  4. Test Adapter Controme v0.5.x
56 Beiträge 5 Kommentatoren 9.2k Aufrufe 4 Beobachtet
    @nobbiman
    Nein, die Langfassung. Du hastt da auch noch einen ganzen Zoo an Paketquellen drin, die nicht zum bullseye passen.
    N Offline
    N Offline
    nobbiman
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
       Static hostname: RasPi-ioBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.6.67-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2024-12-30 11:34:38 CET
               Universal time: Mon 2024-12-30 10:34:38 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        2.1G        437M        0.0K        1.3G        1.6G
    Swap:           2.1G        245M        1.9G
    Total:          5.9G        2.3G        2.3G
    Active iob-Instances:   20
             3790 M total memory
             2085 M used memory
             1823 M active memory
             1289 M inactive memory
              437 M free memory
              145 M buffer memory
             1121 M swap cache
             2147 M total swap
              245 M used swap
             1902 M free swap
    top - 11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
    Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 15.2 us,  4.5 sy,  0.0 ni, 78.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
    MiB Mem :   3791.0 total,    436.7 free,   2086.9 used,   1267.3 buff/cache
    MiB Swap:   2148.0 total,   1902.0 free,    246.0 used.   1620.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      459G   16G  425G   4% /
    devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      255M   33M  223M  13% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Mon Dec 30 09:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=94303a9e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): recovery complete
    [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): mounted filesystem d98b1a68-4ff7-4331-86d3-77c5d911b429 ro with ordered data mode. Quota mode: none.
    [Mon Dec 30 09:38:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Dec 30 09:38:35 2024] EXT4-fs (sda2): re-mounted d98b1a68-4ff7-4331-86d3-77c5d911b429 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.0G    /var/
    1.6G    /var/log
    1.3G    /var/log/journal/2d06defc2eb445c9afef1cfd904ac913
    1.2G    /var/lib
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    940M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    961M    /opt/iobroker/iobroker-data/
    781M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    28M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    RasPi-ioBroker      RasPi-ioBroker (version: 7.0.6, hostname: RasPi-ioBroker, alive, uptime: 830)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.controme@0.5.3 (git+ssh://git@github.com/MadErstam/ioBroker.controme.git#a40bf461eadee0352492c1bf151fcb288f890fe2)
    Adapter State
    + system.adapter.admin.0                  : admin                 : RasPi-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RasPi-ioBroker                           -  enabled
      system.adapter.controme.0               : controme              : RasPi-ioBroker                           -  enabled
    + system.adapter.discovery.0              : discovery             : RasPi-ioBroker                           -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi-ioBroker                           -  enabled
    + system.adapter.fhem.0                   : fhem                  : RasPi-ioBroker                           -  enabled, port: 7072
    + system.adapter.fritzdect.0              : fritzdect             : RasPi-ioBroker                           -  enabled
    + system.adapter.growatt.0                : growatt               : RasPi-ioBroker                           -  enabled
    + system.adapter.history.0                : history               : RasPi-ioBroker                           -  enabled
    + system.adapter.influxdb.0               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : RasPi-ioBroker                           -  enabled
      system.adapter.maxcul.0                 : maxcul                : RasPi-ioBroker                           - disabled
    + system.adapter.modbus.0                 : modbus                : RasPi-ioBroker                           -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : RasPi-ioBroker                           - disabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : RasPi-ioBroker                           -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.powerfox2.0              : powerfox2             : RasPi-ioBroker                           -  enabled
      system.adapter.powerfox2.1              : powerfox2             : RasPi-ioBroker                           -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : RasPi-ioBroker                           -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : RasPi-ioBroker                           -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : RasPi-ioBroker                           -  enabled
    + system.adapter.shelly.0                 : shelly                : RasPi-ioBroker                           -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.viessmannapi.0           : viessmannapi          : RasPi-ioBroker                           -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi-ioBroker                           -  enabled
      system.adapter.vis.0                    : vis                   : RasPi-ioBroker                           -  enabled
    + system.adapter.web.0                    : web                   : RasPi-ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "fhem"         : 3.0.0    , installed 3.0.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "growatt"      : 3.3.1    , installed 3.3.1
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
    Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
    Adapter    "web"          : 6.2.5    , installed 6.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        23107
    States:         19835
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:9 https://apt.glennr.nl/repo bullseye InRelease
    Hit:10 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/7.0 InRelease
    Get:11 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7517 B]
    Fetched 7517 B in 2s (3034 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96463      20066/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       94929      20027/io.shelly.0
    tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      117        6468       1169/bin/mongod
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5527       534/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2496       603/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95636      19881/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95631      19881/iobroker.js-c
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7445       541/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       95058      20216/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96285      19901/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      117        6029       599/java
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        7528       1063/grafana
    tcp6       0      0 :::6789                 :::*                    LISTEN      117        7630       599/java
    tcp6       0      0 :::8843                 :::*                    LISTEN      117        6032       599/java
    tcp6       0      0 :::8880                 :::*                    LISTEN      117        6030       599/java
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5526       534/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2498       603/sshd: /usr/sbin
    tcp6       0      0 :::8443                 :::*                    LISTEN      117        6031       599/java
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2427       384/avahi-daemon: r
    udp        0      0 0.0.0.0:40839           0.0.0.0:*                           108        2429       384/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2530       483/dhcpcd: [master
    udp6       0      0 :::5353                 :::*                                108        2428       384/avahi-daemon: r
    udp6       0      0 :::5514                 :::*                                117        7635       599/java
    udp6       0      0 :::3478                 :::*                                117        7626       599/java
    udp6       0      0 :::44558                :::*                                108        2430       384/avahi-daemon: r
    udp6       0      0 192.168.2.40:42712      :::*                                117        7638       599/java
    udp6       0      0 :::10001                :::*                                117        7639       599/java
    udp6       0      0 :::546                  :::*                                0          2546       483/dhcpcd: [master
    2024-12-30 11:34:28.120  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 23451 terminated with code 0 (NO_ERROR)
    2024-12-30 11:34:50.031  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 23772
    2024-12-30 11:34:52.700  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
    2024-12-30 11:34:52.717  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
    2024-12-30 11:34:52.762  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
    2024-12-30 11:34:52.791  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
    2024-12-30 11:34:52.815  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
    2024-12-30 11:34:52.828  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
    2024-12-30 11:34:53.400  - info: powerfox2.1 (23772) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
    2024-12-30 11:34:53.891  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11206.707 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11206.707
    2024-12-30 11:34:53.916  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.684 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.684
    2024-12-30 11:34:54.074  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3725.902 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3725.902
    2024-12-30 11:34:54.103  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11943.326 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11943.326
    2024-12-30 11:34:54.115  - info: powerfox2.1 (23772) Terminated (NO_ERROR): Without reason
    2024-12-30 11:34:54.647  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 having pid 23772 terminated with code 0 (NO_ERROR)
    2024-12-30 11:35:22.631  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
    2024-12-30 11:35:22.656  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
    2024-12-30 11:35:22.694  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
    2024-12-30 11:35:22.810  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
    2024-12-30 11:35:22.822  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
    2024-12-30 11:35:22.835  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
    2024-12-30 11:35:24.034  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 25097
    2024-12-30 11:35:26.970  - info: powerfox2.0 (25097) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
    2024-12-30 11:35:28.040  - info: powerfox2.0 (25097) Terminated (NO_ERROR): Without reason
    2024-12-30 11:35:28.584  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 25097 terminated with code 0 (NO_ERROR)
    • mcm1957M mcm1957
      @nobbiman
      Siehe:
      https://forum.iobroker.net/topic/78355/test-adapter-controme-v0-5-x/13
      N Offline
      N Offline
      nobbiman
      @mcm1957 Ja, ich werde ein Issue aufmachen, warte im Moment noch ab, was sich noch bei @Thomas-Braun ergibt
        @nobbiman sagte in Test Adapter Controme v0.5.x:
        wie ich meine Daten der Programme sichern muss;
        Per Backitup-Adapter.
        N Offline
        N Offline
        nobbiman
        schrieb am zuletzt editiert von nobbiman
        @thomas-braun Backitup sichert auch Influxx-DB und Grafana-Einstellungen und Grafiken?
        • N nobbiman
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   3790 M total memory
                   2085 M used memory
                    437 M free memory
                    145 M buffer memory
                   1121 M swap cache
                   2147 M total swap
                    245 M used swap
                   1902 M free swap
          *** FILESYSTEM ***
          /var:
          3.0G    /var/
          1.6G    /var/log
          1.2G    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        23107
          States:         19835
          Pending Updates: 0
          Da hat es wohl Einschläge im Dateisystem gegeben. Fahr die Kister IMMER ordentlich herunter, bevor du die vom Strom nimmst.
          Zu controme: Installier den NICHT aus dem GitHub sondern aus einem ioBroker-Repo, sofern da vorhanden.
          • system.adapter.influxdb.0 : influxdb : RasPi-ioBroker - enabled, port: 8086
          • system.adapter.influxdb.1 : influxdb : RasPi-ioBroker - enabled, port: 8086
          dürfte so auch falsch sein.
          Die Quellen würde ich mir anschauen, warum die überhaupt angelegt wurden und ob es da nicht besser passende für dein Release gibt:
          Wenn du es einstellst, ja.
          N 1 Antwort Letzte Antwort
            N Offline
            N Offline
            nobbiman
            @thomas-braun sagte in Test Adapter Controme v0.5.x:
            .. und genau da liegt mein Problem, wenn ich als Laie mit einem Profi chatte, ich verstehe nur Bahnhof und bin z.B. nicht in der Lage zu checken, ob die genannten "Hits" 4,9,10,11 dort hin gehören oder nicht.
            Meine einzige Möglichkeit ist die einer kompletten und sauberen Neuinstalltion unter Bookworm.
            Ich habe mich mal mit dem Backitup befasst und ein Backup durchgeführt. Dort stoße ich auf die Fehlermeldung
            13:30:10.448
            INFO
            gui
            Backup gestartet ...
            13:30:10.516
            DEBUG
            mount
            Wake on LAN wait 180 Seconds for NAS!
            13:30:10.528
            DEBUG
            mount
            Wake on LAN MAC-Address: 00:11:32:37:8C:5C
            13:30:10.531
            DEBUG
            mount
            mount activ... umount is started before mount!!
            13:30:10.578
            DEBUG
            mount
            umount successfully completed
            [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
            13:33:10.487
            DEBUG
            mount
            cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.20/homes/backup/ioBroker/ /opt/iobroker/backups"
            13:33:10.749
            DEBUG
            mount
            13:33:10.752
            DEBUG
            mount
            done
            [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"06:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"timestamp":1735561810465,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.2.40","port":8086,"dbversion":"2.x","token":"60a9d6d04cd505C","protocol":"https","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"PoweroptiPatrickhisory","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.2.40","port":"3000","protocol":"https","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1735561810465}
            13:33:20.052
            DEBUG
            iobroker
            host.RasPi-ioBroker 23099 objects saved
            13:33:21.952
            DEBUG
            iobroker
            host.RasPi-ioBroker 19811 states saved
            host.RasPi-ioBroker Validating backup ...
            13:33:21.961
            DEBUG
            iobroker
            host.RasPi-ioBroker "config.json" is valid
            13:33:21.970
            DEBUG
            iobroker
            host.RasPi-ioBroker "objects.jsonl" exists
            13:33:22.016
            DEBUG
            iobroker
            host.RasPi-ioBroker "states.jsonl" exists
            13:33:23.052
            DEBUG
            iobroker
            host.RasPi-ioBroker JSONL lines are valid
            13:33:23.076
            DEBUG
            iobroker
            host.RasPi-ioBroker The backup is valid!
            13:33:26.634
            DEBUG
            iobroker
            Backup created: /opt/iobroker/backups/iobroker_2024_12_30-13_33_10_backupiobroker.tar.gz
            13:33:26.743
            DEBUG
            iobroker
            This backup can only be restored with js-controller version 7.0 or higher
            13:33:27.670
            DEBUG
            iobroker
            done
            13:33:27.857
            DEBUG
            influxDB
            InfluxDB-Backup started ...
            13:33:27.863
            DEBUG
            influxDB
            Start InfluxDB Backup ...
            13:33:27.864
            DEBUG
            influxDB
            InfluxDB Backup tmp directory created
            13:33:27.871
            DEBUG
            influxDB
            Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
            13:33:27.910
            DEBUG
            influxDB
            InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker" successfully deleted
            [DEBUG] [influxDB] -
            13:33:27.933
            ERROR
            influxDB
            Error: Command failed: influx backup --bucket iobroker --host https://192.168.2.40:8086 --skip-verify -t 60a9d6d04cd505C "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
            Error: API compatibility check failed: Get "https://192.168.2.40:8086/health": http: server gave HTTP response to HTTPS client
            13:33:27.938
            DEBUG
            influxDB
            InfluxDB-Backup for is finish
            13:33:27.944
            DEBUG
            influxDB
            done
            13:33:28.663
            ERROR
            historyDB
            BackItUp cannot found source "undefined" for compress!
            Leider kann ich in den Logdaten nicht sehen, ob alle Daten, also auch die von Grafana, gesichert wurden.
            Bevor das nicht klar ist, wede ich keine KOmplettinstallation durchführen.
            • N nobbiman
              13:30:10.448
              INFO
              gui
              13:30:10.516
              DEBUG
              mount
              13:30:10.528
              DEBUG
              mount
              13:30:10.531
              DEBUG
              mount
              13:30:10.578
              DEBUG
              mount
              13:33:10.487
              DEBUG
              mount
              13:33:10.749
              DEBUG
              mount
              13:33:10.752
              DEBUG
              mount
              done
              13:33:20.052
              DEBUG
              iobroker
              13:33:21.952
              DEBUG
              iobroker
              13:33:21.961
              DEBUG
              iobroker
              13:33:21.970
              DEBUG
              iobroker
              13:33:22.016
              DEBUG
              iobroker
              13:33:23.052
              DEBUG
              iobroker
              13:33:23.076
              DEBUG
              iobroker
              13:33:26.634
              DEBUG
              iobroker
              13:33:26.743
              DEBUG
              iobroker
              13:33:27.670
              DEBUG
              iobroker
              done
              13:33:27.857
              DEBUG
              influxDB
              13:33:27.863
              DEBUG
              influxDB
              13:33:27.864
              DEBUG
              influxDB
              13:33:27.871
              DEBUG
              influxDB
              13:33:27.910
              DEBUG
              influxDB
              13:33:27.933
              ERROR
              influxDB
              13:33:27.938
              DEBUG
              influxDB
              13:33:27.944
              DEBUG
              influxDB
              done
              13:33:28.663
              ERROR
              historyDB
              Du hast sie aber als Admin von dem System angelegt. Dann musst du also auch wissen, warum.
                N Offline
                N Offline
                nobbiman
                Das mag sein, ändert an meiner Aussage aber nichts, da mir die Installation nicht mehr bewußt ist. Vielleicht gehe ich mit meinem System auch nicht so sorgsam um wie du!
                • N nobbiman
                  @nobbiman
                  Wenn du nicht weißt, warum die da sind brauchst du sie offenbar ja nicht.
                    @nobbiman
                    N Offline
                    N Offline
                    nobbiman
                    @thomas-braun So wollte ich auch an die Sache gehen, die sich m.E. aber mit einer Neuaufsetzung des Systems ohnehin erledigt hätte, in der Annahme, dass die genannten Bestandteile kein "Beifang" der Standardinstallation und der gelisteten Adapter sind.
                    Kannst du denn etwas zur Backitup-Fehlermeldung beitragen, damit ich die Neuinstallation angehen kann?
                    • N nobbiman
                      13:30:10.448
                      INFO
                      gui
                      13:30:10.516
                      DEBUG
                      mount
                      13:30:10.528
                      DEBUG
                      mount
                      13:30:10.531
                      DEBUG
                      mount
                      13:30:10.578
                      DEBUG
                      mount
                      13:33:10.487
                      DEBUG
                      mount
                      13:33:10.749
                      DEBUG
                      mount
                      13:33:10.752
                      DEBUG
                      mount
                      done
                      13:33:20.052
                      DEBUG
                      iobroker
                      13:33:21.952
                      DEBUG
                      iobroker
                      13:33:21.961
                      DEBUG
                      iobroker
                      13:33:21.970
                      DEBUG
                      iobroker
                      13:33:22.016
                      DEBUG
                      iobroker
                      13:33:23.052
                      DEBUG
                      iobroker
                      13:33:23.076
                      DEBUG
                      iobroker
                      13:33:26.634
                      DEBUG
                      iobroker
                      13:33:26.743
                      DEBUG
                      iobroker
                      13:33:27.670
                      DEBUG
                      iobroker
                      done
                      13:33:27.857
                      DEBUG
                      influxDB
                      13:33:27.863
                      DEBUG
                      influxDB
                      13:33:27.864
                      DEBUG
                      influxDB
                      13:33:27.871
                      DEBUG
                      influxDB
                      13:33:27.910
                      DEBUG
                      influxDB
                      13:33:27.933
                      ERROR
                      influxDB
                      13:33:27.938
                      DEBUG
                      influxDB
                      13:33:27.944
                      DEBUG
                      influxDB
                      done
                      13:33:28.663
                      ERROR
                      historyDB
                      Deutet darauf hin, dass du da mit unterschiedlichen Protokollen hantierst.
                      N 2 Antworten Letzte Antwort
                        N Offline
                        N Offline
                        nobbiman
                        @thomas-braun OK, Danke, dann gehe ich die Neuinstallation im neuen Jahr mal an.
                          Mittlerweile habe ich eine iOB-Neuinstallation gestartet,
                          Dann nhätte ich auch das Betriebssystem auf die aktuelle Version gesetzt..
                          N Offline
                          N Offline
                          nobbiman
                          @thomas-braun Ich weiß nicht, ob ich hier in diesem Thread weitermachen soll oder besser einen neuen aufmache; ich versuche es mal hier:
                          Ich habe mittlerweile mein System komplett neu auf einem RasPi 5 (mit der alten IP-Adresse) mit bookworm aufgesetzt und über backitup die Datensicherung beim ioBroker eingespielt. Mit dabei waren Influxdb und Grafana; letztere sollen über meine abgespeicherten Links unter Windows wieder erreichbar sein.
                          Nach dem Restore wollen aber die 3 Influx-Instanzen nicht mehr starten, im Protokoll finde ich die Hinweise
                          influxdb.0
                          	2025-01-04 17:22:13.573	info	Influx DB Version used: 2.x
                          influxdb.0
                          	2025-01-04 17:22:13.573	info	Connecting http://192.168.2.40:8086/ ...
                          influxdb.0
                          	2025-01-04 17:22:03.573	error	Error: connect ECONNREFUSED 192.168.2.40:8086
                          Möglicherweise muss der Port 8086 freigegeben werden, oder? Auf Grafana kann ich über den Port 3000 auch nicht zugreifen!
                          Kann mir jemand sagen, wie ich weiter vorgehen sollte?
                          iob diag ergibt
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                           Static hostname: raspberrypi
                                 Icon name: computer
                                    Kernel: Linux 6.6.51+rpt-rpi-2712
                              Architecture: arm64
                          OS is similar to:
                          Model           : Raspberry Pi 5 Model B Rev 1.1
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           17:14:06 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                          CPU threads: 4
                          Operating System is the current Debian stable version codenamed 'bookworm'!
                          Current issues:
                          ~ Under-voltage has occurred
                                         Local time: Sat 2025-01-04 17:14:06 CET
                                     Universal time: Sat 2025-01-04 16:14:06 UTC
                                           RTC time: Sat 2025-01-04 16:14:06
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.2G        1.8G        714M        5.5M        1.8G        2.4G
                          Swap:           536M          0B        536M
                          Total:          4.8G        1.8G        1.3G
                          Active iob-Instances:   22
                                   4045 M total memory
                                   1721 M used memory
                                   1817 M active memory
                                   1210 M inactive memory
                                    681 M free memory
                                    116 M buffer memory
                                   1595 M swap cache
                                    511 M total swap
                                      0 M used swap
                                    511 M free swap
                          top - 17:14:07 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                          Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   4045.1 total,    681.2 free,   1721.9 used,   1712.3 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2323.2 avail Mem
                          *** FILESYSTEM ***
                          udev           devtmpfs  1.9G     0  1.9G   0% /dev
                          tmpfs          tmpfs     405M  5.2M  400M   2% /run
                          /dev/sda2      ext4      110G  5.5G   99G   6% /
                          tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                          /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                          tmpfs          tmpfs     405M     0  405M   0% /run/user/1000
                          [Sat Jan  4 15:37:46 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Sat Jan  4 15:37:49 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                          [Sat Jan  4 15:37:51 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          930M    /var/
                          206M    /var/cache
                          200M    /var/cache/apt
                          164M    /var/lib
                          135M    /var/lib/apt/lists
                          Archived and active journals take up 47.9M in the file system.
                          9.1M    /opt/iobroker/backups/
                          853M    /opt/iobroker/iobroker-data/
                          808M    /opt/iobroker/iobroker-data/files
                          33M     /opt/iobroker/iobroker-data/objects.jsonl
                          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                          13M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                           *** 20.18.1-1nodesource1 1001
                               20.18.0-1nodesource1 1001
                               20.17.0-1nodesource1 1001
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                               18.19.0+dfsg-6~deb12u2 500
                               18.19.0+dfsg-6~deb12u1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1218)
                          admin:          7.1.5
                          javascript:     8.8.3
                          nodejs modules from github:     0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.controme.0               : controme              : raspberrypi                              -  enabled
                            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                          + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
                          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                          + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          + system.adapter.maxcul.0                 : maxcul                : raspberrypi                              -  enabled
                          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                          + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
                            system.adapter.powerfox2.1              : powerfox2             : raspberrypi                              -  enabled
                          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                          + system.adapter.pvforecast.1             : pvforecast            : raspberrypi                              -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + instance is alive
                          Objects and States
                          Objects:        22957
                          States:         19667
                          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                          Pending Updates: 12
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7374       660/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41842      11153/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41837      11153/iobroker.js-c
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       45413      11889/io.mqtt.0
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       44833      12073/io.shelly.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          7376       660/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44054      11183/io.admin.0
                          udp        0      0 0.0.0.0:42016           0.0.0.0:*                           104        7274       534/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7272       534/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                104        7273       534/avahi-daemon: r
                          udp6       0      0 :::49420                :::*                                104        7275       534/avahi-daemon: r
                          udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          4758       620/NetworkManager
                          2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                          2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                          2025-01-04 17:14:21.005  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                          2025-01-04 17:14:21.223  - info: powerfox2.0 (14082) Terminated (NO_ERROR): Without reason
                          2025-01-04 17:14:21.815  - warn: powerfox2.0 (14082) get state error: Connection is closed.
                          2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                          2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                          2025-01-04 17:14:23.489  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                          2025-01-04 17:14:24.753  - info: host.raspberrypi instance system.adapter.powerfox2.0 having pid 14082 terminated with code 0 (NO_ERROR)
                          2025-01-04 17:14:30.984  - info: influxdb.2 (11731) Connecting http://192.168.2.40:8086/ ...
                          2025-01-04 17:14:30.985  - info: influxdb.2 (11731) Influx DB Version used: 2.x
                          2025-01-04 17:14:30.987  - error: influxdb.2 (11731) Error: connect ECONNREFUSED 192.168.2.40:8086
                          2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                          2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                          2025-01-04 17:14:31.008  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                          2025-01-04 17:14:32.383  - info: fhem.0 (12803) event FHEM: myStatDevice | statistics myStatDevice Updated stats for: MiniPV_Messung_Shelly | state > fhem.0.myStatDevice.state Updated stats for: MiniPV_Messung_Shelly
                          2025-01-04 17:14:32.588  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                          2025-01-04 17:14:32.608  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 0.3 > set alias.0.PVAnlage.ModulleistungGarage 0.3
                          2025-01-04 17:14:32.627  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 2.700000047683716 > set alias.0.PVAnlage.PVGarageSystemleistungTag 2.700000047683716
                          2025-01-04 17:14:32.648  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.5 > set alias.0.PVAnlage.Akkutemperatur 9.5
                          2025-01-04 17:14:32.667  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 103 > set alias.0.PVAnlage.BatterieEntladen 103
                          2025-01-04 17:14:32.695  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieLaden | 0 > set alias.0.PVAnlage.BatterieLaden 0
                          2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                          2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                          2025-01-04 17:14:33.492  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                          Nun habe ich einige Hinweise im Backupit-Wiki gefunden, da werde ich erst einmal lesen.
                            N Offline
                            N Offline
                            nobbiman
                            @thomas-braun So, nun bin ich wieder auf Stand und habe die Neuinstallation auf meinem neuen RasPi 5 (fast) laufen. Fast? - ja, nur noch der Controme-Adapter zickt und weist Fehlermeldungen auf, obwohl ich alle Adaptereinstellungen wie auf meinem Alt-RasPi vorgenommen habe.
                            Die Controme-Instanz zeigt eine durchgängigen grünen Status, die auszugsweisen Fehlermeldungen lauten wie folgt:
                            2025-01-07 10:03:01.249	warn	State "controme.0.16.humidity" has no existing object, this might lead to an error in future versions
                            controme.0
                            	2025-01-07 10:03:01.214	warn	State "controme.0.16.temporary_mode_end" has no existing object, this might lead to an error in future versions
                            controme.0
                            	2025-01-07 10:03:01.209	warn	State "controme.0.16.temporary_mode_remaining" has no existing object, this might lead to an error in future versions
                            controme.0
                            	2025-01-07 10:03:01.208	warn	State "controme.0.16.actualTemperature" has no existing object, this might lead to an error in future versions
                            Meine Internetrecherche ergab zu der Fehlermeldung die Notwendigkeit, den Adapter über Github zu installieren, verstehe aber nicht den Sinn, das dort auch nur die Version 0.5.3 zur Verfügung steht.
                            Sollte ihr mich weiterhin unterstützen wollen hier zur Fehleranalyse ioB diag:
                            ```bash
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                             Static hostname: ioBraspi
                                   Icon name: computer
                                      Kernel: Linux 6.6.62+rpt-rpi-2712
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                            CPU threads: 4
                            Current issues:
                                           Local time: Tue 2025-01-07 10:06:52 CET
                                       Universal time: Tue 2025-01-07 09:06:52 UTC
                                             RTC time: Tue 2025-01-07 09:06:52
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.2G        2.2G        1.3G        5.5M        819M        2.0G
                            Swap:           536M          0B        536M
                            Total:          4.8G        2.2G        1.8G
                            Active iob-Instances:   21
                                     4045 M total memory
                                     2110 M used memory
                                     1626 M active memory
                                      922 M inactive memory
                                     1223 M free memory
                                      123 M buffer memory
                                      657 M swap cache
                                      511 M total swap
                                        0 M used swap
                                      511 M free swap
                            top - 10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                            Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
                            MiB Mem :   4045.0 total,   1223.2 free,   2110.7 used,    781.4 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1934.3 avail Mem
                            *** FILESYSTEM ***
                            udev           devtmpfs  2.0G     0  2.0G   0% /dev
                            /dev/sda2      ext4      110G  6.7G   98G   7% /
                            /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
                            [Mon Jan  6 22:21:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Mon Jan  6 22:21:59 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                            [Mon Jan  6 22:22:00 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                            /var:
                            1.1G    /var/
                            237M    /var/lib
                            220M    /var/cache
                            206M    /var/cache/apt
                            144M    /var/lib/apt/lists
                            Archived and active journals take up 87.9M in the file system.
                            82M     /opt/iobroker/backups/
                            991M    /opt/iobroker/iobroker-data/
                            809M    /opt/iobroker/iobroker-data/files
                            68M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            ioBraspi            ioBraspi (version: 7.0.6, hostname: ioBraspi      , alive, uptime: 42280)
                            admin:          7.1.5
                            javascript:     8.8.3
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ioBraspi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : ioBraspi                                 -  enabled
                              system.adapter.controme.0               : controme              : ioBraspi                                 - disabled
                            + system.adapter.discovery.0              : discovery             : ioBraspi                                 -  enabled
                            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBraspi                                 -  enabled
                            + system.adapter.fhem.0                   : fhem                  : ioBraspi                                 -  enabled, port: 7072
                            + system.adapter.fritzdect.0              : fritzdect             : ioBraspi                                 -  enabled
                            + system.adapter.growatt.0                : growatt               : ioBraspi                                 -  enabled
                            + system.adapter.history.0                : history               : ioBraspi                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                            + system.adapter.influxdb.1               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                            + system.adapter.influxdb.2               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                            + system.adapter.javascript.0             : javascript            : ioBraspi                                 -  enabled
                              system.adapter.maxcul.0                 : maxcul                : ioBraspi                                 - disabled
                            + system.adapter.modbus.0                 : modbus                : ioBraspi                                 -  enabled
                            + system.adapter.mqtt-client.0            : mqtt-client           : ioBraspi                                 -  enabled, port: 1883
                              system.adapter.mqtt.0                   : mqtt                  : ioBraspi                                 - disabled, port: 1883, bind: 0.0.0.0
                              system.adapter.powerfox2.0              : powerfox2             : ioBraspi                                 -  enabled
                              system.adapter.powerfox2.1              : powerfox2             : ioBraspi                                 -  enabled
                            + system.adapter.pvforecast.0             : pvforecast            : ioBraspi                                 -  enabled
                            + system.adapter.pvforecast.1             : pvforecast            : ioBraspi                                 -  enabled
                            + system.adapter.rpi2.0                   : rpi2                  : ioBraspi                                 -  enabled
                            + system.adapter.shelly.0                 : shelly                : ioBraspi                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.viessmannapi.0           : viessmannapi          : ioBraspi                                 -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBraspi                                 -  enabled
                              system.adapter.vis.0                    : vis                   : ioBraspi                                 -  enabled
                            + system.adapter.web.0                    : web                   : ioBraspi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                            Objects and States
                            Objects:        23091
                            States:         20132
                            Hit:4 https://apt.grafana.com stable InRelease
                            Hit:5 https://repos.influxdata.com/debian stable InRelease
                            Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3651       662/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       350516     52939/io.shelly.0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6476       764/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1970       764/iobroker.js-con
                            tcp6       0      0 :::3000                 :::*                    LISTEN      106        5972       763/grafana
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          3653       662/sshd: /usr/sbin
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9617       1263/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6530       798/io.admin.0
                            tcp6       0      0 :::8086                 :::*                    LISTEN      999        5939       712/influxd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5758       540/avahi-daemon: r
                            udp        0      0 0.0.0.0:34404           0.0.0.0:*                           1001       240749     917/io.backitup.0
                            udp        0      0 0.0.0.0:41481           0.0.0.0:*                           104        5760       540/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                104        5759       540/avahi-daemon: r
                            udp6       0      0 :::49431                :::*                                104        5761       540/avahi-daemon: r
                            udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          3692       622/NetworkManager
                            2025-01-07 10:06:23.224  - info: fhem.0 (54119) event FHEM: powerfoxZ2NEUSTART | at powerfoxZ2NEUSTART Next: 10:11:23 | state > fhem.0.powerfoxZ2NEUSTART.state Next: 10:11:23
                            2025-01-07 10:06:27.260  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                            2025-01-07 10:06:27.285  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                            2025-01-07 10:06:27.301  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                            2025-01-07 10:06:27.318  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                            2025-01-07 10:06:27.341  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                            2025-01-07 10:06:27.354  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                            2025-01-07 10:06:34.008  - info: host.ioBraspi instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 55193
                            2025-01-07 10:06:34.888  - info: powerfox2.1 (55193) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                            2025-01-07 10:06:35.102  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11495.02 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11495.02
                            2025-01-07 10:06:35.120  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.922 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.922
                            2025-01-07 10:06:35.206  - info: powerfox2.1 (55193) Terminated (NO_ERROR): Without reason
                            2025-01-07 10:06:35.209  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3811.156 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3811.156
                            2025-01-07 10:06:35.223  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11955.872 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11955.872
                            2025-01-07 10:06:35.716  - info: host.ioBraspi instance system.adapter.powerfox2.1 having pid 55193 terminated with code 0 (NO_ERROR)
                            2025-01-07 10:06:57.219  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                            2025-01-07 10:06:57.280  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                            2025-01-07 10:06:57.298  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                            2025-01-07 10:06:57.316  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                            2025-01-07 10:06:57.388  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                            2025-01-07 10:06:57.405  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                            2025-01-07 10:07:19.009  - info: host.ioBraspi instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 56169
                            2025-01-07 10:07:19.927  - info: powerfox2.0 (56169) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                            2025-01-07 10:07:22.247  - info: powerfox2.0 (56169) Terminated (NO_ERROR): Without reason
                            2025-01-07 10:07:22.771  - info: host.ioBraspi instance system.adapter.powerfox2.0 having pid 56169 terminated with code 0 (NO_ERROR)
                            Jetzt sehe ich gerade, auf meinem Alt- und Neu-ioBroker sind gar keine Objekte mehr angelegt!??
                            • N nobbiman
                              controme.0
                              controme.0
                              controme.0
                              ```bash
                              Script v.2024-10-19
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           536M          0B        536M
                                       4045 M total memory
                                       2110 M used memory
                                       1223 M free memory
                                        123 M buffer memory
                                        657 M swap cache
                                        511 M total swap
                                          0 M used swap
                                        511 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.1G    /var/
                              237M    /var/lib
                              220M    /var/cache
                              206M    /var/cache/apt
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        23091
                              States:         20132
                              Pending Updates: 0
                              Versionsnummern von GitHub-Installationen sind irrelevant. Hier gilt nur der CommitHash.
                              Deswegen wird auch immer davon abgeraten direkt aus dem GitHub zu installieren. Da kann einfach 'irgendwas in irgendeinem Zustand' angespült werden.
                              • N nobbiman
                                controme.0
                                controme.0
                                controme.0
                                ```bash
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           536M          0B        536M
                                         4045 M total memory
                                         2110 M used memory
                                         1223 M free memory
                                          123 M buffer memory
                                          657 M swap cache
                                          511 M total swap
                                            0 M used swap
                                          511 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.1G    /var/
                                237M    /var/lib
                                220M    /var/cache
                                206M    /var/cache/apt
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        23091
                                States:         20132
                                Pending Updates: 0
                                @nobbiman
                                Bei GitHub-Installationen muss auch manuell eine Instanz angelegt werden, das passiert nicht automatisch wie bei einer ordentlichen Installation.
                                  @nobbiman
                                  N Offline
                                  N Offline
                                  nobbiman
                                  @thomas-braun Noch habe den Adapter ja auch nur aus dem Beta-Repos installiert!
                                  Bleibt die Frage, warum keine Controme-Objekte mehr angezeigt werden?
                                  Gateway-MAC-Adresse ist korrekt eingestellt
                                  Entwarnung: Hatte das erneute Einlesen der Räume nach einem Adapterneustart nicht mehr angehakt.
                                  Nun sind die Objekt im Alt- und Neu-System da, um einzelne Fehlermeldungen wie
                                  2025-01-07 10:59:24.620	warn	Room 12: Temperature value for sensor 05:17:53:3d is invalid or null
                                  controme.0
                                  	2025-01-07 10:59:24.619	warn	Room 10: Temperature value for sensor 05:81:ff:c6 is invalid or null
                                  controme.0
                                  	2025-01-07 10:59:24.618	warn	Room 10: Temperature value for sensor 05:82:05:6a is invalid or null
                                  controme.0
                                  	2025-01-07 10:59:24.615	warn	Room 9: Temperature value for sensor 05:82:00:49 is invalid or null
                                  controme.0
                                  	2025-01-07 10:58:25.234	warn	State "controme.0.2.sensors.VSensor*1.actualTemperature" has no existing object, this might lead to an error in future versions
                                  .. kümmere ich mich später
                                  Nachtrag:
                                  Nun habe ich festgestellt, dass es sich bei allen 4 Sensoren um Fensterkontakte handelt, die natürlich keine Temperatur zurückmelden können.
                                  Kann ich einfach den Datenpunkt der jeweiligen Temperatur in den Objekten löschen?
                                  • N nobbiman
                                    controme.0
                                    controme.0
                                    controme.0
                                    controme.0
                                    Nachtrag:
                                    @nobbiman
                                    Zu dem Adapter kann ich nix konkretes sagen, hab ich nicht im Einsatz.
                                      @nobbiman
                                      N Offline
                                      N Offline
                                      nobbiman
                                      @thomas-braun Trotzdem vielen Dank für die unermüdliche Unterstützung!
                                      • N Offline
                                        N Offline
                                        nobbiman
                                        @erstam
                                        controme.0
                                        controme.0
                                        controme.0
                                        controme.0
                                        Nun habe ich festgestellt, dass es sich bei allen 4 oberen Sensoren der Meldungen um Fensterkontakte handelt, die natürlich keine Temperatur zurückmelden können.
                                        Kannst du etwas dazu sagen und warum kommen diese Meldungen nicht auf meinem Alt-System?
                                        E 1 Antwort Letzte Antwort
                                        • N nobbiman
                                          @erstam
                                          controme.0
                                          controme.0
                                          controme.0
                                          controme.0
                                          Erstam
                                          @nobbiman : Hi nobbiman!
                                          Danke, dass du den Adapter testest, so viele scheinen hier Controm nicht im Einsatz zu haben. Bei den obigen handelt es sich um Warnungen, nicht um Fehlermeldungen. Die werden vom Adapter generiert, um dich darauf hinzuweisen, dass die Sensoren keine Temperaturwerte zurückliefern. Da ich selbst keine Fenstersensoren im Einsatz habe, habe ich diese Warnungen nicht. Es sollte aber in der Adapter-Konfiguration eine Checkbox geben "Log-Warnungen für Null-Werte anzeigen". Wenn du das anhakst, sind die Warnungen weg. Möglicherweise hast du auf deinem Altsystem genau diesen Haken gesetzt?
                                          Die letzte Warnung deutet darauf hin, dass ein Sensor nicht angelegt wurde, der Adapter aber versucht, Werte dafür zu schreiben. Kannst du bitte den Objektbaum neu aufbauen lassen, indem du in der Adapterkonfiguration die Checkbox "Räume beim nächsten Start neu einlesen" anhakst. Ggf. macht der Stern im Adapternamen ein Problem, das müsste ich prüfen.
