  4. [Adapter] Sonoff- Tasmota
    6.8k
720 Beiträge 75 Kommentatoren 337.9k Aufrufe 8 Beobachtet
  • lobomauL Offline
    lobomauL Offline
    lobomau
    #41
    Schade. Port ändern hat nichts gebracht. Bekomme keine stabile Verbindung hin.
    sonoff.0	2017-10-07 13:22:48.057	debug	Client [DVES_077E54] pingreq
    sonoff.0	2017-10-07 13:22:48.032	debug	Client [DVES_077E9B] pingreq
    sonoff.0	2017-10-07 13:22:43.986	debug	stateChange sonoff.0.DVES_077E54.POWER: {"val":true,"ack":true,"ts":1507375363978,"q":0,"from":"system.adapter.sonoff.0","lc":1507375254245}
    sonoff.0	2017-10-07 13:22:43.981	debug	stateChange sonoff.0.DVES_077E54.RSSI: {"val":36,"ack":true,"ts":1507375363976,"q":0,"from":"system.adapter.sonoff.0","lc":1507375051487}
    sonoff.0	2017-10-07 13:22:43.978	debug	stateChange sonoff.0.DVES_077E54.Vcc: {"val":3.156,"ack":true,"ts":1507375363971,"q":0,"from":"system.adapter.sonoff.0","lc":1507375051478}
    sonoff.0	2017-10-07 13:22:43.972	debug	[DVES_077E54] Received: tele/sonoff03/STATE = {"Time":"2017-10-07T12:22:43", "Uptime":17, "Vcc":3.156, "POWER":"ON", "Wifi":{"AP":1, "SSID":"XXXXXX", "RSSI":36, "APMac":"F2:9F:C2:F7:XX:XX"}}
    sonoff.0	2017-10-07 13:22:35.185	debug	stateChange sonoff.0.DVES_077E9B.POWER: {"val":false,"ack":true,"ts":1507375355164,"q":0,"from":"system.adapter.sonoff.0","lc":1507321006509}
    sonoff.0	2017-10-07 13:22:35.185	debug	stateChange sonoff.0.DVES_077E9B.RSSI: {"val":64,"ack":true,"ts":1507375355164,"q":0,"from":"system.adapter.sonoff.0","lc":1507375355164}
    sonoff.0	2017-10-07 13:22:35.183	debug	stateChange sonoff.0.DVES_077E9B.Vcc: {"val":3.213,"ack":true,"ts":1507375355161,"q":0,"from":"system.adapter.sonoff.0","lc":1507375355161}
    sonoff.0	2017-10-07 13:22:35.156	debug	[DVES_077E9B] Received: tele/sonoff_Zirkulation/STATE = {"Time":"2017-10-07T12:22:35", "Uptime":17, "Vcc":3.213, "POWER":"OFF", "Wifi":{"AP":1, "SSID":"XXXXXXX", "RSSI":64, "APMac":"F2:9F:C2:F7:XX:XX
    sonoff.0	2017-10-07 13:22:33.796	debug	Client [DVES_077E54] pingreq
    sonoff.0	2017-10-07 13:22:32.985	debug	Client [DVES_077E9B] pingreq
    sonoff.0	2017-10-07 13:22:18.056	debug	Client [DVES_077E54] pingreq
    sonoff.0	2017-10-07 13:22:17.985	debug	Client [DVES_077E9B] pingreq
    sonoff.0	2017-10-07 13:22:03.093	debug	Client [DVES_077E54] pingreq
    sonoff.0	2017-10-07 13:22:03.088	debug	Client [DVES_077E9B] pingreq
    sonoff.0	2017-10-07 13:21:47.955	debug	stateChange sonoff.0.DVES_077E54.alive: {"val":true,"ack":true,"ts":1507375307948,"q":0,"from":"system.adapter.sonoff.0","lc":1507375307946}
    sonoff.0	2017-10-07 13:21:47.953	debug	stateChange sonoff.0.DVES_077E54.alive: {"val":true,"ack":true,"ts":1507375307946,"q":0,"from":"system.adapter.sonoff.0","lc":1507375307946}
    sonoff.0	2017-10-07 13:21:47.941	debug	[DVES_077E54] Received: cmnd/sonoff03/POWER =
    sonoff.0	2017-10-07 13:21:45.387	debug	stateChange sonoff.0.info.connection: {"val":"DVES_077E9B,DVES_077E54","ack":true,"ts":1507375305378,"q":0,"from":"system.adapter.sonoff.0","lc":1507375305378}
    sonoff.0	2017-10-07 13:21:45.380	info	Client [DVES_077E54] connected
    sonoff.0	2017-10-07 13:21:44.420	debug	[DVES_077E9B] Received: cmnd/sonoff_Zirkulation/POWER =
    sonoff.0	2017-10-07 13:21:43.050	debug	stateChange sonoff.0.DVES_077E9B.alive: {"val":true,"ack":true,"ts":1507375303042,"q":0,"from":"system.adapter.sonoff.0","lc":1507375303042}
    sonoff.0	2017-10-07 13:21:42.799	debug	stateChange sonoff.0.info.connection: {"val":"DVES_077E9B","ack":true,"ts":1507375302792,"q":0,"from":"system.adapter.sonoff.0","lc":1507375302792}
    sonoff.0	2017-10-07 13:21:42.666	info	Client [DVES_077E9B] connected
    sonoff.0	2017-10-07 13:21:30.134	debug	stateChange sonoff.0.DVES_077E54.alive: {"val":false,"ack":true,"ts":1507375290129,"q":0,"from":"system.adapter.sonoff.0","lc":1507375290129}
    sonoff.0	2017-10-07 13:21:30.134	debug	stateChange sonoff.0.DVES_077E9B.alive: {"val":false,"ack":true,"ts":1507375290127,"q":0,"from":"system.adapter.sonoff.0","lc":1507375290127}
    sonoff.0	2017-10-07 13:21:30.118	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1507375290112,"q":0,"from":"system.adapter.sonoff.0","lc":1507375286454}
    sonoff.0	2017-10-07 13:21:30.096	info	Starting MQTT authenticated server on port 1885
    sonoff.0	2017-10-07 13:21:29.973	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.11.4
    sonoff.0	2017-10-07 13:21:29.931	debug	statesDB connected
    sonoff.0	2017-10-07 13:21:29.886	debug	objectDB connected
    sonoff.0	2017-10-07 13:21:26.459	info	terminating
    sonoff.0	2017-10-07 13:21:26.451	info	Client [DVES_077E54] closed
    sonoff.0	2017-10-07 13:21:26.451	info	Client [DVES_077E9B] closed
    sonoff.0	2017-10-07 13:21:26.450	warn	Client error [DVES_077E54]: Error: Invalid messageId
    sonoff.0	2017-10-07 13:21:26.449	info	Client [DVES_077E54] closed
    sonoff.0	2017-10-07 12:51:39.983	info	Client [DVES_077E54] connected
    sonoff.0	2017-10-07 12:51:38.168	info	Client [DVES_077E54] closed
    sonoff.0	2017-10-07 12:44:44.842	warn	Client error [DVES_077E54]: Error: Invalid messageId
    sonoff.0	2017-10-07 12:44:44.841	info	Client [DVES_077E54] closed
    sonoff.0	2017-10-07 12:44:37.707	info	Client [DVES_077E54] connected
    Edit: habe noch eine Änderung vorgenommen. Unter Configure MQTT habe ich Client ID geändert und zwar in die vom sonoff… vorher stand da eine andere:
    Edit2: hat nur 30min gehalten. Der eine hat sich wieder verabschiedet mit:
    sonoff.0	2017-10-07 13:59:18.646	warn	Client error [DVES_077E54]: Error: Invalid messageId
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
      DrFirebird
      #42
      @knopers1
      @noxx
      Das wars !!!
      Kaum macht man es richtig, schon funktionierts :D
      Vielen Dank
      • kmxakK Offline
        kmxakK Offline
        kmxak
        #43
        @ lobomau
        äußerst komisch habe mehrere seit Tagen laufen und keine Probleme. Hast du die neueste Firmware drauf?
        Hast du mal probiert die Sonoff anders zu benennen? Meine heißen aktuell SonoffPOW1
        Hast du noch irgendwas spezielles eingestellt?
        Steht in der Sonoff Console was drin?
        Gruß Alex
        • K Offline
          knopers1
          #44
          @lomobau
          meine Konfig sieht so aus… Läuft auch stabil!
          • lobomauL Offline
            lobomauL Offline
            lobomau
            #45
            Können alle Geräte gleiches topic "sonoff" haben? Habe ich jetzt mal so eingestellt.
            Wie ist euer rssi-Wert? Mein sonoff, der die Verbindung verliert hat einen Wert um 30 rum, der andere 58.
            Nun habe ich den Geräten sinnvolle Namen gegeben:
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 11:07:32.694
            Zirkulation	true	sonoff.0	2017-10-08 11:07:09.084
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 11:04:58.072
            Zirkulation	true	sonoff.0	2017-10-08 11:03:26.537
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 10:58:10.882
            Zirkulation	true	sonoff.0	2017-10-08 10:58:05.518
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 10:57:38.614
            Zirkulation	true	sonoff.0	2017-10-08 10:55:59.779
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 10:55:13.978
            Zirkulation	true	sonoff.0	2017-10-08 10:53:47.212
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 10:53:41.337
            Zirkulation	true	sonoff.0	2017-10-08 10:51:52.198
            Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 10:51:45.947
            Zirkulation	true	sonoff.0	2017-10-08 10:50:49.806
            • Slave: Pi4
            • K Offline
              knopers1
              #46
              @lobomau:
              Wie ist euer rssi-Wert? `
              meine habens… zumindest drei von 4 Geräten... RSSI Werte je nach Abstand zum Router zwischen 68-88%.
              Mit 30% bist Du relativ weit vom Router mit dem Teil. Das könnte natürlich das Problem sein, dass die Verbindung flöten geht. Stell die Teile näher zum Router hin und beobachte paar Std. Dann kennst Du die Antwort.
              • H Offline
                high_voltage
                #47
                vielleicht könnte mir jemand verraten wie ich diese Daten (gelb markiert) im Minutentakt oder in Echtzeit akutell bekommen kann?
                Vielen Dank und viele Grüße
                P.S. sorry für die vielen Fragen bin noch Beginner … :-)
                • kmxakK Offline
                  kmxakK Offline
                  kmxak
                  #48
                  nun hatte ich die Meldungen auch einmal:
                  sonoff.0	2017-10-09 08:03:12.467	info	Client [Sonoff4ch] connected
                  sonoff.0	2017-10-09 08:03:12.451	info	Client [SonoffPOW] connected
                  sonoff.0	2017-10-09 08:03:10.911	warn	Client error [SonoffPOW]: Error: Invalid messageId
                  sonoff.0	2017-10-09 08:03:10.909	info	Client [SonoffPOW] closed
                  sonoff.0	2017-10-09 08:03:10.496	warn	Client error [Sonoff4ch]: Error: Invalid messageId
                  sonoff.0	2017-10-09 08:03:10.494	info	Client [Sonoff4ch] closed
                  Gruß Alex
                  • lobomauL Offline
                    lobomauL Offline
                    lobomau
                    #49
                    @knopers1:
                    @lobomau:
                    Mit 30% bist Du relativ weit vom Router mit dem Teil. Das könnte natürlich das Problem sein, dass die Verbindung flöten geht. Stell die Teile näher zum Router hin und beobachte paar Std. Dann kennst Du die Antwort. `
                    Zur Abwechslung hat sich nun der mit dem besseren rssi-Wert verabschiedet. Die hängen auch beide ständig am wlan. Ich glaube daran liegt es nicht.
                    Licht_Gartenhaus	true	sonoff.0	2017-10-09 10:29:29.994
                    Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 20:58:42.382
                    Zirkulation	true	sonoff.0	2017-10-08 20:58:41.958
                    true	sonoff.0	2017-10-08 20:58:28.460
                    Zirkulation,Licht_Gartenhaus	true	sonoff.0	2017-10-08 11:19:55.883
                    Zirkulation	true	sonoff.0	2017-10-08 11:11:17.152
                    Zirkulation	true	sonoff.0	2017-10-08 11:08:50.354
                    • Slave: Pi4
                    • BluefoxB Offline
                      BluefoxB Offline
                      #50
                      @kmxak:
                      Es gibt diese Datei:
                      ... node_modules/mqtt-packet/writeToStream.js
                      entwider in /opt/iobroker oder in /opt/iobroker/node_modules/iobroker.sonoff
                      Kannst du folgende Zeilen verändern um raus zu finden, wo Fehler vorkommt?
                      https://github.com/mqttjs/mqtt-packet/b … am.js#L270
                      https://github.com/mqttjs/mqtt-packet/b ... am.js#L303
                      https://github.com/mqttjs/mqtt-packet/b ... am.js#L327
                      https://github.com/mqttjs/mqtt-packet/b ... am.js#L389
                      https://github.com/mqttjs/mqtt-packet/b ... am.js#L429
                      Auf
                      stream.emit('error', new Error('Invalid messageId ' + __line))
                      • kmxakK Offline
                        kmxakK Offline
                        kmxak
                        #51
                        nachdem ich die datei geändert habe und den adapter 2 mal neugestartet habe kamen erste meldungen:
                        host.ioBroker 2017-10-09 13:00:27.890 info instance system.adapter.sonoff.0 started with pid 4118
                        host.ioBroker 2017-10-09 13:00:25.507 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
                        Caught 2017-10-09 13:00:25.507 error by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11)
                        Caught 2017-10-09 13:00:25.507 error by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5)
                        Caught 2017-10-09 13:00:25.506 error by controller[1]: at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64)
                        Caught 2017-10-09 13:00:25.506 error by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22)
                        Caught 2017-10-09 13:00:25.506 error by controller[1]: at Writable.write (_stream_writable.js:243:11)
                        Caught 2017-10-09 13:00:25.506 error by controller[1]: at writeOrBuffer (_stream_writable.js:317:5)
                        Caught 2017-10-09 13:00:25.506 error by controller[1]: at doWrite (_stream_writable.js:331:12)
                        Caught 2017-10-09 13:00:25.505 error by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9)
                        Caught 2017-10-09 13:00:25.505 error by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14)
                        Caught 2017-10-09 13:00:25.505 error by controller[1]: at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59)
                        Caught 2017-10-09 13:00:25.505 error by controller[1]: ReferenceError: __line is not defined
                        Caught 2017-10-09 13:00:25.505 error by controller[0]: at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11)
                        Caught 2017-10-09 13:00:25.505 error by controller[0]: at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5)
                        Caught 2017-10-09 13:00:25.505 error by controller[0]: at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64)
                        Caught 2017-10-09 13:00:25.504 error by controller[0]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22)
                        Caught 2017-10-09 13:00:25.504 error by controller[0]: at Writable.write (_stream_writable.js:243:11)
                        Caught 2017-10-09 13:00:25.504 error by controller[0]: at writeOrBuffer (_stream_writable.js:317:5)
                        Caught 2017-10-09 13:00:25.504 error by controller[0]: at doWrite (_stream_writable.js:331:12)
                        Caught 2017-10-09 13:00:25.504 error by controller[0]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9)
                        Caught 2017-10-09 13:00:25.504 error by controller[0]: at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14)
                        Caught 2017-10-09 13:00:25.503 error by controller[0]: at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59)
                        Caught 2017-10-09 13:00:25.503 error by controller[0]: ReferenceError: __line is not defined
                        sonoff.0 2017-10-09 13:00:25.480 info terminating
                        sonoff.0 2017-10-09 13:00:25.466 error at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11)
                        sonoff.0 2017-10-09 13:00:25.466 error at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5)
                        sonoff.0 2017-10-09 13:00:25.466 error at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64)
                        sonoff.0 2017-10-09 13:00:25.466 error at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22)
                        sonoff.0 2017-10-09 13:00:25.466 error at Writable.write (_stream_writable.js:243:11)
                        sonoff.0 2017-10-09 13:00:25.466 error at writeOrBuffer (_stream_writable.js:317:5)
                        sonoff.0 2017-10-09 13:00:25.466 error at doWrite (_stream_writable.js:331:12)
                        sonoff.0 2017-10-09 13:00:25.466 error at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9)
                        sonoff.0 2017-10-09 13:00:25.466 error at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14)
                        sonoff.0 2017-10-09 13:00:25.466 error at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59)
                        sonoff.0 2017-10-09 13:00:25.466 error ReferenceError: __line is not defined
                        sonoff.0 2017-10-09 13:00:25.466 error uncaught exception: __line is not defined
                        sonoff.0 2017-10-09 13:00:25.465 info Client [SonoffPOW] closed
                        sonoff.0 2017-10-09 13:00:25.464 info Client [Sonoff4ch] closed
                        sonoff.0 2017-10-09 13:00:25.463 warn Client error [ESPClient5]: Error: This socket is closed
                        sonoff.0 2017-10-09 13:00:25.458 info Client [ESPClient5] closed
                        sonoff.0 2017-10-09 13:00:25.458 error at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11)
                        sonoff.0 2017-10-09 13:00:25.458 error at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5)
                        sonoff.0 2017-10-09 13:00:25.458 error at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64)
                        sonoff.0 2017-10-09 13:00:25.458 error at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22)
                        sonoff.0 2017-10-09 13:00:25.458 error at Writable.write (_stream_writable.js:243:11)
                        sonoff.0 2017-10-09 13:00:25.458 error at writeOrBuffer (_stream_writable.js:317:5)
                        sonoff.0 2017-10-09 13:00:25.458 error at doWrite (_stream_writable.js:331:12)
                        sonoff.0 2017-10-09 13:00:25.458 error at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9)
                        sonoff.0 2017-10-09 13:00:25.458 error at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14)
                        sonoff.0 2017-10-09 13:00:25.458 error at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59)
                        sonoff.0 2017-10-09 13:00:25.458 error ReferenceError: __line is not defined
                        sonoff.0 2017-10-09 13:00:25.458 error uncaught exception: __line is not defined
                        sonoff.0 2017-10-09 13:00:25.427 info Client [Sonoff4ch] closed
                        Gruß Alex
                        • chucky666C Online
                          chucky666C Online
                          chucky666
                          #52
                          Hallo
                          Wird der Sonoff S20 auch unterstützt ?
                          Gesendet von iPad mit Tapatalk Pro
                          • BluefoxB Offline
                            BluefoxB Offline
                            #53
                            @kmxak:
                            ! host.ioBroker 2017-10-09 13:00:27.890 info instance system.adapter.sonoff.0 started with pid 4118 host.ioBroker 2017-10-09 13:00:25.507 info instance system.adapter.sonoff.0 terminated with code 0 (OK) Caught 2017-10-09 13:00:25.507 error by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) Caught 2017-10-09 13:00:25.507 error by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) Caught 2017-10-09 13:00:25.506 error by controller[1]: at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) Caught 2017-10-09 13:00:25.506 error by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) Caught 2017-10-09 13:00:25.506 error by controller[1]: at Writable.write (_stream_writable.js:243:11) Caught 2017-10-09 13:00:25.506 error by controller[1]: at writeOrBuffer (_stream_writable.js:317:5) Caught 2017-10-09 13:00:25.506 error by controller[1]: at doWrite (_stream_writable.js:331:12) Caught 2017-10-09 13:00:25.505 error by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) Caught 2017-10-09 13:00:25.505 error by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) Caught 2017-10-09 13:00:25.505 error by controller[1]: at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) Caught 2017-10-09 13:00:25.505 error by controller[1]: ReferenceError: __line is not defined Caught 2017-10-09 13:00:25.505 error by controller[0]: at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) Caught 2017-10-09 13:00:25.505 error by controller[0]: at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) Caught 2017-10-09 13:00:25.505 error by controller[0]: at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) Caught 2017-10-09 13:00:25.504 error by controller[0]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) Caught 2017-10-09 13:00:25.504 error by controller[0]: at Writable.write (_stream_writable.js:243:11) Caught 2017-10-09 13:00:25.504 error by controller[0]: at writeOrBuffer (_stream_writable.js:317:5) Caught 2017-10-09 13:00:25.504 error by controller[0]: at doWrite (_stream_writable.js:331:12) Caught 2017-10-09 13:00:25.504 error by controller[0]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) Caught 2017-10-09 13:00:25.504 error by controller[0]: at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) Caught 2017-10-09 13:00:25.503 error by controller[0]: at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) Caught 2017-10-09 13:00:25.503 error by controller[0]: ReferenceError: __line is not defined sonoff.0 2017-10-09 13:00:25.480 info terminating sonoff.0 2017-10-09 13:00:25.466 error at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) sonoff.0 2017-10-09 13:00:25.466 error at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) sonoff.0 2017-10-09 13:00:25.466 error at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) sonoff.0 2017-10-09 13:00:25.466 error at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) sonoff.0 2017-10-09 13:00:25.466 error at Writable.write (_stream_writable.js:243:11) sonoff.0 2017-10-09 13:00:25.466 error at writeOrBuffer (_stream_writable.js:317:5) sonoff.0 2017-10-09 13:00:25.466 error at doWrite (_stream_writable.js:331:12) sonoff.0 2017-10-09 13:00:25.466 error at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) sonoff.0 2017-10-09 13:00:25.466 error at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) sonoff.0 2017-10-09 13:00:25.466 error at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) sonoff.0 2017-10-09 13:00:25.466 error ReferenceError: __line is not defined sonoff.0 2017-10-09 13:00:25.466 error uncaught exception: __line is not defined sonoff.0 2017-10-09 13:00:25.465 info Client [SonoffPOW] closed sonoff.0 2017-10-09 13:00:25.464 info Client [Sonoff4ch] closed sonoff.0 2017-10-09 13:00:25.463 warn Client error [ESPClient5]: Error: This socket is closed sonoff.0 2017-10-09 13:00:25.458 info Client [ESPClient5] closed sonoff.0 2017-10-09 13:00:25.458 error at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) sonoff.0 2017-10-09 13:00:25.458 error at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) sonoff.0 2017-10-09 13:00:25.458 error at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) sonoff.0 2017-10-09 13:00:25.458 error at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) sonoff.0 2017-10-09 13:00:25.458 error at Writable.write (_stream_writable.js:243:11) sonoff.0 2017-10-09 13:00:25.458 error at writeOrBuffer (_stream_writable.js:317:5) sonoff.0 2017-10-09 13:00:25.458 error at doWrite (_stream_writable.js:331:12) sonoff.0 2017-10-09 13:00:25.458 error at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) sonoff.0 2017-10-09 13:00:25.458 error at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) sonoff.0 2017-10-09 13:00:25.458 error at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) sonoff.0 2017-10-09 13:00:25.458 error ReferenceError: __line is not defined sonoff.0 2017-10-09 13:00:25.458 error uncaught exception: __line is not defined sonoff.0 2017-10-09 13:00:25.427 info Client [Sonoff4ch] closed `
                            Ist vermutlich alte node.js Version.
                            dann ersetze __line mit unterschiedlichen Buchstaben: A, B, C,… so dass du die unterscheiden kannst.
                            • BluefoxB Offline
                              BluefoxB Offline
                              #54
                              @chucky666:
                              Hallo
                              Gesendet von iPad mit Tapatalk Pro `
                              Keine Ahnung. Hast du probiert oder fragst du?
                              • chucky666C Online
                                chucky666C Online
                                chucky666
                                #55
                                Ich frage , wollte mir eine testweise bestellen
                                • kmxakK Offline
                                  kmxakK Offline
                                  kmxak
                                  #56
                                  @Bluefox:
                                  dann ersetze __line mit unterschiedlichen Buchstaben: A, B, C,… so dass du die unterscheiden kannst. `
                                  wo soll ich was ersetzen?`
                                  Die node.js ist aktuell:
                                  root@ioBroker:/home/alex# node -v
                                  v6.11.4
                                  root@ioBroker:/home/alex# nodejs -v
                                  v6.11.4
                                  Gruß Alex
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #57
                                    @kmxak:
                                    @Bluefox:
                                    v6.11.4
                                    v6.11.4
                                    stream.emit('error', new Error('Invalid messageId A'))
                                    stream.emit('error', new Error('Invalid messageId B'))
                                    stream.emit('error', new Error('Invalid messageId C'))
                                    stream.emit('error', new Error('Invalid messageId ...'))
                                    • kmxakK Offline
                                      kmxakK Offline
                                      kmxak
                                      #58
                                      Bislang bekomme ich als einzigen Fehler
                                      sonoff.0	2017-10-11 20:49:16.932	warn	Client error [Sonoff4ch]: Error: Invalid messageId A
                                      Gruß Alex
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        #59
                                        @kmxak:
                                        Und welche Zeile ist das? in node_modules/mqtt-packet/writeToStream.js
                                        • kmxakK Offline
                                          kmxakK Offline
                                          kmxak
                                          #60
                                          hier ein ausschnitt (Zeile 270)
                                          // Topic must be a non-empty string or Buffer
                                            if (typeof topic === 'string') length += Buffer.byteLength(topic) + 2
                                            else if (Buffer.isBuffer(topic)) length += topic.length + 2
                                            else {
                                              stream.emit('error', new Error('Invalid topic'))
                                              return false
                                            // Get the payload length
                                            if (!Buffer.isBuffer(payload)) length += Buffer.byteLength(payload)
                                            else length += payload.length
                                            // Message ID must a number if qos > 0
                                            if (qos && typeof id !== 'number') {
                                              return false
                                            } else if (qos) length += 2
                                            // Header
                                            stream.write(protocol.PUBLISH_HEADER[qos][opts.dup ? 1 : 0][retain ? 1 : 0])
                                            // Remaining length
                                            writeLength(stream, length)
                                            // Topic
                                            writeNumber(stream, byteLength(topic))
                                            stream.write(topic)
                                          Gruß Alex
