  4. vis-2-widgets-collection
    5.8k
406 Beiträge 41 Kommentatoren 116.7k Aufrufe 46 Beobachtet
  • Merlin123M Merlin123
    @carsten04 ah.. ich erinnere mich... Da war was...
    Geht aber trotzdem nicht.
    Hab bei Hintergrundfarbe
    {ts1:evcc.0.loadpoint.1.status.mode; ts1=="pv" ? #00ff00 : #ff0000}
    eingetragen aber der Hintergrund bleibt weiß.....
    Im Editor sieht das so aus:
    Das Widget:
        "tpl": "tplStateCollectionWidget",
        "data": {
          "bindings": [],
          "iconXOffset": "15px",
          "g_common": true,
          "iconYOffset": "0px",
          "header": "PV Laden",
          "footer": "",
          "basePadding": 1,
          "baseElevation": 4,
          "oid": "evcc.0.loadpoint.1.control.pv",
          "unit": "",
          "g_button": true,
          "values_count": 1,
          "onlyStates": false,
          "onlyDisplay": false,
          "name": "Button PV Laden",
          "comment": null,
          "class": null,
          "filterkey": null,
          "multi-views": null,
          "locked": null,
          "g_fixed": true,
          "oidType": "boolean",
          "write": true,
          "minValue": 0,
          "maxValue": 100,
          "icon": null,
          "value1": true,
          "alias1": "",
          "iconSmall": "data:image/svg+xml;base64,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",
          "noFooter": true,
          "valueSize1": 0,
          "iconSize": 150,
          "g_css_font_text": true,
          "iconColor1": "",
          "iconColor": "",
          "valueSize": 0,
          "backgroundColor": "{ts1:evcc.0.loadpoint.1.status.mode; ts1==\"pv\" ? #00ff00 : #ff0000}",
          "backgroundColor1": "{ts1:evcc.0.loadpoint.1.status.mode; ts1==\"pv\" ? #00ff00 : #ff0000}"
        "style": {
          "bindings": [],
          "left": 986,
          "top": "24px",
          "width": "100px",
          "height": "100px",
          "position": "",
          "color": null,
          "text-align": "center",
          "text-shadow": null,
          "font-family": null,
          "font-style": null,
          "font-variant": null,
          "font-weight": null,
          "font-size": null,
          "line-height": null,
          "letter-spacing": null,
          "word-spacing": null
        "widgetSet": "vis-2-widgets-collection",
        "_id": "i000001"
    carsten04C Online
    carsten04C Online
    carsten04
    schrieb am zuletzt editiert von carsten04
    #121
    @merlin123 Setz die Farben mal in "". Wenn das nicht klappt, schaue ich mir das heute Abend noch einmal am Rechner an.
    Merlin123M 1 Antwort Letzte Antwort
    • carsten04C carsten04
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #122
      @carsten04 Die " waren's :) Danke!
      Beta-Tester
      • M micklafisch
        Wenn ich auch einen Wunsch äußern dürfte für ein Widget:
        Ein Dialog/Popup mit der Breite in Dialogbox in variablen % Werten. Alle bisherigen funktionierenden Popups wie MaterialDesignWidget oder jqui laufen mit Vis-2 nicht mehr oder nicht mehr richtig.
        Das wäre fein wenn es da wieder etwas lauffähiges und zugleich anpassbares gibt um Dialoge zu gestalten.
        carsten04C Online
        carsten04C Online
        carsten04
        #123
        @micklafisch Was soll das Widget denn sonst noch können? Nur View anzeigen und Dialogfenster skalieren?
          M Online
          M Online
          micklafisch
          #124
          @carsten04
          Kennst du zufällig das MDW von Scrounger? Das konnte eigentlich fast alles.
          Spontan fällt mir dazu ein:
          • definierte View anzeigen
          • variable Breite und gegebenenfalls Höhe
          • abgedunkelter Hintergrund
          • Option zum Schließen der View bei klicken außerhalb des Dialogs
          • Möglichkeit zur Anzeige/Aktivierung des Dialogs über State
          • optional Titel des Dialogs
          • optional schließen Button oben rechts oder unten
            @merlin123 Du kannst jetzt Rahmen und Inhalt unterschiedlich einfärben, also auch die Rahmenfarbe beibehalten.
            Ich habe zusätzlich noch geringfügig angepasst und optimiert. Wenn Du testen möchtest, dann Widgets bitte komplett neu anlegen.
            Matu
            #125
            @carsten04
            vielen Dank für deine tolle Sammlung. Ich habe versucht einen Button zu konfigurieren der wie die Schreibtischlampe den State true/false mit einem klick ändert (toggle). Leider will dies nicht gelingen. Habe alle 4 Widgets mal ausprobiert und verschiedene Einstellungen vorgenommen.
            Mit der Checkbox klappe es und das Widget ändert Farbe/Symbol usw. jedoch nur wenn ich das State im Objektbaum ändere. Die Checkbox lässt sich nicht auswählen. Das Mouse-Icon ändert sich auch nicht wenn es darüber ist.
              Matu
              #126
              Dieser Beitrag wurde gelöscht!
              • carsten04C Online
                carsten04C Online
                carsten04
                #127
                @matu Woran scheitert es denn genau? Eigentlich kannst Du bei der Grundeinstellung nicht viel falsch machen, schau mal hier:
                Achte auch darauf, dass die vis-2 die v2.9.64 (Stable-Version) hat.
                  Matu
                  #128
                  @carsten04
                  danke für die schnelle Rückmeldung. Die Vis-2 hat die Version 2.9.64.
                  Das Problem ist das ich das Widget nicht anklicken kann.
                  Widget.mp4
                  carsten04C 1 Antwort Letzte Antwort
                  • M Matu
                    @carsten04
                    Widget.mp4
                    carsten04C Online
                    carsten04C Online
                    carsten04
                    #129
                    @matu Zeig mal bitte was unter common im Objekt steht.
                      Matu
                      #130
                      @carsten04
                      das ist der ganz normale Beispiel DP.
                      Am DP liegt es auch nicht weil, weil wenn ich dein Schalter Widget verwende funktioniert es ja.
                      Auch die Button-Gruppe und der Schieberegler funktionieren.
                      Nur Checkbox und Zustand lassen sich nicht anklicken
                      carsten04C 2 Antworten Letzte Antwort
                      • M Matu
                        @carsten04
                        carsten04C Online
                        carsten04C Online
                        carsten04
                        #131
                        • M Matu
                          @carsten04
                          carsten04C Online
                          carsten04C Online
                          carsten04
                          #132
                          @matu Geh mal auf Objektdaten und mache dann bitte einen Screenshot.
                            Matu
                            #133
                            @carsten04
                            • M Matu
                              @carsten04
                              carsten04C Online
                              carsten04C Online
                              carsten04
                              #134
                              @matu Ergänze mal bitte in common:
                              "read": true,
                              "write": true
                                "read": true,
                                "write": true
                                Matu
                                #135
                                @carsten04
                                Keine Veränderung. Hier noch ein Video mit den 3 Widgets die alle auf den DP zugreifen.
                                20250225172110.mp4
                                • M Matu
                                  @carsten04
                                  20250225172110.mp4
                                  carsten04C Online
                                  carsten04C Online
                                  carsten04
                                  #136
                                  @matu Das schaue ich mir morgen am Rechner mal in Ruhe an.
                                  Wenn Du kurz noch Zeit hast mach mal bitte folgendes: lösche alle views in der vis-2 und lege eine neue leere view an und nutze nur das State-Widget. Ist der Effekt dann immer noch da?
                                    Matu
                                    #137
                                    @carsten04
                                    Jetzt funktioniert es, aber trotzdem komisch, dass es bei einigen geht und bei anderen nicht.
                                    Vielen Dank für die schnellen Rückmeldungen, spiele jetzt mal etwas mit deinen Widgets ;-)
                                    • M Matu
                                      @carsten04
                                      carsten04C Online
                                      carsten04C Online
                                      carsten04
                                      #138
                                      @matu Kurz zur Erklärung. Bei dem State-Widget kannst Du "Nur Anzeige" setzen.
                                      Die Anzeigeoption ist nur dann sichtbar, wenn der State writeable ist, ansonsten kann sowieso nur angezeigt werden. Das war bei Dir der Fall, da weder write noch read in common gesetzt war (bei Real Life States eines Adapter sind die beiden Attribute in common eigentlich immer vorhanden).
                                      Nach setzen der beiden Attribute in common, wie von Dir gemacht (insbesondere "write": true), hättest Du eigetlich nur den State (oid) im State-Widget noch einmal neu auswählen müssen, denn erst dann bekommt das Widget die Änderung mit (das ist vis-2 immanent und läßt sich nicht ändern). Die Info von mir die view zu löschen war überflüssig und das Widget macht dann eigentlich auch genau das was es soll.
                                        Matu
                                        #139
                                        @carsten04
                                        Danke für die Erklärung und die schnelle Hilfe.
                                        Ich konnte diese nachvollziehen und es ist genau so. Blöd das grade beim Example state R/W nicht standardmäßig gesetzt ist.
                                        Beste Grüße nach Schalke (nehme ich an) :-)
                                        • M Matu
                                          @carsten04
                                          carsten04C Online
                                          carsten04C Online
                                          carsten04
                                          #140
                                          @matu 👍
