  4. [gelöst] Zigbee Adapter bleibt gelb nach Raspi update
17 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • darkbluD Online
    darkbluD Online
    darkblu
    schrieb am zuletzt editiert von darkblu
    Hallo, ich habe gerade mein Bookworm (Raspi Pi5) geupdatet, es gab 2 Pakete.
    Update erfolge mittels:
    sudo apt update && sudo apt full-upgrade
    Leider bleibt jetzt nach dem ioBroker Neustart der Zigbee Adapter gelb.
    Folgendes steht im Log:
    2024-12-01 16:39:52.536 - info: host.smart stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-12-01 16:39:52.540 - info: zigbee.0 (7470) Got terminate signal TERMINATE_YOURSELF
    2024-12-01 16:39:52.652 - info: host.smart stopInstance system.adapter.zigbee.0 send kill signal
    2024-12-01 16:39:52.542 - info: zigbee.0 (7470) cleaned everything up...
    2024-12-01 16:39:52.553 - info: zigbee.0 (7470) Zigbee: disabling joining new devices.
    2024-12-01 16:39:52.775 - warn: zigbee.0 (7470) Failed to stop zigbee during startup
    2024-12-01 16:39:52.776 - info: zigbee.0 (7470) terminating
    2024-12-01 16:39:52.776 - info: zigbee.0 (7470) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-01 16:39:52.799 - info: zigbee.0 (7470) debug devices set to []
    2024-12-01 16:39:53.042 - info: zigbee.0 (7470) terminating
    2024-12-01 16:39:53.345 - info: host.smart instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-01 16:39:56.763 - info: host.smart instance system.adapter.zigbee.0 in version "1.10.3" started with pid 7486
    2024-12-01 16:39:58.685 - info: zigbee.0 (7486) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
    2024-12-01 16:39:58.715 - info: zigbee.0 (7486) delete old Backup files. keep only last 10
    2024-12-01 16:39:58.716 - info: zigbee.0 (7486) Starting Zigbee npm ...
    2024-12-01 16:39:58.851 - info: zigbee.0 (7486) Installed Version: iobroker.zigbee@1.10.3
    iob diag sagt das hier:
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: smart
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:36:45 up 19 min,  2 users,  load average: 7.43, 6.59, 4.18
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-12-01 16:36:45 CET
               Universal time: Sun 2024-12-01 15:36:45 UTC
                     RTC time: Sun 2024-12-01 15:36:45
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dirk
    HOME=/home/dirk
    GROUPS=dirk adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        3.0G        4.2G        5.6M        1.3G        5.5G
    Swap:           209M          0B        209M
    Total:          8.7G        3.0G        4.5G
    Active iob-Instances:   41
             8052 M total memory
             2834 M used memory
             2717 M active memory
              783 M inactive memory
             4046 M free memory
              121 M buffer memory
             1151 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 16:36:45 up 19 min,  2 users,  load average: 7.43, 6.59, 4.18
    Tasks: 204 total,   1 running, 203 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.2 total,   4046.0 free,   2835.3 used,   1273.1 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5216.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    15 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     806M  5.3M  800M   1% /run
    /dev/sda2      ext4      117G  7.2G  104G   7% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   65M  446M  13% /boot/firmware
    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
    [Sun Dec  1 16:16:52 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:4D:70:41 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eae5867b-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Dec  1 16:16:55 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Sun Dec  1 16:16:55 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    710M    /var/
    206M    /var/cache
    200M    /var/cache/apt
    197M    /var/lib
    134M    /var/lib/apt/lists
    Archived and active journals take up 105.6M in the file system.
    /opt/iobroker/backups:
    403M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2440876-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    smart               smart (version: 7.0.3, hostname: smart         , alive, uptime: 617)
    Core adapters versions
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : smart                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : smart                                    -  enabled
      system.adapter.alias-manager.0          : alias-manager         : smart                                    -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : smart                                    -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : smart                                    -  enabled
    + system.adapter.awtrix-light.2           : awtrix-light          : smart                                    -  enabled
    + system.adapter.backitup.0               : backitup              : smart                                    -  enabled
    + system.adapter.cloud.0                  : cloud                 : smart                                    -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : smart                                    -  enabled
    + system.adapter.discovery.0              : discovery             : smart                                    -  enabled
      system.adapter.dwd.0                    : dwd                   : smart                                    -  enabled
    + system.adapter.echarts.0                : echarts               : smart                                    -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : smart                                    -  enabled
      system.adapter.feiertage.0              : feiertage             : smart                                    -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : smart                                    -  enabled
    + system.adapter.hmip.0                   : hmip                  : smart                                    -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : smart                                    -  enabled
    + system.adapter.hue.0                    : hue                   : smart                                    -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : smart                                    -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : smart                                    -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : smart                                    -  enabled
    + system.adapter.influxdb.0               : influxdb              : smart                                    -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : smart                                    -  enabled
    + system.adapter.javascript.0             : javascript            : smart                                    -  enabled
    + system.adapter.linux-control.0          : linux-control         : smart                                    -  enabled
    + system.adapter.melcloud.0               : melcloud              : smart                                    -  enabled
    + system.adapter.modbus.0                 : modbus                : smart                                    -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : smart                                    -  enabled, port: 1887, bind: 0.0.0.0
    + system.adapter.mytime.0                 : mytime                : smart                                    -  enabled
    + system.adapter.nuki.0                   : nuki                  : smart                                    -  enabled
      system.adapter.reolink.0                : reolink               : smart                                    - disabled
    + system.adapter.shelly.0                 : shelly                : smart                                    -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : smart                                    -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.smart-eq.0               : smart-eq              : smart                                    - disabled
    + system.adapter.sonoff.0                 : sonoff                : smart                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : smart                                    -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smart                                    -  enabled
    + system.adapter.statistics.0             : statistics            : smart                                    -  enabled
    + system.adapter.tr-064.0                 : tr-064                : smart                                    -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : smart                                    -  enabled
    + system.adapter.tuya.0                   : tuya                  : smart                                    -  enabled
    + system.adapter.upnp.0                   : upnp                  : smart                                    -  enabled
      system.adapter.uv-protect.0             : uv-protect            : smart                                    -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : smart                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smart                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : smart                                    -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : smart                                    -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : smart                                    -  enabled
      system.adapter.vis-players.0            : vis-players           : smart                                    -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : smart                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : smart                                    -  enabled
      system.adapter.vis.0                    : vis                   : smart                                    -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : smart                                    -  enabled
    + system.adapter.web.0                    : web                   : smart                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : smart                                    -  enabled
    + system.adapter.wled.0                   : wled                  : smart                                    -  enabled
    + system.adapter.zigbee.0                 : zigbee                : smart                                    -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "hmip"         : 1.24.3   , installed 1.24.3
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "melcloud"     : 2.0.4    , installed 2.0.4
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "uv-protect"   : 0.6.3    , installed 0.6.3
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        20343
    States:         15086
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6420       777/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       21715      3679/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20039      3742/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20004      3724/io.shelly.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18347      3372/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20488      3372/iobroker.js-co
    tcp        0      0 192.168.178.40:9092     0.0.0.0:*               LISTEN      1001       22713      3694/io.nuki.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        7194       889/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6422       777/sshd: /usr/sbin
    tcp6       0      0 :::3001                 :::*                    LISTEN      1001       22094      3998/io.fullybrowse
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       24364      4532/io.upnp.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        3941       889/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17247      3390/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21937      3878/io.web.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21155      3757/io.sonos.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22771      3787/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22772      3787/io.tuya.0
    udp        0      0 0.0.0.0:41825           0.0.0.0:*                           104        4957       647/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24067      4564/io.wled.0
    udp        0      0 192.168.178.40:5353     0.0.0.0:*                           1001       21245      3772/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4955       647/avahi-daemon: r
    udp        0      0 0.0.0.0:58814           0.0.0.0:*                           1001       23541      4532/io.upnp.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21093      3709/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25810      4532/io.upnp.0
    udp6       0      0 fe80::1fd4:b7df:3ba:546 :::*                                0          3857       731/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        4956       647/avahi-daemon: r
    udp6       0      0 :::50457                :::*                                104        4958       647/avahi-daemon: r
    2024-12-01 16:31:00.415  - info: admin.0 (3390) ==> Connected system.user.admin from ::ffff:192.168.178.24
    2024-12-01 16:31:00.474  - error: zigbee.0 (4610) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-12-01 16:31:10.190  - info: admin.0 (3390) <== Disconnect system.user.admin from ::ffff:192.168.178.24
    2024-12-01 16:32:21.351  - info: javascript.0 (3447) script.js.Hue_Push_API: missing update instructions for sensors.light.light_level_report
    2024-12-01 16:32:21.351  - info: javascript.0 (3447) script.js.Hue_Push_API: {"light":{"light_level":20188,"light_level_report":{"changed":"2024-12-01T15:32:21.516Z","light_level":20188}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
    2024-12-01 16:35:52.012  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 6147
    2024-12-01 16:35:53.069  - info: dwd.0 (6147) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
    2024-12-01 16:35:53.525  - info: dwd.0 (6147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-01 16:35:54.038  - info: host.smart instance system.adapter.dwd.0 having pid 6147 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-01 16:37:05.488  - info: javascript.0 (3447) script.js.Hue_Push_API: missing update instructions for sensors.temperature.temperature_report
    2024-12-01 16:37:05.488  - info: javascript.0 (3447) script.js.Hue_Push_API: {"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"},"temperature":{"temperature":5.61,"temperature_report":{"changed":"2024-12-01T15:37:05.657Z","temperature":5.61}}}
    und das summary sagt das hier:
                            v.2024-10-19
           Icon name: computer
        Architecture: arm64
    Installation:           native
    Kernel:                 aarch64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            8.4G        2.9G        4.3G        5.6M        1.3G        5.5G
    Swap:           209M          0B        209M
    Total:          8.7G        2.9G        4.5G
    ioBroker Core:          js-controller           7.0.3
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                20343
    States:                 15085
    Size of iob-Database:
    6.8M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    Mich wundern auch die 15 Errors im iob diag Zeile 93
    dirk@smart:~ $ sudo dmesg --level=emerg,alert,crit -T
    [Sun Dec  1 16:16:57 2024] Unable to handle kernel paging request at virtual address ffffc00080adbf04
    [Sun Dec  1 16:16:57 2024] Mem abort info:
    [Sun Dec  1 16:16:57 2024]   ESR = 0x0000000096000047
    [Sun Dec  1 16:16:57 2024]   EC = 0x25: DABT (current EL), IL = 32 bits
    [Sun Dec  1 16:16:57 2024]   SET = 0, FnV = 0
    [Sun Dec  1 16:16:57 2024]   EA = 0, S1PTW = 0
    [Sun Dec  1 16:16:57 2024]   FSC = 0x07: level 3 translation fault
    [Sun Dec  1 16:16:57 2024] Data abort info:
    [Sun Dec  1 16:16:57 2024]   ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
    [Sun Dec  1 16:16:57 2024]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
    [Sun Dec  1 16:16:57 2024]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
    [Sun Dec  1 16:16:57 2024] swapper pgtable: 16k pages, 47-bit VAs, pgdp=0000000001398000
    [Sun Dec  1 16:16:57 2024] [ffffc00080adbf04] pgd=100000010019c003, p4d=100000010019c003, pud=100000010019c003, pmd=10000001001a0003, pte=0000000000000000
    [Sun Dec  1 16:16:57 2024] Internal error: Oops: 0000000096000047 [#1] PREEMPT SMP
    [Sun Dec  1 16:16:57 2024] Code: d503201f b50000e2 14000020 38401423 (39000003)
    keine Ahnung ob das da schon "immer" stand oder neu ist.
    Raspi 4, 4GB für Influxdb 1.8 und Grafana
    Raspi 5, 8 GB für ioBroker
    Threadnetzwerk per Apple
    • Thomas BraunT Online
      @darkblu sagte in Zigbee Adapter bleibt gelb nach Raspi update:
      Das schaut von der Konfiguration her gut aus.
      Bis auf den zigbee-Port, den würde ich auf
      setzen.
      darkbluD 1 Antwort Letzte Antwort
      • darkbluD darkblu
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        dirk
        HOME=/home/dirk
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 8052 M total memory
                 2834 M used memory
                 4046 M free memory
                  121 M buffer memory
                 1151 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        710M    /var/
        206M    /var/cache
        200M    /var/cache/apt
        197M    /var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.1.5
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        20343
        States:         15086
        Pending Updates: 0
                                v.2024-10-19
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        MEMORY:
        Swap:           209M          0B        209M
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                20343
        States:                 15085
        haselchenH Offline
        haselchenH Offline
        haselchen
        Deine Load Average ist viel zu hoch.
        Du könntest mal das Ergebnis von htop hier in CodeTags posten.
        Und zu Deinen Errors.
        Die Fehlermeldung habe ich im Netz gefunden. Da wird gerätselt ob es ein Kernel Bug ist oder dem RAM zuzuordnen ist.
        Mit @Thomas-Braun Erlaubnis könntest Du ein KernelUpdate auf 6.6.63 machen und gucken, ob es damit behoben ist.
        sudo rpi-update
        Habs eben mal für Dich getestet
        darkbluD 2 Antworten Letzte Antwort
          setzen.
          darkbluD Online
          darkbluD Online
          darkblu
          setzen.
          dumme Frage, gebe ich das in der Instanz unter Einstellungen COM Anschlussname ein ?
          Kannst du noch etwas zu den 15 Errors sagen ?
          Nach gefühlt 20x iob fix und rebooten des Raspis ist der Adapter jetzt wieder grün.
          Ein Adventswunder
          • darkbluD darkblu
            setzen.
            Ein Adventswunder
            @darkblu sagte in [gelöst] Zigbee Adapter bleibt gelb nach Raspi update:
            Ja. Du ersetzt den bisherigen Eintrag.
            Nein.
            • haselchenH haselchen
              sudo rpi-update
              darkbluD Online
              darkbluD Online
              darkblu
              @haselchen said in [gelöst] Zigbee Adapter bleibt gelb nach Raspi update:
              hier die htop Ausgabe ( ok, leider nur ein screenshot)
              Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                sudo rpi-update
                darkbluD Online
                darkbluD Online
                darkblu
                sudo rpi-update
                und war der Test jetzt positiv, also soll ich das auch machen oder lieber doch nicht ?
                • darkbluD darkblu
                  @darkblu
                  Auf dem Screenshot ist es okay, beim iob diag von oben deutlich zu hoch:
                  • darkbluD darkblu
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @darkblu
                    Ok, jetzt ist sie wieder normal. Vermutlich musste nach dem Update noch was verarbeitet werden ?!
                    Wie sieht iob diag jetzt aus?
                    Errors noch da?
                    • darkbluD darkblu
                      sudo rpi-update
                      Nein, besser nicht.
                        Nein, besser nicht.
                        darkbluD Online
                        darkbluD Online
                        darkblu
                        hier der ganz frische iob diag:
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         18:11:14 up 49 min,  2 users,  load average: 0.35, 0.28, 0.32
                        CPU threads: 4
                        Current issues:
                                       Local time: Sun 2024-12-01 18:11:14 CET
                                   Universal time: Sun 2024-12-01 17:11:14 UTC
                                         RTC time: Sun 2024-12-01 17:11:14
                                      NTP service: active
                                  RTC in local TZ: no
                        dirk
                        HOME=/home/dirk
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.4G        3.0G        4.3G        5.6M        1.2G        5.4G
                        Swap:           209M          0B        209M
                                 8052 M total memory
                                 2906 M used memory
                                 2798 M active memory
                                  749 M inactive memory
                                 4137 M free memory
                                   83 M buffer memory
                                 1025 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        top - 18:11:15 up 49 min,  2 users,  load average: 0.35, 0.28, 0.32
                        Tasks: 195 total,   1 running, 194 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   8052.2 total,   4137.6 free,   2906.7 used,   1109.4 buff/cache
                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5145.6 avail Mem
                        No critical errors detected
                        *** FILESYSTEM ***
                        /dev/sda2      ext4      117G  7.3G  104G   7% /
                        [Sun Dec  1 17:21:59 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:4D:70:41 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eae5867b-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Sun Dec  1 17:22:02 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                        [Sun Dec  1 17:22:02 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                        /var:
                        715M    /var/
                        206M    /var/cache
                        202M    /var/lib
                        200M    /var/cache/apt
                        1.3G    /opt/iobroker/iobroker-data/
                        26M     /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        HINT:
                        /dev/ttyACM0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        smart               smart (version: 7.0.3, hostname: smart         , alive, uptime: 2942)
                        admin:          7.1.5
                        javascript:     8.8.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        20343
                        States:         15006
                        Hit:3 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 192.168.178.40:9092     0.0.0.0:*               LISTEN      1001       6946       1216/io.nuki.0
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        859        865/influxd
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          798        776/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6566       904/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6571       904/iobroker.js-con
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7803       1261/io.sonoff.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       6940       1246/io.shelly.1
                        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       6913       1201/io.mqtt.0
                        tcp6       0      0 :::3001                 :::*                    LISTEN      1001       9512       1517/io.fullybrowse
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7307       924/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9380       1397/io.web.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        5802       865/influxd
                        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       10174      2051/io.upnp.0
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       7815       1276/io.sonos.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          800        776/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:60854           0.0.0.0:*                           104        742        647/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10944      2082/io.wled.0
                        udp        0      0 192.168.178.40:5353     0.0.0.0:*                           1001       9221       1291/io.tr-064.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        740        647/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7756       1231/io.shelly.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10105      2051/io.upnp.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9244       1306/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9245       1306/io.tuya.0
                        udp        0      0 0.0.0.0:52000           0.0.0.0:*                           1001       9962       2051/io.upnp.0
                        udp6       0      0 fe80::1fd4:b7df:3ba:546 :::*                                0          886        729/NetworkManager
                        udp6       0      0 :::5353                 :::*                                104        741        647/avahi-daemon: r
                        udp6       0      0 :::35092                :::*                                104        743        647/avahi-daemon: r
                        2024-12-01 18:02:59.299  - info: javascript.0 (981) script.js.Hue_Push_API: missing update instructions for groups.owner.rid
                        2024-12-01 18:02:59.299  - info: javascript.0 (981) script.js.Hue_Push_API: {"dimming":{"brightness":71.15},"owner":{"rid":"f8c6e02c-9bd3-4e55-ad28-71d18c81224f","rtype":"room"}}
                        2024-12-01 18:02:59.299  - info: javascript.0 (981) script.js.Hue_Push_API: missing update instructions for groups.owner.rtype
                        2024-12-01 18:03:21.717  - info: admin.0 (924) <== Disconnect system.user.admin from ::ffff:192.168.178.24
                        2024-12-01 18:05:27.011  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 2344
                        2024-12-01 18:05:28.123  - info: dwd.0 (2344) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                        2024-12-01 18:05:28.569  - info: dwd.0 (2344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-12-01 18:05:29.080  - info: host.smart instance system.adapter.dwd.0 having pid 2344 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-12-01 18:06:30.394  - info: hmip.0 (1111) switchState - id "3014F711A000021A498E296C" - Too fast value changes, change blocked!
                        2024-12-01 18:06:36.652  - info: hmip.0 (1111) Value unchanged, do not send this value
                        2024-12-01 18:06:37.100  - info: fullybrowser.0 (1517) 🗸 192.168.178.128: Command screenOn successfully set to true
                        2024-12-01 18:06:37.101  - info: fullybrowser.0 (1517) 🗸 192.168.178.128: Command screenOn successfully set to true
                        2024-12-01 18:06:44.264  - info: web.0 (1397) ==> Connected system.user.admin from ::ffff:192.168.178.128
                        2024-12-01 18:07:05.373  - info: javascript.0 (981) script.js.Hue_Push_API: missing update instructions for sensors.temperature.temperature_report
                        2024-12-01 18:07:05.373  - info: javascript.0 (981) script.js.Hue_Push_API: {"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"},"temperature":{"temperature":3.58,"temperature_report":{"changed":"2024-12-01T17:07:05.547Z","temperature":3.58}}}
                        2024-12-01 18:08:11.668  - info: fullybrowser.0 (1517) 🗸 192.168.178.128: Command screenOff successfully set to true
                        2024-12-01 18:09:09.758  - info: vw-connect.0 (1382) State value to set for "vw-connect.0.wecharge.chargeandpay.records.latestItem.location_coordinates_latitude" has to be type "number" but received type "string"
                        2024-12-01 18:09:09.758  - info: vw-connect.0 (1382) State value to set for "vw-connect.0.wecharge.chargeandpay.records.latestItem.location_coordinates_longitude" has to be type "number" but received type "string"
                        2024-12-01 18:09:37.655  - info: hmip.0 (1111) Value unchanged, do not send this value
                        2024-12-01 18:10:27.013  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 2403
                        2024-12-01 18:10:28.213  - info: dwd.0 (2403) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                        2024-12-01 18:10:28.662  - info: dwd.0 (2403) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-12-01 18:10:29.176  - info: host.smart instance system.adapter.dwd.0 having pid 2403 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-12-01 18:10:43.209  - info: hmip.0 (1111) Value unchanged, do not send this value
                        iob diag has finished.
                        das war wohl wirklich nur eine ungünstige Momenaufnahme zu kurz nach dem update.
                        Ich danke euch vielmals
                        • darkbluD darkblu
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                        NTP service: active
                                    RTC in local TZ: no
                          dirk
                          HOME=/home/dirk
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           209M          0B        209M
                                   8052 M total memory
                                   2906 M used memory
                                   4137 M free memory
                                     83 M buffer memory
                                   1025 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          *** FILESYSTEM ***
                          /var:
                          715M    /var/
                          206M    /var/cache
                          202M    /var/lib
                          200M    /var/cache/apt
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyACM0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        20343
                          States:         15006
                          Pending Updates: 0
                          USB-Devices by-id:
                          Stell das um...
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyACM0
                            USB-Devices by-id:
                            Stell das um...
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyACM0
                            darkbluD Online
                            darkbluD Online
                            darkblu
                            @thomas-braun , JAAA - hetz mich nicht 😃
                            erledigt:
                            • darkbluD darkblu
                              erledigt:
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @darkblu
                              Nachdem das jetzt vom Tisch ist - poste bitte nochmal ein log vom Start des Adapters - aber bitte vollständig, sprich:
                              • Adapter anhalten
                              • sicherstellen das kein Prozess oder Unterprozess des Adapters noch läuft - das kann manchmal ein paar Sekunden dauern bis alles aufgeräumt ist.
                              • Markierung im Log setzen (ich lösch das Log an der stelle immer gerne)
                              • Adapter starten
                              • ca, 30 Sekunden warten
                              • Log ab der Markierung nehmen - nur die Einträge die von anderen Adaptern sind löschen (Ausgenommen Admin, JS-Controller, host, Zigbee)
                              • Hier posten.
                              A.
                              • AsgothianA Asgothian
                                @darkblu
                                • Adapter anhalten
                                • Adapter starten
                                • Hier posten.
                                A.
                                darkbluD Online
                                darkbluD Online
                                darkblu
                                @asgothian ,
                                hier ist es (hoffentlich wie gewünscht):
                                2024-12-02 14:50:44.263 - info: host.smart "system.adapter.zigbee.0" enabled
                                2024-12-02 14:50:44.849 - info: host.smart instance system.adapter.zigbee.0 in version "1.10.3" started with pid 9991
                                2024-12-02 14:50:46.700 - info: zigbee.0 (9991) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                                2024-12-02 14:50:46.738 - info: zigbee.0 (9991) delete old Backup files. keep only last 10
                                2024-12-02 14:50:46.740 - info: zigbee.0 (9991) Starting Zigbee npm ...
                                2024-12-02 14:50:46.882 - info: zigbee.0 (9991) Installed Version: iobroker.zigbee@1.10.3
                                2024-12-02 14:50:47.071 - info: zigbee.0 (9991) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
                                2024-12-02 14:50:47.092 - info: zigbee.0 (9991) Unable to disable LED, unsupported function.
                                2024-12-02 14:50:47.098 - info: zigbee.0 (9991) --> transmitPower : normal
                                2024-12-02 14:50:47.138 - info: zigbee.0 (9991) Unable to set transmit power, unsupported function.
                                2024-12-02 14:50:47.141 - info: zigbee.0 (9991) Currently 41 devices are joined:
                                2024-12-02 14:50:47.231 - info: zigbee.0 (9991) 0xa4c138263bc0fd54 (addr 48646): A1Z - Nous Smart plug (with power monitoring) (Router)
                                2024-12-02 14:50:47.233 - info: zigbee.0 (9991) 0x00158d00068a104e (addr 5382): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.234 - info: zigbee.0 (9991) 0x00158d00067bd760 (addr 5944): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.234 - info: zigbee.0 (9991) 0x00158d00068a0fc8 (addr 61509): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.235 - info: zigbee.0 (9991) 0x00158d000689b44c (addr 15607): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.235 - info: zigbee.0 (9991) 0x00158d00044fd0ff (addr 51864): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.236 - info: zigbee.0 (9991) 0x00158d000659483a (addr 7445): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.237 - info: zigbee.0 (9991) 0xa4c1383c2241067d (addr 37641): A1Z - Nous Smart plug (with power monitoring) (Router)
                                2024-12-02 14:50:47.238 - info: zigbee.0 (9991) 0x00158d00065a416f (addr 36888): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.238 - info: zigbee.0 (9991) 0x00158d000689def2 (addr 8433): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.239 - info: zigbee.0 (9991) 0x00158d000679680d (addr 55433): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.239 - info: zigbee.0 (9991) 0x00158d000689725b (addr 47949): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.240 - info: zigbee.0 (9991) 0x00158d000679208d (addr 34859): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.240 - info: zigbee.0 (9991) 0x00158d00068971cc (addr 60564): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.240 - info: zigbee.0 (9991) 0x00158d00067bd833 (addr 59748): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.241 - info: zigbee.0 (9991) 0x00158d00067bf5e6 (addr 18745): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.241 - info: zigbee.0 (9991) 0x00158d00067c039a (addr 47927): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.242 - info: zigbee.0 (9991) 0x00158d00067bd6a0 (addr 2007): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.242 - info: zigbee.0 (9991) 0x847127fffe7f023c (addr 4772): SP 220 - Innr Smart plug (Router)
                                2024-12-02 14:50:47.243 - info: zigbee.0 (9991) 0x847127fffe1a1543 (addr 18863): SP 220 - Innr Smart plug (Router)
                                2024-12-02 14:50:47.243 - info: zigbee.0 (9991) 0x00158d00067bfbdd (addr 61571): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.243 - info: zigbee.0 (9991) 0x00158d0006897144 (addr 14303): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.244 - info: zigbee.0 (9991) 0x00158d000651801e (addr 55867): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                                2024-12-02 14:50:47.244 - info: zigbee.0 (9991) 0x00158d00067233bc (addr 13967): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                                2024-12-02 14:50:47.245 - info: zigbee.0 (9991) 0xbc33acfffe22f54d (addr 52407): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                2024-12-02 14:50:47.245 - info: zigbee.0 (9991) 0x3425b4fffe7d9225 (addr 50663): E1743 - IKEA TRADFRI on/off switch (EndDevice)
                                2024-12-02 14:50:47.246 - info: zigbee.0 (9991) 0x00158d00067bf5ba (addr 12983): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                2024-12-02 14:50:47.246 - info: zigbee.0 (9991) 0xbc33acfffe1dbb97 (addr 28468): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                2024-12-02 14:50:47.247 - info: zigbee.0 (9991) 0xcc86ecfffe25fcc0 (addr 14766): SP 220 - Innr Smart plug (Router)
                                2024-12-02 14:50:47.247 - info: zigbee.0 (9991) 0xcc86ecfffe2abecf (addr 7625): SP 220 - Innr Smart plug (Router)
                                2024-12-02 14:50:47.247 - info: zigbee.0 (9991) 0x00158d0007105346 (addr 41994): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.248 - info: zigbee.0 (9991) 0x00158d0006e4c790 (addr 42188): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                2024-12-02 14:50:47.248 - info: zigbee.0 (9991) 0x00158d0007504e37 (addr 49576): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                2024-12-02 14:50:47.248 - info: zigbee.0 (9991) 0x00158d00073a24bb (addr 243): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x00158d00073a2955 (addr 43923): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x84fd27fffe2a515f (addr 16538): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x001788010bd5349f (addr 48418): 929002469202 - Philips Hue white A60 bulb E27 1050lm with Bluetooth (Router)
                                2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x04cd15fffe330915 (addr 30337): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                                2024-12-02 14:50:47.250 - info: zigbee.0 (9991) 0x04cd15fffe2e1e25 (addr 32635): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                                2024-12-02 14:50:47.250 - info: zigbee.0 (9991) 0x84b4dbfffe9f6168 (addr 11791): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                                2024-12-02 14:50:47.250 - info: zigbee.0 (9991) 0xf082c0fffede13d6 (addr 43459): E1743 - IKEA TRADFRI on/off switch (EndDevice)
                                2024-12-02 14:50:47.251 - info: zigbee.0 (9991) Zigbee started
                                2024-12-02 14:50:47.317 - info: zigbee.0 (9991) debug devices set to []
                                • darkbluD darkblu
                                  @asgothian ,
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @darkblu Das sieht doch gut aus - es sollte laufen ?
                                    darkbluD Online
                                    darkbluD Online
                                    darkblu
                                    @asgothian said in [gelöst] Zigbee Adapter bleibt gelb nach Raspi update:
                                    ja, es löppt alles 😰
