  4. Shelly Adapter - genereller Support
mcm1957shelly
525 Beiträge 72 Kommentatoren 74.0k Aufrufe 53 Beobachtet
    docsnyder7
    schrieb am zuletzt editiert von docsnyder7
    #381
    [httpIoBrokerState] Error for state shelly2pmg3#e4b323332644#1.rssi for 192.168.178.157 (shelly2pmg3 / shelly2pmg3-e4b323332644 / shelly2pmg3#e4b323332644#1) "/rpc/Shelly.GetStatus": SyntaxError: Expected ':' after property name in JSON at position 650 (line 1 column 651) - value: "{"ble":{},"bthome":{"errors":["bluetooth_disabled"]},"cloud":{"connected":true},"cover:0":{"id":0, "source":"init", "state":"open","apower":0.0,"voltage":229.4,"current":0.000,"pf":0.00,"freq":50.0,"aenergy":{"total":7.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1774003200},"temperature":{"tC":42.3, "tF":108.1},"pos_control":true,"last_direction":null,"current_pos":100},"input:0":{"id":0,"state":null},"input:1":{"id":1,"state":null},"knx":{},"matter":{"num_fabrics":0,"commissionable":false},"mqtt":{"connected":true},"sys":{"mac":"E4B323332644","restart_required":false,"time":"05:40","unixtime":1774003203,"last_sync_ts":1774002627,"uptime">9236,"ram_size":257820,"ram_free":125688,"ram_min_free":114344,"fs_size":786432,"fs_free":303104,"cfg_rev":31,"kvs_rev":0,"schedule_rev":1,"webhook_rev":1,"btrelay_rev":0,"bthc_rev":0,"available_updates":{},"reset_reason":4,"utc_offset":-18000},"wifi":{"sta_ip":"192.168.178.157","status":"got ip","ssid":"FRITZ!Box 7490","bssid":"50:e6:36:53:64:3b","rssi":-57,"sta_ip6":["fe80::e6b3:23ff:fe33:2644","2a00:6020:439b:7b00:e6b3:23ff:fe33:2644"]},"ws":{"connected":false}}"
    Keine Bewegung im Rollo, aber diese Meldung..
    betrifft auch nur einen der beiden neu verbauten Shelly 2 pm gen3... hab versucht Unterschiede in der Konfiguration herauszufinden...bin noch nicht fündig geworden
    in der shelly cloud hab ich eben gesehen, dass der Status der Position "undefined" war. Hab die kalibrierung nochmal angestoßen
    • haus-automatisierungH Offline
      #382
      Das sind doch alles Daten, welche vom Shelly direkt kommen. Da schleichen sich immer wieder Zeichen ein, welche das JSON ungültig machen. Welche Firmware ist auf den Geräten installiert?
      "last_direction&:"open"
      &enable":false
      "uptime">9236
      📚 Meine Dokumentation
      • mcm1957M Online
        mcm1957M Online
        mcm1957
        #383
        siehe auch: https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1393
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          #384
          Zusatzfrage;
          Hast du Energy-Save Mode bei dem Shelly aktiv?
          Aber in jedem Fall gib mal Bescheid welche Firmwareversionen da laufen. Shelly hat da in letzter Zeit ein wenig Probleme (Plug 1L lifert definitiv falsche Werte, Plug S Gen 3 u Plug PM sterben bei PLUG_UI Paketen. Zu beiden ist tw. seit längerem ein Issue offen ...)
          • mcm1957M mcm1957
            Zusatzfrage;
            docsnyder7
            #385
            @mcm1957 auf beiden Shelly 2pm ist die 1.7.4-gf9878b6
            aber Fehler kommen nur von einem
            • mcm1957M Online
              mcm1957M Online
              mcm1957
              #386
              Mach sicherheitshalber mal ein Ticket bei Shelly auf. Und schick ihnen dass da nur von einem Shelly "unsinnige" Daten kommen.
              Ev. tauschen sie das Ding ja aus oder können da noch mehr testen.
              Alternativ kannst du - wenn du ein wenig scripten kannst - auf der Commandline in einer Schleife via curl Lesebefehle absetzen und schaun ob da auch Schritt kommt.
              • D docsnyder7
                docsnyder7
                #387
                sagte in Shelly Adapter - genereller Support:
                jepp... beide gleich, auch sämtliche Einstellungen sind identisch. Evt hat der doch ne MAcke..
                das Ticket bei shelly ist eröffnet.
                Danke Euch für die Hilfe hierbei
                kann es an der falschen Geoposition gelegen haben? die war aber noch bei beiden falsch...
                • mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #388
                  Wüsste nicht wie die falsche Position u gültige Zeichen in den json scheiben sollte.
                  Also meiner Ansicht nach "nein"
                  • NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #389
                    Hallo
                    Meine Plug S Gen 1 zeigen in shelly.1.SHPLG-S#C52B63#1.Relay0.Power nur 0 W.
                    Letzte Woche wurde der Wert noch korrekt übermittelt.
                    Adapter: 10.6.1
                    Plug S FW: 20230913-113421/v1.14.0-gcb84623
                    PS:
                    gerade im Log gesehn
                    shelly.0 2026-03-24 10:38:02.156	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25) at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29) at processImmediate (node:internal/timers:487:21)
                    shelly.0 2026-03-24 10:38:02.031	error	unhandled promise rejection: DB closed
                    shelly.0 2026-03-24 10:38:02.029	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    ° Fixer ---> iob fix
                    da_WoodyD mcm1957M 2 Antworten Letzte Antwort
                    • NegaleinN Negalein
                      Hallo
                      Adapter: 10.6.1
                      PS:
                      da_WoodyD Offline
                      da_WoodyD Offline
                      da_Woody
                      #390
                      @Negalein sers mein freund! ;)
                      hab zwar mit redis nix am hut, aber ich denk mal, da hast du ein problem. nix mit shelly.
                      für dich getestet an meinem laser.
                      same adapterversion, same FW.
                      in den objekten und in iQontrol alles fein...
                      gruß vom Woody
                      • da_WoodyD da_Woody
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #391
                        @da_Woody sagte in Shelly Adapter - genereller Support:
                        ok, hoff es kommt noch wer der da Bescheid weiss.
                          Hallo
                          Adapter: 10.6.1
                          PS:
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #392
                          @Negalein sagte in Shelly Adapter - genereller Support:
                          Sorry für lange Reaktionszeit - im Moment weiß ich ehrlich nicht mehr was ich zuerst tun soll :-)
                          Verzeih zuerst mal die Standardfragen:
                          • Am shelly selbst (via Webinterface) bzw. in der App werden die Werte angezeigt. Hast du das geschecked?
                          • Hat sich irgendwas in der letzten Zeit an deinem Netzwerk verändert? Restart Router, neue Netzwerkkomponenten, ... ?
                          • Ich nehme mal an die Shelly GEN1 laufen via COAP (und nicht mqtt). Hast du gecheck dass dort unicast und nicht multicast eingestellt ist? Siehe https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md#coap-coiot
                          • Stell die Instanz mal auf DEBUG Log un schau ob von den betroffenen Shellies Daten (insbesonderer Leistungswerte) empfangen werden.
                          Hinweis:
                          Der Onlinestatus besagt nur dass der Shelly via http erreichbar ist. Das muss nicht heißen dass der Shelly seinerseits den ioBroker erreichen kann. Ist unschön ist aber so. Ein grüner Onlinestatus des Shellies sagt also noch nicht aus dass die Coap Confihg am Shelly passt.
                          Bei der Fehlermeldung kommt es drauf an wann bzw. inw elchem Zusammenhang du die im Log hast. Beim Shutdown einer Instanz kann dieser Fehler aufterten. Er sollte zwar seit dem letzten Update verhindert werden - aber das ist nicht zu 100% gesichert. Wenn er bei laufendem System auftritt, d.h nicht beim Shutdown / Restart deiner Shelly Instanz dann ist was in der DB sagen wior mal überprüfungswürdig. Da steig ich mit meinem Wissenstand aber aus. iob diag kann aber nie schaden.
                          Aber schau zuerst mal die obigen Punkte - vor allem die unicast Einstellung seh ich mal als heißen Kandidaten...
                          • mcm1957M mcm1957
                            Hinweis:
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #393
                            @mcm1957 sagte in Shelly Adapter - genereller Support:
                            Sorry für lange Reaktionszeit - im Moment wei´ich ehrlichniocht mehr was ich zuerst tun soll :-)
                            kein Problem
                            Danke, das wars.
                            Der doofe Test-HA hat dort selbstständig die IP vom HA eingetragen.
                            • KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              schrieb am zuletzt editiert von Kusselin
                              #394
                              Hallo Zusammen,
                              ich habe meinen Shelly 3EM pro ja schon einige zeit...nun wollte ich aber das ich die Möglichkeit habe wenn wir Überschuss haben diese auch messen (also die Werte die dann ins Netz an den Netzanbieter gehen messen....
                              Also habe ich den MQTT Adapter installiert udn habe im Shelly die MQTT daten eingegeben....was auch funktioniert hat...anbei mal ein Screenshot der Objekte die angelegt wurden....leider habe ich keien Ahnung was nun was ist.....habe was gelesen das ich "Aliase" anlegen muss??
                              Was muss ich da verwenden?? em:0
                              Was ist das emdata:0 ?
                              Kann ich das irgendwo nachlesen aber auch so das es verstehe?
                              Über ne Rückinfo herzlichen Dank
                              P.S.: Über den aktuellen Shelly adapter ghts glaub ich auch jetzt oder? Wenn ja wäre es über diesen sinnvoller und die datenpunkte da auch besser?
                              • mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #395
                                Na ja - Konkurrenz muss man halt abschalten :-)
                                Bin froh dass ich helfen konnte.
                                • mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #396
                                  Da ich den Shelly Adapter mit betreue muss ich natürlich sagen, der ist die bessere Wahl :-).
                                  Im Prinzip kommts drauf an was du erreichen willst. Im mqtt Adapter bekommst du die Rpohdaten so wie sie der Shelly schickt. Der Shelly Adapter bereite diese auf und stellt States für die einzelnen Infos bereit. Wenn du also nicht direkt mit den json Paketen des Shellies arbeiten willst dann ist m.E. der Shelly Adapetr die bessere Wahl.
                                  Der 3EM Pro sollte mit der aktuellen Shelly Adapter Version voll unterstützt sein.
                                  Edit:
                                  In deinem Screenshot fehlen States des Shelly Adapters. Ich vermute mal du hast den Shelly nicht richtig aufgesetzt.
                                  Hier 2 Screenshots meines aktiven Pro 3EM
                                  • KusselinK Offline
                                    KusselinK Offline
                                    Kusselin
                                    #397
                                    deshalb frage ich ja hier im Board...anscheinend ging das nicht erst mit dem Shelly adapter...dann gehts jetzt...o.k.
                                    so sieht meine Konfig vom shelly adapter aus....ich habe noch shelly1 und 1PMs..
                                    Wie bekomme ich jetzt aber wieder den shelly 3EM pro in die Objekte vom aktuellen shelly adapter?
                                    • mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #398
                                      ALLE Gen 2+ (d.h. Pro und neuer) brauchen MQTT Kommunikation und nicht COAP.
                                      Dazu musst du eine zweite Instanz einrichten
                                      Ist das https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-mqtt.md sehr gut beschrieben.
                                      Wenns um den Shelly Adapter und die Einrichtung geht, bitte im Shelly Support Topic weiter diskutieren:
                                      https://forum.iobroker.net/topic/81297/shelly-adapter-genereller-support
                                      Wenn du mqtt abhakst, kannst du auch gerne @homoran das OK geben diesen Thread an den Shelly Support Topic anzuhängen.
                                      • KusselinK Offline
                                        KusselinK Offline
                                        Kusselin
                                        #399
                                        Ich habe shelly der 1. Gen im Einsatz sowie 2x 1PM (die roten), 2x shelly rgbw und den besagten 3EM pro...
                                        Am Anfang hatte ich mit den Shelly 1 das MQTT eingestellt und nicht COAP....dann hings aber .....
                                        O.K: dann müsste ich einen zweite Shelly Instanz anlegen udn dort dann MQTT wählen udn dann sollte der 3EM pro in der zweiten Shelly instanz auftauchen...richtig?
                                        Ich muss halt zwei Instanzen laufen lassen da ich halt noch shellies der 1. Gen also den Shelly 1 habe..richtig? wills nur verstehen...
                                        • KusselinK Kusselin
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #400
                                          @Kusselin sagte in Shelly 3EM pro mit MQTT Adapter und dann auslesen...:
                                          Ja genau
                                          1 Instanz für COAP (Gen 1 Shellies)
                                          1 Instanz für MQTT (Gen 2+ Shellies = PR, Gen 2, Gen 3, Gen 4, BLE, ...)
                                          Bitte lies die Anleitung zum Einrichten durch. Insbesondere alle 3 Hakerl im Shelly mqtt sind wichtig damit er alles sendet. Und beachte dass die mqtt Instanz eine ander Portnummer hat (haben muss) als der mqtt Adapter.
                                          KusselinK 1 Antwort Letzte Antwort
