  4. zigbee Adapter startet nicht "unavailable Cannot lock port"
28 Beiträge 7 Kommentatoren 4.0k Aufrufe 5 Beobachtet
  • E edonisXP
    [Sun Jun 30 18:36:24 2024] usb 1-1.4: USB disconnect, device number 4
    [Sun Jun 30 18:36:59 2024] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
    [Sun Jun 30 18:36:59 2024] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
    [Sun Jun 30 18:36:59 2024] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [Sun Jun 30 18:36:59 2024] usb 1-1.4: Product: CC2538 USB CDC
    [Sun Jun 30 18:36:59 2024] usb 1-1.4: Manufacturer: Texas Instruments
    [Sun Jun 30 18:36:59 2024] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
    @edonisxp
    Der service ist ausgeknipst?
    sudo systemctl status ModemManager.service
    sagt?
    Kiste mal neugestartet?
    E 1 Antwort Letzte Antwort
    • E edonisXP
      ich brauche mal eure Hilfe, ich bekomme Zigbee nicht mehr zum laufen, der Adapter bleibt gelb.
      Als Stick habe ich den CC2538.
      Folgende Fehlermeldung kommt zum Start:
      2024-06-30 16:22:03.776 - info: host.pi "system.adapter.zigbee.0" enabled
      2024-06-30 16:22:04.696 - info: host.pi instance system.adapter.zigbee.0 started with pid 4896
      2024-06-30 16:22:09.529 - info: zigbee.0 (4896) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.0, js-controller: 6.0.5
      2024-06-30 16:22:09.627 - info: zigbee.0 (4896) delete old Backup files. keep only last 10
      2024-06-30 16:22:09.630 - info: zigbee.0 (4896) Starting Zigbee npm ...
      2024-06-30 16:22:09.988 - info: zigbee.0 (4896) Installed Version: iobroker.zigbee@1.10.3
      2024-06-30 16:22:44.649 - error: zigbee.0 (4896) Starting zigbee-herdsman problem : "network commissioning failed - timed out waiting for nib to settle"
      2024-06-30 16:22:44.650 - error: zigbee.0 (4896) Failed to start Zigbee
      2024-06-30 16:22:44.651 - error: zigbee.0 (4896) Error herdsman start
      2024-06-30 16:22:54.652 - info: zigbee.0 (4896) Try to reconnect. 1 attempts left
      2024-06-30 16:22:54.653 - info: zigbee.0 (4896) Starting Zigbee npm ...
      2024-06-30 16:22:54.668 - info: zigbee.0 (4896) Installed Version: iobroker.zigbee@1.10.3
      2024-06-30 16:22:54.822 - error: zigbee.0 (4896) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      2024-06-30 16:22:54.823 - error: zigbee.0 (4896) Failed to start Zigbee
      2024-06-30 16:22:54.824 - error: zigbee.0 (4896) Error herdsman start
      Hier sehe ich auch keine Auffälligkeiten::
      iob diag:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: pi
             Icon name: computer
                Kernel: Linux 6.6.31+rpt-rpi-v8
          Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       16:31:31 up  2:04,  2 users,  load average: 0.20, 0.32, 0.34
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-06-30 16:31:31 CEST
                 Universal time: Sun 2024-06-30 14:31:31 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      andre
      HOME=/home/andre
      GROUPS=andre adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.5G        1.7G        1.2M        839M        2.5G
      Swap:           209M          0B        209M
      Total:          4.2G        1.5G        1.9G
      Active iob-Instances: 	21
               3792 M total memory
               1419 M used memory
               1408 M active memory
                593 M inactive memory
               1648 M free memory
                 60 M buffer memory
                739 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 16:31:31 up  2:04,  2 users,  load average: 0.20, 0.32, 0.34
      Tasks: 188 total,   1 running, 187 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,   1648.5 free,   1420.1 used,    800.3 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2372.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G  5.4G   22G  20% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sun Jun 30 14:26:47 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5B:71:67 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=92008878-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Jun 30 14:26:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Sun Jun 30 14:26:56 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime,commit=600
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2015
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671308k,nr_inodes=417827,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      639M	/var/
      206M	/var/cache
      200M	/var/cache/apt
      165M	/var/lib
      133M	/var/lib/apt/lists
      Archived and active journals take up 68.0M in the file system.
      /opt/iobroker/backups:
      7.8M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      643M	/opt/iobroker/iobroker-data/
      582M	/opt/iobroker/iobroker-data/files
      299M	/opt/iobroker/iobroker-data/files/javascript.admin
      265M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      264M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      57M	/opt/iobroker/iobroker-data/objects.jsonl
      38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.7beaba8e.js.map
      24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.15.0
      /usr/bin/node 		v20.15.0
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      /usr/bin/corepack 	0.28.1
      nodejs:
        Installed: 20.15.0-1nodesource1
        Candidate: 20.15.0-1nodesource1
        Version table:
       *** 20.15.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      admin: 		7.0.7
      javascript: 	8.6.0
      nodejs modules from github: 	1
      +-- iobroker.life360@0.2.22 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1)
      Adapter State
      + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : pi                                       -  enabled
      + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
      + system.adapter.ble.0                    : ble                   : pi                                       -  enabled
      + system.adapter.cloud.0                  : cloud                 : pi                                       -  enabled
      + system.adapter.denon.0                  : denon                 : pi                                       -  enabled
        system.adapter.devices.0                : devices               : pi                                       - disabled
      + system.adapter.history.0                : history               : pi                                       -  enabled
      + system.adapter.iot.0                    : iot                   : pi                                       -  enabled
      + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
        system.adapter.life360.0                : life360               : pi                                       - disabled
      + system.adapter.lovelace.0               : lovelace              : pi                                       -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.maxcube.0                : maxcube               : pi                                       - disabled, port: 62910, bind: 0.0.0.0
      + system.adapter.miio.0                   : miio                  : pi                                       -  enabled
      + system.adapter.scenes.0                 : scenes                : pi                                       -  enabled
      + system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : pi                                       -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : pi                                       -  enabled
      + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : pi                                       -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : pi                                       -  enabled
      + system.adapter.zigbee.0                 : zigbee                : pi                                       -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.0.7    , installed 7.0.7
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.7    , installed 3.0.7
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "denon"        : 1.15.5   , installed 1.15.5
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.6.0    , installed 8.6.0
      Controller "js-controller": 6.0.5    , installed 6.0.5
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
      Adapter    "miio"         : 0.0.13   , installed 0.0.13
      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 3.6.0    , installed 3.6.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "web"          : 6.3.0    , installed 6.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects: 	3718
      States: 	2553
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18060      2995/io.sonoff.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17894      2810/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17899      2810/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5577       697/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19308      2828/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18172      3173/io.web.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       20757      3143/io.terminal.0
      tcp6       0      0 :::8091                 :::*                    LISTEN      1001       20715      3101/io.lovelace.0
      tcp6       0      0 :::46415                :::*                    LISTEN      1001       19818      3188/io.yahka.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5579       697/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5475       532/avahi-daemon: r
      udp        0      0 0.0.0.0:55378           0.0.0.0:*                           104        5477       532/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        5476       532/avahi-daemon: r
      udp6       0      0 :::46556                :::*                                104        5478       532/avahi-daemon: r
      udp6       0      0 fe80::adc6:381b:b10:546 :::*                                0          9560       625/NetworkManager
      2024-06-30 16:20:58.577  - info: zigbee.0 (4859) cleaned everything up...
      2024-06-30 16:20:58.625  - info: zigbee.0 (4859) Zigbee: disabling joining new devices.
      2024-06-30 16:20:59.069  - warn: zigbee.0 (4859) Failed to stop zigbee during startup
      2024-06-30 16:20:59.069  - info: zigbee.0 (4859) terminating
      2024-06-30 16:20:59.070  - info: zigbee.0 (4859) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-06-30 16:20:59.081  - info: zigbee.0 (4859) terminating
      2024-06-30 16:20:59.127  - info: zigbee.0 (4859) debug devices set to []
      2024-06-30 16:20:59.677  - info: host.pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-06-30 16:20:59.992  - info: admin.0 (2828) ==> Connected system.user.admin from ::ffff:192.168.0.23
      2024-06-30 16:22:00.645  - info: admin.0 (2828) <== Disconnect system.user.admin from ::ffff:192.168.0.23
      			v.2024-05-22
       Static hostname: pi
             Icon name: computer
          Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		64 bit
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      Recommended versions are nodejs 18.20.3 and npm 10.7.0
      MEMORY:
      Mem:            4.0G        1.7G        1.5G        1.2M        850M        2.3G
      Swap:           209M          0B        209M
      Total:          4.2G        1.7G        1.7G
      ioBroker Core: 		js-controller 		6.0.5
      			admin 			7.0.7
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		3718
      States: 		2553
      Size of iob-Database:
      66M	/opt/iobroker/iobroker-data/objects.jsonl
      3.9M	/opt/iobroker/iobroker-data/states.jsonl
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @edonisxp
      Solange du als erstes die folgenden Meldungen bekommst wird der Stick korrekt erkannt, und das ganze Gehampel mit dem Modem-Manager ist ein Nebenkriegsschauplatz.
      diese Meldungen:
      Sind Folgefehler, da die Bibliothek den Port nicht wieder freigibt, und der Adapter beim Versuch erneut zu starten den Port nicht auf bekommt - er ist noch offen.
      Die entscheidenden Fragen sind jetzt:
      • welche Firmware ist auf dem Stick ? Erinnerst du was du darauf geflasht hast, oder hast du ggf. ältere Log-Dateien zum nachschauen
      • wie sieht es um den Stick aus, insbesondere mit 2.4GHz Störquellen (USB3 Devices, DECT, WLAN, BT, aber auch Herstellerspezifische 2.4GHz dongle für Tastaturen/Mäuse/Kopfhörer, etc.
      Was zumeist hilft solange die Firmware noch ok ist:
      • Adapter anhalten
      • Stick abziehen
      • 30 Sekunden warten
      • Stick wieder anstecken
      • Adapter starten.
      Zusätzlich kann es Sinnvoll sein den Stick an einen etwas anderen Ort zu bringen - das geht natürlich nur wenn er via USB Verlängerung angeschlossen ist. Das sollte er aber sowieso sein, da die meisten NUC / PI im 2.4GHz Bereich stören (oft durch USB3/WLan/BT)
      A.
      Nachtrag: Die Firmware auf den verschiedenen Sticks kann nur eine gewisse Menge an Kommunikationsproblemen abfangen bevor sie abstürzt. Daher ist davon auszugehen das mit dem Umfeld etwas nicht optimal ist wenn die Firmware regelmässig / häufig abstürzt. Ich hatte das Problem selber und habe es durch neu-platzieren des sticks lösen können.
      Wichtig ist: Ein Neustart des PI / NUC führt üblicherweise keinen Hardware-Reset am USB Bus durch - nur ein Software-Reset findet statt, weswegen die Firmware erst dann neu initialisiert wird wenn der Stick stromlos wird (abschalten des PI/NUC oder abziehen des Stick)
        @edonisxp
        sagt?
        edonisXP
        Der Modem Manager ist weg:
        Unit ModemManager.service could not be found.
        Kiste neu gestartet und keine Änderung
        [Sun Jun 30 18:51:21 2024] usb 1-1.3: USB disconnect, device number 3
        [Sun Jun 30 18:51:21 2024] usb 1-1.4: USB disconnect, device number 4
        [Sun Jun 30 18:52:04 2024] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
        [Sun Jun 30 18:52:04 2024] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
        [Sun Jun 30 18:52:04 2024] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [Sun Jun 30 18:52:04 2024] usb 1-1.4: Product: CC2538 USB CDC
        [Sun Jun 30 18:52:04 2024] usb 1-1.4: Manufacturer: Texas Instruments
        [Sun Jun 30 18:52:05 2024] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
        • E edonisXP
          @edonisxp
          Dann halt jetzt auf die Umgebung schauen. Hat @Asgothian ja schon viel zu geschrieben.
          • AsgothianA Asgothian
            @edonisxp
            diese Meldungen:
            • Adapter anhalten
            • Stick abziehen
            • Adapter starten.
            A.
            edonisXP
            @asgothian
            Bei der Firmware müsste ich nochmal schauen.
            Ich hab je örtlich nichts geändert, keine neuen Geräte oder ähnliches. Ohne erkennbaren Grund lief es einfach nicht mehr. Stick raus und wieder ein hab ich auch zig mal versucht.
            • E edonisXP
              @asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @edonisxp sagte in zigbee Adapter startet nicht "unavailable Cannot lock port":
              Du hast vielleicht nicht aktiv etwas geändert. Das heisst aber nicht das alles so geblieben ist. WLAN und BT wählen ihre Frequenzen üblicherweise automatisch. Auch ein WLAN eines Nachbarn kann ggf. stören. Selbst das Umstellen einer Metalldose in der Nähe des Koordinators kann auf Grund der durch die Dose entstehenden Reflektionen der Funkwellen einen Effekt haben.
              Stick an USB Kabel, und Stick anders platzieren (andere Ausrichtung ?) kann also helfen.
              Die Meldung
              deutet darauf hin das es der Firmware nicht gelingt innerhalb von 40 Sekunden das Zigbee-Netz stabil aufzubauen. Das ist also ein Funk-Problem oder ein Firmware-Problem.
              A.
                Die Meldung
                A.
                edonisXP
                @asgothian
                Also ich hab die Vermutung das es tatsächlich die Firmware sein könnte.
                2021 hab ich den Stick geholt und da war 20190523 drauf, ich kann mich nicht erinnern hier mal ein update gemacht zu haben, da alles bisher lief hab ich das nie beachtet.
                • E edonisXP
                  @asgothian
                  martinschm
                  Ich hatte auch häufiger das Problem, das nach einem Neustart auf den Zigbee Stick nicht zu gegriffen werden konnte.
                  Hab jetzt auch mal den Modem Manager raus geworfen und die letzten zwei Neustarts gingen ohne Probleme und mein Zigbee Netzwerk war gleich wieder da.
                  Ich hoffe es bleibt dabei.
                  Viele Grüße
                  Martin
