  4. Backitup - Influxdb2 Fehler bei Sicherung
24 Beiträge 5 Kommentatoren 2.6k Aufrufe 4 Beobachtet
    Snopy_16
    Ich habe Iobroker in Proxmox auf einer VM
    Influxdb2 in einem eigenen Container
    Backitup erzeugt folgenden Meldung
    20:14:03.439INFOguiBackup gestartet ...
    20:14:03.488DEBUGmountmount activ... umount is started before mount!!
    20:14:03.644DEBUGmountumount successfully completed
    20:14:13.470DEBUGmountnfs-mount command: "sudo mount 192.168.178.10:/Sicherung/iobroker /opt/iobroker/backups"
    20:14:13.545DEBUGmountmount successfully completed
    20:14:13.589DEBUGmountdone
    20:14:14.575DEBUGiobrokerhost.iobroker 196 states saved
    20:14:14.594DEBUGiobrokerhost.iobroker 330 objects saved
    20:14:14.846DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz
    This backup can only be restored with js-controller version up from 4.1
    20:14:15.853DEBUGiobrokerdone
    20:14:16.010DEBUGinfluxDBInfluxDB-Backup started ...
    20:14:16.019DEBUGinfluxDBStart InfluxDB Backup ...
    20:14:16.070DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker" successfully deleted
    20:14:16.148DEBUGinfluxDBdone
    20:14:16.772DEBUGhistoryDBcompress from historyDB started ...
    20:14:16.778DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz
    20:14:16.817DEBUGhistoryDBdone
    20:14:17.679DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    20:14:17.741DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    20:14:17.785DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    20:14:17.791DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz
    20:14:17.800DEBUGjavascriptsdone
    20:14:19.449DEBUGonedriveOnedrive: Copy iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz...
    20:14:21.417DEBUGonedrive77% uploaded from iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz
    20:14:22.270DEBUGonedrive100% uploaded from iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz
    20:14:22.284DEBUGonedriveOnedrive: Copy historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz...
    20:14:23.765DEBUGonedrive100% uploaded from historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz
    20:14:23.778DEBUGonedrivehistoryDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz with Id: F9759285BF3AC29!s13ced90a49024e8ca407102f2e0a1f60 saved on Onedrive
    20:14:23.789DEBUGonedriveOnedrive: Copy javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz...
    20:14:25.082DEBUGonedrive100% uploaded from javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz
    20:14:25.126DEBUGonedrivejavascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz with Id: F9759285BF3AC29!s5504a43ce19d44d98a12133ecb3aa421 saved on Onedrive
    20:14:25.138DEBUGonedrivedone
    20:14:25.269DEBUGcifsused copy path: /Sicherung/iobroker
    20:14:25.289DEBUGcifsdone
    20:14:25.689DEBUGgoogledriveGoogle Drive: Copy iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz...
    20:14:28.201ERRORgoogledriveGoogle Drive: File "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker.tar.gz" not found
    20:14:28.311DEBUGgoogledriveGoogle Drive: Copy historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz...
    20:14:30.444DEBUGgoogledriveGoogle Drive: Copy javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz...
    20:14:32.595DEBUGgoogledrivedone
    20:14:32.800ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
    20:14:32.808DEBUGcleandone
    20:14:32.899DEBUGhistoryHTMLnew history html values created
    20:14:32.986DEBUGhistoryHTMLdone
    20:14:33.141DEBUGhistoryJSONnew history json values created
    20:14:33.188DEBUGhistoryJSONdone
    20:14:33.297DEBUGumountmount active, umount is started ...
    20:14:38.373DEBUGumountumount successfully completed
    20:14:38.418DEBUGumountdone
    20:14:38.678DEBUGemaildone
    20:14:40.735DEBUGnotificationAdmin notification will be sent
    20:14:40.778DEBUGnotificationdone
    20:14:40.886INFOguiDas Backup wurde erfolgreich erstellt!
    Probleme bei influx eigentlich nicht ersichtbar
    im iobroker log dann dies
    backitup.0
    2024-11-22 20:14:31.666	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0
    2024-11-22 20:14:27.079	error	[iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker.tar.gz" not found
    backitup.0
    2024-11-22 20:14:21.154	error	[iobroker/onedrive] Onedrive: File "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker.tar.gz" not found
    backitup.0
    2024-11-22 20:14:14.935	error	[iobroker] Error: Command failed: influx backup --bucket iobroker -t 5GtVXZUdOX6jOnzTpVNscZ6zjRHLUTBxhGqVAhUMxqKdhhU0uAPZL68Z_bynD53ntnns9cBDHEzXb4Un4QqGFQ== "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker"/bin/sh: 1: influx: not found
    backitup.0
    2024-11-22 20:14:14.935	error	[iobroker/influxDB] /bin/sh: 1: influx: not found
    backitup.0
    2024-11-22 20:14:14.935	error	[iobroker/influxDB] Error: Command failed: influx backup --bucket iobroker -t 5GtVXZUdOX6jOnzTpVNscZ6zjRHLUTBxhGqVAhUMxqKdhhU0uAPZL68Z_bynD53ntnns9cBDHEzXb4Un4QqGFQ== "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker"
    admin.0
    2024-11-22 20:13:45.845	info	==> Connected system.user.admin from ::ffff:192.168.178.93
    Mache ich ein Restore einer noch vom Raspberry erzeugten Sicherung kommt das.
    20:23:11.904INFOguistarting Restore...
    20:23:12.093DEBUGinfluxDBinfluxdb.0 is stopped
    20:23:33.690ERRORinfluxDB/bin/sh: 1: influx: not found
    20:23:33.832DEBUGinfluxDBinfluxdb.0 started
    Ich checks einfach nicht
    Liegt es vielleicht daran dass die Influxdb nicht im selben system wie der iobroker liegt?
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    Thomas BraunT crunchipC 3 Antworten Letzte Antwort
    • S Snopy_16
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      admin.0
      @snopy_16 sagte in Backitup - Influxdb2 Fehler bei Sicherung:
      Richtig, der influxdb-client muss auch lokal installiert werden.
        Snopy_16
        oje, wie geht den das?
        Können sie mir bitte behilflich sein?
        • S Snopy_16
          @snopy_16
          Das hängt davon ab, welche Version von influxdb installiert ist.
          Es könnte z.B.
          sudo apt influxdb-client
          sein
            @snopy_16
            Es könnte z.B.
            sein
            Snopy_16
            schrieb am zuletzt editiert von Snopy_16
            @Thomas-Braun
            Werds versuchen
            • S Snopy_16
              @Thomas-Braun
              Werds versuchen
              @snopy_16
              Dann dürfte es
              sudo apt update
              sudo apt install influxdb2-cli
              sein.
              I 1 Antwort Letzte Antwort
              • S Snopy_16
                backitup.0
                backitup.0
                backitup.0
                backitup.0
                backitup.0
                backitup.0
                admin.0
                crunchipC Abwesend
                crunchipC Abwesend
                hatte ich dir im anderen Thread geschrieben, Beschreibung von backitup, siehe https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch
                S 2 Antworten Letzte Antwort
                  Snopy_16
                  @crunchip @Thomas-Braun
                  Ich weiss, dass ich mit meinen Fragen oft nerve.
                  Aber für mich ist das noch alles ein bißchen komplex.🙄
                  Aber mit jedem Schritt lerne ich dazu und verstehe alles ein bisschen besser.
                  Drum danke Euch, die mich unterstützen.👍 😊 👏
                  (Will gar nicht mehr zu meinen Anfängen zurückdenken - stand da wie der Ochs vorm Tor)😠 😧
                    Snopy_16
                    @crunchip
                    Also, irgendwas mache ich komplett falsch.
                    Beim Restore der influxdb werden keine Datenpunkte zurückgeschrieben.
                    Restore Fehlermeldung.
                    15:00:34.581INFOguistarting Restore...
                    15:00:34.721DEBUGinfluxDBCreated tmp directory
                    15:00:34.736DEBUGinfluxDBStart influxDB Restore ...
                    15:00:57.433ERRORinfluxDBError: API compatibility check failed: Get "http://localhost:8086/health": dial tcp [::1]:8086: connect: connection refused
                    15:00:57.450DEBUGinfluxDBTry deleting the InfluxDB tmp directory
                    15:00:57.557DEBUGinfluxDBinfluxDB Restore completed successfully
                    im log
                    backitup.0
                    2024-11-23 15:00:56.770	error	[influxDB] Error: API compatibility check failed: Get "http://localhost:8086/health": dial tcp [::1]:8086: connect: connection refused
                    backitup.0
                    2024-11-23 15:00:13.312	error	Error: ENOENT: no such file or directory, lstat '/opt/iobroker/backups/influxDB_2024_11_23-14_35_27_backupiobroker.tar.gz'
                    backitup.0
                    2024-11-23 15:00:09.710	error	umount: /opt/iobroker/backups: not mounted.
                    backitup.0
                    2024-11-23 14:59:02.506	error	umount: /opt/iobroker/backups: not mounted.
                    Adapter influxdb vor restore habe ich gestoppt. Alte Influx-Datenbank vor der Wiederherstellung automatisch löschen habe ich auch probiert.
                    Bucket wird angelegt, Measurements werden angelegt. Nur die Historiedaten fehlen.
                    • S Snopy_16
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      admin.0
                      crunchipC Abwesend
                      crunchipC Abwesend
                      Wenn die InfluxDB von einem entfernten Server gesichert werden soll, müssen in der influxdb.conf auf dem entfernten Server die Remote-Rechte für den RPC-Dienst angepasst werden.
                      bind-address = "<InfluxDB-IP>:8088"
                      oder
                      bind-address = "0.0.0.0:8088"
                      Nach dem Änderungen in der Konfiguration muss der InfluxDB-Dienst neugestartet werden.
                      Weitere Informationen zur Datensicherung der InfluxDB sind hier zu finden.
                        oder
                        Snopy_16
                        @crunchip
                        hab ich aber nur bei influxdb 1 gelesen, ich hab influxdb 2
                        Habs aber jetzt hinbekommen.
                        Dafür die nächste Hürde: grafana in einem anderen Container als influx installiert.
                        Beim restore kommt dann das
                        18:10:02.838INFOguistarting Restore...
                        18:10:02.862DEBUGgrafanaStart Grafana Restore ...
                        18:10:02.918DEBUGgrafanafilename for restore: /opt/iobroker/backups/grafana_2024_11_23-14_38_55_backupiobroker.tar.gz
                        18:10:02.924DEBUGgrafanaGrafana tmp directory created: /opt/iobroker/backups/grafana_tmp
                        18:10:02.936DEBUGgrafanastart decompress
                        18:10:03.970DEBUGgrafanaGrafana request started
                        18:10:03.990DEBUGgrafanaGrafana is available ... Status: 200
                        18:10:04.001DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
                        18:10:04.017DEBUGgrafanacannot restore datasource "InfluxDB": "Invalid username or password"
                        18:10:04.024DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/fronius.json
                        18:10:04.067DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/haustechnik.json
                        18:10:04.072DEBUGgrafanacannot restore dashboard "haustechnik": {"message":"Unauthorized","traceID":""}
                        18:10:04.075DEBUGgrafanacannot restore dashboard "fronius": {"message":"Unauthorized","traceID":""}
                        18:10:04.110DEBUGgrafanaGrafana request ended
                        18:10:04.122DEBUGgrafanaTry deleting the Grafana tmp directory
                        18:10:04.126DEBUGgrafanaGrafana tmp directory was successfully deleted
                        18:10:06.076DEBUGgrafanaGrafana Restore completed successfully
                        grafana datenquelle zeigt beim Test
                        es wird nichts restored
                        • crunchipC Abwesend
                          crunchipC Abwesend
                          @snopy_16 hast du deinen token erstellt?
                            Snopy_16
                            @crunchip
                            Danke 👍
                            R 1 Antwort Letzte Antwort
                            • S Snopy_16
                              @crunchip
                              Danke 👍
                              Ralph 0
                              weil ich Antworten auf Fragen, die nie gestellt wurden so liebe ;-):
                              Proxmox hat auch eine super Backup-Funktion. Per Klick oder Zeitplan kannst Du einfach einzelne/alle Container bzw. VMs sichern oder restoren.
                              Was ich besonders nützlich finde, wenn man gerne rumspielt und/oder sich noch nicht so gut auskennt:
                              Neben dem laufendem System aus einem Backup eine Containerkopie restoren, darin die gewünschten Änderungen ausprobieren und wenn's funktioniert diese im Original umsetzen. Hat man den Container "kaputt" gespielt - löschen, neuen restoren und nochmal probieren.
                                @snopy_16
                                Dann dürfte es
                                sudo apt update
                                sein.
                                I Offline
                                I Offline
                                io2345
                                schrieb am zuletzt editiert von io2345
                                @thomas-braun said in Backitup - Influxdb2 Fehler bei Sicherung:
                                @snopy_16
                                Dann dürfte es
                                sudo apt update
                                sein.
                                Da kommt bei mir allerdings:
                                iobrokeradmin@ioBroker8neu:~$ sudo apt install influxdb2-cli
                                Reading package lists... Done
                                Building dependency tree... Done
                                E: Unable to locate package influxdb2-cli
                                Wie hast du das gelöst?
                                Vollständige Beschreibung: Ich habe das fast identisch wie bei dir installiert: Iobroker ist ein LXC-Container auf dem Proxmox, die Influx DB in Version 2.7.5 ein weiterer LXC-Container. Den Iobroker-Container habe ich die letzten Tage erneuert (neuen Container angelegt und dann das Backup eingespielt). Seither kommt der Fehler wie bei dir: "[iobroker/influxDB] /bin/sh: 1: influx: not found" beim Backup.
                                • I io2345
                                  @snopy_16
                                  Dann dürfte es
                                  sudo apt update
                                  sein.
                                  @io2345
                                  Ist das influxdb-Repo angelegt?
                                  sudo apt update
                                  apt policy influxdb2*
                                  sagt?
                                    @io2345
                                    sudo apt update
                                    sagt?
                                    I Offline
                                    I Offline
                                    io2345
                                    Da kommt nichts. "sudo apt update" läuft durch, aber dann
                                    iobrokeradmin@ioBroker8neu:~$ apt policy influxdb2*
                                    N: Unable to locate package influxdb2*
                                    N: Couldn't find any package by glob 'influxdb2*'
                                    Wie bekommt man das Repo angelegt?
                                    • I io2345
                                      @io2345 sagte in Backitup - Influxdb2 Fehler bei Sicherung:
                                      Zeigen!
                                      An der Ausgabe hätte ich schon sehen können was da angelegt ist oder nicht.
                                        Zeigen!
                                        I Offline
                                        I Offline
                                        io2345
                                        Zeigen!
                                        Ah, sorry. Hier isses:
                                        iobrokeradmin@ioBroker8neu:~$ sudo apt update
                                        [sudo] password for iobrokeradmin:
                                        Hit:1 http://security.debian.org bullseye-security InRelease
                                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        All packages are up to date.
                                        • I io2345
                                          Zeigen!
                                          @io2345
                                          sudo rm /etc/apt/sources.list.d/influ*
                                          wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                          echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                          echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                          rm influxdata-archive_compat.key
                                          Danach stehen die Pakete in deinem Pakermanager zur Installation bereit.
