  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. FingerBot stürzt ZHA Adapter ab.
13 Beiträge 3 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • Finn G.F Offline
    Finn G.F Offline
    Finn G.
    schrieb am zuletzt editiert von Finn G.
    Ich habe soeben diesen FingerBot eingebunden. Das hat sofort geklappt. Aber sobald ich den Schalter in der Ansicht umlege. Stürzt der ganze Zigbee ZHA Adapter ab. Ich verwende die SLZB-06 Antenne.
    Bildschirmfoto 2024-10-22 um 17.53.41.png Bildschirmfoto 2024-10-22 um 17.53.35.png
    host.409f9f45872b
    2024-10-22 17:54:13.323	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'includes')
    host.409f9f45872b
    2024-10-22 17:54:13.323	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    admin.0
    2024-10-22 17:54:13.449	info	<== Disconnect system.user.admin from ::ffff:192.168.144.1
    host.409f9f45872b
    2024-10-22 17:54:13.324	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    host.409f9f45872b
    2024-10-22 17:54:13.324	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.409f9f45872b
    2024-10-22 17:54:13.324	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.409f9f45872b
    2024-10-22 17:54:13.323	error	Caught by controller[1]: at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:640:23)
    host.409f9f45872b
    2024-10-22 17:54:13.323	error	Caught by controller[1]: at Array.forEach (<anonymous>)
    host.409f9f45872b
    2024-10-22 17:54:13.323	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:712:31
    host.409f9f45872b
    host.409f9f45872b
    zigbee.0
    2024-10-22 17:54:12.772	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2024-10-22 17:54:12.771	info	terminating
    zigbee.0
    2024-10-22 17:54:12.609	error	getGroupMembersFromController: error is {} "Error: \n at Groups.getGroupMembersFromController (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:88:119)\n at Groups.queryGroupMemberState (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:170:36)\n at Zigbee.callPluginMethod (/opt/iobroker/node_modules/iobroker.zigbee/main.js:926:45)\n at /opt/iobroker/node_modules/iobroker.zigbee/main.js:792:40"
    zigbee.0
    2024-10-22 17:54:12.608	error	getGroupMembersFromController: error is {} "Error: \n at Groups.getGroupMembersFromController (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:88:119)\n at Groups.queryGroupMemberState (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:170:36)\n at Zigbee.callPluginMethod (/opt/iobroker/node_modules/iobroker.zigbee/main.js:926:45)\n at /opt/iobroker/node_modules/iobroker.zigbee/main.js:792:40\n at runNextTicks (node:internal/process/task_queues:60:5)\n at listOnTimeout (node:internal/timers:545:9)\n at processTimers (node:internal/timers:519:7)"
    zigbee.0
    2024-10-22 17:54:12.271	info	Zigbee: disabling joining new devices.
    zigbee.0
    2024-10-22 17:54:12.270	info	cleaned everything up...
    zigbee.0
    2024-10-22 17:54:12.262	error	Cannot read properties of undefined (reading 'includes')
    zigbee.0
    2024-10-22 17:54:12.261	error	TypeError: Cannot read properties of undefined (reading 'includes') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:712:31 at Array.forEach (<anonymous>) at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:640:23)
    zigbee.0
    2024-10-22 17:54:12.261	error	unhandled promise rejection: Cannot read properties of undefined (reading 'includes')
    zigbee.0
    2024-10-22 17:54:12.261	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2024-10-22 17:54:09.079	info	List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    admin.0
    2024-10-22 17:54:08.772	info	==> Connected system.user.admin from ::ffff:192.168.144.1
    Edit: Ich hab den Fingerbot auch schon einmal komplett gelöscht und wieder eingebunden. Sobald ich da drauf klicke, stürzt der Adapter ab.
    • Finn G.F Finn G.
      host.409f9f45872b
      host.409f9f45872b
      admin.0
      host.409f9f45872b
      host.409f9f45872b
      host.409f9f45872b
      host.409f9f45872b
      host.409f9f45872b
      host.409f9f45872b
      host.409f9f45872b
      host.409f9f45872b
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      admin.0
      arteckA Offline
      arteckA Offline
      arteck
      @finn-g pack den mal unter Ausschliessen rein .. und schau nochmal
      Finn G.F 1 Antwort Letzte Antwort
      • arteckA arteck
        Finn G.F Offline
        Finn G.F Offline
        Finn G.
        @arteck Das leer.
        Und dann hab ich diesen über das + Menü hinzugefügt. Aber was soll das bringen? weil wenn ich den Knopf drücke das er was machen soll. Stürzt der Adapter immer noch ab.
        Ja, auch nach dem Adapter neustart, stürzt der Adapter komplett ab, wenn man den Fingerbot verweden will. hab alles merhmals neugestartet. Wurde nicht besser. Scheint aber wiedersprüchlich zu sein, weil er dann ja nicht ausgeschlossen wurde, oder?
        Was sollte da eigentlich passieren? Ich kenne diesen Bereich gar nicht. =)
        • Finn G.F Offline
          Finn G.F Offline
          Finn G.
          Keine Ahnung wie das nun kommt, aber es gibt einige auffällige fehler und vor allem wurde bei allen Gruppen der Inhalt gelöscht.
          host.409f9f45872b
          2024-10-22 23:26:27.032	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.409f9f45872b
          2024-10-22 23:26:27.032	error	Caught by controller[1]: at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:640:23)
          host.409f9f45872b
          2024-10-22 23:26:27.032	error	Caught by controller[1]: at Array.forEach (<anonymous>)
          host.409f9f45872b
          2024-10-22 23:26:27.032	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:712:31
          host.409f9f45872b
          2024-10-22 23:26:27.032	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'includes')
          host.409f9f45872b
          2024-10-22 23:26:27.032	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          zigbee.0
          2024-10-22 23:26:25.926	error	Cannot read properties of undefined (reading 'includes')
          zigbee.0
          2024-10-22 23:26:25.926	error	TypeError: Cannot read properties of undefined (reading 'includes') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:712:31 at Array.forEach (<anonymous>) at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:640:23)
          zigbee.0
          2024-10-22 23:26:25.926	error	unhandled promise rejection: Cannot read properties of undefined (reading 'includes')
          zigbee.0
          2024-10-22 23:26:25.926	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          WTF
          Und nun lassen sich die Geräte nicht wieder in die Gruppe hinzufügen! Was das??? Das zerstört doch das ganze SmartHome -.-
          • AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @finn-g bitte installier mal die aktuelle github 1.10.10. Version zum Testen ob der Fehler dann weg ist.
            Wichtig: vor der Installation eine Kopie aller Dateien aus /opt/iobroker/iobroker-data/zigbee_0 anlegen - diese werden ggf. Benötigt wenn du zurück zur 1.10.3 Version willst.
            A.
            • AsgothianA Asgothian
              A.
              Finn G.F Offline
              Finn G.F Offline
              Finn G.
              @asgothian Ich bin auf ZHA 1.10.10 wegen den Anderen geräten die hier erst richtig gut unterstützt werden. Ikea Button Schalter.
              Das so nervig. Es wird keine Gruppe bei dem gerät angezeigt. Also sie lässt sich auswählen und speichern. Wird aber nicht übernommen. Die Gruppen sind leer. Aber es erkennt den Schalter und steuert dennoch! ANzeigeBUG???
              Bildschirmfoto 2024-10-22 um 23.56.15.png Bildschirmfoto 2024-10-22 um 23.56.05.png
              Und dan steht das alles hier:
              zigbee.0
              2024-10-22 23:51:28.912	warn	DeviceConfigure: 0x048727fffe5cc18f PARASOLL Door/Window Sensor Failed to configure. When device works is all fine when not wake up the device and check again
              javascript.0
              2024-10-22 23:51:16.456	warn	Configured longitude is not a number - check (instance/system) configuration
              javascript.0
              2024-10-22 23:51:16.455	warn	Configured latitude is not a number - check (instance/system) configuration
              host.409f9f45872b
              2024-10-22 23:51:09.064	warn	Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/nodeFailed to set capabilities on file '/usr/bin/node': Operation not supported
              web.0
              2024-10-22 23:49:40.219	warn	setTimeout called, but adapter is shutting down
              zigbee.0
              2024-10-22 23:48:22.522	warn	calling addDevToGroup with 0x00158d0005a06306, 6, 1
              zigbee.0
              2024-10-22 23:48:22.522	warn	updateGroupMembership called with "zigbee.0.00158d0005a06306"
              zigbee.0
              2024-10-22 23:46:51.047	warn	calling addDevToGroup with 0x00158d0005a06306, 1, 1
              zigbee.0
              2024-10-22 23:46:51.047	warn	updateGroupMembership called with "zigbee.0.00158d0005a06306"
              • Finn G.F Finn G.
                zigbee.0
                javascript.0
                javascript.0
                host.409f9f45872b
                web.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @finn-g ich fürchte du hast ein größeres Problem - Beweis dafür sind die Meldungen aus dem Host und dem JS adapter. Bitte die erst gerade ziehen - dann schauen wir weiter.
                A.
                  A.
                  Finn G.F Offline
                  Finn G.F Offline
                  Finn G.
                  @asgothian Meinst du diese Zeile?
                  Weil ich das leider nicht verstehe und nicht weiß woher es kommt. Kann das mit der aktuellen Version von ZHA zu tun haben? Da brauchte ich die aktuelle Version. Liegt das wieder damit zusammen, dass die Gruppen nicht funktionieren?
                  Was muss nun repariert werden? Oder den Docker nochmal installieren?
                  • Finn G.F Finn G.
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @finn-g mit docker kenn ich mich nicht aus. Aber mit dem Zigbee Adapter hat das nix zu tun. Auch das der Web und javascript Adapter mit Warnungen im log auftauchen ist ein red flag - die sind entweder unsauber eingerichtet oder da klemmt was.
                    Nebenbei - ZHA und der Zigbee Adapter sind komplett unterschiedliche Schuhe. Ich gehe im Moment davon aus das du den zigbee Adapter installiert hast.
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      zeigmal die Datenpunkte von dem Ding, ich hab ne vermutung
                      und das LOG nach dem Starten des adapter.. zuerst aber das System sauber ziehen, auch wenns nervt
                      • Finn G.F Offline
                        Finn G.F Offline
                        Finn G.
                        Das ist das Log heute bis jetzt.
                        Ich hab nun den Docker Container nochmal frisch drüber installiert.
                        Und nun wurde das System komplett npchmal hochgefahren und die Meldungen sind:
                        zigbee.0
                        2024-10-23 13:56:58.660	warn	DeviceConfigure: 0x048727fffe5cc18f PARASOLL Door/Window Sensor Failed to configure. When device works is all fine when not wake up the device and check again
                        javascript.0
                        2024-10-23 13:56:40.329	warn	Configured longitude is not a number - check (instance/system) configuration
                        javascript.0
                        2024-10-23 13:56:40.328	warn	Configured latitude is not a number - check (instance/system) configuration
                        host.1e012aeb2c46
                        2024-10-23 13:56:32.880	warn	Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/nodeFailed to set capabilities on file '/usr/bin/node': Operation not supported
                        web.0
                        2024-10-23 13:55:06.101	warn	setTimeout called, but adapter is shutting down
                        @arteck Ja, ich habe den Zigbee Adapter installiert. Ich habe das "Ding" gestern wieder gelöscht. Hat auch nicht geholfen. Kann jemand über Discrod auf meine BIdlschrim drauf und schauen?
                        Kann jemand helfen? Ich weiß nicht weiter und es nervt, dass das Haus nicht geht. Familie :-(
                        • Finn G.F Offline
                          Finn G.F Offline
                          Finn G.
                          Weil dieser Fehler zwei beim einbinden des Geräts passiert ist, habe ich für den Fehler nun einen eigenen Beitrag eröffnet. Hier geht es nur wegen dem Fehler weiter. Dort habe ich auch das Log vom ganzen Tag hochgeladen.
                          • Finn G.F Finn G.
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @finn-g ohne das der docker Container fehlerfrei läuft macht es keinen Sinn am Zigbee Adapter irgend etwas zu versuchen. Das erst lösen, dann kann es weiter gehen. Die von dir gelisteten Meldungen müssen weg
