  4. [gelöst] Neueres Docker Image fährt nicht hoch
    5.4k
52 Beiträge 4 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • Ben1983B Ben1983
    @glasfaser
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : v8.0.0
    Virtualization  : Unknown (buanet/Synology?)
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:42:31 up 48 days,  7:10,  0 users,  load average: 1.93, 1.47, 1.63
    CPU threads: 2
    *** Time and Time Zones ***
    Thu Jun  8 17:42:31 UTC 2023
    Thu Jun  8 19:42:31 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             17G        2.1G        4.8G         37M         10G         15G
    Swap:            12G        330M         12G
    Total:           30G        2.5G         17G
            17836 M total memory
             2125 M used memory
             5996 M active memory
             5949 M inactive memory
             4775 M free memory
             4715 M buffer memory
             6219 M swap cache
            12749 M total swap
              330 M used swap
            12418 M free swap
    *** FILESYSTEM ***
    Filesystem        Type   Size  Used Avail Use% Mounted on
    /dev/vg1/volume_1 btrfs  3.5T  431G  3.1T  13% /
    tmpfs             tmpfs   64M     0   64M   0% /dev
    tmpfs             tmpfs  8.8G     0  8.8G   0% /sys/fs/cgroup
    shm               tmpfs   64M     0   64M   0% /dev/shm
    /dev/vg1/volume_1 btrfs  3.5T  431G  3.1T  13% /opt/iobroker
    /dev/vg1/volume_1 btrfs  3.5T  431G  3.1T  13% /etc/hosts
    sudo: unable to resolve host buanet-iobroker: Name or service not known
    TARGET             SOURCE
        FSTYPE OPTIONS
    /                  /dev/vg1/volume_1[/@syno/@docker/btrfs/subvolumes/ee9e9513376c73a7ea62fdc6082e76a32a416b59ba0ec5debd9e42c11e7de99f]
        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol
    id=1302,subvol=/@syno/@docker/btrfs/subvolumes/ee9e9513376c73a7ea62fdc6082e76a32a416b59ba0ec5debd9e42c11e7de99f
    |-/opt/iobroker    /dev/vg1/volume_1[/@syno/docker/iobroker]
    id=275,subvol=/@syno/docker/iobroker
    |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/resolv.co
    nf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvol
    id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/resolv.conf
    |-/etc/hostname    /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hostname]
    id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hostname
    `-/etc/hosts       /dev/vg1/volume_1[/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hosts]
    id=256,subvol=/@syno/@docker/containers/2b8b7db9bd4243bf9a6f8cd3f8431b7b96d185365b1d6606093834f103a09b8a/hosts
    /var:
    33M     /var/
    30M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    58M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    340M    /opt/iobroker/iobroker-data/
    253M    /opt/iobroker/iobroker-data/files
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    71M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_pa
    rseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_pa
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : buanet-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : buanet-iobroker                          -  enabled
      system.adapter.alias-manager.0          : alias-manager         : buanet-iobroker                          -  enabled
      system.adapter.awtrix-light.0           : awtrix-light          : buanet-iobroker                          -  enabled
    + system.adapter.backitup.0               : backitup              : buanet-iobroker                          -  enabled
      system.adapter.bidirectional-counter.0  : bidirectional-counter : buanet-iobroker                          -  enabled
      system.adapter.birthdays.0              : birthdays             : buanet-iobroker                          -  enabled
      system.adapter.cloud.0                  : cloud                 : buanet-iobroker                          -  enabled
      system.adapter.device-reminder.0        : device-reminder       : buanet-iobroker                          -  enabled
    + system.adapter.discovery.0              : discovery             : buanet-iobroker                          -  enabled
      system.adapter.drag-indicator.0         : drag-indicator        : buanet-iobroker                          -  enabled
      system.adapter.energiefluss.0           : energiefluss          : buanet-iobroker                          -  enabled
      system.adapter.energiefluss.1           : energiefluss          : buanet-iobroker                          -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : buanet-iobroker                          -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : buanet-iobroker                          -  enabled
      system.adapter.go-e.0                   : go-e                  : buanet-iobroker                          - disabled
      system.adapter.heizoel.0                : heizoel               : buanet-iobroker                          - disabled
      system.adapter.ical.0                   : ical                  : buanet-iobroker                          -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : buanet-iobroker                          -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : buanet-iobroker                          -  enabled
    + system.adapter.influxdb.0               : influxdb              : buanet-iobroker                          -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : buanet-iobroker                          -  enabled
      system.adapter.janitza-gridvis.0        : janitza-gridvis       : buanet-iobroker                          -  enabled, port: 8080
    + system.adapter.javascript.0             : javascript            : buanet-iobroker                          -  enabled
      system.adapter.lowpass-filter.0         : lowpass-filter        : buanet-iobroker                          -  enabled
    + system.adapter.modbus.0                 : modbus                : buanet-iobroker                          -  enabled
    + system.adapter.modbus.1                 : modbus                : buanet-iobroker                          -  enabled
    + system.adapter.modbus.2                 : modbus                : buanet-iobroker                          -  enabled
    + system.adapter.modbus.3                 : modbus                : buanet-iobroker                          -  enabled
      system.adapter.mqtt.0                   : mqtt                  : buanet-iobroker                          - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.operating-hours.0        : operating-hours       : buanet-iobroker                          -  enabled
    + system.adapter.shelly.0                 : shelly                : buanet-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : buanet-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : buanet-iobroker                          -  enabled, port: 8087, bind: 0.0.0.0, run as: restuser
    + system.adapter.telegram.0               : telegram              : buanet-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.trashschedule.0          : trashschedule         : buanet-iobroker                          -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : buanet-iobroker                          -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : buanet-iobroker                          -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : buanet-iobroker                          -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : buanet-iobroker                          -  enabled
      system.adapter.vis.0                    : vis                   : buanet-iobroker                          -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : buanet-iobroker                          -  enabled
    + system.adapter.web.0                    : web                   : buanet-iobroker                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : buanet-iobroker                          -  enabled
    + system.adapter.zigbee.0                 : zigbee                : buanet-iobroker                          -  enabled, port: tcp://192.168.2.40:20108
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "bidirectional-counter": 2.1.0, installed 2.1.0
    Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
    Adapter    "cloud"        : 4.3.0    , installed 4.4.1
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "fritzdect"    : 2.2.6    , installed 2.3.1
    Adapter    "go-e"         : 1.0.27   , installed 1.0.27
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "iot"          : 1.14.2   , installed 1.14.5
    Adapter    "janitza-gridvis": 3.1.2  , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "lowpass-filter": 2.2.1   , installed 2.2.1
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "operating-hours": 1.0.1  , installed 1.0.1
    Adapter    "shelly"       : 6.3.1    , installed 6.4.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        9062
    States:         7420
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 33
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:10502           0.0.0.0:*               LISTEN      1000       348577658  277/io.modbus.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       348576391  141/iobroker.js-con
    tcp        0      0 192.168.2.80:49160      0.0.0.0:*               LISTEN      0          73764      -
    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          35534      -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       348576384  141/iobroker.js-con
    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          35536      -
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          67621883   -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          67622274   -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          35538      -
    tcp        0      0 192.168.2.80:50001      0.0.0.0:*               LISTEN      0          71312      -
    tcp        0      0 0.0.0.0:9010            0.0.0.0:*               LISTEN      0          345103681  -
    tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN      0          71653      -
    tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          68478      -
    tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      1026       27940193   -
    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         59666      -
    tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN      0          73793      -
    cp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       348581831  453/io.shelly.1
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          35540      -
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          67621882   -
    tcp        0      0 0.0.0.0:1502            0.0.0.0:*               LISTEN      1000       348581514  425/io.modbus.3
    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          105309     -
    tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          34386      -
    tcp        0      0 0.0.0.0:3010            0.0.0.0:*               LISTEN      0          339069213  -
    tcp6       0      0 :::5000                 :::*                    LISTEN      0          35535      -
    tcp6       0      0 :::5001                 :::*                    LISTEN      0          35537      -
    tcp6       0      0 :::139                  :::*                    LISTEN      0          67621881   -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          67622275   -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          35539      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       348576577  162/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       348583777  608/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      1000       337736385  -
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       348589784  1204/io.simple-api.
    tcp6       0      0 :::443                  :::*                    LISTEN      0          35541      -
    tcp6       0      0 :::445                  :::*                    LISTEN      0          67621880   -
    tcp6       0      0 :::3261                 :::*                    LISTEN      0          38364      -
    tcp6       0      0 :::3263                 :::*                    LISTEN      0          38361      -
    tcp6       0      0 :::3264                 :::*                    LISTEN      0          38366      -
    tcp6       0      0 :::3265                 :::*                    LISTEN      0          40919      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20748      -
    udp        0      0 172.17.0.1:123          0.0.0.0:*                           87         281848115  -
    udp        0      0 192.168.2.80:123        0.0.0.0:*                           87         27816      -
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          22171      -
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          22167      -
    udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          256301103  -
    udp        0      0 192.168.2.80:137        0.0.0.0:*                           0          256301102  -
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          256301070  -
    udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          256301105  -
    udp        0      0 192.168.2.80:138        0.0.0.0:*                           0          256301104  -
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          256301071  -
    udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          34385      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          73767      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          71315      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          66885      -
    udp        0      0 127.0.0.1:51112         0.0.0.0:*                           0          71313      -
    udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         67622113   -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          131011834  -
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       348577499  262/io.shelly.0
    udp        0      0 127.0.0.1:55884         0.0.0.0:*                           0          73765      -
    udp        0      0 192.168.2.80:55900      0.0.0.0:*                           0          71314      -
    udp        0      0 192.168.2.80:55901      0.0.0.0:*                           0          73766      -
    udp        0      0 0.0.0.0:57403           0.0.0.0:*                           0          131011836  -
    udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          22233      -
    udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          22232      -
    udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          22231      -
    udp6       0      0 fe80::101b:1eff:fe6:123 :::*                                87         345104746  -
    udp6       0      0 fe80::1cd5:fff:feca:123 :::*                                87         339069787  -
    udp6       0      0 fe80::42:4bff:fed1::123 :::*                                87         281848120  -
    udp6       0      0 2003:c0:bf41:1000:2:123 :::*                                87         255558829  -
    udp6       0      0 fe80::211:32ff:fef8:123 :::*                                87         34930      -
    udp6       0      0 ::1:123                 :::*                                0          22173      -
    udp6       0      0 :::123                  :::*                                0          22164      -
    udp6       0      0 :::35886                :::*                                0          131011837  -
    udp6       0      0 :::3702                 :::*                                99         67622115   -
    udp6       0      0 :::5353                 :::*                                0          131011835  -
    2023-06-08 19:42:56.632  - info: fritzdect.0 (748) going over to cyclic polling, messages to poll activity only in debug-mode
    2023-06-08 19:42:56.665  - info: lowpass-filter.0 (791) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.lowpass-filter, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:42:57.036  - info: alexa2.0 (311) Subscribing to states...
    2023-06-08 19:42:57.039  - info: alexa2.0 (311) Deleting the following states: ["Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c","Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.#enabled"
    ,"Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.#delete","Smart-Home-Devices.64194aec-81f6-41be-a2c5-770937bdfa6c.powerState"]
    2023-06-08 19:42:58.988  - info: alexa2.0 (311) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-06-08 19:42:59.450  - info: host.buanet-iobroker instance system.adapter.trashschedule.0 started with pid 832
    2023-06-08 19:43:00.861  - info: trashschedule.0 (832) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:01.202  - info: trashschedule.0 (832) [ical] configurured ical preview is 30 days - increase this value to find more events in the future
    2023-06-08 19:43:03.405  - info: host.buanet-iobroker instance scheduled system.adapter.birthdays.0 0 0 * * *
    2023-06-08 19:43:03.429  - info: host.buanet-iobroker instance system.adapter.birthdays.0 started with pid 864
    2023-06-08 19:43:04.807  - info: birthdays.0 (864) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.birthdays, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:05.848  - info: birthdays.0 (864) Terminated (NO_ERROR): Without reason
    2023-06-08 19:43:06.392  - info: host.buanet-iobroker instance system.adapter.birthdays.0 terminated with code 0 (NO_ERROR)
    2023-06-08 19:43:07.435  - info: host.buanet-iobroker instance system.adapter.device-reminder.0 started with pid 908
    2023-06-08 19:43:08.729  - info: device-reminder.0 (908) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:08.823  - info: device-reminder.0 (908) Device "Waschmaschine" was successfully created
    2023-06-08 19:43:08.976  - info: device-reminder.0 (908) Device "Trockner" was successfully created
    2023-06-08 19:43:11.428  - info: host.buanet-iobroker instance system.adapter.simple-api.0 started with pid 1204
    2023-06-08 19:43:12.831  - info: simple-api.0 (1204) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 19:43:12.854  - info: simple-api.0 (1204) simpleAPI server listening on port 8087
    2023-06-08 19:43:12.855  - info: simple-api.0 (1204) Allow states only when user is owner: true
    2023-06-08 19:43:12.869  - info: simple-api.0 (1204) http server listening on port 8087
    2023-06-08 19:43:12.973  - info: alexa2.0 (311) Initialization Done ...
    2023-06-08 19:43:15.430  - info: host.buanet-iobroker instance system.adapter.bidirectional-counter.0 started with pid 1523
    2023-06-08 19:43:16.649  - info: bidirectional-counter.0 (1523) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.bidirectional-counter, node: v18.16.0, js-controller: 4.0.24
    So müsste es stimmen
    GlasfaserG Offline
    GlasfaserG Offline
    @ben1983 sagte in Neueres Docker Image fährt nicht hoch:
    Sieht auf dem ersten Blick , alles gut aus .
    das ist auch gut ... da können auch Fehler sonst kommen , aber du nutzt ja TCP
    Also .. versuche es morgen mal , so wie beschrieben !
    • GlasfaserG Glasfaser
      Ben1983B Offline
      Ben1983B Offline
      Ben1983
      @glasfaser
      Beenden, dann versuchen, oder erst neu starten?
      • DJMarc75D DJMarc75
        @glasfaser sagte in Neueres Docker Image fährt nicht hoch:
        ist OK so .
        also in diesem Docker ist das so ok ? Also Root ?
        GlasfaserG Offline
        GlasfaserG Offline
        @djmarc75 sagte in Neueres Docker Image fährt nicht hoch:
        Ja schon mehere mal hier durchgekaut
        Sorry ... :)
        https://github.com/buanet/ioBroker.docker/blob/main/debian/scripts/iobroker_startup.sh
        https://github.com/buanet/ioBroker.docker/blob/main/debian/scripts/iobroker_startup.sh#LL160C8-L160C8
          Sorry ... :)
          Ben1983B Offline
          Ben1983B Offline
          Ben1983
          @glasfaser weil die uid und die gid auf 1000 stehen? oder wie?
          • Ben1983B Ben1983
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @glasfaser
            Was möchest du jetzt !?
            @ben1983
            Da sollte eigentlich mehr kommen ...
            keine Ahnung gerade was da jetzt so hängt .
            Alle Docker Container die du so hast mal stoppen , dann starte die Syn mal neu , erstelle einen neuen iobroker Container ... dann das Verzeichniss mounten .
            Was ist dann ..
            Dann schreibst du :
            @glasfaser Versuche ich spätestens morgen. muss jetzt erst mal was anderes machen. Melde mich wieder
            Was denn jetzt !????
              ist OK so .
              FredFF Online
              FredFF Online
              FredF
              Most Active Forum Testing
              @djmarc75
              Achtung Outing: Ich lege mir nicht jedes mal, wenn ich ein neues Docker Image baue einen Standarduser an...👼
              ...ich weiss gar nicht, wann ich das letzte mal die Konsole genutzt habe...
              • Ben1983B Ben1983
                GlasfaserG Offline
                GlasfaserG Offline
                Das war nicht für dich !!!!
                Bitte die Finger von lassen
                  @glasfaser
                  @ben1983
                  Was ist dann ..
                  Dann schreibst du :
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  @glasfaser Ich meinte, ob ich dann morgen erst die container beenden soll und vor dem neustart der ds nochmal einen versuch mit dem neuen image machen soll, oder ob ich die erst neu starten soll?
                  Die container dann nicht mit starten lassen, oder?
                  Also ich habe gestern portainer drauf gemacht nur zur Info, falls das was ausmachen könnte.
                  • Ben1983B Ben1983
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @ben1983
                    So wie geschrieben :
                    darauf achten das der Autostart nicht aktiv ist
                    Ben1983B 2 Antworten Letzte Antwort
                      @ben1983
                      Ben1983B Offline
                      Ben1983B Offline
                      Ben1983
                      @glasfaser OK, ich werde morgen berichten
                        @ben1983
                        Ben1983B Offline
                        Ben1983B Offline
                        Ben1983
                        @glasfaser Es schein zu funktionieren.
                        Aber es war das gleiche Bild we gestern. ich habe ih nun einfach mal so laufen lassen (den Container)
                        und irgendwann ging es weiter.
                        Es lag also wirklich an der Zeit.
                        Danke für die Tips und jetzt weiß ich auch den fix. :-)
                        • Ben1983B Ben1983
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Sehr Interessant , sollte eigentlich nicht so sein , nach Step 1
                          Bitte poste noch das DEBUG Log , nach :
                          ----- Step 1 of 5: Preparing container -----
                            Ben1983B Offline
                            Ben1983B Offline
                            Ben1983
                            @glasfaser Wahrscheinlich musste man wirklich einfach etwas warten.
                            Wenn er es jetzt das erste mal durchlaufen hat, geht es so schnell wie immer...
                            ganz normal jetzt. kann es sein, dass beim ersten durchlauf länger braucht, weil er die vorhandene installation schon kennt?
                            • Ben1983B Ben1983
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Bitte dazu das DEBUG Log .. von dieser Installation !
                                Ben1983B Offline
                                Ben1983B Offline
                                Ben1983
                                schrieb am zuletzt editiert von Ben1983
                                @glasfaser Sorry, bin nicht vor Ort und kann jetzt den Container nicht neu starten.
                                Aber es geht ja jetzt normal fix.
                                Dernke das war wirklich das warten.. hat heute morgen ca. 4 min an step 1 gedauert.
                                • Ben1983B Ben1983
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Nochmal ... es geht nicht um
                                  Das Log ist doch vorhanden ...
                                  aber Egal ... Frage jetzt auch nicht mehr nach .. vergesse das Thema .
                                  Es wäre nur sehr Interessant gewesen , was da passiert ist / im DEBUG steht !
                                    Ben1983B Offline
                                    Ben1983B Offline
                                    Ben1983
                                    @glasfaser ich versuche ihn morgen noch mal zu starten.
                                    Hatte heute morgen nicht das Debug rein genommen. Und nachher wenn ich zu Hause bin, mag ich was mit der Family machen.
                                    Mich interessiert es ja auch.
                                    Wie gesagt, ich vermute echt es war wirklich das Warten.
                                    • Ben1983B Ben1983
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Dann hat es sich jetzt erledigt !
                                        Ben1983B Offline
                                        Ben1983B Offline
                                        Ben1983
                                        @glasfaser Nicht sauer sein bitte.
                                        Ich mache es gerne morgen früh nochmal.
                                        Ok?
                                          Ben1983B Offline
                                          Ben1983B Offline
                                          Ben1983
                                          @glasfaser es ist jetzt. Natürlich nicht mehr von dem Start aus zu sehen.
                                          Dann macht es keinen Sinn, oder?
                                          Magst Du lieber das DEBUG Log von dem nächsten Update sehen?
