  3. Einsteigerfragen
  4. Installation
  5. Raspi hängt sich 2x täglich auf
38 Beiträge 7 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • T Theophilus
    Heute nachmittag hat er sich nicht aufgehängt. War wohl Zufall, dass es gestern 2 Uhr und 14 Uhr war.
    Theophilus
    @theophilus Er bleibt bei. Alles läuft super, dann kommt dieser ominöse Neustart und der Raspi hängt sich auf.
    2023-06-05 07:17:15.426 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
    2023-06-05 07:17:15.439 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-06-05 07:17:15.441 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
    2023-06-05 07:17:15.443 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
    2023-06-05 07:17:19.097 - info: host.raspberrypi connected to Objects and States
    2023-06-05 07:17:19.194 - info: host.raspberrypi added notifications configuration of host
    2023-06-05 07:17:20.208 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2023-06-05 07:17:20.221 - info: host.raspberrypi 9 instances found
    2023-06-05 07:17:20.262 - info: host.raspberrypi starting 9 instances
    2023-06-05 07:17:20.399 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2023-06-05 07:17:20.436 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2023-06-05 07:17:20.475 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 632
    2023-06-05 07:17:20.509 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2023-06-05 07:17:20.543 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2023-06-05 07:17:20.617 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2023-06-05 07:17:20.646 - info: host.raspberrypi Some obsolete host states deleted.
    2023-06-05 07:17:24.495 - info: host.raspberrypi instance system.adapter.history.0 started with pid 639
    2023-06-05 07:17:25.903 - info: admin.0 (632) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-06-05 07:17:26.028 - info: admin.0 (632) requesting all states
    2023-06-05 07:17:26.030 - info: admin.0 (632) requesting all objects
    2023-06-05 07:17:28.610 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 666
    2023-06-05 07:17:29.621 - info: admin.0 (632) received all objects
    2023-06-05 07:17:30.198 - info: history.0 (639) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v18.16.0, js-controller: 4.0.24
    2023-06-05 07:17:30.369 - info: history.0 (639) enabled logging of 0_userdata.0.Solar.Solar_Aktuell (Count=1), Alias=false
    2023-06-05 07:17:30.372 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Aktuell (Count=2), Alias=false
    2023-06-05 07:17:30.375 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Total (Count=3), Alias=false
    2023-06-05 07:17:30.377 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Einspeisung_Total (Count=4), Alias=false
    2023-06-05 07:17:31.502 - info: admin.0 (632) Request actual repository...
    2023-06-05 07:17:31.655 - info: admin.0 (632) http server listening on port 8081
    2023-06-05 07:17:31.658 - info: admin.0 (632) Use link "http://localhost:8081" to configure.
    2023-06-05 07:17:31.703 - info: admin.0 (632) socket.io server listening on port 8081
    2023-06-05 07:17:33.587 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-06-05 07:17:33.770 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 681
    2023-06-05 07:17:35.155 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
    2023-06-05 07:17:35.438 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
    2023-06-05 07:17:36.396 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 688
    • T Theophilus
      @theophilus
      Schau in dein Journal.
        @theophilus
        Theophilus
        @thomas-braun Das Merkwürdige ist, dass die iobroker-Instanz zu dieser Zeit gestoppt war. Da ich in den nächsten Tagen viel unterwegs bin und sich der Raspi immer wieder aufhängt und mir dann über Tage hinweg die Stromdaten fehlen, war mein Plan, den Raspi jeweils um 2:00 Uhr nachts neu zu starten. 1.Versuch: per Cron-Job und wenn das nichts bringt, brutal per Zeitschaltuhr und kappen der Stromzufuhr.
        Heute nacht also Cronjob. Der hat geklappt (nur beim Reboot habe ich einen Fehler gemacht.) Journal:
        un 05 02:00:01 raspberrypi CRON[2510]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
        Jun 05 02:00:01 raspberrypi CRON[2511]: (root) CMD (iobroker stop)
        Jun 05 02:00:01 raspberrypi sudo[2516]:     root : PWD=/root ; USER=root ; COMMAND=/usr/bin/systemctl stop iobroker
        Jun 05 02:00:01 raspberrypi sudo[2516]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
        Jun 05 02:00:01 raspberrypi systemd[1]: Stopping ioBroker Server...
        Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
        Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
        Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
        Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
        Jun 05 02:00:06 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
        Jun 05 02:00:06 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
        Jun 05 02:00:06 raspberrypi systemd[1]: Stopped ioBroker Server.
        Jun 05 02:00:06 raspberrypi systemd[1]: iobroker.service: Consumed 38min 33.182s CPU time.
        Jun 05 02:00:06 raspberrypi sudo[2516]: pam_unix(sudo:session): session closed for user root
        Ju
        So ganz verstehe ich aber nicht, was die angezeigte Fehlermeldung bedeutet ...
        crunchipC Thomas BraunT 3 Antworten Letzte Antwort
        • T Theophilus
          Ju
          crunchipC Offline
          crunchipC Offline
          @theophilus sagte in Raspi hängt sich 2x täglich auf:
          das wäre ein dummer und tödlicher Prozess
          • T Theophilus
            Ju
            Welche?
            Und mit
            meinte ich natürlich den Zeitraum, wenn die Kiste rebootet.
            • T Theophilus
              Ju
              crunchipC Offline
              crunchipC Offline
              dann vllt auf die ein oder andere Instanz für den Zeitraum verzichten, z.b tuya
              bzw was läuft da alles?
              eine weitere Möglichkeit wäre, falls vorhanden, die backitup Instanz per script starten/stoppen und nur fürs backup laufen lassen
              letztendlich, sind aber mittlerweile 1GB Ram einfach zu wenig für die heutige Leistung eines iobroker`s
                Theophilus
                @crunchip sagte in Raspi hängt sich 2x täglich auf:
                Aber wenn der Raspi hängt und nicht mal mehr per ssh ansprechbar ist, bleibt mir eh nichts anderes übrig ...
                Deswegen der Gedanke: per cronjob iobroker runterfahren, shutdown für den Raspi, dann den Strom weg. Das ganze in der Nacht, wenn die Daten eh übersichtlich sind.
                Wenn alles läuft, dürfte das dem System nicht schaden, wenn er hängt, kann ich sowieso nichts anderes machen.
                Oder hast du eine bessere Idee?
                • T Theophilus
                  An die Ursachen herangehen.
                  Aber da dürfte schlicht und einfach der Arbeitsspeicher ausgehen.
                    Theophilus
                    @thomas-braun Ich habe jetzt mal den Swap-Speicher auf 1GB erhöht. Vielleicht bringt das was.
                    • T Theophilus
                      Theophilus
                      Das hat funktioniert. Der Raspi läuft jetzt seit 6 Tagen ohne Hänger.
                      • T Theophilus
                        @theophilus
                        Und wie schaut der Speicher nun aus?
                        free -ht --mega
                        • T Theophilus
                          HomoranH Offline
                          HomoranH Offline
                          @theophilus ist aber nicht die feine Art und kann weitere Probleme hervorbringen.
                          Der SWAP ist nur als kurzfristiger Notfallüberlauf für plötzlich ausgehenden RAM gedacht und daher üblicherweise sehr klein dimensioniert.
                          Du nutzst ihn aber als permanenten RAM-Ersatz.
                          Das was RAM ausmacht ist due Geschwindigkeit.
                          Jetzt wird sehr viel permanent auf die SD-Karte geschrieben.
                          Das kostet sehr viel Zeit und führt zu einem Anstieg der Load average.
                          Außerdem kostet es nach und nach Speicherzellen.
                            Theophilus
                            Mem:            909M        642M         87M        0.0K        178M        207M
                            Swap:           999M        338M        661M
                            Total:          1.9G        981M        749M
                              Theophilus
                              @homoran Das ist mir schon klar, aber was soll ich anders tun? Außer einen neuen Mikrocomputer kaufen ...
                              • T Theophilus
                                HomoranH Offline
                                HomoranH Offline
                                • T Theophilus
                                  Einen Rechner mit mehr RAM kaufen.
                                    @thomas-braun sagte in Raspi hängt sich 2x täglich auf:
                                    Moin,
                                    Zitat: Bill Gates
                                    „Niemand braucht mehr als 640kB RAM in seinem PC“
                                    Bernd
                                    Thomas BraunT T 2 Antworten Letzte Antwort
                                      Moin,
                                      Bernd
                                      @dp20eic
                                      Stimmt, 1280 dürfen es dann doch schon sein.
                                        Moin,
                                        Bernd
                                        Theophilus
                                        sabbel nicht - dat geiht!
                                        https://www.youtube.com/watch?v=GRIn8Yu7rU0&t=125s
