  4. Iot connection fail
Iot connection fail
19 Beiträge 4 Kommentatoren 1.5k Aufrufe 4 Beobachtet
    Biterr28
    Hallo zusammen, ich versuche, iot.0 zu installieren und eine Verbindung herzustellen, aber ich erhalte immer wieder ein Protokoll. der Adapter leuchtet immer wieder rot auf. Haben Sie eine Idee?
    host.Smarthome
    2024-10-14 20:32:53.565	info	Restart adapter system.adapter.iot.0 because enabled
    host.Smarthome
    2024-10-14 20:32:53.565	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Smarthome
    2024-10-14 20:32:53.565	error	Caught by controller[0]: Node.js v20.13.1
    host.Smarthome
    2024-10-14 20:32:53.565	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.Smarthome
    2024-10-14 20:32:53.565	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.Smarthome
    2024-10-14 20:32:53.564	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
    host.Smarthome
    2024-10-14 20:32:53.564	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.Smarthome
    2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.Smarthome
    2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.Smarthome
    2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.Smarthome
    2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.Smarthome
    2024-10-14 20:32:53.563	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
    host.Smarthome
    2024-10-14 20:32:53.563	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
    host.Smarthome
    2024-10-14 20:32:53.563	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
    host.Smarthome
    2024-10-14 20:32:53.562	error	Caught by controller[0]: /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/validations.js:1
    host.Smarthome
    2024-10-14 20:32:53.293	info	instance system.adapter.iot.0 in version "3.3.0" started with pid 137786
    host.Smarthome
    2024-10-14 20:32:22.664	info	Restart adapter system.adapter.iot.0 because enabled
    • B Biterr28
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      host.Smarthome
      @biterr28
      Zunächst: Bring dein System auf einen aktuellen Stand.
      B 1 Antwort Letzte Antwort
        @biterr28
        Biterr28
        Hallo, ich habe vor einer Woche ein Update durchgeführt. Ich habe alle Anwendungen erfolgreich aktualisiert.
        • B Biterr28
          @biterr28
          Dann ist da was falsch bei dir...
          Die Langfassung von
          iob diag
          bitte. Dein Betriebssystem hast du nämlich nicht auf Stand.
            @biterr28
            Die Langfassung von
            iob diag
            Biterr28
            @thomas-braun Hi, Ich habe beigefügt, hier sind die Ergebnisse. leider kann ich die Ursache immer noch nicht erkennen
               Static hostname: Smarthome
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CEST, +0200)
            User-ID:                1000
            Display-Server:         false
            Boot Target:            multi-user.target
            Pending OS-Updates:     141
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/nodejs         v20.13.1
            /usr/bin/node           v20.13.1
            /usr/bin/npm            10.5.2
            /usr/bin/npx            10.5.2
            /usr/bin/corepack       0.28.0
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            MEMORY:
            Mem:            7.8G        2.0G        1.9G        0.0K        3.9G        5.7G
            Swap:            99M          0B         99M
            Total:          7.9G        2.0G        2.0G
            Active iob-Instances:   21
            Upgrade policy: none
            ioBroker Core:          js-controller           6.0.11
                                    admin                   7.1.5
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : Smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.web.0                    : web                   : Smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                8789
            States:                 7318
            Size of iob-Database:
            16M     /opt/iobroker/iobroker-data/objects.jsonl
            6.0M    /opt/iobroker/iobroker-data/states.jsonl
            • B Biterr28
                       Icon name: computer
                    Architecture: arm64
              Kernel:                 aarch64
              Userland:               64 bit
              User-ID:                1000
              /usr/bin/npm            10.5.2
              /usr/bin/npx            10.5.2
              MEMORY:
              Swap:            99M          0B         99M
                                      admin                   7.1.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                8789
              States:                 7318
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              @biterr28 das ist die Kurzfassung, die Langfassung bitte
              Da fehlen aber ein Menge Updates
              • BananaJoeB BananaJoe
                Biterr28
                @bananajoe Sie haben Recht, tut mir leid. vollständiger Bericht unten
                ======== Start marking the full check here =========
                ```bash
                Skript v.2024-08-12
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 18:22:55 up 3 days, 21:52,  2 users,  load average: 2.64, 2.27, 2.11
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Wed 2024-10-16 18:22:56 CEST
                           Universal time: Wed 2024-10-16 16:22:56 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                *** Display-Server-Setup ***
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        1.6G        696M        0.0K        5.6G        6.1G
                Swap:            99M          0B         99M
                Total:          7.9G        1.6G        796M
                         7812 M total memory
                         1557 M used memory
                         1838 M active memory
                         4875 M inactive memory
                          696 M free memory
                          287 M buffer memory
                         5270 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 18:22:56 up 3 days, 21:52,  2 users,  load average: 2.64, 2.27, 2.11
                Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,  1.5 sy,  0.0 ni, 98.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   7812.3 total,    695.8 free,   1558.1 used,   5558.4 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6115.5 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4       30G   13G   16G  44% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     1.6G  888K  1.6G   1% /run
                /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
                [Sat Oct 12 20:30:14 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:1C:DF vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=7022dd96-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sat Oct 12 20:30:15 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
                [Sat Oct 12 20:30:15 2024] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
                [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
                [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): recovery complete
                [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                [Sat Oct 12 20:30:17 2024] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                [Sat Oct 12 20:30:19 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                [Tue Oct 15 21:33:11 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_t        ree:1101: inode #1322635: block 7455285: comm find: bad entry in directory: rec_        len is smaller than minimal - offset=0, inode=0, rec_len=0, size=4096 fake=0
                [Tue Oct 15 21:33:41 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_t        ree:1101: inode #1322639: block 7455286: comm find: bad entry in directory: rec_        len is smaller than minimal - offset=0, inode=0, rec_len=0, size=4096 fake=0
                Show mounted filesystems:
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,errors=remount-ro
                /var:
                3.4G    /var/
                2.0G    /var/log
                1.9G    /var/log/journal/bf14957a8fc542ac847a1bfbd4b1e9e4
                1.1G    /var/cache/apt
                Archived and active journals take up 1.8G in the file system.
                /opt/iobroker/backups:
                193M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                1.2G    /opt/iobroker/iobroker-data/
                1.1G    /opt/iobroker/iobroker-data/files
                617M    /opt/iobroker/iobroker-data/files/javascript.admin
                560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.j        s.map
                23M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                /dev/serial/by-id/usb-0658_0200-if00
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.18.0
                /usr/bin/node           v20.18.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.18.0-1nodesource1
                  Candidate: 20.18.0-1nodesource1
                  Version table:
                 *** 20.18.0-1nodesource1 600
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                        100 /var/lib/dpkg/status
                     20.17.0-1nodesource1 600
                     20.16.0-1nodesource1 600
                     20.15.1-1nodesource1 600
                     20.15.0-1nodesource1 600
                     20.14.0-1nodesource1 600
                     20.13.1-1nodesource1 600
                     20.13.0-1nodesource1 600
                     20.12.2-1nodesource1 600
                     20.12.1-1nodesource1 600
                     20.12.0-1nodesource1 600
                     20.11.1-1nodesource1 600
                     20.11.0-1nodesource1 600
                     20.10.0-1nodesource1 600
                     20.9.0-1nodesource1 600
                     20.8.1-1nodesource1 600
                     20.8.0-1nodesource1 600
                     20.7.0-1nodesource1 600
                     20.6.1-1nodesource1 600
                     20.6.0-1nodesource1 600
                     20.5.1-1nodesource1 600
                     20.5.0-1nodesource1 600
                     20.4.0-1nodesource1 600
                     20.3.1-1nodesource1 600
                     20.3.0-1nodesource1 600
                     20.2.0-1nodesource1 600
                     20.1.0-1nodesource1 600
                     20.0.0-1nodesource1 600
                     12.22.12~dfsg-1~deb11u5 500
                        500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  6.0.11
                admin:          7.1.5
                javascript:     8.8.3
                nodejs modules from github:     0
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : Smarthome                                -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : Smarthome                                - disabled
                + system.adapter.backitup.0               : backitup              : Smarthome                                -  enabled
                  system.adapter.cloud.0                  : cloud                 : Smarthome                                - disabled
                + system.adapter.cloud.1                  : cloud                 : Smarthome                                -  enabled
                  system.adapter.devices.0                : devices               : Smarthome                                - disabled
                + system.adapter.discovery.0              : discovery             : Smarthome                                -  enabled
                + system.adapter.email.0                  : email                 : Smarthome                                -  enabled
                + system.adapter.followthesun.0           : followthesun          : Smarthome                                -  enabled
                + system.adapter.fritzbox.0               : fritzbox              : Smarthome                                -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : Smarthome                                -  enabled
                  system.adapter.habpanel.0               : habpanel              : Smarthome                                -  enabled
                + system.adapter.info.0                   : info                  : Smarthome                                -  enabled
                  system.adapter.iot.0                    : iot                   : Smarthome                                -  enabled
                  system.adapter.iwg-vpn.0                : iwg-vpn               : Smarthome                                - disabled
                  system.adapter.iwg-vpn.1                : iwg-vpn               : Smarthome                                - disabled
                + system.adapter.javascript.0             : javascript            : Smarthome                                -  enabled
                  system.adapter.lg-thinq.0               : lg-thinq              : Smarthome                                - disabled
                + system.adapter.linux-control.0          : linux-control         : Smarthome                                -  enabled
                + system.adapter.nina.0                   : nina                  : Smarthome                                -  enabled
                  system.adapter.openweathermap.0         : openweathermap        : Smarthome                                -  enabled
                + system.adapter.pushover.0               : pushover              : Smarthome                                -  enabled
                + system.adapter.scenes.0                 : scenes                : Smarthome                                -  enabled
                + system.adapter.telegram.0               : telegram              : Smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.vis-2.0                  : vis-2                 : Smarthome                                -  enabled
                  system.adapter.vis.0                    : vis                   : Smarthome                                -  enabled
                + system.adapter.zwave2.0                 : zwave2                : Smarthome                                -  enabled
                + system.adapter.zwave2.1                 : zwave2                : Smarthome                                -  enabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                Adapter    "devices"      : 1.1.5    , installed 1.1.5
                Adapter    "email"        : 1.3.1    , installed 1.3.1
                Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                Controller "js-controller": 6.0.11   , installed 6.0.11
                Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
                Objects and States
                Objects:        8838
                States:         7331
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       413471     191964/iobroker.js-
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       414132     191964/iobroker.js-
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11878      557/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          422500     195397/cupsd
                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15597      556/vncserver-x11-c
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          422499     195397/cupsd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       411514     191982/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       415928     192271/io.web.0
                tcp6       0      0 :::44541                :::*                    LISTEN      1001       439348     202043/./pawns-cli
                tcp6       0      0 :::22                   :::*                    LISTEN      0          11880      557/sshd: /usr/sbin
                tcp6       0      0 :::5900                 :::*                    LISTEN      0          15596      556/vncserver-x11-c
                udp        0      0 0.0.0.0:53894           0.0.0.0:*                           108        11851      409/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11849      409/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15622      480/dhcpcd
                udp6       0      0 :::546                  :::*                                0          14830      480/dhcpcd
                udp6       0      0 :::54442                :::*                                108        11852      409/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        11850      409/avahi-daemon: r
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]: Node.js v20.18.0
                2024-10-16 18:23:04.257  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-16 18:23:04.257  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                2024-10-16 18:23:34.594  - info: host.Smarthome instance system.adapter.iot.0 in version "3.3.0" started with pid 218934
                2024-10-16 18:23:34.852  - error: host.Smarthome Caught by controller[0]: /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/validations.js:1
                2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]: SyntaxError: Invalid or unexpected token
                2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1378:20)
                2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1428:41)
                2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]: Node.js v20.18.0
                2024-10-16 18:23:34.854  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-16 18:23:34.854  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                iob diag has finished.
                • B Biterr28
                  ```bash
                  Skript v.2024-08-12
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           7812 M total memory
                           1557 M used memory
                            696 M free memory
                            287 M buffer memory
                           5270 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /var:
                  3.4G    /var/
                  2.0G    /var/log
                  1.1G    /var/cache/apt
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.1.5
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        8838
                  States:         7331
                  Pending Updates: 0
                  @biterr28
                  Sauber neustarten. Da war mit Sicherheit bei den 141 Updates das ein oder andere dabei...
                  Dein Dateisystem sieht auchh nicht mehr topfit aus.
                  vncserver und cups sollten auch nicht laufen.
                    @biterr28
                    Biterr28
                    @thomas-braun Was genau sollte ich in dieser Situation tun?
                    • B Biterr28
                      @biterr28
                      sudo reboot
                        @biterr28
                        sudo reboot
                        Biterr28
                        @thomas-braun immer noch keine Verbindung. unten neue diagnose. können sie bitte helfen? sollte ich versuchen, adpter iot.0 zu deinstallieren und neu zu installieren?
                        ```bash
                        Skript v.2024-08-12
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         19:05:02 up 24 min,  2 users,  load average: 0.56, 0.50, 0.44
                        CPU threads: 4
                        Current issues:
                                       Local time: Wed 2024-10-16 19:05:02 CEST
                                   Universal time: Wed 2024-10-16 17:05:02 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        1.4G        6.0G        0.0K        495M        6.3G
                        Swap:            99M          0B         99M
                        Total:          7.9G        1.4G        6.1G
                                 7812 M total memory
                                 1360 M used memory
                                 1509 M active memory
                                  218 M inactive memory
                                 5956 M free memory
                                   64 M buffer memory
                                  430 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        top - 19:05:03 up 24 min,  2 users,  load average: 0.56, 0.50, 0.44
                        Tasks: 189 total,   1 running, 188 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   7812.3 total,   5956.3 free,   1360.1 used,    496.0 buff/cache
                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6330.7 avail Mem
                        *** FILESYSTEM ***
                        /dev/root      ext4       30G   12G   16G  43% /
                        tmpfs          tmpfs     1.6G  884K  1.6G   1% /run
                        [Wed Oct 16 18:40:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:1C:DF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7022dd96-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Wed Oct 16 18:40:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Wed Oct 16 18:40:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Wed Oct 16 18:40:08 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        3.4G    /var/
                        2.0G    /var/log
                        1.1G    /var/cache/apt
                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        28M     /opt/iobroker/iobroker-data/objects.jsonl
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.1.5
                        javascript:     8.8.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        8836
                        States:         7329
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12804      529/cupsd
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15400      537/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16401      537/iobroker.js-con
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1964       563/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          13881      557/vncserver-x11-c
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16816      1114/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15489      802/io.admin.0
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12803      529/cupsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1966       563/sshd: /usr/sbin
                        tcp6       0      0 :::5900                 :::*                    LISTEN      0          13880      557/vncserver-x11-c
                        tcp6       0      0 :::34367                :::*                    LISTEN      1001       15712      1013/./pawns-cli
                        udp        0      0 0.0.0.0:50310           0.0.0.0:*                           108        1914       410/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1912       410/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2002       475/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        1913       410/avahi-daemon: r
                        udp6       0      0 :::48385                :::*                                108        1915       410/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          15374      475/dhcpcd
                        2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                        2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                        2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                        2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]: Node.js v20.18.0
                        2024-10-16 19:04:58.361  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-16 19:04:58.361  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                        2024-10-16 19:05:28.769  - info: host.Smarthome instance system.adapter.iot.0 in version "3.3.0" started with pid 2547
                        2024-10-16 19:05:29.034  - error: host.Smarthome Caught by controller[0]: /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/validations.js:1
                        2024-10-16 19:05:29.034  - error: host.Smarthome Caught by controller[0]: SyntaxError: Invalid or unexpected token
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1378:20)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1428:41)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[1]: Node.js v20.18.0
                        2024-10-16 19:05:29.036  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-16 19:05:29.036  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                        2024-10-16 19:05:34.135  - info: web.0 (1114) ==> Connected system.user.admin from 2a00:1e:8c84:1901:786b:ecef:7449:b94c
                        • B Biterr28
                          ```bash
                          Skript v.2024-08-12
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7812 M total memory
                                   1360 M used memory
                                   5956 M free memory
                                     64 M buffer memory
                                    430 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          *** FILESYSTEM ***
                          /var:
                          3.4G    /var/
                          2.0G    /var/log
                          1.1G    /var/cache/apt
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        8836
                          States:         7329
                          Pending Updates: 0
                          @biterr28 sagte in Iot connection fail:
                          Das ist Malware. Die ist hier schon verschiedentlich aufgetaucht.
                          System löschen und komplett frisch neuaufsetzen.
                            Biterr28
                            @thomas-braun Ich verstehe nicht wirklich, wovon Sie sprechen und wie man das macht. Das ist völlig neu für mich. Ich habe das aktuelle System vom Vorbesitzer übernommen.
                            • B Biterr28
                              Dann installier es neu, damit es auch DEIN System ist.
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                Biterr28
                                @thomas-braun Gibt es eine Schritt-für-Schritt-Anleitung, wie man das richtig macht?
                                • B Biterr28
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @biterr28 said in Iot connection fail:
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  • mcm1957M mcm1957
                                    Biterr28
                                    @mcm1957 danke :)
                                    und wie kann ich das System deinstallieren? Gibt es auch eine Gebrauchsanweisung? Vielen Dank im Voraus für Ihre Hilfe
                                    • B Biterr28
                                      @mcm1957 danke :)
                                      @biterr28
                                      Eine Neuinstallation überschreibt die alte Installation.
                                      Ich würde aber vermutlich gleich eine neue SD-Karte verwenden.
                                        @biterr28
                                        Biterr28
                                        Herzlichen Dank für Ihre Hilfe. :)
