  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • R RGT
    @arteck So sieht es im ioBroker als Objektliste aus: 2023-06-08 20_59_28-objects - raspberrypi.jpg
    Es gibt für jeden Tag ein "Verzeichnis" mit den Summenwerte des entsprechenden Tages.
    Unter "Tripinfo" steht dann die ANzahl der Fahrten, die sich aber nicht mehr einzeln darstellen lassen.
    Wenn ich die ankommenden Daten aus dem Debug-Log hole, kommen sie so an:
    driveHistory-Data: {
    "cumulated":[
    {"period":0,"consumption":{"total":46497,"engine":37691,"climate":3636,"devices":5170,"battery":0},"regen":17568,"distance":327},
    {"period":1,"consumption":{"total":6642,"engine":5384,"climate":519,"devices":738,"battery":0},"regen":2509,"distance":46.714285714285715},
    {"period":2,"consumption":{"total":8790,"engine":7235,"climate":805,"devices":750,"battery":0},"regen":3437,"distance":71}],
    "history":[
    {"period":0,"rawDate":"20230608","date":"2023-06-07T22:00:00.000Z","consumption":{"total":4783,"engine":3939,"climate":464,"devices":380,"battery":0},"regen":1589,"distance":36},
    {"period":0,"rawDate":"20230607","date":"2023-06-06T22:00:00.000Z","consumption":{"total":8995,"engine":7386,"climate":909,"devices":700,"battery":0},"regen":3368,"distance":70},
    {"period":0,"rawDate":"20230606","date":"2023-06-05T22:00:00.000Z","consumption":{"total":3951,"engine":2656,"climate":405,"devices":890,"battery":0},"regen":1616,"distance":22},
    {"period":0,"rawDate":"20230605","date":"2023-06-04T22:00:00.000Z","consumption":{"total":11185,"engine":9077,"climate":928,"devices":1180,"battery":0},"regen":4713,"distance":80},
    {"period":0,"rawDate":"20230603","date":"2023-06-02T22:00:00.000Z","consumption":{"total":2752,"engine":2124,"climate":198,"devices":430,"battery":0},"regen":1055,"distance":15},
    {"period":0,"rawDate":"20230602","date":"2023-06-01T22:00:00.000Z","consumption":{"total":10119,"engine":8505,"climate":614,"devices":1000,"battery":0},"regen":3939,"distance":74},
    {"period":0,"rawDate":"20230601","date":"2023-05-31T22:00:00.000Z","consumption":{"total":4712,"engine":4004,"climate":118,"devices":590,"battery":0},"regen":1288,"distance":30}]}
    Leider habe ich meinen Ionic erst eine Woche, daher werden nur Werte ab dem 1.6 übertragen.
    Wie weit es in die Vergangenheit zurückgeht, kann ich noch nicht sagen.
    Für den Status der 12V Batterie steht folgendes in den Objekten:
    Was wird noch gebraucht? Vielleicht kann ich helfen.
    LG RGT
    arteckA Offline
    arteckA Offline
    arteck
    #1152
    @rgt das bringt mich schon mal weiter.DANKE... muss bissel Gehirnschmalz investieren...
    • arteckA arteck
      @fredf ok.. und wie viele datumspunkte können da sein.. ?? wenn ich es jeden Tag bewege 7 Tage die Woche.. was steht dann da ?? nur der letzte Tag ??
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      #1153
      @arteck wie schon geschrieben: für jeden Tag seit der Adapter läuft und das Fahrzeug bewegt wurde gibt es einen Ordner. Das sind nach 9 Monaten schon sehr viele…
      • FredFF FredF
        arteckA Offline
        arteckA Offline
        arteck
        #1154
        @fredf ach du scheixxxx... ich dachte letzten 7 Tage oder so..aber.. ok vergiss es..:-)
        • arteckA arteck
          #1155
          @arteck
          Es gibt auf Git irgendwo n Tool, das bereitet das in ner excel Tabelle auf…
          Schau mal connect Monitor
          • arteckA Offline
            arteckA Offline
            arteck
            #1156
            adapter von GIT installieren.. da sollte jetzt für heute ein Datenpunkt entstehen
            es wird in den History Daten nach heutigem Datum gesucht und die Daten werden übernommen..
            wenn nix da ist.. also keine Fahrt erfolgte.. schreibe ich aber auch keine 0 Werte.
            ich kann es nicht testen.. bei meinem PHEV kommen da keine Daten
            • arteckA arteck
              @toki1973 wie kommst du drauf ?
              toki1973
              #1157
              @arteck said in Adapter Hyundai (Bluelink) oder KIA (UVO):
              Der Datenpunkt wurde seit 27.04. nicht mehr aktualisiert
              NUC, PROXMOX, Grafana, Influx, Unify
              • arteckA arteck
                toki1973
                #1158
                @arteck
                Ich habe das Update über GIT gemacht sehen aber noch kein Today Datenpunkt. Wird der soc-12V Status nciht mehr von Bluelink übermittelt?
                arteckA ? 2 Antworten Letzte Antwort
                • T toki1973
                  @arteck
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #1159
                  @toki1973 kein plan .. was fährst du ?? wie ist der adapter eingestellt .. ist die batterie 12V ausreichend geladen.. und und und
                  der today ordner entsteht erst an dem Tag wo das Datum passt.. also bist die nicht am 13.06 gefahren oder der adapter lief da nicht.. gibbet auch kein today..
                  soll ich es für dich umbenennen auf ... binichNURheutegefahrendatenpunkt
                  • R Offline
                    RGT
                    #1160
                    @arteck
                    Herzlichen Dank für deine Arbeit und den neuen Channel "today", der bei mir super funktioniert:
                    Darf ich eine Bitte / einen Wunsch äußern, ohne unverschämt zu wirken?
                    Leider habe ich noch keine Ahnung, wie ich es hier sonst einkippen kann. Im Prinzip in eine "Wunschliste".
                    Da du es hinbekommen hast, die Tagesdaten immer wieder in diesen einen Channel zu schreiben und ich/alle die Daten somit selber fortlaufend in eine DB schreiben können, habe ich damit automatisch die Historie.
                    Kannst du dann in den Einstellungen der Adapter-Instanz eine Checkbox einbauen, die den Download der Historie aus der Datenquelle (siehe Kontoeinstellungen) in den Adapter ausschaltet.
                    Die Historie wird ja nun nicht mehr als eigener Channel pro Tag benötigt.
                    Und wenn sie jemand haben möchte, um seine eigene in seiner DB nachzupflegen, kann er sie anschalten.
                    LG RGT
                    Ich bin zwar alt, aber lernfähig...
                    • R RGT
                      @arteck
                      LG RGT
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #1161
                      @rgt gute idee..mach ich..wird aber erst nächste Woche..
                      • T toki1973
                        @arteck
                        #1162
                        @toki1973
                        Hi, ich fahre einen Ioniq5 und da funktioniert der 12V Batterie Status und Wert einwandfrei.
                        Den Datenpunkt Today kommt bei mir aber auch nicht, ich fahre aber auch zur Zeit nicht jeden Tag..
                        Aktuelle Version von Git ist drauf.. js-controller 5.x Beta..
                        • arteckA arteck
                          #1163
                          @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                          ja, sehr gute Idee!
                          Eine History und geloggt mit Influx/SQL und da kann man es mit Grafana oder was auch immer auswerten...
                            @toki1973
                            toki1973
                            #1164
                            @ilovegym Habe das geleiche Fahrzeug. Nun bekomme ich den Today History Wert. Aber immer noch nicht eine Aktualisierung des 12V SOC.
                            • T toki1973
                              #1165
                              @toki1973
                              neueste Infotainmentsoftware haste drauf im Ioniq? ( seit heute gibts uebrigens das lang angekuendigte Fruehjahr-Update.. also den Navi-Update auf dem Windows Rechner anwerfen und runterladen oder auf OTA warten... )
                              Die 12V aktualisiert sich erst nach ca 20min fahren... oder wenn er am laden ist...
                              Heute ist auch bei mir der Datenpunkt Today aufgetaucht...
                              T Meister MopperM 2 Antworten Letzte Antwort
                                @toki1973
                                toki1973
                                #1166
                                @ilovegym
                                Danke für den Hinweis auf das Update :)
                                  @toki1973
                                  Meister MopperM Online
                                  Meister Mopper
                                  #1167
                                  @ilovegym sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  Da warte ich mal, bin gespannt, ob das ota auch wirklich funzt. Aber, da muss man, glaube ich, ein paar Kilometer schrubben, bis die Daten komplett über SIM-Karte übermittelt wurden.
                                  Proxmox und HA ...
                                  Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                                  • WinniW Offline
                                    WinniW Offline
                                    Winni
                                    #1168
                                    Auf ota warten dauert mir zu lange 😉. Habe gerade runter geladen und mittels usb-stick installiert. Lief problemlos durch.
                                    • G Offline
                                      g.polat
                                      #1169
                                      Ich habe gestern JS-Controller auf 5.0.3 geupdatet, seitdem läuft der Adapter bei mir nicht mehr :-(
                                      bluelink.0	2023-06-14 13:29:56.365	error	unhandled promise rejection: undefined is not a valid state value
                                      bluelink.0	2023-06-14 13:29:56.364	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      bluelink.0	2023-06-14 13:29:56.350	error	undefined is not a valid state value
                                      bluelink.0	2023-06-14 13:29:56.350	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5372:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5333:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:383:17) at async ae. (/opt/iobroker/node_modules/iobroker.bluelink/main.js:222:25)
                                      bluelink.0	2023-06-14 13:29:56.350	error	unhandled promise rejection: undefined is not a valid state value
                                      bluelink.0	2023-06-14 13:29:56.349	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      ? R 2 Antworten Letzte Antwort
                                      • G g.polat
                                        #1170
                                        @g-polat
                                        bei mir laeuft er seit 5.x Alpha problemlos... welche Node und NPM Version, welches BS ?
                                        dein Logauszug ist etwas kurz.. das wichtigste fehlt.. ( was vorher passiert und warum..)
                                        Bei so Sachen bitte immer den Adapter auf Debug stellen und das Log von Start an posten, da werden auch NPM usw mit angezeigt.
                                        G 1 Antwort Letzte Antwort
                                        • G g.polat
                                          RGT
                                          schrieb am zuletzt editiert von RGT
                                          #1171
                                          @g-polat
                                          Ich glaube nicht, dass es etwas mit der JS-Controllerversion zu tun hat.
                                          Irgendwie scheint die Aktualisierung des Adapters nicht zuverlässig alle Datenpunkte zu holen oder zu bekommen.
                                          So wurde zwar heute der Tachostand abgeholt, aber die "Today" bzw. Historie für Heute nicht, wobei die Fahrt länger als 20 Minuten und weiter als 30KM war.
                                          Nach einem Neustart des Instanz wurden dann alle Daten aktualisiert.
                                          Die Daten werden direkt vom Auto geholt und nicht vom Server.
                                          LG RGT
                                          R 1 Antwort Letzte Antwort
