  4. IRobot Roomba Adapter
    6.4k
851 Beiträge 101 Kommentatoren 389.3k Aufrufe 65 Beobachtet
  • H HerrStrich
    @Zefau
    code_text
    ```pi@raspberrypi:~ $  npm install -g dorita980
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/dorita980
    npm ERR! path /usr/lib/node_modules/dorita980
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/dorita980'
    npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules/dorita980']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules/dorita980\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/usr/lib/node_modules/dorita980' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!     /home/pi/.npm/_logs/2019-08-14T12_59_51_462Z-debug.log
    events.js:174
          throw er; // Unhandled 'error' event
    Error: connect ECONNREFUSED 192.168.2.117:8883
        at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    Emitted 'error' event at:
        at emitErrorNT (internal/streams/destroy.js:91:8)
        at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
        at process._tickCallback (internal/process/next_tick.js:63:19)
    Habe ein Roomba 960 mit der 2.4.6-3 Frimware.
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    #221
    @HerrStrich Das ist kein Fehler aufgrund des Roomba's, des Adapters oder der zugrundeliegenden Library. Du hast laut Log keine Schreibrechte auf den Ordner, in dem du dorita980 installieren willst (steht ja auch da).
    Guck mal im ioBroker Ordner. Dort solltest du dorita schon installiert haben.
    Entweder unter
    /opt/iobroker/node_modules/dorita980
    oder
    /opt/iobroker/node_modules/iobroker.roomba/node_modules/dorita980
    In diesem Ordner kannst du dann der Anleitung https://github.com/koalazak/dorita980#how-to-get-your-usernameblid-and-password folgen und npm run getpassword <robotIP> ausführen.
    Sollte das dann fehlschlagen, poste das Log nochmal hier im Forum.
    Meine Adapter: https://zefau.github.io/iobroker/
    H 1 Antwort Letzte Antwort
    • ZefauZ Zefau
      Entweder unter
      oder
      HerrStrich
      #222
      @Zefau
      Passwort bekomm ich nun geb es auch ein aber :
      roomba.0	2019-08-14 18:07:08.487	info	Connecting to Roomba..
      roomba.0	2019-08-14 18:07:08.416	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.roomba, node: v10.16.2
      roomba.0	2019-08-14 18:07:38.576	warn	Connection lost! Roomba offline.
      Er bekommt einfach keine verbindung zum Roomba!
      ZefauZ 1 Antwort Letzte Antwort
      • H HerrStrich
        @Zefau
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        #223
        @HerrStrich Hast du denn parallel die App auf dem Handy offen oder so?
        • ZefauZ Zefau
          HerrStrich
          #224
          @Zefau
          Nein, hab alles ausgemacht leider keine verbindung möglich :(
            Tariot
            #225
            Ich habe genau das selbe Problem... das pw wird nicht automatisch eingefügt... gebe ich es manuell ein bekomme ich die gleiche Meldung... roomba is offline... hatte ihn vorher im ifttt.. auch dort das Gerät gelöscht..
            Trotzdem der gleiche Fehler... würde dir meine logs schicken aber die sind identisch zu herrstrich
            • T Tariot
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #226
              @Tariot @HerrStrich Wenn ihr bewusst ein falsches Passwort eingebt, bekommt ihr dann einen Fehler (by controller[0]: { Error: Connection refused: Not authorized) ?
              • ZefauZ Zefau
                HerrStrich
                #227
                @Zefau
                Nein bekomme keine Fehler Meldung nur das Wasser ich dir schon gezeigt habe!
                Habe die Raspberry jetzt auch nochmal komplett neu aufgesetzt aber leider wieder mit dem gleichen Ergebnis!
                Langsam weiß ich auch nicht mehr weiter :(
                • H HerrStrich
                  @Zefau
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  schrieb am zuletzt editiert von Zefau
                  #228
                  @HerrStrich @Tariot Habe auf Github und npm die Version v1.0.4 veröffentlicht. Diese aktualisiert die zugrundeliegenden Pakete, was ggf. das Problem behebt.
                  Der Passwort-Abruf sollte nun ebenfalls wieder funktionieren.
                  Sollte die Version nach wie vor nicht funktionieren, bitte unter Instanzen den Adapter von info auf debug stellen.
                  Dann werden im Log mehr Informationen ausgegeben. Ggf. hilft uns das, das Problem einzugrenzen.
                    Tariot
                    schrieb am zuletzt editiert von Tariot
                    #229
                    ja PW wird nun automatisch erkannt, ein fortschritt^^ aber leider keine verbindung
                    er schreibt in die loggs nun
                    roomba.0	2019-08-16 11:44:49.928	debug	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                    roomba.0	2019-08-16 11:44:49.926	debug	Roomba Connection closed.
                    roomba.0	2019-08-16 11:44:47.371	debug	Updated state states._connected to value false (from null).
                    roomba.0	2019-08-16 11:44:47.370	debug	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                    roomba.0	2019-08-16 11:44:47.370	debug	Roomba Connection closed.
                    roomba.0	2019-08-16 11:44:47.370	debug	undefined
                    roomba.0	2019-08-16 11:44:47.368	warn	Connection lost! Roomba offline.
                    • T Tariot
                      ZefauZ Offline
                      ZefauZ Offline
                      Zefau
                      #230
                      @Tariot Das genügt. Danke dir. EPROTO deutet scheinbar darauf hin, dass der SSL handshake abbricht. Liegt also nicht direkt am Adapter, sondern der library, die genutzt wird, um mit dem Roomba zu kommunizieren.
                      • ZefauZ Zefau
                        ZefauZ Offline
                        ZefauZ Offline
                        Zefau
                        #231
                        @Tariot @HerrStrich Habt ihr die Möglichkeit per SSH oder Samba Dateien anzupassen?
                        Könntet ihr bitte in den folgenden Ordnern (sofern vorhanden) eine Datei anpassen?
                        /opt/iobroker/node_modules/iobroker.roomba/node_modules/dorita980/lib/v2/
                        und
                        /opt/iobroker/node_modules/dorita980/lib/v2/
                        die Datei local.js.
                        Dort findet ihr ab Zeile 18:
                          var options = {
                            port: 8883,
                            clientId: user,
                            rejectUnauthorized: false,
                            protocolId: 'MQTT',
                            protocolVersion: 4,
                            clean: false,
                            username: user,
                            password: password
                        Dort die folgenden zwei Zeilen hinzufügen (https://github.com/nodejs/node/issues/3692#issuecomment-158414743)
                            ciphers: 'ALL',
                            secureProtocol: 'TLSv1_method'
                        zu
                          var options = {
                            port: 8883,
                            clientId: user,
                            ciphers: 'ALL',
                            secureProtocol: 'TLSv1_method',
                            protocolId: 'MQTT',
                            protocolVersion: 4,
                            clean: false,
                            username: user,
                            password: password
                        Speichern und Adapter neustarten.
                          Tariot
                          #232
                          @Zefau said in IRobot Roomba Adapter:
                          also beide datein geändert... gleiche fehler weiterhin ;(
                          ZefauZ 2 Antworten Letzte Antwort
                          • T Tariot
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            #233
                            @Tariot Welche Node.js Version hast du?
                            • T Tariot
                              ZefauZ Offline
                              ZefauZ Offline
                              Zefau
                              #234
                              @Tariot sagte in IRobot Roomba Adapter:
                              Ist leider ein rumprobieren, da ich den Fehler nicht rekonstruieren kann bei mir.
                              Nimm bitte
                              wieder raus und versuch folgende Optionen:
                                  minVersion: 'TLSv1',
                                  ecdhCurve: 'auto'
                              also:
                                var options = {
                                  port: 8883,
                                  clientId: user,
                                  ciphers: 'ALL',
                                  ecdhCurve: 'auto',
                                  protocolId: 'MQTT',
                                  protocolVersion: 4,
                                  clean: false,
                                  username: user,
                                  password: password
                              EDIT: Und unbedingt Adapter neustarten.
                              • ZefauZ Zefau
                                Nimm bitte
                                    ecdhCurve: 'auto'
                                also:
                                  var options = {
                                    port: 8883,
                                    clientId: user,
                                    ciphers: 'ALL',
                                    ecdhCurve: 'auto',
                                    protocolId: 'MQTT',
                                    protocolVersion: 4,
                                    clean: false,
                                    username: user,
                                    password: password
                                HerrStrich
                                #235
                                @Zefau
                                ecdhCurve: 'auto'
                                damit geht es leider bei mir auch nicht....
                                Zumal ich
                                gar nicht habe....
                                node -v
                                v10.16.3
                                • H HerrStrich
                                  @Zefau
                                  ecdhCurve: 'auto'
                                  Zumal ich
                                  gar nicht habe....
                                  node -v
                                  v10.16.3
                                  ZefauZ Offline
                                  ZefauZ Offline
                                  Zefau
                                  #236
                                  @HerrStrich sagte in IRobot Roomba Adapter:
                                  Welchen der beiden Ordner gibt es denn bei dir?
                                  Ich habe einen Roomba 980 mit FW v2.4.6-3 auf Node.js v10.16.1 und bei mir funktioniert's.
                                  Der Fehler EPROTO deutet (laut Google) auf einen Fehler im SSL Handshake. Ist aber eine reine Vermutung von mir, da ich, wie gesagt, den Fehler nicht habe.
                                  Bei dir ist es ein Roomba 960 mit FW 2.4.6-3 auf Node.js v10.16.3. Also eigl. nicht so anders.
                                  Der Adapter lädt bei dir gar keine Daten? Also auch keine Config-Einstellungen?
                                  Sprich du kannst nicht sehen, was in roomba.0.device.versions.navSwVer bzw roomba.0.device.versions.wifiSwVer steht?
                                  • ZefauZ Zefau
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    #237
                                    Ich hab ein Issue aufgemacht: https://github.com/koalazak/dorita980/issues/95
                                      Tariot
                                      #238
                                      ok die neuen zeilen eingebaut.
                                      nun ist ein teil des fehlers weg
                                      vorher
                                      nun noch
                                      oomba.0	2019-08-17 09:52:03.003	debug	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                                      roomba.0	2019-08-17 09:52:03.001	debug	Roomba Connection closed.
                                      bei mir ist der pfad zu denn datein anders als beschrieben. hoffe das ist egal... immerhin beide gefunden
                                      node version = v10.16.2.
                                      • T Tariot
                                        vorher
                                        nun noch
                                        ZefauZ Offline
                                        ZefauZ Offline
                                        Zefau
                                        #239
                                        @Tariot Ist möglicherweise nicht egal. Wenn du die falschen Dateien bearbeitest, dann haben die Änderungen ja keine Auswirkungen. Die Frage ist, welche Datei konkret vom Adapter gezogen wird, denn die muss geändert werden.
                                        • T Tariot
                                          vorher
                                          nun noch
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #240
                                          @Tariot Welchen dorita980 Ordner hast du denn gefunden?
                                          Gibt es die folgenden Ordner bei dir?
