  4. Beim Update von Adaptern stürzt der ioBroker ab
89 Beiträge 7 Kommentatoren 17.4k Aufrufe 4 Beobachtet
    @flommaster
    cd /opt/iobroker && npm ls
    spuckt aus?
    mcm1957M Online
    mcm1957M Online
    mcm1957
    Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
    npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
    Den Adapter gibts (dort) gar nicht ...
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
      @flommaster
      spuckt aus?
      flommaster
      @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
      zu viele Fehler...
      Teil 1
      iobroker.inst@2.0.3 /opt/iobroker
      ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
      ├── @alcalzone/jsonl-db@3.1.1 extraneous
      ├── @alcalzone/pak@0.8.1 extraneous
      ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
      ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
      ├── @azure/abort-controller@1.1.0 extraneous
      ├── @azure/core-auth@1.7.2 extraneous
      ├── @azure/core-client@ extraneous
      ├── @azure/core-http-compat@ extraneous
      ├── @azure/core-lro@ extraneous
      ├── @azure/core-paging@1.6.2 extraneous
      ├── @azure/core-rest-pipeline@ extraneous
      ├── @azure/core-tracing@1.1.2 extraneous
      ├── @azure/core-util@ extraneous
      ├── @azure/identity@ extraneous
      ├── @azure/keyvault-keys@ extraneous
      ├── @azure/logger@1.1.4 extraneous
      ├── @azure/msal-browser@ extraneous
      ├── @azure/msal-common@ extraneous
      ├── @azure/msal-node@1.18.4 extraneous
      ├── @babel/code-frame@7.24.7 extraneous
      ├── @babel/helper-validator-identifier@7.24.7 extraneous
      ├── @babel/highlight@7.24.7 extraneous
      ├── @babel/runtime@ extraneous
      ├── @colors/colors@1.5.0 extraneous
      ├── @dabh/diagnostics@2.0.3 extraneous
      ├── @datalust/winston-seq@1.0.2 extraneous
      ├── @gar/promisify@1.1.3 extraneous
      ├── @googleapis/calendar@9.7.7 extraneous
      ├── @googleapis/drive@5.1.0 extraneous
      ├── @googleapis/oauth2@1.0.7 extraneous
      ├── @httptoolkit/websocket-stream@6.0.1 extraneous
      ├── @iobroker/db-base@ extraneous
      ├── @iobroker/db-objects-file@ extraneous
      ├── @iobroker/db-objects-jsonl@ extraneous
      ├── @iobroker/db-objects-redis@ extraneous
      ├── @iobroker/db-states-file@ extraneous
      ├── @iobroker/db-states-jsonl@ extraneous
      ├── @iobroker/db-states-redis@ extraneous
      ├── @iobroker/js-controller-adapter@ extraneous
      ├── @iobroker/js-controller-cli@ extraneous
      ├── @iobroker/js-controller-common-db@ extraneous
      ├── @iobroker/js-controller-common@ extraneous
      ├── @iobroker/plugin-base@1.2.1 extraneous
      ├── @iobroker/plugin-sentry@1.2.1 extraneous
      ├── @iobroker/socket-classes@1.5.6 extraneous
      ├── @iobroker/webserver@1.0.3 extraneous
      ├── @isaacs/cliui@8.0.2 extraneous
      ├── @js-joda/core@ extraneous
      ├── @mapbox/node-pre-gyp@1.0.11 extraneous
      ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
      ├── @nodelib/fs.scandir@2.1.5 extraneous
      ├── @nodelib/fs.stat@2.0.5 extraneous
      ├── @nodelib/fs.walk@1.2.8 extraneous
      ├── @npmcli/fs@2.1.2 extraneous
      ├── @npmcli/move-file@2.0.1 extraneous
      ├── @pkgjs/parseargs@0.11.0 extraneous
      ├── @protobufjs/aspromise@1.1.2 extraneous
      ├── @protobufjs/base64@1.1.2 extraneous
      ├── @protobufjs/codegen@2.0.4 extraneous
      ├── @protobufjs/eventemitter@1.1.0 extraneous
      ├── @protobufjs/fetch@1.1.0 extraneous
      ├── @protobufjs/float@1.0.2 extraneous
      ├── @protobufjs/inquire@1.1.0 extraneous
      ├── @protobufjs/path@1.1.2 extraneous
      ├── @protobufjs/pool@1.1.0 extraneous
      ├── @protobufjs/utf8@1.1.0 extraneous
      ├── @quasar/extras@ extraneous
      ├── @samverschueren/stream-to-observable@0.3.1 extraneous
      ├── @sentry-internal/tracing@ extraneous
      ├── @sentry/core@5.30.0 extraneous
      ├── @sentry/hub@5.30.0 extraneous
      ├── @sentry/minimal@5.30.0 extraneous
      ├── @sentry/node@ extraneous
      ├── @sentry/tracing@ extraneous
      ├── @sentry/types@ extraneous
      ├── @sentry/utils@ extraneous
      ├── @sindresorhus/is@4.6.0 extraneous
      ├── @socket.io/component-emitter@3.1.2 extraneous
      ├── @szmarczak/http-timer@4.0.6 extraneous
      ├── @tediousjs/connection-string@0.5.0 extraneous
      ├── @tootallnate/once@2.0.0 extraneous
      ├── @types/bl@5.1.0 extraneous
      ├── @types/cacheable-request@6.0.3 extraneous
      ├── @types/caseless@0.12.5 extraneous
      ├── @types/cookie@0.4.1 extraneous
      ├── @types/cors@2.8.17 extraneous
      ├── @types/geojson@7946.0.14 extraneous
      ├── @types/http-cache-semantics@4.0.4 extraneous
      ├── @types/keyv@3.1.4 extraneous
      ├── @types/leaflet@1.9.12 extraneous
      ├── @types/minimist@1.2.5 extraneous
      ├── @types/node-cron@2.0.8 extraneous
      ├── @types/node@ extraneous
      ├── @types/normalize-package-data@2.4.4 extraneous
      ├── @types/parse-json@4.0.2 extraneous
      ├── @types/readable-stream@4.0.15 extraneous
      ├── @types/request@2.48.12 extraneous
      ├── @types/responselike@1.0.3 extraneous
      ├── @types/tough-cookie@4.0.5 extraneous
      ├── @types/triple-beam@1.3.5 extraneous
      ├── @types/tz-offset@0.0.3 extraneous
      ├── @types/ws@8.5.12 extraneous
      ├── abab@2.0.6 extraneous
      ├── abbrev@1.1.1 extraneous
      ├── abort-controller@3.0.0 extraneous
      ├── agentkeepalive@4.5.0 extraneous
      ├── aggregate-error@3.1.0 extraneous
      ├── ajv@ extraneous
      ├── ansi-align@3.0.1 extraneous
      ├── ansi-colors@4.1.3 extraneous
      ├── ansi-escapes@4.3.2 extraneous
      ├── ansi-regex@5.0.1 extraneous
      ├── ansi-styles@4.3.0 extraneous
      ├── any-observable@0.5.1 extraneous
      ├── anymatch@3.1.3 extraneous
      ├── aproba@2.0.0 extraneous
      ├── archiver-utils@5.0.2 extraneous
      ├── archiver@7.0.1 extraneous
      ├── are-we-there-yet@2.0.0 extraneous
      ├── arg@4.1.0 extraneous
      ├── argparse@1.0.10 extraneous
      ├── array-buffer-byte-length@1.0.1 extraneous
      ├── array-flatten@1.1.1 extraneous
      ├── array-union@2.1.0 extraneous
      ├── arraybuffer.prototype.slice@1.0.3 extraneous
      ├── arrify@2.0.1 extraneous
      ├── asn1@0.2.6 extraneous
      ├── async-exit-hook@2.0.1 extraneous
      ├── authenticate-pam@1.0.5 extraneous
      ├── available-typed-arrays@1.0.7 extraneous
      ├── aws-crt@ extraneous
      ├── b4a@1.6.6 extraneous
      ├── balanced-match@1.0.2 extraneous
      ├── bare-events@2.4.2 extraneous
      ├── base-64@1.0.0 extraneous
      ├── base64-js@1.5.1 extraneous
      ├── bcrypt-pbkdf@1.0.2 extraneous
      ├── binary-extensions@2.3.0 extraneous
      ├── bindings@1.5.0 extraneous
      ├── bl@6.0.14 extraneous
      ├── bluebird@3.7.2 extraneous
      ├── body-parser@1.20.2 extraneous
      ├── bottleneck@2.19.5 extraneous
      ├── boxen@5.1.2 extraneous
      ├── brace-expansion@2.0.1 extraneous
      ├── braces@3.0.3 extraneous
      ├── buffer-crc32@1.0.0 extraneous
      ├── buffer-equal-constant-time@1.0.1 extraneous
      ├── buffer-shims@1.0.0 extraneous
      ├── buffer@6.0.3 extraneous
      ├── buildcheck@0.0.6 extraneous
      ├── builtins@1.0.3 extraneous
      ├── busboy@1.6.0 extraneous
      ├── byte-length@1.0.2 extraneous
      ├── bytes@3.1.2 extraneous
      ├── cacache@16.1.3 extraneous
      ├── cacheable-lookup@5.0.4 extraneous
      ├── cacheable-request@7.0.4 extraneous
      ├── callsites@3.1.0 extraneous
      ├── camelcase-keys@6.2.2 extraneous
      ├── camelcase@5.3.1 extraneous
      ├── capitalize@2.0.4 extraneous
      ├── chalk@4.1.2 extraneous
      ├── chardet@0.7.0 extraneous
      ├── charenc@0.0.2 extraneous
      ├── chokidar@3.6.0 extraneous
      ├── chownr@2.0.0 extraneous
      ├── ci-info@3.9.0 extraneous
      ├── clean-stack@2.2.0 extraneous
      ├── cli-boxes@2.2.1 extraneous
      ├── cli-cursor@3.1.0 extraneous
      ├── cli-truncate@0.2.1 extraneous
      ├── cli-width@3.0.0 extraneous
      ├── clone-response@1.0.3 extraneous
      ├── cloneextend@0.0.3 extraneous
      ├── cluster-key-slot@1.1.2 extraneous
      ├── coap-packet@1.1.1 extraneous
      ├── coffeescript@1.12.7 extraneous
      ├── color-convert@2.0.1 extraneous
      ├── color-name@1.1.4 extraneous
      ├── color-string@1.9.1 extraneous
      ├── color-support@1.1.3 extraneous
      ├── color@3.2.1 extraneous
      ├── colors@1.4.0
      ├── colorspace@1.1.4 extraneous
      ├── commander@9.5.0 extraneous
      ├── commist@3.2.0 extraneous
      ├── compress-commons@6.0.2 extraneous
      ├── compress-json@2.1.2 extraneous
      ├── compressible@2.0.18 extraneous
      ├── compression@1.7.4 extraneous
      ├── concat-map@0.0.1 extraneous
      ├── configstore@5.0.1 extraneous
      ├── connect-flash@0.1.1 extraneous
      ├── connect@3.7.0 extraneous
      ├── console-control-strings@1.1.0 extraneous
      ├── content-disposition@0.5.4 extraneous
      ├── content-type@1.0.5 extraneous
      ├── core-js@ extraneous
      ├── cors@2.8.5 extraneous
      ├── cosmiconfig@7.1.0 extraneous
      ├── cpu-features@ extraneous
      ├── crc-32@1.2.2 extraneous
      ├── crc@ extraneous
      ├── crc32-stream@6.0.0 extraneous
      ├── cross-fetch@4.0.0 extraneous
      ├── crypt@0.0.2 extraneous
      ├── crypto-js@ extraneous
      ├── crypto-random-string@2.0.0 extraneous
      ├── cssstyle@ extraneous
      ├── cycle@1.0.3 extraneous
      ├── dashdash@1.14.1 extraneous
      ├── data-urls@4.0.0 extraneous
      ├── data-view-buffer@1.0.1 extraneous
      ├── data-view-byte-length@1.0.1 extraneous
      ├── data-view-byte-offset@1.0.0 extraneous
      ├── date-and-time@ extraneous
      ├── date-fns@1.30.1 extraneous
      ├── dateformat@4.6.3 extraneous
      ├── dayjs@ extraneous
      ├── decache@4.6.2 extraneous
      ├── decamelize-keys@1.1.1 extraneous
      ├── decimal.js@10.4.3 extraneous
      ├── decompress-response@6.0.0 extraneous
      ├── deep-clone@3.0.3 extraneous
      ├── deep-extend@0.6.0 extraneous
      ├── deep-is@0.1.4 extraneous
      ├── defer-to-connect@2.0.1 extraneous
      ├── define-lazy-prop@2.0.0 extraneous
      ├── del@6.1.1 extraneous
      ├── delegates@1.0.0 extraneous
      ├── denque@1.5.1 extraneous
      ├── destroy@1.2.0 extraneous
      ├── detect-libc@2.0.3 extraneous
      ├── diacritics@1.3.0 extraneous
      ├── digest-header@1.1.0 extraneous
      ├── dir-glob@3.0.1 extraneous
      ├── diskusage@1.2.0 extraneous
      ├── domexception@4.0.0 extraneous
      ├── dot-prop@6.0.1 extraneous
      ├── draftlog@1.0.13 extraneous
      ├── dropbox-v2-api@ extraneous
      ├── duplexer@0.1.2 extraneous
      ├── duplexer3@0.1.5 extraneous
      ├── duplexify@3.7.1 extraneous
      ├── eastasianwidth@0.2.0 extraneous
      ├── ecc-jsbn@0.1.2 extraneous
      ├── ecdsa-sig-formatter@1.0.11 extraneous
      ├── echarts@ extraneous
      ├── ee-first@1.1.1 extraneous
      ├── elegant-spinner@1.0.1 extraneous
      ├── emoji-regex@9.2.2 extraneous
      ├── enabled@2.0.0 extraneous
      ├── encodeurl@1.0.2 extraneous
      ├── encoding@0.1.13 extraneous
      ├── end-of-stream@1.4.4 extraneous
      ├── entities@4.5.0 extraneous
      ├── err-code@2.0.3 extraneous
      ├── es-abstract@ extraneous
      ├── es-aggregate-error@1.0.13 extraneous
      ├── es-object-atoms@1.0.0 extraneous
      ├── es-set-tostringtag@2.0.3 extraneous
      ├── es-to-primitive@1.2.1 extraneous
      ├── es6-promise@4.2.8 extraneous
      ├── es6-promisify@5.0.0 extraneous
      ├── esbuild@0.11.23 extraneous
      ├── escalade@3.1.2 extraneous
      ├── escape-goat@3.0.0 extraneous
      ├── escape-html@1.0.3 extraneous
      ├── escape-string-regexp@4.0.0 extraneous
      ├── escodegen@1.14.3 extraneous
      ├── esprima@1.2.2 extraneous
      ├── estraverse@4.3.0 extraneous
      ├── esutils@2.0.3 extraneous
      ├── etag@1.8.1 extraneous
      ├── event-stream@4.0.1 extraneous
      ├── event-target-shim@5.0.1 extraneous
      ├── eventemitter2@6.4.9 extraneous
      ├── events@3.3.0 extraneous
      ├── execa@5.1.1 extraneous
      ├── expand-template@2.0.3 extraneous
      ├── express-fileupload@1.5.1 extraneous
      ├── express@4.19.2 extraneous
      ├── external-editor@3.1.0 extraneous
      ├── fast-deep-equal@3.1.3 extraneous
      ├── fast-fifo@1.3.2 extraneous
      ├── fast-glob@ extraneous
      ├── fast-json-stable-stringify@2.1.0 extraneous
      ├── fast-levenshtein@2.0.6 extraneous
      ├── fast-text-encoding@1.0.6 extraneous
      ├── fast-unique-numbers@ extraneous
      ├── fast-uri@3.0.1 extraneous
      ├── fast-xml-parser@ extraneous
      ├── fastq@1.17.1 extraneous
      ├── fastseries@2.0.0 extraneous
      ├── fecha@4.2.3 extraneous
      ├── figures@3.2.0 extraneous
      ├── file-stream-rotator@0.6.1 extraneous
      ├── file-type@10.11.0 extraneous
      ├── file-uri-to-path@1.0.0 extraneous
      ├── fill-range@7.1.1 extraneous
      ├── finalhandler@1.2.0 extraneous
      ├── find-up@5.0.0 extraneous
      ├── fn.name@1.1.0 extraneous
      ├── for-each@0.3.3 extraneous
      ├── foreground-child@3.3.0 extraneous
      ├── form-data-encoder@2.1.4 extraneous
      ├── form-data@4.0.0 extraneous
      ├── forwarded@0.2.0 extraneous
      ├── fresh@0.5.2 extraneous
      ├── from@0.1.7 extraneous
      ├── fs-constants@1.0.0 extraneous
      ├── fs-extra@7.0.1
      ├── fs-minipass@2.1.0 extraneous
      ├── fs.realpath@1.0.0 extraneous
      ├── fsevents@ extraneous
      ├── ftp@0.3.10 extraneous
      ├── function.prototype.name@1.1.6 extraneous
      ├── functions-have-names@1.2.3 extraneous
      ├── futoin-hkdf@1.4.3 extraneous
      ├── gauge@3.0.2 extraneous
      ├── gaxios@5.1.3 extraneous
      ├── gcp-metadata@5.3.0 extraneous
      ├── generate-function@2.3.1 extraneous
      ├── get-ssl-certificate@2.3.3 extraneous
      ├── get-stream@5.2.0 extraneous
      ├── get-symbol-description@1.0.2 extraneous
      ├── getpass@0.1.7 extraneous
      ├── github-from-package@0.0.0 extraneous
      ├── github-url-from-git@1.5.0 extraneous
      ├── glob-parent@5.1.2 extraneous
      ├── glob@10.4.5 extraneous
      ├── global-dirs@2.1.0 extraneous
      ├── globalthis@1.0.4 extraneous
      ├── globby@11.1.0 extraneous
      ├── glossy@0.1.7 extraneous
      ├── google-auth-library@ extraneous
      ├── google-p12-pem@4.0.1 extraneous
      ├── googleapis-common@6.0.4 extraneous
      ├── googleapis@ extraneous
      ├── gtoken@6.1.2 extraneous
      ├── hard-rejection@2.1.0 extraneous
      ├── has-ansi@2.0.0 extraneous
      ├── has-bigints@1.0.2 extraneous
      ├── has-flag@4.0.0 extraneous
      ├── has-tostringtag@1.0.2 extraneous
      ├── has-unicode@2.0.1 extraneous
      ├── has-yarn@2.1.0 extraneous
      ├── he@1.2.0 extraneous
      ├── help-me@5.0.0 extraneous
      ├── homebridge-plugin-wrapper@ extraneous
      ├── hosted-git-info@3.0.8 extraneous
      ├── hot-patcher@1.0.0 extraneous
      ├── html-encoding-sniffer@3.0.0 extraneous
      ├── http-cache-semantics@4.1.1 extraneous
      ├── http-errors@2.0.0 extraneous
      ├── http-proxy-agent@5.0.0 extraneous
      ├── http2-wrapper@1.0.3 extraneous
      ├── https@1.0.0 extraneous
      ├── humanize-ms@1.2.1 extraneous
      ├── ical.js@ extraneous
      ├── iconv-lite@0.4.24 extraneous
      ├── ieee754@1.2.1 extraneous
      ├── ignore-walk@3.0.4 extraneous
      ├── ignore@5.3.2 extraneous
      ├── image-type@4.1.0 extraneous
      ├── immediate@3.0.6 extraneous
      ├── import-fresh@3.3.0 extraneous
      ├── import-lazy@2.1.0 extraneous
      ├── import-local@3.2.0 extraneous
      ├── imurmurhash@0.1.4 extraneous
      ├── indent-string@3.2.0 extraneous
      ├── infer-owner@1.0.4 extraneous
      ├── inflight@1.0.6 extraneous
      ├── ini@1.3.7 extraneous
      ├── inquirer-autosubmit-prompt@0.2.0 extraneous
      ├── inquirer@7.3.3 extraneous
      ├── int64-buffer@1.0.1 extraneous
      ├── internal-slot@1.0.7 extraneous
      ├── iobroker-adapter-helpers@0.0.8 extraneous
      ├── iobroker.admin@ invalid: "^6.10.1" from the root project
      ├── iobroker.backitup@ invalid: "2.6.23" from the root project
      ├── iobroker.bmw@2.5.7
      ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
      ├── iobroker.cloud@4.4.1
      ├── iobroker.coronavirus-statistics@0.8.7
      ├── iobroker.daswetter@3.1.10
      ├── iobroker.discovery@ invalid: "3.1.0" from the root project
      ├── iobroker.dwd@2.8.5
      ├── iobroker.echarts@ invalid: "1.5.1" from the root project
      ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
      ├── iobroker.eusec@1.1.2
      ├── iobroker.flot@ invalid: "1.12.0" from the root project
      ├── iobroker.fritzbox@0.2.1
      ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
      ├── iobroker.fullybrowser@2.1.2
      ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
      ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
      ├── iobroker.harmony@1.2.2
      ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
      ├── iobroker.history@2.2.6
      ├── iobroker.hm-rega@3.0.47
      ├── iobroker.hm-rpc@1.15.19
      ├── iobroker.hue@3.9.5
      ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
      ├── iobroker.icons-icons8@0.0.1
      ├── iobroker.icons-material-png@0.1.0
      ├── iobroker.icons-mfd-png@1.1.0
      ├── iobroker.icons-ultimate-png@1.0.1
      ├── iobroker.info@ invalid: "1.9.26" from the root project
      ├── iobroker.javascript@ invalid: "7.1.4" from the root project
      ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
      ├── iobroker.logparser@2.2.0
      ├── iobroker.material@ invalid: "1.3.1" from the root project
      ├── iobroker.meross@1.15.1
      ├── iobroker.mihome-vacuum@3.11.0
      ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
      ├── iobroker.milight@0.3.6
      ├── iobroker.mobile@ invalid: "1.0.1" from the root project
      ├── iobroker.modbus@ invalid: "5.0.11" from the root project
      ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
      ├── iobroker.nina@ invalid: "0.0.25" from the root project
      ├── iobroker.pollenflug@1.0.6
      ├── iobroker.pushover@3.0.3
      ├── iobroker.pushsafer@1.0.3
      ├── iobroker.pvforecast@2.7.1
      ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
      ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
      ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.smartmeter@3.3.4
      ├── iobroker.socketio@6.5.2
      ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
      ├── iobroker.sql@2.2.0
      ├── iobroker.statistics@2.3.0
      ├── iobroker.sunnyportal@0.1.5
      ├── iobroker.synology@ invalid: "2.1.13" from the root project
      ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
      ├── iobroker.terminal@ invalid: "1.0.0" from the root project
      ├── iobroker.tr-064@4.2.18
      ├── iobroker.trashschedule@2.2.0
      ├── iobroker.unifi@ invalid: "0.6.6" from the root project
      ├── iobroker.upnp@1.0.21
      ├── iobroker.valloxmv@1.2.0
      ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
      ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
      ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
      ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
      ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
      ├── iobroker.vis-fancyswitch@1.1.0
      ├── iobroker.vis-google-fonts@1.0.4
      ├── iobroker.vis-history@1.0.0
      ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
      ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
      ├── iobroker.vis-jqui-mfd@1.0.12
      ├── iobroker.vis-justgage@1.0.2
      ├── iobroker.vis-map@1.0.4
      ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
      ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
      ├── iobroker.vis-rgraph@0.0.2
      ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
      ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
      ├── iobroker.vis@ invalid: "1.4.16" from the root project
      ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
      ├── iobroker.weatherunderground@3.4.2
      ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
      ├── iobroker.web@ invalid: "6.1.0" from the root project
      ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
      ├── iobroker.wiffi-wz@2.2.1
      ├── iobroker.windows-control@0.1.5
      ├── iobroker.worx@2.3.2
      ├── iobroker.ws@2.5.3
      ├── iobroker@2.0.3
      ├── ioredis@ extraneous
      ├── ip-address@9.0.5 extraneous
      ├── ip-regex@4.3.0 extraneous
      ├── ipaddr.js@2.2.0 extraneous
      ├── is-array-buffer@3.0.4 extraneous
      ├── is-bigint@1.0.4 extraneous
      ├── is-binary-path@2.1.0 extraneous
      ├── is-boolean-object@1.1.2 extraneous
      ├── is-buffer@1.1.6 extraneous
      ├── is-callable@1.2.7 extraneous
      ├── is-ci@2.0.0 extraneous
      ├── is-core-module@2.15.0 extraneous
      ├── is-data-view@1.0.1 extraneous
      ├── is-date-object@1.0.5 extraneous
      ├── is-docker@2.2.1 extraneous
      ├── is-empty-object@1.1.1 extraneous
      ├── is-extglob@2.1.1 extraneous
      ├── is-fullwidth-code-point@3.0.0 extraneous
      ├── is-glob@4.0.3 extraneous
      ├── is-installed-globally@0.3.2 extraneous
      ├── is-interactive@1.0.0 extraneous
      ├── is-lambda@1.0.1 extraneous
      ├── is-negative-zero@2.0.3 extraneous
      ├── is-npm@5.0.0 extraneous
      ├── is-number-object@1.0.7 extraneous
      ├── is-number@7.0.0 extraneous
      ├── is-obj@2.0.0 extraneous
      ├── is-observable@1.1.0 extraneous
      ├── is-path-cwd@2.2.0 extraneous
      ├── is-path-inside@3.0.3 extraneous
      ├── is-plain-obj@1.1.0 extraneous
      ├── is-potential-custom-element-name@1.0.1 extraneous
      ├── is-promise@2.2.2 extraneous
      ├── is-property@1.0.2 extraneous
      ├── is-regex@1.1.4 extraneous
      ├── is-scoped@2.1.0 extraneous
      ├── is-shared-array-buffer@1.0.3 extraneous
      ├── is-string@1.0.7 extraneous
      ├── is-symbol@1.0.4 extraneous
      ├── is-typed-array@1.1.13 extraneous
      ├── is-unicode-supported@0.1.0 extraneous
      ├── is-url-superb@4.0.0 extraneous
      ├── is-url@1.2.4 extraneous
      ├── is-weakref@1.0.2 extraneous
      ├── is-wsl@2.2.0 extraneous
      ├── is-yarn-global@0.3.0 extraneous
      ├── is@3.3.0 extraneous
      ├── is2@2.0.9 extraneous
      ├── isomorphic-ws@4.0.1 extraneous
      ├── issue-regex@3.1.0 extraneous
      ├── jackspeak@3.4.3 extraneous
      ├── js-md4@0.3.2 extraneous
      ├── js-sdsl@4.3.0 extraneous
      ├── js-tokens@4.0.0 extraneous
      ├── js-yaml@ extraneous
      ├── jsbi@4.3.0 extraneous
      ├── jsbn@1.1.0 extraneous
      ├── jsdom@ extraneous
      ├── jshashes@1.0.8 extraneous
      ├── json-buffer@3.0.1 extraneous
      ├── json-logic-js@2.0.5 extraneous
      ├── json-parse-even-better-errors@2.3.1 extraneous
      ├── json-schema-traverse@1.0.0 extraneous
      ├── json5@2.2.3 extraneous
      ├── jsonata@ extraneous
      ├── jsonc-parser@3.3.1 extraneous
      ├── jsonwebtoken@9.0.2 extraneous
      ├── jszip@ extraneous
      ├── jwa@2.0.0 extraneous
      ├── jws@4.0.0 extraneous
      ├── keyv@4.5.4 extraneous
      ├── kind-of@6.0.3 extraneous
      ├── kuler@2.0.0 extraneous
      ├── later@1.2.0 extraneous
      ├── latest-version@5.1.0 extraneous
      ├── layerr@0.1.2 extraneous
      ├── lazystream@1.0.1 extraneous
      ├── leven@2.1.0 extraneous
      ├── levn@0.3.0 extraneous
      ├── lie@3.3.0 extraneous
      ├── lines-and-columns@1.2.4 extraneous
      ├── listr-input@0.2.1 extraneous
      ├── listr-silent-renderer@1.1.1 extraneous
      ├── listr-update-renderer@0.5.0 extraneous
      ├── listr-verbose-renderer@0.5.0 extraneous
      ├── listr@0.14.3 extraneous
      ├── loadavg-windows@1.1.1 extraneous
      ├── locate-path@6.0.0 extraneous
      ├── lodash.defaults@4.2.0 extraneous
      ├── lodash.flatten@4.4.0 extraneous
      ├── lodash.includes@4.3.0 extraneous
      ├── lodash.isarguments@3.1.0 extraneous
      ├── lodash.isboolean@3.0.3 extraneous
      ├── lodash.isequal@4.5.0 extraneous
      ├── lodash.isinteger@4.0.4 extraneous
      ├── lodash.isnumber@3.0.3 extraneous
      ├── lodash.isplainobject@4.0.6 extraneous
      ├── lodash.isstring@4.0.1 extraneous
      ├── lodash.once@4.1.1 extraneous
      ├── lodash.zip@4.2.0 extraneous
      ├── log-symbols@4.1.0 extraneous
      ├── log-update@2.3.0 extraneous
      ├── logform@ extraneous
      ├── long@5.2.3 extraneous
      ├── lowercase-keys@2.0.0 extraneous
      ├── lru_map@0.3.3 extraneous
      ├── lru-cache@6.0.0 extraneous
      ├── make-dir@3.1.0 extraneous
      ├── make-fetch-happen@10.2.1 extraneous
      ├── map-age-cleaner@0.1.3 extraneous
      ├── map-obj@4.3.0 extraneous
      ├── map-stream@0.0.7 extraneous
      ├── md5@2.3.0 extraneous
      ├── media-typer@0.3.0 extraneous
      ├── meow@8.1.2 extraneous
      ├── merge-descriptors@1.0.1 extraneous
      ├── merge2@1.4.1 extraneous
      ├── methods@1.1.2 extraneous
      ├── micro@9.4.1 extraneous
      ├── micromatch@4.0.7 extraneous
      ├── mime-db@1.53.0 extraneous
      ├── mimic-response@1.0.1 extraneous
      ├── min-indent@1.0.1 extraneous
      ├── minimatch@9.0.5 extraneous
      ├── minimist-options@4.1.0 extraneous
      ├── minipass-collect@1.0.2 extraneous
      ├── minipass-fetch@2.1.2 extraneous
      ├── minipass-flush@1.0.5 extraneous
      ├── minipass-pipeline@1.2.4 extraneous
      ├── minipass-sized@1.0.3 extraneous
      ├── minipass@7.1.2 extraneous
      ├── minizlib@2.1.2 extraneous
      ├── mkdirp-classic@0.5.3 extraneous
      ├── mkdirp@1.0.4 extraneous
      ├── mock-require@3.0.3 extraneous
      ├── moment-duration-format@2.3.2 extraneous
      ├── mqtt-connection@4.1.0 extraneous
      ├── mqtt-packet@9.0.0 extraneous
      ├── mqtt@ extraneous
      ├── mute-stream@0.0.8 extraneous
      ├── named-placeholders@1.1.3 extraneous
      ├── nan@ extraneous
      ├── nanoid@3.3.7 extraneous
      ├── napi-build-utils@1.0.2 extraneous
      ├── native-duplexpair@1.0.0 extraneous
      ├── nconf@0.10.0 extraneous
      ├── nested-property@4.0.0 extraneous
      ├── netmask@2.0.2 extraneous
      ├── new-github-release-url@1.0.0 extraneous
      ├── node-abi@3.65.0 extraneous
      ├── node-abort-controller@3.1.1 extraneous
      ├── node-cron@2.0.3 extraneous
      ├── node-fetch@2.7.0 extraneous
      ├── node-forge@ extraneous
      ├── node-gyp@ extraneous
      ├── node-ical@0.16.1 extraneous
      ├── node-inspect@2.0.0 extraneous
      ├── node-libcurl@3.0.0 extraneous
      ├── node-mndp@0.0.3 extraneous
      ├── node-persist@0.0.11 extraneous
      ├── node-rsa@1.1.1 extraneous
      ├── node-unifi@2.5.1 extraneous
      ├── node-wol@0.1.1 extraneous
      ├── node.extend@2.0.3 extraneous
      ├── nopt@5.0.0 extraneous
      ├── normalize-package-data@3.0.3 extraneous
      ├── normalize-path@3.0.0 extraneous
      ├── normalize-url@6.1.0 extraneous
      ├── np@7.7.0 extraneous
      ├── npm-name@6.0.1 extraneous
      ├── npmlog@5.0.1 extraneous
      ├── number-allocator@1.0.14 extraneous
      ├── nwsapi@2.2.12 extraneous
      ├── object-assign@4.1.1 extraneous
      ├── object-hash@3.0.0 extraneous
      ├── on-finished@2.4.1 extraneous
      ├── once@1.4.0 extraneous
      ├── one-time@1.0.0 extraneous
      ├── onedrive-api@1.1.1 extraneous
      ├── open@7.4.2 extraneous
      ├── opencollective-postinstall@2.0.3 extraneous
      ├── optionator@0.8.3 extraneous
      ├── org-regex@1.0.0 extraneous
      ├── os-tmpdir@1.0.2 extraneous
      ├── ospath@1.2.2 extraneous
      ├── osx-temperature-sensor@ extraneous
      ├── otplib@11.0.1 extraneous
      ├── ow@0.21.0 extraneous
      ├── p-cancelable@2.1.1 extraneous
      ├── p-defer@1.0.0 extraneous
      ├── p-event@4.2.0 extraneous
      ├── p-finally@1.0.0 extraneous
      ├── p-limit@2.3.0 extraneous
      ├── p-locate@5.0.0 extraneous
      ├── p-map@2.1.0 extraneous
      ├── p-memoize@4.0.4 extraneous
      ├── p-reflect@2.1.0 extraneous
      ├── p-settle@4.1.1 extraneous
      ├── p-throttle@4.1.1 extraneous
      ├── p-timeout@4.1.0 extraneous
      ├── p-try@2.2.0 extraneous
      ├── package-json-from-dist@1.0.0 extraneous
      ├── package-json@6.5.0 extraneous
      ├── pako@ extraneous
      ├── parent-module@1.0.1 extraneous
      ├── parse-json@5.2.0 extraneous
      ├── parse5@ extraneous
      ├── passport-local@1.0.0 extraneous
      ├── passport@0.7.0 extraneous
      ├── path-exists@4.0.0 extraneous
      ├── path-is-absolute@1.0.1 extraneous
      ├── path-parse@1.0.7 extraneous
      ├── path-posix@1.0.0 extraneous
      ├── path-scurry@1.11.1 extraneous
      ├── path-to-regexp@0.1.7 extraneous
      ├── path-type@4.0.0 extraneous
      ├── pause-stream@0.0.11 extraneous
      ├── picomatch@2.3.1 extraneous
      ├── pidtree@0.6.0 extraneous
      ├── pidusage@3.0.2 extraneous
      ├── ping@0.4.4 extraneous
      ├── pkg-dir@5.0.0 extraneous
      ├── pluralize@8.0.0 extraneous
      ├── possible-typed-array-names@1.0.0 extraneous
      ├── prebuild-install@7.1.2 extraneous
      ├── prelude-ls@1.1.2 extraneous
      ├── prepend-http@2.0.0 extraneous
      ├── process-nextick-args@2.0.1 extraneous
      ├── process@0.11.10 extraneous
      ├── promise-inflight@1.0.1 extraneous
      ├── promise-object@0.1.7 extraneous
      ├── promise-retry@2.0.1 extraneous
      ├── promise-retryer@0.0.1 extraneous
      ├── promisify-child-process@4.1.2 extraneous
      ├── prompt@1.3.0 extraneous
      ├── protobufjs@ extraneous
      ├── proxy-addr@2.0.7 extraneous
      ├── proxy-from-env@1.1.0 extraneous
      ├── pump@3.0.0 extraneous
      ├── pupa@2.1.1 extraneous
      ├── q@1.1.2 extraneous
      ├── quasar@ extraneous
      ├── queue-microtask@1.2.3 extraneous
      ├── queue-tick@1.0.1 extraneous
      ├── quick-lru@5.1.1 extraneous
      ├── range-parser@1.2.1 extraneous
      ├── raw-body@2.5.2 extraneous
      ├── rc@1.2.8 extraneous
      ├── read-pkg-up@7.0.1 extraneous
      ├── read-pkg@5.2.0 extraneous
      ├── read@1.0.7 extraneous
      ├── readable-stream@ extraneous
      ├── readdir-glob@1.1.3 extraneous
      ├── readdirp@3.6.0 extraneous
      ├── readline-sync@1.4.10 extraneous
      ├── readline@1.3.0 extraneous
      ├── redent@3.0.0 extraneous
      ├── redis-commands@1.7.0 extraneous
      ├── redis-errors@1.2.0 extraneous
      ├── redis-parser@3.0.0 extraneous
      ├── regenerator-runtime@0.14.1 extraneous
      ├── regex-escape@3.4.10 extraneous
      ├── regexp.prototype.flags@1.5.2 extraneous
      ├── registry-auth-token@4.2.2 extraneous
      ├── registry-url@5.1.0 extraneous
      ├── reinterval@1.1.0 extraneous
      ├── remove-trailing-separator@1.1.0 extraneous
      ├── require-from-string@2.0.2 extraneous
      ├── resolve-alpn@1.2.1 extraneous
      ├── resolve-cwd@3.0.0 extraneous
      ├── resolve-from@4.0.0 extraneous
      ├── respjs@4.2.0 extraneous
      ├── responselike@2.0.1 extraneous
      ├── restore-cursor@3.1.0 extraneous
      ├── retry-axios@2.6.0 extraneous
      ├── retry@0.12.0 extraneous
      ├── reusify@1.0.4 extraneous
      ├── revalidator@0.1.8 extraneous
      ├── rfdc@1.4.1 extraneous
      ├── rimraf@3.0.2 extraneous
      ├── rrule@2.8.1 extraneous
      ├── rrweb-cssom@0.6.0 extraneous
      ├── run-async@2.4.1 extraneous
      ├── run-parallel@1.2.0 extraneous
      ├── rxjs@ extraneous
      ├── safe-array-concat@1.1.2 extraneous
      ├── safe-regex-test@1.0.3 extraneous
      ├── safe-stable-stringify@2.4.3 extraneous
      ├── safer-buffer@2.1.2 extraneous
      ├── saxes@6.0.0 extraneous
      ├── scoped-regex@2.1.0 extraneous
      ├── secure-keys@1.0.0 extraneous
      ├── semver-diff@3.1.1 extraneous
      ├── semver@5.7.2
      ├── send@0.18.0 extraneous
      ├── seq-logging@1.1.2 extraneous
      ├── seq-queue@0.0.5 extraneous
      ├── serve-static@1.15.0 extraneous
      ├── set-function-name@2.0.2 extraneous
      ├── setimmediate@1.0.5 extraneous
      ├── setprototypeof@1.2.0 extraneous
      ├── signal-exit@4.1.0 extraneous
      ├── simple-concat@1.0.1 extraneous
      ├── simple-get@3.1.1 extraneous
      ├── simple-ssh@1.1.1 extraneous
      ├── simple-swizzle@0.2.2 extraneous
      ├── slash@3.0.0 extraneous
      ├── slice-ansi@0.0.4 extraneous
      ├── smart-buffer@4.2.0 extraneous
      ├── socks-proxy-agent@7.0.0 extraneous
      ├── socks@2.8.3 extraneous
      ├── speedtest-net@1.6.2 extraneous
      ├── split@1.0.1 extraneous
      ├── sprintf-js@1.1.3 extraneous
      ├── sqlstring@2.3.3 extraneous
      ├── ssh2@ extraneous
      ├── ssri@9.0.1 extraneous
      ├── stack-trace@0.0.10 extraneous
      ├── stampit-event-bus@0.1.1 extraneous
      ├── stampit-state-machine@0.2.1 extraneous
      ├── stampit@2.1.2 extraneous
      ├── standard-as-callback@2.1.0 extraneous
      ├── static-eval@2.0.2 extraneous
      ├── statuses@2.0.1 extraneous
      ├── stoppable@1.1.0 extraneous
      ├── stream-combiner@0.2.2 extraneous
      ├── stream-shift@1.0.3 extraneous
      ├── streamsearch@1.1.0 extraneous
      ├── streamx@2.18.0 extraneous
      ├── string-argv@0.3.2 extraneous
      ├── string-width-cjs@npm:string-width@4.2.3 extraneous
      ├── string-width@5.1.2 extraneous
      ├── string.prototype.trim@1.2.9 extraneous
      ├── string.prototype.trimend@1.0.8 extraneous
      ├── string.prototype.trimstart@1.0.8 extraneous
      ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
      ├── strip-ansi@6.0.1 extraneous
      ├── strip-indent@3.0.0 extraneous
      ├── strip-json-comments@2.0.1 extraneous
      ├── strnum@1.0.5 extraneous
      ├── suncalc@1.9.0 extraneous
      ├── suncalc2@1.8.1 extraneous
      ├── supermixer@1.0.5 extraneous
      ├── supports-color@7.2.0 extraneous
      ├── supports-hyperlinks@2.3.0 extraneous
      ├── supports-preserve-symlinks-flag@1.0.0 extraneous
      ├── sweet-collections@1.1.0 extraneous
      ├── symbol-observable@3.0.0 extraneous
      ├── symbol-tree@3.2.4 extraneous
      ├── syno@ extraneous
      ├── systeminformation@ extraneous
      ├── tar-fs@2.1.1 extraneous
      ├── tar-stream@3.1.7 extraneous
      ├── tar@6.2.1 extraneous
      ├── tarn@3.0.2 extraneous
      ├── tcp-port-used@1.0.2 extraneous
      ├── tedious@ extraneous
      ├── terminal-link@2.1.1 extraneous
      ├── text-decoder@1.1.1 extraneous
      ├── text-hex@1.0.0 extraneous
      ├── thirty-two@1.0.2 extraneous
      ├── through@2.3.8 extraneous
      ├── through2@2.0.5 extraneous
      ├── tiny-typed-emitter@2.1.0 extraneous
      ├── tinycolor2@1.6.0 extraneous
      ├── tmp@0.0.33 extraneous
      ├── to-readable-stream@2.1.0 extraneous
      ├── to-regex-range@5.0.1 extraneous
      ├── toidentifier@1.0.1 extraneous
      ├── tr46@4.1.1 extraneous
      ├── trim-newlines@3.0.1 extraneous
      ├── triple-beam@1.4.1 extraneous
      ├── tsdav@ extraneous
      ├── tslib@2.3.0 extraneous
      ├── tweetnacl@0.14.5 extraneous
      ├── type-check@0.3.2 extraneous
      ├── type-fest@0.21.3 extraneous
      ├── type-is@1.6.18 extraneous
      ├── typed-array-buffer@1.0.2 extraneous
      ├── typed-array-byte-length@1.0.1 extraneous
      ├── typed-array-byte-offset@1.0.2 extraneous
      ├── typed-array-length@1.0.6 extraneous
      ├── typedarray-to-buffer@3.1.5 extraneous
      ├── typedarray.prototype.slice@1.0.3 extraneous
      ├── typescript@ extraneous
      ├── tz-offset@0.0.1 extraneous
      ├── uid-number@0.0.6 extraneous
      ├── unbox-primitive@1.0.2 extraneous
      ├── undici-types@6.19.6 extraneous
      ├── unique-filename@2.0.1 extraneous
      ├── unique-slug@3.0.0 extraneous
      ├── unique-string@2.0.0 extraneous
      ├── unix-dgram@2.0.6 extraneous
      ├── unpipe@1.0.0 extraneous
      ├── update-notifier@5.1.0 extraneous
      ├── uri-js@4.4.1 extraneous
      ├── url-join@4.0.1 extraneous
      ├── url-parse-lax@3.0.0 extraneous
      ├── url-template@2.0.8 extraneous
      ├── url@0.11.4 extraneous
      ├── vali-date@1.0.0 extraneous
      ├── validate-npm-package-name@3.0.0 extraneous
      ├── vary@1.1.2 extraneous
      ├── virtual-tsc@0.6.2 extraneous
      ├── vue-i18n@ extraneous
      ├── vuelidate-messages@0.1.2 extraneous
      ├── vuelidate@ extraneous
      ├── vuex-map-fields@1.4.1 extraneous
      ├── w3c-xmlserializer@4.0.0 extraneous
      ├── wake_on_lan@1.0.0 extraneous
      ├── weak-daemon@1.0.3 extraneous
      ├── webdav@ extraneous
      ├── webidl-conversions@7.0.0 extraneous
      ├── websocket-stream@5.5.2 extraneous
      ├── whatwg-encoding@2.0.0 extraneous
      ├── whatwg-mimetype@3.0.0 extraneous
      ├── whatwg-url@12.0.1 extraneous
      ├── which-boxed-primitive@1.0.2 extraneous
      ├── which-typed-array@1.1.15 extraneous
      ├── wide-align@1.1.5 extraneous
      ├── widest-line@3.1.0 extraneous
      ├── window-size@0.1.4 extraneous
      ├── winston-daily-rotate-file@5.0.0 extraneous
      ├── winston-seq-updated@1.0.4 extraneous
      ├── winston-syslog@2.7.1 extraneous
      ├── winston-transport@4.7.1 extraneous
      ├── winston@ extraneous
      ├── word-wrap@1.2.5 extraneous
      ├── worker-timers-broker@6.1.8 extraneous
      ├── worker-timers-worker@7.0.71 extraneous
      ├── worker-timers@7.1.8 extraneous
      ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
      ├── wrap-ansi@8.1.0 extraneous
      ├── wrappy@1.0.2 extraneous
      ├── write-file-atomic@3.0.3 extraneous
      ├── xdg-basedir@4.0.0 extraneous
      ├── xml-js@1.6.11 extraneous
      ├── xml-name-validator@4.0.0 extraneous
      ├── xmlchars@2.2.0 extraneous
      ├── xregexp@2.0.0 extraneous
      ├── yallist@4.0.0 extraneous
      ├── yaml@ extraneous
      ├── yargs-parser@20.2.9 extraneous
      ├── yargs@7.1.2
      ├── yocto-queue@0.1.0 extraneous
      ├── zip-stream@6.0.1 extraneous
      └── zrender@ extraneous
      F 1 Antwort Letzte Antwort
      • F flommaster
        zu viele Fehler...
        Teil 1
        ├── ajv@ extraneous
        ├── colors@1.4.0
        ├── crc@ extraneous
        ├── fs-extra@7.0.1
        ├── iobroker@2.0.3
        ├── nan@ extraneous
        ├── semver@5.7.2
        ├── yargs@7.1.2
        flommaster
        Teil 2
        npm error code ELSPROBLEMS
        npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
        npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
        npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
        npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
        npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
        npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
        npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
        npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
        npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
        npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
        npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
        npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
        npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
        npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
        npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
        npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
        npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
        npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
        npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
        npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
        npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
        npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
        npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
        npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
        npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
        npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
        npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
        npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
        npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
        npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
        npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
        npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
        npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
        npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
        npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
        npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
        npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
        npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
        npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
        npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
        npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
        npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
        npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
        npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
        npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
        npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
        npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
        npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
        npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
        npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
        npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
        npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
        npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
        npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
        npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
        npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
        npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
        npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
        npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
        npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
        npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
        npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
        npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
        npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
        npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
        npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
        npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
        npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
        npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
        npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
        npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
        npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
        npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
        npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
        npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
        npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
        npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
        npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
        npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
        npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
        npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
        npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
        npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
        npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
        npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
        npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
        npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
        npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
        npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
        npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
        npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
        npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
        npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
        npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
        npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
        npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
        npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
        npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
        npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
        npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
        npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
        npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
        npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
        npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
        npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
        npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
        npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
        npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
        npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
        npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
        npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
        npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
        npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
        npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
        npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
        npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
        npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
        npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
        npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
        npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
        npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
        npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
        npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
        npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
        npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
        npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
        npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
        npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
        npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
        npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
        npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
        npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
        npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
        npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
        npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
        npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
        npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
        npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
        npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
        npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
        npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
        npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
        npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
        npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
        npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
        npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
        npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
        npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
        npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
        npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
        npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
        npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
        npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
        npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
        npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
        npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
        npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
        npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
        npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
        npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
        npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
        npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
        npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
        npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
        npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
        npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
        npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
        npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
        npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
        npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
        npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
        npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
        npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
        npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
        npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
        npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
        npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
        npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
        npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
        npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
        npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
        npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
        npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
        npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
        npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
        npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
        npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
        npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
        npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
        npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
        npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
        npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
        npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
        npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
        npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
        npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
        npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
        npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
        npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
        npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
        npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
        npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
        npm error extraneous: crc@ /opt/iobroker/node_modules/crc
        npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
        npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
        npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
        npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
        npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
        npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
        npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
        npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
        npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
        npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
        npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
        npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
        npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
        npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
        npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
        npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
        npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
        npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
        npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
        npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
        npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
        npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
        npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
        npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
        npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
        npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
        npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
        npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
        npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
        npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
        npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
        npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
        npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
        npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
        npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
        npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
        npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
        npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
        npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
        npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
        npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
        npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
        npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
        npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
        npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
        npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
        npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
        npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
        npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
        npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
        npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
        npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
        npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
        npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
        npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
        npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
        npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
        npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
        npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
        npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
        npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
        npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
        npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
        npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
        npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
        npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
        npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
        npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
        npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
        npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
        npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
        npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
        npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
        npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
        npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
        npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
        npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
        npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
        npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
        npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
        npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
        npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
        npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
        npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
        npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
        npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
        npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
        npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
        npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
        npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
        npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
        npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
        npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
        npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
        npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
        npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
        npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
        npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
        npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
        npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
        npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
        npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
        npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
        npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
        npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
        npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
        npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
        npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
        npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
        npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
        npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
        npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
        npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
        npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
        npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
        npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
        npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
        npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
        npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
        npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
        npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
        npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
        npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
        npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
        npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
        npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
        npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
        npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
        npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
        npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
        npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
        npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
        npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
        npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
        npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
        npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
        npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
        npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
        npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
        npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
        npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
        npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
        npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
        npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
        npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
        npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
        npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
        npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
        npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
        npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
        npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
        npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
        npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
        npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
        npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
        npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
        npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
        npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
        npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
        npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
        npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
        npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
        npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
        npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
        npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
        npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
        npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
        npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
        npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
        npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
        npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
        npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
        npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
        npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
        npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
        npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
        npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
        npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
        npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
        npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
        npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
        npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
        npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
        npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
        npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
        npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
        npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
        npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
        npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
        npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
        npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
        npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
        npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
        npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
        npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
        npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
        npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
        npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
        npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
        npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
        npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
        npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
        npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
        npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
        npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
        npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
        npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
        npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
        npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
        npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
        npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
        npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
        npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
        npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
        npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
        npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
        npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
        npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
        npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
        npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
        npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
        npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
        npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
        npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
        npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
        npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
        npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
        npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
        npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
        npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
        npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
        npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
        npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
        npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
        npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
        npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
        npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
        npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
        npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
        npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
        npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
        npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
        npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
        npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
        npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
        npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
        npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
        npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
        npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
        npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
        npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
        npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
        npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
        npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
        npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
        npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
        npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
        npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
        npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
        npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
        npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
        npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
        npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
        npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
        npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
        npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
        npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
        npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
        npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
        npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
        npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
        npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
        npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
        npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
        npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
        npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
        npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
        npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
        npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
        npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
        npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
        npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
        npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
        npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
        npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
        npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
        npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
        npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
        npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
        npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
        npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
        npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
        npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
        npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
        npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
        npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
        npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
        npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
        npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
        npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
        npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
        npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
        npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
        npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
        npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
        npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
        npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
        npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
        npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
        npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
        npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
        npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
        npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
        npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
        npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
        npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
        npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
        npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
        npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
        npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
        npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
        npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
        npm error extraneous: logform@ /opt/iobroker/node_modules/logform
        npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
        npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
        npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
        npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
        npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
        npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
        npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
        npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
        npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
        npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
        npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
        npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
        npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
        npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
        npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
        npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
        npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
        npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
        npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
        npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
        npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
        npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
        npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
        npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
        npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
        npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
        npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
        npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
        npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
        npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
        npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
        npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
        npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
        npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
        npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
        npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
        npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
        npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
        npm error extraneous: nan@ /opt/iobroker/node_modules/nan
        npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
        npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
        npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
        npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
        npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
        npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
        npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
        npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
        npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
        npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
        npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
        npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
        npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
        npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
        npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
        npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
        npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
        npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
        npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
        npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
        npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
        npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
        npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
        npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
        npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
        npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
        npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
        npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
        npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
        npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
        npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
        npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
        npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
        npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
        npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
        npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
        npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
        npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
        npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
        npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
        npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
        npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
        npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
        npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
        npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
        npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
        npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
        npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
        npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
        npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
        npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
        npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
        npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
        npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
        npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
        npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
        npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
        npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
        npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
        npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
        npm error extraneous: pako@ /opt/iobroker/node_modules/pako
        npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
        npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
        npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
        npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
        npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
        npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
        npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
        npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
        npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
        npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
        npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
        npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
        npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
        npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
        npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
        npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
        npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
        npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
        npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
        npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
        npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
        npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
        npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
        npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
        npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
        npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
        npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
        npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
        npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
        npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
        npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
        npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
        npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
        npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
        npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
        npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
        npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
        npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
        npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
        npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
        npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
        npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
        npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
        npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
        npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
        npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
        npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
        npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
        npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
        npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
        npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
        npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
        npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
        npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
        npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
        npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
        npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
        npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
        npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
        npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
        npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
        npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
        npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
        npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
        npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
        npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
        npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
        npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
        npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
        npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
        npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
        npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
        npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
        npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
        npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
        npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
        npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
        npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
        npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
        npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
        npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
        npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
        npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
        npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
        npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
        npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
        npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
        npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
        npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
        npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
        npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
        npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
        npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
        npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
        npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
        npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
        npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
        npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
        npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
        npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
        npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
        npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
        npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
        npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
        npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
        npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
        npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
        npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
        npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
        npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
        npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
        npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
        npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
        npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
        npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
        npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
        npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
        npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
        npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
        npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
        npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
        npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
        npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
        npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
        npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
        npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
        npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
        npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
        npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
        npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
        npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
        npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
        npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
        npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
        npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
        npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
        npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
        npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
        npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
        npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
        npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
        npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
        npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
        npm error extraneous: syno@ /opt/iobroker/node_modules/syno
        npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
        npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
        npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
        npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
        npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
        npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
        npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
        npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
        npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
        npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
        npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
        npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
        npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
        npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
        npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
        npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
        npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
        npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
        npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
        npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
        npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
        npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
        npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
        npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
        npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
        npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
        npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
        npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
        npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
        npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
        npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
        npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
        npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
        npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
        npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
        npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
        npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
        npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
        npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
        npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
        npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
        npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
        npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
        npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
        npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
        npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
        npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
        npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
        npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
        npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
        npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
        npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
        npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
        npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
        npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
        npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
        npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
        npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
        npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
        npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
        npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
        npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
        npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
        npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
        npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
        npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
        npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
        npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
        npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
        npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
        npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
        npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
        npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
        npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
        npm error extraneous: winston@ /opt/iobroker/node_modules/winston
        npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
        npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
        npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
        npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
        npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
        npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
        npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
        npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
        npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
        npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
        npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
        npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
        npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
        npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
        npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
        npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
        npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
        npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
        npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_54_40_124Z-debug-0.log
        • mcm1957M mcm1957
          Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
          npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
          Den Adapter gibts (dort) gar nicht ...
          @mcm1957 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
          War mich auch schon in's Auge gesprungen.
          F 1 Antwort Letzte Antwort
            flommaster
            @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
            Keine Ahnung.
            Soll ich das System komplett neu aufsetzen?
            • F flommaster
              Keine Ahnung.
              @flommaster
              npm prune
              npm ls
              • F flommaster
                Keine Ahnung.
                @flommaster
                Das kommt davon, wenn man da alles und jedes (Ich hab da jetzt 13 Kandidaten gezählt) über github installiert und nicht ordentlich aus einem Repo.
                Da wird wohl einer der Adapter gelöscht oder verschoben worden sein sein. Das führt dann für alle anderen Adapter zu der Meldung
                invalid "blablubb" from the root project
                  @flommaster
                  flommaster
                  Der Befehl "npm prune" liefert folgendes Ergebnis:
                  Kann ich die github Installationen löschen?
                  npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                  npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                  npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                  npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                  npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                  npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                  npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                  npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                  npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                  npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                  npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                  npm warn deprecated har-validator@5.1.5: this library is no longer supported
                  npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                  npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                  npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                  npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                  npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                  npm warn deprecated
                  npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                  npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                  npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                  npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                  npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                  npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                  npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                  npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                  npm warn deprecated gauge@3.0.2: This package is no longer supported.
                  npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm warn deprecated gauge@4.0.4: This package is no longer supported.
                  npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                  npm error git dep preparation failed
                  npm error signal SIGINT
                  npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                  npm error npm warn using --force Recommended protections disabled.
                  • F flommaster
                    npm warn deprecated
                    @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                    Vollständig.
                    Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                    F 2 Antworten Letzte Antwort
                      Vollständig.
                      flommaster
                      Gerne. Hier der komplette Auszug (Teil 1)
                      flo@ioBrokerdebian:/opt/iobroker$ npm prune
                      npm ls
                      npm warn deprecated
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
                      iobroker.inst@2.0.3 /opt/iobroker
                      ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                      ├── @alcalzone/jsonl-db@3.1.1 extraneous
                      ├── @alcalzone/pak@0.8.1 extraneous
                      ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                      ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                      ├── @azure/abort-controller@1.1.0 extraneous
                      ├── @azure/core-auth@1.7.2 extraneous
                      ├── @azure/core-client@ extraneous
                      ├── @azure/core-http-compat@ extraneous
                      ├── @azure/core-lro@ extraneous
                      ├── @azure/core-paging@1.6.2 extraneous
                      ├── @azure/core-rest-pipeline@ extraneous
                      ├── @azure/core-tracing@1.1.2 extraneous
                      ├── @azure/core-util@ extraneous
                      ├── @azure/identity@ extraneous
                      ├── @azure/keyvault-keys@ extraneous
                      ├── @azure/logger@1.1.4 extraneous
                      ├── @azure/msal-browser@ extraneous
                      ├── @azure/msal-common@ extraneous
                      ├── @azure/msal-node@1.18.4 extraneous
                      ├── @babel/code-frame@7.24.7 extraneous
                      ├── @babel/helper-validator-identifier@7.24.7 extraneous
                      ├── @babel/highlight@7.24.7 extraneous
                      ├── @babel/runtime@ extraneous
                      ├── @colors/colors@1.5.0 extraneous
                      ├── @dabh/diagnostics@2.0.3 extraneous
                      ├── @datalust/winston-seq@1.0.2 extraneous
                      ├── @gar/promisify@1.1.3 extraneous
                      ├── @googleapis/calendar@9.7.7 extraneous
                      ├── @googleapis/drive@5.1.0 extraneous
                      ├── @googleapis/oauth2@1.0.7 extraneous
                      ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                      ├── @iobroker/db-base@ extraneous
                      ├── @iobroker/db-objects-file@ extraneous
                      ├── @iobroker/db-objects-jsonl@ extraneous
                      ├── @iobroker/db-objects-redis@ extraneous
                      ├── @iobroker/db-states-file@ extraneous
                      ├── @iobroker/db-states-jsonl@ extraneous
                      ├── @iobroker/db-states-redis@ extraneous
                      ├── @iobroker/js-controller-adapter@ extraneous
                      ├── @iobroker/js-controller-cli@ extraneous
                      ├── @iobroker/js-controller-common-db@ extraneous
                      ├── @iobroker/js-controller-common@ extraneous
                      ├── @iobroker/plugin-base@1.2.1 extraneous
                      ├── @iobroker/plugin-sentry@1.2.1 extraneous
                      ├── @iobroker/socket-classes@1.5.6 extraneous
                      ├── @iobroker/webserver@1.0.3 extraneous
                      ├── @isaacs/cliui@8.0.2 extraneous
                      ├── @js-joda/core@ extraneous
                      ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                      ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                      ├── @nodelib/fs.scandir@2.1.5 extraneous
                      ├── @nodelib/fs.stat@2.0.5 extraneous
                      ├── @nodelib/fs.walk@1.2.8 extraneous
                      ├── @npmcli/fs@2.1.2 extraneous
                      ├── @npmcli/move-file@2.0.1 extraneous
                      ├── @pkgjs/parseargs@0.11.0 extraneous
                      ├── @protobufjs/aspromise@1.1.2 extraneous
                      ├── @protobufjs/base64@1.1.2 extraneous
                      ├── @protobufjs/codegen@2.0.4 extraneous
                      ├── @protobufjs/eventemitter@1.1.0 extraneous
                      ├── @protobufjs/fetch@1.1.0 extraneous
                      ├── @protobufjs/float@1.0.2 extraneous
                      ├── @protobufjs/inquire@1.1.0 extraneous
                      ├── @protobufjs/path@1.1.2 extraneous
                      ├── @protobufjs/pool@1.1.0 extraneous
                      ├── @protobufjs/utf8@1.1.0 extraneous
                      ├── @quasar/extras@ extraneous
                      ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                      ├── @sentry-internal/tracing@ extraneous
                      ├── @sentry/core@5.30.0 extraneous
                      ├── @sentry/hub@5.30.0 extraneous
                      ├── @sentry/minimal@5.30.0 extraneous
                      ├── @sentry/node@ extraneous
                      ├── @sentry/tracing@ extraneous
                      ├── @sentry/types@ extraneous
                      ├── @sentry/utils@ extraneous
                      ├── @sindresorhus/is@4.6.0 extraneous
                      ├── @socket.io/component-emitter@3.1.2 extraneous
                      ├── @szmarczak/http-timer@4.0.6 extraneous
                      ├── @tediousjs/connection-string@0.5.0 extraneous
                      ├── @tootallnate/once@2.0.0 extraneous
                      ├── @types/bl@5.1.0 extraneous
                      ├── @types/cacheable-request@6.0.3 extraneous
                      ├── @types/caseless@0.12.5 extraneous
                      ├── @types/cookie@0.4.1 extraneous
                      ├── @types/cors@2.8.17 extraneous
                      ├── @types/geojson@7946.0.14 extraneous
                      ├── @types/http-cache-semantics@4.0.4 extraneous
                      ├── @types/keyv@3.1.4 extraneous
                      ├── @types/leaflet@1.9.12 extraneous
                      ├── @types/minimist@1.2.5 extraneous
                      ├── @types/node-cron@2.0.8 extraneous
                      ├── @types/node@ extraneous
                      ├── @types/normalize-package-data@2.4.4 extraneous
                      ├── @types/parse-json@4.0.2 extraneous
                      ├── @types/readable-stream@4.0.15 extraneous
                      ├── @types/request@2.48.12 extraneous
                      ├── @types/responselike@1.0.3 extraneous
                      ├── @types/tough-cookie@4.0.5 extraneous
                      ├── @types/triple-beam@1.3.5 extraneous
                      ├── @types/tz-offset@0.0.3 extraneous
                      ├── @types/ws@8.5.12 extraneous
                      ├── abab@2.0.6 extraneous
                      ├── abbrev@1.1.1 extraneous
                      ├── abort-controller@3.0.0 extraneous
                      ├── agentkeepalive@4.5.0 extraneous
                      ├── aggregate-error@3.1.0 extraneous
                      ├── ajv@ extraneous
                      ├── ansi-align@3.0.1 extraneous
                      ├── ansi-colors@4.1.3 extraneous
                      ├── ansi-escapes@4.3.2 extraneous
                      ├── ansi-regex@5.0.1 extraneous
                      ├── ansi-styles@4.3.0 extraneous
                      ├── any-observable@0.5.1 extraneous
                      ├── anymatch@3.1.3 extraneous
                      ├── aproba@2.0.0 extraneous
                      ├── archiver-utils@5.0.2 extraneous
                      ├── archiver@7.0.1 extraneous
                      ├── are-we-there-yet@2.0.0 extraneous
                      ├── arg@4.1.0 extraneous
                      ├── argparse@1.0.10 extraneous
                      ├── array-buffer-byte-length@1.0.1 extraneous
                      ├── array-flatten@1.1.1 extraneous
                      ├── array-union@2.1.0 extraneous
                      ├── arraybuffer.prototype.slice@1.0.3 extraneous
                      ├── arrify@2.0.1 extraneous
                      ├── asn1@0.2.6 extraneous
                      ├── async-exit-hook@2.0.1 extraneous
                      ├── authenticate-pam@1.0.5 extraneous
                      ├── available-typed-arrays@1.0.7 extraneous
                      ├── aws-crt@ extraneous
                      ├── b4a@1.6.6 extraneous
                      ├── balanced-match@1.0.2 extraneous
                      ├── bare-events@2.4.2 extraneous
                      ├── base-64@1.0.0 extraneous
                      ├── base64-js@1.5.1 extraneous
                      ├── bcrypt-pbkdf@1.0.2 extraneous
                      ├── binary-extensions@2.3.0 extraneous
                      ├── bindings@1.5.0 extraneous
                      ├── bl@6.0.14 extraneous
                      ├── bluebird@3.7.2 extraneous
                      ├── body-parser@1.20.2 extraneous
                      ├── bottleneck@2.19.5 extraneous
                      ├── boxen@5.1.2 extraneous
                      ├── brace-expansion@2.0.1 extraneous
                      ├── braces@3.0.3 extraneous
                      ├── buffer-crc32@1.0.0 extraneous
                      ├── buffer-equal-constant-time@1.0.1 extraneous
                      ├── buffer-shims@1.0.0 extraneous
                      ├── buffer@6.0.3 extraneous
                      ├── buildcheck@0.0.6 extraneous
                      ├── builtins@1.0.3 extraneous
                      ├── busboy@1.6.0 extraneous
                      ├── byte-length@1.0.2 extraneous
                      ├── bytes@3.1.2 extraneous
                      ├── cacache@16.1.3 extraneous
                      ├── cacheable-lookup@5.0.4 extraneous
                      ├── cacheable-request@7.0.4 extraneous
                      ├── callsites@3.1.0 extraneous
                      ├── camelcase-keys@6.2.2 extraneous
                      ├── camelcase@5.3.1 extraneous
                      ├── capitalize@2.0.4 extraneous
                      ├── chalk@4.1.2 extraneous
                      ├── chardet@0.7.0 extraneous
                      ├── charenc@0.0.2 extraneous
                      ├── chokidar@3.6.0 extraneous
                      ├── chownr@2.0.0 extraneous
                      ├── ci-info@3.9.0 extraneous
                      ├── clean-stack@2.2.0 extraneous
                      ├── cli-boxes@2.2.1 extraneous
                      ├── cli-cursor@3.1.0 extraneous
                      ├── cli-truncate@0.2.1 extraneous
                      ├── cli-width@3.0.0 extraneous
                      ├── clone-response@1.0.3 extraneous
                      ├── cloneextend@0.0.3 extraneous
                      ├── cluster-key-slot@1.1.2 extraneous
                      ├── coap-packet@1.1.1 extraneous
                      ├── coffeescript@1.12.7 extraneous
                      ├── color-convert@2.0.1 extraneous
                      ├── color-name@1.1.4 extraneous
                      ├── color-string@1.9.1 extraneous
                      ├── color-support@1.1.3 extraneous
                      ├── color@3.2.1 extraneous
                      ├── colors@1.4.0
                      ├── colorspace@1.1.4 extraneous
                      ├── commander@9.5.0 extraneous
                      ├── commist@3.2.0 extraneous
                      ├── compress-commons@6.0.2 extraneous
                      ├── compress-json@2.1.2 extraneous
                      ├── compressible@2.0.18 extraneous
                      ├── compression@1.7.4 extraneous
                      ├── concat-map@0.0.1 extraneous
                      ├── configstore@5.0.1 extraneous
                      ├── connect-flash@0.1.1 extraneous
                      ├── connect@3.7.0 extraneous
                      ├── console-control-strings@1.1.0 extraneous
                      ├── content-disposition@0.5.4 extraneous
                      ├── content-type@1.0.5 extraneous
                      ├── core-js@ extraneous
                      ├── cors@2.8.5 extraneous
                      ├── cosmiconfig@7.1.0 extraneous
                      ├── cpu-features@ extraneous
                      ├── crc-32@1.2.2 extraneous
                      ├── crc@ extraneous
                      ├── crc32-stream@6.0.0 extraneous
                      ├── cross-fetch@4.0.0 extraneous
                      ├── crypt@0.0.2 extraneous
                      ├── crypto-js@ extraneous
                      ├── crypto-random-string@2.0.0 extraneous
                      ├── cssstyle@ extraneous
                      ├── cycle@1.0.3 extraneous
                      ├── dashdash@1.14.1 extraneous
                      ├── data-urls@4.0.0 extraneous
                      ├── data-view-buffer@1.0.1 extraneous
                      ├── data-view-byte-length@1.0.1 extraneous
                      ├── data-view-byte-offset@1.0.0 extraneous
                      ├── date-and-time@ extraneous
                      ├── date-fns@1.30.1 extraneous
                      ├── dateformat@4.6.3 extraneous
                      ├── dayjs@ extraneous
                      ├── decache@4.6.2 extraneous
                      ├── decamelize-keys@1.1.1 extraneous
                      ├── decimal.js@10.4.3 extraneous
                      ├── decompress-response@6.0.0 extraneous
                      ├── deep-clone@3.0.3 extraneous
                      ├── deep-extend@0.6.0 extraneous
                      ├── deep-is@0.1.4 extraneous
                      ├── defer-to-connect@2.0.1 extraneous
                      ├── define-lazy-prop@2.0.0 extraneous
                      ├── del@6.1.1 extraneous
                      ├── delegates@1.0.0 extraneous
                      ├── denque@1.5.1 extraneous
                      ├── destroy@1.2.0 extraneous
                      ├── detect-libc@2.0.3 extraneous
                      ├── diacritics@1.3.0 extraneous
                      ├── digest-header@1.1.0 extraneous
                      ├── dir-glob@3.0.1 extraneous
                      ├── diskusage@1.2.0 extraneous
                      ├── domexception@4.0.0 extraneous
                      ├── dot-prop@6.0.1 extraneous
                      ├── draftlog@1.0.13 extraneous
                      ├── dropbox-v2-api@ extraneous
                      ├── duplexer@0.1.2 extraneous
                      ├── duplexer3@0.1.5 extraneous
                      ├── duplexify@3.7.1 extraneous
                      ├── eastasianwidth@0.2.0 extraneous
                      ├── ecc-jsbn@0.1.2 extraneous
                      ├── ecdsa-sig-formatter@1.0.11 extraneous
                      ├── echarts@ extraneous
                      ├── ee-first@1.1.1 extraneous
                      ├── elegant-spinner@1.0.1 extraneous
                      ├── emoji-regex@9.2.2 extraneous
                      ├── enabled@2.0.0 extraneous
                      ├── encodeurl@1.0.2 extraneous
                      ├── encoding@0.1.13 extraneous
                      ├── end-of-stream@1.4.4 extraneous
                      ├── entities@4.5.0 extraneous
                      ├── err-code@2.0.3 extraneous
                      ├── es-abstract@ extraneous
                      ├── es-aggregate-error@1.0.13 extraneous
                      ├── es-object-atoms@1.0.0 extraneous
                      ├── es-set-tostringtag@2.0.3 extraneous
                      ├── es-to-primitive@1.2.1 extraneous
                      ├── es6-promise@4.2.8 extraneous
                      ├── es6-promisify@5.0.0 extraneous
                      ├── esbuild@0.11.23 extraneous
                      ├── escalade@3.1.2 extraneous
                      ├── escape-goat@3.0.0 extraneous
                      ├── escape-html@1.0.3 extraneous
                      ├── escape-string-regexp@4.0.0 extraneous
                      ├── escodegen@1.14.3 extraneous
                      ├── esprima@1.2.2 extraneous
                      ├── estraverse@4.3.0 extraneous
                      ├── esutils@2.0.3 extraneous
                      ├── etag@1.8.1 extraneous
                      ├── event-stream@4.0.1 extraneous
                      ├── event-target-shim@5.0.1 extraneous
                      ├── eventemitter2@6.4.9 extraneous
                      ├── events@3.3.0 extraneous
                      ├── execa@5.1.1 extraneous
                      ├── expand-template@2.0.3 extraneous
                      ├── express-fileupload@1.5.1 extraneous
                      ├── express@4.19.2 extraneous
                      ├── external-editor@3.1.0 extraneous
                      ├── fast-deep-equal@3.1.3 extraneous
                      ├── fast-fifo@1.3.2 extraneous
                      ├── fast-glob@ extraneous
                      ├── fast-json-stable-stringify@2.1.0 extraneous
                      ├── fast-levenshtein@2.0.6 extraneous
                      ├── fast-text-encoding@1.0.6 extraneous
                      ├── fast-unique-numbers@ extraneous
                      ├── fast-uri@3.0.1 extraneous
                      ├── fast-xml-parser@ extraneous
                      ├── fastq@1.17.1 extraneous
                      ├── fastseries@2.0.0 extraneous
                      ├── fecha@4.2.3 extraneous
                      ├── figures@3.2.0 extraneous
                      ├── file-stream-rotator@0.6.1 extraneous
                      ├── file-type@10.11.0 extraneous
                      ├── file-uri-to-path@1.0.0 extraneous
                      ├── fill-range@7.1.1 extraneous
                      ├── finalhandler@1.2.0 extraneous
                      ├── find-up@5.0.0 extraneous
                      ├── fn.name@1.1.0 extraneous
                      ├── for-each@0.3.3 extraneous
                      ├── foreground-child@3.3.0 extraneous
                      ├── form-data-encoder@2.1.4 extraneous
                      ├── form-data@4.0.0 extraneous
                      ├── forwarded@0.2.0 extraneous
                      ├── fresh@0.5.2 extraneous
                      ├── from@0.1.7 extraneous
                      ├── fs-constants@1.0.0 extraneous
                      ├── fs-extra@7.0.1
                      ├── fs-minipass@2.1.0 extraneous
                      ├── fs.realpath@1.0.0 extraneous
                      ├── fsevents@ extraneous
                      ├── ftp@0.3.10 extraneous
                      ├── function.prototype.name@1.1.6 extraneous
                      ├── functions-have-names@1.2.3 extraneous
                      ├── futoin-hkdf@1.4.3 extraneous
                      ├── gauge@3.0.2 extraneous
                      ├── gaxios@5.1.3 extraneous
                      ├── gcp-metadata@5.3.0 extraneous
                      ├── generate-function@2.3.1 extraneous
                      ├── get-ssl-certificate@2.3.3 extraneous
                      ├── get-stream@5.2.0 extraneous
                      ├── get-symbol-description@1.0.2 extraneous
                      ├── getpass@0.1.7 extraneous
                      ├── github-from-package@0.0.0 extraneous
                      ├── github-url-from-git@1.5.0 extraneous
                      ├── glob-parent@5.1.2 extraneous
                      ├── glob@10.4.5 extraneous
                      ├── global-dirs@2.1.0 extraneous
                      ├── globalthis@1.0.4 extraneous
                      ├── globby@11.1.0 extraneous
                      ├── glossy@0.1.7 extraneous
                      ├── google-auth-library@ extraneous
                      ├── google-p12-pem@4.0.1 extraneous
                      ├── googleapis-common@6.0.4 extraneous
                      ├── googleapis@ extraneous
                      ├── gtoken@6.1.2 extraneous
                      ├── hard-rejection@2.1.0 extraneous
                      ├── has-ansi@2.0.0 extraneous
                      ├── has-bigints@1.0.2 extraneous
                      ├── has-flag@4.0.0 extraneous
                      ├── has-tostringtag@1.0.2 extraneous
                      ├── has-unicode@2.0.1 extraneous
                      ├── has-yarn@2.1.0 extraneous
                      ├── he@1.2.0 extraneous
                      ├── help-me@5.0.0 extraneous
                      ├── homebridge-plugin-wrapper@ extraneous
                      ├── hosted-git-info@3.0.8 extraneous
                      ├── hot-patcher@1.0.0 extraneous
                      ├── html-encoding-sniffer@3.0.0 extraneous
                      ├── http-cache-semantics@4.1.1 extraneous
                      ├── http-errors@2.0.0 extraneous
                      ├── http-proxy-agent@5.0.0 extraneous
                      ├── http2-wrapper@1.0.3 extraneous
                      ├── https@1.0.0 extraneous
                      ├── humanize-ms@1.2.1 extraneous
                      ├── ical.js@ extraneous
                      ├── iconv-lite@0.4.24 extraneous
                      ├── ieee754@1.2.1 extraneous
                      ├── ignore-walk@3.0.4 extraneous
                      ├── ignore@5.3.2 extraneous
                      ├── image-type@4.1.0 extraneous
                      ├── immediate@3.0.6 extraneous
                      ├── import-fresh@3.3.0 extraneous
                      ├── import-lazy@2.1.0 extraneous
                      ├── import-local@3.2.0 extraneous
                      ├── imurmurhash@0.1.4 extraneous
                      ├── indent-string@3.2.0 extraneous
                      ├── infer-owner@1.0.4 extraneous
                      ├── inflight@1.0.6 extraneous
                      ├── ini@1.3.7 extraneous
                      ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                      ├── inquirer@7.3.3 extraneous
                      ├── int64-buffer@1.0.1 extraneous
                      ├── internal-slot@1.0.7 extraneous
                      ├── iobroker-adapter-helpers@0.0.8 extraneous
                      ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                      ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                      ├── iobroker.bmw@2.5.7
                      ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                      ├── iobroker.cloud@4.4.1
                      ├── iobroker.coronavirus-statistics@0.8.7
                      ├── iobroker.daswetter@3.1.10
                      ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                      ├── iobroker.dwd@2.8.5
                      ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                      ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                      ├── iobroker.eusec@1.1.2
                      ├── iobroker.flot@ invalid: "1.12.0" from the root project
                      ├── iobroker.fritzbox@0.2.1
                      ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                      ├── iobroker.fullybrowser@2.1.2
                      ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                      ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                      ├── iobroker.harmony@1.2.2
                      ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                      ├── iobroker.history@2.2.6
                      ├── iobroker.hm-rega@3.0.47
                      ├── iobroker.hm-rpc@1.15.19
                      ├── iobroker.hue@3.9.5
                      ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                      ├── iobroker.icons-icons8@0.0.1
                      ├── iobroker.icons-material-png@0.1.0
                      ├── iobroker.icons-mfd-png@1.1.0
                      ├── iobroker.icons-ultimate-png@1.0.1
                      ├── iobroker.info@ invalid: "1.9.26" from the root project
                      ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                      ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                      ├── iobroker.logparser@2.2.0
                      ├── iobroker.material@ invalid: "1.3.1" from the root project
                      ├── iobroker.meross@1.15.1
                      ├── iobroker.mihome-vacuum@3.11.0
                      ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                      ├── iobroker.milight@0.3.6
                      ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                      ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                      ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                      ├── iobroker.nina@ invalid: "0.0.25" from the root project
                      ├── iobroker.pollenflug@1.0.6
                      ├── iobroker.pushover@3.0.3
                      ├── iobroker.pushsafer@1.0.3
                      ├── iobroker.pvforecast@2.7.1
                      ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                      ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                      ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                      ├── iobroker.simple-api@2.7.2
                      ├── iobroker.smartmeter@3.3.4
                      ├── iobroker.socketio@6.5.2
                      ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                      ├── iobroker.sql@2.2.0
                      ├── iobroker.statistics@2.3.0
                      ├── iobroker.sunnyportal@0.1.5
                      ├── iobroker.synology@ invalid: "2.1.13" from the root project
                      ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                      ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                      ├── iobroker.tr-064@4.2.18
                      ├── iobroker.trashschedule@2.2.0
                      ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                      ├── iobroker.upnp@1.0.21
                      ├── iobroker.valloxmv@1.2.0
                      ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                      ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                      ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                      ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                      ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                      ├── iobroker.vis-fancyswitch@1.1.0
                      ├── iobroker.vis-google-fonts@1.0.4
                      ├── iobroker.vis-history@1.0.0
                      ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                      ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                      ├── iobroker.vis-jqui-mfd@1.0.12
                      ├── iobroker.vis-justgage@1.0.2
                      ├── iobroker.vis-map@1.0.4
                      ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                      ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                      ├── iobroker.vis-rgraph@0.0.2
                      ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                      ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                      ├── iobroker.vis@ invalid: "1.4.16" from the root project
                      ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                      ├── iobroker.weatherunderground@3.4.2
                      ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                      ├── iobroker.web@ invalid: "6.1.0" from the root project
                      ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                      ├── iobroker.wiffi-wz@2.2.1
                      ├── iobroker.windows-control@0.1.5
                      ├── iobroker.worx@2.3.2
                      ├── iobroker.ws@2.5.3
                      ├── iobroker@2.0.3
                      ├── ioredis@ extraneous
                      ├── ip-address@9.0.5 extraneous
                      ├── ip-regex@4.3.0 extraneous
                      ├── ipaddr.js@2.2.0 extraneous
                      ├── is-array-buffer@3.0.4 extraneous
                      ├── is-bigint@1.0.4 extraneous
                      ├── is-binary-path@2.1.0 extraneous
                      ├── is-boolean-object@1.1.2 extraneous
                      ├── is-buffer@1.1.6 extraneous
                      ├── is-callable@1.2.7 extraneous
                      ├── is-ci@2.0.0 extraneous
                      ├── is-core-module@2.15.0 extraneous
                      ├── is-data-view@1.0.1 extraneous
                      ├── is-date-object@1.0.5 extraneous
                      ├── is-docker@2.2.1 extraneous
                      ├── is-empty-object@1.1.1 extraneous
                      ├── is-extglob@2.1.1 extraneous
                      ├── is-fullwidth-code-point@3.0.0 extraneous
                      ├── is-glob@4.0.3 extraneous
                      ├── is-installed-globally@0.3.2 extraneous
                      ├── is-interactive@1.0.0 extraneous
                      ├── is-lambda@1.0.1 extraneous
                      ├── is-negative-zero@2.0.3 extraneous
                      ├── is-npm@5.0.0 extraneous
                      ├── is-number-object@1.0.7 extraneous
                      ├── is-number@7.0.0 extraneous
                      ├── is-obj@2.0.0 extraneous
                      ├── is-observable@1.1.0 extraneous
                      ├── is-path-cwd@2.2.0 extraneous
                      ├── is-path-inside@3.0.3 extraneous
                      ├── is-plain-obj@1.1.0 extraneous
                      ├── is-potential-custom-element-name@1.0.1 extraneous
                      ├── is-promise@2.2.2 extraneous
                      ├── is-property@1.0.2 extraneous
                      ├── is-regex@1.1.4 extraneous
                      ├── is-scoped@2.1.0 extraneous
                      ├── is-shared-array-buffer@1.0.3 extraneous
                      ├── is-string@1.0.7 extraneous
                      ├── is-symbol@1.0.4 extraneous
                      ├── is-typed-array@1.1.13 extraneous
                      ├── is-unicode-supported@0.1.0 extraneous
                      ├── is-url-superb@4.0.0 extraneous
                      ├── is-url@1.2.4 extraneous
                      ├── is-weakref@1.0.2 extraneous
                      ├── is-wsl@2.2.0 extraneous
                      ├── is-yarn-global@0.3.0 extraneous
                      ├── is@3.3.0 extraneous
                      ├── is2@2.0.9 extraneous
                      ├── isomorphic-ws@4.0.1 extraneous
                      ├── issue-regex@3.1.0 extraneous
                      ├── jackspeak@3.4.3 extraneous
                      ├── js-md4@0.3.2 extraneous
                      ├── js-sdsl@4.3.0 extraneous
                      ├── js-tokens@4.0.0 extraneous
                      ├── js-yaml@ extraneous
                      ├── jsbi@4.3.0 extraneous
                      ├── jsbn@1.1.0 extraneous
                      ├── jsdom@ extraneous
                      ├── jshashes@1.0.8 extraneous
                      ├── json-buffer@3.0.1 extraneous
                      ├── json-logic-js@2.0.5 extraneous
                      ├── json-parse-even-better-errors@2.3.1 extraneous
                      ├── json-schema-traverse@1.0.0 extraneous
                      ├── json5@2.2.3 extraneous
                      ├── jsonata@ extraneous
                      ├── jsonc-parser@3.3.1 extraneous
                      ├── jsonwebtoken@9.0.2 extraneous
                      ├── jszip@ extraneous
                      ├── jwa@2.0.0 extraneous
                      ├── jws@4.0.0 extraneous
                      ├── keyv@4.5.4 extraneous
                      ├── kind-of@6.0.3 extraneous
                      ├── kuler@2.0.0 extraneous
                      ├── later@1.2.0 extraneous
                      ├── latest-version@5.1.0 extraneous
                      ├── layerr@0.1.2 extraneous
                      ├── lazystream@1.0.1 extraneous
                      ├── leven@2.1.0 extraneous
                      ├── levn@0.3.0 extraneous
                      ├── lie@3.3.0 extraneous
                      ├── lines-and-columns@1.2.4 extraneous
                      ├── listr-input@0.2.1 extraneous
                      ├── listr-silent-renderer@1.1.1 extraneous
                      ├── listr-update-renderer@0.5.0 extraneous
                      ├── listr-verbose-renderer@0.5.0 extraneous
                      ├── listr@0.14.3 extraneous
                      ├── loadavg-windows@1.1.1 extraneous
                      ├── locate-path@6.0.0 extraneous
                      ├── lodash.defaults@4.2.0 extraneous
                      ├── lodash.flatten@4.4.0 extraneous
                      ├── lodash.includes@4.3.0 extraneous
                      ├── lodash.isarguments@3.1.0 extraneous
                      ├── lodash.isboolean@3.0.3 extraneous
                      ├── lodash.isequal@4.5.0 extraneous
                      ├── lodash.isinteger@4.0.4 extraneous
                      ├── lodash.isnumber@3.0.3 extraneous
                      ├── lodash.isplainobject@4.0.6 extraneous
                      ├── lodash.isstring@4.0.1 extraneous
                      ├── lodash.once@4.1.1 extraneous
                      ├── lodash.zip@4.2.0 extraneous
                      ├── log-symbols@4.1.0 extraneous
                      ├── log-update@2.3.0 extraneous
                      ├── logform@ extraneous
                      ├── long@5.2.3 extraneous
                      ├── lowercase-keys@2.0.0 extraneous
                      ├── lru_map@0.3.3 extraneous
                      ├── lru-cache@6.0.0 extraneous
                      ├── make-dir@3.1.0 extraneous
                      ├── make-fetch-happen@10.2.1 extraneous
                      ├── map-age-cleaner@0.1.3 extraneous
                      ├── map-obj@4.3.0 extraneous
                      ├── map-stream@0.0.7 extraneous
                      ├── md5@2.3.0 extraneous
                      ├── media-typer@0.3.0 extraneous
                      ├── meow@8.1.2 extraneous
                      ├── merge-descriptors@1.0.1 extraneous
                      ├── merge2@1.4.1 extraneous
                      ├── methods@1.1.2 extraneous
                      ├── micro@9.4.1 extraneous
                      ├── micromatch@4.0.7 extraneous
                      ├── mime-db@1.53.0 extraneous
                      ├── mimic-response@1.0.1 extraneous
                      ├── min-indent@1.0.1 extraneous
                      ├── minimatch@9.0.5 extraneous
                      ├── minimist-options@4.1.0 extraneous
                      ├── minipass-collect@1.0.2 extraneous
                      ├── minipass-fetch@2.1.2 extraneous
                      ├── minipass-flush@1.0.5 extraneous
                      ├── minipass-pipeline@1.2.4 extraneous
                      ├── minipass-sized@1.0.3 extraneous
                      ├── minipass@7.1.2 extraneous
                      ├── minizlib@2.1.2 extraneous
                      ├── mkdirp-classic@0.5.3 extraneous
                      ├── mkdirp@1.0.4 extraneous
                      ├── mock-require@3.0.3 extraneous
                      ├── moment-duration-format@2.3.2 extraneous
                      ├── mqtt-connection@4.1.0 extraneous
                      ├── mqtt-packet@9.0.0 extraneous
                      ├── mqtt@ extraneous
                      ├── mute-stream@0.0.8 extraneous
                      ├── named-placeholders@1.1.3 extraneous
                      ├── nan@ extraneous
                      ├── nanoid@3.3.7 extraneous
                      ├── napi-build-utils@1.0.2 extraneous
                      ├── native-duplexpair@1.0.0 extraneous
                      ├── nconf@0.10.0 extraneous
                      ├── nested-property@4.0.0 extraneous
                      ├── netmask@2.0.2 extraneous
                      ├── new-github-release-url@1.0.0 extraneous
                      ├── node-abi@3.65.0 extraneous
                      ├── node-abort-controller@3.1.1 extraneous
                      ├── node-cron@2.0.3 extraneous
                      ├── node-fetch@2.7.0 extraneous
                      ├── node-forge@ extraneous
                      ├── node-gyp@ extraneous
                      ├── node-ical@0.16.1 extraneous
                      ├── node-inspect@2.0.0 extraneous
                      ├── node-libcurl@3.0.0 extraneous
                      ├── node-mndp@0.0.3 extraneous
                      ├── node-persist@0.0.11 extraneous
                      ├── node-rsa@1.1.1 extraneous
                      ├── node-unifi@2.5.1 extraneous
                      ├── node-wol@0.1.1 extraneous
                      ├── node.extend@2.0.3 extraneous
                      ├── nopt@5.0.0 extraneous
                      ├── normalize-package-data@3.0.3 extraneous
                      ├── normalize-path@3.0.0 extraneous
                      ├── normalize-url@6.1.0 extraneous
                      ├── np@7.7.0 extraneous
                      ├── npm-name@6.0.1 extraneous
                      ├── npmlog@5.0.1 extraneous
                      ├── number-allocator@1.0.14 extraneous
                      ├── nwsapi@2.2.12 extraneous
                      ├── object-assign@4.1.1 extraneous
                      ├── object-hash@3.0.0 extraneous
                      ├── on-finished@2.4.1 extraneous
                      ├── once@1.4.0 extraneous
                      ├── one-time@1.0.0 extraneous
                      ├── onedrive-api@1.1.1 extraneous
                      ├── open@7.4.2 extraneous
                      ├── opencollective-postinstall@2.0.3 extraneous
                      ├── optionator@0.8.3 extraneous
                      ├── org-regex@1.0.0 extraneous
                      ├── os-tmpdir@1.0.2 extraneous
                      ├── ospath@1.2.2 extraneous
                      ├── osx-temperature-sensor@ extraneous
                      ├── otplib@11.0.1 extraneous
                      ├── ow@0.21.0 extraneous
                      ├── p-cancelable@2.1.1 extraneous
                      ├── p-defer@1.0.0 extraneous
                      ├── p-event@4.2.0 extraneous
                      ├── p-finally@1.0.0 extraneous
                      ├── p-limit@2.3.0 extraneous
                      ├── p-locate@5.0.0 extraneous
                      ├── p-map@2.1.0 extraneous
                      ├── p-memoize@4.0.4 extraneous
                      ├── p-reflect@2.1.0 extraneous
                      ├── p-settle@4.1.1 extraneous
                      ├── p-throttle@4.1.1 extraneous
                      ├── p-timeout@4.1.0 extraneous
                      ├── p-try@2.2.0 extraneous
                      ├── package-json-from-dist@1.0.0 extraneous
                      ├── package-json@6.5.0 extraneous
                      ├── pako@ extraneous
                      ├── parent-module@1.0.1 extraneous
                      ├── parse-json@5.2.0 extraneous
                      ├── parse5@ extraneous
                      ├── passport-local@1.0.0 extraneous
                      ├── passport@0.7.0 extraneous
                      ├── path-exists@4.0.0 extraneous
                      ├── path-is-absolute@1.0.1 extraneous
                      ├── path-parse@1.0.7 extraneous
                      ├── path-posix@1.0.0 extraneous
                      ├── path-scurry@1.11.1 extraneous
                      ├── path-to-regexp@0.1.7 extraneous
                      ├── path-type@4.0.0 extraneous
                      ├── pause-stream@0.0.11 extraneous
                      ├── picomatch@2.3.1 extraneous
                      ├── pidtree@0.6.0 extraneous
                      ├── pidusage@3.0.2 extraneous
                      ├── ping@0.4.4 extraneous
                      ├── pkg-dir@5.0.0 extraneous
                      ├── pluralize@8.0.0 extraneous
                      ├── possible-typed-array-names@1.0.0 extraneous
                      ├── prebuild-install@7.1.2 extraneous
                      ├── prelude-ls@1.1.2 extraneous
                      ├── prepend-http@2.0.0 extraneous
                      ├── process-nextick-args@2.0.1 extraneous
                      ├── process@0.11.10 extraneous
                      ├── promise-inflight@1.0.1 extraneous
                      ├── promise-object@0.1.7 extraneous
                      ├── promise-retry@2.0.1 extraneous
                      ├── promise-retryer@0.0.1 extraneous
                      ├── promisify-child-process@4.1.2 extraneous
                      ├── prompt@1.3.0 extraneous
                      ├── protobufjs@ extraneous
                      ├── proxy-addr@2.0.7 extraneous
                      ├── proxy-from-env@1.1.0 extraneous
                      ├── pump@3.0.0 extraneous
                      ├── pupa@2.1.1 extraneous
                      ├── q@1.1.2 extraneous
                      ├── quasar@ extraneous
                      ├── queue-microtask@1.2.3 extraneous
                      ├── queue-tick@1.0.1 extraneous
                      ├── quick-lru@5.1.1 extraneous
                      ├── range-parser@1.2.1 extraneous
                      ├── raw-body@2.5.2 extraneous
                      ├── rc@1.2.8 extraneous
                      ├── read-pkg-up@7.0.1 extraneous
                      ├── read-pkg@5.2.0 extraneous
                      ├── read@1.0.7 extraneous
                      ├── readable-stream@ extraneous
                      ├── readdir-glob@1.1.3 extraneous
                      ├── readdirp@3.6.0 extraneous
                      ├── readline-sync@1.4.10 extraneous
                      ├── readline@1.3.0 extraneous
                      ├── redent@3.0.0 extraneous
                      ├── redis-commands@1.7.0 extraneous
                      ├── redis-errors@1.2.0 extraneous
                      ├── redis-parser@3.0.0 extraneous
                      ├── regenerator-runtime@0.14.1 extraneous
                      ├── regex-escape@3.4.10 extraneous
                      ├── regexp.prototype.flags@1.5.2 extraneous
                      ├── registry-auth-token@4.2.2 extraneous
                      ├── registry-url@5.1.0 extraneous
                      ├── reinterval@1.1.0 extraneous
                      ├── remove-trailing-separator@1.1.0 extraneous
                      ├── require-from-string@2.0.2 extraneous
                      ├── resolve-alpn@1.2.1 extraneous
                      ├── resolve-cwd@3.0.0 extraneous
                      ├── resolve-from@4.0.0 extraneous
                      ├── respjs@4.2.0 extraneous
                      ├── responselike@2.0.1 extraneous
                      ├── restore-cursor@3.1.0 extraneous
                      ├── retry-axios@2.6.0 extraneous
                      ├── retry@0.12.0 extraneous
                      ├── reusify@1.0.4 extraneous
                      ├── revalidator@0.1.8 extraneous
                      ├── rfdc@1.4.1 extraneous
                      ├── rimraf@3.0.2 extraneous
                      ├── rrule@2.8.1 extraneous
                      ├── rrweb-cssom@0.6.0 extraneous
                      ├── run-async@2.4.1 extraneous
                      ├── run-parallel@1.2.0 extraneous
                      ├── rxjs@ extraneous
                      ├── safe-array-concat@1.1.2 extraneous
                      ├── safe-regex-test@1.0.3 extraneous
                      ├── safe-stable-stringify@2.4.3 extraneous
                      ├── safer-buffer@2.1.2 extraneous
                      ├── saxes@6.0.0 extraneous
                      ├── scoped-regex@2.1.0 extraneous
                      ├── secure-keys@1.0.0 extraneous
                      ├── semver-diff@3.1.1 extraneous
                      ├── semver@5.7.2
                      ├── send@0.18.0 extraneous
                      ├── seq-logging@1.1.2 extraneous
                      ├── seq-queue@0.0.5 extraneous
                      ├── serve-static@1.15.0 extraneous
                      ├── set-function-name@2.0.2 extraneous
                      ├── setimmediate@1.0.5 extraneous
                      ├── setprototypeof@1.2.0 extraneous
                      ├── signal-exit@4.1.0 extraneous
                      ├── simple-concat@1.0.1 extraneous
                      ├── simple-get@3.1.1 extraneous
                      ├── simple-ssh@1.1.1 extraneous
                      ├── simple-swizzle@0.2.2 extraneous
                      ├── slash@3.0.0 extraneous
                      ├── slice-ansi@0.0.4 extraneous
                      ├── smart-buffer@4.2.0 extraneous
                      ├── socks-proxy-agent@7.0.0 extraneous
                      ├── socks@2.8.3 extraneous
                      ├── speedtest-net@1.6.2 extraneous
                      ├── split@1.0.1 extraneous
                      ├── sprintf-js@1.1.3 extraneous
                      ├── sqlstring@2.3.3 extraneous
                      ├── ssh2@ extraneous
                      ├── ssri@9.0.1 extraneous
                      ├── stack-trace@0.0.10 extraneous
                      ├── stampit-event-bus@0.1.1 extraneous
                      ├── stampit-state-machine@0.2.1 extraneous
                      ├── stampit@2.1.2 extraneous
                      ├── standard-as-callback@2.1.0 extraneous
                      ├── static-eval@2.0.2 extraneous
                      ├── statuses@2.0.1 extraneous
                      ├── stoppable@1.1.0 extraneous
                      ├── stream-combiner@0.2.2 extraneous
                      ├── stream-shift@1.0.3 extraneous
                      ├── streamsearch@1.1.0 extraneous
                      ├── streamx@2.18.0 extraneous
                      ├── string-argv@0.3.2 extraneous
                      ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                      ├── string-width@5.1.2 extraneous
                      ├── string.prototype.trim@1.2.9 extraneous
                      ├── string.prototype.trimend@1.0.8 extraneous
                      ├── string.prototype.trimstart@1.0.8 extraneous
                      ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                      ├── strip-ansi@6.0.1 extraneous
                      ├── strip-indent@3.0.0 extraneous
                      ├── strip-json-comments@2.0.1 extraneous
                      ├── strnum@1.0.5 extraneous
                      ├── suncalc@1.9.0 extraneous
                      ├── suncalc2@1.8.1 extraneous
                      ├── supermixer@1.0.5 extraneous
                      ├── supports-color@7.2.0 extraneous
                      ├── supports-hyperlinks@2.3.0 extraneous
                      ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                      ├── sweet-collections@1.1.0 extraneous
                      ├── symbol-observable@3.0.0 extraneous
                      ├── symbol-tree@3.2.4 extraneous
                      ├── syno@ extraneous
                      ├── systeminformation@ extraneous
                      ├── tar-fs@2.1.1 extraneous
                      ├── tar-stream@3.1.7 extraneous
                      ├── tar@6.2.1 extraneous
                      ├── tarn@3.0.2 extraneous
                      ├── tcp-port-used@1.0.2 extraneous
                      ├── tedious@ extraneous
                      ├── terminal-link@2.1.1 extraneous
                      ├── text-decoder@1.1.1 extraneous
                      ├── text-hex@1.0.0 extraneous
                      ├── thirty-two@1.0.2 extraneous
                      ├── through@2.3.8 extraneous
                      ├── through2@2.0.5 extraneous
                      ├── tiny-typed-emitter@2.1.0 extraneous
                      ├── tinycolor2@1.6.0 extraneous
                      ├── tmp@0.0.33 extraneous
                      ├── to-readable-stream@2.1.0 extraneous
                      ├── to-regex-range@5.0.1 extraneous
                      ├── toidentifier@1.0.1 extraneous
                      ├── tr46@4.1.1 extraneous
                      ├── trim-newlines@3.0.1 extraneous
                      ├── triple-beam@1.4.1 extraneous
                      ├── tsdav@ extraneous
                      ├── tslib@2.3.0 extraneous
                      ├── tweetnacl@0.14.5 extraneous
                      ├── type-check@0.3.2 extraneous
                      ├── type-fest@0.21.3 extraneous
                      ├── type-is@1.6.18 extraneous
                      ├── typed-array-buffer@1.0.2 extraneous
                      ├── typed-array-byte-length@1.0.1 extraneous
                      ├── typed-array-byte-offset@1.0.2 extraneous
                      ├── typed-array-length@1.0.6 extraneous
                      ├── typedarray-to-buffer@3.1.5 extraneous
                      ├── typedarray.prototype.slice@1.0.3 extraneous
                      ├── typescript@ extraneous
                      ├── tz-offset@0.0.1 extraneous
                      ├── uid-number@0.0.6 extraneous
                      ├── unbox-primitive@1.0.2 extraneous
                      ├── undici-types@6.19.6 extraneous
                      ├── unique-filename@2.0.1 extraneous
                      ├── unique-slug@3.0.0 extraneous
                      ├── unique-string@2.0.0 extraneous
                      ├── unix-dgram@2.0.6 extraneous
                      ├── unpipe@1.0.0 extraneous
                      ├── update-notifier@5.1.0 extraneous
                      ├── uri-js@4.4.1 extraneous
                      ├── url-join@4.0.1 extraneous
                      ├── url-parse-lax@3.0.0 extraneous
                      ├── url-template@2.0.8 extraneous
                      ├── url@0.11.4 extraneous
                      ├── vali-date@1.0.0 extraneous
                      ├── validate-npm-package-name@3.0.0 extraneous
                      ├── vary@1.1.2 extraneous
                      ├── virtual-tsc@0.6.2 extraneous
                      ├── vue-i18n@ extraneous
                      ├── vuelidate-messages@0.1.2 extraneous
                      ├── vuelidate@ extraneous
                      ├── vuex-map-fields@1.4.1 extraneous
                      ├── w3c-xmlserializer@4.0.0 extraneous
                      ├── wake_on_lan@1.0.0 extraneous
                      ├── weak-daemon@1.0.3 extraneous
                      ├── webdav@ extraneous
                      ├── webidl-conversions@7.0.0 extraneous
                      ├── websocket-stream@5.5.2 extraneous
                      ├── whatwg-encoding@2.0.0 extraneous
                      ├── whatwg-mimetype@3.0.0 extraneous
                      ├── whatwg-url@12.0.1 extraneous
                      ├── which-boxed-primitive@1.0.2 extraneous
                      ├── which-typed-array@1.1.15 extraneous
                      ├── wide-align@1.1.5 extraneous
                      ├── widest-line@3.1.0 extraneous
                      ├── window-size@0.1.4 extraneous
                      ├── winston-daily-rotate-file@5.0.0 extraneous
                      ├── winston-seq-updated@1.0.4 extraneous
                      ├── winston-syslog@2.7.1 extraneous
                      ├── winston-transport@4.7.1 extraneous
                      ├── winston@ extraneous
                      ├── word-wrap@1.2.5 extraneous
                      ├── worker-timers-broker@6.1.8 extraneous
                      ├── worker-timers-worker@7.0.71 extraneous
                      ├── worker-timers@7.1.8 extraneous
                      ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                      ├── wrap-ansi@8.1.0 extraneous
                      ├── wrappy@1.0.2 extraneous
                      ├── write-file-atomic@3.0.3 extraneous
                      ├── xdg-basedir@4.0.0 extraneous
                      ├── xml-js@1.6.11 extraneous
                      ├── xml-name-validator@4.0.0 extraneous
                      ├── xmlchars@2.2.0 extraneous
                      ├── xregexp@2.0.0 extraneous
                      ├── yallist@4.0.0 extraneous
                      ├── yaml@ extraneous
                      ├── yargs-parser@20.2.9 extraneous
                      ├── yargs@7.1.2
                      ├── yocto-queue@0.1.0 extraneous
                      ├── zip-stream@6.0.1 extraneous
                      └── zrender@ extraneous
                        Vollständig.
                        flommaster
                        Teil 2
                        npm error code ELSPROBLEMS
                        npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                        npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                        npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                        npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                        npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                        npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                        npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                        npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                        npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                        npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                        npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                        npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                        npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                        npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                        npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                        npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                        npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                        npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                        npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                        npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                        npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                        npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                        npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                        npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                        npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                        npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                        npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                        npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                        npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                        npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                        npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                        npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                        npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                        npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                        npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                        npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                        npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                        npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                        npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                        npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                        npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                        npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                        npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                        npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                        npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                        npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                        npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                        npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                        npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                        npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                        npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                        npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                        npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                        npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                        npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                        npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                        npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                        npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                        npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                        npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                        npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                        npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                        npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                        npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                        npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                        npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                        npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                        npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                        npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                        npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                        npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                        npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                        npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                        npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                        npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                        npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                        npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                        npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                        npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                        npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                        npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                        npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                        npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                        npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                        npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                        npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                        npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                        npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                        npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                        npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                        npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                        npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                        npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                        npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                        npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                        npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                        npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                        npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                        npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                        npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                        npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                        npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                        npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                        npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                        npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                        npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                        npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                        npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                        npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                        npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                        npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                        npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                        npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                        npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                        npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                        npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                        npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                        npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                        npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                        npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                        npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                        npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                        npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                        npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                        npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                        npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                        npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                        npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                        npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                        npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                        npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                        npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                        npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                        npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                        npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                        npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                        npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                        npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                        npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                        npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                        npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                        npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                        npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                        npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                        npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                        npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                        npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                        npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                        npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                        npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                        npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                        npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                        npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                        npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                        npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                        npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                        npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                        npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                        npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                        npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                        npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                        npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                        npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                        npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                        npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                        npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                        npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                        npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                        npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                        npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                        npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                        npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                        npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                        npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                        npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                        npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                        npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                        npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                        npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                        npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                        npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                        npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                        npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                        npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                        npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                        npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                        npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                        npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                        npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                        npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                        npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                        npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                        npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                        npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                        npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                        npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                        npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                        npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                        npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                        npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                        npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                        npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                        npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                        npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                        npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                        npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                        npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                        npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                        npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                        npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                        npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                        npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                        npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                        npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                        npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                        npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                        npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                        npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                        npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                        npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                        npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                        npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                        npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                        npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                        npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                        npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                        npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                        npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                        npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                        npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                        npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                        npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                        npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                        npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                        npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                        npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                        npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                        npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                        npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                        npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                        npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                        npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                        npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                        npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                        npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                        npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                        npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                        npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                        npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                        npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                        npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                        npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                        npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                        npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                        npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                        npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                        npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                        npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                        npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                        npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                        npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                        npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                        npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                        npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                        npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                        npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                        npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                        npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                        npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                        npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                        npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                        npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                        npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                        npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                        npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                        npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                        npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                        npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                        npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                        npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                        npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                        npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                        npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                        npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                        npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                        npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                        npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                        npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                        npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                        npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                        npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                        npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                        npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                        npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                        npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                        npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                        npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                        npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                        npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                        npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                        npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                        npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                        npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                        npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                        npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                        npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                        npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                        npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                        npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                        npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                        npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                        npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                        npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                        npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                        npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                        npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                        npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                        npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                        npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                        npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                        npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                        npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                        npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                        npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                        npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                        npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                        npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                        npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                        npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                        npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                        npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                        npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                        npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                        npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                        npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                        npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                        npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                        npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                        npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                        npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                        npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                        npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                        npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                        npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                        npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                        npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                        npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                        npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                        npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                        npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                        npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                        npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                        npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                        npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                        npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                        npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                        npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                        npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                        npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                        npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                        npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                        npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                        npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                        npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                        npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                        npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                        npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                        npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                        npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                        npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                        npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                        npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                        npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                        npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                        npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                        npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                        npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                        npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                        npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                        npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                        npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                        npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                        npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                        npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                        npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                        npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                        npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                        npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                        npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                        npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                        npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                        npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                        npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                        npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                        npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                        npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                        npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                        npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                        npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                        npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                        npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                        npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                        npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                        npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                        npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                        npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                        npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                        npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                        npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                        npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                        npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                        npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                        npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                        npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                        npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                        npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                        npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                        npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                        npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                        npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                        npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                        npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                        npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                        npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                        npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                        npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                        npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                        npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                        npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                        npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                        npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                        npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                        npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                        npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                        npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                        npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                        npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                        npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                        npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                        npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                        npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                        npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                        npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                        npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                        npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                        npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                        npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                        npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                        npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                        npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                        npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                        npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                        npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                        npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                        npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                        npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                        npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                        npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                        npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                        npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                        npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                        npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                        npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                        npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                        npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                        npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                        npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                        npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                        npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                        npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                        npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                        npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                        npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                        npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                        npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                        npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                        npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                        npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                        npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                        npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                        npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                        npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                        npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                        npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                        npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                        npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                        npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                        npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                        npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                        npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                        npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                        npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                        npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                        npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                        npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                        npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                        npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                        npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                        npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                        npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                        npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                        npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                        npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                        npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                        npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                        npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                        npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                        npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                        npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                        npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                        npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                        npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                        npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                        npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                        npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                        npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                        npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                        npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                        npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                        npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                        npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                        npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                        npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                        npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                        npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                        npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                        npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                        npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                        npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                        npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                        npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                        npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                        npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                        npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                        npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                        npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                        npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                        npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                        npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                        npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                        npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                        npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                        npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                        npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                        npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                        npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                        npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                        npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                        npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                        npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                        npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                        npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                        npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                        npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                        npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                        npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                        npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                        npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                        npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                        npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                        npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                        npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                        npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                        npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                        npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                        npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                        npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                        npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                        npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                        npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                        npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                        npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                        npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                        npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                        npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                        npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                        npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                        npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                        npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                        npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                        npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                        npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                        npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                        npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                        npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                        npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                        npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                        npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                        npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                        npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                        npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                        npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                        npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                        npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                        npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                        npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                        npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                        npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                        npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                        npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                        npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                        npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                        npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                        npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                        npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                        npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                        npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                        npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                        npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                        npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                        npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                        npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                        npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                        npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                        npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                        npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                        npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                        npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                        npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                        npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                        npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                        npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                        npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                        npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                        npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                        npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                        npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                        npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                        npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                        npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                        npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                        npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                        npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                        npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                        npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                        npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                        npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                        npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                        npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                        npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                        npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                        npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                        npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                        npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                        npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                        npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                        npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                        npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                        npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                        npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                        npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                        npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                        npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                        npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                        npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                        npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                        npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                        npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                        npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                        npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                        npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                        npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                        npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                        npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                        npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                        npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                        npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                        npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                        npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                        npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                        npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                        npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                        npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                        npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                        npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                        npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                        npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                        npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                        npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                        npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                        npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                        npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                        npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                        npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                        npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                        npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                        npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                        npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                        npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                        npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                        npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                        npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                        npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                        npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                        npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                        npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                        npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                        npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                        npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                        npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                        npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                        npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                        npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                        npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                        npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                        npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                        npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                        npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                        npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                        npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                        npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                        npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                        npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                        npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                        npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                        npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                        npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                        npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                        npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                        npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                        npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                        npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                        npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                        npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                        npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                        npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                        npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                        npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                        npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                        npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                        npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                        npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                        npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                        npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                        npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                        npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                        npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                        npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                        npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                        npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                        npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                        npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                        npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                        npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                        npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                        npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                        npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                        npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                        npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                        npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                        npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                        npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                        npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                        npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                        npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                        npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                        npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                        npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                        npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                        npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                        npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                        npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                        npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                        npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                        npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                        npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                        npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                        npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                        npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                        npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                        npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                        npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                        npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                        npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                        npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                        npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                        npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                        npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                        npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                        npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                        npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                        npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                        npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                        npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                        npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                        npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                        npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                        npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                        npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                        npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                        npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                        npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                        npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                        npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                        npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                        npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                        npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                        npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                        npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                        npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                        npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                        npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                        npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                        npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                        npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                        npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                        npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                        npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                        npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                        npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                        npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                        npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                        npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                        npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                        npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                        npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                        npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                        npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                        npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                        npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                        npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                        npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                        npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                        npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                        npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                        npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                        npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                        npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                        npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                        npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                        npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                        npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                        npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                        npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                        npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                        npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                        npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                        npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                        npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                        npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                        npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                        npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                        npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                        npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                        npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                        npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                        npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                        npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                        npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                        npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                        npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                        npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                        npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                        npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                        npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                        npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                        npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                        npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                        npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                        npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                        npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                        npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                        npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                        npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                        npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                        npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                        npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                        npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                        npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
                        • F flommaster
                          Teil 2
                          npm error code ELSPROBLEMS
                          npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                          npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                          npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                          npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                          npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                          npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                          npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                          npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                          npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                          npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                          npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                          npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                          npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                          npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                          npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                          npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                          npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                          npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                          npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                          npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                          npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                          npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                          npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                          npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                          npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                          npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                          npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                          npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                          npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                          npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                          npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                          npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                          npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                          npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                          npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                          npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                          npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                          npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                          npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                          npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                          npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                          npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                          npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                          npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                          npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                          npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                          npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                          npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                          npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                          npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                          npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                          npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                          npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                          npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                          npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                          npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                          npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                          npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                          npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                          npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                          npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                          npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                          npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                          npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                          npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                          npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                          npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                          npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                          npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                          npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                          npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                          npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                          npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                          npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                          npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                          npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                          npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                          npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                          npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                          npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                          npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                          npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                          npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                          npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                          npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                          npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                          npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                          npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                          npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                          npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                          npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                          npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                          npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                          npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                          npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                          npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                          npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                          npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                          npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                          npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                          npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                          npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                          npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                          npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                          npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                          npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                          npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                          npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                          npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                          npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                          npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                          npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                          npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                          npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                          npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                          npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                          npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                          npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                          npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                          npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                          npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                          npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                          npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                          npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                          npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                          npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                          npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                          npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                          npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                          npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                          npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                          npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                          npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                          npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                          npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                          npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                          npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                          npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                          npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                          npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                          npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                          npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                          npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                          npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                          npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                          npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                          npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                          npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                          npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                          npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                          npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                          npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                          npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                          npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                          npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                          npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                          npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                          npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                          npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                          npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                          npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                          npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                          npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                          npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                          npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                          npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                          npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                          npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                          npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                          npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                          npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                          npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                          npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                          npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                          npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                          npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                          npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                          npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                          npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                          npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                          npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                          npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                          npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                          npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                          npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                          npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                          npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                          npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                          npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                          npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                          npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                          npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                          npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                          npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                          npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                          npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                          npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                          npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                          npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                          npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                          npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                          npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                          npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                          npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                          npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                          npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                          npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                          npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                          npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                          npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                          npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                          npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                          npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                          npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                          npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                          npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                          npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                          npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                          npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                          npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                          npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                          npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                          npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                          npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                          npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                          npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                          npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                          npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                          npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                          npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                          npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                          npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                          npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                          npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                          npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                          npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                          npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                          npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                          npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                          npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                          npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                          npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                          npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                          npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                          npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                          npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                          npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                          npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                          npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                          npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                          npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                          npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                          npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                          npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                          npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                          npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                          npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                          npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                          npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                          npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                          npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                          npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                          npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                          npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                          npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                          npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                          npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                          npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                          npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                          npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                          npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                          npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                          npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                          npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                          npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                          npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                          npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                          npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                          npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                          npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                          npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                          npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                          npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                          npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                          npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                          npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                          npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                          npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                          npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                          npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                          npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                          npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                          npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                          npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                          npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                          npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                          npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                          npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                          npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                          npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                          npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                          npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                          npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                          npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                          npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                          npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                          npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                          npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                          npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                          npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                          npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                          npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                          npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                          npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                          npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                          npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                          npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                          npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                          npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                          npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                          npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                          npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                          npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                          npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                          npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                          npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                          npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                          npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                          npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                          npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                          npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                          npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                          npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                          npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                          npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                          npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                          npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                          npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                          npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                          npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                          npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                          npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                          npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                          npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                          npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                          npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                          npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                          npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                          npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                          npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                          npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                          npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                          npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                          npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                          npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                          npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                          npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                          npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                          npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                          npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                          npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                          npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                          npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                          npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                          npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                          npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                          npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                          npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                          npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                          npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                          npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                          npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                          npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                          npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                          npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                          npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                          npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                          npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                          npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                          npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                          npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                          npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                          npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                          npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                          npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                          npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                          npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                          npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                          npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                          npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                          npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                          npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                          npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                          npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                          npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                          npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                          npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                          npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                          npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                          npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                          npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                          npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                          npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                          npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                          npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                          npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                          npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                          npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                          npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                          npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                          npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                          npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                          npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                          npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                          npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                          npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                          npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                          npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                          npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                          npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                          npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                          npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                          npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                          npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                          npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                          npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                          npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                          npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                          npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                          npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                          npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                          npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                          npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                          npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                          npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                          npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                          npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                          npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                          npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                          npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                          npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                          npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                          npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                          npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                          npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                          npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                          npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                          npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                          npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                          npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                          npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                          npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                          npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                          npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                          npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                          npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                          npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                          npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                          npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                          npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                          npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                          npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                          npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                          npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                          npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                          npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                          npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                          npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                          npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                          npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                          npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                          npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                          npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                          npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                          npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                          npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                          npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                          npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                          npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                          npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                          npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                          npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                          npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                          npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                          npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                          npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                          npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                          npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                          npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                          npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                          npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                          npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                          npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                          npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                          npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                          npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                          npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                          npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                          npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                          npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                          npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                          npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                          npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                          npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                          npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                          npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                          npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                          npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                          npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                          npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                          npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                          npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                          npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                          npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                          npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                          npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                          npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                          npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                          npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                          npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                          npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                          npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                          npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                          npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                          npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                          npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                          npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                          npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                          npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                          npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                          npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                          npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                          npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                          npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                          npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                          npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                          npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                          npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                          npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                          npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                          npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                          npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                          npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                          npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                          npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                          npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                          npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                          npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                          npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                          npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                          npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                          npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                          npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                          npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                          npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                          npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                          npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                          npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                          npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                          npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                          npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                          npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                          npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                          npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                          npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                          npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                          npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                          npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                          npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                          npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                          npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                          npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                          npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                          npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                          npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                          npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                          npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                          npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                          npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                          npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                          npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                          npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                          npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                          npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                          npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                          npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                          npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                          npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                          npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                          npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                          npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                          npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                          npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                          npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                          npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                          npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                          npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                          npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                          npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                          npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                          npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                          npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                          npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                          npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                          npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                          npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                          npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                          npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                          npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                          npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                          npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                          npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                          npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                          npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                          npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                          npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                          npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                          npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                          npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                          npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                          npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                          npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                          npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                          npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                          npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                          npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                          npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                          npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                          npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                          npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                          npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                          npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                          npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                          npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                          npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                          npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                          npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                          npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                          npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                          npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                          npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                          npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                          npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                          npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                          npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                          npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                          npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                          npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                          npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                          npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                          npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                          npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                          npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                          npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                          npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                          npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                          npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                          npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                          npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                          npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                          npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                          npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                          npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                          npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                          npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                          npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                          npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                          npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                          npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                          npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                          npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                          npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                          npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                          npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                          npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                          npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                          npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                          npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                          npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                          npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                          npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                          npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                          npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                          npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                          npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                          npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                          npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                          npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                          npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                          npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                          npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                          npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                          npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                          npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                          npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                          npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                          npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                          npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                          npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                          npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                          npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                          npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                          npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                          npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                          npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                          npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                          npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                          npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                          npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                          npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                          npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                          npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                          npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                          npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                          npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                          npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                          npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                          npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                          npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                          npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                          npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                          npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                          npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                          npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                          npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                          npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                          npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                          npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                          npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                          npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                          npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                          npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                          npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                          npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                          npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                          npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                          npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                          npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                          npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                          npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                          npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                          npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                          npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                          npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                          npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                          npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                          npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                          npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                          npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                          npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                          npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                          npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                          npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                          npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                          npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                          npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                          npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                          npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                          npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                          npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                          npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                          npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                          npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                          npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                          npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                          npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                          npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                          npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                          npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                          npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                          npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                          npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                          npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                          npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                          npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                          npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                          npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                          npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                          npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                          npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                          npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                          npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                          npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                          npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                          npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                          npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                          npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                          npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                          npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                          npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                          npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                          npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                          npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                          npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                          npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                          npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                          npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                          npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                          npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                          npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                          npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                          npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                          npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                          npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                          npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                          npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                          npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                          npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                          npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                          npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                          npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                          npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                          npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                          npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                          npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                          npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                          npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                          npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                          npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                          npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                          npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                          npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                          npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                          npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                          npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                          npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                          npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                          npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                          npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                          npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                          npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                          npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                          npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                          npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                          npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                          npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                          npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                          npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                          npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                          npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                          npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                          npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                          npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                          npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                          npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                          npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                          npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                          npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                          npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                          npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                          npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                          npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                          npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                          npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                          npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                          npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                          npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                          npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                          npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                          npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                          npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                          npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                          npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                          npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                          npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                          npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                          npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                          npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                          npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
                          @flommaster
                          iob repo list
                          F 1 Antwort Letzte Antwort
                            @flommaster
                            iob repo list
                            flommaster
                            flo@ioBrokerdebian:/opt/iobroker$ iob repo list
                            node:internal/modules/cjs/loader:1148
                              throw err;
                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                                at Module._load (node:internal/modules/cjs/loader:986:27)
                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                                at node:internal/main/run_main_module:28:49 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                            Node.js v20.16.0
                            • F flommaster
                              Gerne. Hier der komplette Auszug (Teil 1)
                              flo@ioBrokerdebian:/opt/iobroker$ npm prune
                              npm ls
                              npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                              npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                              npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                              npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                              npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                              npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                              npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                              npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                              npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                              npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                              npm warn deprecated har-validator@5.1.5: this library is no longer supported
                              npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                              npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                              npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                              npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                              npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                              npm warn deprecated
                              npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                              npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                              npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                              npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                              npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                              npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                              npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                              npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                              npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                              npm warn deprecated gauge@3.0.2: This package is no longer supported.
                              npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              npm warn deprecated gauge@4.0.4: This package is no longer supported.
                              npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                              npm error git dep preparation failed
                              npm error signal SIGINT
                              npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                              npm error npm warn using --force Recommended protections disabled.
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
                              iobroker.inst@2.0.3 /opt/iobroker
                              ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                              ├── @alcalzone/jsonl-db@3.1.1 extraneous
                              ├── @alcalzone/pak@0.8.1 extraneous
                              ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                              ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                              ├── @azure/abort-controller@1.1.0 extraneous
                              ├── @azure/core-auth@1.7.2 extraneous
                              ├── @azure/core-client@ extraneous
                              ├── @azure/core-http-compat@ extraneous
                              ├── @azure/core-lro@ extraneous
                              ├── @azure/core-paging@1.6.2 extraneous
                              ├── @azure/core-rest-pipeline@ extraneous
                              ├── @azure/core-tracing@1.1.2 extraneous
                              ├── @azure/core-util@ extraneous
                              ├── @azure/identity@ extraneous
                              ├── @azure/keyvault-keys@ extraneous
                              ├── @azure/logger@1.1.4 extraneous
                              ├── @azure/msal-browser@ extraneous
                              ├── @azure/msal-common@ extraneous
                              ├── @azure/msal-node@1.18.4 extraneous
                              ├── @babel/code-frame@7.24.7 extraneous
                              ├── @babel/helper-validator-identifier@7.24.7 extraneous
                              ├── @babel/highlight@7.24.7 extraneous
                              ├── @babel/runtime@ extraneous
                              ├── @colors/colors@1.5.0 extraneous
                              ├── @dabh/diagnostics@2.0.3 extraneous
                              ├── @datalust/winston-seq@1.0.2 extraneous
                              ├── @gar/promisify@1.1.3 extraneous
                              ├── @googleapis/calendar@9.7.7 extraneous
                              ├── @googleapis/drive@5.1.0 extraneous
                              ├── @googleapis/oauth2@1.0.7 extraneous
                              ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                              ├── @iobroker/db-base@ extraneous
                              ├── @iobroker/db-objects-file@ extraneous
                              ├── @iobroker/db-objects-jsonl@ extraneous
                              ├── @iobroker/db-objects-redis@ extraneous
                              ├── @iobroker/db-states-file@ extraneous
                              ├── @iobroker/db-states-jsonl@ extraneous
                              ├── @iobroker/db-states-redis@ extraneous
                              ├── @iobroker/js-controller-adapter@ extraneous
                              ├── @iobroker/js-controller-cli@ extraneous
                              ├── @iobroker/js-controller-common-db@ extraneous
                              ├── @iobroker/js-controller-common@ extraneous
                              ├── @iobroker/plugin-base@1.2.1 extraneous
                              ├── @iobroker/plugin-sentry@1.2.1 extraneous
                              ├── @iobroker/socket-classes@1.5.6 extraneous
                              ├── @iobroker/webserver@1.0.3 extraneous
                              ├── @isaacs/cliui@8.0.2 extraneous
                              ├── @js-joda/core@ extraneous
                              ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                              ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                              ├── @nodelib/fs.scandir@2.1.5 extraneous
                              ├── @nodelib/fs.stat@2.0.5 extraneous
                              ├── @nodelib/fs.walk@1.2.8 extraneous
                              ├── @npmcli/fs@2.1.2 extraneous
                              ├── @npmcli/move-file@2.0.1 extraneous
                              ├── @pkgjs/parseargs@0.11.0 extraneous
                              ├── @protobufjs/aspromise@1.1.2 extraneous
                              ├── @protobufjs/base64@1.1.2 extraneous
                              ├── @protobufjs/codegen@2.0.4 extraneous
                              ├── @protobufjs/eventemitter@1.1.0 extraneous
                              ├── @protobufjs/fetch@1.1.0 extraneous
                              ├── @protobufjs/float@1.0.2 extraneous
                              ├── @protobufjs/inquire@1.1.0 extraneous
                              ├── @protobufjs/path@1.1.2 extraneous
                              ├── @protobufjs/pool@1.1.0 extraneous
                              ├── @protobufjs/utf8@1.1.0 extraneous
                              ├── @quasar/extras@ extraneous
                              ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                              ├── @sentry-internal/tracing@ extraneous
                              ├── @sentry/core@5.30.0 extraneous
                              ├── @sentry/hub@5.30.0 extraneous
                              ├── @sentry/minimal@5.30.0 extraneous
                              ├── @sentry/node@ extraneous
                              ├── @sentry/tracing@ extraneous
                              ├── @sentry/types@ extraneous
                              ├── @sentry/utils@ extraneous
                              ├── @sindresorhus/is@4.6.0 extraneous
                              ├── @socket.io/component-emitter@3.1.2 extraneous
                              ├── @szmarczak/http-timer@4.0.6 extraneous
                              ├── @tediousjs/connection-string@0.5.0 extraneous
                              ├── @tootallnate/once@2.0.0 extraneous
                              ├── @types/bl@5.1.0 extraneous
                              ├── @types/cacheable-request@6.0.3 extraneous
                              ├── @types/caseless@0.12.5 extraneous
                              ├── @types/cookie@0.4.1 extraneous
                              ├── @types/cors@2.8.17 extraneous
                              ├── @types/geojson@7946.0.14 extraneous
                              ├── @types/http-cache-semantics@4.0.4 extraneous
                              ├── @types/keyv@3.1.4 extraneous
                              ├── @types/leaflet@1.9.12 extraneous
                              ├── @types/minimist@1.2.5 extraneous
                              ├── @types/node-cron@2.0.8 extraneous
                              ├── @types/node@ extraneous
                              ├── @types/normalize-package-data@2.4.4 extraneous
                              ├── @types/parse-json@4.0.2 extraneous
                              ├── @types/readable-stream@4.0.15 extraneous
                              ├── @types/request@2.48.12 extraneous
                              ├── @types/responselike@1.0.3 extraneous
                              ├── @types/tough-cookie@4.0.5 extraneous
                              ├── @types/triple-beam@1.3.5 extraneous
                              ├── @types/tz-offset@0.0.3 extraneous
                              ├── @types/ws@8.5.12 extraneous
                              ├── abab@2.0.6 extraneous
                              ├── abbrev@1.1.1 extraneous
                              ├── abort-controller@3.0.0 extraneous
                              ├── agentkeepalive@4.5.0 extraneous
                              ├── aggregate-error@3.1.0 extraneous
                              ├── ajv@ extraneous
                              ├── ansi-align@3.0.1 extraneous
                              ├── ansi-colors@4.1.3 extraneous
                              ├── ansi-escapes@4.3.2 extraneous
                              ├── ansi-regex@5.0.1 extraneous
                              ├── ansi-styles@4.3.0 extraneous
                              ├── any-observable@0.5.1 extraneous
                              ├── anymatch@3.1.3 extraneous
                              ├── aproba@2.0.0 extraneous
                              ├── archiver-utils@5.0.2 extraneous
                              ├── archiver@7.0.1 extraneous
                              ├── are-we-there-yet@2.0.0 extraneous
                              ├── arg@4.1.0 extraneous
                              ├── argparse@1.0.10 extraneous
                              ├── array-buffer-byte-length@1.0.1 extraneous
                              ├── array-flatten@1.1.1 extraneous
                              ├── array-union@2.1.0 extraneous
                              ├── arraybuffer.prototype.slice@1.0.3 extraneous
                              ├── arrify@2.0.1 extraneous
                              ├── asn1@0.2.6 extraneous
                              ├── async-exit-hook@2.0.1 extraneous
                              ├── authenticate-pam@1.0.5 extraneous
                              ├── available-typed-arrays@1.0.7 extraneous
                              ├── aws-crt@ extraneous
                              ├── b4a@1.6.6 extraneous
                              ├── balanced-match@1.0.2 extraneous
                              ├── bare-events@2.4.2 extraneous
                              ├── base-64@1.0.0 extraneous
                              ├── base64-js@1.5.1 extraneous
                              ├── bcrypt-pbkdf@1.0.2 extraneous
                              ├── binary-extensions@2.3.0 extraneous
                              ├── bindings@1.5.0 extraneous
                              ├── bl@6.0.14 extraneous
                              ├── bluebird@3.7.2 extraneous
                              ├── body-parser@1.20.2 extraneous
                              ├── bottleneck@2.19.5 extraneous
                              ├── boxen@5.1.2 extraneous
                              ├── brace-expansion@2.0.1 extraneous
                              ├── braces@3.0.3 extraneous
                              ├── buffer-crc32@1.0.0 extraneous
                              ├── buffer-equal-constant-time@1.0.1 extraneous
                              ├── buffer-shims@1.0.0 extraneous
                              ├── buffer@6.0.3 extraneous
                              ├── buildcheck@0.0.6 extraneous
                              ├── builtins@1.0.3 extraneous
                              ├── busboy@1.6.0 extraneous
                              ├── byte-length@1.0.2 extraneous
                              ├── bytes@3.1.2 extraneous
                              ├── cacache@16.1.3 extraneous
                              ├── cacheable-lookup@5.0.4 extraneous
                              ├── cacheable-request@7.0.4 extraneous
                              ├── callsites@3.1.0 extraneous
                              ├── camelcase-keys@6.2.2 extraneous
                              ├── camelcase@5.3.1 extraneous
                              ├── capitalize@2.0.4 extraneous
                              ├── chalk@4.1.2 extraneous
                              ├── chardet@0.7.0 extraneous
                              ├── charenc@0.0.2 extraneous
                              ├── chokidar@3.6.0 extraneous
                              ├── chownr@2.0.0 extraneous
                              ├── ci-info@3.9.0 extraneous
                              ├── clean-stack@2.2.0 extraneous
                              ├── cli-boxes@2.2.1 extraneous
                              ├── cli-cursor@3.1.0 extraneous
                              ├── cli-truncate@0.2.1 extraneous
                              ├── cli-width@3.0.0 extraneous
                              ├── clone-response@1.0.3 extraneous
                              ├── cloneextend@0.0.3 extraneous
                              ├── cluster-key-slot@1.1.2 extraneous
                              ├── coap-packet@1.1.1 extraneous
                              ├── coffeescript@1.12.7 extraneous
                              ├── color-convert@2.0.1 extraneous
                              ├── color-name@1.1.4 extraneous
                              ├── color-string@1.9.1 extraneous
                              ├── color-support@1.1.3 extraneous
                              ├── color@3.2.1 extraneous
                              ├── colors@1.4.0
                              ├── colorspace@1.1.4 extraneous
                              ├── commander@9.5.0 extraneous
                              ├── commist@3.2.0 extraneous
                              ├── compress-commons@6.0.2 extraneous
                              ├── compress-json@2.1.2 extraneous
                              ├── compressible@2.0.18 extraneous
                              ├── compression@1.7.4 extraneous
                              ├── concat-map@0.0.1 extraneous
                              ├── configstore@5.0.1 extraneous
                              ├── connect-flash@0.1.1 extraneous
                              ├── connect@3.7.0 extraneous
                              ├── console-control-strings@1.1.0 extraneous
                              ├── content-disposition@0.5.4 extraneous
                              ├── content-type@1.0.5 extraneous
                              ├── core-js@ extraneous
                              ├── cors@2.8.5 extraneous
                              ├── cosmiconfig@7.1.0 extraneous
                              ├── cpu-features@ extraneous
                              ├── crc-32@1.2.2 extraneous
                              ├── crc@ extraneous
                              ├── crc32-stream@6.0.0 extraneous
                              ├── cross-fetch@4.0.0 extraneous
                              ├── crypt@0.0.2 extraneous
                              ├── crypto-js@ extraneous
                              ├── crypto-random-string@2.0.0 extraneous
                              ├── cssstyle@ extraneous
                              ├── cycle@1.0.3 extraneous
                              ├── dashdash@1.14.1 extraneous
                              ├── data-urls@4.0.0 extraneous
                              ├── data-view-buffer@1.0.1 extraneous
                              ├── data-view-byte-length@1.0.1 extraneous
                              ├── data-view-byte-offset@1.0.0 extraneous
                              ├── date-and-time@ extraneous
                              ├── date-fns@1.30.1 extraneous
                              ├── dateformat@4.6.3 extraneous
                              ├── dayjs@ extraneous
                              ├── decache@4.6.2 extraneous
                              ├── decamelize-keys@1.1.1 extraneous
                              ├── decimal.js@10.4.3 extraneous
                              ├── decompress-response@6.0.0 extraneous
                              ├── deep-clone@3.0.3 extraneous
                              ├── deep-extend@0.6.0 extraneous
                              ├── deep-is@0.1.4 extraneous
                              ├── defer-to-connect@2.0.1 extraneous
                              ├── define-lazy-prop@2.0.0 extraneous
                              ├── del@6.1.1 extraneous
                              ├── delegates@1.0.0 extraneous
                              ├── denque@1.5.1 extraneous
                              ├── destroy@1.2.0 extraneous
                              ├── detect-libc@2.0.3 extraneous
                              ├── diacritics@1.3.0 extraneous
                              ├── digest-header@1.1.0 extraneous
                              ├── dir-glob@3.0.1 extraneous
                              ├── diskusage@1.2.0 extraneous
                              ├── domexception@4.0.0 extraneous
                              ├── dot-prop@6.0.1 extraneous
                              ├── draftlog@1.0.13 extraneous
                              ├── dropbox-v2-api@ extraneous
                              ├── duplexer@0.1.2 extraneous
                              ├── duplexer3@0.1.5 extraneous
                              ├── duplexify@3.7.1 extraneous
                              ├── eastasianwidth@0.2.0 extraneous
                              ├── ecc-jsbn@0.1.2 extraneous
                              ├── ecdsa-sig-formatter@1.0.11 extraneous
                              ├── echarts@ extraneous
                              ├── ee-first@1.1.1 extraneous
                              ├── elegant-spinner@1.0.1 extraneous
                              ├── emoji-regex@9.2.2 extraneous
                              ├── enabled@2.0.0 extraneous
                              ├── encodeurl@1.0.2 extraneous
                              ├── encoding@0.1.13 extraneous
                              ├── end-of-stream@1.4.4 extraneous
                              ├── entities@4.5.0 extraneous
                              ├── err-code@2.0.3 extraneous
                              ├── es-abstract@ extraneous
                              ├── es-aggregate-error@1.0.13 extraneous
                              ├── es-object-atoms@1.0.0 extraneous
                              ├── es-set-tostringtag@2.0.3 extraneous
                              ├── es-to-primitive@1.2.1 extraneous
                              ├── es6-promise@4.2.8 extraneous
                              ├── es6-promisify@5.0.0 extraneous
                              ├── esbuild@0.11.23 extraneous
                              ├── escalade@3.1.2 extraneous
                              ├── escape-goat@3.0.0 extraneous
                              ├── escape-html@1.0.3 extraneous
                              ├── escape-string-regexp@4.0.0 extraneous
                              ├── escodegen@1.14.3 extraneous
                              ├── esprima@1.2.2 extraneous
                              ├── estraverse@4.3.0 extraneous
                              ├── esutils@2.0.3 extraneous
                              ├── etag@1.8.1 extraneous
                              ├── event-stream@4.0.1 extraneous
                              ├── event-target-shim@5.0.1 extraneous
                              ├── eventemitter2@6.4.9 extraneous
                              ├── events@3.3.0 extraneous
                              ├── execa@5.1.1 extraneous
                              ├── expand-template@2.0.3 extraneous
                              ├── express-fileupload@1.5.1 extraneous
                              ├── express@4.19.2 extraneous
                              ├── external-editor@3.1.0 extraneous
                              ├── fast-deep-equal@3.1.3 extraneous
                              ├── fast-fifo@1.3.2 extraneous
                              ├── fast-glob@ extraneous
                              ├── fast-json-stable-stringify@2.1.0 extraneous
                              ├── fast-levenshtein@2.0.6 extraneous
                              ├── fast-text-encoding@1.0.6 extraneous
                              ├── fast-unique-numbers@ extraneous
                              ├── fast-uri@3.0.1 extraneous
                              ├── fast-xml-parser@ extraneous
                              ├── fastq@1.17.1 extraneous
                              ├── fastseries@2.0.0 extraneous
                              ├── fecha@4.2.3 extraneous
                              ├── figures@3.2.0 extraneous
                              ├── file-stream-rotator@0.6.1 extraneous
                              ├── file-type@10.11.0 extraneous
                              ├── file-uri-to-path@1.0.0 extraneous
                              ├── fill-range@7.1.1 extraneous
                              ├── finalhandler@1.2.0 extraneous
                              ├── find-up@5.0.0 extraneous
                              ├── fn.name@1.1.0 extraneous
                              ├── for-each@0.3.3 extraneous
                              ├── foreground-child@3.3.0 extraneous
                              ├── form-data-encoder@2.1.4 extraneous
                              ├── form-data@4.0.0 extraneous
                              ├── forwarded@0.2.0 extraneous
                              ├── fresh@0.5.2 extraneous
                              ├── from@0.1.7 extraneous
                              ├── fs-constants@1.0.0 extraneous
                              ├── fs-extra@7.0.1
                              ├── fs-minipass@2.1.0 extraneous
                              ├── fs.realpath@1.0.0 extraneous
                              ├── fsevents@ extraneous
                              ├── ftp@0.3.10 extraneous
                              ├── function.prototype.name@1.1.6 extraneous
                              ├── functions-have-names@1.2.3 extraneous
                              ├── futoin-hkdf@1.4.3 extraneous
                              ├── gauge@3.0.2 extraneous
                              ├── gaxios@5.1.3 extraneous
                              ├── gcp-metadata@5.3.0 extraneous
                              ├── generate-function@2.3.1 extraneous
                              ├── get-ssl-certificate@2.3.3 extraneous
                              ├── get-stream@5.2.0 extraneous
                              ├── get-symbol-description@1.0.2 extraneous
                              ├── getpass@0.1.7 extraneous
                              ├── github-from-package@0.0.0 extraneous
                              ├── github-url-from-git@1.5.0 extraneous
                              ├── glob-parent@5.1.2 extraneous
                              ├── glob@10.4.5 extraneous
                              ├── global-dirs@2.1.0 extraneous
                              ├── globalthis@1.0.4 extraneous
                              ├── globby@11.1.0 extraneous
                              ├── glossy@0.1.7 extraneous
                              ├── google-auth-library@ extraneous
                              ├── google-p12-pem@4.0.1 extraneous
                              ├── googleapis-common@6.0.4 extraneous
                              ├── googleapis@ extraneous
                              ├── gtoken@6.1.2 extraneous
                              ├── hard-rejection@2.1.0 extraneous
                              ├── has-ansi@2.0.0 extraneous
                              ├── has-bigints@1.0.2 extraneous
                              ├── has-flag@4.0.0 extraneous
                              ├── has-tostringtag@1.0.2 extraneous
                              ├── has-unicode@2.0.1 extraneous
                              ├── has-yarn@2.1.0 extraneous
                              ├── he@1.2.0 extraneous
                              ├── help-me@5.0.0 extraneous
                              ├── homebridge-plugin-wrapper@ extraneous
                              ├── hosted-git-info@3.0.8 extraneous
                              ├── hot-patcher@1.0.0 extraneous
                              ├── html-encoding-sniffer@3.0.0 extraneous
                              ├── http-cache-semantics@4.1.1 extraneous
                              ├── http-errors@2.0.0 extraneous
                              ├── http-proxy-agent@5.0.0 extraneous
                              ├── http2-wrapper@1.0.3 extraneous
                              ├── https@1.0.0 extraneous
                              ├── humanize-ms@1.2.1 extraneous
                              ├── ical.js@ extraneous
                              ├── iconv-lite@0.4.24 extraneous
                              ├── ieee754@1.2.1 extraneous
                              ├── ignore-walk@3.0.4 extraneous
                              ├── ignore@5.3.2 extraneous
                              ├── image-type@4.1.0 extraneous
                              ├── immediate@3.0.6 extraneous
                              ├── import-fresh@3.3.0 extraneous
                              ├── import-lazy@2.1.0 extraneous
                              ├── import-local@3.2.0 extraneous
                              ├── imurmurhash@0.1.4 extraneous
                              ├── indent-string@3.2.0 extraneous
                              ├── infer-owner@1.0.4 extraneous
                              ├── inflight@1.0.6 extraneous
                              ├── ini@1.3.7 extraneous
                              ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                              ├── inquirer@7.3.3 extraneous
                              ├── int64-buffer@1.0.1 extraneous
                              ├── internal-slot@1.0.7 extraneous
                              ├── iobroker-adapter-helpers@0.0.8 extraneous
                              ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                              ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                              ├── iobroker.bmw@2.5.7
                              ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                              ├── iobroker.cloud@4.4.1
                              ├── iobroker.coronavirus-statistics@0.8.7
                              ├── iobroker.daswetter@3.1.10
                              ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                              ├── iobroker.dwd@2.8.5
                              ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                              ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                              ├── iobroker.eusec@1.1.2
                              ├── iobroker.flot@ invalid: "1.12.0" from the root project
                              ├── iobroker.fritzbox@0.2.1
                              ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                              ├── iobroker.fullybrowser@2.1.2
                              ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                              ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                              ├── iobroker.harmony@1.2.2
                              ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                              ├── iobroker.history@2.2.6
                              ├── iobroker.hm-rega@3.0.47
                              ├── iobroker.hm-rpc@1.15.19
                              ├── iobroker.hue@3.9.5
                              ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                              ├── iobroker.icons-icons8@0.0.1
                              ├── iobroker.icons-material-png@0.1.0
                              ├── iobroker.icons-mfd-png@1.1.0
                              ├── iobroker.icons-ultimate-png@1.0.1
                              ├── iobroker.info@ invalid: "1.9.26" from the root project
                              ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                              ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                              ├── iobroker.logparser@2.2.0
                              ├── iobroker.material@ invalid: "1.3.1" from the root project
                              ├── iobroker.meross@1.15.1
                              ├── iobroker.mihome-vacuum@3.11.0
                              ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                              ├── iobroker.milight@0.3.6
                              ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                              ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                              ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                              ├── iobroker.nina@ invalid: "0.0.25" from the root project
                              ├── iobroker.pollenflug@1.0.6
                              ├── iobroker.pushover@3.0.3
                              ├── iobroker.pushsafer@1.0.3
                              ├── iobroker.pvforecast@2.7.1
                              ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                              ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                              ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                              ├── iobroker.simple-api@2.7.2
                              ├── iobroker.smartmeter@3.3.4
                              ├── iobroker.socketio@6.5.2
                              ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                              ├── iobroker.sql@2.2.0
                              ├── iobroker.statistics@2.3.0
                              ├── iobroker.sunnyportal@0.1.5
                              ├── iobroker.synology@ invalid: "2.1.13" from the root project
                              ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                              ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                              ├── iobroker.tr-064@4.2.18
                              ├── iobroker.trashschedule@2.2.0
                              ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                              ├── iobroker.upnp@1.0.21
                              ├── iobroker.valloxmv@1.2.0
                              ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                              ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                              ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                              ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                              ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                              ├── iobroker.vis-fancyswitch@1.1.0
                              ├── iobroker.vis-google-fonts@1.0.4
                              ├── iobroker.vis-history@1.0.0
                              ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                              ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                              ├── iobroker.vis-jqui-mfd@1.0.12
                              ├── iobroker.vis-justgage@1.0.2
                              ├── iobroker.vis-map@1.0.4
                              ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                              ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                              ├── iobroker.vis-rgraph@0.0.2
                              ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                              ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                              ├── iobroker.vis@ invalid: "1.4.16" from the root project
                              ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                              ├── iobroker.weatherunderground@3.4.2
                              ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                              ├── iobroker.web@ invalid: "6.1.0" from the root project
                              ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                              ├── iobroker.wiffi-wz@2.2.1
                              ├── iobroker.windows-control@0.1.5
                              ├── iobroker.worx@2.3.2
                              ├── iobroker.ws@2.5.3
                              ├── iobroker@2.0.3
                              ├── ioredis@ extraneous
                              ├── ip-address@9.0.5 extraneous
                              ├── ip-regex@4.3.0 extraneous
                              ├── ipaddr.js@2.2.0 extraneous
                              ├── is-array-buffer@3.0.4 extraneous
                              ├── is-bigint@1.0.4 extraneous
                              ├── is-binary-path@2.1.0 extraneous
                              ├── is-boolean-object@1.1.2 extraneous
                              ├── is-buffer@1.1.6 extraneous
                              ├── is-callable@1.2.7 extraneous
                              ├── is-ci@2.0.0 extraneous
                              ├── is-core-module@2.15.0 extraneous
                              ├── is-data-view@1.0.1 extraneous
                              ├── is-date-object@1.0.5 extraneous
                              ├── is-docker@2.2.1 extraneous
                              ├── is-empty-object@1.1.1 extraneous
                              ├── is-extglob@2.1.1 extraneous
                              ├── is-fullwidth-code-point@3.0.0 extraneous
                              ├── is-glob@4.0.3 extraneous
                              ├── is-installed-globally@0.3.2 extraneous
                              ├── is-interactive@1.0.0 extraneous
                              ├── is-lambda@1.0.1 extraneous
                              ├── is-negative-zero@2.0.3 extraneous
                              ├── is-npm@5.0.0 extraneous
                              ├── is-number-object@1.0.7 extraneous
                              ├── is-number@7.0.0 extraneous
                              ├── is-obj@2.0.0 extraneous
                              ├── is-observable@1.1.0 extraneous
                              ├── is-path-cwd@2.2.0 extraneous
                              ├── is-path-inside@3.0.3 extraneous
                              ├── is-plain-obj@1.1.0 extraneous
                              ├── is-potential-custom-element-name@1.0.1 extraneous
                              ├── is-promise@2.2.2 extraneous
                              ├── is-property@1.0.2 extraneous
                              ├── is-regex@1.1.4 extraneous
                              ├── is-scoped@2.1.0 extraneous
                              ├── is-shared-array-buffer@1.0.3 extraneous
                              ├── is-string@1.0.7 extraneous
                              ├── is-symbol@1.0.4 extraneous
                              ├── is-typed-array@1.1.13 extraneous
                              ├── is-unicode-supported@0.1.0 extraneous
                              ├── is-url-superb@4.0.0 extraneous
                              ├── is-url@1.2.4 extraneous
                              ├── is-weakref@1.0.2 extraneous
                              ├── is-wsl@2.2.0 extraneous
                              ├── is-yarn-global@0.3.0 extraneous
                              ├── is@3.3.0 extraneous
                              ├── is2@2.0.9 extraneous
                              ├── isomorphic-ws@4.0.1 extraneous
                              ├── issue-regex@3.1.0 extraneous
                              ├── jackspeak@3.4.3 extraneous
                              ├── js-md4@0.3.2 extraneous
                              ├── js-sdsl@4.3.0 extraneous
                              ├── js-tokens@4.0.0 extraneous
                              ├── js-yaml@ extraneous
                              ├── jsbi@4.3.0 extraneous
                              ├── jsbn@1.1.0 extraneous
                              ├── jsdom@ extraneous
                              ├── jshashes@1.0.8 extraneous
                              ├── json-buffer@3.0.1 extraneous
                              ├── json-logic-js@2.0.5 extraneous
                              ├── json-parse-even-better-errors@2.3.1 extraneous
                              ├── json-schema-traverse@1.0.0 extraneous
                              ├── json5@2.2.3 extraneous
                              ├── jsonata@ extraneous
                              ├── jsonc-parser@3.3.1 extraneous
                              ├── jsonwebtoken@9.0.2 extraneous
                              ├── jszip@ extraneous
                              ├── jwa@2.0.0 extraneous
                              ├── jws@4.0.0 extraneous
                              ├── keyv@4.5.4 extraneous
                              ├── kind-of@6.0.3 extraneous
                              ├── kuler@2.0.0 extraneous
                              ├── later@1.2.0 extraneous
                              ├── latest-version@5.1.0 extraneous
                              ├── layerr@0.1.2 extraneous
                              ├── lazystream@1.0.1 extraneous
                              ├── leven@2.1.0 extraneous
                              ├── levn@0.3.0 extraneous
                              ├── lie@3.3.0 extraneous
                              ├── lines-and-columns@1.2.4 extraneous
                              ├── listr-input@0.2.1 extraneous
                              ├── listr-silent-renderer@1.1.1 extraneous
                              ├── listr-update-renderer@0.5.0 extraneous
                              ├── listr-verbose-renderer@0.5.0 extraneous
                              ├── listr@0.14.3 extraneous
                              ├── loadavg-windows@1.1.1 extraneous
                              ├── locate-path@6.0.0 extraneous
                              ├── lodash.defaults@4.2.0 extraneous
                              ├── lodash.flatten@4.4.0 extraneous
                              ├── lodash.includes@4.3.0 extraneous
                              ├── lodash.isarguments@3.1.0 extraneous
                              ├── lodash.isboolean@3.0.3 extraneous
                              ├── lodash.isequal@4.5.0 extraneous
                              ├── lodash.isinteger@4.0.4 extraneous
                              ├── lodash.isnumber@3.0.3 extraneous
                              ├── lodash.isplainobject@4.0.6 extraneous
                              ├── lodash.isstring@4.0.1 extraneous
                              ├── lodash.once@4.1.1 extraneous
                              ├── lodash.zip@4.2.0 extraneous
                              ├── log-symbols@4.1.0 extraneous
                              ├── log-update@2.3.0 extraneous
                              ├── logform@ extraneous
                              ├── long@5.2.3 extraneous
                              ├── lowercase-keys@2.0.0 extraneous
                              ├── lru_map@0.3.3 extraneous
                              ├── lru-cache@6.0.0 extraneous
                              ├── make-dir@3.1.0 extraneous
                              ├── make-fetch-happen@10.2.1 extraneous
                              ├── map-age-cleaner@0.1.3 extraneous
                              ├── map-obj@4.3.0 extraneous
                              ├── map-stream@0.0.7 extraneous
                              ├── md5@2.3.0 extraneous
                              ├── media-typer@0.3.0 extraneous
                              ├── meow@8.1.2 extraneous
                              ├── merge-descriptors@1.0.1 extraneous
                              ├── merge2@1.4.1 extraneous
                              ├── methods@1.1.2 extraneous
                              ├── micro@9.4.1 extraneous
                              ├── micromatch@4.0.7 extraneous
                              ├── mime-db@1.53.0 extraneous
                              ├── mimic-response@1.0.1 extraneous
                              ├── min-indent@1.0.1 extraneous
                              ├── minimatch@9.0.5 extraneous
                              ├── minimist-options@4.1.0 extraneous
                              ├── minipass-collect@1.0.2 extraneous
                              ├── minipass-fetch@2.1.2 extraneous
                              ├── minipass-flush@1.0.5 extraneous
                              ├── minipass-pipeline@1.2.4 extraneous
                              ├── minipass-sized@1.0.3 extraneous
                              ├── minipass@7.1.2 extraneous
                              ├── minizlib@2.1.2 extraneous
                              ├── mkdirp-classic@0.5.3 extraneous
                              ├── mkdirp@1.0.4 extraneous
                              ├── mock-require@3.0.3 extraneous
                              ├── moment-duration-format@2.3.2 extraneous
                              ├── mqtt-connection@4.1.0 extraneous
                              ├── mqtt-packet@9.0.0 extraneous
                              ├── mqtt@ extraneous
                              ├── mute-stream@0.0.8 extraneous
                              ├── named-placeholders@1.1.3 extraneous
                              ├── nan@ extraneous
                              ├── nanoid@3.3.7 extraneous
                              ├── napi-build-utils@1.0.2 extraneous
                              ├── native-duplexpair@1.0.0 extraneous
                              ├── nconf@0.10.0 extraneous
                              ├── nested-property@4.0.0 extraneous
                              ├── netmask@2.0.2 extraneous
                              ├── new-github-release-url@1.0.0 extraneous
                              ├── node-abi@3.65.0 extraneous
                              ├── node-abort-controller@3.1.1 extraneous
                              ├── node-cron@2.0.3 extraneous
                              ├── node-fetch@2.7.0 extraneous
                              ├── node-forge@ extraneous
                              ├── node-gyp@ extraneous
                              ├── node-ical@0.16.1 extraneous
                              ├── node-inspect@2.0.0 extraneous
                              ├── node-libcurl@3.0.0 extraneous
                              ├── node-mndp@0.0.3 extraneous
                              ├── node-persist@0.0.11 extraneous
                              ├── node-rsa@1.1.1 extraneous
                              ├── node-unifi@2.5.1 extraneous
                              ├── node-wol@0.1.1 extraneous
                              ├── node.extend@2.0.3 extraneous
                              ├── nopt@5.0.0 extraneous
                              ├── normalize-package-data@3.0.3 extraneous
                              ├── normalize-path@3.0.0 extraneous
                              ├── normalize-url@6.1.0 extraneous
                              ├── np@7.7.0 extraneous
                              ├── npm-name@6.0.1 extraneous
                              ├── npmlog@5.0.1 extraneous
                              ├── number-allocator@1.0.14 extraneous
                              ├── nwsapi@2.2.12 extraneous
                              ├── object-assign@4.1.1 extraneous
                              ├── object-hash@3.0.0 extraneous
                              ├── on-finished@2.4.1 extraneous
                              ├── once@1.4.0 extraneous
                              ├── one-time@1.0.0 extraneous
                              ├── onedrive-api@1.1.1 extraneous
                              ├── open@7.4.2 extraneous
                              ├── opencollective-postinstall@2.0.3 extraneous
                              ├── optionator@0.8.3 extraneous
                              ├── org-regex@1.0.0 extraneous
                              ├── os-tmpdir@1.0.2 extraneous
                              ├── ospath@1.2.2 extraneous
                              ├── osx-temperature-sensor@ extraneous
                              ├── otplib@11.0.1 extraneous
                              ├── ow@0.21.0 extraneous
                              ├── p-cancelable@2.1.1 extraneous
                              ├── p-defer@1.0.0 extraneous
                              ├── p-event@4.2.0 extraneous
                              ├── p-finally@1.0.0 extraneous
                              ├── p-limit@2.3.0 extraneous
                              ├── p-locate@5.0.0 extraneous
                              ├── p-map@2.1.0 extraneous
                              ├── p-memoize@4.0.4 extraneous
                              ├── p-reflect@2.1.0 extraneous
                              ├── p-settle@4.1.1 extraneous
                              ├── p-throttle@4.1.1 extraneous
                              ├── p-timeout@4.1.0 extraneous
                              ├── p-try@2.2.0 extraneous
                              ├── package-json-from-dist@1.0.0 extraneous
                              ├── package-json@6.5.0 extraneous
                              ├── pako@ extraneous
                              ├── parent-module@1.0.1 extraneous
                              ├── parse-json@5.2.0 extraneous
                              ├── parse5@ extraneous
                              ├── passport-local@1.0.0 extraneous
                              ├── passport@0.7.0 extraneous
                              ├── path-exists@4.0.0 extraneous
                              ├── path-is-absolute@1.0.1 extraneous
                              ├── path-parse@1.0.7 extraneous
                              ├── path-posix@1.0.0 extraneous
                              ├── path-scurry@1.11.1 extraneous
                              ├── path-to-regexp@0.1.7 extraneous
                              ├── path-type@4.0.0 extraneous
                              ├── pause-stream@0.0.11 extraneous
                              ├── picomatch@2.3.1 extraneous
                              ├── pidtree@0.6.0 extraneous
                              ├── pidusage@3.0.2 extraneous
                              ├── ping@0.4.4 extraneous
                              ├── pkg-dir@5.0.0 extraneous
                              ├── pluralize@8.0.0 extraneous
                              ├── possible-typed-array-names@1.0.0 extraneous
                              ├── prebuild-install@7.1.2 extraneous
                              ├── prelude-ls@1.1.2 extraneous
                              ├── prepend-http@2.0.0 extraneous
                              ├── process-nextick-args@2.0.1 extraneous
                              ├── process@0.11.10 extraneous
                              ├── promise-inflight@1.0.1 extraneous
                              ├── promise-object@0.1.7 extraneous
                              ├── promise-retry@2.0.1 extraneous
                              ├── promise-retryer@0.0.1 extraneous
                              ├── promisify-child-process@4.1.2 extraneous
                              ├── prompt@1.3.0 extraneous
                              ├── protobufjs@ extraneous
                              ├── proxy-addr@2.0.7 extraneous
                              ├── proxy-from-env@1.1.0 extraneous
                              ├── pump@3.0.0 extraneous
                              ├── pupa@2.1.1 extraneous
                              ├── q@1.1.2 extraneous
                              ├── quasar@ extraneous
                              ├── queue-microtask@1.2.3 extraneous
                              ├── queue-tick@1.0.1 extraneous
                              ├── quick-lru@5.1.1 extraneous
                              ├── range-parser@1.2.1 extraneous
                              ├── raw-body@2.5.2 extraneous
                              ├── rc@1.2.8 extraneous
                              ├── read-pkg-up@7.0.1 extraneous
                              ├── read-pkg@5.2.0 extraneous
                              ├── read@1.0.7 extraneous
                              ├── readable-stream@ extraneous
                              ├── readdir-glob@1.1.3 extraneous
                              ├── readdirp@3.6.0 extraneous
                              ├── readline-sync@1.4.10 extraneous
                              ├── readline@1.3.0 extraneous
                              ├── redent@3.0.0 extraneous
                              ├── redis-commands@1.7.0 extraneous
                              ├── redis-errors@1.2.0 extraneous
                              ├── redis-parser@3.0.0 extraneous
                              ├── regenerator-runtime@0.14.1 extraneous
                              ├── regex-escape@3.4.10 extraneous
                              ├── regexp.prototype.flags@1.5.2 extraneous
                              ├── registry-auth-token@4.2.2 extraneous
                              ├── registry-url@5.1.0 extraneous
                              ├── reinterval@1.1.0 extraneous
                              ├── remove-trailing-separator@1.1.0 extraneous
                              ├── require-from-string@2.0.2 extraneous
                              ├── resolve-alpn@1.2.1 extraneous
                              ├── resolve-cwd@3.0.0 extraneous
                              ├── resolve-from@4.0.0 extraneous
                              ├── respjs@4.2.0 extraneous
                              ├── responselike@2.0.1 extraneous
                              ├── restore-cursor@3.1.0 extraneous
                              ├── retry-axios@2.6.0 extraneous
                              ├── retry@0.12.0 extraneous
                              ├── reusify@1.0.4 extraneous
                              ├── revalidator@0.1.8 extraneous
                              ├── rfdc@1.4.1 extraneous
                              ├── rimraf@3.0.2 extraneous
                              ├── rrule@2.8.1 extraneous
                              ├── rrweb-cssom@0.6.0 extraneous
                              ├── run-async@2.4.1 extraneous
                              ├── run-parallel@1.2.0 extraneous
                              ├── rxjs@ extraneous
                              ├── safe-array-concat@1.1.2 extraneous
                              ├── safe-regex-test@1.0.3 extraneous
                              ├── safe-stable-stringify@2.4.3 extraneous
                              ├── safer-buffer@2.1.2 extraneous
                              ├── saxes@6.0.0 extraneous
                              ├── scoped-regex@2.1.0 extraneous
                              ├── secure-keys@1.0.0 extraneous
                              ├── semver-diff@3.1.1 extraneous
                              ├── semver@5.7.2
                              ├── send@0.18.0 extraneous
                              ├── seq-logging@1.1.2 extraneous
                              ├── seq-queue@0.0.5 extraneous
                              ├── serve-static@1.15.0 extraneous
                              ├── set-function-name@2.0.2 extraneous
                              ├── setimmediate@1.0.5 extraneous
                              ├── setprototypeof@1.2.0 extraneous
                              ├── signal-exit@4.1.0 extraneous
                              ├── simple-concat@1.0.1 extraneous
                              ├── simple-get@3.1.1 extraneous
                              ├── simple-ssh@1.1.1 extraneous
                              ├── simple-swizzle@0.2.2 extraneous
                              ├── slash@3.0.0 extraneous
                              ├── slice-ansi@0.0.4 extraneous
                              ├── smart-buffer@4.2.0 extraneous
                              ├── socks-proxy-agent@7.0.0 extraneous
                              ├── socks@2.8.3 extraneous
                              ├── speedtest-net@1.6.2 extraneous
                              ├── split@1.0.1 extraneous
                              ├── sprintf-js@1.1.3 extraneous
                              ├── sqlstring@2.3.3 extraneous
                              ├── ssh2@ extraneous
                              ├── ssri@9.0.1 extraneous
                              ├── stack-trace@0.0.10 extraneous
                              ├── stampit-event-bus@0.1.1 extraneous
                              ├── stampit-state-machine@0.2.1 extraneous
                              ├── stampit@2.1.2 extraneous
                              ├── standard-as-callback@2.1.0 extraneous
                              ├── static-eval@2.0.2 extraneous
                              ├── statuses@2.0.1 extraneous
                              ├── stoppable@1.1.0 extraneous
                              ├── stream-combiner@0.2.2 extraneous
                              ├── stream-shift@1.0.3 extraneous
                              ├── streamsearch@1.1.0 extraneous
                              ├── streamx@2.18.0 extraneous
                              ├── string-argv@0.3.2 extraneous
                              ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                              ├── string-width@5.1.2 extraneous
                              ├── string.prototype.trim@1.2.9 extraneous
                              ├── string.prototype.trimend@1.0.8 extraneous
                              ├── string.prototype.trimstart@1.0.8 extraneous
                              ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                              ├── strip-ansi@6.0.1 extraneous
                              ├── strip-indent@3.0.0 extraneous
                              ├── strip-json-comments@2.0.1 extraneous
                              ├── strnum@1.0.5 extraneous
                              ├── suncalc@1.9.0 extraneous
                              ├── suncalc2@1.8.1 extraneous
                              ├── supermixer@1.0.5 extraneous
                              ├── supports-color@7.2.0 extraneous
                              ├── supports-hyperlinks@2.3.0 extraneous
                              ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                              ├── sweet-collections@1.1.0 extraneous
                              ├── symbol-observable@3.0.0 extraneous
                              ├── symbol-tree@3.2.4 extraneous
                              ├── syno@ extraneous
                              ├── systeminformation@ extraneous
                              ├── tar-fs@2.1.1 extraneous
                              ├── tar-stream@3.1.7 extraneous
                              ├── tar@6.2.1 extraneous
                              ├── tarn@3.0.2 extraneous
                              ├── tcp-port-used@1.0.2 extraneous
                              ├── tedious@ extraneous
                              ├── terminal-link@2.1.1 extraneous
                              ├── text-decoder@1.1.1 extraneous
                              ├── text-hex@1.0.0 extraneous
                              ├── thirty-two@1.0.2 extraneous
                              ├── through@2.3.8 extraneous
                              ├── through2@2.0.5 extraneous
                              ├── tiny-typed-emitter@2.1.0 extraneous
                              ├── tinycolor2@1.6.0 extraneous
                              ├── tmp@0.0.33 extraneous
                              ├── to-readable-stream@2.1.0 extraneous
                              ├── to-regex-range@5.0.1 extraneous
                              ├── toidentifier@1.0.1 extraneous
                              ├── tr46@4.1.1 extraneous
                              ├── trim-newlines@3.0.1 extraneous
                              ├── triple-beam@1.4.1 extraneous
                              ├── tsdav@ extraneous
                              ├── tslib@2.3.0 extraneous
                              ├── tweetnacl@0.14.5 extraneous
                              ├── type-check@0.3.2 extraneous
                              ├── type-fest@0.21.3 extraneous
                              ├── type-is@1.6.18 extraneous
                              ├── typed-array-buffer@1.0.2 extraneous
                              ├── typed-array-byte-length@1.0.1 extraneous
                              ├── typed-array-byte-offset@1.0.2 extraneous
                              ├── typed-array-length@1.0.6 extraneous
                              ├── typedarray-to-buffer@3.1.5 extraneous
                              ├── typedarray.prototype.slice@1.0.3 extraneous
                              ├── typescript@ extraneous
                              ├── tz-offset@0.0.1 extraneous
                              ├── uid-number@0.0.6 extraneous
                              ├── unbox-primitive@1.0.2 extraneous
                              ├── undici-types@6.19.6 extraneous
                              ├── unique-filename@2.0.1 extraneous
                              ├── unique-slug@3.0.0 extraneous
                              ├── unique-string@2.0.0 extraneous
                              ├── unix-dgram@2.0.6 extraneous
                              ├── unpipe@1.0.0 extraneous
                              ├── update-notifier@5.1.0 extraneous
                              ├── uri-js@4.4.1 extraneous
                              ├── url-join@4.0.1 extraneous
                              ├── url-parse-lax@3.0.0 extraneous
                              ├── url-template@2.0.8 extraneous
                              ├── url@0.11.4 extraneous
                              ├── vali-date@1.0.0 extraneous
                              ├── validate-npm-package-name@3.0.0 extraneous
                              ├── vary@1.1.2 extraneous
                              ├── virtual-tsc@0.6.2 extraneous
                              ├── vue-i18n@ extraneous
                              ├── vuelidate-messages@0.1.2 extraneous
                              ├── vuelidate@ extraneous
                              ├── vuex-map-fields@1.4.1 extraneous
                              ├── w3c-xmlserializer@4.0.0 extraneous
                              ├── wake_on_lan@1.0.0 extraneous
                              ├── weak-daemon@1.0.3 extraneous
                              ├── webdav@ extraneous
                              ├── webidl-conversions@7.0.0 extraneous
                              ├── websocket-stream@5.5.2 extraneous
                              ├── whatwg-encoding@2.0.0 extraneous
                              ├── whatwg-mimetype@3.0.0 extraneous
                              ├── whatwg-url@12.0.1 extraneous
                              ├── which-boxed-primitive@1.0.2 extraneous
                              ├── which-typed-array@1.1.15 extraneous
                              ├── wide-align@1.1.5 extraneous
                              ├── widest-line@3.1.0 extraneous
                              ├── window-size@0.1.4 extraneous
                              ├── winston-daily-rotate-file@5.0.0 extraneous
                              ├── winston-seq-updated@1.0.4 extraneous
                              ├── winston-syslog@2.7.1 extraneous
                              ├── winston-transport@4.7.1 extraneous
                              ├── winston@ extraneous
                              ├── word-wrap@1.2.5 extraneous
                              ├── worker-timers-broker@6.1.8 extraneous
                              ├── worker-timers-worker@7.0.71 extraneous
                              ├── worker-timers@7.1.8 extraneous
                              ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                              ├── wrap-ansi@8.1.0 extraneous
                              ├── wrappy@1.0.2 extraneous
                              ├── write-file-atomic@3.0.3 extraneous
                              ├── xdg-basedir@4.0.0 extraneous
                              ├── xml-js@1.6.11 extraneous
                              ├── xml-name-validator@4.0.0 extraneous
                              ├── xmlchars@2.2.0 extraneous
                              ├── xregexp@2.0.0 extraneous
                              ├── yallist@4.0.0 extraneous
                              ├── yaml@ extraneous
                              ├── yargs-parser@20.2.9 extraneous
                              ├── yargs@7.1.2
                              ├── yocto-queue@0.1.0 extraneous
                              ├── zip-stream@6.0.1 extraneous
                              └── zrender@ extraneous
                              @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                              hast du beide Befehle auf einmal gestartet?
                              bitte einzeln abarbeiten
                              F Thomas BraunT 2 Antworten Letzte Antwort
                                flommaster
                                Ja,
                                Hier ist das Ergebnis von "npm prune"
                                npm warn deprecated
                                  @flommaster
                                  Gerade noch gehabt...
                                  Vollständig.
                                  Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                                  Und auch inkl. der neuen leeren Eingabezeile, damit man sieht das es durchgelaufen ist und da nix fehlt.
                                  iobroker url https://github.com/DrozmotiX/ioBroker.sourceanalytix --debug
                                    @flommaster
                                    Vollständig.
                                    flommaster
                                    schrieb am zuletzt editiert von flommaster
                                    @thomas-braun @Homoran
                                    hier ist noch das Ergebnis von npm prune
                                    root@ioBrokerdebian:/home/flo# npm prune
                                    up to date, audited 135 packages in 2s
                                    11 packages are looking for funding
                                      run `npm fund` for details
                                    4 vulnerabilities (2 moderate, 2 high)
                                    To address all issues, run:
                                      npm audit fix
                                    Run `npm audit` for details.
                                    npm ls
                                    root@ioBrokerdebian:/home/flo# npm ls
                                    flo@ /home/flo
                                    └── iobroker.admin@6.10.2
                                    Vielen Dank und viele Grüße
                                    • F flommaster
                                        npm audit fix
                                      npm ls
                                      flo@ /home/flo
                                      root@
                                      Nie nie niemals als root herumkaspern...
                                        root@
                                        flommaster
                                        Ok. Mach ich nicht mehr.
                                        Davor bin ich noch der Anweisung gefolgt und habe den Befehl "npm audit fix" ausgeführt.
                                        Danach wurden mir bei npm prune keine Fehler mehr angezeigt.
                                        up to date, audited 133 packages in 2s
                                        found 0 vulnerabilities
                                        flo@ /home/flo
                                        • F flommaster
                                          flo@ /home/flo
                                          @flommaster
                                          Mooooooooooooooarrrrrrrrrrrr...
                                          MELD DICH ALS ROOT AB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                          Und NIE NIE NIEMEHR als root an!!!!!!!!!!!!!!!!
                                          Und du hampelst dann auch im falschen Verzeichnis herum....
                                          Und iobroker admin hat in /home/flo auch nix verloren...
                                          Und auch nie npm audit fix ausführen. Insbesondere nicht mit --force.
                                          Das macht dir auch mehr kaputt als das es hilft.
