  4. Test Adapter smartfriends v1.3.x Latest
  • Weihnachtsangebot 2025! 🎄
    2.1k
55 Beiträge 7 Kommentatoren 1.3k Aufrufe 7 Watching
  • W wak
    @Black-Thunder sagte in [Neuer Adapter] smartfriends:
    Also ab der Zeile "instance system.adapter.smartfriends.0 in version "1.2.0-alpha.0" started with pid XXX"
    2026-01-08 14:10:01.503 - info: host.iobroker instance system.adapter.smartfriends.0 in version "1.2.0-alpha.0" started with pid 1012
    2026-01-08 14:10:04.173 - debug: smartfriends.0 (1012) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2026-01-08 14:10:04.212 - debug: smartfriends.0 (1012) Objects client ready ... initialize now
    2026-01-08 14:10:04.214 - debug: smartfriends.0 (1012) Objects create System PubSub Client
    2026-01-08 14:10:04.215 - debug: smartfriends.0 (1012) Objects create User PubSub Client
    2026-01-08 14:10:04.228 - debug: smartfriends.0 (1012) Objects client initialize lua scripts
    2026-01-08 14:10:04.238 - debug: smartfriends.0 (1012) Objects connected to redis: 127.0.0.1:9001
    2026-01-08 14:10:04.247 - debug: smartfriends.0 (1012) Redis States: Use Redis connection: 127.0.0.1:9000
    2026-01-08 14:10:04.254 - debug: smartfriends.0 (1012) States create System PubSub Client
    2026-01-08 14:10:04.255 - debug: smartfriends.0 (1012) States create User PubSub Client
    2026-01-08 14:10:04.262 - debug: smartfriends.0 (1012) States connected to redis: 127.0.0.1:9000
    2026-01-08 14:10:04.365 - info: smartfriends.0 (1012) starting. Version 1.2.0-alpha.0 in /opt/iobroker/node_modules/iobroker.smartfriends, node: v22.21.0, js-controller: 7.0.7
    2026-01-08 14:10:04.382 - debug: smartfriends.0 (1012) Initializing objects...
    2026-01-08 14:10:04.408 - debug: smartfriends.0 (1012) Checking adapter settings...
    2026-01-08 14:10:04.409 - info: smartfriends.0 (1012) Connecting to gateway and retrieving data...
    2026-01-08 14:10:04.409 - debug: smartfriends.0 (1012) IP: 192.168.178.33 - Port: 4300 - CSymbol: D19033i - SHCVersion: 3.7.4 - SHAPIVersion: 3.4
    2026-01-08 14:10:04.410 - debug: smartfriends.0 (1012) Setting up socket...
    2026-01-08 14:10:04.603 - debug: smartfriends.0 (1012) Cert issuer organization: enexoma AG
    2026-01-08 14:10:04.604 - debug: smartfriends.0 (1012) Setting up socket events...
    2026-01-08 14:10:04.604 - debug: smartfriends.0 (1012) Setup socket successfully
    2026-01-08 14:10:04.605 - debug: smartfriends.0 (1012) Send and receive JSON: {"command":"helo","username":"ioBroker"}
    2026-01-08 14:10:04.616 - debug: smartfriends.0 (1012) Received data: { "response" : { "majorApiVersion" : "3", "salt" : "MYRTCDlGvl9mjrVHWZ3EVUHdudM=", "sessionSalt" : "QmMkABafQL/xaBXC9r6D4L9FYT4=" }, "responseCode" : 1, "responseMessage" : "success" }
    2026-01-08 14:10:04.617 - debug: smartfriends.0 (1012) Message received: success (code: 1)
    2026-01-08 14:10:04.618 - debug: smartfriends.0 (1012) Send and receive JSON: {"command":"login","username":"ioBroker","digest":"RsoP7JZftLJKEgb0G52CUwLDSNE=","cSymbol":"D19033i","shcVersion":"3.7.4","shApiVersion":"3.4"}
    2026-01-08 14:10:04.645 - debug: smartfriends.0 (1012) Received data: { "response" : { "environment" : { }, "hardware" : "SmartFriendsBox", "localSHServerTime" : "20260108141004+0100", "macAddress" : "8c:19:2d:60:23:25", "ownerSetup" : true, "pushNotificationUrl" : "https://live.ergyserver.de/eif/pn/registry/D19033/154039763346213", "remoteHome" : { "activated" : true, "status" : "notConnected", "url" : "rhlive.ergyserver.de" }, "sessionID" : "9ENSBjRLRYRYYFRrhM9D", "shsVersion" : "4.4.1-release", "user" : { "administratorRights" : true, "email" : "", "emailValidated" : false, "firstName" : "M", "gender" : "none", "id" : 35196, "lastName" : "M", "loginAllowedUntil" : 0, "mobileNo" : "", "name" : "ioBroker", "passwordValidity" : 4294967295, "settings" : { "backgroundSettings" : { } }, "username" : "ioBroker", "usertype" : "person", "wrappers" : [ 36928, 36000, 36001, 36002 ] }, "webshopUrl" : "https://shpportal.com/webshop-smartfriends.aspx?MAC=154039763346213" }, "responseCode" : 1, "responseMessage" : "success" }
    2026-01-08 14:10:04.646 - debug: smartfriends.0 (1012) Message received: success (code: 1)
    2026-01-08 14:10:04.647 - debug: smartfriends.0 (1012) Connection and login to gateway SmartFriendsBox successful.
    2026-01-08 14:10:04.648 - info: smartfriends.0 (1012) Querying all devices...
    2026-01-08 14:10:04.649 - debug: smartfriends.0 (1012) Send and receive JSON: {"command":"getAllNewInfos","timestamp":"0","compatibilityConfigurationVersion":"0","languageTranslationVersion":"0","sessionID":"9ENSBjRLRYRYYFRrhM9D"}
    2026-01-08 14:10:09.650 - debug: smartfriends.0 (1012) Sending command with method: keepalive
    2026-01-08 14:10:09.651 - debug: smartfriends.0 (1012) Send JSON: {"command":"keepalive"}
    2026-01-08 14:10:09.653 - error: smartfriends.0 (1012) Connection failed: "timeout"
    Die Einträge gehen dann zwar noch weiter, aber das sind mehr als die möglichen 1000 Zeichen...
    Black ThunderB Offline
    Black Thunder
    #41
    @wak Ja, genau das brauche ich, nur nicht als Screenshot. Stelle bitte das gesamte Log vollständig hier als .txt Datei zur Verfügung.
    W 1 Antwort Letzte Antwort
    • Black ThunderB Black Thunder
      W Online
      W Online
      wak
      schrieb am zuletzt editiert von wak
      #42
      @Black-Thunder
      Ich hoffe das paßt so...
      iobroker.txt
      Black ThunderB 1 Antwort Letzte Antwort
      • W wak
        @Black-Thunder
        iobroker.txt
        Black Thunder
        #43
        @wak Ja, jetzt ist inhaltlich alles da. Auch wenn die Formatierung darin etwas wild ist 😉
        Zu deinem Problem: Anscheinend war der Timeout beim initialen Abruf der Geräte etwas konservativ angesetzt. Ich habe das nun deutlich erhöht, so dass es bei dir ohne Fehler durchlaufen sollte und die Geräte als States auftauchen müssten. Probier es bitte mit v1.2.0-alpha.1.
          W Online
          W Online
          wak
          #44
          @Black-Thunder
          Wir sind einen Schritt weiter ... 👍
          Im Log stehen jetzt die Rohrmotoren u.s.w., aber unter Objekte finde immer noch keine Einträge 🤔
          2026-01-09 09:30:02.200 - info: host.iobroker instance system.adapter.smartfriends.0 in version "1.2.0-alpha.1" started with pid 56896
          2026-01-09 09:30:03.523 - info: smartfriends.0 (56896) starting. Version 1.2.0-alpha.1 in /opt/iobroker/node_modules/iobroker.smartfriends, node: v22.21.0, js-controller: 7.0.7
          2026-01-09 09:30:03.561 - info: smartfriends.0 (56896) Connecting to gateway and retrieving data...
          2026-01-09 09:30:03.876 - info: smartfriends.0 (56896) Querying all devices...
          2026-01-09 09:30:10.335 - info: smartfriends.0 (56896) Device created: Rohrmotor PREMIUM (Kanal 4 / Doppelfenster) (ID: 10170)
          2026-01-09 09:30:10.357 - info: smartfriends.0 (56896) Device created: Rohrmotor PREMIUM (Kanal 5) (ID: 15210)
          2026-01-09 09:30:10.376 - info: smartfriends.0 (56896) Device created: ${Input} (ID: 13012)
          2026-01-09 09:30:10.395 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 15939)
          2026-01-09 09:30:10.403 - info: smartfriends.0 (56896) Device created: ${State} (ID: 19358)
          2026-01-09 09:30:10.427 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 3776)
          2026-01-09 09:30:10.434 - info: smartfriends.0 (56896) Device created: ${State} (ID: 19603)
          2026-01-09 09:30:10.456 - info: smartfriends.0 (56896) Device created: Rohrmotor PREMIUM (Kanal 2 / Terrassentür) (ID: 1535)
          2026-01-09 09:30:10.475 - info: smartfriends.0 (56896) Device created: Rohrmotor PREMIUM (Kanal 1) (ID: 10637)
          2026-01-09 09:30:10.490 - info: smartfriends.0 (56896) Device created: ${State} (ID: 6409)
          2026-01-09 09:30:10.509 - info: smartfriends.0 (56896) Device created: Rohrmotor PREMIUM (Kanal 5.2) (ID: 4789)
          2026-01-09 09:30:10.526 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 12198)
          2026-01-09 09:30:10.533 - info: smartfriends.0 (56896) Device created: ${State} (ID: 6394)
          2026-01-09 09:30:10.589 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 19264)
          2026-01-09 09:30:10.600 - info: smartfriends.0 (56896) Device created: ${State} (ID: 4067)
          2026-01-09 09:30:10.630 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 9205)
          2026-01-09 09:30:10.660 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 6356)
          2026-01-09 09:30:10.669 - info: smartfriends.0 (56896) Device created: ${State} (ID: 19125)
          2026-01-09 09:30:10.724 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 977)
          2026-01-09 09:30:10.741 - info: smartfriends.0 (56896) Device created: ${State} (ID: 4468)
          2026-01-09 09:30:10.791 - info: smartfriends.0 (56896) Device created: Rohrmotor PREMIUM (Kanal 3 / Festverglasung) (ID: 452)
          2026-01-09 09:30:10.817 - info: smartfriends.0 (56896) Device created: ${Input} (ID: 9863)
          2026-01-09 09:30:10.840 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 2583)
          2026-01-09 09:30:10.867 - info: smartfriends.0 (56896) Device created: ${State} (ID: 13391)
          2026-01-09 09:30:10.909 - info: smartfriends.0 (56896) Device created: ${Temperature} (ID: 8082)
          2026-01-09 09:30:11.052 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 16168)
          2026-01-09 09:30:11.066 - info: smartfriends.0 (56896) Device created: ${State} (ID: 9663)
          2026-01-09 09:30:11.114 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 639)
          2026-01-09 09:30:11.128 - info: smartfriends.0 (56896) Device created: ${State} (ID: 2709)
          2026-01-09 09:30:11.247 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 17470)
          2026-01-09 09:30:11.286 - info: smartfriends.0 (56896) Device created: ${State} (ID: 575)
          2026-01-09 09:30:11.332 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 4870)
          2026-01-09 09:30:11.341 - info: smartfriends.0 (56896) Device created: ${State} (ID: 19223)
          2026-01-09 09:30:11.371 - info: smartfriends.0 (56896) Device created: ${State} (ID: 15527)
          2026-01-09 09:30:11.381 - info: smartfriends.0 (56896) Device created: ${State} (ID: 18111)
          2026-01-09 09:30:11.422 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 8348)
          2026-01-09 09:30:11.433 - info: smartfriends.0 (56896) Device created: ${State} (ID: 5526)
          2026-01-09 09:30:11.475 - info: smartfriends.0 (56896) Device created: ${Input} (ID: 8527)
          2026-01-09 09:30:11.507 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 298)
          2026-01-09 09:30:11.518 - info: smartfriends.0 (56896) Device created: ${State} (ID: 9211)
          2026-01-09 09:30:11.560 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 4170)
          2026-01-09 09:30:11.574 - info: smartfriends.0 (56896) Device created: ${State} (ID: 6417)
          2026-01-09 09:30:11.695 - info: smartfriends.0 (56896) Device created: ${Switch} (ID: 14625)
          2026-01-09 09:30:11.710 - info: smartfriends.0 (56896) Device created: ${State} (ID: 12896)
          2026-01-09 09:30:11.751 - info: smartfriends.0 (56896) Processed 158 device(s), created 28 master device(s).
          2026-01-09 09:30:49.916 - info: admin.0 (165) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
          2026-01-09 09:30:52.208 - info: admin.0 (165) ==> Connected system.user.admin from ::ffff:192.168.65.1
          • W wak
            @Black-Thunder
            Black Thunder
            schrieb am zuletzt editiert von Black Thunder
            #45
            @wak Laut Log sieht das doch eigentlich gut aus. Hast du auch mal den "devices"-Ordner aufgeklappt? Im Screenshot ist er noch zu 😉
            Ansonsten auch mal versuchen, den kompletten "devices"-Ordner zu löschen, und dann den Adapter neu starten. Dann müssen eigentlich alle Objekte da sein.
            W 2 Antworten Letzte Antwort
              W Online
              W Online
              wak
              #46
              Das hat's gebracht. Danke dafür !
                @HeiLuRa Sind denn unter "smartfriends.0.devices.6597.13631.control" überhaupt States angelegt worden? Da müsste es sowas wie "on", "off" und "toggle" geben. "control" ist ja erstmal nur der übergeordnete Channel und ist selbst nicht schaltbar.
                Welche Version verwendest du? Nach einem Upgrade auf die aktuelle 1.2.0-alpha.0 solltest du einmalig den Objektbaum löschen, damit er korrekt neu angelegt werden kann.
                Ansonsten bitte ein vollständiges Debug-Log nach Adapterstart hochladen.
                HeiLuRa
                #47
                @Black-Thunder Ich habe den Adapter neu installiert, also jetzt Version 1.2.0-alpha.0. Es lag nicht nur an der richtigen Version, sondern auch vor dem Rechner.
                Vielen Dank nochmals für die Entwicklung des Adapters. Zur Info: ich habe die Premium Rollomotoren und Zigbee-Steckdosenschalter vom Lidl.
                  W Online
                  W Online
                  wak
                  #48
                  @Black-Thunder
                  Nochmal eine Frage zu Devices, mir fehlen noch ein paar...
                  Schellenberg Funk-Thermostate (21001) 6x
                  Schellenberg Funk-Fenster/Türkontakt (21012) 1x
                  ABUS Z-Wave Rauchmelder (SHRM10000) 6x
                  ABUS Z-Wave Tür-/Fensterkontakte (SHMK10000) 6x
                  ABUS Z-Wave Wassermelder (SHWM10000) 1x
                  ABUS Z-Wave Taster (SHBE10000) 1x
                  und bei dem ABUS Multisensor Z-Wave (SHBW10000) wird nur die Temperatur übermittelt (Luftfeuchtigkeit, Helligkeit und Bewegungsmelder fehlen)
                  Siehst Du die im Log, oder werden die nicht unterstützt ?
                  • W wak
                    @Black-Thunder
                    Black Thunder
                    #49
                    @wak Da hast du Recht, diese Gerätetypen sind bisher noch nicht abgedeckt.
                    Bitte probiere es mit 1.3.0-alpha.0 und lösche auch hier wieder einmalig den kompletten "devices"-Ordner.
                    Jetzt sollten alle deine genannten Geräte (und auch potentiell noch viele weitere) angelegt werden. Außerdem werden nun Umlaute in den Gerätenamen korrekt behandelt und dargestellt.
                      W Online
                      W Online
                      wak
                      #50
                      @Black-Thunder
                      Vielen Dank !!!
                        W Online
                        W Online
                        wak
                        #51
                        @Black-Thunder
                        ich habe die aktuelle Version 1.3.3. installiert.
                        Sehe gerade, daß das Log alle paar Minuten einen Fehler meldet.
                        smartfriends.0
                        2026-01-21 19:41:18.197	error	Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        Kannst Du da bitte mal drüber schauen ?
                        2026-01-21 17:35:31.487 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:38:13.652 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 17:39:08.984 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:39:09.285 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:39:10.394 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:39:35.883 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:39:39.582 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:11.216 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:40:18.076 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:26.172 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:40:27.280 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:29.795 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:41.929 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:40:41.930 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 javascript
                        2026-01-21 17:40:43.157 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:46.807 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:48.681 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:40:48.683 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 javascript
                        2026-01-21 17:40:49.760 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:52.443 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:40:59.076 - info: javascript.0 (190) script.js.Tür_Tor: start JavaScript (Blockly)
                        2026-01-21 17:40:59.094 - info: javascript.0 (190) script.js.Tür_Tor: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-01-21 17:41:00.195 - info: javascript.0 (190) script.js.Rauchmelder_Alarm: start JavaScript (Blockly)
                        2026-01-21 17:41:00.202 - info: javascript.0 (190) script.js.Rauchmelder_Alarm: registered 12 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-01-21 17:41:03.700 - info: javascript.0 (190) script.js.Fenster: start JavaScript (Blockly)
                        2026-01-21 17:41:03.706 - info: javascript.0 (190) script.js.Fenster: registered 18 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2026-01-21 17:41:15.316 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:41:15.322 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 javascript
                        2026-01-21 17:41:16.294 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:41:17.582 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:42:05.688 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 17:49:15.109 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:49:16.431 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 17:49:35.250 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:49:36.073 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 17:49:38.944 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 17:55:41.911 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:01:34.419 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:05:18.265 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:07:04.724 - warn: admin.0 (183) REAUTHENTICATE!
                        2026-01-21 18:07:04.774 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 18:11:53.653 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:15:31.972 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:17:26.831 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 18:23:21.574 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:28:12.390 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:35:08.542 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:41:18.411 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:47:03.703 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:54:05.954 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 18:58:08.012 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:00:40.529 - info: web.0 (290) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 19:01:10.998 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:01:14.591 - info: web.0 (290) <== Disconnect system.user.admin from ::ffff:192.168.65.1 iqontrol.0
                        2026-01-21 19:04:57.610 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:10:49.237 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:17:08.720 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:25:08.570 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:29:10.591 - warn: admin.0 (183) REAUTHENTICATE!
                        2026-01-21 19:29:10.727 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                        2026-01-21 19:29:12.257 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                        2026-01-21 19:31:50.791 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:36:58.191 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        2026-01-21 19:41:18.197 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                        • W wak
                          @Black-Thunder
                          smartfriends.0
                          Black Thunder
                          #52
                          @wak Funktioniert die Steuerung der Geräte trotzdem? In dem Fall würde ich die Meldung einfach künftig unterdrücken.
                          Wenn du magst, kannst du mir gerne auch ein Debug-Log zur Verfügung stellen, dann sehe ich genau, woher diese Meldung stammt.
                            W Online
                            W Online
                            wak
                            #53
                            @Black-Thunder viel mehr steht im Log aktuell nicht drin, weil ich es vorhin schon einmal gelöscht hatte, um dann nacheinander die Skripte wieder zuzuschalten, lag aber nicht daran.
                            Ansonsten scheint alles zu funktionieren.  🤷‍♂️
                            2026-01-21 19:47:34.760 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 19:53:04.539 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:00:28.413 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:04:10.193 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                            2026-01-21 20:04:45.398 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 javascript
                            2026-01-21 20:04:46.356 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                            2026-01-21 20:04:53.108 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:04:55.742 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 devices
                            2026-01-21 20:05:07.077 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                            2026-01-21 20:06:12.084 - warn: javascript.0 (190) Alias alias.0.Rollladen_Terrassentür.SET has no target 5
                            2026-01-21 20:06:12.125 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Rollladen_Terrassentür.SET has no target
                            2026-01-21 20:06:40.242 - warn: admin.0 (183) REAUTHENTICATE!
                            2026-01-21 20:06:40.409 - warn: admin.0 (183) REAUTHENTICATE!
                            2026-01-21 20:06:40.588 - warn: javascript.0 (190) Alias alias.0.Rollladen_Terrassentür.SET has no target 5
                            2026-01-21 20:06:40.590 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Rollladen_Terrassentür.SET has no target
                            2026-01-21 20:06:40.592 - warn: admin.0 (183) REAUTHENTICATE!
                            2026-01-21 20:06:40.606 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
                            2026-01-21 20:06:40.864 - warn: javascript.0 (190) Alias alias.0.Terrassentür.SET has no target 5
                            2026-01-21 20:06:40.865 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Terrassentür.SET has no target
                            2026-01-21 20:07:47.648 - warn: javascript.0 (190) Alias alias.0.Terrassentür.SET has no target 5
                            2026-01-21 20:07:47.649 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Terrassentür.SET has no target
                            2026-01-21 20:07:47.979 - warn: javascript.0 (190) Alias alias.0.Terrassentür.SET has no target 5
                            2026-01-21 20:07:47.981 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Terrassentür.SET has no target
                            2026-01-21 20:07:56.980 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:08:18.164 - warn: javascript.0 (190) Alias alias.0.Rollladen_Terrassentür.SET has no target 5
                            2026-01-21 20:08:18.165 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Rollladen_Terrassentür.SET has no target
                            2026-01-21 20:09:07.469 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 devices
                            2026-01-21 20:09:27.239 - info: admin.0 (183) ==> Connected system.user.admin from ::ffff:192.168.65.1
                            2026-01-21 20:12:42.869 - warn: javascript.0 (190) Alias alias.0.Rollladen_Terrassentür.SET has no target 5
                            2026-01-21 20:12:42.870 - warn: javascript.0 (190) Could not add alias subscription: Alias alias.0.Rollladen_Terrassentür.SET has no target
                            2026-01-21 20:12:51.212 - info: admin.0 (183) <== Disconnect system.user.admin from ::ffff:192.168.65.1 devices
                            2026-01-21 20:12:59.378 - warn: admin.0 (183) Alias alias.0.Rollladen_Terrassentür.SET has no target 5
                            2026-01-21 20:12:59.381 - warn: admin.0 (183) cannot subscribe on alias "alias.0.Rollladen_Terrassentür.SET": Alias alias.0.Rollladen_Terrassentür.SET has no target
                            2026-01-21 20:14:21.784 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:18:26.055 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:25:04.331 - info: admin.0 (183) Request actual repository...
                            2026-01-21 20:25:05.204 - info: host.1ef5be6e5c14 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                            2026-01-21 20:25:10.232 - error: smartfriends.0 (89960) Unknown message response code: 85 (message: 'Host not found') - Please report this to the developer!
                            2026-01-21 20:25:36.088 - info: admin.0 (183) Repository received successfully.
                            • W wak
                              Black Thunder
                              #54
                              @wak Alles klar, in der kommenden v1.3.4 wird diese Meldung ignoriert und nicht mehr protokolliert. Alle weiteren potenziellen unbekannten Meldungen werden nur noch als Warnung und nicht mehr als Fehler protokolliert.
                              Die Ursache dieser Meldung liegt vermutlich darin, dass durch die Insolvenz des Betreibers nach und nach Infrastrukturbestandteile in der Cloud abgeschaltet werden und diese daher nicht mehr erreichbar sind. Das stört uns aber zum Glück nicht weiter. 😉
                                W Online
                                W Online
                                wak
                                #55
                                @Black-Thunder Vielen Dank !
                                32.6k
                                82.1k
