  4. Beim Update von Adaptern stürzt der ioBroker ab
89 Beiträge 7 Kommentatoren 17.4k Aufrufe 4 Beobachtet
    @flommaster
    cd /opt/iobroker && npm ls
    spuckt aus?
    flommaster
    @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
    zu viele Fehler...
    Teil 1
    iobroker.inst@2.0.3 /opt/iobroker
    ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
    ├── @alcalzone/jsonl-db@3.1.1 extraneous
    ├── @alcalzone/pak@0.8.1 extraneous
    ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
    ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
    ├── @azure/abort-controller@1.1.0 extraneous
    ├── @azure/core-auth@1.7.2 extraneous
    ├── @azure/core-client@ extraneous
    ├── @azure/core-http-compat@ extraneous
    ├── @azure/core-lro@ extraneous
    ├── @azure/core-paging@1.6.2 extraneous
    ├── @azure/core-rest-pipeline@ extraneous
    ├── @azure/core-tracing@1.1.2 extraneous
    ├── @azure/core-util@ extraneous
    ├── @azure/identity@ extraneous
    ├── @azure/keyvault-keys@ extraneous
    ├── @azure/logger@1.1.4 extraneous
    ├── @azure/msal-browser@ extraneous
    ├── @azure/msal-common@ extraneous
    ├── @azure/msal-node@1.18.4 extraneous
    ├── @babel/code-frame@7.24.7 extraneous
    ├── @babel/helper-validator-identifier@7.24.7 extraneous
    ├── @babel/highlight@7.24.7 extraneous
    ├── @babel/runtime@ extraneous
    ├── @colors/colors@1.5.0 extraneous
    ├── @dabh/diagnostics@2.0.3 extraneous
    ├── @datalust/winston-seq@1.0.2 extraneous
    ├── @gar/promisify@1.1.3 extraneous
    ├── @googleapis/calendar@9.7.7 extraneous
    ├── @googleapis/drive@5.1.0 extraneous
    ├── @googleapis/oauth2@1.0.7 extraneous
    ├── @httptoolkit/websocket-stream@6.0.1 extraneous
    ├── @iobroker/db-base@ extraneous
    ├── @iobroker/db-objects-file@ extraneous
    ├── @iobroker/db-objects-jsonl@ extraneous
    ├── @iobroker/db-objects-redis@ extraneous
    ├── @iobroker/db-states-file@ extraneous
    ├── @iobroker/db-states-jsonl@ extraneous
    ├── @iobroker/db-states-redis@ extraneous
    ├── @iobroker/js-controller-adapter@ extraneous
    ├── @iobroker/js-controller-cli@ extraneous
    ├── @iobroker/js-controller-common-db@ extraneous
    ├── @iobroker/js-controller-common@ extraneous
    ├── @iobroker/plugin-base@1.2.1 extraneous
    ├── @iobroker/plugin-sentry@1.2.1 extraneous
    ├── @iobroker/socket-classes@1.5.6 extraneous
    ├── @iobroker/webserver@1.0.3 extraneous
    ├── @isaacs/cliui@8.0.2 extraneous
    ├── @js-joda/core@ extraneous
    ├── @mapbox/node-pre-gyp@1.0.11 extraneous
    ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
    ├── @nodelib/fs.scandir@2.1.5 extraneous
    ├── @nodelib/fs.stat@2.0.5 extraneous
    ├── @nodelib/fs.walk@1.2.8 extraneous
    ├── @npmcli/fs@2.1.2 extraneous
    ├── @npmcli/move-file@2.0.1 extraneous
    ├── @pkgjs/parseargs@0.11.0 extraneous
    ├── @protobufjs/aspromise@1.1.2 extraneous
    ├── @protobufjs/base64@1.1.2 extraneous
    ├── @protobufjs/codegen@2.0.4 extraneous
    ├── @protobufjs/eventemitter@1.1.0 extraneous
    ├── @protobufjs/fetch@1.1.0 extraneous
    ├── @protobufjs/float@1.0.2 extraneous
    ├── @protobufjs/inquire@1.1.0 extraneous
    ├── @protobufjs/path@1.1.2 extraneous
    ├── @protobufjs/pool@1.1.0 extraneous
    ├── @protobufjs/utf8@1.1.0 extraneous
    ├── @quasar/extras@ extraneous
    ├── @samverschueren/stream-to-observable@0.3.1 extraneous
    ├── @sentry-internal/tracing@ extraneous
    ├── @sentry/core@5.30.0 extraneous
    ├── @sentry/hub@5.30.0 extraneous
    ├── @sentry/minimal@5.30.0 extraneous
    ├── @sentry/node@ extraneous
    ├── @sentry/tracing@ extraneous
    ├── @sentry/types@ extraneous
    ├── @sentry/utils@ extraneous
    ├── @sindresorhus/is@4.6.0 extraneous
    ├── @socket.io/component-emitter@3.1.2 extraneous
    ├── @szmarczak/http-timer@4.0.6 extraneous
    ├── @tediousjs/connection-string@0.5.0 extraneous
    ├── @tootallnate/once@2.0.0 extraneous
    ├── @types/bl@5.1.0 extraneous
    ├── @types/cacheable-request@6.0.3 extraneous
    ├── @types/caseless@0.12.5 extraneous
    ├── @types/cookie@0.4.1 extraneous
    ├── @types/cors@2.8.17 extraneous
    ├── @types/geojson@7946.0.14 extraneous
    ├── @types/http-cache-semantics@4.0.4 extraneous
    ├── @types/keyv@3.1.4 extraneous
    ├── @types/leaflet@1.9.12 extraneous
    ├── @types/minimist@1.2.5 extraneous
    ├── @types/node-cron@2.0.8 extraneous
    ├── @types/node@ extraneous
    ├── @types/normalize-package-data@2.4.4 extraneous
    ├── @types/parse-json@4.0.2 extraneous
    ├── @types/readable-stream@4.0.15 extraneous
    ├── @types/request@2.48.12 extraneous
    ├── @types/responselike@1.0.3 extraneous
    ├── @types/tough-cookie@4.0.5 extraneous
    ├── @types/triple-beam@1.3.5 extraneous
    ├── @types/tz-offset@0.0.3 extraneous
    ├── @types/ws@8.5.12 extraneous
    ├── abab@2.0.6 extraneous
    ├── abbrev@1.1.1 extraneous
    ├── abort-controller@3.0.0 extraneous
    ├── agentkeepalive@4.5.0 extraneous
    ├── aggregate-error@3.1.0 extraneous
    ├── ajv@ extraneous
    ├── ansi-align@3.0.1 extraneous
    ├── ansi-colors@4.1.3 extraneous
    ├── ansi-escapes@4.3.2 extraneous
    ├── ansi-regex@5.0.1 extraneous
    ├── ansi-styles@4.3.0 extraneous
    ├── any-observable@0.5.1 extraneous
    ├── anymatch@3.1.3 extraneous
    ├── aproba@2.0.0 extraneous
    ├── archiver-utils@5.0.2 extraneous
    ├── archiver@7.0.1 extraneous
    ├── are-we-there-yet@2.0.0 extraneous
    ├── arg@4.1.0 extraneous
    ├── argparse@1.0.10 extraneous
    ├── array-buffer-byte-length@1.0.1 extraneous
    ├── array-flatten@1.1.1 extraneous
    ├── array-union@2.1.0 extraneous
    ├── arraybuffer.prototype.slice@1.0.3 extraneous
    ├── arrify@2.0.1 extraneous
    ├── asn1@0.2.6 extraneous
    ├── async-exit-hook@2.0.1 extraneous
    ├── authenticate-pam@1.0.5 extraneous
    ├── available-typed-arrays@1.0.7 extraneous
    ├── aws-crt@ extraneous
    ├── b4a@1.6.6 extraneous
    ├── balanced-match@1.0.2 extraneous
    ├── bare-events@2.4.2 extraneous
    ├── base-64@1.0.0 extraneous
    ├── base64-js@1.5.1 extraneous
    ├── bcrypt-pbkdf@1.0.2 extraneous
    ├── binary-extensions@2.3.0 extraneous
    ├── bindings@1.5.0 extraneous
    ├── bl@6.0.14 extraneous
    ├── bluebird@3.7.2 extraneous
    ├── body-parser@1.20.2 extraneous
    ├── bottleneck@2.19.5 extraneous
    ├── boxen@5.1.2 extraneous
    ├── brace-expansion@2.0.1 extraneous
    ├── braces@3.0.3 extraneous
    ├── buffer-crc32@1.0.0 extraneous
    ├── buffer-equal-constant-time@1.0.1 extraneous
    ├── buffer-shims@1.0.0 extraneous
    ├── buffer@6.0.3 extraneous
    ├── buildcheck@0.0.6 extraneous
    ├── builtins@1.0.3 extraneous
    ├── busboy@1.6.0 extraneous
    ├── byte-length@1.0.2 extraneous
    ├── bytes@3.1.2 extraneous
    ├── cacache@16.1.3 extraneous
    ├── cacheable-lookup@5.0.4 extraneous
    ├── cacheable-request@7.0.4 extraneous
    ├── callsites@3.1.0 extraneous
    ├── camelcase-keys@6.2.2 extraneous
    ├── camelcase@5.3.1 extraneous
    ├── capitalize@2.0.4 extraneous
    ├── chalk@4.1.2 extraneous
    ├── chardet@0.7.0 extraneous
    ├── charenc@0.0.2 extraneous
    ├── chokidar@3.6.0 extraneous
    ├── chownr@2.0.0 extraneous
    ├── ci-info@3.9.0 extraneous
    ├── clean-stack@2.2.0 extraneous
    ├── cli-boxes@2.2.1 extraneous
    ├── cli-cursor@3.1.0 extraneous
    ├── cli-truncate@0.2.1 extraneous
    ├── cli-width@3.0.0 extraneous
    ├── clone-response@1.0.3 extraneous
    ├── cloneextend@0.0.3 extraneous
    ├── cluster-key-slot@1.1.2 extraneous
    ├── coap-packet@1.1.1 extraneous
    ├── coffeescript@1.12.7 extraneous
    ├── color-convert@2.0.1 extraneous
    ├── color-name@1.1.4 extraneous
    ├── color-string@1.9.1 extraneous
    ├── color-support@1.1.3 extraneous
    ├── color@3.2.1 extraneous
    ├── colors@1.4.0
    ├── colorspace@1.1.4 extraneous
    ├── commander@9.5.0 extraneous
    ├── commist@3.2.0 extraneous
    ├── compress-commons@6.0.2 extraneous
    ├── compress-json@2.1.2 extraneous
    ├── compressible@2.0.18 extraneous
    ├── compression@1.7.4 extraneous
    ├── concat-map@0.0.1 extraneous
    ├── configstore@5.0.1 extraneous
    ├── connect-flash@0.1.1 extraneous
    ├── connect@3.7.0 extraneous
    ├── console-control-strings@1.1.0 extraneous
    ├── content-disposition@0.5.4 extraneous
    ├── content-type@1.0.5 extraneous
    ├── core-js@ extraneous
    ├── cors@2.8.5 extraneous
    ├── cosmiconfig@7.1.0 extraneous
    ├── cpu-features@ extraneous
    ├── crc-32@1.2.2 extraneous
    ├── crc@ extraneous
    ├── crc32-stream@6.0.0 extraneous
    ├── cross-fetch@4.0.0 extraneous
    ├── crypt@0.0.2 extraneous
    ├── crypto-js@ extraneous
    ├── crypto-random-string@2.0.0 extraneous
    ├── cssstyle@ extraneous
    ├── cycle@1.0.3 extraneous
    ├── dashdash@1.14.1 extraneous
    ├── data-urls@4.0.0 extraneous
    ├── data-view-buffer@1.0.1 extraneous
    ├── data-view-byte-length@1.0.1 extraneous
    ├── data-view-byte-offset@1.0.0 extraneous
    ├── date-and-time@ extraneous
    ├── date-fns@1.30.1 extraneous
    ├── dateformat@4.6.3 extraneous
    ├── dayjs@ extraneous
    ├── decache@4.6.2 extraneous
    ├── decamelize-keys@1.1.1 extraneous
    ├── decimal.js@10.4.3 extraneous
    ├── decompress-response@6.0.0 extraneous
    ├── deep-clone@3.0.3 extraneous
    ├── deep-extend@0.6.0 extraneous
    ├── deep-is@0.1.4 extraneous
    ├── defer-to-connect@2.0.1 extraneous
    ├── define-lazy-prop@2.0.0 extraneous
    ├── del@6.1.1 extraneous
    ├── delegates@1.0.0 extraneous
    ├── denque@1.5.1 extraneous
    ├── destroy@1.2.0 extraneous
    ├── detect-libc@2.0.3 extraneous
    ├── diacritics@1.3.0 extraneous
    ├── digest-header@1.1.0 extraneous
    ├── dir-glob@3.0.1 extraneous
    ├── diskusage@1.2.0 extraneous
    ├── domexception@4.0.0 extraneous
    ├── dot-prop@6.0.1 extraneous
    ├── draftlog@1.0.13 extraneous
    ├── dropbox-v2-api@ extraneous
    ├── duplexer@0.1.2 extraneous
    ├── duplexer3@0.1.5 extraneous
    ├── duplexify@3.7.1 extraneous
    ├── eastasianwidth@0.2.0 extraneous
    ├── ecc-jsbn@0.1.2 extraneous
    ├── ecdsa-sig-formatter@1.0.11 extraneous
    ├── echarts@ extraneous
    ├── ee-first@1.1.1 extraneous
    ├── elegant-spinner@1.0.1 extraneous
    ├── emoji-regex@9.2.2 extraneous
    ├── enabled@2.0.0 extraneous
    ├── encodeurl@1.0.2 extraneous
    ├── encoding@0.1.13 extraneous
    ├── end-of-stream@1.4.4 extraneous
    ├── entities@4.5.0 extraneous
    ├── err-code@2.0.3 extraneous
    ├── es-abstract@ extraneous
    ├── es-aggregate-error@1.0.13 extraneous
    ├── es-object-atoms@1.0.0 extraneous
    ├── es-set-tostringtag@2.0.3 extraneous
    ├── es-to-primitive@1.2.1 extraneous
    ├── es6-promise@4.2.8 extraneous
    ├── es6-promisify@5.0.0 extraneous
    ├── esbuild@0.11.23 extraneous
    ├── escalade@3.1.2 extraneous
    ├── escape-goat@3.0.0 extraneous
    ├── escape-html@1.0.3 extraneous
    ├── escape-string-regexp@4.0.0 extraneous
    ├── escodegen@1.14.3 extraneous
    ├── esprima@1.2.2 extraneous
    ├── estraverse@4.3.0 extraneous
    ├── esutils@2.0.3 extraneous
    ├── etag@1.8.1 extraneous
    ├── event-stream@4.0.1 extraneous
    ├── event-target-shim@5.0.1 extraneous
    ├── eventemitter2@6.4.9 extraneous
    ├── events@3.3.0 extraneous
    ├── execa@5.1.1 extraneous
    ├── expand-template@2.0.3 extraneous
    ├── express-fileupload@1.5.1 extraneous
    ├── express@4.19.2 extraneous
    ├── external-editor@3.1.0 extraneous
    ├── fast-deep-equal@3.1.3 extraneous
    ├── fast-fifo@1.3.2 extraneous
    ├── fast-glob@ extraneous
    ├── fast-json-stable-stringify@2.1.0 extraneous
    ├── fast-levenshtein@2.0.6 extraneous
    ├── fast-text-encoding@1.0.6 extraneous
    ├── fast-unique-numbers@ extraneous
    ├── fast-uri@3.0.1 extraneous
    ├── fast-xml-parser@ extraneous
    ├── fastq@1.17.1 extraneous
    ├── fastseries@2.0.0 extraneous
    ├── fecha@4.2.3 extraneous
    ├── figures@3.2.0 extraneous
    ├── file-stream-rotator@0.6.1 extraneous
    ├── file-type@10.11.0 extraneous
    ├── file-uri-to-path@1.0.0 extraneous
    ├── fill-range@7.1.1 extraneous
    ├── finalhandler@1.2.0 extraneous
    ├── find-up@5.0.0 extraneous
    ├── fn.name@1.1.0 extraneous
    ├── for-each@0.3.3 extraneous
    ├── foreground-child@3.3.0 extraneous
    ├── form-data-encoder@2.1.4 extraneous
    ├── form-data@4.0.0 extraneous
    ├── forwarded@0.2.0 extraneous
    ├── fresh@0.5.2 extraneous
    ├── from@0.1.7 extraneous
    ├── fs-constants@1.0.0 extraneous
    ├── fs-extra@7.0.1
    ├── fs-minipass@2.1.0 extraneous
    ├── fs.realpath@1.0.0 extraneous
    ├── fsevents@ extraneous
    ├── ftp@0.3.10 extraneous
    ├── function.prototype.name@1.1.6 extraneous
    ├── functions-have-names@1.2.3 extraneous
    ├── futoin-hkdf@1.4.3 extraneous
    ├── gauge@3.0.2 extraneous
    ├── gaxios@5.1.3 extraneous
    ├── gcp-metadata@5.3.0 extraneous
    ├── generate-function@2.3.1 extraneous
    ├── get-ssl-certificate@2.3.3 extraneous
    ├── get-stream@5.2.0 extraneous
    ├── get-symbol-description@1.0.2 extraneous
    ├── getpass@0.1.7 extraneous
    ├── github-from-package@0.0.0 extraneous
    ├── github-url-from-git@1.5.0 extraneous
    ├── glob-parent@5.1.2 extraneous
    ├── glob@10.4.5 extraneous
    ├── global-dirs@2.1.0 extraneous
    ├── globalthis@1.0.4 extraneous
    ├── globby@11.1.0 extraneous
    ├── glossy@0.1.7 extraneous
    ├── google-auth-library@ extraneous
    ├── google-p12-pem@4.0.1 extraneous
    ├── googleapis-common@6.0.4 extraneous
    ├── googleapis@ extraneous
    ├── gtoken@6.1.2 extraneous
    ├── hard-rejection@2.1.0 extraneous
    ├── has-ansi@2.0.0 extraneous
    ├── has-bigints@1.0.2 extraneous
    ├── has-flag@4.0.0 extraneous
    ├── has-tostringtag@1.0.2 extraneous
    ├── has-unicode@2.0.1 extraneous
    ├── has-yarn@2.1.0 extraneous
    ├── he@1.2.0 extraneous
    ├── help-me@5.0.0 extraneous
    ├── homebridge-plugin-wrapper@ extraneous
    ├── hosted-git-info@3.0.8 extraneous
    ├── hot-patcher@1.0.0 extraneous
    ├── html-encoding-sniffer@3.0.0 extraneous
    ├── http-cache-semantics@4.1.1 extraneous
    ├── http-errors@2.0.0 extraneous
    ├── http-proxy-agent@5.0.0 extraneous
    ├── http2-wrapper@1.0.3 extraneous
    ├── https@1.0.0 extraneous
    ├── humanize-ms@1.2.1 extraneous
    ├── ical.js@ extraneous
    ├── iconv-lite@0.4.24 extraneous
    ├── ieee754@1.2.1 extraneous
    ├── ignore-walk@3.0.4 extraneous
    ├── ignore@5.3.2 extraneous
    ├── image-type@4.1.0 extraneous
    ├── immediate@3.0.6 extraneous
    ├── import-fresh@3.3.0 extraneous
    ├── import-lazy@2.1.0 extraneous
    ├── import-local@3.2.0 extraneous
    ├── imurmurhash@0.1.4 extraneous
    ├── indent-string@3.2.0 extraneous
    ├── infer-owner@1.0.4 extraneous
    ├── inflight@1.0.6 extraneous
    ├── ini@1.3.7 extraneous
    ├── inquirer-autosubmit-prompt@0.2.0 extraneous
    ├── inquirer@7.3.3 extraneous
    ├── int64-buffer@1.0.1 extraneous
    ├── internal-slot@1.0.7 extraneous
    ├── iobroker-adapter-helpers@0.0.8 extraneous
    ├── iobroker.admin@ invalid: "^6.10.1" from the root project
    ├── iobroker.backitup@ invalid: "2.6.23" from the root project
    ├── iobroker.bmw@2.5.7
    ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
    ├── iobroker.cloud@4.4.1
    ├── iobroker.coronavirus-statistics@0.8.7
    ├── iobroker.daswetter@3.1.10
    ├── iobroker.discovery@ invalid: "3.1.0" from the root project
    ├── iobroker.dwd@2.8.5
    ├── iobroker.echarts@ invalid: "1.5.1" from the root project
    ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
    ├── iobroker.eusec@1.1.2
    ├── iobroker.flot@ invalid: "1.12.0" from the root project
    ├── iobroker.fritzbox@0.2.1
    ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
    ├── iobroker.fullybrowser@2.1.2
    ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
    ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
    ├── iobroker.harmony@1.2.2
    ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
    ├── iobroker.history@2.2.6
    ├── iobroker.hm-rega@3.0.47
    ├── iobroker.hm-rpc@1.15.19
    ├── iobroker.hue@3.9.5
    ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
    ├── iobroker.icons-icons8@0.0.1
    ├── iobroker.icons-material-png@0.1.0
    ├── iobroker.icons-mfd-png@1.1.0
    ├── iobroker.icons-ultimate-png@1.0.1
    ├── iobroker.info@ invalid: "1.9.26" from the root project
    ├── iobroker.javascript@ invalid: "7.1.4" from the root project
    ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
    ├── iobroker.logparser@2.2.0
    ├── iobroker.material@ invalid: "1.3.1" from the root project
    ├── iobroker.meross@1.15.1
    ├── iobroker.mihome-vacuum@3.11.0
    ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
    ├── iobroker.milight@0.3.6
    ├── iobroker.mobile@ invalid: "1.0.1" from the root project
    ├── iobroker.modbus@ invalid: "5.0.11" from the root project
    ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
    ├── iobroker.nina@ invalid: "0.0.25" from the root project
    ├── iobroker.pollenflug@1.0.6
    ├── iobroker.pushover@3.0.3
    ├── iobroker.pushsafer@1.0.3
    ├── iobroker.pvforecast@2.7.1
    ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
    ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
    ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
    ├── iobroker.simple-api@2.7.2
    ├── iobroker.smartmeter@3.3.4
    ├── iobroker.socketio@6.5.2
    ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
    ├── iobroker.sql@2.2.0
    ├── iobroker.statistics@2.3.0
    ├── iobroker.sunnyportal@0.1.5
    ├── iobroker.synology@ invalid: "2.1.13" from the root project
    ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
    ├── iobroker.terminal@ invalid: "1.0.0" from the root project
    ├── iobroker.tr-064@4.2.18
    ├── iobroker.trashschedule@2.2.0
    ├── iobroker.unifi@ invalid: "0.6.6" from the root project
    ├── iobroker.upnp@1.0.21
    ├── iobroker.valloxmv@1.2.0
    ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
    ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
    ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
    ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
    ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
    ├── iobroker.vis-fancyswitch@1.1.0
    ├── iobroker.vis-google-fonts@1.0.4
    ├── iobroker.vis-history@1.0.0
    ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
    ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
    ├── iobroker.vis-jqui-mfd@1.0.12
    ├── iobroker.vis-justgage@1.0.2
    ├── iobroker.vis-map@1.0.4
    ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
    ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
    ├── iobroker.vis-rgraph@0.0.2
    ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
    ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
    ├── iobroker.vis@ invalid: "1.4.16" from the root project
    ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
    ├── iobroker.weatherunderground@3.4.2
    ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
    ├── iobroker.web@ invalid: "6.1.0" from the root project
    ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
    ├── iobroker.wiffi-wz@2.2.1
    ├── iobroker.windows-control@0.1.5
    ├── iobroker.worx@2.3.2
    ├── iobroker.ws@2.5.3
    ├── iobroker@2.0.3
    ├── ioredis@ extraneous
    ├── ip-address@9.0.5 extraneous
    ├── ip-regex@4.3.0 extraneous
    ├── ipaddr.js@2.2.0 extraneous
    ├── is-array-buffer@3.0.4 extraneous
    ├── is-bigint@1.0.4 extraneous
    ├── is-binary-path@2.1.0 extraneous
    ├── is-boolean-object@1.1.2 extraneous
    ├── is-buffer@1.1.6 extraneous
    ├── is-callable@1.2.7 extraneous
    ├── is-ci@2.0.0 extraneous
    ├── is-core-module@2.15.0 extraneous
    ├── is-data-view@1.0.1 extraneous
    ├── is-date-object@1.0.5 extraneous
    ├── is-docker@2.2.1 extraneous
    ├── is-empty-object@1.1.1 extraneous
    ├── is-extglob@2.1.1 extraneous
    ├── is-fullwidth-code-point@3.0.0 extraneous
    ├── is-glob@4.0.3 extraneous
    ├── is-installed-globally@0.3.2 extraneous
    ├── is-interactive@1.0.0 extraneous
    ├── is-lambda@1.0.1 extraneous
    ├── is-negative-zero@2.0.3 extraneous
    ├── is-npm@5.0.0 extraneous
    ├── is-number-object@1.0.7 extraneous
    ├── is-number@7.0.0 extraneous
    ├── is-obj@2.0.0 extraneous
    ├── is-observable@1.1.0 extraneous
    ├── is-path-cwd@2.2.0 extraneous
    ├── is-path-inside@3.0.3 extraneous
    ├── is-plain-obj@1.1.0 extraneous
    ├── is-potential-custom-element-name@1.0.1 extraneous
    ├── is-promise@2.2.2 extraneous
    ├── is-property@1.0.2 extraneous
    ├── is-regex@1.1.4 extraneous
    ├── is-scoped@2.1.0 extraneous
    ├── is-shared-array-buffer@1.0.3 extraneous
    ├── is-string@1.0.7 extraneous
    ├── is-symbol@1.0.4 extraneous
    ├── is-typed-array@1.1.13 extraneous
    ├── is-unicode-supported@0.1.0 extraneous
    ├── is-url-superb@4.0.0 extraneous
    ├── is-url@1.2.4 extraneous
    ├── is-weakref@1.0.2 extraneous
    ├── is-wsl@2.2.0 extraneous
    ├── is-yarn-global@0.3.0 extraneous
    ├── is@3.3.0 extraneous
    ├── is2@2.0.9 extraneous
    ├── isomorphic-ws@4.0.1 extraneous
    ├── issue-regex@3.1.0 extraneous
    ├── jackspeak@3.4.3 extraneous
    ├── js-md4@0.3.2 extraneous
    ├── js-sdsl@4.3.0 extraneous
    ├── js-tokens@4.0.0 extraneous
    ├── js-yaml@ extraneous
    ├── jsbi@4.3.0 extraneous
    ├── jsbn@1.1.0 extraneous
    ├── jsdom@ extraneous
    ├── jshashes@1.0.8 extraneous
    ├── json-buffer@3.0.1 extraneous
    ├── json-logic-js@2.0.5 extraneous
    ├── json-parse-even-better-errors@2.3.1 extraneous
    ├── json-schema-traverse@1.0.0 extraneous
    ├── json5@2.2.3 extraneous
    ├── jsonata@ extraneous
    ├── jsonc-parser@3.3.1 extraneous
    ├── jsonwebtoken@9.0.2 extraneous
    ├── jszip@ extraneous
    ├── jwa@2.0.0 extraneous
    ├── jws@4.0.0 extraneous
    ├── keyv@4.5.4 extraneous
    ├── kind-of@6.0.3 extraneous
    ├── kuler@2.0.0 extraneous
    ├── later@1.2.0 extraneous
    ├── latest-version@5.1.0 extraneous
    ├── layerr@0.1.2 extraneous
    ├── lazystream@1.0.1 extraneous
    ├── leven@2.1.0 extraneous
    ├── levn@0.3.0 extraneous
    ├── lie@3.3.0 extraneous
    ├── lines-and-columns@1.2.4 extraneous
    ├── listr-input@0.2.1 extraneous
    ├── listr-silent-renderer@1.1.1 extraneous
    ├── listr-update-renderer@0.5.0 extraneous
    ├── listr-verbose-renderer@0.5.0 extraneous
    ├── listr@0.14.3 extraneous
    ├── loadavg-windows@1.1.1 extraneous
    ├── locate-path@6.0.0 extraneous
    ├── lodash.defaults@4.2.0 extraneous
    ├── lodash.flatten@4.4.0 extraneous
    ├── lodash.includes@4.3.0 extraneous
    ├── lodash.isarguments@3.1.0 extraneous
    ├── lodash.isboolean@3.0.3 extraneous
    ├── lodash.isequal@4.5.0 extraneous
    ├── lodash.isinteger@4.0.4 extraneous
    ├── lodash.isnumber@3.0.3 extraneous
    ├── lodash.isplainobject@4.0.6 extraneous
    ├── lodash.isstring@4.0.1 extraneous
    ├── lodash.once@4.1.1 extraneous
    ├── lodash.zip@4.2.0 extraneous
    ├── log-symbols@4.1.0 extraneous
    ├── log-update@2.3.0 extraneous
    ├── logform@ extraneous
    ├── long@5.2.3 extraneous
    ├── lowercase-keys@2.0.0 extraneous
    ├── lru_map@0.3.3 extraneous
    ├── lru-cache@6.0.0 extraneous
    ├── make-dir@3.1.0 extraneous
    ├── make-fetch-happen@10.2.1 extraneous
    ├── map-age-cleaner@0.1.3 extraneous
    ├── map-obj@4.3.0 extraneous
    ├── map-stream@0.0.7 extraneous
    ├── md5@2.3.0 extraneous
    ├── media-typer@0.3.0 extraneous
    ├── meow@8.1.2 extraneous
    ├── merge-descriptors@1.0.1 extraneous
    ├── merge2@1.4.1 extraneous
    ├── methods@1.1.2 extraneous
    ├── micro@9.4.1 extraneous
    ├── micromatch@4.0.7 extraneous
    ├── mime-db@1.53.0 extraneous
    ├── mimic-response@1.0.1 extraneous
    ├── min-indent@1.0.1 extraneous
    ├── minimatch@9.0.5 extraneous
    ├── minimist-options@4.1.0 extraneous
    ├── minipass-collect@1.0.2 extraneous
    ├── minipass-fetch@2.1.2 extraneous
    ├── minipass-flush@1.0.5 extraneous
    ├── minipass-pipeline@1.2.4 extraneous
    ├── minipass-sized@1.0.3 extraneous
    ├── minipass@7.1.2 extraneous
    ├── minizlib@2.1.2 extraneous
    ├── mkdirp-classic@0.5.3 extraneous
    ├── mkdirp@1.0.4 extraneous
    ├── mock-require@3.0.3 extraneous
    ├── moment-duration-format@2.3.2 extraneous
    ├── mqtt-connection@4.1.0 extraneous
    ├── mqtt-packet@9.0.0 extraneous
    ├── mqtt@ extraneous
    ├── mute-stream@0.0.8 extraneous
    ├── named-placeholders@1.1.3 extraneous
    ├── nan@ extraneous
    ├── nanoid@3.3.7 extraneous
    ├── napi-build-utils@1.0.2 extraneous
    ├── native-duplexpair@1.0.0 extraneous
    ├── nconf@0.10.0 extraneous
    ├── nested-property@4.0.0 extraneous
    ├── netmask@2.0.2 extraneous
    ├── new-github-release-url@1.0.0 extraneous
    ├── node-abi@3.65.0 extraneous
    ├── node-abort-controller@3.1.1 extraneous
    ├── node-cron@2.0.3 extraneous
    ├── node-fetch@2.7.0 extraneous
    ├── node-forge@ extraneous
    ├── node-gyp@ extraneous
    ├── node-ical@0.16.1 extraneous
    ├── node-inspect@2.0.0 extraneous
    ├── node-libcurl@3.0.0 extraneous
    ├── node-mndp@0.0.3 extraneous
    ├── node-persist@0.0.11 extraneous
    ├── node-rsa@1.1.1 extraneous
    ├── node-unifi@2.5.1 extraneous
    ├── node-wol@0.1.1 extraneous
    ├── node.extend@2.0.3 extraneous
    ├── nopt@5.0.0 extraneous
    ├── normalize-package-data@3.0.3 extraneous
    ├── normalize-path@3.0.0 extraneous
    ├── normalize-url@6.1.0 extraneous
    ├── np@7.7.0 extraneous
    ├── npm-name@6.0.1 extraneous
    ├── npmlog@5.0.1 extraneous
    ├── number-allocator@1.0.14 extraneous
    ├── nwsapi@2.2.12 extraneous
    ├── object-assign@4.1.1 extraneous
    ├── object-hash@3.0.0 extraneous
    ├── on-finished@2.4.1 extraneous
    ├── once@1.4.0 extraneous
    ├── one-time@1.0.0 extraneous
    ├── onedrive-api@1.1.1 extraneous
    ├── open@7.4.2 extraneous
    ├── opencollective-postinstall@2.0.3 extraneous
    ├── optionator@0.8.3 extraneous
    ├── org-regex@1.0.0 extraneous
    ├── os-tmpdir@1.0.2 extraneous
    ├── ospath@1.2.2 extraneous
    ├── osx-temperature-sensor@ extraneous
    ├── otplib@11.0.1 extraneous
    ├── ow@0.21.0 extraneous
    ├── p-cancelable@2.1.1 extraneous
    ├── p-defer@1.0.0 extraneous
    ├── p-event@4.2.0 extraneous
    ├── p-finally@1.0.0 extraneous
    ├── p-limit@2.3.0 extraneous
    ├── p-locate@5.0.0 extraneous
    ├── p-map@2.1.0 extraneous
    ├── p-memoize@4.0.4 extraneous
    ├── p-reflect@2.1.0 extraneous
    ├── p-settle@4.1.1 extraneous
    ├── p-throttle@4.1.1 extraneous
    ├── p-timeout@4.1.0 extraneous
    ├── p-try@2.2.0 extraneous
    ├── package-json-from-dist@1.0.0 extraneous
    ├── package-json@6.5.0 extraneous
    ├── pako@ extraneous
    ├── parent-module@1.0.1 extraneous
    ├── parse-json@5.2.0 extraneous
    ├── parse5@ extraneous
    ├── passport-local@1.0.0 extraneous
    ├── passport@0.7.0 extraneous
    ├── path-exists@4.0.0 extraneous
    ├── path-is-absolute@1.0.1 extraneous
    ├── path-parse@1.0.7 extraneous
    ├── path-posix@1.0.0 extraneous
    ├── path-scurry@1.11.1 extraneous
    ├── path-to-regexp@0.1.7 extraneous
    ├── path-type@4.0.0 extraneous
    ├── pause-stream@0.0.11 extraneous
    ├── picomatch@2.3.1 extraneous
    ├── pidtree@0.6.0 extraneous
    ├── pidusage@3.0.2 extraneous
    ├── ping@0.4.4 extraneous
    ├── pkg-dir@5.0.0 extraneous
    ├── pluralize@8.0.0 extraneous
    ├── possible-typed-array-names@1.0.0 extraneous
    ├── prebuild-install@7.1.2 extraneous
    ├── prelude-ls@1.1.2 extraneous
    ├── prepend-http@2.0.0 extraneous
    ├── process-nextick-args@2.0.1 extraneous
    ├── process@0.11.10 extraneous
    ├── promise-inflight@1.0.1 extraneous
    ├── promise-object@0.1.7 extraneous
    ├── promise-retry@2.0.1 extraneous
    ├── promise-retryer@0.0.1 extraneous
    ├── promisify-child-process@4.1.2 extraneous
    ├── prompt@1.3.0 extraneous
    ├── protobufjs@ extraneous
    ├── proxy-addr@2.0.7 extraneous
    ├── proxy-from-env@1.1.0 extraneous
    ├── pump@3.0.0 extraneous
    ├── pupa@2.1.1 extraneous
    ├── q@1.1.2 extraneous
    ├── quasar@ extraneous
    ├── queue-microtask@1.2.3 extraneous
    ├── queue-tick@1.0.1 extraneous
    ├── quick-lru@5.1.1 extraneous
    ├── range-parser@1.2.1 extraneous
    ├── raw-body@2.5.2 extraneous
    ├── rc@1.2.8 extraneous
    ├── read-pkg-up@7.0.1 extraneous
    ├── read-pkg@5.2.0 extraneous
    ├── read@1.0.7 extraneous
    ├── readable-stream@ extraneous
    ├── readdir-glob@1.1.3 extraneous
    ├── readdirp@3.6.0 extraneous
    ├── readline-sync@1.4.10 extraneous
    ├── readline@1.3.0 extraneous
    ├── redent@3.0.0 extraneous
    ├── redis-commands@1.7.0 extraneous
    ├── redis-errors@1.2.0 extraneous
    ├── redis-parser@3.0.0 extraneous
    ├── regenerator-runtime@0.14.1 extraneous
    ├── regex-escape@3.4.10 extraneous
    ├── regexp.prototype.flags@1.5.2 extraneous
    ├── registry-auth-token@4.2.2 extraneous
    ├── registry-url@5.1.0 extraneous
    ├── reinterval@1.1.0 extraneous
    ├── remove-trailing-separator@1.1.0 extraneous
    ├── require-from-string@2.0.2 extraneous
    ├── resolve-alpn@1.2.1 extraneous
    ├── resolve-cwd@3.0.0 extraneous
    ├── resolve-from@4.0.0 extraneous
    ├── respjs@4.2.0 extraneous
    ├── responselike@2.0.1 extraneous
    ├── restore-cursor@3.1.0 extraneous
    ├── retry-axios@2.6.0 extraneous
    ├── retry@0.12.0 extraneous
    ├── reusify@1.0.4 extraneous
    ├── revalidator@0.1.8 extraneous
    ├── rfdc@1.4.1 extraneous
    ├── rimraf@3.0.2 extraneous
    ├── rrule@2.8.1 extraneous
    ├── rrweb-cssom@0.6.0 extraneous
    ├── run-async@2.4.1 extraneous
    ├── run-parallel@1.2.0 extraneous
    ├── rxjs@ extraneous
    ├── safe-array-concat@1.1.2 extraneous
    ├── safe-regex-test@1.0.3 extraneous
    ├── safe-stable-stringify@2.4.3 extraneous
    ├── safer-buffer@2.1.2 extraneous
    ├── saxes@6.0.0 extraneous
    ├── scoped-regex@2.1.0 extraneous
    ├── secure-keys@1.0.0 extraneous
    ├── semver-diff@3.1.1 extraneous
    ├── semver@5.7.2
    ├── send@0.18.0 extraneous
    ├── seq-logging@1.1.2 extraneous
    ├── seq-queue@0.0.5 extraneous
    ├── serve-static@1.15.0 extraneous
    ├── set-function-name@2.0.2 extraneous
    ├── setimmediate@1.0.5 extraneous
    ├── setprototypeof@1.2.0 extraneous
    ├── signal-exit@4.1.0 extraneous
    ├── simple-concat@1.0.1 extraneous
    ├── simple-get@3.1.1 extraneous
    ├── simple-ssh@1.1.1 extraneous
    ├── simple-swizzle@0.2.2 extraneous
    ├── slash@3.0.0 extraneous
    ├── slice-ansi@0.0.4 extraneous
    ├── smart-buffer@4.2.0 extraneous
    ├── socks-proxy-agent@7.0.0 extraneous
    ├── socks@2.8.3 extraneous
    ├── speedtest-net@1.6.2 extraneous
    ├── split@1.0.1 extraneous
    ├── sprintf-js@1.1.3 extraneous
    ├── sqlstring@2.3.3 extraneous
    ├── ssh2@ extraneous
    ├── ssri@9.0.1 extraneous
    ├── stack-trace@0.0.10 extraneous
    ├── stampit-event-bus@0.1.1 extraneous
    ├── stampit-state-machine@0.2.1 extraneous
    ├── stampit@2.1.2 extraneous
    ├── standard-as-callback@2.1.0 extraneous
    ├── static-eval@2.0.2 extraneous
    ├── statuses@2.0.1 extraneous
    ├── stoppable@1.1.0 extraneous
    ├── stream-combiner@0.2.2 extraneous
    ├── stream-shift@1.0.3 extraneous
    ├── streamsearch@1.1.0 extraneous
    ├── streamx@2.18.0 extraneous
    ├── string-argv@0.3.2 extraneous
    ├── string-width-cjs@npm:string-width@4.2.3 extraneous
    ├── string-width@5.1.2 extraneous
    ├── string.prototype.trim@1.2.9 extraneous
    ├── string.prototype.trimend@1.0.8 extraneous
    ├── string.prototype.trimstart@1.0.8 extraneous
    ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
    ├── strip-ansi@6.0.1 extraneous
    ├── strip-indent@3.0.0 extraneous
    ├── strip-json-comments@2.0.1 extraneous
    ├── strnum@1.0.5 extraneous
    ├── suncalc@1.9.0 extraneous
    ├── suncalc2@1.8.1 extraneous
    ├── supermixer@1.0.5 extraneous
    ├── supports-color@7.2.0 extraneous
    ├── supports-hyperlinks@2.3.0 extraneous
    ├── supports-preserve-symlinks-flag@1.0.0 extraneous
    ├── sweet-collections@1.1.0 extraneous
    ├── symbol-observable@3.0.0 extraneous
    ├── symbol-tree@3.2.4 extraneous
    ├── syno@ extraneous
    ├── systeminformation@ extraneous
    ├── tar-fs@2.1.1 extraneous
    ├── tar-stream@3.1.7 extraneous
    ├── tar@6.2.1 extraneous
    ├── tarn@3.0.2 extraneous
    ├── tcp-port-used@1.0.2 extraneous
    ├── tedious@ extraneous
    ├── terminal-link@2.1.1 extraneous
    ├── text-decoder@1.1.1 extraneous
    ├── text-hex@1.0.0 extraneous
    ├── thirty-two@1.0.2 extraneous
    ├── through@2.3.8 extraneous
    ├── through2@2.0.5 extraneous
    ├── tiny-typed-emitter@2.1.0 extraneous
    ├── tinycolor2@1.6.0 extraneous
    ├── tmp@0.0.33 extraneous
    ├── to-readable-stream@2.1.0 extraneous
    ├── to-regex-range@5.0.1 extraneous
    ├── toidentifier@1.0.1 extraneous
    ├── tr46@4.1.1 extraneous
    ├── trim-newlines@3.0.1 extraneous
    ├── triple-beam@1.4.1 extraneous
    ├── tsdav@ extraneous
    ├── tslib@2.3.0 extraneous
    ├── tweetnacl@0.14.5 extraneous
    ├── type-check@0.3.2 extraneous
    ├── type-fest@0.21.3 extraneous
    ├── type-is@1.6.18 extraneous
    ├── typed-array-buffer@1.0.2 extraneous
    ├── typed-array-byte-length@1.0.1 extraneous
    ├── typed-array-byte-offset@1.0.2 extraneous
    ├── typed-array-length@1.0.6 extraneous
    ├── typedarray-to-buffer@3.1.5 extraneous
    ├── typedarray.prototype.slice@1.0.3 extraneous
    ├── typescript@ extraneous
    ├── tz-offset@0.0.1 extraneous
    ├── uid-number@0.0.6 extraneous
    ├── unbox-primitive@1.0.2 extraneous
    ├── undici-types@6.19.6 extraneous
    ├── unique-filename@2.0.1 extraneous
    ├── unique-slug@3.0.0 extraneous
    ├── unique-string@2.0.0 extraneous
    ├── unix-dgram@2.0.6 extraneous
    ├── unpipe@1.0.0 extraneous
    ├── update-notifier@5.1.0 extraneous
    ├── uri-js@4.4.1 extraneous
    ├── url-join@4.0.1 extraneous
    ├── url-parse-lax@3.0.0 extraneous
    ├── url-template@2.0.8 extraneous
    ├── url@0.11.4 extraneous
    ├── vali-date@1.0.0 extraneous
    ├── validate-npm-package-name@3.0.0 extraneous
    ├── vary@1.1.2 extraneous
    ├── virtual-tsc@0.6.2 extraneous
    ├── vue-i18n@ extraneous
    ├── vuelidate-messages@0.1.2 extraneous
    ├── vuelidate@ extraneous
    ├── vuex-map-fields@1.4.1 extraneous
    ├── w3c-xmlserializer@4.0.0 extraneous
    ├── wake_on_lan@1.0.0 extraneous
    ├── weak-daemon@1.0.3 extraneous
    ├── webdav@ extraneous
    ├── webidl-conversions@7.0.0 extraneous
    ├── websocket-stream@5.5.2 extraneous
    ├── whatwg-encoding@2.0.0 extraneous
    ├── whatwg-mimetype@3.0.0 extraneous
    ├── whatwg-url@12.0.1 extraneous
    ├── which-boxed-primitive@1.0.2 extraneous
    ├── which-typed-array@1.1.15 extraneous
    ├── wide-align@1.1.5 extraneous
    ├── widest-line@3.1.0 extraneous
    ├── window-size@0.1.4 extraneous
    ├── winston-daily-rotate-file@5.0.0 extraneous
    ├── winston-seq-updated@1.0.4 extraneous
    ├── winston-syslog@2.7.1 extraneous
    ├── winston-transport@4.7.1 extraneous
    ├── winston@ extraneous
    ├── word-wrap@1.2.5 extraneous
    ├── worker-timers-broker@6.1.8 extraneous
    ├── worker-timers-worker@7.0.71 extraneous
    ├── worker-timers@7.1.8 extraneous
    ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
    ├── wrap-ansi@8.1.0 extraneous
    ├── wrappy@1.0.2 extraneous
    ├── write-file-atomic@3.0.3 extraneous
    ├── xdg-basedir@4.0.0 extraneous
    ├── xml-js@1.6.11 extraneous
    ├── xml-name-validator@4.0.0 extraneous
    ├── xmlchars@2.2.0 extraneous
    ├── xregexp@2.0.0 extraneous
    ├── yallist@4.0.0 extraneous
    ├── yaml@ extraneous
    ├── yargs-parser@20.2.9 extraneous
    ├── yargs@7.1.2
    ├── yocto-queue@0.1.0 extraneous
    ├── zip-stream@6.0.1 extraneous
    └── zrender@ extraneous
    F 1 Antwort Letzte Antwort
    • F flommaster
      zu viele Fehler...
      Teil 1
      ├── ajv@ extraneous
      ├── colors@1.4.0
      ├── crc@ extraneous
      ├── fs-extra@7.0.1
      ├── iobroker@2.0.3
      ├── nan@ extraneous
      ├── semver@5.7.2
      ├── yargs@7.1.2
      flommaster
      Teil 2
      npm error code ELSPROBLEMS
      npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
      npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
      npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
      npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
      npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
      npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
      npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
      npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
      npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
      npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
      npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
      npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
      npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
      npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
      npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
      npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
      npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
      npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
      npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
      npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
      npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
      npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
      npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
      npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
      npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
      npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
      npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
      npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
      npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
      npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
      npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
      npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
      npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
      npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
      npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
      npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
      npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
      npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
      npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
      npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
      npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
      npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
      npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
      npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
      npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
      npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
      npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
      npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
      npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
      npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
      npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
      npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
      npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
      npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
      npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
      npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
      npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
      npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
      npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
      npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
      npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
      npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
      npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
      npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
      npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
      npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
      npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
      npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
      npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
      npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
      npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
      npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
      npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
      npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
      npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
      npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
      npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
      npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
      npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
      npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
      npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
      npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
      npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
      npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
      npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
      npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
      npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
      npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
      npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
      npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
      npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
      npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
      npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
      npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
      npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
      npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
      npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
      npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
      npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
      npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
      npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
      npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
      npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
      npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
      npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
      npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
      npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
      npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
      npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
      npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
      npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
      npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
      npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
      npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
      npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
      npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
      npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
      npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
      npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
      npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
      npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
      npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
      npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
      npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
      npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
      npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
      npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
      npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
      npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
      npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
      npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
      npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
      npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
      npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
      npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
      npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
      npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
      npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
      npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
      npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
      npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
      npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
      npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
      npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
      npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
      npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
      npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
      npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
      npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
      npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
      npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
      npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
      npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
      npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
      npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
      npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
      npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
      npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
      npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
      npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
      npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
      npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
      npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
      npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
      npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
      npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
      npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
      npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
      npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
      npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
      npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
      npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
      npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
      npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
      npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
      npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
      npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
      npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
      npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
      npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
      npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
      npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
      npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
      npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
      npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
      npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
      npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
      npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
      npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
      npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
      npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
      npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
      npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
      npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
      npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
      npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
      npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
      npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
      npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
      npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
      npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
      npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
      npm error extraneous: crc@ /opt/iobroker/node_modules/crc
      npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
      npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
      npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
      npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
      npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
      npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
      npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
      npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
      npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
      npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
      npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
      npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
      npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
      npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
      npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
      npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
      npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
      npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
      npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
      npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
      npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
      npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
      npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
      npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
      npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
      npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
      npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
      npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
      npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
      npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
      npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
      npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
      npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
      npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
      npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
      npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
      npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
      npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
      npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
      npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
      npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
      npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
      npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
      npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
      npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
      npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
      npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
      npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
      npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
      npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
      npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
      npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
      npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
      npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
      npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
      npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
      npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
      npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
      npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
      npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
      npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
      npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
      npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
      npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
      npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
      npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
      npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
      npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
      npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
      npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
      npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
      npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
      npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
      npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
      npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
      npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
      npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
      npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
      npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
      npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
      npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
      npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
      npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
      npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
      npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
      npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
      npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
      npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
      npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
      npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
      npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
      npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
      npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
      npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
      npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
      npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
      npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
      npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
      npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
      npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
      npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
      npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
      npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
      npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
      npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
      npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
      npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
      npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
      npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
      npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
      npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
      npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
      npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
      npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
      npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
      npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
      npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
      npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
      npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
      npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
      npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
      npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
      npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
      npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
      npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
      npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
      npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
      npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
      npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
      npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
      npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
      npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
      npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
      npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
      npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
      npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
      npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
      npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
      npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
      npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
      npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
      npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
      npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
      npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
      npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
      npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
      npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
      npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
      npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
      npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
      npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
      npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
      npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
      npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
      npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
      npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
      npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
      npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
      npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
      npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
      npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
      npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
      npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
      npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
      npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
      npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
      npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
      npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
      npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
      npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
      npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
      npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
      npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
      npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
      npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
      npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
      npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
      npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
      npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
      npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
      npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
      npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
      npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
      npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
      npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
      npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
      npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
      npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
      npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
      npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
      npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
      npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
      npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
      npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
      npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
      npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
      npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
      npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
      npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
      npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
      npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
      npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
      npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
      npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
      npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
      npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
      npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
      npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
      npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
      npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
      npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
      npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
      npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
      npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
      npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
      npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
      npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
      npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
      npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
      npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
      npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
      npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
      npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
      npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
      npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
      npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
      npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
      npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
      npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
      npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
      npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
      npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
      npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
      npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
      npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
      npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
      npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
      npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
      npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
      npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
      npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
      npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
      npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
      npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
      npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
      npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
      npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
      npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
      npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
      npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
      npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
      npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
      npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
      npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
      npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
      npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
      npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
      npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
      npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
      npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
      npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
      npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
      npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
      npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
      npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
      npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
      npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
      npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
      npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
      npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
      npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
      npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
      npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
      npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
      npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
      npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
      npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
      npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
      npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
      npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
      npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
      npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
      npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
      npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
      npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
      npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
      npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
      npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
      npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
      npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
      npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
      npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
      npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
      npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
      npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
      npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
      npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
      npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
      npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
      npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
      npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
      npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
      npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
      npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
      npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
      npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
      npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
      npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
      npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
      npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
      npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
      npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
      npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
      npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
      npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
      npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
      npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
      npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
      npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
      npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
      npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
      npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
      npm error extraneous: logform@ /opt/iobroker/node_modules/logform
      npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
      npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
      npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
      npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
      npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
      npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
      npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
      npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
      npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
      npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
      npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
      npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
      npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
      npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
      npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
      npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
      npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
      npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
      npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
      npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
      npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
      npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
      npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
      npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
      npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
      npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
      npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
      npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
      npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
      npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
      npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
      npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
      npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
      npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
      npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
      npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
      npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
      npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
      npm error extraneous: nan@ /opt/iobroker/node_modules/nan
      npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
      npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
      npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
      npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
      npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
      npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
      npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
      npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
      npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
      npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
      npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
      npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
      npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
      npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
      npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
      npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
      npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
      npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
      npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
      npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
      npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
      npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
      npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
      npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
      npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
      npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
      npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
      npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
      npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
      npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
      npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
      npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
      npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
      npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
      npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
      npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
      npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
      npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
      npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
      npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
      npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
      npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
      npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
      npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
      npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
      npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
      npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
      npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
      npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
      npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
      npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
      npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
      npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
      npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
      npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
      npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
      npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
      npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
      npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
      npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
      npm error extraneous: pako@ /opt/iobroker/node_modules/pako
      npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
      npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
      npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
      npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
      npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
      npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
      npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
      npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
      npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
      npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
      npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
      npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
      npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
      npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
      npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
      npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
      npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
      npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
      npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
      npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
      npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
      npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
      npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
      npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
      npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
      npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
      npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
      npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
      npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
      npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
      npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
      npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
      npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
      npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
      npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
      npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
      npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
      npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
      npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
      npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
      npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
      npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
      npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
      npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
      npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
      npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
      npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
      npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
      npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
      npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
      npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
      npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
      npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
      npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
      npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
      npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
      npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
      npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
      npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
      npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
      npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
      npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
      npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
      npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
      npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
      npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
      npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
      npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
      npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
      npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
      npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
      npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
      npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
      npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
      npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
      npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
      npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
      npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
      npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
      npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
      npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
      npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
      npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
      npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
      npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
      npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
      npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
      npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
      npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
      npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
      npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
      npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
      npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
      npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
      npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
      npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
      npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
      npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
      npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
      npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
      npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
      npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
      npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
      npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
      npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
      npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
      npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
      npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
      npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
      npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
      npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
      npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
      npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
      npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
      npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
      npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
      npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
      npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
      npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
      npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
      npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
      npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
      npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
      npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
      npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
      npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
      npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
      npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
      npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
      npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
      npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
      npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
      npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
      npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
      npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
      npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
      npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
      npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
      npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
      npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
      npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
      npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
      npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
      npm error extraneous: syno@ /opt/iobroker/node_modules/syno
      npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
      npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
      npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
      npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
      npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
      npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
      npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
      npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
      npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
      npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
      npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
      npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
      npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
      npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
      npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
      npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
      npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
      npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
      npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
      npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
      npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
      npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
      npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
      npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
      npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
      npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
      npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
      npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
      npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
      npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
      npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
      npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
      npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
      npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
      npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
      npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
      npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
      npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
      npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
      npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
      npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
      npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
      npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
      npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
      npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
      npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
      npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
      npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
      npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
      npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
      npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
      npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
      npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
      npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
      npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
      npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
      npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
      npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
      npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
      npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
      npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
      npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
      npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
      npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
      npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
      npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
      npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
      npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
      npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
      npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
      npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
      npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
      npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
      npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
      npm error extraneous: winston@ /opt/iobroker/node_modules/winston
      npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
      npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
      npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
      npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
      npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
      npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
      npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
      npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
      npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
      npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
      npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
      npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
      npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
      npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
      npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
      npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
      npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
      npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
      npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_54_40_124Z-debug-0.log
      • mcm1957M mcm1957
        Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
        npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
        Den Adapter gibts (dort) gar nicht ...
        @mcm1957 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
        War mich auch schon in's Auge gesprungen.
        F 1 Antwort Letzte Antwort
          flommaster
          @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
          Keine Ahnung.
          Soll ich das System komplett neu aufsetzen?
          • F flommaster
            Keine Ahnung.
            @flommaster
            npm prune
            npm ls
            • F flommaster
              Keine Ahnung.
              @flommaster
              Das kommt davon, wenn man da alles und jedes (Ich hab da jetzt 13 Kandidaten gezählt) über github installiert und nicht ordentlich aus einem Repo.
              Da wird wohl einer der Adapter gelöscht oder verschoben worden sein sein. Das führt dann für alle anderen Adapter zu der Meldung
              invalid "blablubb" from the root project
                @flommaster
                flommaster
                Der Befehl "npm prune" liefert folgendes Ergebnis:
                Kann ich die github Installationen löschen?
                npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                npm warn deprecated har-validator@5.1.5: this library is no longer supported
                npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                npm warn deprecated
                npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                npm warn deprecated gauge@3.0.2: This package is no longer supported.
                npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm warn deprecated gauge@4.0.4: This package is no longer supported.
                npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                npm error git dep preparation failed
                npm error signal SIGINT
                npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                npm error npm warn using --force Recommended protections disabled.
                • F flommaster
                  npm warn deprecated
                  @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                  Vollständig.
                  Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                  F 2 Antworten Letzte Antwort
                    Vollständig.
                    flommaster
                    Gerne. Hier der komplette Auszug (Teil 1)
                    flo@ioBrokerdebian:/opt/iobroker$ npm prune
                    npm ls
                    npm warn deprecated
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
                    iobroker.inst@2.0.3 /opt/iobroker
                    ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                    ├── @alcalzone/jsonl-db@3.1.1 extraneous
                    ├── @alcalzone/pak@0.8.1 extraneous
                    ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                    ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                    ├── @azure/abort-controller@1.1.0 extraneous
                    ├── @azure/core-auth@1.7.2 extraneous
                    ├── @azure/core-client@ extraneous
                    ├── @azure/core-http-compat@ extraneous
                    ├── @azure/core-lro@ extraneous
                    ├── @azure/core-paging@1.6.2 extraneous
                    ├── @azure/core-rest-pipeline@ extraneous
                    ├── @azure/core-tracing@1.1.2 extraneous
                    ├── @azure/core-util@ extraneous
                    ├── @azure/identity@ extraneous
                    ├── @azure/keyvault-keys@ extraneous
                    ├── @azure/logger@1.1.4 extraneous
                    ├── @azure/msal-browser@ extraneous
                    ├── @azure/msal-common@ extraneous
                    ├── @azure/msal-node@1.18.4 extraneous
                    ├── @babel/code-frame@7.24.7 extraneous
                    ├── @babel/helper-validator-identifier@7.24.7 extraneous
                    ├── @babel/highlight@7.24.7 extraneous
                    ├── @babel/runtime@ extraneous
                    ├── @colors/colors@1.5.0 extraneous
                    ├── @dabh/diagnostics@2.0.3 extraneous
                    ├── @datalust/winston-seq@1.0.2 extraneous
                    ├── @gar/promisify@1.1.3 extraneous
                    ├── @googleapis/calendar@9.7.7 extraneous
                    ├── @googleapis/drive@5.1.0 extraneous
                    ├── @googleapis/oauth2@1.0.7 extraneous
                    ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                    ├── @iobroker/db-base@ extraneous
                    ├── @iobroker/db-objects-file@ extraneous
                    ├── @iobroker/db-objects-jsonl@ extraneous
                    ├── @iobroker/db-objects-redis@ extraneous
                    ├── @iobroker/db-states-file@ extraneous
                    ├── @iobroker/db-states-jsonl@ extraneous
                    ├── @iobroker/db-states-redis@ extraneous
                    ├── @iobroker/js-controller-adapter@ extraneous
                    ├── @iobroker/js-controller-cli@ extraneous
                    ├── @iobroker/js-controller-common-db@ extraneous
                    ├── @iobroker/js-controller-common@ extraneous
                    ├── @iobroker/plugin-base@1.2.1 extraneous
                    ├── @iobroker/plugin-sentry@1.2.1 extraneous
                    ├── @iobroker/socket-classes@1.5.6 extraneous
                    ├── @iobroker/webserver@1.0.3 extraneous
                    ├── @isaacs/cliui@8.0.2 extraneous
                    ├── @js-joda/core@ extraneous
                    ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                    ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                    ├── @nodelib/fs.scandir@2.1.5 extraneous
                    ├── @nodelib/fs.stat@2.0.5 extraneous
                    ├── @nodelib/fs.walk@1.2.8 extraneous
                    ├── @npmcli/fs@2.1.2 extraneous
                    ├── @npmcli/move-file@2.0.1 extraneous
                    ├── @pkgjs/parseargs@0.11.0 extraneous
                    ├── @protobufjs/aspromise@1.1.2 extraneous
                    ├── @protobufjs/base64@1.1.2 extraneous
                    ├── @protobufjs/codegen@2.0.4 extraneous
                    ├── @protobufjs/eventemitter@1.1.0 extraneous
                    ├── @protobufjs/fetch@1.1.0 extraneous
                    ├── @protobufjs/float@1.0.2 extraneous
                    ├── @protobufjs/inquire@1.1.0 extraneous
                    ├── @protobufjs/path@1.1.2 extraneous
                    ├── @protobufjs/pool@1.1.0 extraneous
                    ├── @protobufjs/utf8@1.1.0 extraneous
                    ├── @quasar/extras@ extraneous
                    ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                    ├── @sentry-internal/tracing@ extraneous
                    ├── @sentry/core@5.30.0 extraneous
                    ├── @sentry/hub@5.30.0 extraneous
                    ├── @sentry/minimal@5.30.0 extraneous
                    ├── @sentry/node@ extraneous
                    ├── @sentry/tracing@ extraneous
                    ├── @sentry/types@ extraneous
                    ├── @sentry/utils@ extraneous
                    ├── @sindresorhus/is@4.6.0 extraneous
                    ├── @socket.io/component-emitter@3.1.2 extraneous
                    ├── @szmarczak/http-timer@4.0.6 extraneous
                    ├── @tediousjs/connection-string@0.5.0 extraneous
                    ├── @tootallnate/once@2.0.0 extraneous
                    ├── @types/bl@5.1.0 extraneous
                    ├── @types/cacheable-request@6.0.3 extraneous
                    ├── @types/caseless@0.12.5 extraneous
                    ├── @types/cookie@0.4.1 extraneous
                    ├── @types/cors@2.8.17 extraneous
                    ├── @types/geojson@7946.0.14 extraneous
                    ├── @types/http-cache-semantics@4.0.4 extraneous
                    ├── @types/keyv@3.1.4 extraneous
                    ├── @types/leaflet@1.9.12 extraneous
                    ├── @types/minimist@1.2.5 extraneous
                    ├── @types/node-cron@2.0.8 extraneous
                    ├── @types/node@ extraneous
                    ├── @types/normalize-package-data@2.4.4 extraneous
                    ├── @types/parse-json@4.0.2 extraneous
                    ├── @types/readable-stream@4.0.15 extraneous
                    ├── @types/request@2.48.12 extraneous
                    ├── @types/responselike@1.0.3 extraneous
                    ├── @types/tough-cookie@4.0.5 extraneous
                    ├── @types/triple-beam@1.3.5 extraneous
                    ├── @types/tz-offset@0.0.3 extraneous
                    ├── @types/ws@8.5.12 extraneous
                    ├── abab@2.0.6 extraneous
                    ├── abbrev@1.1.1 extraneous
                    ├── abort-controller@3.0.0 extraneous
                    ├── agentkeepalive@4.5.0 extraneous
                    ├── aggregate-error@3.1.0 extraneous
                    ├── ajv@ extraneous
                    ├── ansi-align@3.0.1 extraneous
                    ├── ansi-colors@4.1.3 extraneous
                    ├── ansi-escapes@4.3.2 extraneous
                    ├── ansi-regex@5.0.1 extraneous
                    ├── ansi-styles@4.3.0 extraneous
                    ├── any-observable@0.5.1 extraneous
                    ├── anymatch@3.1.3 extraneous
                    ├── aproba@2.0.0 extraneous
                    ├── archiver-utils@5.0.2 extraneous
                    ├── archiver@7.0.1 extraneous
                    ├── are-we-there-yet@2.0.0 extraneous
                    ├── arg@4.1.0 extraneous
                    ├── argparse@1.0.10 extraneous
                    ├── array-buffer-byte-length@1.0.1 extraneous
                    ├── array-flatten@1.1.1 extraneous
                    ├── array-union@2.1.0 extraneous
                    ├── arraybuffer.prototype.slice@1.0.3 extraneous
                    ├── arrify@2.0.1 extraneous
                    ├── asn1@0.2.6 extraneous
                    ├── async-exit-hook@2.0.1 extraneous
                    ├── authenticate-pam@1.0.5 extraneous
                    ├── available-typed-arrays@1.0.7 extraneous
                    ├── aws-crt@ extraneous
                    ├── b4a@1.6.6 extraneous
                    ├── balanced-match@1.0.2 extraneous
                    ├── bare-events@2.4.2 extraneous
                    ├── base-64@1.0.0 extraneous
                    ├── base64-js@1.5.1 extraneous
                    ├── bcrypt-pbkdf@1.0.2 extraneous
                    ├── binary-extensions@2.3.0 extraneous
                    ├── bindings@1.5.0 extraneous
                    ├── bl@6.0.14 extraneous
                    ├── bluebird@3.7.2 extraneous
                    ├── body-parser@1.20.2 extraneous
                    ├── bottleneck@2.19.5 extraneous
                    ├── boxen@5.1.2 extraneous
                    ├── brace-expansion@2.0.1 extraneous
                    ├── braces@3.0.3 extraneous
                    ├── buffer-crc32@1.0.0 extraneous
                    ├── buffer-equal-constant-time@1.0.1 extraneous
                    ├── buffer-shims@1.0.0 extraneous
                    ├── buffer@6.0.3 extraneous
                    ├── buildcheck@0.0.6 extraneous
                    ├── builtins@1.0.3 extraneous
                    ├── busboy@1.6.0 extraneous
                    ├── byte-length@1.0.2 extraneous
                    ├── bytes@3.1.2 extraneous
                    ├── cacache@16.1.3 extraneous
                    ├── cacheable-lookup@5.0.4 extraneous
                    ├── cacheable-request@7.0.4 extraneous
                    ├── callsites@3.1.0 extraneous
                    ├── camelcase-keys@6.2.2 extraneous
                    ├── camelcase@5.3.1 extraneous
                    ├── capitalize@2.0.4 extraneous
                    ├── chalk@4.1.2 extraneous
                    ├── chardet@0.7.0 extraneous
                    ├── charenc@0.0.2 extraneous
                    ├── chokidar@3.6.0 extraneous
                    ├── chownr@2.0.0 extraneous
                    ├── ci-info@3.9.0 extraneous
                    ├── clean-stack@2.2.0 extraneous
                    ├── cli-boxes@2.2.1 extraneous
                    ├── cli-cursor@3.1.0 extraneous
                    ├── cli-truncate@0.2.1 extraneous
                    ├── cli-width@3.0.0 extraneous
                    ├── clone-response@1.0.3 extraneous
                    ├── cloneextend@0.0.3 extraneous
                    ├── cluster-key-slot@1.1.2 extraneous
                    ├── coap-packet@1.1.1 extraneous
                    ├── coffeescript@1.12.7 extraneous
                    ├── color-convert@2.0.1 extraneous
                    ├── color-name@1.1.4 extraneous
                    ├── color-string@1.9.1 extraneous
                    ├── color-support@1.1.3 extraneous
                    ├── color@3.2.1 extraneous
                    ├── colors@1.4.0
                    ├── colorspace@1.1.4 extraneous
                    ├── commander@9.5.0 extraneous
                    ├── commist@3.2.0 extraneous
                    ├── compress-commons@6.0.2 extraneous
                    ├── compress-json@2.1.2 extraneous
                    ├── compressible@2.0.18 extraneous
                    ├── compression@1.7.4 extraneous
                    ├── concat-map@0.0.1 extraneous
                    ├── configstore@5.0.1 extraneous
                    ├── connect-flash@0.1.1 extraneous
                    ├── connect@3.7.0 extraneous
                    ├── console-control-strings@1.1.0 extraneous
                    ├── content-disposition@0.5.4 extraneous
                    ├── content-type@1.0.5 extraneous
                    ├── core-js@ extraneous
                    ├── cors@2.8.5 extraneous
                    ├── cosmiconfig@7.1.0 extraneous
                    ├── cpu-features@ extraneous
                    ├── crc-32@1.2.2 extraneous
                    ├── crc@ extraneous
                    ├── crc32-stream@6.0.0 extraneous
                    ├── cross-fetch@4.0.0 extraneous
                    ├── crypt@0.0.2 extraneous
                    ├── crypto-js@ extraneous
                    ├── crypto-random-string@2.0.0 extraneous
                    ├── cssstyle@ extraneous
                    ├── cycle@1.0.3 extraneous
                    ├── dashdash@1.14.1 extraneous
                    ├── data-urls@4.0.0 extraneous
                    ├── data-view-buffer@1.0.1 extraneous
                    ├── data-view-byte-length@1.0.1 extraneous
                    ├── data-view-byte-offset@1.0.0 extraneous
                    ├── date-and-time@ extraneous
                    ├── date-fns@1.30.1 extraneous
                    ├── dateformat@4.6.3 extraneous
                    ├── dayjs@ extraneous
                    ├── decache@4.6.2 extraneous
                    ├── decamelize-keys@1.1.1 extraneous
                    ├── decimal.js@10.4.3 extraneous
                    ├── decompress-response@6.0.0 extraneous
                    ├── deep-clone@3.0.3 extraneous
                    ├── deep-extend@0.6.0 extraneous
                    ├── deep-is@0.1.4 extraneous
                    ├── defer-to-connect@2.0.1 extraneous
                    ├── define-lazy-prop@2.0.0 extraneous
                    ├── del@6.1.1 extraneous
                    ├── delegates@1.0.0 extraneous
                    ├── denque@1.5.1 extraneous
                    ├── destroy@1.2.0 extraneous
                    ├── detect-libc@2.0.3 extraneous
                    ├── diacritics@1.3.0 extraneous
                    ├── digest-header@1.1.0 extraneous
                    ├── dir-glob@3.0.1 extraneous
                    ├── diskusage@1.2.0 extraneous
                    ├── domexception@4.0.0 extraneous
                    ├── dot-prop@6.0.1 extraneous
                    ├── draftlog@1.0.13 extraneous
                    ├── dropbox-v2-api@ extraneous
                    ├── duplexer@0.1.2 extraneous
                    ├── duplexer3@0.1.5 extraneous
                    ├── duplexify@3.7.1 extraneous
                    ├── eastasianwidth@0.2.0 extraneous
                    ├── ecc-jsbn@0.1.2 extraneous
                    ├── ecdsa-sig-formatter@1.0.11 extraneous
                    ├── echarts@ extraneous
                    ├── ee-first@1.1.1 extraneous
                    ├── elegant-spinner@1.0.1 extraneous
                    ├── emoji-regex@9.2.2 extraneous
                    ├── enabled@2.0.0 extraneous
                    ├── encodeurl@1.0.2 extraneous
                    ├── encoding@0.1.13 extraneous
                    ├── end-of-stream@1.4.4 extraneous
                    ├── entities@4.5.0 extraneous
                    ├── err-code@2.0.3 extraneous
                    ├── es-abstract@ extraneous
                    ├── es-aggregate-error@1.0.13 extraneous
                    ├── es-object-atoms@1.0.0 extraneous
                    ├── es-set-tostringtag@2.0.3 extraneous
                    ├── es-to-primitive@1.2.1 extraneous
                    ├── es6-promise@4.2.8 extraneous
                    ├── es6-promisify@5.0.0 extraneous
                    ├── esbuild@0.11.23 extraneous
                    ├── escalade@3.1.2 extraneous
                    ├── escape-goat@3.0.0 extraneous
                    ├── escape-html@1.0.3 extraneous
                    ├── escape-string-regexp@4.0.0 extraneous
                    ├── escodegen@1.14.3 extraneous
                    ├── esprima@1.2.2 extraneous
                    ├── estraverse@4.3.0 extraneous
                    ├── esutils@2.0.3 extraneous
                    ├── etag@1.8.1 extraneous
                    ├── event-stream@4.0.1 extraneous
                    ├── event-target-shim@5.0.1 extraneous
                    ├── eventemitter2@6.4.9 extraneous
                    ├── events@3.3.0 extraneous
                    ├── execa@5.1.1 extraneous
                    ├── expand-template@2.0.3 extraneous
                    ├── express-fileupload@1.5.1 extraneous
                    ├── express@4.19.2 extraneous
                    ├── external-editor@3.1.0 extraneous
                    ├── fast-deep-equal@3.1.3 extraneous
                    ├── fast-fifo@1.3.2 extraneous
                    ├── fast-glob@ extraneous
                    ├── fast-json-stable-stringify@2.1.0 extraneous
                    ├── fast-levenshtein@2.0.6 extraneous
                    ├── fast-text-encoding@1.0.6 extraneous
                    ├── fast-unique-numbers@ extraneous
                    ├── fast-uri@3.0.1 extraneous
                    ├── fast-xml-parser@ extraneous
                    ├── fastq@1.17.1 extraneous
                    ├── fastseries@2.0.0 extraneous
                    ├── fecha@4.2.3 extraneous
                    ├── figures@3.2.0 extraneous
                    ├── file-stream-rotator@0.6.1 extraneous
                    ├── file-type@10.11.0 extraneous
                    ├── file-uri-to-path@1.0.0 extraneous
                    ├── fill-range@7.1.1 extraneous
                    ├── finalhandler@1.2.0 extraneous
                    ├── find-up@5.0.0 extraneous
                    ├── fn.name@1.1.0 extraneous
                    ├── for-each@0.3.3 extraneous
                    ├── foreground-child@3.3.0 extraneous
                    ├── form-data-encoder@2.1.4 extraneous
                    ├── form-data@4.0.0 extraneous
                    ├── forwarded@0.2.0 extraneous
                    ├── fresh@0.5.2 extraneous
                    ├── from@0.1.7 extraneous
                    ├── fs-constants@1.0.0 extraneous
                    ├── fs-extra@7.0.1
                    ├── fs-minipass@2.1.0 extraneous
                    ├── fs.realpath@1.0.0 extraneous
                    ├── fsevents@ extraneous
                    ├── ftp@0.3.10 extraneous
                    ├── function.prototype.name@1.1.6 extraneous
                    ├── functions-have-names@1.2.3 extraneous
                    ├── futoin-hkdf@1.4.3 extraneous
                    ├── gauge@3.0.2 extraneous
                    ├── gaxios@5.1.3 extraneous
                    ├── gcp-metadata@5.3.0 extraneous
                    ├── generate-function@2.3.1 extraneous
                    ├── get-ssl-certificate@2.3.3 extraneous
                    ├── get-stream@5.2.0 extraneous
                    ├── get-symbol-description@1.0.2 extraneous
                    ├── getpass@0.1.7 extraneous
                    ├── github-from-package@0.0.0 extraneous
                    ├── github-url-from-git@1.5.0 extraneous
                    ├── glob-parent@5.1.2 extraneous
                    ├── glob@10.4.5 extraneous
                    ├── global-dirs@2.1.0 extraneous
                    ├── globalthis@1.0.4 extraneous
                    ├── globby@11.1.0 extraneous
                    ├── glossy@0.1.7 extraneous
                    ├── google-auth-library@ extraneous
                    ├── google-p12-pem@4.0.1 extraneous
                    ├── googleapis-common@6.0.4 extraneous
                    ├── googleapis@ extraneous
                    ├── gtoken@6.1.2 extraneous
                    ├── hard-rejection@2.1.0 extraneous
                    ├── has-ansi@2.0.0 extraneous
                    ├── has-bigints@1.0.2 extraneous
                    ├── has-flag@4.0.0 extraneous
                    ├── has-tostringtag@1.0.2 extraneous
                    ├── has-unicode@2.0.1 extraneous
                    ├── has-yarn@2.1.0 extraneous
                    ├── he@1.2.0 extraneous
                    ├── help-me@5.0.0 extraneous
                    ├── homebridge-plugin-wrapper@ extraneous
                    ├── hosted-git-info@3.0.8 extraneous
                    ├── hot-patcher@1.0.0 extraneous
                    ├── html-encoding-sniffer@3.0.0 extraneous
                    ├── http-cache-semantics@4.1.1 extraneous
                    ├── http-errors@2.0.0 extraneous
                    ├── http-proxy-agent@5.0.0 extraneous
                    ├── http2-wrapper@1.0.3 extraneous
                    ├── https@1.0.0 extraneous
                    ├── humanize-ms@1.2.1 extraneous
                    ├── ical.js@ extraneous
                    ├── iconv-lite@0.4.24 extraneous
                    ├── ieee754@1.2.1 extraneous
                    ├── ignore-walk@3.0.4 extraneous
                    ├── ignore@5.3.2 extraneous
                    ├── image-type@4.1.0 extraneous
                    ├── immediate@3.0.6 extraneous
                    ├── import-fresh@3.3.0 extraneous
                    ├── import-lazy@2.1.0 extraneous
                    ├── import-local@3.2.0 extraneous
                    ├── imurmurhash@0.1.4 extraneous
                    ├── indent-string@3.2.0 extraneous
                    ├── infer-owner@1.0.4 extraneous
                    ├── inflight@1.0.6 extraneous
                    ├── ini@1.3.7 extraneous
                    ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                    ├── inquirer@7.3.3 extraneous
                    ├── int64-buffer@1.0.1 extraneous
                    ├── internal-slot@1.0.7 extraneous
                    ├── iobroker-adapter-helpers@0.0.8 extraneous
                    ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                    ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                    ├── iobroker.bmw@2.5.7
                    ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                    ├── iobroker.cloud@4.4.1
                    ├── iobroker.coronavirus-statistics@0.8.7
                    ├── iobroker.daswetter@3.1.10
                    ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                    ├── iobroker.dwd@2.8.5
                    ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                    ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                    ├── iobroker.eusec@1.1.2
                    ├── iobroker.flot@ invalid: "1.12.0" from the root project
                    ├── iobroker.fritzbox@0.2.1
                    ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                    ├── iobroker.fullybrowser@2.1.2
                    ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                    ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                    ├── iobroker.harmony@1.2.2
                    ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                    ├── iobroker.history@2.2.6
                    ├── iobroker.hm-rega@3.0.47
                    ├── iobroker.hm-rpc@1.15.19
                    ├── iobroker.hue@3.9.5
                    ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                    ├── iobroker.icons-icons8@0.0.1
                    ├── iobroker.icons-material-png@0.1.0
                    ├── iobroker.icons-mfd-png@1.1.0
                    ├── iobroker.icons-ultimate-png@1.0.1
                    ├── iobroker.info@ invalid: "1.9.26" from the root project
                    ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                    ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                    ├── iobroker.logparser@2.2.0
                    ├── iobroker.material@ invalid: "1.3.1" from the root project
                    ├── iobroker.meross@1.15.1
                    ├── iobroker.mihome-vacuum@3.11.0
                    ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                    ├── iobroker.milight@0.3.6
                    ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                    ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                    ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                    ├── iobroker.nina@ invalid: "0.0.25" from the root project
                    ├── iobroker.pollenflug@1.0.6
                    ├── iobroker.pushover@3.0.3
                    ├── iobroker.pushsafer@1.0.3
                    ├── iobroker.pvforecast@2.7.1
                    ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                    ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                    ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                    ├── iobroker.simple-api@2.7.2
                    ├── iobroker.smartmeter@3.3.4
                    ├── iobroker.socketio@6.5.2
                    ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                    ├── iobroker.sql@2.2.0
                    ├── iobroker.statistics@2.3.0
                    ├── iobroker.sunnyportal@0.1.5
                    ├── iobroker.synology@ invalid: "2.1.13" from the root project
                    ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                    ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                    ├── iobroker.tr-064@4.2.18
                    ├── iobroker.trashschedule@2.2.0
                    ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                    ├── iobroker.upnp@1.0.21
                    ├── iobroker.valloxmv@1.2.0
                    ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                    ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                    ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                    ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                    ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                    ├── iobroker.vis-fancyswitch@1.1.0
                    ├── iobroker.vis-google-fonts@1.0.4
                    ├── iobroker.vis-history@1.0.0
                    ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                    ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                    ├── iobroker.vis-jqui-mfd@1.0.12
                    ├── iobroker.vis-justgage@1.0.2
                    ├── iobroker.vis-map@1.0.4
                    ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                    ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                    ├── iobroker.vis-rgraph@0.0.2
                    ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                    ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                    ├── iobroker.vis@ invalid: "1.4.16" from the root project
                    ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                    ├── iobroker.weatherunderground@3.4.2
                    ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                    ├── iobroker.web@ invalid: "6.1.0" from the root project
                    ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                    ├── iobroker.wiffi-wz@2.2.1
                    ├── iobroker.windows-control@0.1.5
                    ├── iobroker.worx@2.3.2
                    ├── iobroker.ws@2.5.3
                    ├── iobroker@2.0.3
                    ├── ioredis@ extraneous
                    ├── ip-address@9.0.5 extraneous
                    ├── ip-regex@4.3.0 extraneous
                    ├── ipaddr.js@2.2.0 extraneous
                    ├── is-array-buffer@3.0.4 extraneous
                    ├── is-bigint@1.0.4 extraneous
                    ├── is-binary-path@2.1.0 extraneous
                    ├── is-boolean-object@1.1.2 extraneous
                    ├── is-buffer@1.1.6 extraneous
                    ├── is-callable@1.2.7 extraneous
                    ├── is-ci@2.0.0 extraneous
                    ├── is-core-module@2.15.0 extraneous
                    ├── is-data-view@1.0.1 extraneous
                    ├── is-date-object@1.0.5 extraneous
                    ├── is-docker@2.2.1 extraneous
                    ├── is-empty-object@1.1.1 extraneous
                    ├── is-extglob@2.1.1 extraneous
                    ├── is-fullwidth-code-point@3.0.0 extraneous
                    ├── is-glob@4.0.3 extraneous
                    ├── is-installed-globally@0.3.2 extraneous
                    ├── is-interactive@1.0.0 extraneous
                    ├── is-lambda@1.0.1 extraneous
                    ├── is-negative-zero@2.0.3 extraneous
                    ├── is-npm@5.0.0 extraneous
                    ├── is-number-object@1.0.7 extraneous
                    ├── is-number@7.0.0 extraneous
                    ├── is-obj@2.0.0 extraneous
                    ├── is-observable@1.1.0 extraneous
                    ├── is-path-cwd@2.2.0 extraneous
                    ├── is-path-inside@3.0.3 extraneous
                    ├── is-plain-obj@1.1.0 extraneous
                    ├── is-potential-custom-element-name@1.0.1 extraneous
                    ├── is-promise@2.2.2 extraneous
                    ├── is-property@1.0.2 extraneous
                    ├── is-regex@1.1.4 extraneous
                    ├── is-scoped@2.1.0 extraneous
                    ├── is-shared-array-buffer@1.0.3 extraneous
                    ├── is-string@1.0.7 extraneous
                    ├── is-symbol@1.0.4 extraneous
                    ├── is-typed-array@1.1.13 extraneous
                    ├── is-unicode-supported@0.1.0 extraneous
                    ├── is-url-superb@4.0.0 extraneous
                    ├── is-url@1.2.4 extraneous
                    ├── is-weakref@1.0.2 extraneous
                    ├── is-wsl@2.2.0 extraneous
                    ├── is-yarn-global@0.3.0 extraneous
                    ├── is@3.3.0 extraneous
                    ├── is2@2.0.9 extraneous
                    ├── isomorphic-ws@4.0.1 extraneous
                    ├── issue-regex@3.1.0 extraneous
                    ├── jackspeak@3.4.3 extraneous
                    ├── js-md4@0.3.2 extraneous
                    ├── js-sdsl@4.3.0 extraneous
                    ├── js-tokens@4.0.0 extraneous
                    ├── js-yaml@ extraneous
                    ├── jsbi@4.3.0 extraneous
                    ├── jsbn@1.1.0 extraneous
                    ├── jsdom@ extraneous
                    ├── jshashes@1.0.8 extraneous
                    ├── json-buffer@3.0.1 extraneous
                    ├── json-logic-js@2.0.5 extraneous
                    ├── json-parse-even-better-errors@2.3.1 extraneous
                    ├── json-schema-traverse@1.0.0 extraneous
                    ├── json5@2.2.3 extraneous
                    ├── jsonata@ extraneous
                    ├── jsonc-parser@3.3.1 extraneous
                    ├── jsonwebtoken@9.0.2 extraneous
                    ├── jszip@ extraneous
                    ├── jwa@2.0.0 extraneous
                    ├── jws@4.0.0 extraneous
                    ├── keyv@4.5.4 extraneous
                    ├── kind-of@6.0.3 extraneous
                    ├── kuler@2.0.0 extraneous
                    ├── later@1.2.0 extraneous
                    ├── latest-version@5.1.0 extraneous
                    ├── layerr@0.1.2 extraneous
                    ├── lazystream@1.0.1 extraneous
                    ├── leven@2.1.0 extraneous
                    ├── levn@0.3.0 extraneous
                    ├── lie@3.3.0 extraneous
                    ├── lines-and-columns@1.2.4 extraneous
                    ├── listr-input@0.2.1 extraneous
                    ├── listr-silent-renderer@1.1.1 extraneous
                    ├── listr-update-renderer@0.5.0 extraneous
                    ├── listr-verbose-renderer@0.5.0 extraneous
                    ├── listr@0.14.3 extraneous
                    ├── loadavg-windows@1.1.1 extraneous
                    ├── locate-path@6.0.0 extraneous
                    ├── lodash.defaults@4.2.0 extraneous
                    ├── lodash.flatten@4.4.0 extraneous
                    ├── lodash.includes@4.3.0 extraneous
                    ├── lodash.isarguments@3.1.0 extraneous
                    ├── lodash.isboolean@3.0.3 extraneous
                    ├── lodash.isequal@4.5.0 extraneous
                    ├── lodash.isinteger@4.0.4 extraneous
                    ├── lodash.isnumber@3.0.3 extraneous
                    ├── lodash.isplainobject@4.0.6 extraneous
                    ├── lodash.isstring@4.0.1 extraneous
                    ├── lodash.once@4.1.1 extraneous
                    ├── lodash.zip@4.2.0 extraneous
                    ├── log-symbols@4.1.0 extraneous
                    ├── log-update@2.3.0 extraneous
                    ├── logform@ extraneous
                    ├── long@5.2.3 extraneous
                    ├── lowercase-keys@2.0.0 extraneous
                    ├── lru_map@0.3.3 extraneous
                    ├── lru-cache@6.0.0 extraneous
                    ├── make-dir@3.1.0 extraneous
                    ├── make-fetch-happen@10.2.1 extraneous
                    ├── map-age-cleaner@0.1.3 extraneous
                    ├── map-obj@4.3.0 extraneous
                    ├── map-stream@0.0.7 extraneous
                    ├── md5@2.3.0 extraneous
                    ├── media-typer@0.3.0 extraneous
                    ├── meow@8.1.2 extraneous
                    ├── merge-descriptors@1.0.1 extraneous
                    ├── merge2@1.4.1 extraneous
                    ├── methods@1.1.2 extraneous
                    ├── micro@9.4.1 extraneous
                    ├── micromatch@4.0.7 extraneous
                    ├── mime-db@1.53.0 extraneous
                    ├── mimic-response@1.0.1 extraneous
                    ├── min-indent@1.0.1 extraneous
                    ├── minimatch@9.0.5 extraneous
                    ├── minimist-options@4.1.0 extraneous
                    ├── minipass-collect@1.0.2 extraneous
                    ├── minipass-fetch@2.1.2 extraneous
                    ├── minipass-flush@1.0.5 extraneous
                    ├── minipass-pipeline@1.2.4 extraneous
                    ├── minipass-sized@1.0.3 extraneous
                    ├── minipass@7.1.2 extraneous
                    ├── minizlib@2.1.2 extraneous
                    ├── mkdirp-classic@0.5.3 extraneous
                    ├── mkdirp@1.0.4 extraneous
                    ├── mock-require@3.0.3 extraneous
                    ├── moment-duration-format@2.3.2 extraneous
                    ├── mqtt-connection@4.1.0 extraneous
                    ├── mqtt-packet@9.0.0 extraneous
                    ├── mqtt@ extraneous
                    ├── mute-stream@0.0.8 extraneous
                    ├── named-placeholders@1.1.3 extraneous
                    ├── nan@ extraneous
                    ├── nanoid@3.3.7 extraneous
                    ├── napi-build-utils@1.0.2 extraneous
                    ├── native-duplexpair@1.0.0 extraneous
                    ├── nconf@0.10.0 extraneous
                    ├── nested-property@4.0.0 extraneous
                    ├── netmask@2.0.2 extraneous
                    ├── new-github-release-url@1.0.0 extraneous
                    ├── node-abi@3.65.0 extraneous
                    ├── node-abort-controller@3.1.1 extraneous
                    ├── node-cron@2.0.3 extraneous
                    ├── node-fetch@2.7.0 extraneous
                    ├── node-forge@ extraneous
                    ├── node-gyp@ extraneous
                    ├── node-ical@0.16.1 extraneous
                    ├── node-inspect@2.0.0 extraneous
                    ├── node-libcurl@3.0.0 extraneous
                    ├── node-mndp@0.0.3 extraneous
                    ├── node-persist@0.0.11 extraneous
                    ├── node-rsa@1.1.1 extraneous
                    ├── node-unifi@2.5.1 extraneous
                    ├── node-wol@0.1.1 extraneous
                    ├── node.extend@2.0.3 extraneous
                    ├── nopt@5.0.0 extraneous
                    ├── normalize-package-data@3.0.3 extraneous
                    ├── normalize-path@3.0.0 extraneous
                    ├── normalize-url@6.1.0 extraneous
                    ├── np@7.7.0 extraneous
                    ├── npm-name@6.0.1 extraneous
                    ├── npmlog@5.0.1 extraneous
                    ├── number-allocator@1.0.14 extraneous
                    ├── nwsapi@2.2.12 extraneous
                    ├── object-assign@4.1.1 extraneous
                    ├── object-hash@3.0.0 extraneous
                    ├── on-finished@2.4.1 extraneous
                    ├── once@1.4.0 extraneous
                    ├── one-time@1.0.0 extraneous
                    ├── onedrive-api@1.1.1 extraneous
                    ├── open@7.4.2 extraneous
                    ├── opencollective-postinstall@2.0.3 extraneous
                    ├── optionator@0.8.3 extraneous
                    ├── org-regex@1.0.0 extraneous
                    ├── os-tmpdir@1.0.2 extraneous
                    ├── ospath@1.2.2 extraneous
                    ├── osx-temperature-sensor@ extraneous
                    ├── otplib@11.0.1 extraneous
                    ├── ow@0.21.0 extraneous
                    ├── p-cancelable@2.1.1 extraneous
                    ├── p-defer@1.0.0 extraneous
                    ├── p-event@4.2.0 extraneous
                    ├── p-finally@1.0.0 extraneous
                    ├── p-limit@2.3.0 extraneous
                    ├── p-locate@5.0.0 extraneous
                    ├── p-map@2.1.0 extraneous
                    ├── p-memoize@4.0.4 extraneous
                    ├── p-reflect@2.1.0 extraneous
                    ├── p-settle@4.1.1 extraneous
                    ├── p-throttle@4.1.1 extraneous
                    ├── p-timeout@4.1.0 extraneous
                    ├── p-try@2.2.0 extraneous
                    ├── package-json-from-dist@1.0.0 extraneous
                    ├── package-json@6.5.0 extraneous
                    ├── pako@ extraneous
                    ├── parent-module@1.0.1 extraneous
                    ├── parse-json@5.2.0 extraneous
                    ├── parse5@ extraneous
                    ├── passport-local@1.0.0 extraneous
                    ├── passport@0.7.0 extraneous
                    ├── path-exists@4.0.0 extraneous
                    ├── path-is-absolute@1.0.1 extraneous
                    ├── path-parse@1.0.7 extraneous
                    ├── path-posix@1.0.0 extraneous
                    ├── path-scurry@1.11.1 extraneous
                    ├── path-to-regexp@0.1.7 extraneous
                    ├── path-type@4.0.0 extraneous
                    ├── pause-stream@0.0.11 extraneous
                    ├── picomatch@2.3.1 extraneous
                    ├── pidtree@0.6.0 extraneous
                    ├── pidusage@3.0.2 extraneous
                    ├── ping@0.4.4 extraneous
                    ├── pkg-dir@5.0.0 extraneous
                    ├── pluralize@8.0.0 extraneous
                    ├── possible-typed-array-names@1.0.0 extraneous
                    ├── prebuild-install@7.1.2 extraneous
                    ├── prelude-ls@1.1.2 extraneous
                    ├── prepend-http@2.0.0 extraneous
                    ├── process-nextick-args@2.0.1 extraneous
                    ├── process@0.11.10 extraneous
                    ├── promise-inflight@1.0.1 extraneous
                    ├── promise-object@0.1.7 extraneous
                    ├── promise-retry@2.0.1 extraneous
                    ├── promise-retryer@0.0.1 extraneous
                    ├── promisify-child-process@4.1.2 extraneous
                    ├── prompt@1.3.0 extraneous
                    ├── protobufjs@ extraneous
                    ├── proxy-addr@2.0.7 extraneous
                    ├── proxy-from-env@1.1.0 extraneous
                    ├── pump@3.0.0 extraneous
                    ├── pupa@2.1.1 extraneous
                    ├── q@1.1.2 extraneous
                    ├── quasar@ extraneous
                    ├── queue-microtask@1.2.3 extraneous
                    ├── queue-tick@1.0.1 extraneous
                    ├── quick-lru@5.1.1 extraneous
                    ├── range-parser@1.2.1 extraneous
                    ├── raw-body@2.5.2 extraneous
                    ├── rc@1.2.8 extraneous
                    ├── read-pkg-up@7.0.1 extraneous
                    ├── read-pkg@5.2.0 extraneous
                    ├── read@1.0.7 extraneous
                    ├── readable-stream@ extraneous
                    ├── readdir-glob@1.1.3 extraneous
                    ├── readdirp@3.6.0 extraneous
                    ├── readline-sync@1.4.10 extraneous
                    ├── readline@1.3.0 extraneous
                    ├── redent@3.0.0 extraneous
                    ├── redis-commands@1.7.0 extraneous
                    ├── redis-errors@1.2.0 extraneous
                    ├── redis-parser@3.0.0 extraneous
                    ├── regenerator-runtime@0.14.1 extraneous
                    ├── regex-escape@3.4.10 extraneous
                    ├── regexp.prototype.flags@1.5.2 extraneous
                    ├── registry-auth-token@4.2.2 extraneous
                    ├── registry-url@5.1.0 extraneous
                    ├── reinterval@1.1.0 extraneous
                    ├── remove-trailing-separator@1.1.0 extraneous
                    ├── require-from-string@2.0.2 extraneous
                    ├── resolve-alpn@1.2.1 extraneous
                    ├── resolve-cwd@3.0.0 extraneous
                    ├── resolve-from@4.0.0 extraneous
                    ├── respjs@4.2.0 extraneous
                    ├── responselike@2.0.1 extraneous
                    ├── restore-cursor@3.1.0 extraneous
                    ├── retry-axios@2.6.0 extraneous
                    ├── retry@0.12.0 extraneous
                    ├── reusify@1.0.4 extraneous
                    ├── revalidator@0.1.8 extraneous
                    ├── rfdc@1.4.1 extraneous
                    ├── rimraf@3.0.2 extraneous
                    ├── rrule@2.8.1 extraneous
                    ├── rrweb-cssom@0.6.0 extraneous
                    ├── run-async@2.4.1 extraneous
                    ├── run-parallel@1.2.0 extraneous
                    ├── rxjs@ extraneous
                    ├── safe-array-concat@1.1.2 extraneous
                    ├── safe-regex-test@1.0.3 extraneous
                    ├── safe-stable-stringify@2.4.3 extraneous
                    ├── safer-buffer@2.1.2 extraneous
                    ├── saxes@6.0.0 extraneous
                    ├── scoped-regex@2.1.0 extraneous
                    ├── secure-keys@1.0.0 extraneous
                    ├── semver-diff@3.1.1 extraneous
                    ├── semver@5.7.2
                    ├── send@0.18.0 extraneous
                    ├── seq-logging@1.1.2 extraneous
                    ├── seq-queue@0.0.5 extraneous
                    ├── serve-static@1.15.0 extraneous
                    ├── set-function-name@2.0.2 extraneous
                    ├── setimmediate@1.0.5 extraneous
                    ├── setprototypeof@1.2.0 extraneous
                    ├── signal-exit@4.1.0 extraneous
                    ├── simple-concat@1.0.1 extraneous
                    ├── simple-get@3.1.1 extraneous
                    ├── simple-ssh@1.1.1 extraneous
                    ├── simple-swizzle@0.2.2 extraneous
                    ├── slash@3.0.0 extraneous
                    ├── slice-ansi@0.0.4 extraneous
                    ├── smart-buffer@4.2.0 extraneous
                    ├── socks-proxy-agent@7.0.0 extraneous
                    ├── socks@2.8.3 extraneous
                    ├── speedtest-net@1.6.2 extraneous
                    ├── split@1.0.1 extraneous
                    ├── sprintf-js@1.1.3 extraneous
                    ├── sqlstring@2.3.3 extraneous
                    ├── ssh2@ extraneous
                    ├── ssri@9.0.1 extraneous
                    ├── stack-trace@0.0.10 extraneous
                    ├── stampit-event-bus@0.1.1 extraneous
                    ├── stampit-state-machine@0.2.1 extraneous
                    ├── stampit@2.1.2 extraneous
                    ├── standard-as-callback@2.1.0 extraneous
                    ├── static-eval@2.0.2 extraneous
                    ├── statuses@2.0.1 extraneous
                    ├── stoppable@1.1.0 extraneous
                    ├── stream-combiner@0.2.2 extraneous
                    ├── stream-shift@1.0.3 extraneous
                    ├── streamsearch@1.1.0 extraneous
                    ├── streamx@2.18.0 extraneous
                    ├── string-argv@0.3.2 extraneous
                    ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                    ├── string-width@5.1.2 extraneous
                    ├── string.prototype.trim@1.2.9 extraneous
                    ├── string.prototype.trimend@1.0.8 extraneous
                    ├── string.prototype.trimstart@1.0.8 extraneous
                    ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                    ├── strip-ansi@6.0.1 extraneous
                    ├── strip-indent@3.0.0 extraneous
                    ├── strip-json-comments@2.0.1 extraneous
                    ├── strnum@1.0.5 extraneous
                    ├── suncalc@1.9.0 extraneous
                    ├── suncalc2@1.8.1 extraneous
                    ├── supermixer@1.0.5 extraneous
                    ├── supports-color@7.2.0 extraneous
                    ├── supports-hyperlinks@2.3.0 extraneous
                    ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                    ├── sweet-collections@1.1.0 extraneous
                    ├── symbol-observable@3.0.0 extraneous
                    ├── symbol-tree@3.2.4 extraneous
                    ├── syno@ extraneous
                    ├── systeminformation@ extraneous
                    ├── tar-fs@2.1.1 extraneous
                    ├── tar-stream@3.1.7 extraneous
                    ├── tar@6.2.1 extraneous
                    ├── tarn@3.0.2 extraneous
                    ├── tcp-port-used@1.0.2 extraneous
                    ├── tedious@ extraneous
                    ├── terminal-link@2.1.1 extraneous
                    ├── text-decoder@1.1.1 extraneous
                    ├── text-hex@1.0.0 extraneous
                    ├── thirty-two@1.0.2 extraneous
                    ├── through@2.3.8 extraneous
                    ├── through2@2.0.5 extraneous
                    ├── tiny-typed-emitter@2.1.0 extraneous
                    ├── tinycolor2@1.6.0 extraneous
                    ├── tmp@0.0.33 extraneous
                    ├── to-readable-stream@2.1.0 extraneous
                    ├── to-regex-range@5.0.1 extraneous
                    ├── toidentifier@1.0.1 extraneous
                    ├── tr46@4.1.1 extraneous
                    ├── trim-newlines@3.0.1 extraneous
                    ├── triple-beam@1.4.1 extraneous
                    ├── tsdav@ extraneous
                    ├── tslib@2.3.0 extraneous
                    ├── tweetnacl@0.14.5 extraneous
                    ├── type-check@0.3.2 extraneous
                    ├── type-fest@0.21.3 extraneous
                    ├── type-is@1.6.18 extraneous
                    ├── typed-array-buffer@1.0.2 extraneous
                    ├── typed-array-byte-length@1.0.1 extraneous
                    ├── typed-array-byte-offset@1.0.2 extraneous
                    ├── typed-array-length@1.0.6 extraneous
                    ├── typedarray-to-buffer@3.1.5 extraneous
                    ├── typedarray.prototype.slice@1.0.3 extraneous
                    ├── typescript@ extraneous
                    ├── tz-offset@0.0.1 extraneous
                    ├── uid-number@0.0.6 extraneous
                    ├── unbox-primitive@1.0.2 extraneous
                    ├── undici-types@6.19.6 extraneous
                    ├── unique-filename@2.0.1 extraneous
                    ├── unique-slug@3.0.0 extraneous
                    ├── unique-string@2.0.0 extraneous
                    ├── unix-dgram@2.0.6 extraneous
                    ├── unpipe@1.0.0 extraneous
                    ├── update-notifier@5.1.0 extraneous
                    ├── uri-js@4.4.1 extraneous
                    ├── url-join@4.0.1 extraneous
                    ├── url-parse-lax@3.0.0 extraneous
                    ├── url-template@2.0.8 extraneous
                    ├── url@0.11.4 extraneous
                    ├── vali-date@1.0.0 extraneous
                    ├── validate-npm-package-name@3.0.0 extraneous
                    ├── vary@1.1.2 extraneous
                    ├── virtual-tsc@0.6.2 extraneous
                    ├── vue-i18n@ extraneous
                    ├── vuelidate-messages@0.1.2 extraneous
                    ├── vuelidate@ extraneous
                    ├── vuex-map-fields@1.4.1 extraneous
                    ├── w3c-xmlserializer@4.0.0 extraneous
                    ├── wake_on_lan@1.0.0 extraneous
                    ├── weak-daemon@1.0.3 extraneous
                    ├── webdav@ extraneous
                    ├── webidl-conversions@7.0.0 extraneous
                    ├── websocket-stream@5.5.2 extraneous
                    ├── whatwg-encoding@2.0.0 extraneous
                    ├── whatwg-mimetype@3.0.0 extraneous
                    ├── whatwg-url@12.0.1 extraneous
                    ├── which-boxed-primitive@1.0.2 extraneous
                    ├── which-typed-array@1.1.15 extraneous
                    ├── wide-align@1.1.5 extraneous
                    ├── widest-line@3.1.0 extraneous
                    ├── window-size@0.1.4 extraneous
                    ├── winston-daily-rotate-file@5.0.0 extraneous
                    ├── winston-seq-updated@1.0.4 extraneous
                    ├── winston-syslog@2.7.1 extraneous
                    ├── winston-transport@4.7.1 extraneous
                    ├── winston@ extraneous
                    ├── word-wrap@1.2.5 extraneous
                    ├── worker-timers-broker@6.1.8 extraneous
                    ├── worker-timers-worker@7.0.71 extraneous
                    ├── worker-timers@7.1.8 extraneous
                    ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                    ├── wrap-ansi@8.1.0 extraneous
                    ├── wrappy@1.0.2 extraneous
                    ├── write-file-atomic@3.0.3 extraneous
                    ├── xdg-basedir@4.0.0 extraneous
                    ├── xml-js@1.6.11 extraneous
                    ├── xml-name-validator@4.0.0 extraneous
                    ├── xmlchars@2.2.0 extraneous
                    ├── xregexp@2.0.0 extraneous
                    ├── yallist@4.0.0 extraneous
                    ├── yaml@ extraneous
                    ├── yargs-parser@20.2.9 extraneous
                    ├── yargs@7.1.2
                    ├── yocto-queue@0.1.0 extraneous
                    ├── zip-stream@6.0.1 extraneous
                    └── zrender@ extraneous
                      Vollständig.
                      flommaster
                      Teil 2
                      npm error code ELSPROBLEMS
                      npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                      npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                      npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                      npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                      npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                      npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                      npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                      npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                      npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                      npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                      npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                      npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                      npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                      npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                      npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                      npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                      npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                      npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                      npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                      npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                      npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                      npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                      npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                      npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                      npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                      npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                      npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                      npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                      npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                      npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                      npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                      npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                      npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                      npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                      npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                      npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                      npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                      npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                      npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                      npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                      npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                      npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                      npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                      npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                      npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                      npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                      npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                      npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                      npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                      npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                      npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                      npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                      npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                      npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                      npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                      npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                      npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                      npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                      npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                      npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                      npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                      npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                      npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                      npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                      npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                      npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                      npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                      npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                      npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                      npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                      npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                      npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                      npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                      npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                      npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                      npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                      npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                      npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                      npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                      npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                      npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                      npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                      npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                      npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                      npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                      npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                      npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                      npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                      npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                      npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                      npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                      npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                      npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                      npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                      npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                      npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                      npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                      npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                      npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                      npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                      npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                      npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                      npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                      npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                      npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                      npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                      npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                      npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                      npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                      npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                      npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                      npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                      npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                      npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                      npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                      npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                      npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                      npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                      npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                      npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                      npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                      npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                      npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                      npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                      npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                      npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                      npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                      npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                      npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                      npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                      npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                      npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                      npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                      npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                      npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                      npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                      npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                      npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                      npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                      npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                      npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                      npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                      npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                      npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                      npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                      npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                      npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                      npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                      npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                      npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                      npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                      npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                      npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                      npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                      npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                      npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                      npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                      npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                      npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                      npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                      npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                      npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                      npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                      npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                      npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                      npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                      npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                      npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                      npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                      npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                      npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                      npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                      npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                      npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                      npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                      npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                      npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                      npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                      npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                      npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                      npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                      npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                      npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                      npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                      npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                      npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                      npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                      npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                      npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                      npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                      npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                      npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                      npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                      npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                      npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                      npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                      npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                      npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                      npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                      npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                      npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                      npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                      npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                      npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                      npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                      npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                      npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                      npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                      npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                      npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                      npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                      npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                      npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                      npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                      npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                      npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                      npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                      npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                      npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                      npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                      npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                      npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                      npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                      npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                      npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                      npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                      npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                      npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                      npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                      npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                      npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                      npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                      npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                      npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                      npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                      npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                      npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                      npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                      npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                      npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                      npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                      npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                      npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                      npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                      npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                      npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                      npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                      npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                      npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                      npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                      npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                      npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                      npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                      npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                      npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                      npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                      npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                      npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                      npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                      npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                      npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                      npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                      npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                      npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                      npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                      npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                      npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                      npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                      npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                      npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                      npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                      npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                      npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                      npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                      npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                      npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                      npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                      npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                      npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                      npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                      npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                      npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                      npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                      npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                      npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                      npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                      npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                      npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                      npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                      npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                      npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                      npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                      npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                      npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                      npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                      npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                      npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                      npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                      npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                      npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                      npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                      npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                      npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                      npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                      npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                      npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                      npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                      npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                      npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                      npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                      npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                      npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                      npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                      npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                      npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                      npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                      npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                      npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                      npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                      npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                      npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                      npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                      npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                      npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                      npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                      npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                      npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                      npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                      npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                      npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                      npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                      npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                      npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                      npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                      npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                      npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                      npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                      npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                      npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                      npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                      npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                      npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                      npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                      npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                      npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                      npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                      npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                      npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                      npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                      npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                      npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                      npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                      npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                      npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                      npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                      npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                      npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                      npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                      npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                      npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                      npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                      npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                      npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                      npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                      npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                      npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                      npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                      npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                      npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                      npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                      npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                      npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                      npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                      npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                      npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                      npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                      npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                      npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                      npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                      npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                      npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                      npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                      npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                      npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                      npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                      npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                      npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                      npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                      npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                      npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                      npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                      npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                      npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                      npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                      npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                      npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                      npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                      npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                      npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                      npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                      npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                      npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                      npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                      npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                      npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                      npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                      npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                      npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                      npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                      npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                      npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                      npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                      npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                      npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                      npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                      npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                      npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                      npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                      npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                      npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                      npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                      npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                      npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                      npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                      npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                      npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                      npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                      npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                      npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                      npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                      npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                      npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                      npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                      npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                      npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                      npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                      npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                      npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                      npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                      npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                      npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                      npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                      npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                      npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                      npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                      npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                      npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                      npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                      npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                      npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                      npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                      npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                      npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                      npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                      npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                      npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                      npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                      npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                      npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                      npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                      npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                      npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                      npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                      npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                      npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                      npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                      npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                      npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                      npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                      npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                      npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                      npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                      npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                      npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                      npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                      npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                      npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                      npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                      npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                      npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                      npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                      npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                      npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                      npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                      npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                      npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                      npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                      npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                      npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                      npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                      npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                      npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                      npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                      npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                      npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                      npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                      npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                      npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                      npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                      npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                      npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                      npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                      npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                      npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                      npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                      npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                      npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                      npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                      npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                      npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                      npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                      npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                      npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                      npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                      npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                      npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                      npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                      npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                      npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                      npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                      npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                      npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                      npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                      npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                      npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                      npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                      npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                      npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                      npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                      npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                      npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                      npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                      npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                      npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                      npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                      npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                      npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                      npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                      npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                      npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                      npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                      npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                      npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                      npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                      npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                      npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                      npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                      npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                      npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                      npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                      npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                      npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                      npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                      npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                      npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                      npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                      npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                      npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                      npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                      npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                      npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                      npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                      npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                      npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                      npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                      npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                      npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                      npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                      npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                      npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                      npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                      npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                      npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                      npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                      npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                      npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                      npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                      npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                      npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                      npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                      npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                      npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                      npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                      npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                      npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                      npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                      npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                      npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                      npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                      npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                      npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                      npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                      npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                      npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                      npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                      npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                      npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                      npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                      npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                      npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                      npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                      npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                      npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                      npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                      npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                      npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                      npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                      npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                      npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                      npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                      npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                      npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                      npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                      npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                      npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                      npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                      npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                      npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                      npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                      npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                      npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                      npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                      npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                      npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                      npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                      npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                      npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                      npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                      npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                      npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                      npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                      npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                      npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                      npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                      npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                      npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                      npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                      npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                      npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                      npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                      npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                      npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                      npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                      npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                      npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                      npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                      npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                      npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                      npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                      npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                      npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                      npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                      npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                      npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                      npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                      npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                      npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                      npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                      npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                      npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                      npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                      npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                      npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                      npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                      npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                      npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                      npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                      npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                      npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                      npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                      npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                      npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                      npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                      npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                      npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                      npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                      npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                      npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                      npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                      npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                      npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                      npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                      npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                      npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                      npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                      npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                      npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                      npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                      npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                      npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                      npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                      npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                      npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                      npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                      npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                      npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                      npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                      npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                      npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                      npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                      npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                      npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                      npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                      npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                      npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                      npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                      npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                      npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                      npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                      npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                      npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                      npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                      npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                      npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                      npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                      npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                      npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                      npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                      npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                      npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                      npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                      npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                      npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                      npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                      npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                      npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                      npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                      npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                      npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                      npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                      npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                      npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                      npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                      npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                      npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                      npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                      npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                      npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                      npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                      npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                      npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                      npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                      npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                      npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                      npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                      npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                      npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                      npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                      npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                      npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                      npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                      npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                      npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                      npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                      npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                      npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                      npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                      npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                      npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                      npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                      npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                      npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                      npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                      npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                      npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                      npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                      npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                      npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                      npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                      npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                      npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                      npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                      npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                      npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                      npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                      npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                      npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                      npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                      npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                      npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                      npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                      npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                      npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                      npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                      npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                      npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                      npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                      npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                      npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                      npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                      npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                      npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                      npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                      npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                      npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                      npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                      npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                      npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                      npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                      npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                      npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                      npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                      npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                      npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                      npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                      npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                      npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                      npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                      npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                      npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                      npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                      npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                      npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                      npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                      npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                      npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                      npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                      npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                      npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                      npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                      npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                      npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                      npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                      npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                      npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                      npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                      npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                      npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                      npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                      npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                      npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                      npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                      npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                      npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                      npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                      npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                      npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                      npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                      npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                      npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                      npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                      npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                      npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                      npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                      npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                      npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                      npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                      npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                      npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                      npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                      npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                      npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                      npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                      npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                      npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                      npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                      npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                      npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                      npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                      npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                      npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                      npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                      npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                      npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                      npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                      npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                      npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                      npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                      npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
                      • F flommaster
                        Teil 2
                        npm error code ELSPROBLEMS
                        npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                        npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                        npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                        npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                        npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                        npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                        npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                        npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                        npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                        npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                        npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                        npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                        npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                        npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                        npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                        npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                        npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                        npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                        npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                        npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                        npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                        npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                        npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                        npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                        npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                        npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                        npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                        npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                        npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                        npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                        npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                        npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                        npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                        npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                        npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                        npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                        npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                        npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                        npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                        npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                        npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                        npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                        npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                        npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                        npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                        npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                        npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                        npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                        npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                        npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                        npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                        npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                        npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                        npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                        npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                        npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                        npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                        npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                        npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                        npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                        npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                        npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                        npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                        npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                        npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                        npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                        npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                        npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                        npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                        npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                        npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                        npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                        npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                        npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                        npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                        npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                        npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                        npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                        npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                        npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                        npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                        npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                        npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                        npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                        npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                        npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                        npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                        npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                        npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                        npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                        npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                        npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                        npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                        npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                        npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                        npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                        npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                        npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                        npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                        npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                        npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                        npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                        npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                        npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                        npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                        npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                        npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                        npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                        npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                        npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                        npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                        npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                        npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                        npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                        npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                        npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                        npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                        npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                        npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                        npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                        npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                        npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                        npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                        npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                        npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                        npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                        npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                        npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                        npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                        npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                        npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                        npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                        npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                        npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                        npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                        npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                        npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                        npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                        npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                        npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                        npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                        npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                        npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                        npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                        npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                        npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                        npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                        npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                        npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                        npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                        npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                        npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                        npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                        npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                        npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                        npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                        npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                        npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                        npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                        npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                        npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                        npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                        npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                        npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                        npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                        npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                        npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                        npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                        npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                        npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                        npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                        npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                        npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                        npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                        npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                        npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                        npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                        npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                        npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                        npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                        npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                        npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                        npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                        npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                        npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                        npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                        npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                        npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                        npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                        npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                        npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                        npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                        npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                        npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                        npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                        npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                        npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                        npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                        npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                        npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                        npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                        npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                        npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                        npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                        npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                        npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                        npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                        npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                        npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                        npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                        npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                        npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                        npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                        npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                        npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                        npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                        npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                        npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                        npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                        npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                        npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                        npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                        npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                        npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                        npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                        npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                        npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                        npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                        npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                        npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                        npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                        npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                        npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                        npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                        npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                        npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                        npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                        npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                        npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                        npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                        npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                        npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                        npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                        npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                        npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                        npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                        npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                        npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                        npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                        npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                        npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                        npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                        npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                        npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                        npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                        npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                        npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                        npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                        npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                        npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                        npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                        npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                        npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                        npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                        npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                        npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                        npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                        npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                        npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                        npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                        npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                        npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                        npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                        npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                        npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                        npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                        npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                        npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                        npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                        npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                        npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                        npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                        npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                        npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                        npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                        npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                        npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                        npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                        npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                        npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                        npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                        npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                        npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                        npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                        npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                        npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                        npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                        npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                        npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                        npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                        npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                        npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                        npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                        npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                        npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                        npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                        npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                        npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                        npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                        npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                        npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                        npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                        npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                        npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                        npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                        npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                        npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                        npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                        npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                        npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                        npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                        npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                        npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                        npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                        npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                        npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                        npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                        npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                        npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                        npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                        npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                        npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                        npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                        npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                        npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                        npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                        npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                        npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                        npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                        npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                        npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                        npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                        npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                        npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                        npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                        npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                        npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                        npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                        npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                        npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                        npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                        npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                        npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                        npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                        npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                        npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                        npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                        npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                        npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                        npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                        npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                        npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                        npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                        npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                        npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                        npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                        npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                        npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                        npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                        npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                        npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                        npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                        npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                        npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                        npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                        npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                        npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                        npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                        npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                        npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                        npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                        npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                        npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                        npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                        npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                        npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                        npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                        npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                        npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                        npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                        npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                        npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                        npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                        npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                        npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                        npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                        npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                        npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                        npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                        npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                        npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                        npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                        npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                        npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                        npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                        npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                        npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                        npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                        npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                        npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                        npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                        npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                        npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                        npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                        npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                        npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                        npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                        npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                        npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                        npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                        npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                        npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                        npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                        npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                        npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                        npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                        npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                        npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                        npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                        npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                        npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                        npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                        npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                        npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                        npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                        npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                        npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                        npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                        npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                        npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                        npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                        npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                        npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                        npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                        npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                        npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                        npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                        npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                        npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                        npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                        npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                        npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                        npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                        npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                        npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                        npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                        npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                        npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                        npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                        npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                        npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                        npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                        npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                        npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                        npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                        npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                        npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                        npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                        npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                        npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                        npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                        npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                        npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                        npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                        npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                        npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                        npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                        npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                        npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                        npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                        npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                        npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                        npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                        npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                        npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                        npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                        npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                        npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                        npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                        npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                        npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                        npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                        npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                        npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                        npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                        npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                        npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                        npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                        npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                        npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                        npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                        npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                        npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                        npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                        npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                        npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                        npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                        npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                        npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                        npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                        npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                        npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                        npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                        npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                        npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                        npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                        npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                        npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                        npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                        npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                        npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                        npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                        npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                        npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                        npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                        npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                        npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                        npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                        npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                        npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                        npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                        npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                        npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                        npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                        npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                        npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                        npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                        npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                        npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                        npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                        npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                        npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                        npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                        npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                        npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                        npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                        npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                        npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                        npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                        npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                        npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                        npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                        npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                        npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                        npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                        npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                        npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                        npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                        npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                        npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                        npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                        npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                        npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                        npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                        npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                        npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                        npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                        npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                        npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                        npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                        npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                        npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                        npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                        npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                        npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                        npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                        npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                        npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                        npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                        npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                        npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                        npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                        npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                        npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                        npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                        npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                        npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                        npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                        npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                        npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                        npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                        npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                        npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                        npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                        npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                        npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                        npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                        npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                        npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                        npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                        npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                        npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                        npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                        npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                        npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                        npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                        npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                        npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                        npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                        npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                        npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                        npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                        npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                        npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                        npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                        npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                        npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                        npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                        npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                        npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                        npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                        npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                        npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                        npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                        npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                        npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                        npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                        npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                        npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                        npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                        npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                        npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                        npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                        npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                        npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                        npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                        npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                        npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                        npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                        npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                        npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                        npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                        npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                        npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                        npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                        npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                        npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                        npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                        npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                        npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                        npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                        npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                        npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                        npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                        npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                        npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                        npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                        npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                        npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                        npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                        npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                        npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                        npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                        npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                        npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                        npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                        npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                        npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                        npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                        npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                        npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                        npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                        npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                        npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                        npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                        npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                        npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                        npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                        npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                        npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                        npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                        npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                        npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                        npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                        npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                        npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                        npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                        npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                        npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                        npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                        npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                        npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                        npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                        npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                        npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                        npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                        npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                        npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                        npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                        npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                        npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                        npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                        npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                        npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                        npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                        npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                        npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                        npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                        npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                        npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                        npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                        npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                        npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                        npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                        npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                        npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                        npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                        npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                        npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                        npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                        npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                        npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                        npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                        npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                        npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                        npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                        npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                        npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                        npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                        npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                        npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                        npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                        npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                        npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                        npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                        npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                        npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                        npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                        npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                        npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                        npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                        npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                        npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                        npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                        npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                        npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                        npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                        npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                        npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                        npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                        npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                        npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                        npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                        npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                        npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                        npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                        npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                        npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                        npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                        npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                        npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                        npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                        npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                        npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                        npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                        npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                        npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                        npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                        npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                        npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                        npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                        npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                        npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                        npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                        npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                        npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                        npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                        npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                        npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                        npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                        npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                        npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                        npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                        npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                        npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                        npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                        npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                        npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                        npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                        npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                        npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                        npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                        npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                        npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                        npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                        npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                        npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                        npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                        npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                        npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                        npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                        npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                        npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                        npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                        npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                        npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                        npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                        npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                        npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                        npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                        npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                        npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                        npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                        npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                        npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                        npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                        npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                        npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                        npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                        npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                        npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                        npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                        npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                        npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                        npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                        npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                        npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                        npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                        npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                        npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                        npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                        npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                        npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                        npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                        npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                        npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                        npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                        npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                        npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                        npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                        npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                        npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                        npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                        npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                        npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                        npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                        npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                        npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                        npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                        npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                        npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                        npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                        npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                        npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                        npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                        npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                        npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                        npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                        npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                        npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                        npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                        npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                        npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                        npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                        npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                        npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                        npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                        npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                        npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
                        @flommaster
                        iob repo list
                        F 1 Antwort Letzte Antwort
                          @flommaster
                          iob repo list
                          flommaster
                          flo@ioBrokerdebian:/opt/iobroker$ iob repo list
                          node:internal/modules/cjs/loader:1148
                            throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                              at Module._load (node:internal/modules/cjs/loader:986:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                              at node:internal/main/run_main_module:28:49 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          Node.js v20.16.0
                          • F flommaster
                            Gerne. Hier der komplette Auszug (Teil 1)
                            flo@ioBrokerdebian:/opt/iobroker$ npm prune
                            npm ls
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                            npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                            npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                            npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                            npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                            npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                            npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                            npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                            npm warn deprecated har-validator@5.1.5: this library is no longer supported
                            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                            npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                            npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                            npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                            npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                            npm warn deprecated
                            npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                            npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                            npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                            npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                            npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                            npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                            npm warn deprecated gauge@3.0.2: This package is no longer supported.
                            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm warn deprecated gauge@4.0.4: This package is no longer supported.
                            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                            npm error git dep preparation failed
                            npm error signal SIGINT
                            npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                            npm error npm warn using --force Recommended protections disabled.
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
                            iobroker.inst@2.0.3 /opt/iobroker
                            ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                            ├── @alcalzone/jsonl-db@3.1.1 extraneous
                            ├── @alcalzone/pak@0.8.1 extraneous
                            ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                            ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                            ├── @azure/abort-controller@1.1.0 extraneous
                            ├── @azure/core-auth@1.7.2 extraneous
                            ├── @azure/core-client@ extraneous
                            ├── @azure/core-http-compat@ extraneous
                            ├── @azure/core-lro@ extraneous
                            ├── @azure/core-paging@1.6.2 extraneous
                            ├── @azure/core-rest-pipeline@ extraneous
                            ├── @azure/core-tracing@1.1.2 extraneous
                            ├── @azure/core-util@ extraneous
                            ├── @azure/identity@ extraneous
                            ├── @azure/keyvault-keys@ extraneous
                            ├── @azure/logger@1.1.4 extraneous
                            ├── @azure/msal-browser@ extraneous
                            ├── @azure/msal-common@ extraneous
                            ├── @azure/msal-node@1.18.4 extraneous
                            ├── @babel/code-frame@7.24.7 extraneous
                            ├── @babel/helper-validator-identifier@7.24.7 extraneous
                            ├── @babel/highlight@7.24.7 extraneous
                            ├── @babel/runtime@ extraneous
                            ├── @colors/colors@1.5.0 extraneous
                            ├── @dabh/diagnostics@2.0.3 extraneous
                            ├── @datalust/winston-seq@1.0.2 extraneous
                            ├── @gar/promisify@1.1.3 extraneous
                            ├── @googleapis/calendar@9.7.7 extraneous
                            ├── @googleapis/drive@5.1.0 extraneous
                            ├── @googleapis/oauth2@1.0.7 extraneous
                            ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                            ├── @iobroker/db-base@ extraneous
                            ├── @iobroker/db-objects-file@ extraneous
                            ├── @iobroker/db-objects-jsonl@ extraneous
                            ├── @iobroker/db-objects-redis@ extraneous
                            ├── @iobroker/db-states-file@ extraneous
                            ├── @iobroker/db-states-jsonl@ extraneous
                            ├── @iobroker/db-states-redis@ extraneous
                            ├── @iobroker/js-controller-adapter@ extraneous
                            ├── @iobroker/js-controller-cli@ extraneous
                            ├── @iobroker/js-controller-common-db@ extraneous
                            ├── @iobroker/js-controller-common@ extraneous
                            ├── @iobroker/plugin-base@1.2.1 extraneous
                            ├── @iobroker/plugin-sentry@1.2.1 extraneous
                            ├── @iobroker/socket-classes@1.5.6 extraneous
                            ├── @iobroker/webserver@1.0.3 extraneous
                            ├── @isaacs/cliui@8.0.2 extraneous
                            ├── @js-joda/core@ extraneous
                            ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                            ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                            ├── @nodelib/fs.scandir@2.1.5 extraneous
                            ├── @nodelib/fs.stat@2.0.5 extraneous
                            ├── @nodelib/fs.walk@1.2.8 extraneous
                            ├── @npmcli/fs@2.1.2 extraneous
                            ├── @npmcli/move-file@2.0.1 extraneous
                            ├── @pkgjs/parseargs@0.11.0 extraneous
                            ├── @protobufjs/aspromise@1.1.2 extraneous
                            ├── @protobufjs/base64@1.1.2 extraneous
                            ├── @protobufjs/codegen@2.0.4 extraneous
                            ├── @protobufjs/eventemitter@1.1.0 extraneous
                            ├── @protobufjs/fetch@1.1.0 extraneous
                            ├── @protobufjs/float@1.0.2 extraneous
                            ├── @protobufjs/inquire@1.1.0 extraneous
                            ├── @protobufjs/path@1.1.2 extraneous
                            ├── @protobufjs/pool@1.1.0 extraneous
                            ├── @protobufjs/utf8@1.1.0 extraneous
                            ├── @quasar/extras@ extraneous
                            ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                            ├── @sentry-internal/tracing@ extraneous
                            ├── @sentry/core@5.30.0 extraneous
                            ├── @sentry/hub@5.30.0 extraneous
                            ├── @sentry/minimal@5.30.0 extraneous
                            ├── @sentry/node@ extraneous
                            ├── @sentry/tracing@ extraneous
                            ├── @sentry/types@ extraneous
                            ├── @sentry/utils@ extraneous
                            ├── @sindresorhus/is@4.6.0 extraneous
                            ├── @socket.io/component-emitter@3.1.2 extraneous
                            ├── @szmarczak/http-timer@4.0.6 extraneous
                            ├── @tediousjs/connection-string@0.5.0 extraneous
                            ├── @tootallnate/once@2.0.0 extraneous
                            ├── @types/bl@5.1.0 extraneous
                            ├── @types/cacheable-request@6.0.3 extraneous
                            ├── @types/caseless@0.12.5 extraneous
                            ├── @types/cookie@0.4.1 extraneous
                            ├── @types/cors@2.8.17 extraneous
                            ├── @types/geojson@7946.0.14 extraneous
                            ├── @types/http-cache-semantics@4.0.4 extraneous
                            ├── @types/keyv@3.1.4 extraneous
                            ├── @types/leaflet@1.9.12 extraneous
                            ├── @types/minimist@1.2.5 extraneous
                            ├── @types/node-cron@2.0.8 extraneous
                            ├── @types/node@ extraneous
                            ├── @types/normalize-package-data@2.4.4 extraneous
                            ├── @types/parse-json@4.0.2 extraneous
                            ├── @types/readable-stream@4.0.15 extraneous
                            ├── @types/request@2.48.12 extraneous
                            ├── @types/responselike@1.0.3 extraneous
                            ├── @types/tough-cookie@4.0.5 extraneous
                            ├── @types/triple-beam@1.3.5 extraneous
                            ├── @types/tz-offset@0.0.3 extraneous
                            ├── @types/ws@8.5.12 extraneous
                            ├── abab@2.0.6 extraneous
                            ├── abbrev@1.1.1 extraneous
                            ├── abort-controller@3.0.0 extraneous
                            ├── agentkeepalive@4.5.0 extraneous
                            ├── aggregate-error@3.1.0 extraneous
                            ├── ajv@ extraneous
                            ├── ansi-align@3.0.1 extraneous
                            ├── ansi-colors@4.1.3 extraneous
                            ├── ansi-escapes@4.3.2 extraneous
                            ├── ansi-regex@5.0.1 extraneous
                            ├── ansi-styles@4.3.0 extraneous
                            ├── any-observable@0.5.1 extraneous
                            ├── anymatch@3.1.3 extraneous
                            ├── aproba@2.0.0 extraneous
                            ├── archiver-utils@5.0.2 extraneous
                            ├── archiver@7.0.1 extraneous
                            ├── are-we-there-yet@2.0.0 extraneous
                            ├── arg@4.1.0 extraneous
                            ├── argparse@1.0.10 extraneous
                            ├── array-buffer-byte-length@1.0.1 extraneous
                            ├── array-flatten@1.1.1 extraneous
                            ├── array-union@2.1.0 extraneous
                            ├── arraybuffer.prototype.slice@1.0.3 extraneous
                            ├── arrify@2.0.1 extraneous
                            ├── asn1@0.2.6 extraneous
                            ├── async-exit-hook@2.0.1 extraneous
                            ├── authenticate-pam@1.0.5 extraneous
                            ├── available-typed-arrays@1.0.7 extraneous
                            ├── aws-crt@ extraneous
                            ├── b4a@1.6.6 extraneous
                            ├── balanced-match@1.0.2 extraneous
                            ├── bare-events@2.4.2 extraneous
                            ├── base-64@1.0.0 extraneous
                            ├── base64-js@1.5.1 extraneous
                            ├── bcrypt-pbkdf@1.0.2 extraneous
                            ├── binary-extensions@2.3.0 extraneous
                            ├── bindings@1.5.0 extraneous
                            ├── bl@6.0.14 extraneous
                            ├── bluebird@3.7.2 extraneous
                            ├── body-parser@1.20.2 extraneous
                            ├── bottleneck@2.19.5 extraneous
                            ├── boxen@5.1.2 extraneous
                            ├── brace-expansion@2.0.1 extraneous
                            ├── braces@3.0.3 extraneous
                            ├── buffer-crc32@1.0.0 extraneous
                            ├── buffer-equal-constant-time@1.0.1 extraneous
                            ├── buffer-shims@1.0.0 extraneous
                            ├── buffer@6.0.3 extraneous
                            ├── buildcheck@0.0.6 extraneous
                            ├── builtins@1.0.3 extraneous
                            ├── busboy@1.6.0 extraneous
                            ├── byte-length@1.0.2 extraneous
                            ├── bytes@3.1.2 extraneous
                            ├── cacache@16.1.3 extraneous
                            ├── cacheable-lookup@5.0.4 extraneous
                            ├── cacheable-request@7.0.4 extraneous
                            ├── callsites@3.1.0 extraneous
                            ├── camelcase-keys@6.2.2 extraneous
                            ├── camelcase@5.3.1 extraneous
                            ├── capitalize@2.0.4 extraneous
                            ├── chalk@4.1.2 extraneous
                            ├── chardet@0.7.0 extraneous
                            ├── charenc@0.0.2 extraneous
                            ├── chokidar@3.6.0 extraneous
                            ├── chownr@2.0.0 extraneous
                            ├── ci-info@3.9.0 extraneous
                            ├── clean-stack@2.2.0 extraneous
                            ├── cli-boxes@2.2.1 extraneous
                            ├── cli-cursor@3.1.0 extraneous
                            ├── cli-truncate@0.2.1 extraneous
                            ├── cli-width@3.0.0 extraneous
                            ├── clone-response@1.0.3 extraneous
                            ├── cloneextend@0.0.3 extraneous
                            ├── cluster-key-slot@1.1.2 extraneous
                            ├── coap-packet@1.1.1 extraneous
                            ├── coffeescript@1.12.7 extraneous
                            ├── color-convert@2.0.1 extraneous
                            ├── color-name@1.1.4 extraneous
                            ├── color-string@1.9.1 extraneous
                            ├── color-support@1.1.3 extraneous
                            ├── color@3.2.1 extraneous
                            ├── colors@1.4.0
                            ├── colorspace@1.1.4 extraneous
                            ├── commander@9.5.0 extraneous
                            ├── commist@3.2.0 extraneous
                            ├── compress-commons@6.0.2 extraneous
                            ├── compress-json@2.1.2 extraneous
                            ├── compressible@2.0.18 extraneous
                            ├── compression@1.7.4 extraneous
                            ├── concat-map@0.0.1 extraneous
                            ├── configstore@5.0.1 extraneous
                            ├── connect-flash@0.1.1 extraneous
                            ├── connect@3.7.0 extraneous
                            ├── console-control-strings@1.1.0 extraneous
                            ├── content-disposition@0.5.4 extraneous
                            ├── content-type@1.0.5 extraneous
                            ├── core-js@ extraneous
                            ├── cors@2.8.5 extraneous
                            ├── cosmiconfig@7.1.0 extraneous
                            ├── cpu-features@ extraneous
                            ├── crc-32@1.2.2 extraneous
                            ├── crc@ extraneous
                            ├── crc32-stream@6.0.0 extraneous
                            ├── cross-fetch@4.0.0 extraneous
                            ├── crypt@0.0.2 extraneous
                            ├── crypto-js@ extraneous
                            ├── crypto-random-string@2.0.0 extraneous
                            ├── cssstyle@ extraneous
                            ├── cycle@1.0.3 extraneous
                            ├── dashdash@1.14.1 extraneous
                            ├── data-urls@4.0.0 extraneous
                            ├── data-view-buffer@1.0.1 extraneous
                            ├── data-view-byte-length@1.0.1 extraneous
                            ├── data-view-byte-offset@1.0.0 extraneous
                            ├── date-and-time@ extraneous
                            ├── date-fns@1.30.1 extraneous
                            ├── dateformat@4.6.3 extraneous
                            ├── dayjs@ extraneous
                            ├── decache@4.6.2 extraneous
                            ├── decamelize-keys@1.1.1 extraneous
                            ├── decimal.js@10.4.3 extraneous
                            ├── decompress-response@6.0.0 extraneous
                            ├── deep-clone@3.0.3 extraneous
                            ├── deep-extend@0.6.0 extraneous
                            ├── deep-is@0.1.4 extraneous
                            ├── defer-to-connect@2.0.1 extraneous
                            ├── define-lazy-prop@2.0.0 extraneous
                            ├── del@6.1.1 extraneous
                            ├── delegates@1.0.0 extraneous
                            ├── denque@1.5.1 extraneous
                            ├── destroy@1.2.0 extraneous
                            ├── detect-libc@2.0.3 extraneous
                            ├── diacritics@1.3.0 extraneous
                            ├── digest-header@1.1.0 extraneous
                            ├── dir-glob@3.0.1 extraneous
                            ├── diskusage@1.2.0 extraneous
                            ├── domexception@4.0.0 extraneous
                            ├── dot-prop@6.0.1 extraneous
                            ├── draftlog@1.0.13 extraneous
                            ├── dropbox-v2-api@ extraneous
                            ├── duplexer@0.1.2 extraneous
                            ├── duplexer3@0.1.5 extraneous
                            ├── duplexify@3.7.1 extraneous
                            ├── eastasianwidth@0.2.0 extraneous
                            ├── ecc-jsbn@0.1.2 extraneous
                            ├── ecdsa-sig-formatter@1.0.11 extraneous
                            ├── echarts@ extraneous
                            ├── ee-first@1.1.1 extraneous
                            ├── elegant-spinner@1.0.1 extraneous
                            ├── emoji-regex@9.2.2 extraneous
                            ├── enabled@2.0.0 extraneous
                            ├── encodeurl@1.0.2 extraneous
                            ├── encoding@0.1.13 extraneous
                            ├── end-of-stream@1.4.4 extraneous
                            ├── entities@4.5.0 extraneous
                            ├── err-code@2.0.3 extraneous
                            ├── es-abstract@ extraneous
                            ├── es-aggregate-error@1.0.13 extraneous
                            ├── es-object-atoms@1.0.0 extraneous
                            ├── es-set-tostringtag@2.0.3 extraneous
                            ├── es-to-primitive@1.2.1 extraneous
                            ├── es6-promise@4.2.8 extraneous
                            ├── es6-promisify@5.0.0 extraneous
                            ├── esbuild@0.11.23 extraneous
                            ├── escalade@3.1.2 extraneous
                            ├── escape-goat@3.0.0 extraneous
                            ├── escape-html@1.0.3 extraneous
                            ├── escape-string-regexp@4.0.0 extraneous
                            ├── escodegen@1.14.3 extraneous
                            ├── esprima@1.2.2 extraneous
                            ├── estraverse@4.3.0 extraneous
                            ├── esutils@2.0.3 extraneous
                            ├── etag@1.8.1 extraneous
                            ├── event-stream@4.0.1 extraneous
                            ├── event-target-shim@5.0.1 extraneous
                            ├── eventemitter2@6.4.9 extraneous
                            ├── events@3.3.0 extraneous
                            ├── execa@5.1.1 extraneous
                            ├── expand-template@2.0.3 extraneous
                            ├── express-fileupload@1.5.1 extraneous
                            ├── express@4.19.2 extraneous
                            ├── external-editor@3.1.0 extraneous
                            ├── fast-deep-equal@3.1.3 extraneous
                            ├── fast-fifo@1.3.2 extraneous
                            ├── fast-glob@ extraneous
                            ├── fast-json-stable-stringify@2.1.0 extraneous
                            ├── fast-levenshtein@2.0.6 extraneous
                            ├── fast-text-encoding@1.0.6 extraneous
                            ├── fast-unique-numbers@ extraneous
                            ├── fast-uri@3.0.1 extraneous
                            ├── fast-xml-parser@ extraneous
                            ├── fastq@1.17.1 extraneous
                            ├── fastseries@2.0.0 extraneous
                            ├── fecha@4.2.3 extraneous
                            ├── figures@3.2.0 extraneous
                            ├── file-stream-rotator@0.6.1 extraneous
                            ├── file-type@10.11.0 extraneous
                            ├── file-uri-to-path@1.0.0 extraneous
                            ├── fill-range@7.1.1 extraneous
                            ├── finalhandler@1.2.0 extraneous
                            ├── find-up@5.0.0 extraneous
                            ├── fn.name@1.1.0 extraneous
                            ├── for-each@0.3.3 extraneous
                            ├── foreground-child@3.3.0 extraneous
                            ├── form-data-encoder@2.1.4 extraneous
                            ├── form-data@4.0.0 extraneous
                            ├── forwarded@0.2.0 extraneous
                            ├── fresh@0.5.2 extraneous
                            ├── from@0.1.7 extraneous
                            ├── fs-constants@1.0.0 extraneous
                            ├── fs-extra@7.0.1
                            ├── fs-minipass@2.1.0 extraneous
                            ├── fs.realpath@1.0.0 extraneous
                            ├── fsevents@ extraneous
                            ├── ftp@0.3.10 extraneous
                            ├── function.prototype.name@1.1.6 extraneous
                            ├── functions-have-names@1.2.3 extraneous
                            ├── futoin-hkdf@1.4.3 extraneous
                            ├── gauge@3.0.2 extraneous
                            ├── gaxios@5.1.3 extraneous
                            ├── gcp-metadata@5.3.0 extraneous
                            ├── generate-function@2.3.1 extraneous
                            ├── get-ssl-certificate@2.3.3 extraneous
                            ├── get-stream@5.2.0 extraneous
                            ├── get-symbol-description@1.0.2 extraneous
                            ├── getpass@0.1.7 extraneous
                            ├── github-from-package@0.0.0 extraneous
                            ├── github-url-from-git@1.5.0 extraneous
                            ├── glob-parent@5.1.2 extraneous
                            ├── glob@10.4.5 extraneous
                            ├── global-dirs@2.1.0 extraneous
                            ├── globalthis@1.0.4 extraneous
                            ├── globby@11.1.0 extraneous
                            ├── glossy@0.1.7 extraneous
                            ├── google-auth-library@ extraneous
                            ├── google-p12-pem@4.0.1 extraneous
                            ├── googleapis-common@6.0.4 extraneous
                            ├── googleapis@ extraneous
                            ├── gtoken@6.1.2 extraneous
                            ├── hard-rejection@2.1.0 extraneous
                            ├── has-ansi@2.0.0 extraneous
                            ├── has-bigints@1.0.2 extraneous
                            ├── has-flag@4.0.0 extraneous
                            ├── has-tostringtag@1.0.2 extraneous
                            ├── has-unicode@2.0.1 extraneous
                            ├── has-yarn@2.1.0 extraneous
                            ├── he@1.2.0 extraneous
                            ├── help-me@5.0.0 extraneous
                            ├── homebridge-plugin-wrapper@ extraneous
                            ├── hosted-git-info@3.0.8 extraneous
                            ├── hot-patcher@1.0.0 extraneous
                            ├── html-encoding-sniffer@3.0.0 extraneous
                            ├── http-cache-semantics@4.1.1 extraneous
                            ├── http-errors@2.0.0 extraneous
                            ├── http-proxy-agent@5.0.0 extraneous
                            ├── http2-wrapper@1.0.3 extraneous
                            ├── https@1.0.0 extraneous
                            ├── humanize-ms@1.2.1 extraneous
                            ├── ical.js@ extraneous
                            ├── iconv-lite@0.4.24 extraneous
                            ├── ieee754@1.2.1 extraneous
                            ├── ignore-walk@3.0.4 extraneous
                            ├── ignore@5.3.2 extraneous
                            ├── image-type@4.1.0 extraneous
                            ├── immediate@3.0.6 extraneous
                            ├── import-fresh@3.3.0 extraneous
                            ├── import-lazy@2.1.0 extraneous
                            ├── import-local@3.2.0 extraneous
                            ├── imurmurhash@0.1.4 extraneous
                            ├── indent-string@3.2.0 extraneous
                            ├── infer-owner@1.0.4 extraneous
                            ├── inflight@1.0.6 extraneous
                            ├── ini@1.3.7 extraneous
                            ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                            ├── inquirer@7.3.3 extraneous
                            ├── int64-buffer@1.0.1 extraneous
                            ├── internal-slot@1.0.7 extraneous
                            ├── iobroker-adapter-helpers@0.0.8 extraneous
                            ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                            ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                            ├── iobroker.bmw@2.5.7
                            ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                            ├── iobroker.cloud@4.4.1
                            ├── iobroker.coronavirus-statistics@0.8.7
                            ├── iobroker.daswetter@3.1.10
                            ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                            ├── iobroker.dwd@2.8.5
                            ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                            ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                            ├── iobroker.eusec@1.1.2
                            ├── iobroker.flot@ invalid: "1.12.0" from the root project
                            ├── iobroker.fritzbox@0.2.1
                            ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                            ├── iobroker.fullybrowser@2.1.2
                            ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                            ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                            ├── iobroker.harmony@1.2.2
                            ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                            ├── iobroker.history@2.2.6
                            ├── iobroker.hm-rega@3.0.47
                            ├── iobroker.hm-rpc@1.15.19
                            ├── iobroker.hue@3.9.5
                            ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                            ├── iobroker.icons-icons8@0.0.1
                            ├── iobroker.icons-material-png@0.1.0
                            ├── iobroker.icons-mfd-png@1.1.0
                            ├── iobroker.icons-ultimate-png@1.0.1
                            ├── iobroker.info@ invalid: "1.9.26" from the root project
                            ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                            ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                            ├── iobroker.logparser@2.2.0
                            ├── iobroker.material@ invalid: "1.3.1" from the root project
                            ├── iobroker.meross@1.15.1
                            ├── iobroker.mihome-vacuum@3.11.0
                            ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                            ├── iobroker.milight@0.3.6
                            ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                            ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                            ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                            ├── iobroker.nina@ invalid: "0.0.25" from the root project
                            ├── iobroker.pollenflug@1.0.6
                            ├── iobroker.pushover@3.0.3
                            ├── iobroker.pushsafer@1.0.3
                            ├── iobroker.pvforecast@2.7.1
                            ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                            ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                            ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                            ├── iobroker.simple-api@2.7.2
                            ├── iobroker.smartmeter@3.3.4
                            ├── iobroker.socketio@6.5.2
                            ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                            ├── iobroker.sql@2.2.0
                            ├── iobroker.statistics@2.3.0
                            ├── iobroker.sunnyportal@0.1.5
                            ├── iobroker.synology@ invalid: "2.1.13" from the root project
                            ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                            ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                            ├── iobroker.tr-064@4.2.18
                            ├── iobroker.trashschedule@2.2.0
                            ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                            ├── iobroker.upnp@1.0.21
                            ├── iobroker.valloxmv@1.2.0
                            ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                            ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                            ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                            ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                            ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                            ├── iobroker.vis-fancyswitch@1.1.0
                            ├── iobroker.vis-google-fonts@1.0.4
                            ├── iobroker.vis-history@1.0.0
                            ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                            ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                            ├── iobroker.vis-jqui-mfd@1.0.12
                            ├── iobroker.vis-justgage@1.0.2
                            ├── iobroker.vis-map@1.0.4
                            ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                            ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                            ├── iobroker.vis-rgraph@0.0.2
                            ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                            ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                            ├── iobroker.vis@ invalid: "1.4.16" from the root project
                            ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                            ├── iobroker.weatherunderground@3.4.2
                            ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                            ├── iobroker.web@ invalid: "6.1.0" from the root project
                            ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                            ├── iobroker.wiffi-wz@2.2.1
                            ├── iobroker.windows-control@0.1.5
                            ├── iobroker.worx@2.3.2
                            ├── iobroker.ws@2.5.3
                            ├── iobroker@2.0.3
                            ├── ioredis@ extraneous
                            ├── ip-address@9.0.5 extraneous
                            ├── ip-regex@4.3.0 extraneous
                            ├── ipaddr.js@2.2.0 extraneous
                            ├── is-array-buffer@3.0.4 extraneous
                            ├── is-bigint@1.0.4 extraneous
                            ├── is-binary-path@2.1.0 extraneous
                            ├── is-boolean-object@1.1.2 extraneous
                            ├── is-buffer@1.1.6 extraneous
                            ├── is-callable@1.2.7 extraneous
                            ├── is-ci@2.0.0 extraneous
                            ├── is-core-module@2.15.0 extraneous
                            ├── is-data-view@1.0.1 extraneous
                            ├── is-date-object@1.0.5 extraneous
                            ├── is-docker@2.2.1 extraneous
                            ├── is-empty-object@1.1.1 extraneous
                            ├── is-extglob@2.1.1 extraneous
                            ├── is-fullwidth-code-point@3.0.0 extraneous
                            ├── is-glob@4.0.3 extraneous
                            ├── is-installed-globally@0.3.2 extraneous
                            ├── is-interactive@1.0.0 extraneous
                            ├── is-lambda@1.0.1 extraneous
                            ├── is-negative-zero@2.0.3 extraneous
                            ├── is-npm@5.0.0 extraneous
                            ├── is-number-object@1.0.7 extraneous
                            ├── is-number@7.0.0 extraneous
                            ├── is-obj@2.0.0 extraneous
                            ├── is-observable@1.1.0 extraneous
                            ├── is-path-cwd@2.2.0 extraneous
                            ├── is-path-inside@3.0.3 extraneous
                            ├── is-plain-obj@1.1.0 extraneous
                            ├── is-potential-custom-element-name@1.0.1 extraneous
                            ├── is-promise@2.2.2 extraneous
                            ├── is-property@1.0.2 extraneous
                            ├── is-regex@1.1.4 extraneous
                            ├── is-scoped@2.1.0 extraneous
                            ├── is-shared-array-buffer@1.0.3 extraneous
                            ├── is-string@1.0.7 extraneous
                            ├── is-symbol@1.0.4 extraneous
                            ├── is-typed-array@1.1.13 extraneous
                            ├── is-unicode-supported@0.1.0 extraneous
                            ├── is-url-superb@4.0.0 extraneous
                            ├── is-url@1.2.4 extraneous
                            ├── is-weakref@1.0.2 extraneous
                            ├── is-wsl@2.2.0 extraneous
                            ├── is-yarn-global@0.3.0 extraneous
                            ├── is@3.3.0 extraneous
                            ├── is2@2.0.9 extraneous
                            ├── isomorphic-ws@4.0.1 extraneous
                            ├── issue-regex@3.1.0 extraneous
                            ├── jackspeak@3.4.3 extraneous
                            ├── js-md4@0.3.2 extraneous
                            ├── js-sdsl@4.3.0 extraneous
                            ├── js-tokens@4.0.0 extraneous
                            ├── js-yaml@ extraneous
                            ├── jsbi@4.3.0 extraneous
                            ├── jsbn@1.1.0 extraneous
                            ├── jsdom@ extraneous
                            ├── jshashes@1.0.8 extraneous
                            ├── json-buffer@3.0.1 extraneous
                            ├── json-logic-js@2.0.5 extraneous
                            ├── json-parse-even-better-errors@2.3.1 extraneous
                            ├── json-schema-traverse@1.0.0 extraneous
                            ├── json5@2.2.3 extraneous
                            ├── jsonata@ extraneous
                            ├── jsonc-parser@3.3.1 extraneous
                            ├── jsonwebtoken@9.0.2 extraneous
                            ├── jszip@ extraneous
                            ├── jwa@2.0.0 extraneous
                            ├── jws@4.0.0 extraneous
                            ├── keyv@4.5.4 extraneous
                            ├── kind-of@6.0.3 extraneous
                            ├── kuler@2.0.0 extraneous
                            ├── later@1.2.0 extraneous
                            ├── latest-version@5.1.0 extraneous
                            ├── layerr@0.1.2 extraneous
                            ├── lazystream@1.0.1 extraneous
                            ├── leven@2.1.0 extraneous
                            ├── levn@0.3.0 extraneous
                            ├── lie@3.3.0 extraneous
                            ├── lines-and-columns@1.2.4 extraneous
                            ├── listr-input@0.2.1 extraneous
                            ├── listr-silent-renderer@1.1.1 extraneous
                            ├── listr-update-renderer@0.5.0 extraneous
                            ├── listr-verbose-renderer@0.5.0 extraneous
                            ├── listr@0.14.3 extraneous
                            ├── loadavg-windows@1.1.1 extraneous
                            ├── locate-path@6.0.0 extraneous
                            ├── lodash.defaults@4.2.0 extraneous
                            ├── lodash.flatten@4.4.0 extraneous
                            ├── lodash.includes@4.3.0 extraneous
                            ├── lodash.isarguments@3.1.0 extraneous
                            ├── lodash.isboolean@3.0.3 extraneous
                            ├── lodash.isequal@4.5.0 extraneous
                            ├── lodash.isinteger@4.0.4 extraneous
                            ├── lodash.isnumber@3.0.3 extraneous
                            ├── lodash.isplainobject@4.0.6 extraneous
                            ├── lodash.isstring@4.0.1 extraneous
                            ├── lodash.once@4.1.1 extraneous
                            ├── lodash.zip@4.2.0 extraneous
                            ├── log-symbols@4.1.0 extraneous
                            ├── log-update@2.3.0 extraneous
                            ├── logform@ extraneous
                            ├── long@5.2.3 extraneous
                            ├── lowercase-keys@2.0.0 extraneous
                            ├── lru_map@0.3.3 extraneous
                            ├── lru-cache@6.0.0 extraneous
                            ├── make-dir@3.1.0 extraneous
                            ├── make-fetch-happen@10.2.1 extraneous
                            ├── map-age-cleaner@0.1.3 extraneous
                            ├── map-obj@4.3.0 extraneous
                            ├── map-stream@0.0.7 extraneous
                            ├── md5@2.3.0 extraneous
                            ├── media-typer@0.3.0 extraneous
                            ├── meow@8.1.2 extraneous
                            ├── merge-descriptors@1.0.1 extraneous
                            ├── merge2@1.4.1 extraneous
                            ├── methods@1.1.2 extraneous
                            ├── micro@9.4.1 extraneous
                            ├── micromatch@4.0.7 extraneous
                            ├── mime-db@1.53.0 extraneous
                            ├── mimic-response@1.0.1 extraneous
                            ├── min-indent@1.0.1 extraneous
                            ├── minimatch@9.0.5 extraneous
                            ├── minimist-options@4.1.0 extraneous
                            ├── minipass-collect@1.0.2 extraneous
                            ├── minipass-fetch@2.1.2 extraneous
                            ├── minipass-flush@1.0.5 extraneous
                            ├── minipass-pipeline@1.2.4 extraneous
                            ├── minipass-sized@1.0.3 extraneous
                            ├── minipass@7.1.2 extraneous
                            ├── minizlib@2.1.2 extraneous
                            ├── mkdirp-classic@0.5.3 extraneous
                            ├── mkdirp@1.0.4 extraneous
                            ├── mock-require@3.0.3 extraneous
                            ├── moment-duration-format@2.3.2 extraneous
                            ├── mqtt-connection@4.1.0 extraneous
                            ├── mqtt-packet@9.0.0 extraneous
                            ├── mqtt@ extraneous
                            ├── mute-stream@0.0.8 extraneous
                            ├── named-placeholders@1.1.3 extraneous
                            ├── nan@ extraneous
                            ├── nanoid@3.3.7 extraneous
                            ├── napi-build-utils@1.0.2 extraneous
                            ├── native-duplexpair@1.0.0 extraneous
                            ├── nconf@0.10.0 extraneous
                            ├── nested-property@4.0.0 extraneous
                            ├── netmask@2.0.2 extraneous
                            ├── new-github-release-url@1.0.0 extraneous
                            ├── node-abi@3.65.0 extraneous
                            ├── node-abort-controller@3.1.1 extraneous
                            ├── node-cron@2.0.3 extraneous
                            ├── node-fetch@2.7.0 extraneous
                            ├── node-forge@ extraneous
                            ├── node-gyp@ extraneous
                            ├── node-ical@0.16.1 extraneous
                            ├── node-inspect@2.0.0 extraneous
                            ├── node-libcurl@3.0.0 extraneous
                            ├── node-mndp@0.0.3 extraneous
                            ├── node-persist@0.0.11 extraneous
                            ├── node-rsa@1.1.1 extraneous
                            ├── node-unifi@2.5.1 extraneous
                            ├── node-wol@0.1.1 extraneous
                            ├── node.extend@2.0.3 extraneous
                            ├── nopt@5.0.0 extraneous
                            ├── normalize-package-data@3.0.3 extraneous
                            ├── normalize-path@3.0.0 extraneous
                            ├── normalize-url@6.1.0 extraneous
                            ├── np@7.7.0 extraneous
                            ├── npm-name@6.0.1 extraneous
                            ├── npmlog@5.0.1 extraneous
                            ├── number-allocator@1.0.14 extraneous
                            ├── nwsapi@2.2.12 extraneous
                            ├── object-assign@4.1.1 extraneous
                            ├── object-hash@3.0.0 extraneous
                            ├── on-finished@2.4.1 extraneous
                            ├── once@1.4.0 extraneous
                            ├── one-time@1.0.0 extraneous
                            ├── onedrive-api@1.1.1 extraneous
                            ├── open@7.4.2 extraneous
                            ├── opencollective-postinstall@2.0.3 extraneous
                            ├── optionator@0.8.3 extraneous
                            ├── org-regex@1.0.0 extraneous
                            ├── os-tmpdir@1.0.2 extraneous
                            ├── ospath@1.2.2 extraneous
                            ├── osx-temperature-sensor@ extraneous
                            ├── otplib@11.0.1 extraneous
                            ├── ow@0.21.0 extraneous
                            ├── p-cancelable@2.1.1 extraneous
                            ├── p-defer@1.0.0 extraneous
                            ├── p-event@4.2.0 extraneous
                            ├── p-finally@1.0.0 extraneous
                            ├── p-limit@2.3.0 extraneous
                            ├── p-locate@5.0.0 extraneous
                            ├── p-map@2.1.0 extraneous
                            ├── p-memoize@4.0.4 extraneous
                            ├── p-reflect@2.1.0 extraneous
                            ├── p-settle@4.1.1 extraneous
                            ├── p-throttle@4.1.1 extraneous
                            ├── p-timeout@4.1.0 extraneous
                            ├── p-try@2.2.0 extraneous
                            ├── package-json-from-dist@1.0.0 extraneous
                            ├── package-json@6.5.0 extraneous
                            ├── pako@ extraneous
                            ├── parent-module@1.0.1 extraneous
                            ├── parse-json@5.2.0 extraneous
                            ├── parse5@ extraneous
                            ├── passport-local@1.0.0 extraneous
                            ├── passport@0.7.0 extraneous
                            ├── path-exists@4.0.0 extraneous
                            ├── path-is-absolute@1.0.1 extraneous
                            ├── path-parse@1.0.7 extraneous
                            ├── path-posix@1.0.0 extraneous
                            ├── path-scurry@1.11.1 extraneous
                            ├── path-to-regexp@0.1.7 extraneous
                            ├── path-type@4.0.0 extraneous
                            ├── pause-stream@0.0.11 extraneous
                            ├── picomatch@2.3.1 extraneous
                            ├── pidtree@0.6.0 extraneous
                            ├── pidusage@3.0.2 extraneous
                            ├── ping@0.4.4 extraneous
                            ├── pkg-dir@5.0.0 extraneous
                            ├── pluralize@8.0.0 extraneous
                            ├── possible-typed-array-names@1.0.0 extraneous
                            ├── prebuild-install@7.1.2 extraneous
                            ├── prelude-ls@1.1.2 extraneous
                            ├── prepend-http@2.0.0 extraneous
                            ├── process-nextick-args@2.0.1 extraneous
                            ├── process@0.11.10 extraneous
                            ├── promise-inflight@1.0.1 extraneous
                            ├── promise-object@0.1.7 extraneous
                            ├── promise-retry@2.0.1 extraneous
                            ├── promise-retryer@0.0.1 extraneous
                            ├── promisify-child-process@4.1.2 extraneous
                            ├── prompt@1.3.0 extraneous
                            ├── protobufjs@ extraneous
                            ├── proxy-addr@2.0.7 extraneous
                            ├── proxy-from-env@1.1.0 extraneous
                            ├── pump@3.0.0 extraneous
                            ├── pupa@2.1.1 extraneous
                            ├── q@1.1.2 extraneous
                            ├── quasar@ extraneous
                            ├── queue-microtask@1.2.3 extraneous
                            ├── queue-tick@1.0.1 extraneous
                            ├── quick-lru@5.1.1 extraneous
                            ├── range-parser@1.2.1 extraneous
                            ├── raw-body@2.5.2 extraneous
                            ├── rc@1.2.8 extraneous
                            ├── read-pkg-up@7.0.1 extraneous
                            ├── read-pkg@5.2.0 extraneous
                            ├── read@1.0.7 extraneous
                            ├── readable-stream@ extraneous
                            ├── readdir-glob@1.1.3 extraneous
                            ├── readdirp@3.6.0 extraneous
                            ├── readline-sync@1.4.10 extraneous
                            ├── readline@1.3.0 extraneous
                            ├── redent@3.0.0 extraneous
                            ├── redis-commands@1.7.0 extraneous
                            ├── redis-errors@1.2.0 extraneous
                            ├── redis-parser@3.0.0 extraneous
                            ├── regenerator-runtime@0.14.1 extraneous
                            ├── regex-escape@3.4.10 extraneous
                            ├── regexp.prototype.flags@1.5.2 extraneous
                            ├── registry-auth-token@4.2.2 extraneous
                            ├── registry-url@5.1.0 extraneous
                            ├── reinterval@1.1.0 extraneous
                            ├── remove-trailing-separator@1.1.0 extraneous
                            ├── require-from-string@2.0.2 extraneous
                            ├── resolve-alpn@1.2.1 extraneous
                            ├── resolve-cwd@3.0.0 extraneous
                            ├── resolve-from@4.0.0 extraneous
                            ├── respjs@4.2.0 extraneous
                            ├── responselike@2.0.1 extraneous
                            ├── restore-cursor@3.1.0 extraneous
                            ├── retry-axios@2.6.0 extraneous
                            ├── retry@0.12.0 extraneous
                            ├── reusify@1.0.4 extraneous
                            ├── revalidator@0.1.8 extraneous
                            ├── rfdc@1.4.1 extraneous
                            ├── rimraf@3.0.2 extraneous
                            ├── rrule@2.8.1 extraneous
                            ├── rrweb-cssom@0.6.0 extraneous
                            ├── run-async@2.4.1 extraneous
                            ├── run-parallel@1.2.0 extraneous
                            ├── rxjs@ extraneous
                            ├── safe-array-concat@1.1.2 extraneous
                            ├── safe-regex-test@1.0.3 extraneous
                            ├── safe-stable-stringify@2.4.3 extraneous
                            ├── safer-buffer@2.1.2 extraneous
                            ├── saxes@6.0.0 extraneous
                            ├── scoped-regex@2.1.0 extraneous
                            ├── secure-keys@1.0.0 extraneous
                            ├── semver-diff@3.1.1 extraneous
                            ├── semver@5.7.2
                            ├── send@0.18.0 extraneous
                            ├── seq-logging@1.1.2 extraneous
                            ├── seq-queue@0.0.5 extraneous
                            ├── serve-static@1.15.0 extraneous
                            ├── set-function-name@2.0.2 extraneous
                            ├── setimmediate@1.0.5 extraneous
                            ├── setprototypeof@1.2.0 extraneous
                            ├── signal-exit@4.1.0 extraneous
                            ├── simple-concat@1.0.1 extraneous
                            ├── simple-get@3.1.1 extraneous
                            ├── simple-ssh@1.1.1 extraneous
                            ├── simple-swizzle@0.2.2 extraneous
                            ├── slash@3.0.0 extraneous
                            ├── slice-ansi@0.0.4 extraneous
                            ├── smart-buffer@4.2.0 extraneous
                            ├── socks-proxy-agent@7.0.0 extraneous
                            ├── socks@2.8.3 extraneous
                            ├── speedtest-net@1.6.2 extraneous
                            ├── split@1.0.1 extraneous
                            ├── sprintf-js@1.1.3 extraneous
                            ├── sqlstring@2.3.3 extraneous
                            ├── ssh2@ extraneous
                            ├── ssri@9.0.1 extraneous
                            ├── stack-trace@0.0.10 extraneous
                            ├── stampit-event-bus@0.1.1 extraneous
                            ├── stampit-state-machine@0.2.1 extraneous
                            ├── stampit@2.1.2 extraneous
                            ├── standard-as-callback@2.1.0 extraneous
                            ├── static-eval@2.0.2 extraneous
                            ├── statuses@2.0.1 extraneous
                            ├── stoppable@1.1.0 extraneous
                            ├── stream-combiner@0.2.2 extraneous
                            ├── stream-shift@1.0.3 extraneous
                            ├── streamsearch@1.1.0 extraneous
                            ├── streamx@2.18.0 extraneous
                            ├── string-argv@0.3.2 extraneous
                            ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                            ├── string-width@5.1.2 extraneous
                            ├── string.prototype.trim@1.2.9 extraneous
                            ├── string.prototype.trimend@1.0.8 extraneous
                            ├── string.prototype.trimstart@1.0.8 extraneous
                            ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                            ├── strip-ansi@6.0.1 extraneous
                            ├── strip-indent@3.0.0 extraneous
                            ├── strip-json-comments@2.0.1 extraneous
                            ├── strnum@1.0.5 extraneous
                            ├── suncalc@1.9.0 extraneous
                            ├── suncalc2@1.8.1 extraneous
                            ├── supermixer@1.0.5 extraneous
                            ├── supports-color@7.2.0 extraneous
                            ├── supports-hyperlinks@2.3.0 extraneous
                            ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                            ├── sweet-collections@1.1.0 extraneous
                            ├── symbol-observable@3.0.0 extraneous
                            ├── symbol-tree@3.2.4 extraneous
                            ├── syno@ extraneous
                            ├── systeminformation@ extraneous
                            ├── tar-fs@2.1.1 extraneous
                            ├── tar-stream@3.1.7 extraneous
                            ├── tar@6.2.1 extraneous
                            ├── tarn@3.0.2 extraneous
                            ├── tcp-port-used@1.0.2 extraneous
                            ├── tedious@ extraneous
                            ├── terminal-link@2.1.1 extraneous
                            ├── text-decoder@1.1.1 extraneous
                            ├── text-hex@1.0.0 extraneous
                            ├── thirty-two@1.0.2 extraneous
                            ├── through@2.3.8 extraneous
                            ├── through2@2.0.5 extraneous
                            ├── tiny-typed-emitter@2.1.0 extraneous
                            ├── tinycolor2@1.6.0 extraneous
                            ├── tmp@0.0.33 extraneous
                            ├── to-readable-stream@2.1.0 extraneous
                            ├── to-regex-range@5.0.1 extraneous
                            ├── toidentifier@1.0.1 extraneous
                            ├── tr46@4.1.1 extraneous
                            ├── trim-newlines@3.0.1 extraneous
                            ├── triple-beam@1.4.1 extraneous
                            ├── tsdav@ extraneous
                            ├── tslib@2.3.0 extraneous
                            ├── tweetnacl@0.14.5 extraneous
                            ├── type-check@0.3.2 extraneous
                            ├── type-fest@0.21.3 extraneous
                            ├── type-is@1.6.18 extraneous
                            ├── typed-array-buffer@1.0.2 extraneous
                            ├── typed-array-byte-length@1.0.1 extraneous
                            ├── typed-array-byte-offset@1.0.2 extraneous
                            ├── typed-array-length@1.0.6 extraneous
                            ├── typedarray-to-buffer@3.1.5 extraneous
                            ├── typedarray.prototype.slice@1.0.3 extraneous
                            ├── typescript@ extraneous
                            ├── tz-offset@0.0.1 extraneous
                            ├── uid-number@0.0.6 extraneous
                            ├── unbox-primitive@1.0.2 extraneous
                            ├── undici-types@6.19.6 extraneous
                            ├── unique-filename@2.0.1 extraneous
                            ├── unique-slug@3.0.0 extraneous
                            ├── unique-string@2.0.0 extraneous
                            ├── unix-dgram@2.0.6 extraneous
                            ├── unpipe@1.0.0 extraneous
                            ├── update-notifier@5.1.0 extraneous
                            ├── uri-js@4.4.1 extraneous
                            ├── url-join@4.0.1 extraneous
                            ├── url-parse-lax@3.0.0 extraneous
                            ├── url-template@2.0.8 extraneous
                            ├── url@0.11.4 extraneous
                            ├── vali-date@1.0.0 extraneous
                            ├── validate-npm-package-name@3.0.0 extraneous
                            ├── vary@1.1.2 extraneous
                            ├── virtual-tsc@0.6.2 extraneous
                            ├── vue-i18n@ extraneous
                            ├── vuelidate-messages@0.1.2 extraneous
                            ├── vuelidate@ extraneous
                            ├── vuex-map-fields@1.4.1 extraneous
                            ├── w3c-xmlserializer@4.0.0 extraneous
                            ├── wake_on_lan@1.0.0 extraneous
                            ├── weak-daemon@1.0.3 extraneous
                            ├── webdav@ extraneous
                            ├── webidl-conversions@7.0.0 extraneous
                            ├── websocket-stream@5.5.2 extraneous
                            ├── whatwg-encoding@2.0.0 extraneous
                            ├── whatwg-mimetype@3.0.0 extraneous
                            ├── whatwg-url@12.0.1 extraneous
                            ├── which-boxed-primitive@1.0.2 extraneous
                            ├── which-typed-array@1.1.15 extraneous
                            ├── wide-align@1.1.5 extraneous
                            ├── widest-line@3.1.0 extraneous
                            ├── window-size@0.1.4 extraneous
                            ├── winston-daily-rotate-file@5.0.0 extraneous
                            ├── winston-seq-updated@1.0.4 extraneous
                            ├── winston-syslog@2.7.1 extraneous
                            ├── winston-transport@4.7.1 extraneous
                            ├── winston@ extraneous
                            ├── word-wrap@1.2.5 extraneous
                            ├── worker-timers-broker@6.1.8 extraneous
                            ├── worker-timers-worker@7.0.71 extraneous
                            ├── worker-timers@7.1.8 extraneous
                            ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                            ├── wrap-ansi@8.1.0 extraneous
                            ├── wrappy@1.0.2 extraneous
                            ├── write-file-atomic@3.0.3 extraneous
                            ├── xdg-basedir@4.0.0 extraneous
                            ├── xml-js@1.6.11 extraneous
                            ├── xml-name-validator@4.0.0 extraneous
                            ├── xmlchars@2.2.0 extraneous
                            ├── xregexp@2.0.0 extraneous
                            ├── yallist@4.0.0 extraneous
                            ├── yaml@ extraneous
                            ├── yargs-parser@20.2.9 extraneous
                            ├── yargs@7.1.2
                            ├── yocto-queue@0.1.0 extraneous
                            ├── zip-stream@6.0.1 extraneous
                            └── zrender@ extraneous
                            @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                            hast du beide Befehle auf einmal gestartet?
                            bitte einzeln abarbeiten
                            F Thomas BraunT 2 Antworten Letzte Antwort
                              flommaster
                              Ja,
                              Hier ist das Ergebnis von "npm prune"
                              npm warn deprecated
                                @flommaster
                                Gerade noch gehabt...
                                Vollständig.
                                Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                                Und auch inkl. der neuen leeren Eingabezeile, damit man sieht das es durchgelaufen ist und da nix fehlt.
                                iobroker url https://github.com/DrozmotiX/ioBroker.sourceanalytix --debug
                                  @flommaster
                                  Vollständig.
                                  flommaster
                                  schrieb am zuletzt editiert von flommaster
                                  @thomas-braun @Homoran
                                  hier ist noch das Ergebnis von npm prune
                                  root@ioBrokerdebian:/home/flo# npm prune
                                  up to date, audited 135 packages in 2s
                                  11 packages are looking for funding
                                    run `npm fund` for details
                                  4 vulnerabilities (2 moderate, 2 high)
                                  To address all issues, run:
                                    npm audit fix
                                  Run `npm audit` for details.
                                  npm ls
                                  root@ioBrokerdebian:/home/flo# npm ls
                                  flo@ /home/flo
                                  └── iobroker.admin@6.10.2
                                  Vielen Dank und viele Grüße
                                  • F flommaster
                                      npm audit fix
                                    npm ls
                                    flo@ /home/flo
                                    root@
                                    Nie nie niemals als root herumkaspern...
                                      root@
                                      flommaster
                                      Ok. Mach ich nicht mehr.
                                      Davor bin ich noch der Anweisung gefolgt und habe den Befehl "npm audit fix" ausgeführt.
                                      Danach wurden mir bei npm prune keine Fehler mehr angezeigt.
                                      up to date, audited 133 packages in 2s
                                      found 0 vulnerabilities
                                      flo@ /home/flo
                                      • F flommaster
                                        flo@ /home/flo
                                        @flommaster
                                        Mooooooooooooooarrrrrrrrrrrr...
                                        MELD DICH ALS ROOT AB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                        Und NIE NIE NIEMEHR als root an!!!!!!!!!!!!!!!!
                                        Und du hampelst dann auch im falschen Verzeichnis herum....
                                        Und iobroker admin hat in /home/flo auch nix verloren...
                                        Und auch nie npm audit fix ausführen. Insbesondere nicht mit --force.
                                        Das macht dir auch mehr kaputt als das es hilft.
                                          @flommaster
                                          flommaster
                                          erledigt. Bin als Root abgemeldet.
                                          Sorry, das wusste ich nicht.
                                          Ich habe npm prune gerade unter dem Verzeichnis "/opt/iobroker" gestartet.
                                          Hier ist das Ergebnis:
                                          npm error code ENOTEMPTY
                                          npm error syscall rename
                                          npm error path /opt/iobroker/node_modules/ajv
                                          npm error dest /opt/iobroker/node_modules/.ajv-Kze9IpmC
                                          npm error errno -39
                                          npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ajv' -> '/opt/iobroker/node_modules/.ajv-Kze9IpmC'
                                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T19_54_02_939Z-debug-0.log
                                          npm ls
                                          flo@ioBrokerdebian:~$ cd /opt/iobroker && npm ls
                                          [sudo] Passwort für flo:
                                          ├── @azure/core-http-compat@2.1.2 extraneous
                                          ├── @azure/core-util@1.9.2 extraneous
                                          ├── @azure/keyvault-keys@4.8.0 extraneous
                                          ├── @azure/msal-node@ extraneous
                                          ├── @iobroker/db-base@6.0.10 extraneous
                                          ├── @iobroker/db-objects-file@6.0.10 extraneous
                                          ├── @iobroker/db-objects-jsonl@6.0.10 extraneous
                                          ├── @iobroker/db-objects-redis@6.0.10 extraneous
                                          ├── @iobroker/db-states-file@6.0.10 extraneous
                                          ├── @iobroker/db-states-jsonl@6.0.10 extraneous
                                          ├── @iobroker/db-states-redis@6.0.10 extraneous
                                          ├── @iobroker/js-controller-adapter@6.0.10 extraneous
                                          ├── @iobroker/js-controller-common-db@6.0.10 extraneous
                                          ├── @iobroker/js-controller-common@6.0.10 extraneous
                                          ├── @sentry/node@5.30.0 extraneous
                                          ├── @sentry/types@5.30.0 extraneous
                                          ├── @sentry/utils@5.30.0 extraneous
                                          ├── ajv@ extraneous
                                          ├── colors@1.4.0
                                          ├── crc@4.1.1 extraneous
                                          ├── cssstyle@3.0.0 extraneous
                                          ├── fast-unique-numbers@8.0.13 extraneous
                                          ├── fast-xml-parser@4.4.1 extraneous
                                          ├── fs-extra@7.0.1
                                          ├── google-auth-library@8.9.0 extraneous
                                          ├── ical.js@1.5.0 extraneous
                                          ├── iobroker.fullcalendar@1.2.0
                                          ├── iobroker.heatingcontrol@2.11.1
                                          ├── iobroker.synology@2.1.13
                                          ├── iobroker.terminal@1.0.0
                                          ├── iobroker.unifi@0.6.6
                                          ├── iobroker.vis-colorpicker@2.0.3
                                          ├── iobroker.vis-hqwidgets@1.4.0
                                          ├── iobroker.vis-inventwo@3.3.3
                                          ├── iobroker.vis-timeandweather@1.2.2
                                          ├── iobroker@2.0.3
                                          ├── ioredis@4.28.5 extraneous
                                          ├── js-yaml@3.14.1 extraneous
                                          ├── jsonata@2.0.5 extraneous
                                          ├── jszip@3.10.1 extraneous
                                          ├── logform@2.6.1 extraneous
                                          ├── node-gyp@9.3.0 extraneous
                                          ├── pako@1.0.11 extraneous
                                          ├── parse5@7.1.2 extraneous
                                          ├── semver@5.7.2
                                          ├── systeminformation@5.23.4 extraneous
                                          ├── tsdav@2.1.1 extraneous
                                          ├── vue-i18n@8.28.2 extraneous
                                          ├── vuelidate@0.7.7 extraneous
                                          ├── webdav@4.11.3 extraneous
                                          ├── winston@3.14.2 extraneous
                                          ├── yargs@7.1.2
                                          npm error code ELSPROBLEMS
                                          npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                          npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                          npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                                          npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                          npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                                          npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                                          npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                                          npm error extraneous: @azure/core-http-compat@2.1.2 /opt/iobroker/node_modules/@azure/core-http-compat
                                          npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                                          npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                                          npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                                          npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                                          npm error extraneous: @azure/core-util@1.9.2 /opt/iobroker/node_modules/@azure/core-util
                                          npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                                          npm error extraneous: @azure/keyvault-keys@4.8.0 /opt/iobroker/node_modules/@azure/keyvault-keys
                                          npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                                          npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                                          npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                                          npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
                                          npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                                          npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                                          npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                                          npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                          npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                                          npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                                          npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                                          npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                                          npm error extraneous: @iobroker/db-base@6.0.10 /opt/iobroker/node_modules/@iobroker/db-base
                                          npm error extraneous: @iobroker/db-objects-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-file
                                          npm error extraneous: @iobroker/db-objects-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                          npm error extraneous: @iobroker/db-objects-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                          npm error extraneous: @iobroker/db-states-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-file
                                          npm error extraneous: @iobroker/db-states-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                          npm error extraneous: @iobroker/db-states-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-redis
                                          npm error extraneous: @iobroker/js-controller-adapter@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                          npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                          npm error extraneous: @iobroker/js-controller-common-db@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                          npm error extraneous: @iobroker/js-controller-common@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common
                                          npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                          npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                          npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                                          npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                                          npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                                          npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                                          npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                                          npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                                          npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                                          npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                                          npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                          npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                          npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                          npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                          npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                          npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                          npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                          npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                          npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                          npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                          npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                                          npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                                          npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                                          npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                                          npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                                          npm error extraneous: @sentry/node@5.30.0 /opt/iobroker/node_modules/@sentry/node
                                          npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                                          npm error extraneous: @sentry/types@5.30.0 /opt/iobroker/node_modules/@sentry/types
                                          npm error extraneous: @sentry/utils@5.30.0 /opt/iobroker/node_modules/@sentry/utils
                                          npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                          npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                          npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                                          npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                                          npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                                          npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                          npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                          npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                                          npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                                          npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                          npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                                          npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                          npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                          npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                                          npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                                          npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                                          npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                                          npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                                          npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                          npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                                          npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                                          npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                                          npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                          npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                                          npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                                          npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                                          npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                                          npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                                          npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                          npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                          npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                                          npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                                          npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                          npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                                          npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                          npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                                          npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                                          npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                          npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                          npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                          npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                          npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                                          npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                          npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                                          npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                                          npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                                          npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                          npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                          npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                                          npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                                          npm error extraneous: crc@4.1.1 /opt/iobroker/node_modules/crc
                                          npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                                          npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                                          npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                          npm error extraneous: cssstyle@3.0.0 /opt/iobroker/node_modules/cssstyle
                                          npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                          npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                                          npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                                          npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                                          npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                                          npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                                          npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                                          npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                                          npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                          npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                          npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                                          npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                          npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                                          npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                                          npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                                          npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                                          npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                          npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                          npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                                          npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                          npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                          npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                                          npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                          npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                                          npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                                          npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                          npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                                          npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                                          npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                                          npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                          npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                          npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                                          npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                          npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                          npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                          npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                                          npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                          npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                                          npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                                          npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                          npm error extraneous: fast-unique-numbers@8.0.13 /opt/iobroker/node_modules/fast-unique-numbers
                                          npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                                          npm error extraneous: fast-xml-parser@4.4.1 /opt/iobroker/node_modules/fast-xml-parser
                                          npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                          npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                                          npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                                          npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                          npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                          npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                          npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                                          npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                          npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                          npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                          npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                          npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                                          npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                          npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                          npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                                          npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                                          npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                                          npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                                          npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                          npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                                          npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                                          npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                          npm error extraneous: google-auth-library@8.9.0 /opt/iobroker/node_modules/google-auth-library
                                          npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                          npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                                          npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                                          npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                          npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                          npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                                          npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                          npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                                          npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                          npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                          npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                          npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                          npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                          npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                          npm error extraneous: ical.js@1.5.0 /opt/iobroker/node_modules/ical.js
                                          npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                                          npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                                          npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                                          npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                                          npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                          npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                          npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                                          npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                          npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                          npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                                          npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                          npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                                          npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                                          npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                          npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                          npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                          npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                          npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                          npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                                          npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                          npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                                          npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                                          npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                                          npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                                          npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                                          npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                                          npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                                          npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                          npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                                          npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                                          npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                                          npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                                          npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                          npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                          npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                          npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                          npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                                          npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                                          npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                          npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                                          npm error extraneous: ioredis@4.28.5 /opt/iobroker/node_modules/ioredis
                                          npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                                          npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                                          npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                                          npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                                          npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                          npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                          npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                          npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                          npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                          npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                                          npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                          npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                                          npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                                          npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                                          npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                          npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                          npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                          npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                                          npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                          npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                          npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                                          npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                                          npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                          npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                          npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                                          npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                                          npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                                          npm error extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/js-yaml
                                          npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                                          npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                                          npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                          npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                          npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                                          npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                                          npm error extraneous: jsonata@2.0.5 /opt/iobroker/node_modules/jsonata
                                          npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                                          npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                                          npm error extraneous: jszip@3.10.1 /opt/iobroker/node_modules/jszip
                                          npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                          npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                          npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                          npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                          npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                                          npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                          npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                          npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                          npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                          npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                          npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                          npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                          npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                          npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                          npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                          npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                          npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                          npm error extraneous: logform@2.6.1 /opt/iobroker/node_modules/logform
                                          npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                                          npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                                          npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                          npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                          npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                                          npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                                          npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                                          npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                                          npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                                          npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                                          npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                                          npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                                          npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                          npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                          npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                                          npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                                          npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                                          npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                          npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                                          npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                          npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                                          npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                                          npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                          npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                                          npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                                          npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                                          npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                                          npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                          npm error extraneous: node-gyp@9.3.0 /opt/iobroker/node_modules/node-gyp
                                          npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                                          npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                          npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                                          npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                          npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                          npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                          npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                          npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                                          npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                          npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                                          npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                          npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                          npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                                          npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                                          npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                                          npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                          npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                                          npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                          npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                                          npm error extraneous: pako@1.0.11 /opt/iobroker/node_modules/pako
                                          npm error extraneous: parse5@7.1.2 /opt/iobroker/node_modules/parse5
                                          npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                                          npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                          npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                          npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                                          npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                          npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                                          npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                                          npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                                          npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                                          npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                                          npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                                          npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                                          npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                                          npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                                          npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                                          npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                                          npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                          npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                          npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                          npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                                          npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                          npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                          npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                                          npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                          npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                          npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                          npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                          npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                          npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                          npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                                          npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                                          npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                                          npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                          npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                                          npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                          npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                                          npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                          npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                          npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                                          npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                                          npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                                          npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                                          npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                                          npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                          npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                                          npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                                          npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                                          npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                          npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                                          npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                          npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                          npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                                          npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                                          npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                                          npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                                          npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                                          npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                          npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                                          npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                                          npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                                          npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                          npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                                          npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                          npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                                          npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                                          npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                          npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                                          npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                                          npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                                          npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                                          npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                                          npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                                          npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                          npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                                          npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                          npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                                          npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                          npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                                          npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                          npm error extraneous: systeminformation@5.23.4 /opt/iobroker/node_modules/systeminformation
                                          npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                                          npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                                          npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                                          npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                                          npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                          npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                                          npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                          npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                                          npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                                          npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                                          npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                                          npm error extraneous: tsdav@2.1.1 /opt/iobroker/node_modules/tsdav
                                          npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                                          npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                                          npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                                          npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                                          npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                                          npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                                          npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                          npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                                          npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                          npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                                          npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                                          npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                                          npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                                          npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                          npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                          npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                          npm error extraneous: vue-i18n@8.28.2 /opt/iobroker/node_modules/vue-i18n
                                          npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                                          npm error extraneous: vuelidate@0.7.7 /opt/iobroker/node_modules/vuelidate
                                          npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                                          npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                          npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                          npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                          npm error extraneous: webdav@4.11.3 /opt/iobroker/node_modules/webdav
                                          npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                          npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                          npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                          npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                          npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                                          npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                          npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                                          npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                                          npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                                          npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                          npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                                          npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                                          npm error extraneous: winston@3.14.2 /opt/iobroker/node_modules/winston
                                          npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                                          npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                                          npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                                          npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                                          npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                                          npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                                          npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                          npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                          npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                          npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                                          npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T19_53_39_857Z-debug-0.log
                                          flo@ioBrokerdebian:/opt/iobroker$
