  4. Update von nodejs auf 20.x schiefgegangen?
25 Beiträge 4 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • L Offline
    legro
    Heute habe ich nodejs auf die empfohlene Version 20.x aktualisiert. Nun erhalte ich Fehlermeldungen im Log ..
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: Node.js v20.18.1
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: }
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12) {
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/socketcan/dist/socketcan.js:51:26)
    host.raspiBullseye
    2024-12-14 12:23:31.303	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1586:18)
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: Error: Module did not self-register: '/opt/iobroker/node_modules/socketcan/build/Release/can.node'.
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: ^
    host.raspiBullseye
    2024-12-14 12:23:31.302	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.raspiBullseye
    2024-12-14 12:23:31.301	error	Caught by controller[0]: node:internal/modules/cjs/loader:1586
    host.raspiBullseye
    2024-12-14 12:23:29.894	info	instance system.adapter.e3oncan.0 in version "0.10.3" started with pid 3890
    host.raspiBullseye
    2024-12-14 12:22:58.362	info	Restart adapter system.adapter.e3oncan.0 because enabled
    host.raspiBullseye
    2024-12-14 12:22:58.362	error	instance system.adapter.e3oncan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Was habe ich ggf. falsch gemacht?
    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
    • L legro
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      host.raspiBullseye
      @legro sagte in Update von nodejs auf 20.x schiefgegangen?:
      Was hast du denn gemacht?
      iob nodejs-update
      oder was?
      Schau dir per
      iob diag
      den Ist-Zustand an.
      L 1 Antwort Letzte Antwort
        iob nodejs-update
        oder was?
        Schau dir per
        iob diag
        den Ist-Zustand an.
        legro
        schrieb am zuletzt editiert von legro
        Ich habe iobroker nodejs-update eingegeben, weil dies ja die Installation ebenfalls überprüft. Herausgekommen ist dies ..
        ioBroker nodejs fixer 2024-10-10
        Recommended nodejs-version is: 20.18.1
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs 	v20.18.1
        /usr/bin/node 		v20.18.1
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.29.4
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
        Nothing to do - Your installation is using the correct paths.
        Nothing to do - Your version is the recommended one.
        ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
        *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
         *** DO NOT use 'nodejs-update' as part of a regular update process! ***
        Ich dachte natürlich, hurra - es ist alles in Ordnung. Leider ist dem nicht so.
        iob diag liefert ..
        Copy text starting here:
        ```bash
        			v.2024-10-19
         Static hostname: raspiBullseye
               Icon name: computer
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		64 bit
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        Display-Server: 	false
        Boot Target: 		multi-user.target
        Pending OS-Updates: 	0
        Pending iob updates: 	1
        Nodejs-Installation:
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            8.2G        3.3G        3.6G        1.1M        1.4G        4.9G
        Swap:           209M          0B        209M
        Total:          8.4G        3.3G        3.8G
        Active iob-Instances: 	32
        Upgrade policy: none
        ioBroker Core: 		js-controller 		7.0.3
        			admin 			7.1.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspiBullseye                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : raspiBullseye                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects: 		20716
        States: 		17417
        Size of iob-Database:
        50M	/opt/iobroker/iobroker-data/objects.jsonl
        17M	/opt/iobroker/iobroker-data/states.jsonl
        Operating System is the current Debian stable version codenamed 'bookworm'!
        Die Langversion ist in Arbeit und poste ich gleich.
        haselchenH Thomas BraunT 3 Antworten Letzte Antwort
        • L legro
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          nodejs:
            Version table:
          iob diag liefert ..
          ```bash
          			v.2024-10-19
                 Icon name: computer
              Architecture: arm64
          Kernel: 		aarch64
          Userland: 		64 bit
          User-ID: 		1000
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          MEMORY:
          Swap:           209M          0B        209M
          			admin 			7.1.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		20716
          States: 		17417
          haselchenH Offline
          haselchenH Offline
          haselchen
          @legro
          Ist kein Node 20 Fehler.
          Hat mit dem Adapter zu tun.
          Da steht zwar Node22 , aber in dem Issue wird Dein Fehler aus dem Log behandelt.
          https://github.com/MyHomeMyData/ioBroker.e3oncan/issues/65
          • L legro
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            nodejs:
              Version table:
            iob diag liefert ..
            ```bash
            			v.2024-10-19
                   Icon name: computer
                Architecture: arm64
            Kernel: 		aarch64
            Userland: 		64 bit
            User-ID: 		1000
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            MEMORY:
            Swap:           209M          0B        209M
            			admin 			7.1.5
            Objects type: jsonl
            States  type: jsonl
            Objects: 		20716
            States: 		17417
            iobroker nodejs-updatiob diag
            ist ja auch Quatsch...
            iob diag
            muss das heißen.
            Rasperry ggfls. mit der Testversion von hier anpacken:
            https://forum.iobroker.net/topic/59549/iob-diag-skript
            • L legro
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              nodejs:
                Version table:
              iob diag liefert ..
              ```bash
              			v.2024-10-19
                     Icon name: computer
                  Architecture: arm64
              Kernel: 		aarch64
              Userland: 		64 bit
              User-ID: 		1000
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              MEMORY:
              Swap:           209M          0B        209M
              			admin 			7.1.5
              Objects type: jsonl
              States  type: jsonl
              Objects: 		20716
              States: 		17417
              haselchenH Offline
              haselchenH Offline
              haselchen
              @legro
              Das ist vermutlich die Lösung vom Entwickler
                iob diag
                muss das heißen.
                legro
                Hier die Langversion ..
                bash
                Script v.2024-10-19
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Model		: Raspberry Pi 4 Model B Rev 1.5
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 12:44:37 up 32 min,  3 users,  load average: 0.85, 1.08, 1.09
                CPU threads: 4
                *** LIFE CYCLE STATUS ***
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** TIME AND TIMEZONES ***
                               Local time: Sat 2024-12-14 12:44:37 CET
                           Universal time: Sat 2024-12-14 11:44:37 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
                *** DISPLAY-SERVER SETUP ***
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Mem:            8.2G        3.0G        3.9G        1.1M        1.4G        5.2G
                Swap:           209M          0B        209M
                Total:          8.4G        3.0G        4.1G
                         7812 M total memory
                         2886 M used memory
                         3054 M active memory
                          783 M inactive memory
                         3722 M free memory
                          155 M buffer memory
                         1186 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 12:44:38 up 32 min,  3 users,  load average: 0.86, 1.08, 1.09
                Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 57.1 us, 14.3 sy,  0.0 ni, 28.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   7812.3 total,   3722.4 free,   2886.9 used,   1341.8 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4925.4 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                No critical errors detected
                *** FILESYSTEM ***
                /dev/root      ext4       29G   16G   12G  58% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     1.6G  932K  1.6G   1% /run
                tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                /dev/mmcblk0p1 vfat      253M   33M  220M  13% /boot
                tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                [Sat Dec 14 12:12:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:AC:B4:A2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=5ace6bce-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sat Dec 14 12:12:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sat Dec 14 12:12:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Sat Dec 14 12:12:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                Show mounted filesystems:
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                6.0G	/var/
                2.9G	/var/lib
                2.6G	/var/log
                2.5G	/var/log/journal/71ce3d9ea88f4118a23250ffbeda1105
                Journal file /var/log/journal/71ce3d9ea88f4118a23250ffbeda1105/system@000617b59b4419c3-7f20c1d2455234ec.journal~ is truncated, ignoring file.
                Archived and active journals take up 2.4G in the file system.
                /opt/iobroker/backups:
                805M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                1.4G	/opt/iobroker/iobroker-data/
                1.1G	/opt/iobroker/iobroker-data/files
                617M	/opt/iobroker/iobroker-data/files/javascript.admin
                560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                USB-Devices by-id:
                No Devices found 'by-id'
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                *** NodeJS-Installation ***
                /usr/bin/npm 		10.8.2
                /usr/bin/npx 		10.8.2
                nodejs:
                  Version table:
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                raspiBullseye       raspiBullseye (version: 7.0.3, hostname: raspiBullseye , alive, uptime: 1907)
                Core adapters versions
                js-controller: 	7.0.3
                admin: 		7.1.5
                javascript: 	8.8.3
                nodejs modules from github: 	0
                Adapter State
                + system.adapter.backitup.0               : backitup              : raspiBullseye                            -  enabled
                  system.adapter.birthdays.0              : birthdays             : raspiBullseye                            -  enabled
                  system.adapter.bydhvs.0                 : bydhvs                : raspiBullseye                            - disabled
                + system.adapter.daikin.0                 : daikin                : raspiBullseye                            -  enabled
                + system.adapter.daikin.1                 : daikin                : raspiBullseye                            -  enabled
                + system.adapter.daikin.2                 : daikin                : raspiBullseye                            -  enabled
                  system.adapter.daswetter.0              : daswetter             : raspiBullseye                            -  enabled
                + system.adapter.device-reminder.0        : device-reminder       : raspiBullseye                            -  enabled
                + system.adapter.discovery.0              : discovery             : raspiBullseye                            -  enabled
                  system.adapter.dwd.0                    : dwd                   : raspiBullseye                            -  enabled
                  system.adapter.e3oncan.0                : e3oncan               : raspiBullseye                            -  enabled
                + system.adapter.echarts.0                : echarts               : raspiBullseye                            -  enabled
                  system.adapter.feiertage.0              : feiertage             : raspiBullseye                            -  enabled
                  system.adapter.flexcharts.0             : flexcharts            : raspiBullseye                            -  enabled
                + system.adapter.fronius.0                : fronius               : raspiBullseye                            -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : raspiBullseye                            -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : raspiBullseye                            -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : raspiBullseye                            -  enabled, port: 42010
                + system.adapter.hue.0                    : hue                   : raspiBullseye                            -  enabled, port: 80
                  system.adapter.ical.0                   : ical                  : raspiBullseye                            -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspiBullseye                            -  enabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspiBullseye                            -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : raspiBullseye                            -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspiBullseye                            -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspiBullseye                            -  enabled
                + system.adapter.influxdb.0               : influxdb              : raspiBullseye                            -  enabled, port: 8086
                + system.adapter.javascript.0             : javascript            : raspiBullseye                            -  enabled
                  system.adapter.modbus.0                 : modbus                : raspiBullseye                            - disabled
                  system.adapter.modbus.1                 : modbus                : raspiBullseye                            - disabled
                  system.adapter.modbus.2                 : modbus                : raspiBullseye                            - disabled
                + system.adapter.netatmo.0                : netatmo               : raspiBullseye                            -  enabled
                + system.adapter.nuki-extended.0          : nuki-extended         : raspiBullseye                            -  enabled
                + system.adapter.pushover.0               : pushover              : raspiBullseye                            -  enabled
                + system.adapter.rpi2.0                   : rpi2                  : raspiBullseye                            -  enabled
                + system.adapter.scenes.0                 : scenes                : raspiBullseye                            -  enabled
                + system.adapter.shelly.0                 : shelly                : raspiBullseye                            -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : raspiBullseye                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspiBullseye                            -  enabled
                + system.adapter.telegram.0               : telegram              : raspiBullseye                            -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : raspiBullseye                            -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : raspiBullseye                            -  enabled
                + system.adapter.tuya.0                   : tuya                  : raspiBullseye                            -  enabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspiBullseye                            -  enabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspiBullseye                            -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspiBullseye                            -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspiBullseye                            -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspiBullseye                            -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspiBullseye                            -  enabled
                  system.adapter.vis-map.0                : vis-map               : raspiBullseye                            -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : raspiBullseye                            -  enabled
                  system.adapter.vis-metro.0              : vis-metro             : raspiBullseye                            -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspiBullseye                            -  enabled
                  system.adapter.vis.0                    : vis                   : raspiBullseye                            -  enabled
                + system.adapter.yahka.0                  : yahka                 : raspiBullseye                            -  enabled
                + system.adapter.zigbee.0                 : zigbee                : raspiBullseye                            -  enabled, port: tcp://192.168.4.92:6638
                + instance is alive
                ioBroker-Repositories
                │ (index) │ name          │ url                                                     │ auto upgrade │
                │ 0       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                │ 1       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                │ 2       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                │ 3       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
                Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                Adapter    "e3oncan"      : 0.10.3   , installed 0.10.3
                Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                Adapter    "fronius"      : 2.1.1    , installed 1.1.3  [Updatable]
                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                Adapter    "hue"          : 3.13.1   , installed 3.13.1
                Adapter    "ical"         : 1.16.1   , installed 1.16.1
                Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                Controller "js-controller": 7.0.3    , installed 7.0.3
                Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                Objects and States
                Objects: 	20716
                States: 	17408
                Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://deb.debian.org/debian bookworm InRelease
                Hit:4 https://apt.grafana.com stable InRelease
                Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:6 https://repos.influxdata.com/debian stable InRelease
                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12093      992/dnsmasq
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16689      1112/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1995       1112/iobroker.js-co
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15170      983/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:43165         0.0.0.0:*               LISTEN      1001       20190      2952/io.yahka.0
                tcp        0      0 192.168.4.72:42010      0.0.0.0:*               LISTEN      1001       18261      2425/io.hm-rpc.1
                tcp        0      0 192.168.4.72:42001      0.0.0.0:*               LISTEN      1001       18250      2374/io.hm-rpc.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      112        1910       908/mosquitto
                tcp6       0      0 :::34875                :::*                    LISTEN      1001       20836      2952/io.yahka.0
                tcp6       0      0 :::39359                :::*                    LISTEN      1001       20832      2952/io.yahka.0
                tcp6       0      0 :::51989                :::*                    LISTEN      1001       19629      2623/io.nuki-extend
                tcp6       0      0 :::3000                 :::*                    LISTEN      111        14038      1111/grafana
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20707      2824/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14210      1659/io.admin.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21974      3018/io.simple-api.
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        14000      895/influxd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          15172      983/sshd: /usr/sbin
                tcp6       0      0 :::42629                :::*                    LISTEN      1001       20834      2952/io.yahka.0
                tcp6       0      0 :::1883                 :::*                    LISTEN      112        1911       908/mosquitto
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20158      2816/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20159      2816/io.tuya.0
                udp        0      0 0.0.0.0:40945           0.0.0.0:*                           108        1726       372/avahi-daemon: r
                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12092      992/dnsmasq
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12089      992/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1815       764/dhclient
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1724       372/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21837      2715/io.shelly.0
                udp6       0      0 :::33846                :::*                                108        1727       372/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        1725       372/avahi-daemon: r
                2024-12-14 12:45:02.900  - error: host.raspiBullseye Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                2024-12-14 12:45:02.900  - error: host.raspiBullseye Caught by controller[0]: }
                2024-12-14 12:45:02.900  - error: host.raspiBullseye Caught by controller[0]: Node.js v20.18.1
                2024-12-14 12:45:02.900  - error: host.raspiBullseye instance system.adapter.e3oncan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-12-14 12:45:02.900  - info: host.raspiBullseye Restart adapter system.adapter.e3oncan.0 because enabled
                2024-12-14 12:45:34.598  - info: host.raspiBullseye instance system.adapter.e3oncan.0 in version "0.10.3" started with pid 9589
                2024-12-14 12:45:36.280  - error: host.raspiBullseye Caught by controller[0]: node:internal/modules/cjs/loader:1586
                2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]:                  ^
                2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]: Error: Module did not self-register: '/opt/iobroker/node_modules/socketcan/build/Release/can.node'.
                2024-12-14 12:45:36.281  - error: host.raspiBullseye Caught by controller[0]:     at Module._extensions..node (node:internal/modules/cjs/loader:1586:18)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/socketcan/dist/socketcan.js:51:26)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-12-14 12:45:36.282  - error: host.raspiBullseye Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12) {
                2024-12-14 12:45:36.283  - error: host.raspiBullseye Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                2024-12-14 12:45:36.283  - error: host.raspiBullseye Caught by controller[0]: }
                2024-12-14 12:45:36.283  - error: host.raspiBullseye Caught by controller[0]: Node.js v20.18.1
                2024-12-14 12:45:36.283  - error: host.raspiBullseye instance system.adapter.e3oncan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-12-14 12:45:36.283  - info: host.raspiBullseye Restart adapter system.adapter.e3oncan.0 because enabled
                iob diag has finished.
                • L legro
                  bash
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:           209M          0B        209M
                           7812 M total memory
                           2886 M used memory
                           3722 M free memory
                            155 M buffer memory
                           1186 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  *** FILESYSTEM ***
                  /var:
                  6.0G	/var/
                  2.9G	/var/lib
                  2.6G	/var/log
                  USB-Devices by-id:
                  HINT:
                  tcp
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin: 		7.1.5
                  javascript: 	8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	20716
                  States: 	17408
                  Pending Updates: 0
                  Da sieht man mal wieder, warum es keine brillante Idee ist, Versionsangaben in den hostname zu integrieren.
                  Oder in der Signatur. Sowas irritiert nur Helfer, wenn es nicht wenigstens dann auch aktuell gehalten wird...
                  Der 'Bookworm' ist auch nicht richtig installiert bzw. upgegraded worden. Nicht umsonst wird in dem Fall 'Bullseye auf Raspberry' eine NEUinstallation vorgesehen.
                  Um so schiefe Installationen werde ich mich nicht weiter kümmern.
                  Installier es gescheit von Grund auf neu.
                    legro
                    @thomas-braun sagte in Update von nodejs auf 20.x schiefgegangen?:
                    Da diskreditierst du allerdings deine eigenen Arbeiten.🙄 Ich habe die Aktualisierung auf Bookworm nach deinen Anleitungen sorgfältig/minutiös durchgeführt - was auch monatelang zu keinerlei Schwierigkeiten/Fehler führte.
                    Dennoch werde ich deinen Rat annehmen und mein System neu aufsetzen.
                    • L legro
                      nur dass diese Anleitung nicht für bullseye -> bookworm gilt!
                      • L legro
                        Dann hast du aber die Passage
                        Diesmal rät Raspberry OS allerdings noch dringender als sonst dazu, die Systeme nicht von einem zum anderen Release rüberzuheben, sondern eine komplette Neuinstallation zu machen:
                        Wichtig zu wissen: Früher empfahl man eine frische Installation, aber es war möglich, vom Vorgänger zu aktualisieren. Die jetzige Installation sollte aber auf jeden Fall neu sein.
                        Da die Änderungen an der zugrundeliegenden Architektur so signifikant sind, schlägt man dieses Mal keine Prozedur vor, um ein Bullseye-Image auf Bookworm zu aktualisieren; jeder Versuch, dies zu tun, wird mit ziemlicher Sicherheit mit einem nicht bootenden Desktop und Datenverlust enden.
                        Die einzige Möglichkeit, Bookworm zu bekommen, ist entweder eine SD-Karte mit dem Raspberry Pi Imager zu erstellen oder ein Bookworm-Image von hier herunterzuladen und mit dem Tool der Wahl zu flashen.
                        Gilt aber auch für ein System ohne Desktop, bei meinen Versuchen hab ich schwer mit dem Bootvorgang zu kämpfen, den aktuellen Kernel habe ich nicht vollständig gestartet bekommen.
                        geflissentlich ignoriert, wenn du dich an diese Anleitung gehalten haben willst:
                        https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                          legro
                          .. geflissentlich ignoriert, wenn du ..
                          Ein Versuch war's wert! Schließlich bin ich bisher nie schlecht mit deinen Anleitungen gefahren. Außerdem hat doch tatsächlich das Ganze über viele, viele Monate anstandslos funktioniert.
                          Mein Fazit: Linux ist und bleibt für mich eine ewige Bastelstube. Man schimpft immer auf M$ Windows. Zurecht - nur kannte ich mich damit wenigstens in etwa so aus, wie du in Sachen Linux.😊
                          Aber alles Lamentieren hilft mir nichts. Ich werde also mein System völlig neu aufsetzen und nehme dazu auch gleich einen neuen Raspberry Pi 5.
                          • L legro
                            Das ist eher das 'Problem' an der Stelle, nicht die vermeintliche 'Bastelbude'.
                            Das wird nämlich nur von Leuten so gesehen, die 'Ahnung von Windows' haben und ihr 'Wissen' von dort versuchen in die Linux-Welt zu retten. Das funktioniert nur nicht und ist nur hinderlich im Umgang mit einem komplett anders aufgebauten Betriebssystem.
                            Linux IST nicht wie Windows. Und will und soll es auch gar nicht sein. Einen Windows-Klon braucht die Welt nicht und deswegen tickt Linux ganz bewusst anders.
                            Wenn das so eine 'Bastelbude' wäre, dann würde nicht die überwiegende Zahl der Server und 'Supercomputer' auf Linux setzen.
                              legro
                              Du trägst Eulen nach Athen.🙂 Aber Linux bräuchte endlich eine vernünftige Möglichkeit, das System auf eine neue Version anzuheben ohne gleich alles neu installieren - oder eben ein Profi in Sachen Linux sein - zu müssen.
                              Ich fürchte, dass dies auch Kostengründe haben dürfte.😉
                              Solche Diskussionen sind letztendlich müßig. Statt weiter zu lamentieren installiere ich halt zum x. Mal alles wieder neu.
                              haselchenH Thomas BraunT HomoranH 5 Antworten Letzte Antwort
                              • L legro
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @legro
                                OT on
                                Müßig ist das keinesfalls, denn auch Windows kannst Du nicht so einfach von einer Version zur Anderen bringen -> Thema Hardware Voraussetzungen.
                                Und bei Windows wird Dir bei ner Installation einfach was ins System geklatscht.
                                In Linux kannst Du das überwiegend selbst steuern.
                                OT off
                                Und wenn Du so oft neu installieren musst , dann ist da was mit der Lernkurve nicht richtig 😉
                                • haselchenH haselchen
                                  @legro
                                  OT on
                                  OT off
                                  legro
                                  @haselchen sagte in Update von nodejs auf 20.x schiefgegangen?:
                                  @legro
                                  Und wenn Du so oft neu installieren musst, dann ist da was mit der Lernkurve nicht richtig 😉
                                  Auf meine alten Tage: Nein, nein und nochmals nein.
                                  Ich will in Sachen Linux kein Profi müssen sein. 😂
                                  Mit überzeugten Linux-Anwendern über Windows zu diskutieren, ist müßig. Das Ganze ist eh bloß noch OT.
                                  • L legro
                                    Die gibt es natürlich grundsätzlich (es gibt allerdings kein 'Linux' in dem Sinne, nur hunderte von Distributionen, die alle auf dem Linux-Kernel aufsetzen).
                                    Sog. 'rolling release'-Distributionen gibt es, die installierst du einmal und dann rollst du regelmäßig mit dem Upstream mit und hast immer die aktuellsten Versionen. Hab ich zum Beispiel auf dem Laptop von dem ich gerade tippe laufen.
                                    Setzt aber voraus, dass man sich mit dem System beschäftigen will und z. B. release notes liest.
                                    Und auch bei 'point releases' (wie z. B. Debian) geht das grundsätzlich von einem Release zum nächsten (tw. mit ein paar Kniffen und Anpassungen). In deinem konkreten Fall von 'Raspberry 11 - Bullseye' auf 'Raspberry 12 - Bookworm' sind die Änderungen zwischen den Releases allerdings so groß, das es auf eine Neuinstallation herausläuft. Die Änderungen ergeben sich übrigens daraus, das man bei der Bastelbude 'Raspberry OS' zu der Erkenntnis gekommen ist, das die eigenen Basteleien am OS nicht mehr erforderlich sein sollten und man nun auf den Debian-Standard zurückgeht. Es wird also künftig bei Raspberry OS weniger gebastelt und ein Sprung von 'Bookworm' auf 'Trixie' im Sommer 2025 dürfte wieder per 'in-line'-Upgrade funktionieren.
                                    • L legro
                                      Beim Betrieb von Servern sind die Lizenzkosten der kleinste Faktor. Da stehen andere Aspekte mehr im Vordergrund.
                                      Und diese Anforderungen werden von der 'Bastelbude' Linux wohl überwiegend besser erfüllt als von anderen Systemen.
                                      • L legro
                                        hat es!
                                        nur in diesem einen speziellen Fall von Raspberrypi OS bullseye auf Raspberry pi OS bookworm geht das sinnvollerweise nicht.
                                        Dazu wurde früher im Raspberry pi OS / Raspbian zu viele Dinge Raspi-spezifisch in deren Linux eingebaut.
                                        mit Bookworm nähert man sich jetzt deutlich mehr an Debian an.
                                        Musst du auch nicht. Bin ich auch nicht.
                                        Habe erst durch ioBroker meinen ersten Kontakt mit Linux gehabt.
                                        Und weil ich mich mit Linux nicht wirklich auskenne mache ich bei jedem Wechsel des major releases eine Neuinstallation, spiele das Backup zurück und fertig.
                                        Der Vorteil ist, dass aller Schrott runter ist, dass ich (bisher) parallel aufbauen kann.
                                        Wenn ich fertig bin wird der alte Server abgeklemmt, beim neuen die IP angepasst, dann sind nur wenige Minuten Totzeit.
                                        Bei Raspi3/4 hab ich sogar die Karte einfach umgesteckt.
                                        für den Pi5 hab ich noch kein Reservegerät
                                        • L legro
                                          @legro
                                          Du kannst auch versuchen mit dieser Anleitung auf ein stabiles Raspberry OS 12 - Bookworm zu kommen:
                                          https://www.heise.de/hintergrund/Raspberry-Pi-OS-InPlace-Upgrade-von-Bullseye-auf-Bookworm-wagen-9999516.html
                                          Ich würde das aber nicht als generellen Upgrade-Pfad für alle user empfehlen wollen.
                                          Es gibt also schon Wege, dein Raspberry OS 11 auf 12 zu hieven. Sie sind nur in diesem Fall für meinen Geschmack zu verschlungen und unsicher für selbst-erklärte Linux-Laien und 'Warum-ist-Linux-nicht-wie-xy'-Frager.
                                          Thomas BraunT L 2 Antworten Letzte Antwort
