  4. Zigbee, keine Aktion und keinerlei Verbindungen
31 Beiträge 3 Kommentatoren 4.6k Aufrufe 3 Beobachtet
  • AsgothianA Asgothian
    @alexzi Please test this:
    • stop the adapter
    • unplug the stick
    • rename the file nvbackup.json to nvbackup.old
    • plug the stick in
    • start the adapter
    • try to switch the test plug
    • post the log
    A.
    alexzi
    @asgothian
    2025-02-06 15:14:24.682 - info: zigbee.0 (3396) Zigbee started
    2025-02-06 15:14:25.136 - info: zigbee.0 (3396) debug devices set to ["84ba20fffe77b850"]
    2025-02-06 15:14:25.890 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"available":true}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated 'true' from device 84ba20fffe77b850 for 'Available'
    2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":10}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated '10' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:15:07.510 - warn: zigbee.0 (3396) ELEVATED O1: User state change of state zigbee.0.84ba20fffe77b850.state with value false (ack: false) from system.adapter.admin.0
    2025-02-06 15:15:07.517 - warn: zigbee.0 (3396) ELEVATED O2: Change state 'state' at device 0x84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:15:07.524 - warn: zigbee.0 (3396) ELEVATED O3C: Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]}
    2025-02-06 15:15:07.526 - warn: zigbee.0 (3396) ELEVATED O4: convert state, "OFF", {} for device 0x84ba20fffe77b850 with Endpoint state
    A 1 Antwort Letzte Antwort
    • A alexzi
      @asgothian
      alexzi
      2025-02-06 15:15:59.296 - info: zigbee.0 (3396) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
      2025-02-06 15:16:00.674 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":51,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:00.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":51}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:00.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '51' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:00.875 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:01.077 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:01.271 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:01.470 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:01.676 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:01.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:01.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:01.876 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:02.070 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:02.272 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:02.284 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:02.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:02.468 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:02.480 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:02.481 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:02.669 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:02.866 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:02.878 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:02.879 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:03.068 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:03.123 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:03.124 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:03.265 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:03.477 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
      2025-02-06 15:16:03.490 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:16:03.491 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:16:26.028 - info: admin.0 (909) <== Disconnect system.user.admin from ::ffff:10.100.200.45
      • A alexzi
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @alexzi Dann sehe ich aktuell nur die Möglichkeit das du auf den Adapter Version 1.10.3 zurück gehst.
        A.
          alexzi
          @asgothian
          ich heul.
          hab jetzt mit npm install iobroker.zigbee@1.10.3 ein Downgrade gemacht.
          Jetzt geht gar nichts mehr.
          iobroker fix schon gemacht
          diag sag 1.10.3 installiert
          uffff
          tut mir echt leid, dass ich nicht weiterkomme und euch auf den Nerv gehe
          2025-02-06 18:07:18.159 - error: zigbee.0 (3168) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
          2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Failed to start Zigbee
          2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Error herdsman start
          Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
          • A alexzi
            @asgothian
            ich heul.
            uffff
            @alexzi sagte in Zigbee, keine Aktion und keinerlei Verbindungen:
            Macht man ja auch nicht so...
            iob upgrade adapter@ziel.vers.ion
            ist der bessere Weg.
            • A alexzi
              @asgothian
              ich heul.
              uffff
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              uffff
              Such mal bitte die korrekte Fehlermeldung. Die die du gepostet hast ist eine Folgemeldung, die beim 2. oder 3. Startversuch entsteht.
              A.
                alexzi
                oh Mann, wieder Layer 8, grrr
                gemacht, Meldung kam, sauber installiert. geht aber immer noch nicht
                  uffff
                  A.
                  alexzi
                  @asgothian
                  meinst du das?
                  2025-02-06 18:45:11.091 - info: zigbee.0 (6526) Starting Zigbee npm ...
                  2025-02-06 18:45:11.449 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                  2025-02-06 18:45:12.127 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                  2025-02-06 18:45:12.128 - error: zigbee.0 (6526) Failed to start Zigbee
                  2025-02-06 18:45:12.129 - error: zigbee.0 (6526) Error herdsman start
                  2025-02-06 18:45:22.133 - info: zigbee.0 (6526) Try to reconnect. 1 attempts left
                  2025-02-06 18:45:22.136 - info: zigbee.0 (6526) Starting Zigbee npm ...
                  2025-02-06 18:45:22.175 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                  2025-02-06 18:45:22.337 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                  2025-02-06 18:45:22.338 - error: zigbee.0 (6526) Failed to start Zigbee
                  2025-02-06 18:45:22.339 - error: zigbee.0 (6526) Error herdsman start
                  • A alexzi
                    @asgothian
                    meinst du das?
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @alexzi bitte nochmal
                    • adapter anhalten
                    • stick abziehen
                    • 30 sekunden warten
                    • stick anstecken
                    • die nvbackup.json Datei löschen
                    • adapter starten
                    Dann sollte es gehen
                      • adapter anhalten
                      • stick abziehen
                      • stick anstecken
                      • adapter starten
                      alexzi
                      @asgothian HALLELUJA Adapter läuft, Testschaltung hat auch funktioniert. DANKE
                      ich warte noch bis morgen, wenn es soweit ok aussieht, dann setze ich den Thread auf Gelöst
                      @Thomas-Braun Dir auch vielen Dank
                      • A alexzi
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @alexzi kannst du mit die shepherd.db hier zukommen lassen ? ich will nach etwas schauen
                        A.
