  4. Tester wanted - Zigbee Adapter 3.1
testerzhczigbeezigbee 3.1
273 Beiträge 17 Kommentatoren 34.6k Aufrufe 16 Beobachtet
  • Peter V.P Offline
    Peter V.P Offline
    Peter V.
    schrieb am zuletzt editiert von Peter V.
    #261
    Ich werf bei mir mal den TS0043 raus, der wird als Router angezeigt...ist aber definitiv ein Batterie Schalter
    zigbee.0
    	2025-10-19 20:16:43.111	warn	DeviceAvailability:ELEVATED: Non-pingable device 0xe0798dfffe9c86c7 TS0043 was last seen '54.658' seconds ago.
    zigbee.0
    	2025-10-19 20:15:48.470	warn	ELEVATED:I04 (4de7) value generated '255' from device e0798dfffe9c86c7 for 'Link quality'
    zigbee.0
    	2025-10-19 20:15:48.470	warn	ELEVATED:I03 (4de7) message received '{"linkquality":255}' from device e0798dfffe9c86c7 type 'TS0043'
    zigbee.0
    	2025-10-19 20:15:48.470	warn	ELEVATED:I02 (4de7) 0 converter available for 'TS0043' 'e0798dfffe9c86c7' with cluster 'genBasic' and type 'readResponse'
    zigbee.0
    	2025-10-19 20:15:48.456	warn	ELEVATED:I01 (4de7) Zigbee Event of Type readResponse from device 0xe0798dfffe9c86c7, incoming event: {"type":"readResponse","data":{"65534":0,"manufacturerName":"_TZ3000_gbm10jnj","zclVersion":3,"appVersion":66,"modelId":"TS0043","powerSource":3},"linkquality":255,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,17,1,4,0,0,66,16,95,84,90,51,48,48,48,95,103,98,109,49,48,106,110,106,0,0,0,32,3,1,0,0,32,66,5,0,0,66,6,84,83,48,48,52,51,7,0,0,48,3,254,255,0,48,0]},"zclTransactionSequenceNumber":17,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2025-10-19 20:15:48.342	warn	ELEVATED:I04 (4d6a) value generated 'true' from device e0798dfffe9c86c7 for '3_single'
    zigbee.0
    	2025-10-19 20:15:48.342	warn	ELEVATED:I04 (4d6a) value generated '"3_single"' from device e0798dfffe9c86c7 for 'Triggered action (e.g. a button click)'
    zigbee.0
    	2025-10-19 20:15:48.342	warn	ELEVATED:I03 (4d6a) message received '{"action":"3_single"}' from device e0798dfffe9c86c7 type 'TS0043'
    zigbee.0
    	2025-10-19 20:15:48.341	warn	ELEVATED:I02.1c (4d6a) candidates: [{"action":"3_single"}] => payload {"action":"3_single"}
    zigbee.0
    	2025-10-19 20:15:48.341	warn	ELEVATED:I02.0b (4d6a) data: {"value":0,"data":{"type":"Buffer","data":[]}} options: {} meta:{"deviceIEEE":"0xe0798dfffe9c86c7","logger":"StatesController","state":{"state":""}} result:{"action":"3_single"}
    zigbee.0
    	2025-10-19 20:15:48.341	warn	ELEVATED:I02.1a (4d6a) converter 1 : Cluster genOnOff
    zigbee.0
    	2025-10-19 20:15:48.341	warn	ELEVATED:I04 (4d6a) value generated '255' from device e0798dfffe9c86c7 for 'Link quality'
    zigbee.0
    	2025-10-19 20:15:48.341	warn	ELEVATED:I03 (4d6a) message received '{"linkquality":255}' from device e0798dfffe9c86c7 type 'TS0043'
    zigbee.0
    	2025-10-19 20:15:48.341	warn	ELEVATED:I02 (4d6a) 1 converter available for 'TS0043' 'e0798dfffe9c86c7' with cluster 'genOnOff' and type 'commandTuyaAction'
    zigbee.0
    	2025-10-19 20:15:48.331	warn	ELEVATED:I01 (4d6a) Zigbee Event of Type commandTuyaAction from device 0xe0798dfffe9c86c7, incoming event: {"type":"commandTuyaAction","data":{"value":0,"data":{"type":"Buffer","data":[]}},"linkquality":255,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[1,28,253,0]},"zclTransactionSequenceNumber":28,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":3}
    • Peter V.P Peter V.
      @asgothian
      Ja, habe ich.
      Probiert mit direkt vor dem und auch direkt nach dem drücken von reconfigure.
      Sobald ich den Button am Gerät drücke, wird auch die Anzeige (Uhr) aktualisiert
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #262
      @peter-v sagte in Tester wanted - Zigbee Adapter 3.1:
      @asgothian
      Ja, habe ich.
      dann muss es auch Meldungen im Protokoll geben, wenn das Gerät im Debug ist.
      Bitte den Test wiederholen:
      • gerät in Debug schalten
      • Knopf drücken
      • reconfigure ausführen
      • ins Protokoll wechseln
      • 120 s warten
      • nochmal den Knopf drücken
      • die Warn-Meldungen des Adapters hier posten - als Text, in Code Tags
      A.
      • Peter V.P Offline
        Peter V.P Offline
        Peter V.
        #263
        Debug Karteikarte innerhalb Zigbee ist leer.
        Debug IOBroker sagt:
        zigbee.0
        	2025-10-19 20:36:45.876	info	DeviceConfigure successful 0x00124b002a50ad66 SNZB-02
        zigbee.0
        	2025-10-19 20:36:30.809	info	Configuring 0x00124b002a50ad66 SNZB-02
        Nur leider keine Änderungen im Status des Gerätes.
        Update: jetzt kommt noch folgende Meldung:
        zigbee.0
        	2025-10-19 20:39:06.805	warn	DeviceAvailability:ELEVATED: Non-pingable device 0x00124b002a50ad66 TH01 was last seen '557.964' seconds ago.
          zigbee.0
          zigbee.0
          zigbee.0
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #264
          zigbee.0
          zigbee.0
          zigbee.0
          Solange keine weiteren Meldungen kommen sendet der Sensor nichts. Da kann dann auch nichts aktualisiert werden.
          Die Elevated Meldungen kommen direkt sobald vom ZH eine Nachricht empfangen wird.
          A.
          • Peter V.P Offline
            Peter V.P Offline
            Peter V.
            #265
            Hab eine Lösung gefunden.
            Ich habe in den Einstellungen der Instanz das Gerät bei Overrides eingetragen und neu gepairt.
            Jetzt funktioniert es und zeigt alle Werte an.
            Update: 1 von 6 Sensoren geht jetzt mal, die anderen wollen noch nicht.....
            Morgen mal neue Batterien einsetzen, dann neuer Test....
            Danke ersteinmal und einen schönen Restsonntag.
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #266
              Das ist nur ein Pflaster, keine Lösung.
              Ich vermute du hast im Objektbaum orange eingefärbte Datenpunkte - die wurden beim Update 1.x auf 2.x abgehängt und durch andere ersetzt.
              Du hast da jedenfalls eine Baustelle, die dich in der Zukunft einholen wird.
              A.
              Peter V.P 1 Antwort Letzte Antwort
                Skippy07
                #267
                ich habe gerade von 3.0.5 auf 3.1.5 upgedatet.
                Funktioniert soweit alles. Nur ist mir aufgefallen, das beim Filter (siehe Screenshot) keine Einträge mehr zu den Räumen sind. Ist das beabsichtigt oder ist ist bei mir doch was schief gelaufen?
                • AsgothianA Asgothian
                  A.
                  Peter V.P Offline
                  Peter V.P Offline
                  Peter V.
                  #268
                  @asgothian
                  Habe noch mal ganz von vorne angefangen, alle Reste gelöscht, Adapter neu installiert, Dongle reset, neu geflasht, und dann komplett neu eingerichtet, momentan läuft alles wie gewünscht, hatte da wohl irgendwo einen Fehler drin.
                  Noch ist mein ZigbeeNetz übersichtlich, was sich aber ändern kann....
                  • S Skippy07
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #269
                    @skippy07 sagte in Tester wanted - Zigbee Adapter 3.1:
                    Denkbar das da was schief ist - hatte keiner der beta-tester bisher gemeldet. Müsste in der 3.1.6 aus dem latest behoben sein.
                    Sicher bin ich nicht. Bei mir tritt der Fehler nicht (mehr) auf.
                    A.
                      A.
                      Skippy07
                      #270
                      @asgothian Habe gerade 3.1.6 installiert und schon funktioniert es wieder wie gewohnt.
                      Danke!
                        #271
                        Ich nutze noch die 3.1.5
                        Mir ist eben aufgefallen, dass sich bei zwei Steckdosen, die ich "variabel" einsetze, der über die Kachel geänderte Name in der Kachel und in den Objekten wieder zurückgesetzt hat.
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #272
                          @Homoran sagte in Tester wanted - Zigbee Adapter 3.1:
                          Mit welcher Version hattest du die geändert ? Das sollte eigentlich nicht passieren.
                          A.
                            A.
                            #273
                            @Asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
                            mit der 3.1.5
                            Das war auch "einige Zeit" geblieben.
                            Hab nur jetzt die Dosen nach aktuellem Verwendungszweck gesucht und nicht (mehr) gefunden
