[gelöst] Neueres Docker Image fährt nicht hoch
Skript v.2023-04-16 *** BASE SYSTEM *** Architecture : x86_64 Docker : v8.0.0 Virtualization : Unknown (buanet/Synology?) Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 19:42:31 up 48 days, 7:10, 0 users, load average: 1.93, 1.47, 1.63 CPU threads: 2 *** Time and Time Zones *** Thu Jun 8 17:42:31 UTC 2023 Thu Jun 8 19:42:31 CEST 2023 CEST +0200 Etc/UTC *** User and Groups *** root /root root *** X-Server-Setup *** X-Server: false Desktop: Terminal: *** MEMORY *** total used free shared buff/cache available Mem: 17G 2.1G 4.8G 37M 10G 15G Swap: 12G 330M 12G Total: 30G 2.5G 17G 17836 M total memory 2125 M used memory 5996 M active memory 5949 M inactive memory 4775 M free memory 4715 M buffer memory 6219 M swap cache 12749 M total swap 330 M used swap 12418 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/vg1/volume_1 btrfs 3.5T 431G 3.1T 13% / tmpfs tmpfs 64M 0 64M 0% /dev tmpfs tmpfs 8.8G 0 8.8G 0% /sys/fs/cgroup shm tmpfs 64M 0 64M 0% /dev/shm /dev/vg1/volume_1 btrfs 3.5T 431G 3.1T 13% /opt/iobroker /dev/vg1/volume_1 btrfs 3.5T 431G 3.1T 13% /etc/hosts Messages concerning ext4 filesystem in dmesg: sudo: unable to resolve host buanet-iobroker: Name or service not known Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/vg1/volume_1[/@syno/@docker/btrfs/subvolumes/ee9e9513376c73a7ea62fdc6082e76a32a416b59ba0ec5debd9e42c11e7de99f] btrfs rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol id=1302,subvol=/@syno/@docker/btrfs/subvolumes/ee9e9513376c73a7ea62fdc6082e76a32a416b59ba0ec5debd9e42c11e7de99f |-/opt/iobroker /dev/vg1/volume_1[/@syno/docker/iobroker] btrfs rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol id=275,subvol=/@syno/docker/iobroker |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/resolv.co nf] btrfs rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/resolv.conf |-/etc/hostname /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hostname] btrfs rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hostname `-/etc/hosts /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hosts] btrfs rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hosts Files in neuralgic directories: /var: sudo: unable to resolve host buanet-iobroker: Name or service not known 33M /var/ 30M /var/lib 18M /var/lib/apt/lists 18M /var/lib/apt 13M /var/lib/dpkg /opt/iobroker/backups: 58M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 340M /opt/iobroker/iobroker-data/ 253M /opt/iobroker/iobroker-data/files 72M /opt/iobroker/iobroker-data/files/telegram.admin 71M /opt/iobroker/iobroker-data/backup-objects 51M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map 15M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_pa rseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map 14M /opt/iobroker/iobroker-data/objects.jsonl 8.2M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js 7.2M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_pa rseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js *** NodeJS-Installation *** /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.0-deb-1nodesource1 Candidate: 18.16.0-deb-1nodesource1 Version table: *** 18.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://deb.debian.org/debian bullseye/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 3 Adapter State + system.adapter.admin.0 : admin : buanet-iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : buanet-iobroker - enabled system.adapter.alias-manager.0 : alias-manager : buanet-iobroker - enabled system.adapter.awtrix-light.0 : awtrix-light : buanet-iobroker - enabled + system.adapter.backitup.0 : backitup : buanet-iobroker - enabled system.adapter.bidirectional-counter.0 : bidirectional-counter : buanet-iobroker - enabled system.adapter.birthdays.0 : birthdays : buanet-iobroker - enabled system.adapter.cloud.0 : cloud : buanet-iobroker - enabled system.adapter.device-reminder.0 : device-reminder : buanet-iobroker - enabled + system.adapter.discovery.0 : discovery : buanet-iobroker - enabled system.adapter.drag-indicator.0 : drag-indicator : buanet-iobroker - enabled system.adapter.energiefluss.0 : energiefluss : buanet-iobroker - enabled system.adapter.energiefluss.1 : energiefluss : buanet-iobroker - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : buanet-iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : buanet-iobroker - enabled system.adapter.go-e.0 : go-e : buanet-iobroker - disabled system.adapter.heizoel.0 : heizoel : buanet-iobroker - disabled system.adapter.ical.0 : ical : buanet-iobroker - enabled system.adapter.icons-material-svg.0 : icons-material-svg : buanet-iobroker - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : buanet-iobroker - enabled + system.adapter.influxdb.0 : influxdb : buanet-iobroker - enabled, port: 8086 system.adapter.iot.0 : iot : buanet-iobroker - enabled system.adapter.janitza-gridvis.0 : janitza-gridvis : buanet-iobroker - enabled, port: 8080 + system.adapter.javascript.0 : javascript : buanet-iobroker - enabled system.adapter.lowpass-filter.0 : lowpass-filter : buanet-iobroker - enabled + system.adapter.modbus.0 : modbus : buanet-iobroker - enabled + system.adapter.modbus.1 : modbus : buanet-iobroker - enabled + system.adapter.modbus.2 : modbus : buanet-iobroker - enabled + system.adapter.modbus.3 : modbus : buanet-iobroker - enabled system.adapter.mqtt.0 : mqtt : buanet-iobroker - disabled, port: 1883, bind: 0.0.0.0 system.adapter.operating-hours.0 : operating-hours : buanet-iobroker - enabled + system.adapter.shelly.0 : shelly : buanet-iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : buanet-iobroker - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : buanet-iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: restuser + system.adapter.telegram.0 : telegram : buanet-iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.trashschedule.0 : trashschedule : buanet-iobroker - enabled system.adapter.vis-icontwo.0 : vis-icontwo : buanet-iobroker - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : buanet-iobroker - enabled system.adapter.vis-justgage.0 : vis-justgage : buanet-iobroker - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : buanet-iobroker - enabled system.adapter.vis.0 : vis : buanet-iobroker - enabled system.adapter.weatherunderground.0 : weatherunderground : buanet-iobroker - enabled + system.adapter.web.0 : web : buanet-iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.yahka.0 : yahka : buanet-iobroker - enabled + system.adapter.zigbee.0 : zigbee : buanet-iobroker - enabled, port: tcp://192.168.2.40:20108 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : buanet-iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : buanet-iobroker - enabled, port: 8086 system.adapter.janitza-gridvis.0 : janitza-gridvis : buanet-iobroker - enabled, port: 8080 + system.adapter.shelly.0 : shelly : buanet-iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : buanet-iobroker - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : buanet-iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: restuser + system.adapter.telegram.0 : telegram : buanet-iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : buanet-iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : buanet-iobroker - enabled, port: tcp://192.168.2.40:20108 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alexa2" : 3.23.2 , installed 3.23.2 Adapter "alias-manager": 1.2.4 , installed 1.2.4 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "bidirectional-counter": 2.1.0, installed 2.1.0 Adapter "birthdays" : 2.2.0 , installed 2.2.0 Adapter "cloud" : 4.3.0 , installed 4.4.1 Adapter "device-reminder": 1.2.9 , installed 1.2.9 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "drag-indicator": 2.1.0 , installed 2.1.0 Adapter "fb-checkpresence": 1.1.26, installed 1.1.26 Adapter "fritzdect" : 2.2.6 , installed 2.3.1 Adapter "go-e" : 1.0.27 , installed 1.0.27 Adapter "heizoel" : 1.0.3 , installed 1.0.3 Adapter "ical" : 1.13.2 , installed 1.13.2 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "iot" : 1.14.2 , installed 1.14.5 Adapter "janitza-gridvis": 3.1.2 , installed 3.1.2 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "lowpass-filter": 2.2.1 , installed 2.2.1 Adapter "modbus" : 5.0.11 , installed 5.0.11 Adapter "mqtt" : 4.0.7 , installed 4.0.7 Adapter "operating-hours": 1.0.1 , installed 1.0.1 Adapter "shelly" : 6.3.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "telegram" : 1.15.2 , installed 1.15.2 Adapter "trashschedule": 2.2.0 , installed 2.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-icontwo" : 0.93.0 , installed 0.93.0 Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-material-advanced": 1.7.2, installed 1.7.2 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "yahka" : 0.17.0 , installed 0.17.0 Adapter "zigbee" : 1.8.10 , installed 1.8.10 Objects and States Please stand by - This may take a while Objects: 9062 States: 7420 *** OS-Repositories and Updates *** sudo: unable to resolve host buanet-iobroker: Name or service not known sudo: unable to resolve host buanet-iobroker: Name or service not known Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists... Pending Updates: 33 *** Listening Ports *** sudo: unable to resolve host buanet-iobroker: Name or service not known Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:10502 0.0.0.0:* LISTEN 1000 348577658 277/io.modbus.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1000 348576391 141/iobroker.js-con tcp 0 0 192.168.2.80:49160 0.0.0.0:* LISTEN 0 73764 - tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 0 35534 - tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1000 348576384 141/iobroker.js-con tcp 0 0 0.0.0.0:5001 0.0.0.0:* LISTEN 0 35536 - tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 67621883 - tcp 0 0 0.0.0.0:5357 0.0.0.0:* LISTEN 0 67622274 - tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 35538 - tcp 0 0 192.168.2.80:50001 0.0.0.0:* LISTEN 0 71312 - tcp 0 0 0.0.0.0:9010 0.0.0.0:* LISTEN 0 345103681 - tcp 0 0 0.0.0.0:50002 0.0.0.0:* LISTEN 0 71653 - tcp 0 0 127.0.0.1:915 0.0.0.0:* LISTEN 0 68478 - tcp 0 0 0.0.0.0:3000 0.0.0.0:* LISTEN 1026 27940193 - tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 55 59666 - tcp 0 0 127.0.0.1:18617 0.0.0.0:* LISTEN 0 73793 - cp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1000 348581831 453/io.shelly.1 tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 35540 - tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 67621882 - tcp 0 0 0.0.0.0:1502 0.0.0.0:* LISTEN 1000 348581514 425/io.modbus.3 tcp 0 0 127.0.0.1:512 0.0.0.0:* LISTEN 0 105309 - tcp 0 0 127.0.0.1:161 0.0.0.0:* LISTEN 0 34386 - tcp 0 0 0.0.0.0:3010 0.0.0.0:* LISTEN 0 339069213 - tcp6 0 0 :::5000 :::* LISTEN 0 35535 - tcp6 0 0 :::5001 :::* LISTEN 0 35537 - tcp6 0 0 :::139 :::* LISTEN 0 67621881 - tcp6 0 0 :::5357 :::* LISTEN 0 67622275 - tcp6 0 0 :::80 :::* LISTEN 0 35539 - tcp6 0 0 :::8081 :::* LISTEN 1000 348576577 162/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1000 348583777 608/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 1000 337736385 - tcp6 0 0 :::8087 :::* LISTEN 1000 348589784 1204/io.simple-api. tcp6 0 0 :::443 :::* LISTEN 0 35541 - tcp6 0 0 :::445 :::* LISTEN 0 67621880 - tcp6 0 0 :::3261 :::* LISTEN 0 38364 - tcp6 0 0 :::3263 :::* LISTEN 0 38361 - tcp6 0 0 :::3264 :::* LISTEN 0 38366 - tcp6 0 0 :::3265 :::* LISTEN 0 40919 - udp 0 0 0.0.0.0:68 0.0.0.0:* 0 20748 - udp 0 0 172.17.0.1:123 0.0.0.0:* 87 281848115 - udp 0 0 192.168.2.80:123 0.0.0.0:* 87 27816 - udp 0 0 127.0.0.1:123 0.0.0.0:* 0 22171 - udp 0 0 0.0.0.0:123 0.0.0.0:* 0 22167 - udp 0 0 192.168.2.255:137 0.0.0.0:* 0 256301103 - udp 0 0 192.168.2.80:137 0.0.0.0:* 0 256301102 - udp 0 0 0.0.0.0:137 0.0.0.0:* 0 256301070 - udp 0 0 192.168.2.255:138 0.0.0.0:* 0 256301105 - udp 0 0 192.168.2.80:138 0.0.0.0:* 0 256301104 - udp 0 0 0.0.0.0:138 0.0.0.0:* 0 256301071 - udp 0 0 127.0.0.1:161 0.0.0.0:* 0 34385 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 73767 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 71315 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 66885 - udp 0 0 127.0.0.1:51112 0.0.0.0:* 0 71313 - udp 0 0 0.0.0.0:3702 0.0.0.0:* 99 67622113 - udp 0 0 0.0.0.0:5353 0.0.0.0:* 0 131011834 - udp 0 0 0.0.0.0:5683 0.0.0.0:* 1000 348577499 262/io.shelly.0 udp 0 0 127.0.0.1:55884 0.0.0.0:* 0 73765 - udp 0 0 192.168.2.80:55900 0.0.0.0:* 0 71314 - udp 0 0 192.168.2.80:55901 0.0.0.0:* 0 73766 - udp 0 0 0.0.0.0:57403 0.0.0.0:* 0 131011836 - udp 0 0 0.0.0.0:9997 0.0.0.0:* 0 22233 - udp 0 0 0.0.0.0:9998 0.0.0.0:* 0 22232 - udp 0 0 0.0.0.0:9999 0.0.0.0:* 0 22231 - udp6 0 0 fe80::101b:1eff:fe6:123 :::* 87 345104746 - udp6 0 0 fe80::1cd5:fff:feca:123 :::* 87 339069787 - cp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1000 348581831 453/io.shelly.1 tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 35540 - tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 67621882 - tcp 0 0 0.0.0.0:1502 0.0.0.0:* LISTEN 1000 348581514 425/io.modbus.3 tcp 0 0 127.0.0.1:512 0.0.0.0:* LISTEN 0 105309 - tcp 0 0 127.0.0.1:161 0.0.0.0:* LISTEN 0 34386 - tcp 0 0 0.0.0.0:3010 0.0.0.0:* LISTEN 0 339069213 - tcp6 0 0 :::5000 :::* LISTEN 0 35535 - tcp6 0 0 :::5001 :::* LISTEN 0 35537 - tcp6 0 0 :::139 :::* LISTEN 0 67621881 - tcp6 0 0 :::5357 :::* LISTEN 0 67622275 - tcp6 0 0 :::80 :::* LISTEN 0 35539 - tcp6 0 0 :::8081 :::* LISTEN 1000 348576577 162/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1000 348583777 608/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 1000 337736385 - tcp6 0 0 :::8087 :::* LISTEN 1000 348589784 1204/io.simple-api. tcp6 0 0 :::443 :::* LISTEN 0 35541 - tcp6 0 0 :::445 :::* LISTEN 0 67621880 - tcp6 0 0 :::3261 :::* LISTEN 0 38364 - tcp6 0 0 :::3263 :::* LISTEN 0 38361 - tcp6 0 0 :::3264 :::* LISTEN 0 38366 - tcp6 0 0 :::3265 :::* LISTEN 0 40919 - udp 0 0 0.0.0.0:68 0.0.0.0:* 0 20748 - udp 0 0 172.17.0.1:123 0.0.0.0:* 87 281848115 - udp 0 0 192.168.2.80:123 0.0.0.0:* 87 27816 - udp 0 0 127.0.0.1:123 0.0.0.0:* 0 22171 - udp 0 0 0.0.0.0:123 0.0.0.0:* 0 22167 - udp 0 0 192.168.2.255:137 0.0.0.0:* 0 256301103 - udp 0 0 192.168.2.80:137 0.0.0.0:* 0 256301102 - udp 0 0 0.0.0.0:137 0.0.0.0:* 0 256301070 - udp 0 0 192.168.2.255:138 0.0.0.0:* 0 256301105 - udp 0 0 192.168.2.80:138 0.0.0.0:* 0 256301104 - udp 0 0 0.0.0.0:138 0.0.0.0:* 0 256301071 - udp 0 0 127.0.0.1:161 0.0.0.0:* 0 34385 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 73767 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 71315 - udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 66885 - udp 0 0 127.0.0.1:51112 0.0.0.0:* 0 71313 - udp 0 0 0.0.0.0:3702 0.0.0.0:* 99 67622113 - udp 0 0 0.0.0.0:5353 0.0.0.0:* 0 131011834 - udp 0 0 0.0.0.0:5683 0.0.0.0:* 1000 348577499 262/io.shelly.0 udp 0 0 127.0.0.1:55884 0.0.0.0:* 0 73765 - udp 0 0 192.168.2.80:55900 0.0.0.0:* 0 71314 - udp 0 0 192.168.2.80:55901 0.0.0.0:* 0 73766 - udp 0 0 0.0.0.0:57403 0.0.0.0:* 0 131011836 - udp 0 0 0.0.0.0:9997 0.0.0.0:* 0 22233 - udp 0 0 0.0.0.0:9998 0.0.0.0:* 0 22232 - udp 0 0 0.0.0.0:9999 0.0.0.0:* 0 22231 - udp6 0 0 fe80::101b:1eff:fe6:123 :::* 87 345104746 - udp6 0 0 fe80::1cd5:fff:feca:123 :::* 87 339069787 - udp6 0 0 fe80::42:4bff:fed1::123 :::* 87 281848120 - udp6 0 0 2003:c0:bf41:1000:2:123 :::* 87 255558829 - udp6 0 0 fe80::211:32ff:fef8:123 :::* 87 34930 - udp6 0 0 ::1:123 :::* 0 22173 - udp6 0 0 :::123 :::* 0 22164 - udp6 0 0 :::35886 :::* 0 131011837 - udp6 0 0 :::3702 :::* 99 67622115 - udp6 0 0 :::5353 :::* 0 131011835 - *** Log File - Last 25 Lines *** 2023-06-08 19:42:56.632 - info: fritzdect.0 (748) going over to cyclic polling, messages to poll activity only in debug-mode 2023-06-08 19:42:56.665 - info: lowpass-filter.0 (791) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.lowpass-filter, node: v18.16.0, js-controller: 4.0.24 2023-06-08 19:42:57.036 - info: alexa2.0 (311) Subscribing to states... 2023-06-08 19:42:57.039 - info: alexa2.0 (311) Deleting the following states: ["Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c","Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.#enabled" ,"Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.#delete","Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.powerState"] 2023-06-08 19:42:58.988 - info: alexa2.0 (311) Alexa-Push-Connection (macDms = true) established. Disable Polling 2023-06-08 19:42:59.450 - info: host.buanet-iobroker instance system.adapter.trashschedule.0 started with pid 832 2023-06-08 19:43:00.861 - info: trashschedule.0 (832) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.16.0, js-controller: 4.0.24 2023-06-08 19:43:01.202 - info: trashschedule.0 (832) [ical] configurured ical preview is 30 days - increase this value to find more events in the future 2023-06-08 19:43:03.405 - info: host.buanet-iobroker instance scheduled system.adapter.birthdays.0 0 0 * * * 2023-06-08 19:43:03.429 - info: host.buanet-iobroker instance system.adapter.birthdays.0 started with pid 864 2023-06-08 19:43:04.807 - info: birthdays.0 (864) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.birthdays, node: v18.16.0, js-controller: 4.0.24 2023-06-08 19:43:05.848 - info: birthdays.0 (864) Terminated (NO_ERROR): Without reason 2023-06-08 19:43:06.392 - info: host.buanet-iobroker instance system.adapter.birthdays.0 terminated with code 0 (NO_ERROR) 2023-06-08 19:43:07.435 - info: host.buanet-iobroker instance system.adapter.device-reminder.0 started with pid 908 2023-06-08 19:43:08.729 - info: device-reminder.0 (908) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.16.0, js-controller: 4.0.24 2023-06-08 19:43:08.823 - info: device-reminder.0 (908) Device "Waschmaschine" was successfully created 2023-06-08 19:43:08.976 - info: device-reminder.0 (908) Device "Trockner" was successfully created 2023-06-08 19:43:11.428 - info: host.buanet-iobroker instance system.adapter.simple-api.0 started with pid 1204 2023-06-08 19:43:12.831 - info: simple-api.0 (1204) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24 2023-06-08 19:43:12.854 - info: simple-api.0 (1204) simpleAPI server listening on port 8087 2023-06-08 19:43:12.855 - info: simple-api.0 (1204) Allow states only when user is owner: true 2023-06-08 19:43:12.869 - info: simple-api.0 (1204) http server listening on port 8087 2023-06-08 19:43:12.973 - info: alexa2.0 (311) Initialization Done ... 2023-06-08 19:43:15.430 - info: host.buanet-iobroker instance system.adapter.bidirectional-counter.0 started with pid 1523 2023-06-08 19:43:16.649 - info: bidirectional-counter.0 (1523) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.bidirectional-counter, node: v18.16.0, js-controller: 4.0.24 ============ Mark until here for C&P =============
So müsste es stimmen
@ben1983 der Herr Root
@djmarc75 sagte in Neueres Docker Image fährt nicht hoch:
Alles gut ... ist OK so .
@ben1983 sagte in Neueres Docker Image fährt nicht hoch:
Ich habe eine DS220+ auf dem docker läuft. -
@glasfaser Das bedeutet?
Sollte jetzt mit dem andern image auch gehen?Ps. woran sieht man dass alles gut ist?
@glasfaser sagte in Neueres Docker Image fährt nicht hoch:
ist OK so .
also in diesem Docker ist das so ok ? Also Root ?
Sieht auf dem ersten Blick , alles gut aus .
das ist auch gut ... da können auch Fehler sonst kommen , aber du nutzt ja TCP
Also .. versuche es morgen mal , so wie beschrieben !
Beenden, dann versuchen, oder erst neu starten?
Ja schon mehere mal hier durchgekaut
Sorry ...
https://github.com/buanet/ioBroker.docker/blob/main/debian/scripts/iobroker_startup.sh
@glasfaser weil die uid und die gid auf 1000 stehen? oder wie?
@glasfaserBeenden, dann versuchen, oder erst neu starten?
Was möchest du jetzt !?
@ben1983Da sollte eigentlich mehr kommen ...
keine Ahnung gerade was da jetzt so hängt .
Alle Docker Container die du so hast mal stoppen , dann starte die Syn mal neu , erstelle einen neuen iobroker Container ... dann das Verzeichniss mounten .
Was ist dann ..
Dann schreibst du :
@glasfaser Versuche ich spätestens morgen. muss jetzt erst mal was anderes machen. Melde mich wieder
Was denn jetzt !????
@djmarc75
Achtung Outing: Ich lege mir nicht jedes mal, wenn ich ein neues Docker Image baue einen Standarduser an...
...ich weiss gar nicht, wann ich das letzte mal die Konsole genutzt habe... -
Das war nicht für dich !!!!
Bitte die Finger von lassen
@glasfaser Ich meinte, ob ich dann morgen erst die container beenden soll und vor dem neustart der ds nochmal einen versuch mit dem neuen image machen soll, oder ob ich die erst neu starten soll?
Die container dann nicht mit starten lassen, oder?
Also ich habe gestern portainer drauf gemacht nur zur Info, falls das was ausmachen könnte.
So wie geschrieben :
darauf achten das der Autostart nicht aktiv ist
@glasfaser OK, ich werde morgen berichten
@glasfaser Es schein zu funktionieren.
Aber es war das gleiche Bild we gestern. ich habe ih nun einfach mal so laufen lassen (den Container)
und irgendwann ging es weiter.
Es lag also wirklich an der Zeit.
Danke für die Tips und jetzt weiß ich auch den fix. -
Sehr Interessant , sollte eigentlich nicht so sein , nach Step 1
Bitte poste noch das DEBUG Log , nach :
----- Step 1 of 5: Preparing container -----
@glasfaser Wahrscheinlich musste man wirklich einfach etwas warten.
Wenn er es jetzt das erste mal durchlaufen hat, geht es so schnell wie immer...
ganz normal jetzt. kann es sein, dass beim ersten durchlauf länger braucht, weil er die vorhandene installation schon kennt? -
Bitte dazu das DEBUG Log .. von dieser Installation !
@glasfaser Sorry, bin nicht vor Ort und kann jetzt den Container nicht neu starten.
Aber es geht ja jetzt normal fix.
Dernke das war wirklich das warten.. hat heute morgen ca. 4 min an step 1 gedauert.
