@haus-automatisierung
Bei iob diag kommt
*** iob diag is starting up, please wait ***
The state system.host.raspberrypi.versions.nodeNewestNext was not found!
Hilft das (?):
raspberrypi:/opt/iobroker $ iobroker list instances
  system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled,
  system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
+ system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
  system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
  system.adapter.history.0                : history               : raspberrypi                              - disabled
  system.adapter.ical.1                   : ical                  : raspberrypi                              - disabled
  system.adapter.info.0                   : info                  : raspberrypi                              - disabled
  system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
  system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
  system.adapter.knx.0                    : knx                   : raspberrypi                              - disabled,
  system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled,
  system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled,
  system.adapter.opendtu.0                : opendtu               : raspberrypi                              - disabled
  system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              - disabled
  system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
  system.adapter.statistics.0             : statistics            : raspberrypi                              - disabled
  system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled,
  system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
  system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
  system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
  system.adapter.web.0                    : web                   : raspberrypi                              - disabled,
  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
  system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
+ instance is alive
raspberrypi:/opt/iobroker $ node -v
v20.18.0
raspberrypi:/opt/iobroker $ npm -v
10.8.2
