  4. Zigbee, keine Aktion und keinerlei Verbindungen
31 Beiträge 3 Kommentatoren 4.6k Aufrufe 3 Beobachtet
  • A alexzi
    @asgothian
    2025-02-06 15:14:24.682 - info: zigbee.0 (3396) Zigbee started
    2025-02-06 15:14:25.136 - info: zigbee.0 (3396) debug devices set to ["84ba20fffe77b850"]
    2025-02-06 15:14:25.890 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"available":true}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated 'true' from device 84ba20fffe77b850 for 'Available'
    2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":10}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated '10' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:15:07.510 - warn: zigbee.0 (3396) ELEVATED O1: User state change of state zigbee.0.84ba20fffe77b850.state with value false (ack: false) from system.adapter.admin.0
    2025-02-06 15:15:07.517 - warn: zigbee.0 (3396) ELEVATED O2: Change state 'state' at device 0x84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:15:07.524 - warn: zigbee.0 (3396) ELEVATED O3C: Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]}
    2025-02-06 15:15:07.526 - warn: zigbee.0 (3396) ELEVATED O4: convert state, "OFF", {} for device 0x84ba20fffe77b850 with Endpoint state
    alexzi
    2025-02-06 15:15:59.296 - info: zigbee.0 (3396) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    2025-02-06 15:16:00.674 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":51,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:00.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":51}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:00.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '51' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:00.875 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:01.077 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:01.271 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:01.470 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:01.676 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:01.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:01.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:01.876 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:02.070 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:02.272 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:02.284 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:02.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:02.468 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:02.480 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:02.481 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:02.669 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:02.866 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:02.878 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:02.879 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:03.068 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:03.123 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:03.124 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:03.265 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:03.477 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
    2025-02-06 15:16:03.490 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
    2025-02-06 15:16:03.491 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
    2025-02-06 15:16:26.028 - info: admin.0 (909) <== Disconnect system.user.admin from ::ffff:10.100.200.45
    • A alexzi
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @alexzi Dann sehe ich aktuell nur die Möglichkeit das du auf den Adapter Version 1.10.3 zurück gehst.
      A.
        alexzi
        @asgothian
        ich heul.
        hab jetzt mit npm install iobroker.zigbee@1.10.3 ein Downgrade gemacht.
        Jetzt geht gar nichts mehr.
        iobroker fix schon gemacht
        diag sag 1.10.3 installiert
        uffff
        tut mir echt leid, dass ich nicht weiterkomme und euch auf den Nerv gehe
        2025-02-06 18:07:18.159 - error: zigbee.0 (3168) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
        2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Failed to start Zigbee
        2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Error herdsman start
        Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
        • A alexzi
          @asgothian
          ich heul.
          uffff
          @alexzi sagte in Zigbee, keine Aktion und keinerlei Verbindungen:
          Macht man ja auch nicht so...
          iob upgrade adapter@ziel.vers.ion
          ist der bessere Weg.
          • A alexzi
            @asgothian
            ich heul.
            uffff
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            uffff
            Such mal bitte die korrekte Fehlermeldung. Die die du gepostet hast ist eine Folgemeldung, die beim 2. oder 3. Startversuch entsteht.
            A.
              alexzi
              oh Mann, wieder Layer 8, grrr
              gemacht, Meldung kam, sauber installiert. geht aber immer noch nicht
              • AsgothianA Asgothian
                uffff
                A.
                alexzi
                @asgothian
                meinst du das?
                2025-02-06 18:45:11.091 - info: zigbee.0 (6526) Starting Zigbee npm ...
                2025-02-06 18:45:11.449 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                2025-02-06 18:45:12.127 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                2025-02-06 18:45:12.128 - error: zigbee.0 (6526) Failed to start Zigbee
                2025-02-06 18:45:12.129 - error: zigbee.0 (6526) Error herdsman start
                2025-02-06 18:45:22.133 - info: zigbee.0 (6526) Try to reconnect. 1 attempts left
                2025-02-06 18:45:22.136 - info: zigbee.0 (6526) Starting Zigbee npm ...
                2025-02-06 18:45:22.175 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                2025-02-06 18:45:22.337 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                2025-02-06 18:45:22.338 - error: zigbee.0 (6526) Failed to start Zigbee
                2025-02-06 18:45:22.339 - error: zigbee.0 (6526) Error herdsman start
                • A alexzi
                  @asgothian
                  meinst du das?
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @alexzi bitte nochmal
                  • adapter anhalten
                  • stick abziehen
                  • 30 sekunden warten
                  • stick anstecken
                  • die nvbackup.json Datei löschen
                  • adapter starten
                  Dann sollte es gehen
                    • adapter anhalten
                    • stick abziehen
                    • stick anstecken
                    • adapter starten
                    alexzi
                    @asgothian HALLELUJA Adapter läuft, Testschaltung hat auch funktioniert. DANKE
                    ich warte noch bis morgen, wenn es soweit ok aussieht, dann setze ich den Thread auf Gelöst
                    @Thomas-Braun Dir auch vielen Dank
                    • A alexzi
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @alexzi kannst du mit die shepherd.db hier zukommen lassen ? ich will nach etwas schauen
                      A.
