@holger-dietrich-0 said in IoB hängt sich nach versuchtem Repository update auf:
nach Iob fix lief iob diag jetzt durch
das Ergebnis;
```bash
Script v.2025-02-23
*** BASE SYSTEM ***
Static hostname: raspberrypi
Icon name: computer
Kernel: Linux 6.6.74+rpt-rpi-v8
Architecture: arm64
OS is similar to:
Model : Raspberry Pi 4 Model B Rev 1.4
Docker : false
Virtualization : none
Kernel : aarch64
Userland : 64 bit
Systemuptime and Load:
07:57:46 up 46 min, 4 users, load average: 0.79, 1.09, 0.88
CPU threads: 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'bookworm'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
Local time: Thu 2025-03-13 07:57:46 CET
Universal time: Thu 2025-03-13 06:57:46 UTC
RTC time: n/a
NTP service: active
RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
dietr
HOME=/home/dietr
GROUPS=dietr adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
iobroker
HOME=/home/iobroker
*** DISPLAY-SERVER SETUP ***
Display-Server: true
Desktop:
Terminal: tty
System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
*** MEMORY ***
Mem: 1.9G 1.3G 205M 10M 531M 655M
Swap: 536M 527M 9.6M
Total: 2.5G 1.8G 215M
Active iob-Instances: 14
1846 M total memory
1221 M used memory
643 M active memory
818 M inactive memory
196 M free memory
22 M buffer memory
484 M swap cache
511 M total swap
502 M used swap
9 M free swap
*** top - Table Of Processes ***
top - 07:57:47 up 46 min, 4 users, load average: 0.79, 1.09, 0.88
Tasks: 233 total, 1 running, 232 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 20.0 sy, 0.0 ni, 80.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 1846.8 total, 195.1 free, 1223.2 used, 506.7 buff/cache
MiB Swap: 512.0 total, 9.2 free, 502.8 used. 623.6 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 659M 0 659M 0% /dev
tmpfs tmpfs 185M 1.3M 184M 1% /run
/dev/mmcblk0p2 ext4 58G 10G 45G 19% /
tmpfs tmpfs 924M 224K 924M 1% /dev/shm
tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock
/dev/mmcblk0p1 vfat 510M 67M 444M 14% /boot/firmware
tmpfs tmpfs 185M 48K 185M 1% /run/user/1000
[Thu Mar 13 07:11:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:DF:94:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=4b796769-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
[Thu Mar 13 07:11:04 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
[Thu Mar 13 07:11:06 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
Show mounted filesystems:
TARGET SOURCE FSTYPE OPTIONS
/ /dev/mmcblk0p2 ext4 rw,noatime
|-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
`-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
1.6G /var/
573M /var/lib
349M /var/lib/mysql
311M /var/cache
304M /var/cache/apt
Archived and active journals take up 159.9M in the file system.
/opt/iobroker/backups:
4.0K /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
1.1G /opt/iobroker/iobroker-data/
968M /opt/iobroker/iobroker-data/files
617M /opt/iobroker/iobroker-data/files/javascript.admin
560M /opt/iobroker/iobroker-data/files/javascript.admin/static
558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
28M /opt/iobroker/iobroker-data/objects.jsonl
24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
10M /opt/iobroker/iobroker-data/states.jsonl
8.7M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
8.6M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
No Devices found 'by-id'
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
*** NodeJS-Installation ***
/usr/bin/nodejs v18.20.6
/usr/bin/node v18.20.6
/usr/bin/npm 10.8.2
/usr/bin/npx 10.8.2
/usr/bin/corepack 0.29.4
nodejs:
Installed: 18.20.6-1nodesource1
Candidate: 18.20.6-1nodesource1
Version table:
*** 18.20.6-1nodesource1 600
500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
100 /var/lib/dpkg/status
18.20.5-1nodesource1 600
18.20.4-1nodesource1 600
18.20.3-1nodesource1 600
18.20.2-1nodesource1 600
18.20.1-1nodesource1 600
18.20.0-1nodesource1 600
18.19.1-1nodesource1 600
18.19.0+dfsg-6~deb12u2 500
500 http://deb.debian.org/debian bookworm/main arm64 Packages
18.19.0+dfsg-6~deb12u1 500
500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
18.19.0-1nodesource1 600
18.18.2-1nodesource1 600
18.18.1-1nodesource1 600
18.18.0-1nodesource1 600
18.17.1-1nodesource1 600
18.17.0-1nodesource1 600
18.16.1-1nodesource1 600
18.16.0-1nodesource1 600
18.15.0-1nodesource1 600
18.14.2-1nodesource1 600
18.14.1-1nodesource1 600
18.14.0-1nodesource1 600
18.13.0-1nodesource1 600
18.12.0-1nodesource1 600
18.11.0-1nodesource1 600
18.10.0-1nodesource1 600
18.9.1-1nodesource1 600
18.9.0-1nodesource1 600
18.8.0-1nodesource1 600
18.7.0-1nodesource1 600
18.6.0-1nodesource1 600
18.5.0-1nodesource1 600
18.4.0-1nodesource1 600
18.3.0-1nodesource1 600
18.2.0-1nodesource1 600
18.1.0-1nodesource1 600
18.0.0-1nodesource1 600
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States type: jsonl
Hosts:
raspberrypi raspberrypi (version: 7.0.6, hostname: raspberrypi , alive, uptime: 2240)
Core adapters versions
js-controller: 7.0.6
admin: 7.4.10
javascript: 8.8.3
nodejs modules from github: 2
+-- iobroker.goodwe@1.0.4 (git+ssh://git@github.com/FossyTom/ioBroker.goodwe.git#8d36899279986a1d9f645ba284ca0400c5937470)
+-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#93de058900073dc703b24502ff289003610aac5f)
Adapter State
+ system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.backitup.0 : backitup : raspberrypi - enabled
system.adapter.bydhvs.0 : bydhvs : raspberrypi - disabled
system.adapter.discovery.0 : discovery : raspberrypi - disabled
system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - disabled
+ system.adapter.go-e.0 : go-e : raspberrypi - enabled
+ system.adapter.goodwe.0 : goodwe : raspberrypi - enabled
+ system.adapter.goodwe.1 : goodwe : raspberrypi - enabled
system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : raspberrypi - disabled
system.adapter.icons-material-png.0 : icons-material-png : raspberrypi - disabled
system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled
system.adapter.influxdb.0 : influxdb : raspberrypi - disabled, port: 8086
+ system.adapter.javascript.0 : javascript : raspberrypi - enabled
system.adapter.meross.0 : meross : raspberrypi - disabled
+ system.adapter.pvforecast.0 : pvforecast : raspberrypi - enabled
+ system.adapter.renault.0 : renault : raspberrypi - enabled
+ system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin
+ system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1881, bind: 0.0.0.0
+ system.adapter.sql.0 : sql : raspberrypi - enabled
system.adapter.vis-2-widgets-energy.0 : vis-2-widgets-energy : raspberrypi - disabled
system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi - disabled
system.adapter.vis-fancyswitch.0 : vis-fancyswitch : raspberrypi - disabled
system.adapter.vis-history.0 : vis-history : raspberrypi - disabled
system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled
system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled
system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspberrypi - disabled
system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled
system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - disabled
system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled
system.adapter.vis.0 : vis : raspberrypi - enabled
+ system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
│ (index) │ name │ url │ auto upgrade │
│ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ true │
│ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ true │
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: stable
Adapter "admin" : 7.4.10 , installed 7.4.10
Adapter "backitup" : 3.0.31 , installed 3.0.31
Adapter "bydhvs" : 1.5.0 , installed 1.5.0
Adapter "discovery" : 5.0.0 , installed 5.0.0
Adapter "fb-checkpresence": 1.2.8 , installed 1.2.8
Adapter "go-e" : 1.0.41 , installed 1.0.41
Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0
Adapter "icons-material-png": 0.1.0, installed 0.1.0
Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
Adapter "influxdb" : 4.0.2 , installed 4.0.2
Adapter "javascript" : 8.8.3 , installed 8.8.3
Controller "js-controller": 7.0.6 , installed 7.0.6
Adapter "meross" : 1.17.0 , installed 1.17.0
Adapter "pvforecast" : 4.1.0 , installed 4.1.0
Adapter "shelly" : 8.5.1 , installed 8.5.1
Adapter "simple-api" : 2.8.0 , installed 2.8.0
Adapter "socketio" : 6.7.1 , installed 6.7.1
Adapter "sonoff" : 3.1.2 , installed 3.1.2
Adapter "sql" : 3.0.1 , installed 3.0.1
Adapter "vis" : 1.5.6 , installed 1.5.6
Adapter "vis-2-widgets-energy": 1.0.2, installed 1.0.2
Adapter "vis-2-widgets-material": 1.4.10, installed 1.4.10
Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
Adapter "vis-history" : 1.0.0 , installed 1.0.0
Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1
Adapter "vis-icontwo" : 1.11.0 , installed 1.11.0
Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1
Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
Adapter "vis-metro" : 1.2.0 , installed 1.2.0
Adapter "web" : 6.2.5 , installed 6.2.5
Adapter "ws" : 2.6.2 , installed 2.6.2
Objects and States
Objects: 12801
States: 11269
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Hit:5 https://apt.grafana.com stable InRelease
Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Pending Updates: 20
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 0.0.0.0:1881 0.0.0.0:* LISTEN 1001 24113 3687/io.sonoff.0
tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 23548 3680/io.shelly.0
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 23240 3574/iobroker.js-co
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 23247 3574/iobroker.js-co
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 7346 626/cupsd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 5045 650/sshd: /usr/sbin
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 112 1009 715/mariadbd
tcp6 0 0 :::3000 :::* LISTEN 113 9867 1050/grafana
tcp6 0 0 :::8087 :::* LISTEN 1001 25168 3809/io.simple-api.
tcp6 0 0 :::8081 :::* LISTEN 1001 25669 3592/io.admin.0
tcp6 0 0 :::8082 :::* LISTEN 1001 24357 3856/io.web.0
tcp6 0 0 ::1:631 :::* LISTEN 0 7345 626/cupsd
tcp6 0 0 :::22 :::* LISTEN 0 5047 650/sshd: /usr/sbin
udp 0 0 0.0.0.0:58168 0.0.0.0:* 104 4941 445/avahi-daemon: r
udp 0 0 0.0.0.0:60410 0.0.0.0:* 1001 26715 3756/io.goodwe.1
udp 0 0 0.0.0.0:38102 0.0.0.0:* 1001 24150 3737/io.goodwe.0
udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4939 445/avahi-daemon: r
udp6 0 0 fe80::b6bd:43bb:3ca:546 :::* 0 7637 569/NetworkManager
udp6 0 0 fe80::b2bd:aed3:6d6:546 :::* 0 8523 569/NetworkManager
udp6 0 0 :::5353 :::* 104 4940 445/avahi-daemon: r
udp6 0 0 :::33002 :::* 104 4942 445/avahi-daemon: r
2025-03-13 07:21:21.930 - info: host.raspberrypi instance system.adapter.web.0 in version "6.2.5" started with pid 3856
2025-03-13 07:21:22.456 - info: vis.0 (3841) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.6, js-controller: 7.0.6
2025-03-13 07:21:22.466 - info: renault.0 (3794) Feature not found for VF1AG000868646847. Ignore lock-status for updates.
2025-03-13 07:21:22.851 - info: renault.0 (3794) Feature not found for VF1AG000868646847. Ignore res-state for updates.
2025-03-13 07:21:23.439 - info: pvforecast.0 (3782) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
2025-03-13 07:21:29.070 - info: vis.0 (3841) Terminated (NO_ERROR): Without reason
2025-03-13 07:21:29.753 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
2025-03-13 07:21:31.804 - info: web.0 (3856) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.6, js-controller: 7.0.6
2025-03-13 07:21:32.316 - info: web.0 (3856) socket.io server listening on port 8082
2025-03-13 07:21:32.341 - info: web.0 (3856) http server listening on port 8082
2025-03-13 07:21:39.228 - info: sonoff.0 (3687) Client [Stromzaehler] connected with secret 1741846899213_139
2025-03-13 07:21:39.398 - info: sonoff.0 (3687) Client [Gaszaehler] connected with secret 1741846899396_3688
2025-03-13 07:21:39.942 - info: javascript.0 (3603) script.js.SmartMeterUmschalter: SoC_2 geändert: 98 SoC_1:: 0 Schalter:true
2025-03-13 07:21:42.343 - info: javascript.0 (3603) script.js.SmartMeterUmschalter: SoC_1 geändert: 28 SoC_2:: 98 Schalter:true
2025-03-13 07:23:12.377 - info: javascript.0 (3603) script.js.SmartMeterUmschalter: SoC_1 geändert: 27 SoC_2:: 98 Schalter:true
2025-03-13 07:23:12.386 - info: javascript.0 (3603) script.js.LadeRegelung: Laderegelung: nicht gestoppt weil SoC_gesamt = 62.5 Allow charging 0
2025-03-13 07:32:20.536 - info: admin.0 (3592) <== Disconnect system.user.admin from ::ffff:192.168.178.200 admin
2025-03-13 07:36:40.905 - info: javascript.0 (3603) script.js.SmartMeterUmschalter: SoC_2 geändert: 99 SoC_1:: 27 Schalter:true
2025-03-13 07:36:40.910 - info: javascript.0 (3603) script.js.LadeRegelung: Laderegelung: nicht gestoppt weil SoC_gesamt = 63 Allow charging 0
2025-03-13 07:37:13.224 - info: javascript.0 (3603) script.js.SmartMeterUmschalter: SoC_1 geändert: 26 SoC_2:: 99 Schalter:true
2025-03-13 07:37:13.232 - info: javascript.0 (3603) script.js.LadeRegelung: Laderegelung: nicht gestoppt weil SoC_gesamt = 62.5 Allow charging 0
2025-03-13 07:45:11.452 - info: javascript.0 (3603) script.js.SmartMeterUmschalter: SoC_2 geändert: 100 SoC_1:: 26 Schalter:true
2025-03-13 07:45:11.462 - info: javascript.0 (3603) script.js.LadeRegelung: Laderegelung: nicht gestoppt weil SoC_gesamt = 63 Allow charging 0
2025-03-13 07:45:42.155 - info: admin.0 (3592) ==> Connected system.user.admin from ::ffff:192.168.178.200
2025-03-13 07:46:50.128 - info: web.0 (3856) ==> Connected system.user.admin from ::ffff:192.168.178.200
iob diag has finished.
Press any key for a summary
