  3. Off Topic
  4. Pflege des Betriebssystems
  5. System krumm?
System krumm?
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 1 Beobachtet
  • L luft-post
    @luft-post
    Fehler steht leider immer noch an
    luft-post
    hier noch mal der aktuelle iob diag
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-09-30 21:10:53 CEST
               Universal time: Tue 2025-09-30 19:10:53 UTC
                     RTC time: Tue 2025-09-30 19:10:53
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             17G        3.4G         12G         14M        1.4G         13G
    Swap:           536M          0B        536M
    Total:           17G        3.4G         12G
    Active iob-Instances:   31
            16219 M total memory
             3286 M used memory
             2981 M active memory
              869 M inactive memory
            11710 M free memory
              196 M buffer memory
             1159 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
    Tasks: 230 total,   1 running, 229 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16219.1 total,  11710.8 free,   3286.4 used,   1356.2 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12932.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
    /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
    tmpfs          tmpfs     8.0G   32K  8.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
    /dev/sda       ext4      234G   28K  222G   1% /backup
    tmpfs          tmpfs     1.6G  160K  1.6G   1% /run/user/1000
    [Tue Sep 30 21:00:25 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Tue Sep 30 21:00:26 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Quota mode: none.
    [Tue Sep 30 21:00:27 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
    [Tue Sep 30 21:00:28 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    |-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/backup        /dev/sda       ext4   rw,noatime,stripe=8191
    /var:
    2.6G    /var/
    1.4G    /var/lib
    1.2G    /var/lib/mysql
    989M    /var/lib/mysql/iobroker
    698M    /var/cache
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    677M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    639M    /opt/iobroker/iobroker-data/
    443M    /opt/iobroker/iobroker-data/files
    148M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    13M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.20.0
    /usr/bin/node           v22.20.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.20.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
     *** 22.20.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 242)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     6
    +-- iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
    +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
    +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
    +-- iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
    +-- iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
    + system.adapter.alpha2.0                 : alpha2                : raspberrypi                              -  enabled
      system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.daswetter.1              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              - disabled
      system.adapter.fully-tablet-control.0   : fully-tablet-control  : raspberrypi                              - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.homepilot20.0            : homepilot20           : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1885, bind: 0.0.0.0
      system.adapter.notification-manager.0   : notification-manager  : raspberrypi                              - disabled
      system.adapter.onvif-alt.0              : onvif-alt             : raspberrypi                              - disabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
      system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
    + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.siegenia.0               : siegenia              : raspberrypi                              -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      system.adapter.smartcontrol.1           : smartcontrol          : raspberrypi                              - disabled
      system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.2.70
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.tradfri.0                : tradfri               : raspberrypi                              - disabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      system.adapter.weatherunderground.1     : weatherunderground    : raspberrypi                              - disabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alarm"        : 3.7.4    , installed 3.7.4
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "alpha2"       : 1.0.0    , installed 1.0.3
    Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.4.3
    Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-rc.5
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
    Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
    Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        38379
    States:         29244
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        6119       831/mariadbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6496       772/sshd: /usr/sbin
    tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       22046      3523/io.sonoff.0
    tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       20727      3371/io.hm-rpc.1
    tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       20699      3356/io.hm-rpc.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6010       742/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16255      3066/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17358      3066/iobroker.js-co
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6009       742/cupsd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22859      3726/io.terminal.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23579      3834/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18649      3091/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6498       772/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7953       591/avahi-daemon: r
    udp        0      0 0.0.0.0:54916           0.0.0.0:*                           104        7955       591/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        7954       591/avahi-daemon: r
    udp6       0      0 :::47089                :::*                                104        7956       591/avahi-daemon: r
    udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          6708       660/NetworkManager
    2025-09-30 21:09:05.362  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2025-09-30 21:09:05.984  - info: host.raspberrypi instance system.adapter.web.0 in version "7.0.8" started with pid 3834
    2025-09-30 21:09:06.444  - info: admin.0 (3091) ==> Connected system.user.admin from ::ffff:192.168.2.211
    2025-09-30 21:09:09.341  - info: web.0 (3834) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
    2025-09-30 21:09:09.645  - info: web.0 (3834) socket.io server listening on port 8082
    2025-09-30 21:09:09.649  - info: web.0 (3834) http server listening on port 8082
    2025-09-30 21:09:11.072  - info: daswetter.0 (3597) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-09-30 21:09:11.583  - info: daswetter.0 (3597) cleaned everything up...
    2025-09-30 21:09:11.715  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-09-30 21:09:11.872  - info: daswetter.1 (3614) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-09-30 21:09:12.377  - info: daswetter.1 (3614) cleaned everything up...
    2025-09-30 21:09:12.504  - info: host.raspberrypi instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-09-30 21:09:12.508  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack = true)
    2025-09-30 21:09:12.548  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.7 (ack = true)
    2025-09-30 21:09:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 12 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 18 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 7 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259354853,"q":0,"from":"system.adapter.javascript.0","lc":1759259354853,"c":"script.js.common.11_FensterUeberwachungOG"})
    2025-09-30 21:09:16.312  - debug: smartcontrol.0 (3707) [_asyncOnMessage] command 'Verify Adapter Configuration' received from admin/index_m.html. Verifying the configuration and sending the result back to index_m.html...
    2025-09-30 21:09:16.356  - debug: smartcontrol.0 (3707) [_asyncOnMessage] Configuration verification failed, 4 issue(s) found.
    2025-09-30 21:09:24.520  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
    2025-09-30 21:09:24.561  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.8 (ack = true)
    2025-09-30 21:10:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 21 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 13 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 19 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 8 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259414853,"q":0,"from":"system.adapter.javascript.0","lc":1759259414853,"c":"script.js.common.11_FensterUeberwachungOG"})
    2025-09-30 21:10:37.869  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
    2025-09-30 21:10:50.009  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
    2025-09-30 21:11:02.518  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
    2025-09-30 21:11:14.687  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
    2025-09-30 21:11:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 22 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 14 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 9 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259474853,"q":0,"from":"system.adapter.javascript.0","lc":1759259474853,"c":"script.js.common.11_FensterUeberwachungOG"})
    iob diag has finished.
    pi@raspberrypi:/opt/iobroker $
    • L luft-post
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           536M          0B        536M
      Total:           17G        3.4G         12G
               3286 M used memory
              11710 M free memory
                196 M buffer memory
               1159 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      2.6G    /var/
      1.4G    /var/lib
      1.2G    /var/lib/mysql
      698M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        38379
      States:         29244
      Pending Updates: 0
      @luft-post
      Funktioniert jetzt der Aufruf von
      iob diag
      wieder auf direktem Weg?
      L 1 Antwort Letzte Antwort
        @luft-post
        iob diag
        luft-post
        @thomas-braun ja
        • L luft-post
          @thomas-braun ja
          @luft-post
          Gut, dann sind deine verfummelten Rechte jetzt wieder gerade.
          NICHT als iobroker einloggen, NICHT als root einloggen.
          Du zerballerst dir damit sonst die Rechte.
          Und nachdem deine Kiste jetzt wieder senkrecht ist schaut dein Problem mit dem Adapter genau wie aus?
          HomoranH L 2 Antworten Letzte Antwort
          • HomoranH Offline
            HomoranH Offline
            ich hab den Teil mal abgetrennt und aus Tester hierher geschoben
              @luft-post
              HomoranH Offline
              HomoranH Offline
              @thomas-braun sagte in System krumm?:
              dann bitte wieder im Original Thread weitermachen!
                luft-post
                @homoran ok vielen Dank
