  4. Test Adapter Controme v0.5.x
56 Beiträge 5 Kommentatoren 9.2k Aufrufe 4 Beobachtet
  • N nobbiman
    @thomas-braun reicht das summary?
    ```bash
                            v.2024-10-19
       Static hostname: RasPi-ioBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.6.67-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            3.8G        2.0G        488M        0.0K        1.3G        1.7G
    Swap:           2.1G        246M        1.9G
    Total:          5.9G        2.3G        2.4G
    Active iob-Instances:   20
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.6
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : RasPi-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : RasPi-ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                23107
    States:                 19835
    Size of iob-Database:
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/states.jsonl
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    @nobbiman
    Nein, die Langfassung. Du hastt da auch noch einen ganzen Zoo an Paketquellen drin, die nicht zum bullseye passen.
    N 1 Antwort Letzte Antwort
    • N nobbiman
      ```bash
                              v.2024-10-19
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                23107
      States:                 19835
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @nobbiman
      Siehe:
      https://forum.iobroker.net/topic/78355/test-adapter-controme-v0-5-x/13
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
        @nobbiman
        N Offline
        N Offline
        nobbiman
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2024-12-30 11:34:38 CET
                   Universal time: Mon 2024-12-30 10:34:38 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        JAVA_HOME=/usr/lib/jvm/java-17-openjdk-arm64
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        2.1G        437M        0.0K        1.3G        1.6G
        Swap:           2.1G        245M        1.9G
        Total:          5.9G        2.3G        2.3G
                 3790 M total memory
                 2085 M used memory
                 1823 M active memory
                 1289 M inactive memory
                  437 M free memory
                  145 M buffer memory
                 1121 M swap cache
                 2147 M total swap
                  245 M used swap
                 1902 M free swap
        top - 11:34:38 up  1:56,  2 users,  load average: 0.86, 1.06, 1.25
        Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 15.2 us,  4.5 sy,  0.0 ni, 78.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
        MiB Mem :   3791.0 total,    436.7 free,   2086.9 used,   1267.3 buff/cache
        MiB Swap:   2148.0 total,   1902.0 free,    246.0 used.   1620.3 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4      459G   16G  425G   4% /
        devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/sda1      vfat      255M   33M  223M  13% /boot
        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
        [Mon Dec 30 09:38:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=94303a9e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): write access will be enabled during recovery
        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): recovery complete
        [Mon Dec 30 09:38:33 2024] EXT4-fs (sda2): mounted filesystem d98b1a68-4ff7-4331-86d3-77c5d911b429 ro with ordered data mode. Quota mode: none.
        [Mon Dec 30 09:38:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Dec 30 09:38:35 2024] EXT4-fs (sda2): re-mounted d98b1a68-4ff7-4331-86d3-77c5d911b429 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.0G    /var/
        1.6G    /var/log
        1.3G    /var/log/journal/2d06defc2eb445c9afef1cfd904ac913
        1.2G    /var/lib
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        940M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        961M    /opt/iobroker/iobroker-data/
        781M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        28M     /opt/iobroker/iobroker-data/states.jsonl
        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.18.0-1nodesource1 600
             20.17.0-1nodesource1 600
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        RasPi-ioBroker      RasPi-ioBroker (version: 7.0.6, hostname: RasPi-ioBroker, alive, uptime: 830)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     1
        +-- iobroker.controme@0.5.3 (git+ssh://git@github.com/MadErstam/ioBroker.controme.git#a40bf461eadee0352492c1bf151fcb288f890fe2)
        Adapter State
        + system.adapter.backitup.0               : backitup              : RasPi-ioBroker                           -  enabled
          system.adapter.controme.0               : controme              : RasPi-ioBroker                           -  enabled
        + system.adapter.discovery.0              : discovery             : RasPi-ioBroker                           -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPi-ioBroker                           -  enabled
        + system.adapter.fhem.0                   : fhem                  : RasPi-ioBroker                           -  enabled, port: 7072
        + system.adapter.fritzdect.0              : fritzdect             : RasPi-ioBroker                           -  enabled
        + system.adapter.growatt.0                : growatt               : RasPi-ioBroker                           -  enabled
        + system.adapter.history.0                : history               : RasPi-ioBroker                           -  enabled
        + system.adapter.influxdb.0               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : RasPi-ioBroker                           -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : RasPi-ioBroker                           -  enabled
          system.adapter.maxcul.0                 : maxcul                : RasPi-ioBroker                           - disabled
        + system.adapter.modbus.0                 : modbus                : RasPi-ioBroker                           -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : RasPi-ioBroker                           - disabled, port: 1883
        + system.adapter.mqtt.0                   : mqtt                  : RasPi-ioBroker                           -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.powerfox2.0              : powerfox2             : RasPi-ioBroker                           -  enabled
          system.adapter.powerfox2.1              : powerfox2             : RasPi-ioBroker                           -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : RasPi-ioBroker                           -  enabled
        + system.adapter.pvforecast.1             : pvforecast            : RasPi-ioBroker                           -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : RasPi-ioBroker                           -  enabled
        + system.adapter.shelly.0                 : shelly                : RasPi-ioBroker                           -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.viessmannapi.0           : viessmannapi          : RasPi-ioBroker                           -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPi-ioBroker                           -  enabled
          system.adapter.vis.0                    : vis                   : RasPi-ioBroker                           -  enabled
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
        Adapter    "fhem"         : 3.0.0    , installed 3.0.0
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "growatt"      : 3.3.1    , installed 3.3.1
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
        Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
        Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
        Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
        Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
        Adapter    "web"          : 6.2.5    , installed 6.3.0
        Objects and States
        Objects:        23107
        States:         19835
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://repos.influxdata.com/debian stable InRelease
        Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:9 https://apt.glennr.nl/repo bullseye InRelease
        Hit:10 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/7.0 InRelease
        Get:11 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7517 B]
        Fetched 7517 B in 2s (3034 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96463      20066/io.mqtt.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       94929      20027/io.shelly.0
        tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      117        6468       1169/bin/mongod
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5527       534/cupsd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2496       603/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95636      19881/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95631      19881/iobroker.js-c
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        7445       541/influxd
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       95058      20216/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96285      19901/io.admin.0
        tcp6       0      0 :::8080                 :::*                    LISTEN      117        6029       599/java
        tcp6       0      0 :::3000                 :::*                    LISTEN      116        7528       1063/grafana
        tcp6       0      0 :::6789                 :::*                    LISTEN      117        7630       599/java
        tcp6       0      0 :::8843                 :::*                    LISTEN      117        6032       599/java
        tcp6       0      0 :::8880                 :::*                    LISTEN      117        6030       599/java
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5526       534/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          2498       603/sshd: /usr/sbin
        tcp6       0      0 :::8443                 :::*                    LISTEN      117        6031       599/java
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2427       384/avahi-daemon: r
        udp        0      0 0.0.0.0:40839           0.0.0.0:*                           108        2429       384/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2530       483/dhcpcd: [master
        udp6       0      0 :::5353                 :::*                                108        2428       384/avahi-daemon: r
        udp6       0      0 :::5514                 :::*                                117        7635       599/java
        udp6       0      0 :::3478                 :::*                                117        7626       599/java
        udp6       0      0 :::44558                :::*                                108        2430       384/avahi-daemon: r
        udp6       0      0 192.168.2.40:42712      :::*                                117        7638       599/java
        udp6       0      0 :::10001                :::*                                117        7639       599/java
        udp6       0      0 :::546                  :::*                                0          2546       483/dhcpcd: [master
        2024-12-30 11:34:28.120  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 23451 terminated with code 0 (NO_ERROR)
        2024-12-30 11:34:50.031  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 23772
        2024-12-30 11:34:52.700  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
        2024-12-30 11:34:52.717  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
        2024-12-30 11:34:52.762  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
        2024-12-30 11:34:52.791  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
        2024-12-30 11:34:52.815  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
        2024-12-30 11:34:52.828  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
        2024-12-30 11:34:53.400  - info: powerfox2.1 (23772) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
        2024-12-30 11:34:53.891  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11206.707 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11206.707
        2024-12-30 11:34:53.916  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.684 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.684
        2024-12-30 11:34:54.074  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3725.902 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3725.902
        2024-12-30 11:34:54.103  - info: fhem.0 (20016) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11943.326 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11943.326
        2024-12-30 11:34:54.115  - info: powerfox2.1 (23772) Terminated (NO_ERROR): Without reason
        2024-12-30 11:34:54.647  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.1 having pid 23772 terminated with code 0 (NO_ERROR)
        2024-12-30 11:35:22.631  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkuladung | 11 > set alias.0.PVAnlage.Akkuladung 11
        2024-12-30 11:35:22.656  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 234.5 > set alias.0.PVAnlage.ModulleistungGarage 234.5
        2024-12-30 11:35:22.694  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
        2024-12-30 11:35:22.810  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 7 > set alias.0.PVAnlage.Akkutemperatur 7
        2024-12-30 11:35:22.822  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
        2024-12-30 11:35:22.835  - info: fhem.0 (20016) stateChange (out): alias.0.PVAnlage.BatterieLaden | 194 > set alias.0.PVAnlage.BatterieLaden 194
        2024-12-30 11:35:24.034  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 25097
        2024-12-30 11:35:26.970  - info: powerfox2.0 (25097) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
        2024-12-30 11:35:28.040  - info: powerfox2.0 (25097) Terminated (NO_ERROR): Without reason
        2024-12-30 11:35:28.584  - info: host.RasPi-ioBroker instance system.adapter.powerfox2.0 having pid 25097 terminated with code 0 (NO_ERROR)
        • mcm1957M mcm1957
          @nobbiman
          Siehe:
          N Offline
          N Offline
          nobbiman
          @mcm1957 Ja, ich werde ein Issue aufmachen, warte im Moment noch ab, was sich noch bei @Thomas-Braun ergibt
            @nobbiman sagte in Test Adapter Controme v0.5.x:
            wie ich meine Daten der Programme sichern muss;
            Per Backitup-Adapter.
            N Offline
            N Offline
            nobbiman
            schrieb am zuletzt editiert von nobbiman
            @thomas-braun Backitup sichert auch Influxx-DB und Grafana-Einstellungen und Grafiken?
            • N nobbiman
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
                       3790 M total memory
                       2085 M used memory
                        437 M free memory
                        145 M buffer memory
                       1121 M swap cache
                       2147 M total swap
                        245 M used swap
                       1902 M free swap
              *** FILESYSTEM ***
              /var:
              3.0G    /var/
              1.6G    /var/log
              1.2G    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.1.5
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        23107
              States:         19835
              Pending Updates: 0
              Da hat es wohl Einschläge im Dateisystem gegeben. Fahr die Kister IMMER ordentlich herunter, bevor du die vom Strom nimmst.
              Zu controme: Installier den NICHT aus dem GitHub sondern aus einem ioBroker-Repo, sofern da vorhanden.
              • system.adapter.influxdb.0 : influxdb : RasPi-ioBroker - enabled, port: 8086
              • system.adapter.influxdb.1 : influxdb : RasPi-ioBroker - enabled, port: 8086
              dürfte so auch falsch sein.
              Die Quellen würde ich mir anschauen, warum die überhaupt angelegt wurden und ob es da nicht besser passende für dein Release gibt:
              Wenn du es einstellst, ja.
                N Offline
                N Offline
                nobbiman
                @thomas-braun sagte in Test Adapter Controme v0.5.x:
                .. und genau da liegt mein Problem, wenn ich als Laie mit einem Profi chatte, ich verstehe nur Bahnhof und bin z.B. nicht in der Lage zu checken, ob die genannten "Hits" 4,9,10,11 dort hin gehören oder nicht.
                Meine einzige Möglichkeit ist die einer kompletten und sauberen Neuinstalltion unter Bookworm.
                Ich habe mich mal mit dem Backitup befasst und ein Backup durchgeführt. Dort stoße ich auf die Fehlermeldung
                13:30:10.448
                INFO
                gui
                Backup gestartet ...
                13:30:10.516
                DEBUG
                mount
                Wake on LAN wait 180 Seconds for NAS!
                13:30:10.528
                DEBUG
                mount
                Wake on LAN MAC-Address: 00:11:32:37:8C:5C
                13:30:10.531
                DEBUG
                mount
                mount activ... umount is started before mount!!
                13:30:10.578
                DEBUG
                mount
                umount successfully completed
                [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
                13:33:10.487
                DEBUG
                mount
                cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.20/homes/backup/ioBroker/ /opt/iobroker/backups"
                13:33:10.749
                DEBUG
                mount
                13:33:10.752
                DEBUG
                mount
                done
                [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"06:00","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"timestamp":1735561810465,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"nameSuffix":"","slaveSuffix":"","hostType":"Single","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.2.40","port":8086,"dbversion":"2.x","token":"60a9d6d04cd505C","protocol":"https","exe":"","dbType":"remote","influxDBEvents":[],"influxDBMulti":false,"ignoreErrors":false,"deleteDataBase":false},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"PoweroptiPatrickhisory","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.2.20","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00:11:32:37:8C:5C","wolTime":180,"wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/homes/backup/ioBroker/","dirMinimal":"/homes/backup/ioBroker/","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"username","pass":"****","url":"https://<example.com>/remote.php/dav/files/<username>/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"googledriveDeleteAfter":10,"advancedDelete":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.2.40","port":"3000","protocol":"https","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1735561810465}
                13:33:20.052
                DEBUG
                iobroker
                host.RasPi-ioBroker 23099 objects saved
                13:33:21.952
                DEBUG
                iobroker
                host.RasPi-ioBroker 19811 states saved
                host.RasPi-ioBroker Validating backup ...
                13:33:21.961
                DEBUG
                iobroker
                host.RasPi-ioBroker "config.json" is valid
                13:33:21.970
                DEBUG
                iobroker
                host.RasPi-ioBroker "objects.jsonl" exists
                13:33:22.016
                DEBUG
                iobroker
                host.RasPi-ioBroker "states.jsonl" exists
                13:33:23.052
                DEBUG
                iobroker
                host.RasPi-ioBroker JSONL lines are valid
                13:33:23.076
                DEBUG
                iobroker
                host.RasPi-ioBroker The backup is valid!
                13:33:26.634
                DEBUG
                iobroker
                Backup created: /opt/iobroker/backups/iobroker_2024_12_30-13_33_10_backupiobroker.tar.gz
                13:33:26.743
                DEBUG
                iobroker
                This backup can only be restored with js-controller version 7.0 or higher
                13:33:27.670
                DEBUG
                iobroker
                done
                13:33:27.857
                DEBUG
                influxDB
                InfluxDB-Backup started ...
                13:33:27.863
                DEBUG
                influxDB
                Start InfluxDB Backup ...
                13:33:27.864
                DEBUG
                influxDB
                InfluxDB Backup tmp directory created
                13:33:27.871
                DEBUG
                influxDB
                Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                13:33:27.910
                DEBUG
                influxDB
                InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker" successfully deleted
                [DEBUG] [influxDB] -
                13:33:27.933
                ERROR
                influxDB
                Error: Command failed: influx backup --bucket iobroker --host https://192.168.2.40:8086 --skip-verify -t 60a9d6d04cd505C "/opt/iobroker/backups/influxDB_2024_12_30-13_33_27_backupiobroker"
                Error: API compatibility check failed: Get "https://192.168.2.40:8086/health": http: server gave HTTP response to HTTPS client
                13:33:27.938
                DEBUG
                influxDB
                InfluxDB-Backup for is finish
                13:33:27.944
                DEBUG
                influxDB
                done
                13:33:28.663
                ERROR
                historyDB
                BackItUp cannot found source "undefined" for compress!
                Leider kann ich in den Logdaten nicht sehen, ob alle Daten, also auch die von Grafana, gesichert wurden.
                Bevor das nicht klar ist, wede ich keine KOmplettinstallation durchführen.
                • N nobbiman
                  13:30:10.448
                  INFO
                  gui
                  13:30:10.516
                  DEBUG
                  mount
                  13:30:10.528
                  DEBUG
                  mount
                  13:30:10.531
                  DEBUG
                  mount
                  13:30:10.578
                  DEBUG
                  mount
                  13:33:10.487
                  DEBUG
                  mount
                  13:33:10.749
                  DEBUG
                  mount
                  13:33:10.752
                  DEBUG
                  mount
                  done
                  13:33:20.052
                  DEBUG
                  iobroker
                  13:33:21.952
                  DEBUG
                  iobroker
                  13:33:21.961
                  DEBUG
                  iobroker
                  13:33:21.970
                  DEBUG
                  iobroker
                  13:33:22.016
                  DEBUG
                  iobroker
                  13:33:23.052
                  DEBUG
                  iobroker
                  13:33:23.076
                  DEBUG
                  iobroker
                  13:33:26.634
                  DEBUG
                  iobroker
                  13:33:26.743
                  DEBUG
                  iobroker
                  13:33:27.670
                  DEBUG
                  iobroker
                  done
                  13:33:27.857
                  DEBUG
                  influxDB
                  13:33:27.863
                  DEBUG
                  influxDB
                  13:33:27.864
                  DEBUG
                  influxDB
                  13:33:27.871
                  DEBUG
                  influxDB
                  13:33:27.910
                  DEBUG
                  influxDB
                  13:33:27.933
                  ERROR
                  influxDB
                  13:33:27.938
                  DEBUG
                  influxDB
                  13:33:27.944
                  DEBUG
                  influxDB
                  done
                  13:33:28.663
                  ERROR
                  historyDB
                  Du hast sie aber als Admin von dem System angelegt. Dann musst du also auch wissen, warum.
                    N Offline
                    N Offline
                    nobbiman
                    Das mag sein, ändert an meiner Aussage aber nichts, da mir die Installation nicht mehr bewußt ist. Vielleicht gehe ich mit meinem System auch nicht so sorgsam um wie du!
                    • N nobbiman
                      @nobbiman
                      Wenn du nicht weißt, warum die da sind brauchst du sie offenbar ja nicht.
                        @nobbiman
                        N Offline
                        N Offline
                        nobbiman
                        @thomas-braun So wollte ich auch an die Sache gehen, die sich m.E. aber mit einer Neuaufsetzung des Systems ohnehin erledigt hätte, in der Annahme, dass die genannten Bestandteile kein "Beifang" der Standardinstallation und der gelisteten Adapter sind.
                        Kannst du denn etwas zur Backitup-Fehlermeldung beitragen, damit ich die Neuinstallation angehen kann?
                        • N nobbiman
                          13:30:10.448
                          INFO
                          gui
                          13:30:10.516
                          DEBUG
                          mount
                          13:30:10.528
                          DEBUG
                          mount
                          13:30:10.531
                          DEBUG
                          mount
                          13:30:10.578
                          DEBUG
                          mount
                          13:33:10.487
                          DEBUG
                          mount
                          13:33:10.749
                          DEBUG
                          mount
                          13:33:10.752
                          DEBUG
                          mount
                          done
                          13:33:20.052
                          DEBUG
                          iobroker
                          13:33:21.952
                          DEBUG
                          iobroker
                          13:33:21.961
                          DEBUG
                          iobroker
                          13:33:21.970
                          DEBUG
                          iobroker
                          13:33:22.016
                          DEBUG
                          iobroker
                          13:33:23.052
                          DEBUG
                          iobroker
                          13:33:23.076
                          DEBUG
                          iobroker
                          13:33:26.634
                          DEBUG
                          iobroker
                          13:33:26.743
                          DEBUG
                          iobroker
                          13:33:27.670
                          DEBUG
                          iobroker
                          done
                          13:33:27.857
                          DEBUG
                          influxDB
                          13:33:27.863
                          DEBUG
                          influxDB
                          13:33:27.864
                          DEBUG
                          influxDB
                          13:33:27.871
                          DEBUG
                          influxDB
                          13:33:27.910
                          DEBUG
                          influxDB
                          13:33:27.933
                          ERROR
                          influxDB
                          13:33:27.938
                          DEBUG
                          influxDB
                          13:33:27.944
                          DEBUG
                          influxDB
                          done
                          13:33:28.663
                          ERROR
                          historyDB
                          Deutet darauf hin, dass du da mit unterschiedlichen Protokollen hantierst.
                          N 2 Antworten Letzte Antwort
                            N Offline
                            N Offline
                            nobbiman
                            @thomas-braun OK, Danke, dann gehe ich die Neuinstallation im neuen Jahr mal an.
                              Mittlerweile habe ich eine iOB-Neuinstallation gestartet,
                              Dann nhätte ich auch das Betriebssystem auf die aktuelle Version gesetzt..
                              N Offline
                              N Offline
                              nobbiman
                              @thomas-braun Ich weiß nicht, ob ich hier in diesem Thread weitermachen soll oder besser einen neuen aufmache; ich versuche es mal hier:
                              Ich habe mittlerweile mein System komplett neu auf einem RasPi 5 (mit der alten IP-Adresse) mit bookworm aufgesetzt und über backitup die Datensicherung beim ioBroker eingespielt. Mit dabei waren Influxdb und Grafana; letztere sollen über meine abgespeicherten Links unter Windows wieder erreichbar sein.
                              Nach dem Restore wollen aber die 3 Influx-Instanzen nicht mehr starten, im Protokoll finde ich die Hinweise
                              influxdb.0
                              	2025-01-04 17:22:13.573	info	Influx DB Version used: 2.x
                              influxdb.0
                              	2025-01-04 17:22:13.573	info	Connecting http://192.168.2.40:8086/ ...
                              influxdb.0
                              	2025-01-04 17:22:03.573	error	Error: connect ECONNREFUSED 192.168.2.40:8086
                              Möglicherweise muss der Port 8086 freigegeben werden, oder? Auf Grafana kann ich über den Port 3000 auch nicht zugreifen!
                              Kann mir jemand sagen, wie ich weiter vorgehen sollte?
                              iob diag ergibt
                              ```bash
                              Script v.2024-10-19
                              *** BASE SYSTEM ***
                               Static hostname: raspberrypi
                                     Icon name: computer
                                        Kernel: Linux 6.6.51+rpt-rpi-2712
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 5 Model B Rev 1.1
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               17:14:06 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                              CPU threads: 4
                              Operating System is the current Debian stable version codenamed 'bookworm'!
                              Current issues:
                              ~ Under-voltage has occurred
                                             Local time: Sat 2025-01-04 17:14:06 CET
                                         Universal time: Sat 2025-01-04 16:14:06 UTC
                                               RTC time: Sat 2025-01-04 16:14:06
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.2G        1.8G        714M        5.5M        1.8G        2.4G
                              Swap:           536M          0B        536M
                              Total:          4.8G        1.8G        1.3G
                              Active iob-Instances:   22
                                       4045 M total memory
                                       1721 M used memory
                                       1817 M active memory
                                       1210 M inactive memory
                                        681 M free memory
                                        116 M buffer memory
                                       1595 M swap cache
                                        511 M total swap
                                          0 M used swap
                                        511 M free swap
                              top - 17:14:07 up  1:36,  2 users,  load average: 0.18, 0.25, 0.42
                              Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   4045.1 total,    681.2 free,   1721.9 used,   1712.3 buff/cache
                              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2323.2 avail Mem
                              *** FILESYSTEM ***
                              udev           devtmpfs  1.9G     0  1.9G   0% /dev
                              tmpfs          tmpfs     405M  5.2M  400M   2% /run
                              /dev/sda2      ext4      110G  5.5G   99G   6% /
                              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                              /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                              tmpfs          tmpfs     405M     0  405M   0% /run/user/1000
                              [Sat Jan  4 15:37:46 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Sat Jan  4 15:37:49 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                              [Sat Jan  4 15:37:51 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                              `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              930M    /var/
                              206M    /var/cache
                              200M    /var/cache/apt
                              164M    /var/lib
                              135M    /var/lib/apt/lists
                              Archived and active journals take up 47.9M in the file system.
                              9.1M    /opt/iobroker/backups/
                              853M    /opt/iobroker/iobroker-data/
                              808M    /opt/iobroker/iobroker-data/files
                              33M     /opt/iobroker/iobroker-data/objects.jsonl
                              24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                              13M     /opt/iobroker/iobroker-data/states.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                               *** 20.18.1-1nodesource1 1001
                                   20.18.0-1nodesource1 1001
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                   18.19.0+dfsg-6~deb12u1 500
                                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1218)
                              admin:          7.1.5
                              javascript:     8.8.3
                              nodejs modules from github:     0
                              Adapter State
                              + system.adapter.controme.0               : controme              : raspberrypi                              -  enabled
                                system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                              + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
                              + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                              + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                              + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                              + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                              + system.adapter.maxcul.0                 : maxcul                : raspberrypi                              -  enabled
                              + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                              + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
                                system.adapter.powerfox2.1              : powerfox2             : raspberrypi                              -  enabled
                              + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                              + system.adapter.pvforecast.1             : pvforecast            : raspberrypi                              -  enabled
                              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              Objects and States
                              Objects:        22957
                              States:         19667
                              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                              Pending Updates: 12
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7374       660/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41842      11153/iobroker.js-c
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41837      11153/iobroker.js-c
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       45413      11889/io.mqtt.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       44833      12073/io.shelly.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          7376       660/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44054      11183/io.admin.0
                              udp        0      0 0.0.0.0:42016           0.0.0.0:*                           104        7274       534/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7272       534/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                104        7273       534/avahi-daemon: r
                              udp6       0      0 :::49420                :::*                                104        7275       534/avahi-daemon: r
                              udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          4758       620/NetworkManager
                              2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                              2025-01-04 17:14:21.000  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                              2025-01-04 17:14:21.005  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                              2025-01-04 17:14:21.223  - info: powerfox2.0 (14082) Terminated (NO_ERROR): Without reason
                              2025-01-04 17:14:21.815  - warn: powerfox2.0 (14082) get state error: Connection is closed.
                              2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                              2025-01-04 17:14:23.483  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                              2025-01-04 17:14:23.489  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                              2025-01-04 17:14:24.753  - info: host.raspberrypi instance system.adapter.powerfox2.0 having pid 14082 terminated with code 0 (NO_ERROR)
                              2025-01-04 17:14:30.984  - info: influxdb.2 (11731) Connecting http://192.168.2.40:8086/ ...
                              2025-01-04 17:14:30.985  - info: influxdb.2 (11731) Influx DB Version used: 2.x
                              2025-01-04 17:14:30.987  - error: influxdb.2 (11731) Error: connect ECONNREFUSED 192.168.2.40:8086
                              2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Connecting http://192.168.2.40:8086/ ...
                              2025-01-04 17:14:31.006  - info: influxdb.1 (11716) Influx DB Version used: 2.x
                              2025-01-04 17:14:31.008  - error: influxdb.1 (11716) Error: connect ECONNREFUSED 192.168.2.40:8086
                              2025-01-04 17:14:32.383  - info: fhem.0 (12803) event FHEM: myStatDevice | statistics myStatDevice Updated stats for: MiniPV_Messung_Shelly | state > fhem.0.myStatDevice.state Updated stats for: MiniPV_Messung_Shelly
                              2025-01-04 17:14:32.588  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                              2025-01-04 17:14:32.608  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 0.3 > set alias.0.PVAnlage.ModulleistungGarage 0.3
                              2025-01-04 17:14:32.627  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 2.700000047683716 > set alias.0.PVAnlage.PVGarageSystemleistungTag 2.700000047683716
                              2025-01-04 17:14:32.648  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.5 > set alias.0.PVAnlage.Akkutemperatur 9.5
                              2025-01-04 17:14:32.667  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 103 > set alias.0.PVAnlage.BatterieEntladen 103
                              2025-01-04 17:14:32.695  - info: fhem.0 (12803) stateChange (out): alias.0.PVAnlage.BatterieLaden | 0 > set alias.0.PVAnlage.BatterieLaden 0
                              2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Connecting http://192.168.2.40:8086/ ...
                              2025-01-04 17:14:33.490  - info: influxdb.0 (12320) Influx DB Version used: 2.x
                              2025-01-04 17:14:33.492  - error: influxdb.0 (12320) Error: connect ECONNREFUSED 192.168.2.40:8086
                              Nun habe ich einige Hinweise im Backupit-Wiki gefunden, da werde ich erst einmal lesen.
                                N Offline
                                N Offline
                                nobbiman
                                @thomas-braun So, nun bin ich wieder auf Stand und habe die Neuinstallation auf meinem neuen RasPi 5 (fast) laufen. Fast? - ja, nur noch der Controme-Adapter zickt und weist Fehlermeldungen auf, obwohl ich alle Adaptereinstellungen wie auf meinem Alt-RasPi vorgenommen habe.
                                Die Controme-Instanz zeigt eine durchgängigen grünen Status, die auszugsweisen Fehlermeldungen lauten wie folgt:
                                2025-01-07 10:03:01.249	warn	State "controme.0.16.humidity" has no existing object, this might lead to an error in future versions
                                controme.0
                                	2025-01-07 10:03:01.214	warn	State "controme.0.16.temporary_mode_end" has no existing object, this might lead to an error in future versions
                                controme.0
                                	2025-01-07 10:03:01.209	warn	State "controme.0.16.temporary_mode_remaining" has no existing object, this might lead to an error in future versions
                                controme.0
                                	2025-01-07 10:03:01.208	warn	State "controme.0.16.actualTemperature" has no existing object, this might lead to an error in future versions
                                Meine Internetrecherche ergab zu der Fehlermeldung die Notwendigkeit, den Adapter über Github zu installieren, verstehe aber nicht den Sinn, das dort auch nur die Version 0.5.3 zur Verfügung steht.
                                Sollte ihr mich weiterhin unterstützen wollen hier zur Fehleranalyse ioB diag:
                                ```bash
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                 Static hostname: ioBraspi
                                       Icon name: computer
                                          Kernel: Linux 6.6.62+rpt-rpi-2712
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                 10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                CPU threads: 4
                                Current issues:
                                               Local time: Tue 2025-01-07 10:06:52 CET
                                           Universal time: Tue 2025-01-07 09:06:52 UTC
                                                 RTC time: Tue 2025-01-07 09:06:52
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            4.2G        2.2G        1.3G        5.5M        819M        2.0G
                                Swap:           536M          0B        536M
                                Total:          4.8G        2.2G        1.8G
                                Active iob-Instances:   21
                                         4045 M total memory
                                         2110 M used memory
                                         1626 M active memory
                                          922 M inactive memory
                                         1223 M free memory
                                          123 M buffer memory
                                          657 M swap cache
                                          511 M total swap
                                            0 M used swap
                                          511 M free swap
                                top - 10:06:52 up 11:44,  2 users,  load average: 0.45, 0.24, 0.18
                                Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
                                MiB Mem :   4045.0 total,   1223.2 free,   2110.7 used,    781.4 buff/cache
                                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1934.3 avail Mem
                                *** FILESYSTEM ***
                                udev           devtmpfs  2.0G     0  2.0G   0% /dev
                                /dev/sda2      ext4      110G  6.7G   98G   7% /
                                /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
                                [Mon Jan  6 22:21:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:A6:06:DE vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1951decd-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Mon Jan  6 22:21:59 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                [Mon Jan  6 22:22:00 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                /var:
                                1.1G    /var/
                                237M    /var/lib
                                220M    /var/cache
                                206M    /var/cache/apt
                                144M    /var/lib/apt/lists
                                Archived and active journals take up 87.9M in the file system.
                                82M     /opt/iobroker/backups/
                                991M    /opt/iobroker/iobroker-data/
                                809M    /opt/iobroker/iobroker-data/files
                                68M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                ioBraspi            ioBraspi (version: 7.0.6, hostname: ioBraspi      , alive, uptime: 42280)
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : ioBraspi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0               : backitup              : ioBraspi                                 -  enabled
                                  system.adapter.controme.0               : controme              : ioBraspi                                 - disabled
                                + system.adapter.discovery.0              : discovery             : ioBraspi                                 -  enabled
                                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBraspi                                 -  enabled
                                + system.adapter.fhem.0                   : fhem                  : ioBraspi                                 -  enabled, port: 7072
                                + system.adapter.fritzdect.0              : fritzdect             : ioBraspi                                 -  enabled
                                + system.adapter.growatt.0                : growatt               : ioBraspi                                 -  enabled
                                + system.adapter.history.0                : history               : ioBraspi                                 -  enabled
                                + system.adapter.influxdb.0               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                + system.adapter.influxdb.1               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                + system.adapter.influxdb.2               : influxdb              : ioBraspi                                 -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : ioBraspi                                 -  enabled
                                  system.adapter.maxcul.0                 : maxcul                : ioBraspi                                 - disabled
                                + system.adapter.modbus.0                 : modbus                : ioBraspi                                 -  enabled
                                + system.adapter.mqtt-client.0            : mqtt-client           : ioBraspi                                 -  enabled, port: 1883
                                  system.adapter.mqtt.0                   : mqtt                  : ioBraspi                                 - disabled, port: 1883, bind: 0.0.0.0
                                  system.adapter.powerfox2.0              : powerfox2             : ioBraspi                                 -  enabled
                                  system.adapter.powerfox2.1              : powerfox2             : ioBraspi                                 -  enabled
                                + system.adapter.pvforecast.0             : pvforecast            : ioBraspi                                 -  enabled
                                + system.adapter.pvforecast.1             : pvforecast            : ioBraspi                                 -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : ioBraspi                                 -  enabled
                                + system.adapter.shelly.0                 : shelly                : ioBraspi                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.viessmannapi.0           : viessmannapi          : ioBraspi                                 -  enabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBraspi                                 -  enabled
                                  system.adapter.vis.0                    : vis                   : ioBraspi                                 -  enabled
                                + system.adapter.web.0                    : web                   : ioBraspi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                Objects and States
                                Objects:        23091
                                States:         20132
                                Hit:4 https://apt.grafana.com stable InRelease
                                Hit:5 https://repos.influxdata.com/debian stable InRelease
                                Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
                                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3651       662/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       350516     52939/io.shelly.0
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6476       764/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1970       764/iobroker.js-con
                                tcp6       0      0 :::3000                 :::*                    LISTEN      106        5972       763/grafana
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          3653       662/sshd: /usr/sbin
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9617       1263/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6530       798/io.admin.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        5939       712/influxd
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5758       540/avahi-daemon: r
                                udp        0      0 0.0.0.0:34404           0.0.0.0:*                           1001       240749     917/io.backitup.0
                                udp        0      0 0.0.0.0:41481           0.0.0.0:*                           104        5760       540/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                104        5759       540/avahi-daemon: r
                                udp6       0      0 :::49431                :::*                                104        5761       540/avahi-daemon: r
                                udp6       0      0 fe80::114e:93e1:e39:546 :::*                                0          3692       622/NetworkManager
                                2025-01-07 10:06:23.224  - info: fhem.0 (54119) event FHEM: powerfoxZ2NEUSTART | at powerfoxZ2NEUSTART Next: 10:11:23 | state > fhem.0.powerfoxZ2NEUSTART.state Next: 10:11:23
                                2025-01-07 10:06:27.260  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                2025-01-07 10:06:27.285  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                2025-01-07 10:06:27.301  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                2025-01-07 10:06:27.318  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                2025-01-07 10:06:27.341  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                2025-01-07 10:06:27.354  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                2025-01-07 10:06:34.008  - info: host.ioBraspi instance system.adapter.powerfox2.1 in version "0.0.14" started with pid 55193
                                2025-01-07 10:06:34.888  - info: powerfox2.1 (55193) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                2025-01-07 10:06:35.102  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh | 11495.02 > set powerfox2.1.devices.1097bd711c28.consumptionMeterReadingKWh 11495.02
                                2025-01-07 10:06:35.120  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh | 10119.922 > set powerfox2.1.devices.1097bd711c28.feedInMeterReadingKWh 10119.922
                                2025-01-07 10:06:35.206  - info: powerfox2.1 (55193) Terminated (NO_ERROR): Without reason
                                2025-01-07 10:06:35.209  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh | 3811.156 > set powerfox2.1.devices.1097bd728260.consumptionMeterReadingKWh 3811.156
                                2025-01-07 10:06:35.223  - info: fhem.0 (54119) stateChange (out): powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh | 11955.872 > set powerfox2.1.devices.1097bd728260.feedInMeterReadingKWh 11955.872
                                2025-01-07 10:06:35.716  - info: host.ioBraspi instance system.adapter.powerfox2.1 having pid 55193 terminated with code 0 (NO_ERROR)
                                2025-01-07 10:06:57.219  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkuladung | 10 > set alias.0.PVAnlage.Akkuladung 10
                                2025-01-07 10:06:57.280  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.ModulleistungGarage | 167.6 > set alias.0.PVAnlage.ModulleistungGarage 167.6
                                2025-01-07 10:06:57.298  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.PVGarageSystemleistungTag | 0.10000000149011612 > set alias.0.PVAnlage.PVGarageSystemleistungTag 0.10000000149011612
                                2025-01-07 10:06:57.316  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.Akkutemperatur | 9.7 > set alias.0.PVAnlage.Akkutemperatur 9.7
                                2025-01-07 10:06:57.388  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieEntladen | 0 > set alias.0.PVAnlage.BatterieEntladen 0
                                2025-01-07 10:06:57.405  - info: fhem.0 (54119) stateChange (out): alias.0.PVAnlage.BatterieLaden | 122 > set alias.0.PVAnlage.BatterieLaden 122
                                2025-01-07 10:07:19.009  - info: host.ioBraspi instance system.adapter.powerfox2.0 in version "0.0.14" started with pid 56169
                                2025-01-07 10:07:19.927  - info: powerfox2.0 (56169) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v20.18.1, js-controller: 7.0.6
                                2025-01-07 10:07:22.247  - info: powerfox2.0 (56169) Terminated (NO_ERROR): Without reason
                                2025-01-07 10:07:22.771  - info: host.ioBraspi instance system.adapter.powerfox2.0 having pid 56169 terminated with code 0 (NO_ERROR)
                                Jetzt sehe ich gerade, auf meinem Alt- und Neu-ioBroker sind gar keine Objekte mehr angelegt!??
                                • N nobbiman
                                  controme.0
                                  controme.0
                                  controme.0
                                  ```bash
                                  Script v.2024-10-19
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                  Current issues:
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           536M          0B        536M
                                           4045 M total memory
                                           2110 M used memory
                                           1223 M free memory
                                            123 M buffer memory
                                            657 M swap cache
                                            511 M total swap
                                              0 M used swap
                                            511 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.1G    /var/
                                  237M    /var/lib
                                  220M    /var/cache
                                  206M    /var/cache/apt
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        23091
                                  States:         20132
                                  Pending Updates: 0
                                  Versionsnummern von GitHub-Installationen sind irrelevant. Hier gilt nur der CommitHash.
                                  Deswegen wird auch immer davon abgeraten direkt aus dem GitHub zu installieren. Da kann einfach 'irgendwas in irgendeinem Zustand' angespült werden.
                                  • N nobbiman
                                    controme.0
                                    controme.0
                                    controme.0
                                    ```bash
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    HOME=/home/pi
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           536M          0B        536M
                                             4045 M total memory
                                             2110 M used memory
                                             1223 M free memory
                                              123 M buffer memory
                                              657 M swap cache
                                              511 M total swap
                                                0 M used swap
                                              511 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.1G    /var/
                                    237M    /var/lib
                                    220M    /var/cache
                                    206M    /var/cache/apt
                                    USB-Devices by-id:
                                    /usr/bin/nodejs         v20.18.1
                                    /usr/bin/node           v20.18.1
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.29.4
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    Adapter State
                                    + instance is alive
                                    Upgrade policy: none
                                    Objects and States
                                    Objects:        23091
                                    States:         20132
                                    Pending Updates: 0
                                    @nobbiman
                                    Bei GitHub-Installationen muss auch manuell eine Instanz angelegt werden, das passiert nicht automatisch wie bei einer ordentlichen Installation.
                                      @nobbiman
                                      N Offline
                                      N Offline
                                      nobbiman
                                      @thomas-braun Noch habe den Adapter ja auch nur aus dem Beta-Repos installiert!
                                      Bleibt die Frage, warum keine Controme-Objekte mehr angezeigt werden?
                                      Gateway-MAC-Adresse ist korrekt eingestellt
                                      Entwarnung: Hatte das erneute Einlesen der Räume nach einem Adapterneustart nicht mehr angehakt.
                                      Nun sind die Objekt im Alt- und Neu-System da, um einzelne Fehlermeldungen wie
                                      2025-01-07 10:59:24.620	warn	Room 12: Temperature value for sensor 05:17:53:3d is invalid or null
                                      controme.0
                                      	2025-01-07 10:59:24.619	warn	Room 10: Temperature value for sensor 05:81:ff:c6 is invalid or null
                                      controme.0
                                      	2025-01-07 10:59:24.618	warn	Room 10: Temperature value for sensor 05:82:05:6a is invalid or null
                                      controme.0
                                      	2025-01-07 10:59:24.615	warn	Room 9: Temperature value for sensor 05:82:00:49 is invalid or null
                                      controme.0
                                      	2025-01-07 10:58:25.234	warn	State "controme.0.2.sensors.VSensor*1.actualTemperature" has no existing object, this might lead to an error in future versions
                                      .. kümmere ich mich später
                                      Nachtrag:
                                      Nun habe ich festgestellt, dass es sich bei allen 4 Sensoren um Fensterkontakte handelt, die natürlich keine Temperatur zurückmelden können.
                                      Kann ich einfach den Datenpunkt der jeweiligen Temperatur in den Objekten löschen?
                                      • N nobbiman
                                        controme.0
                                        controme.0
                                        controme.0
                                        controme.0
                                        Nachtrag:
                                        @nobbiman
                                        Zu dem Adapter kann ich nix konkretes sagen, hab ich nicht im Einsatz.
                                        N 1 Antwort Letzte Antwort
                                          @nobbiman
                                          N Offline
                                          N Offline
                                          nobbiman
                                          @thomas-braun Trotzdem vielen Dank für die unermüdliche Unterstützung!
