  4. Anfrage Tahoma/Somfy IO Adapter
    5.1k
611 Beiträge 103 Kommentatoren 289.6k Aufrufe 86 Beobachtet
  • M mike2712
    @strathcole Denke das mit dem Token hat geklappt, aber es gibt doch einiger Meldungen
    tahoma.0
    2022-04-23 10:46:09.796	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup/gateways with payload:{}
    tahoma.0
    2022-04-23 10:45:59.782	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
    tahoma.0
    2022-04-23 10:45:59.781	debug	Update gateway status for id undefined
    tahoma.0
    2022-04-23 10:45:29.778	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup/gateways with payload:{}
    tahoma.0
    2022-04-23 10:45:19.856	warn	{"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"gateway-2006-2989-5271.local"}}
    tahoma.0
    2022-04-23 10:45:19.856	warn	setup failed!
    tahoma.0
    2022-04-23 10:45:19.854	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-************.local, request path: setup with payload:{}
    tahoma.0
    2022-04-23 10:45:19.761	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
    tahoma.0
    2022-04-23 10:45:19.760	debug	Update gateway status for id undefined
    tahoma.0
    2022-04-23 10:45:09.872	debug	stateChange tahoma.0.update {"val":false,"ack":true,"ts":1650703509865,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1639459009806}
    tahoma.0
    2022-04-23 10:45:09.868	debug	stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1650703509858,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1650703509858}
    tahoma.0
    2022-04-23 10:45:09.761	debug	GET request on https://gateway-************.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
    tahoma.0
    2022-04-23 10:45:09.759	info	Using stored bearer token 6263bc8bf4649771a996
    tahoma.0
    2022-04-23 10:45:09.753	debug	[START] Started Adapter
    StrathColeS Offline
    StrathColeS Offline
    StrathCole
    #281
    @mike2712 du solltest die Logs anonymisiert posten. Da steht deine Pin drin.
    Die Meldung heißt, dass deine Box über die URL nicht erreichbar ist. Entweder der Entwicklermodus ist nicht aktiv, die IP ist lokal nicht erreichbar oder gesperrt, oder die Firmware der Box nicht aktuell.
    SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
    M 2 Antworten Letzte Antwort
    • StrathColeS StrathCole
      mike2712
      #282
      @strathcole okay, danke, dann werde ich mal weiter danach schauen
      ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
        mike2712
        schrieb am zuletzt editiert von mike2712
        #283
        @strathcole sagte in Anfrage Tahoma/Somfy IO Adapter:
        die App sagt ist auf dem aktuellsten Stand, Version 1.9.0 März 22, im Web ist der Modus aktiviert.
        Folgende Einträge kommen kontinuierlich im Log:
        tahoma.0
        2022-04-23 15:48:35.106	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-****-*****-*****.local, request path: setup/gateways with payload:{}
        tahoma.0
        2022-04-23 15:48:25.091	debug	GET request on https://gateway-****-*****-*****.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
        tahoma.0
        2022-04-23 15:48:25.091	debug	Update gateway status for id undefined
          @willi-wunder Hi. Vermutlich hast du den Entwicklermodus nicht aktiviert. Siehe meinen Beitrag und die Infos auf der Somfy Seite
          W Offline
          W Offline
          Willi-Wunder
          #284
          @strathcole
          Vielen Dank, den Entwicklermodus hatte ich ganz überlesen, jetzt funktioniert es. :-)
          Damit sollten die erfolglosen Anmeldeversuche hoffentlich tabu sein. Sehr cool.
          G 1 Antwort Letzte Antwort
          • W Willi-Wunder
            @strathcole
            gammler2003
            schrieb am zuletzt editiert von gammler2003
            #285
            @StrathCole Vielen Dank dir auch für den Hinweis. Ich habe alle Schritte wie von dir beschrieben durchgeführt und es funktioniert. So ganz sicher bin ich mir aber nicht, ob die Tahoma tatsächlich lokal angesprochen wird oder doch über die Cloud. Kann man das irgendwo sehen?
            Edit: Habe mittlerweile herausgefunden, dass mit der neuen Installation die auf der Tahoma konfigurierten Szenen nicht funktionieren ("Action Groups" im Adapter). Also habe ich den Adapter deinstalliert und aus dem Stable neu geladen - jetzt geht wieder alles wie gehabt (und ich nutze wieder den Weg über die Cloud).
            StrathColeS 1 Antwort Letzte Antwort
            • G gammler2003
              StrathColeS Offline
              StrathColeS Offline
              StrathCole
              schrieb am zuletzt editiert von StrathCole
              #286
              @gammler2003 Action groups scheint es zumindest derzeit nur in der Cloud zu geben.
              Wenn du die Pin aus der Konfig nimmst, sollte aber Cloud auch weiterhin gehen.
              G 2 Antworten Letzte Antwort
                gammler2003
                #287
                @strathcole Hi, nur die Pin rausnehmen hatte ich zuerst probiert, hat aber leider nicht den gewünschten Erfolg gebracht. Ich meine der Adapter hat lediglich ‚gemeckert‘, dass ihm die Pin fehlt. Kann aber auch sein, dass ich zu ungeduldig war.
                Kann man den irgendwo sehen, welchen Weg der Adapter gerade nimmt (Cloud vs. lokal)? Fände ich zumindest nicht schlecht, die Info als Objekt oder im Log zu haben. Auch die Möglichkeit des einfachen Umschaltens zwischen den beiden Wegen wäre klasse.
                Viele Grüße
                StrathColeS W 2 Antworten Letzte Antwort
                • G gammler2003
                  Viele Grüße
                  StrathColeS Offline
                  StrathColeS Offline
                  StrathCole
                  #288
                  @gammler2003 Nein, eine Anzeige gibts derzeit nicht. Vielleicht hat @Excodibur in nächster Zeit noch die Zeit, meinen Code zu verbessern. Mir ging es (erst einmal) nur darum, die lokale API zu unterstützen. Aus Zeitmangel kann ich selbst nicht viel machen gerade.
                  • G gammler2003
                    Viele Grüße
                    W Offline
                    W Offline
                    wusa
                    #289
                    @gammler2003
                    Ich habe mich auch gefragt, welchen Weg der Adapter jetzt nimmt und ob ich sichergehen kann, dass es jetzt auch wirklich lokal funktioniert.
                    Ich bin dann radikal hergegangen und habe in meiner Firewall der Tahoma-Box keinen Zugriff auf das Internet gegeben. Lokal habe ich die Box aber weiterhin erreichbar gemacht.
                    Die LED von der Tahoma-Box war dann bei mir auch rot, was ja bedeutet, dass keine Internetverbindung bestellt.
                    Dann habe ich über den ioBroker Befehle an die Tahoma-Box geschickt (Rollo auf, Rollo zu) und siehe da, es funktioniert weiterhin. So weiß ich jetzt ziemlich sicher, dass Lokal alles funktioniert.
                    Ich hatte auch immer wieder Probleme mit der Cloud. Das sollte jetzt denke ich aber gegessen sein. @StrathCole Danke!
                    • W wusa
                      @gammler2003
                      StrathColeS Offline
                      StrathColeS Offline
                      StrathCole
                      #290
                      @wusa sagte in Anfrage Tahoma/Somfy IO Adapter:
                      Genau das ist auch meine Hoffnung. Vielleicht kommen ja noch ein paar Funktionen lokal, die derzeit nicht funktionieren oder nur via Workaround (Event-Listener, Szenen …).
                      Zumindest die Event-Listener sollen angeblich schon gepatcht sein und beim nächsten Firmwareupdate laufen. Der Adapter sollte das schon drin haben und dann automatisch nutzen.
                      W 1 Antwort Letzte Antwort
                        W Offline
                        W Offline
                        wusa
                        #291
                        @strathcole
                        Event-Listener sagt mir z.B. leider gar nichts. Ich vermute, dann habe ich das bisher auch nicht genutzt.
                        Kannst du mir kurz sagen, was damit gemeint ist? Vielleicht "brauche" ich es wenn es funktioniert 😉
                        • W wusa
                          @strathcole
                          StrathColeS Offline
                          StrathColeS Offline
                          StrathCole
                          #292
                          @wusa das ist eine interne Geschichte, damit er nicht alle X Sekunden alle Geräte anfragen muss, sondern nur die Ereignisse, die seit der letzten Anfrage passiert sind. Via Cloud geht das, lokal ist da ein Bug drin, sodass ich einen Fallback nutzen musste.
                            W Offline
                            W Offline
                            wusa
                            schrieb am zuletzt editiert von wusa
                            #293
                            @strathcole
                            Ok, Danke
                            Ich bin relativ froh, dass das ganze jetzt lokal funktioniert.
                            Hier im Forum ist ja zu lesen, dass einige User unter anderem auch ich schon paar mal bei Somfy /Tahoma gesperrt wurde. Da kam dann die Meldung "Auf Ebene des Servers ist ein Fehler aufgetreten".
                            Man konnte das dann nur durch Anrufen bei Somfy lösen.
                            Wenn ich das so lesen, dass so viele Anfragen bei Somfy eingehen, dann kann ich mir gut vorstellen, dass manchmal jemand gesperrt wird. Das solle aber vermutlich auch bald der Vergangenheit angehören, wenn nicht mehr so viele Anfrage bei Somfy eingehen.
                            Server werden dann ja auch ganz schön entlastet.
                            • W wusa
                              @strathcole
                              Ok, Danke
                              derdominik
                              #294
                              Hallo. Voller Freude bin ich auf die Suche nach dem Developer-Mode meiner Connexoon gegangen. Finde ihn aber nicht.
                              Gibt es den nur bei der großen Tahoma Box?
                              StrathColeS 2 Antworten Letzte Antwort
                              • D derdominik
                                StrathColeS Offline
                                StrathColeS Offline
                                StrathCole
                                #295
                                @derdominik sagte in Anfrage Tahoma/Somfy IO Adapter:
                                Das kann ich nicht beantworten. Könnte es mir aber durchaus vorstellen. Ggf. reicht die Leistung der kleinen Box nicht für einen internen API-Webserver aus …
                                • D derdominik
                                  StrathColeS Offline
                                  StrathColeS Offline
                                  StrathCole
                                  #296
                                  @derdominik Gerade geschaut. Connexxoon wird (bisher) nicht unterstützt: https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/9
                                    derdominik
                                    #297
                                    Oh auf die github issues habe ich natürlich nicht geschaut, danke für den link, @strathcole :-)
                                      mike2712
                                      #298
                                      ich bekomme das nicht am laufen, für welche Box funktioniert es? Bin echt am verzweifeln, vielleicht geht es bei meiner Box gar nicht, ich habe die Somfy TaHoma Switch?
                                      • M mike2712
                                        W Offline
                                        W Offline
                                        wusa
                                        #299
                                        @mike2712
                                        Hast du den Developer Mode, wenn du dich einloggst? Auf Github ist nur von TaHoma die Rede.
                                        Da könnte die Switch eigentlich darunter fallen.
                                        • L Offline
                                          Lucky 0
                                          #300
                                          Moin,
                                          ich habe den Developer-Modus aktiviert,
                                          Adapter wie besprochen installiert,
                                          habe Usernamen, Passwort und PIN eingegeben.
                                          Die Instanz startete auch erfolgsversprechend:
                                          Got token for local api: 6274.......
                                          aber dann:
                                          tahoma.0
                                          2022-05-06 10:30:21.950	warn	error during request: Error: getaddrinfo ENOTFOUND gateway-1XXX-7XXX-6XXX.local, request path: setup/gateways with payload:{}
                                          tahoma.0
                                          2022-05-06 10:30:11.981	warn	{"error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"gateway-1XXX-7XXX-6XXX.local"}}
                                          tahoma.0
                                          2022-05-06 10:30:11.981	warn	setup failed!
                                          tahoma.0
                                          2022-05-06 10:30:11.981	warn	error during request: Error: getaddrinfo ENOTFOUND gateway-1XXX-7XXX-6XXX.local, request path: setup with payload:{}
                                          Die URL https://gateway-1XXX-7XXX-6XXX.local:8443/enduser-mobile-web/1/enduserAPI/
                                          ist im Browser erreichbar.
                                          User, Passwort, PIN und aktivierten Entwicklermodus habe ich mehrfach überprüft.
                                          Firmware der Tahoma Box Premium ist aktuell
                                          Kann mir jemand weiterhelfen?
