen :-)
    Wer suchet der findet^^
    • eric2905E Offline
      eric2905E Offline
      eric2905
      @thronis:
      Wer suchet der findet^^ `
      Wer liest, auch :D
      Schau mal in die Hilfe zu den Adaptern - da findest zu (fast) alles zu den Konfig-Möglichkeiten. ==> http://www.iobroker.net/?page_id=2236&lang=de
      Gruß,
      Eric
      Von unterwegs getippert
        Karim
        Also es ist zwar besser geworden, aber es gibt immer noch Fehler.
        Ich bin aber auch noch blutiger Anfänger, sodass ich keine Ahnung habe, was da schief läuft.
        harmony.0	2017-05-04 22:17:57.313	info	synced hub config
        harmony.0	2017-05-04 22:17:56.201	info	connected to Karim's Harmony Hub
        harmony.0	2017-05-04 22:17:53.914	info	connecting to Karim's Harmony Hub
        harmony.0	2017-05-04 22:17:53.804	info	discovered Karim's Harmony Hub
        harmony.0	2017-05-04 22:17:50.826	warn	could not connect to Karim's Harmony Hub: Error: Timed out after 5000 ms
        harmony.0	2017-05-04 22:17:40.800	info	keep alive failed: Error: Timed out after 5000 ms
        harmony.0	2017-05-04 22:17:38.950	info	client ended: Karim's_Harmony_Hub
        harmony.0	2017-05-04 22:17:38.943	warn	lost Karim's Harmony Hub
        cloud.0	2017-05-04 22:09:22.453	info	Connection changed: CONNECTED1
        cloud.0	2017-05-04 22:09:22.149	info	2017-05-04T20:09:22.149Z Connected system.user.admin
        cloud.0	2017-05-04 22:09:12.005	info	Connection changed: DISCONNECTED1
        cloud.0	2017-05-04 22:09:12.002	info	Connection changed: DISCONNECTED3
        cloud.0	2017-05-04 22:09:11.995	error	Ping timeout
        harmony.0	2017-05-04 22:05:13.450	warn	error sending command, client offline
        harmony.0	2017-05-04 22:05:09.557	warn	error sending command, client offline
        harmony.0	2017-05-04 22:05:09.540	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=0
        harmony.0	2017-05-04 22:05:09.539	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=0
        harmony.0	2017-05-04 22:04:45.548	warn	error sending command, client offline
        harmony.0	2017-05-04 22:04:45.517	warn	error sending command, client offline
        harmony.0	2017-05-04 22:04:45.475	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=1
        harmony.0	2017-05-04 22:04:45.470	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Amazon_Fire_TV.Home=0
        harmony.0	2017-05-04 22:04:45.470	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=1
        harmony.0	2017-05-04 22:04:45.465	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Amazon_Fire_TV.Home=0
        harmony.0	2017-05-04 20:57:16.266	warn	error sending command, client offline
        harmony.0	2017-05-04 20:57:16.246	warn	error sending command, client offline
        harmony.0	2017-05-04 20:57:16.239	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Philips-Fernseher.InputHdmi1=1
        harmony.0	2017-05-04 20:57:16.235	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Philips-Fernseher.InputHdmi1=1
        harmony.0	2017-05-04 20:57:12.454	warn	error sending command, client offline
        harmony.0	2017-05-04 20:57:12.425	warn	error sending command, client offline
        harmony.0	2017-05-04 20:57:12.395	warn	error sending command, client offline
        harmony.0	2017-05-04 20:57:12.368	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=0
        harmony.0	2017-05-04 20:57:12.367	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Amazon_Fire_TV.Home=1
        harmony.0	2017-05-04 20:57:12.363	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=0
        harmony.0	2017-05-04 20:57:12.356	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Amazon_Fire_TV.Home=1
        harmony.0	2017-05-04 20:57:12.352	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Philips-Fernseher.PowerToggle=1
        harmony.0	2017-05-04 20:57:12.343	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.Philips-Fernseher.PowerToggle=1
        harmony.0	2017-05-04 20:44:46.107	warn	error sending command, client offline
        hue.0	2017-05-04 20:44:42.433	info	final lightState for Philips_hue.Treppe:{"bri":254,"on":true,"level":100}
        hue.0	2017-05-04 20:44:42.426	info	final lightState for Philips_hue.Sideboard:{"bri":254,"on":true,"level":100}
        hue.0	2017-05-04 20:44:42.386	info	final lightState for Philips_hue.Pflanzen:{"bri":254,"on":true,"level":100}
        hue.0	2017-05-04 20:44:42.375	info	final lightState for Philips_hue.Esszimmer:{"bri":254,"on":true,"level":100}
        hue.0	2017-05-04 20:44:42.353	info	final lightState for Philips_hue.Couch:{"bri":254,"on":true,"level":100}
        harmony.0	2017-05-04 20:44:42.263	warn	error sending command, client offline
        harmony.0	2017-05-04 20:44:42.224	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=0
        harmony.0	2017-05-04 20:44:42.223	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.AV-Receiver.PowerOff=0
        harmony.0	2017-05-04 20:44:36.369	warn	change activities, not currentActivity
        harmony.0	2017-05-04 20:44:36.031	warn	change activities, not currentActivity
        harmony.0	2017-05-04 20:44:36.029	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.activities.currentActivity=Musik
        harmony.0	2017-05-04 20:44:35.997	warn	error changing activity, client offline
        harmony.0	2017-05-04 20:44:28.714	warn	change activities, not currentActivity
        harmony.0	2017-05-04 20:44:28.478	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.activities.currentActivity=Musik
        harmony.0	2017-05-04 20:44:28.468	warn	change activities, not currentActivity
        harmony.0	2017-05-04 20:44:28.461	warn	error changing activity, client offline
        harmony.0	2017-05-04 20:43:09.516	warn	error sending command, client offline
        Lieben Gruß, Karim.
        • P Offline
          Pman
          @Karim:
          Lieben Gruß, Karim. `
          In diesem Fall würde ich auf WLAN Probleme Tippen, einmal wird auch Cloud neu verbunden. Der Harmony Hub ist einfach extrem empfindlich, was das angeht. Ich habe den Hub jetzt 24 Stunden an einer weiter vom Router entfernten Stelle angeschlossen. Mein Log ist komplett voll mit Disconnects und oft auf darauf folgenden Abstürzen des Adapters, da sich der Hub beim Wiederverbinden teilweise schon wieder ausklinkt. Das positive ist, dass er schlussendlich immer wieder automatisch verbunden hat.
          Als nächstes werde ich es nochmal direkt beim Router testen.
            Karim
            Ok, das ist ja auch interessant. Schade eigentlich, das das Teil so empfindlich ist.
            Leider bin ich ziemlich eingeschränkt, was den Aufstellort angeht. Schließlich muss ja Sichtkontakt zu den anderen Geräten bestehen.
            Was ich halt so komisch finde ist, dass bevor ich ioBroker genutzt habe, es so gut wie nie Probleme mit dem Teil gab.
            Wenn ich die befehle einzeln sende, habe ich auch eine höhere Erfolgsquote als wenn ich die activity direkt starte.
            Lieben Gruß, Karim
              andyb
              Am 04.05.2017 hab ich auf 0.7.1 upgedatet, seither lief der Adapter ohne Probleme.
              Seit gestern kriege ich keine Verbindung mehr zum Hub "Hubconnected false"
              ioBroker und Hub neu gestartet brachte keine Besserung.
              Adapter gelöscht und neu brachte auch nix.
              Jemand ne Idee?
              Über Haandyapp ist der Hub erreichbar und steuerbar.
              host.orangepiplus2e	2017-06-19 21:40:51.177	info	instance system.adapter.harmony.0 started with pid 24495
              iobroker	2017-06-19 21:40:48.801	info	exit 0
              iobroker	2017-06-19 21:40:48.764	info	Adapter "harmony" updated
              iobroker	2017-06-19 21:40:48.646	info	upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
              host.orangepiplus2e	2017-06-19 21:40:48.615	info	stopInstance system.adapter.harmony.0 killing pid 24249
              host.orangepiplus2e	2017-06-19 21:40:48.614	info	stopInstance system.adapter.harmony.0
              host.orangepiplus2e	2017-06-19 21:40:48.610	info	object change system.adapter.harmony.0
              iobroker	2017-06-19 21:40:48.586	info	Update "system.adapter.harmony.0"
              iobroker	2017-06-19 21:40:48.471	info	upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
              iobroker	2017-06-19 21:40:48.435	info	got /opt/iobroker/node_modules/iobroker.harmony/admin
              iobroker	2017-06-19 21:40:16.871	info	WARN deprecated node-xmpp-jid@2.3.0: use @xmpp/jid package
              iobroker	2017-06-19 21:40:16.868	info	npm
              iobroker	2017-06-19 21:40:05.416	info	WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
              iobroker	2017-06-19 21:40:05.412	info	npm
              iobroker	2017-06-19 21:39:58.622	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.harmony"
              iobroker	2017-06-19 21:38:17.297	info	npm install iobroker.harmony@0.7.1 --production --prefix "/opt/iobroker" (System call)
              iobroker	2017-06-19 21:38:13.465	info	upgrade harmony
              • N Offline
                N Offline
                Nabla
                Ich habe leider auch regelmäßig Abbrüche.
                Ich tippe aber nicht auf das WLAN des Harmony-Hubs, da Alexa zu jederzeit Zugriff auf den Hub hat.
                Leider funktionieren die Alexa-Kommandos jedoch nicht zuverlässig, die im iobroker hinterlegt sind, da disconnect.
                Nach einem Neustart des Harmony-Adapters funktioniert dann wieder alles.
                Also ein Adapter-Problem. Kann man hier nicht einen automatischen Refresh implementieren?
                Sonst müsste man es mit einem Skript-Lösen.
                Als Trigger "HubConnected = False" -> Adapter Stoppen, Adapter Neustarten
                und dann solange wiederholen, bis HubConnected wieder auf True steht
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  @Nabla:
                  und dann solange wiederholen, bis HubConnected wieder auf True steht `
                  bei mir startet er autmatisch neu wen er verbindung verliert:
                  harmony.0	2017-10-11 21:03:30.730	info	synced hub config
                  harmony.0	2017-10-11 21:03:29.827	info	connected to Woonkamer
                  harmony.0	2017-10-11 21:03:27.575	info	connecting to Woonkamer
                  harmony.0	2017-10-11 21:03:27.547	info	discovered Woonkamer
                  harmony.0	2017-10-11 21:03:25.600	info	client ended: Woonkamer
                  harmony.0	2017-10-11 21:03:25.598	warn	lost Woonkamer
                  harmony.0	2017-10-11 21:03:20.520	info	synced hub config
                  harmony.0	2017-10-11 21:03:19.760	info	connected to Woonkamer
                  harmony.0	2017-10-11 21:03:17.497	info	connecting to Woonkamer
                  harmony.0	2017-10-11 21:03:17.452	info	discovered Woonkamer
                  harmony.0	2017-10-11 21:03:15.596	info	client ended: Woonkamer
                  harmony.0	2017-10-11 21:03:15.592	warn	lost Woonkamer
                  harmony.0	2017-10-11 21:00:55.010	info	synced hub config
                  harmony.0	2017-10-11 21:00:54.085	info	connected to Woonkamer
                  harmony.0	2017-10-11 21:00:51.779	info	connecting to Woonkamer
                  harmony.0	2017-10-11 21:00:51.733	info	discovered Woonkamer
                  harmony.0	2017-10-11 21:00:51.099	info	client ended: Woonkamer
                  harmony.0	2017-10-11 21:00:51.096	warn	lost Woonkamer
                  harmony.0	2017-10-11 20:59:42.908	info	synced hub config
                  harmony.0	2017-10-11 20:59:41.837	info	connected to Woonkamer
                  harmony.0	2017-10-11 20:59:39.539	info	connecting to Woonkamer
                  harmony.0	2017-10-11 20:59:39.493	info	discovered Woonkamer
                  harmony.0	2017-10-11 20:59:38.853	info	client ended: Woonkamer
                  harmony.0	2017-10-11 20:59:38.851	warn	lost Woonkamer
                  version 0.7.1
                  • N Offline
                    N Offline
                    Nabla
                    bei mir sieht es so aus und ist genau in dem Moment aufgetreten, als ich den Alexa-Befehl abgegeben habe:
                    harmony.0	2017-10-11 20:49:00.829	warn	error changing activity, client offline
                    harmony.0	2017-10-11 20:49:00.827	warn	error changing activity, client offline
                    harmony.0	2017-10-11 20:48:40.838	warn	error sending command, client offline
                    harmony.0	2017-10-11 20:48:40.836	warn	error sending command, client offline
                    harmony.0	2017-10-11 20:48:35.841	warn	error sending command, client offline
                    harmony.0	2017-10-11 20:48:35.836	warn	error sending command, client offline
                    harmony.0	2017-10-11 20:46:18.807	warn	error changing activity, client offline
                    harmony.0	2017-10-11 20:46:18.811	warn	error changing activity, client offline
                    harmony.0	2017-10-11 20:43:46.526	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
                    harmony.0	2017-10-11 20:43:39.522	info	connecting to Harmony Hub 2
                    harmony.0	2017-10-11 20:43:39.477	info	discovered Harmony Hub 2
                    harmony.0	2017-10-11 20:43:38.426	warn	lost Harmony Hub 2
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @Nabla:
                      welche adapter version hast du ?
                      • N Offline
                        N Offline
                        Nabla
                        harmony.0	2017-10-11 20:54:03.434	info	starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.harmony, node: v6.11.2
                        • wendy2702W Offline
                          wendy2702W Offline
                          Seit ihr sicher das es keine WLAN Probleme sind?
                          Muss ja nicht zwingend der Abstand HUB-WLAN Router oder Repeater sein. Auch Störeinflüsse von Nachbar Netzen bringen den HUB gerne aus dem tritt.
                          Ich hatte das auch bis ich mir in ca. 2 m Entfernung zum HUB einen Access Point installiert habe. Dann die Fritzbox und AP auf Autokanal gestellt damit die sich selber um Störeinflüsse kümmern kann und bei bedarf den Kanel wechselt.
                          Seitdem… ist Ruhe im logfile.
                          • N Offline
                            N Offline
                            Nabla
                            Steht bei mir 3 Meter neben einem Devolo 1200+ Adapter.
                            Aber ich wechsel noch mal auf die Fritzbox, die steht zwar weiter weg, aber vielleicht stört ja auch das Powerlan dazwischen.
                            Dazu kann ich dann aber erst nach ein paar Tagen Test wieder etwas sagen.
                            Gegen WLAN spricht halt weiterhin, dass Alexa (über Yonomi) direkt Zugriff auf den Hub hatte
                              wendy2702W Offline
                              Also hast du verschiedene WLAN Netze die sich gegenseitig beeinflussen können wenn ich das richtig interpretiere.
                              Vielleicht kannst du für einen Zeitraum auch mal bis auf das Netz welches den HUB versorgt die anderen deaktivieren… es sei denn das sind WLAN Repeater, dann wird das schwierig.
                              Powerline macht die merkwürdigsten sachen. Mein Schwager hatte eine Box von Unitymedia und dahinter oder dazwischen Powerline... hat dazu geführt das sich aus welchem Grund auch immer die Unitymedia Box immer mal wieder restartet hat. Powerline zum testen raus und langes LAN Kabel ran und alles war gut.
                              • N Offline
                                N Offline
                                Nabla
                                Also an der Fritzbox geht es gar nicht richtig. Da scheint das wlan wirklich gestört zu sein, da funktioniert selbst Alexa nicht mehr korrekt
                                mit dem Harmony Hub. Die Fritzbox steht auch rund 15 Meter und zwei Räume entfernt.
                                harmony.0	2017-10-12 22:18:10.501	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
                                harmony.0	2017-10-12 22:18:03.491	info	connecting to Harmony Hub 2
                                harmony.0	2017-10-12 22:18:03.444	info	discovered Harmony Hub 2
                                harmony.0	2017-10-12 22:17:13.782	warn	lost Harmony Hub 2
                                harmony.0	2017-10-12 22:16:59.400	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
                                harmony.0	2017-10-12 22:16:52.396	info	connecting to Harmony Hub 2
                                harmony.0	2017-10-12 22:16:52.356	info	discovered Harmony Hub 2
                                harmony.0	2017-10-12 22:16:08.766	warn	lost Harmony Hub 2
                                harmony.0	2017-10-12 22:15:58.477	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
                                harmony.0	2017-10-12 22:15:51.472	info	connecting to Harmony Hub 2
                                harmony.0	2017-10-12 22:15:51.428	info	discovered Harmony Hub 2
                                harmony.0	2017-10-12 22:15:48.760	warn	lost Harmony Hub 2
                                harmony.0	2017-10-12 22:15:22.542	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
                                harmony.0	2017-10-12 22:15:15.535	info	connecting to Harmony Hub 2
                                harmony.0	2017-10-12 22:15:15.488	info	discovered Harmony Hub 2
                                harmony.0	2017-10-12 22:15:11.510	warn	error changing activity, client offline
                                harmony.0	2017-10-12 22:15:11.495	warn	error changing activity, client offline
                                harmony.0	2017-10-12 22:15:08.755	warn	lost Harmony Hub 2
                                harmony.0	2017-10-12 22:15:05.501	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
                                harmony.0	2017-10-12 22:14:58.495	info	connecting to Harmony Hub 2
                                harmony.0	2017-10-12 22:14:58.466	info	discovered Harmony Hub 2
                                Ich werde wieder auf die Powerlan WLAN-Spots switchen, da diese dichter dran sind. Leider wird das 5Ghz Netz nicht unterstützt, das wäre
                                noch mal eine Alternative gewesen.
                                  wendy2702W Offline
                                  Ui,
                                  15m mit Wänden dazwischen ist auch schon eine Hausnummer.
                                  Du hast nicht zufällig zum testen ein langes Kabel und einen Repeater den du mal als Access Point näher an den Hub bringen könntest?
                                    @Nabla:
                                    neben einem Devolo 1200+ Adapter. `
                                    Power-LAN taugt da IMHO gar nicht.
                                    @Nabla:
                                    Die Fritzbox steht auch rund 15 Meter und zwei Räume entfernt. `
                                    ich habe damals einen AP in direkter Sichtlinie 5 Meter von dem Harmony-Hub installieren müssen, damit es problemlos funktioniert.
                                    Die WLAN anbindung des Hubs ist grottenschlecht.
                                    • eric2905E Offline
                                      eric2905E Offline
                                      eric2905
                                      Ich habe per DLAN die ganze Verteilung im Haus und keine Probleme damit.
                                      Allerdings habe ich jeweils einen UniFi-Switch am DLAN-Modul und dann dahinter die Endgeräte und/oder die UniFi-APs.
                                      Gruß,
                                      Eric
                                      • N Offline
                                        N Offline
                                        Nabla
                                        Nach einem Neustart des Hub ist es wieder besser. Ich betreibe ihn nun weiterhin am Devolo DLAN-Adapter.
                                        Hatte jetzt nach 48h Stunden nur einen Reconnect. Vielleicht muss ich den Hub Abends mit vom Strom nehmen und
                                        morgens neu starten.
                                          wendy2702W Offline
                                          Gerade mal meine Logfiles der letzten 5 Tage durchsucht.
                                          Es gab einen restart bzw. reconnect weil ich am HUB gefummelt habe. Sonst scheint der Adapter bei mir gut zu laufen.
                                          Habe noch Version 0.7.0 installiert.
                                          Abstand Fritz AP <-> HUB ca. 2,50m
