  4. Test Dreame Home Adapter
    1.7k
259 Beiträge 44 Kommentatoren 62.2k Aufrufe 48 Beobachtet
  • Housemeister 0H Offline
    Housemeister 0
    #221
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: smarthome
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:09:10 up 13 days, 21:08,  2 users,  load average: 1.58, 0.76, 0.43
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-10-08 20:09:11 CEST
               Universal time: Wed 2025-10-08 18:09:11 UTC
                     RTC time: Wed 2025-10-08 18:09:11
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    kai
    HOME=/home/kai
    GROUPS=kai adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             17G        5.2G        9.5G        160M        2.6G         11G
    Swap:           536M          0B        536M
    Total:           17G        5.2G         10G
    Active iob-Instances:   36
            16219 M total memory
             4958 M used memory
             4875 M active memory
             1687 M inactive memory
             9094 M free memory
              156 M buffer memory
             2282 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 20:09:11 up 13 days, 21:08,  2 users,  load average: 1.58, 0.76, 0.43
    Tasks: 240 total,   1 running, 239 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 50.0 id, 50.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16219.1 total,   9094.5 free,   4958.9 used,   2439.0 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.  11260.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     1.6G  153M  1.5G  10% /run
    /dev/mmcblk0p2 ext4      115G  8.6G  100G   8% /
    tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   57M  454M  12% /boot/firmware
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Wed Sep 24 23:00:56 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:27:16:68 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e11f02e0-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Wed Sep 24 23:00:59 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
    [Wed Sep 24 23:01:00 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.7G    /var/
    751M    /var/cache
    737M    /var/cache/apt
    621M    /var/cache/apt/archives
    425M    /var/lib
    Archived and active journals take up 147.6M in the file system.
    /opt/iobroker/backups:
    165M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    512M    /opt/iobroker/iobroker-data/
    360M    /opt/iobroker/iobroker-data/files
    116M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/vis-2/widgets
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    17M     /opt/iobroker/iobroker-data/files/vis-2.0/Smartpad V1.0/Background/schwarzer-hintergrund-mit-stoffstruktur.jpg
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803151340-if00
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.20.0
    /usr/bin/node           v22.20.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.20.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
     *** 22.20.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    smarthome           smarthome (version: 7.0.7, hostname: smarthome     , alive, uptime: 1199296)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     9.0.11
    nodejs modules from github:     3
    +-- iobroker.dreame@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#a0e1b46849b68d02cafe1bdf3504193195e927f8)
    +-- iobroker.dreamehome@1.0.0 (git+ssh://git@github.com/spayrosam/ioBroker.dreamehome.git#7893b33ffe944c9e017b2f64a3667fd98da6ddf1)
    +-- iobroker.ws@3.0.19 (git+ssh://git@github.com/ioBroker/ioBroker.ws.git#835702659099b5d0991289a5377d8f2bff4b89ac)
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
      system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
    + system.adapter.discovery.0              : discovery             : smarthome                                -  enabled
      system.adapter.dreame.0                 : dreame                : smarthome                                - disabled
      system.adapter.dreamehome.0             : dreamehome            : smarthome                                - disabled
      system.adapter.dwd.0                    : dwd                   : smarthome                                -  enabled
    + system.adapter.e3dc-rscp.0              : e3dc-rscp             : smarthome                                -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: smarthome                                -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : smarthome                                -  enabled
      system.adapter.flot.0                   : flot                  : smarthome                                - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : smarthome                                -  enabled
    + system.adapter.geofency.0               : geofency              : smarthome                                -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.history.0                : history               : smarthome                                -  enabled
    + system.adapter.hmip.0                   : hmip                  : smarthome                                -  enabled
    + system.adapter.hue.0                    : hue                   : smarthome                                -  enabled, port: 443
      system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
      system.adapter.ical.2                   : ical                  : smarthome                                -  enabled
      system.adapter.ical.3                   : ical                  : smarthome                                -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : smarthome                                - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : smarthome                                - disabled
    + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
    + system.adapter.matter.0                 : matter                : smarthome                                -  enabled
    + system.adapter.meross.0                 : meross                : smarthome                                -  enabled
    + system.adapter.ring.0                   : ring                  : smarthome                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : smarthome                                -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : smarthome                                -  enabled
    + system.adapter.scenes.0                 : scenes                : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tesla-motors.0           : tesla-motors          : smarthome                                -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : smarthome                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
    + system.adapter.tuya.0                   : tuya                  : smarthome                                -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: smarthome                                - disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: smarthome                                - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: smarthome                                - disabled
      system.adapter.vis-2-widgets-rssfeed.0  : vis-2-widgets-rssfeed : smarthome                                - disabled
    + system.adapter.vis-2.0                  : vis-2                 : smarthome                                -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthome                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803151340-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "bring"        : 1.8.4    , installed 1.9.1
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "e3dc-rscp"    : 1.4.3    , installed 1.4.2  [Updatable]
    Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.8
    Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 3.3.0    , installed 3.6.0
    Adapter    "javascript"   : 8.9.2    , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.2    , installed 0.5.2
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "ring"         : 6.4.0    , installed 6.4.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "rssfeed"      : 3.6.1    , installed 3.5.2  [Updatable]
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.2.0   , installed 10.2.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
    Adapter    "tibberlink"   : 5.0.2    , installed 5.0.2
    Adapter    "trashschedule": 3.3.0    , installed 4.0.1
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.3.5
    Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.4.7
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-rssfeed": 1.2.2, installed 1.2.2
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.9
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        15266
    States:         12774
    W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is not signed.
    Pending Updates: 27
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      107        5742       684/influxd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3020       685/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3025       685/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          666        701/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1157267    97123/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       6895       1265/io.shelly.0
    tcp6       0      0 :::7070                 :::*                    LISTEN      106        6329       805/evcc
    tcp6       0      0 :::7999                 :::*                    LISTEN      1001       8280       1115/io.geofency.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      107        5749       684/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       10282      1580/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7884       1565/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       823        816/io.admin.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      105        1170476    98315/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          668        701/sshd: /usr/sbin
    udp        0      0 0.0.0.0:52970           0.0.0.0:*                           104        1992       571/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       7752803    318516/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       3391016    318516/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       3391001    318516/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       3390993    318516/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        780        805/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1990       571/avahi-daemon: r
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       3391010    318516/io.matter.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       6920       1295/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       6921       1295/io.tuya.0
    udp        0      0 0.0.0.0:39468           0.0.0.0:*                           1001       3392574    318516/io.matter.0
    udp6       0      0 fe80::9b90:5c0c:88d:546 :::*                                0          903071     656/NetworkManager
    udp6       0      0 fe80::1bb1:e9f4:8cf:546 :::*                                0          770        656/NetworkManager
    udp6       0      0 :::5353                 :::*                                1001       7752804    318516/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       3391017    318516/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       3391004    318516/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       3390996    318516/io.matter.0
    udp6       0      0 :::5353                 :::*                                106        781        805/evcc
    udp6       0      0 :::5353                 :::*                                104        1991       571/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1001       3391009    318516/io.matter.0
    udp6       0      0 :::39120                :::*                                104        1993       571/avahi-daemon: r
    udp6       0      0 :::39468                :::*                                1001       3392573    318516/io.matter.0
    2025-10-08 20:00:06.531  - info: ical.2 (688853) processing URL: Kai https://calendar.google.com/calendar/ical/reeflover82%40gmail.com/private-47d92a1cdbeae54baf7a78aa1cdf3bf3/basic.ics
    2025-10-08 20:00:06.774  - info: ical.3 (688815) Terminated (NO_ERROR): Without reason
    2025-10-08 20:00:07.294  - info: host.smarthome instance system.adapter.ical.3 having pid 688815 terminated with code 0 (NO_ERROR)
    2025-10-08 20:00:10.012  - info: host.smarthome instance system.adapter.daswetter.0 in version "3.2.3" started with pid 688870
    2025-10-08 20:00:11.698  - info: daswetter.0 (688870) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.20.0, js-controller: 7.0.7
    2025-10-08 20:00:11.783  - info: ical.2 (688853) Terminated (NO_ERROR): Without reason
    2025-10-08 20:00:12.330  - info: host.smarthome instance system.adapter.ical.2 having pid 688853 terminated with code 0 (NO_ERROR)
    2025-10-08 20:00:20.426  - info: daswetter.0 (688870) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-10-08 20:00:20.931  - info: daswetter.0 (688870) cleaned everything up...
    2025-10-08 20:00:20.941  - info: host.smarthome instance system.adapter.daswetter.0 having pid 688870 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-08 20:00:23.010  - info: host.smarthome instance system.adapter.dwd.0 in version "2.8.5" started with pid 688885
    2025-10-08 20:00:23.947  - info: dwd.0 (688885) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.20.0, js-controller: 7.0.7
    2025-10-08 20:00:24.318  - info: dwd.0 (688885) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-10-08 20:00:24.831  - info: host.smarthome instance system.adapter.dwd.0 having pid 688885 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-08 20:03:06.185  - info: web.0 (1565) <== Disconnect system.user.admin from ::ffff:192.168.178.180 vis-2
    2025-10-08 20:03:07.549  - info: web.0 (1565) ==> Connected system.user.admin from ::ffff:192.168.178.180
    2025-10-08 20:03:09.713  - info: vis-2.0 (1535) vis-2 license is OK.
    2025-10-08 20:04:54.175  - warn: e3dc-rscp.0 (1387) Received data type ERROR: RSCP_ERR_NOT_AVAILABLE (6) - tag TAG_EMS_EMERGENCY_POWER_TEST_STATUS (0x1800093)
    2025-10-08 20:05:23.014  - info: host.smarthome instance system.adapter.dwd.0 in version "2.8.5" started with pid 689034
    2025-10-08 20:05:23.964  - info: dwd.0 (689034) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.20.0, js-controller: 7.0.7
    2025-10-08 20:05:24.312  - info: dwd.0 (689034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-10-08 20:05:24.831  - info: host.smarthome instance system.adapter.dwd.0 having pid 689034 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-08 20:08:19.638  - info: web.0 (1565) <== Disconnect system.user.admin from ::ffff:192.168.178.180 vis-2
    2025-10-08 20:08:21.029  - info: web.0 (1565) ==> Connected system.user.admin from ::ffff:192.168.178.180
    2025-10-08 20:08:23.126  - info: vis-2.0 (1535) vis-2 license is OK.
    • Housemeister 0H Housemeister 0
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      kai
      HOME=/home/kai
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           536M          0B        536M
      Total:           17G        5.2G         10G
               4958 M used memory
               9094 M free memory
                156 M buffer memory
               2282 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      751M    /var/cache
      737M    /var/cache/apt
      425M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15266
      States:         12774
      Pending Updates: 27
      #222
      @housemeister-0
      Soweit passt das eigentlich.
      Leg das Influxdb-Repo nochmal neu an:
      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
      Und dann die updates einspielen. Sowohl für das Betriebssystem wie auch für den ioBroker.
      Perspektivisch auch da in diesem Winter RaspberryOS 13 installieren.
      Housemeister 0H 1 Antwort Letzte Antwort
        @housemeister-0
        Housemeister 0
        schrieb am zuletzt editiert von Housemeister 0
        #223
        @thomas-braun danke für die Tipps, habe Influxdb nochmal neu installiert und danach alle updates gezogen, leider keine Verbessserung
          #224
          @housemeister-0
          Du musst wohl libcairo aktualisieren.
          Da würde ich aber wie gesagt dann gleich die große Lösung (Update auf RaspberryOS 13) wählen.
            @housemeister-0
            Housemeister 0
            #225
            @thomas-braun said in Test Dreame Home Adapter:
            Mist hätt ich gewusst das Trixie im Oktober kommt, hätte ich noch ein paar Tage mit dem Wechsel auf den Pi5 gewartet. Hab das System erst im September neu aufgesetzt.
              #226
              @housemeister-0
              Dann dürfte ein inline-Upgrade ja kein großes Ding sein.
              https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
                Housemeister 0
                #227
                Update erfolgt, das hat geklappt zu haben. Fehler mit dem Adapter ist aber aktuell noch da
                Log:
                Script v.2025-08-09
                *** BASE SYSTEM ***
                Operating System: Debian GNU/Linux 13 (trixie)
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 22:01:12 up 7 min,  1 user,  load average: 1.72, 1.34, 0.69
                CPU threads: 4
                Operating System is the current Debian stable version codenamed 'trixie'!
                Current issues:
                               Local time: Wed 2025-10-08 22:01:12 CEST
                           Universal time: Wed 2025-10-08 20:01:12 UTC
                                 RTC time: Wed 2025-10-08 20:01:12
                              NTP service: active
                          RTC in local TZ: no
                kai
                HOME=/home/kai
                iobroker
                HOME=/home/iobroker
                SUDO_HOME=/home/kai
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:             17G        3.8G         11G         26M        2.0G         13G
                Swap:           536M          0B        536M
                Total:           17G        3.8G         11G
                        16218 M total memory
                         3663 M used memory
                         3660 M active memory
                         1254 M inactive memory
                        10779 M free memory
                          198 M buffer memory
                         1721 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                top - 22:01:12 up 7 min,  1 user,  load average: 1.72, 1.34, 0.69
                Tasks: 244 total,   1 running, 243 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  16219.0 total,  10776.0 free,   3666.6 used,   1920.7 buff/cache
                MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12552.4 avail Mem
                *** FILESYSTEM ***
                tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                /dev/mmcblk0p2 ext4      115G  9.1G  100G   9% /
                tmpfs          tmpfs     8.0G  9.9M  8.0G   1% /tmp
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                tmpfs          tmpfs     1.6G   48K  1.6G   1% /run/user/1000
                [Wed Oct  8 21:53:20 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:27:16:68 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e11f02e0-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                [Wed Oct  8 21:53:23 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                [Wed Oct  8 21:53:25 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                /var:
                1.6G    /var/
                704M    /var/cache
                696M    /var/cache/apt
                564M    /var/cache/apt/archives
                400M    /var/lib
                Archived and active journals take up 9.5M in the file system.
                198M    /opt/iobroker/backups/
                515M    /opt/iobroker/iobroker-data/
                23M     /opt/iobroker/iobroker-data/objects.jsonl
                12M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.3
                /usr/bin/npx            10.9.3
                nodejs:
                  Version table:
                     20.19.2+dfsg-1 500
                        500 http://deb.debian.org/debian trixie/main arm64 Packages
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                smarthome           smarthome (version: 7.0.7, hostname: smarthome     , alive, uptime: 457)
                admin:          7.7.2
                javascript:     9.0.11
                Adapter State
                + instance is alive
                Adapter    "e3dc-rscp"    : 1.4.3    , installed 1.4.3
                Adapter    "rssfeed"      : 3.6.1    , installed 3.6.1
                Objects and States
                Objects:        15272
                States:         12805
                W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                Hit:1 http://deb.debian.org/debian trixie InRelease
                Hit:2 http://phoscon.de/apt/deconz generic InRelease
                Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                Hit:5 http://deb.debian.org/debian trixie-updates InRelease
                Hit:6 https://apt.grafana.com stable InRelease
                Hit:7 https://repos.influxdata.com/debian stable InRelease
                Hit:8 https://deb.nodesource.com/node_22.x nodistro InRelease
                Get:9 https://dl.evcc.io/public/evcc/stable/deb/debian trixie InRelease
                Fetched 11.7 kB in 0s (83.4 kB/s)
                Reading package lists...
                Pending Updates: 0
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      107        6827       1086/influxd
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8784       1132/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9541       1132/iobroker.js-co
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13978      2205/io.shelly.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14867      2220/io.sonoff.0
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6749       1041/exim4
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5862       782/sshd: /usr/sbin
                tcp6       0      0 :::7999                 :::*                    LISTEN      1001       14388      1903/io.geofency.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10391      1240/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18436      2531/io.web.0
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       19472      2546/io.ws.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      107        8667       1086/influxd
                tcp6       0      0 :::7070                 :::*                    LISTEN      106        6930       791/evcc
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6750       1041/exim4
                tcp6       0      0 :::3000                 :::*                    LISTEN      105        10342      1131/grafana
                tcp6       0      0 :::1984                 :::*                    LISTEN      1000       6417       593/go2rtc_linux_ar
                tcp6       0      0 :::8554                 :::*                    LISTEN      1000       6420       593/go2rtc_linux_ar
                tcp6       0      0 :::8555                 :::*                    LISTEN      1000       6421       593/go2rtc_linux_ar
                tcp6       0      0 :::22                   :::*                    LISTEN      0          5864       782/sshd: /usr/sbin
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           106        8716       791/evcc
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           106        8712       791/evcc
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           106        8708       791/evcc
                udp        0      0 0.0.0.0:60112           0.0.0.0:*                           1001       15124      2406/io.matter.0
                udp        0      0 0.0.0.0:45856           0.0.0.0:*                           104        7341       586/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17552      2406/io.matter.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17318      2406/io.matter.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17303      2406/io.matter.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17295      2406/io.matter.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        9457       791/evcc
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7339       586/avahi-daemon: r
                udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       17312      2406/io.matter.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       13163      2250/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       13164      2250/io.tuya.0
                udp6       0      0 fe80::1bb1:e9f4:8cf:546 :::*                                0          5876       682/NetworkManager
                udp6       0      0 :::60112                :::*                                1001       15123      2406/io.matter.0
                udp6       0      0 :::5353                 :::*                                1001       17553      2406/io.matter.0
                udp6       0      0 :::5353                 :::*                                1001       17319      2406/io.matter.0
                udp6       0      0 :::5353                 :::*                                1001       17306      2406/io.matter.0
                udp6       0      0 :::5353                 :::*                                1001       17298      2406/io.matter.0
                udp6       0      0 :::5353                 :::*                                106        9458       791/evcc
                udp6       0      0 :::5353                 :::*                                104        7340       586/avahi-daemon: r
                udp6       0      0 :::5540                 :::*                                1001       17311      2406/io.matter.0
                udp6       0      0 :::46934                :::*                                104        7342       586/avahi-daemon: r
                2025-10-08 22:00:28.009  - info: dwd.0 (4213) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.20.0, js-controller: 7.0.7
                2025-10-08 22:00:28.375  - info: dwd.0 (4213) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-10-08 22:00:28.885  - info: host.smarthome instance system.adapter.dwd.0 having pid 4213 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-10-08 22:00:32.769  - info: meross.0 (2132) Can not get Data for Device 2202248724641190870548e1e98a7ebe: Error: Timeout
                2025-10-08 22:00:32.769  - warn: meross.0 (2132) Can not get Data for Device 2202248724641190870548e1e98a7ebe: undefined
                2025-10-08 22:00:40.499  - warn: e3dc-rscp.0 (2346) Received data type ERROR: RSCP_ERR_NOT_AVAILABLE (6) - tag TAG_EMS_EMERGENCY_POWER_TEST_STATUS (0x1800093)
                2025-10-08 22:00:53.008  - error: host.smarthome Caught by controller[0]: node:internal/modules/cjs/loader:1865
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:                  ^
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Object..node (node:internal/modules/cjs/loader:1865:18)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1441:32)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1263:12)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14)
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1839:10) {
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]: }
                2025-10-08 22:00:53.009  - error: host.smarthome Caught by controller[0]: Node.js v22.20.0
                2025-10-08 22:00:53.009  - error: host.smarthome instance system.adapter.dreamehome.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2025-10-08 22:00:53.009  - info: host.smarthome Do not restart adapter system.adapter.dreamehome.0 because disabled or deleted
                  Log:
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                NTP service: active
                            RTC in local TZ: no
                  kai
                  HOME=/home/kai
                  iobroker
                  HOME=/home/iobroker
                  SUDO_HOME=/home/kai
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:           536M          0B        536M
                  Total:           17G        3.8G         11G
                           3663 M used memory
                          10779 M free memory
                            198 M buffer memory
                           1721 M swap cache
                            511 M total swap
                              0 M used swap
                            511 M free swap
                  *** FILESYSTEM ***
                  /var:
                  1.6G    /var/
                  704M    /var/cache
                  696M    /var/cache/apt
                  400M    /var/lib
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.3
                  /usr/bin/npx            10.9.3
                  nodejs:
                    Version table:
                       20.19.2+dfsg-1 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.2
                  javascript:     9.0.11
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        15272
                  States:         12805
                  Pending Updates: 0
                  #228
                  @housemeister-0 sagte in Test Dreame Home Adapter:
                  Installier den Adapter mal komplett neu, damit der gegen die aktuelle libcairo2 gelinkt werden kann.
                  Edit: Ich hab den gerade mal installiert. Läuft auf meinem System.
                  2025-10-08 22:37:06.525  - info: dreamehome.0 (154814) starting. Version 1.0.0 (non-npm: spayrosam/ioBroker.dreamehome#7893b33ffe944c9e017b2f64a3667fd98da6ddf1) in /opt/iobroker/node_modules/iobroker.dreamehome, node: v24.9.0, js-controller: 7.0.7
                  2025-10-08 22:37:06.554  - error: dreamehome.0 (154814) Please set username and password in the instance settings
                  2025-10-08 22:37:25.376  - info: dreamehome.0 (154814) Got terminate signal TERMINATE_YOURSELF
                  2025-10-08 22:37:25.381  - info: dreamehome.0 (154814) Cleaning up resources...
                  2025-10-08 22:37:25.383  - info: dreamehome.0 (154814) terminating
                  2025-10-08 22:37:25.385  - info: dreamehome.0 (154814) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-10-08 22:37:25.888  - info: dreamehome.0 (154814) terminating
                  2025-10-08 22:37:32.983  - info: dreamehome.0 (154830) starting. Version 1.0.0 (non-npm: spayrosam/ioBroker.dreamehome#7893b33ffe944c9e017b2f64a3667fd98da6ddf1) in /opt/iobroker/node_modules/iobroker.dreamehome, node: v24.9.0, js-controller: 7.0.7
                  2025-10-08 22:37:33.012  - error: dreamehome.0 (154830) Please set username and password in the instance settings
                  Version:
                    Version:
                    Housemeister 0
                    #229
                    Selbst danach hat er noch den Fehler mit der Libcairo
                    2025-10-08 22:44:42.999	error	Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                      tombox
                      schrieb am zuletzt editiert von tombox
                      #230
                      cd /opt/iobroker
                      npm uninstall canvas
                      Vielleicht hilft das
                      Aber warum nutzt du nicht
                      https://github.com/TA2k/ioBroker.dreame
                      • T tombox
                        cd /opt/iobroker
                        Housemeister 0
                        #231
                        @tombox
                        du meinst den Canvas neu installieren, werde ich versuchen. Warum ich nicht den Dreame Adapter nehme. Da @wawyo den Adapter doch auf Dreame Home umbenannt hat und dieser weiter gepflegt wird.
                          @tombox
                          #232
                          @housemeister-0
                          Hast du noch andere Adapter, die auf canvas zurückgreifen?
                          cd /opt/iobroker && npm ls canvas
                            @housemeister-0
                            Housemeister 0
                            #233
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├── canvas@3.2.0
                            └─┬ iobroker.dreamehome@1.0.0 (git+ssh://git@github.com/spayrosam/ioBroker.dreamehome.git#7893b33ffe944c9e017b2f64a3667fd98da6ddf1)
                              └── canvas@3.2.0 deduped
                            Damit kann ich leider nix anfangen, heißt das, dass auch andere Adapter auf Canvas zugreifen?
                              ├── canvas@3.2.0
                              #234
                              @housemeister-0
                              Das hätte man dann da sehen können. Auf meiner Kiste sieht das z. B. so aus:
                              echad@chet:/opt/iobroker $ npm ls canvas
                              ├─┬ iobroker.echarts@2.0.10
                              │ ├── canvas@3.1.2
                              │ └─┬ jsdom@26.1.0
                              │   └── canvas@3.1.2 deduped
                              ├─┬ iobroker.mihome-vacuum@5.3.0
                              └─┬ iobroker.parcel@0.2.10
                                └─┬ jsdom@25.0.1
                                  └── canvas@3.1.2
                              Bei dir ist aber canvas in der ersten Ebene installiert. Das sollten sich aber eigentlich nur iobroker.XYZ Einträge finden.
                              Schmeiß das mal an der Stelle raus:
                              cd /opt/iobroker
                              Liegt da noch mehr rum?
                              cd /opt/iobroker
                              npm ls
                              anschauen.
                              Und dann iobroker.dreamehome nochmal installieren.
                                @housemeister-0
                                │ ├── canvas@3.1.2
                                │ └─┬ jsdom@26.1.0
                                  └─┬ jsdom@25.0.1
                                    └── canvas@3.1.2
                                cd /opt/iobroker
                                cd /opt/iobroker
                                npm ls
                                anschauen.
                                Housemeister 0
                                #235
                                ├── @iobroker-javascript.0/axios@npm:axios@1.12.2
                                ├── @iobroker-javascript.0/fs@npm:fs@0.0.1-security
                                ├── @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
                                ├── @iobroker-javascript.0/is-it-bst@npm:is-it-bst@1.0.2
                                ├── @iobroker-javascript.0/tail@npm:tail@2.2.6
                                ├── iobroker.admin@7.7.2
                                ├── iobroker.alexa2@3.27.3
                                ├── iobroker.backitup@3.3.5
                                ├── iobroker.bring@1.9.1
                                ├── iobroker.cloud@5.0.1
                                ├── iobroker.daswetter@3.2.3
                                ├── iobroker.discovery@5.0.0
                                ├── iobroker.dreamehome@1.0.0 (git+ssh://git@github.com/spayrosam/ioBroker.dreamehome.git#7893b33ffe944c9e017b2f64a3667fd98da6ddf1)
                                ├── iobroker.dwd@2.8.5
                                ├── iobroker.e3dc-rscp@1.4.3
                                ├── iobroker.energiefluss-erweitert@0.7.8
                                ├── iobroker.fb-checkpresence@1.4.0
                                ├── iobroker.flot@1.12.0
                                ├── iobroker.fullybrowser@3.1.2
                                ├── iobroker.geofency@1.2.4
                                ├── iobroker.history@3.0.1
                                ├── iobroker.hmip@1.27.0
                                ├── iobroker.hue@3.16.2
                                ├── iobroker.ical@1.17.0
                                ├── iobroker.icons-mfd-svg@1.2.0
                                ├── iobroker.icons-ultimate-png@1.0.1
                                ├── iobroker.influxdb@4.0.2
                                ├── iobroker.iot@3.6.0
                                ├── iobroker.javascript@9.0.11
                                ├── iobroker.js-controller@7.0.7
                                ├── iobroker.matter@0.5.2
                                ├── iobroker.meross@1.17.0
                                ├── iobroker.ring@6.4.0
                                ├── iobroker.rpi2@2.4.0
                                ├── iobroker.rssfeed@3.6.1
                                ├── iobroker.scenes@4.0.3
                                ├── iobroker.shelly@10.2.0
                                ├── iobroker.sonoff@3.2.1
                                ├── iobroker.telegram@4.1.0
                                ├── iobroker.tesla-motors@1.4.5
                                ├── iobroker.tibberlink@5.0.2
                                ├── iobroker.trashschedule@4.0.1
                                ├── iobroker.tuya@3.17.0
                                ├── iobroker.vis-2-widgets-inventwo@0.3.5
                                ├── iobroker.vis-2-widgets-jaeger-design@1.4.7
                                ├── iobroker.vis-2-widgets-material@1.4.10
                                ├── iobroker.vis-2-widgets-rssfeed@1.2.2
                                ├── iobroker.vis-2@2.13.4
                                ├── iobroker.vis-hqwidgets@1.5.1
                                ├── iobroker.vis-icontwo@1.18.0
                                ├── iobroker.vis-inventwo@3.3.5
                                ├── iobroker.web@7.0.9
                                ├── iobroker.ws@3.0.19 (git+ssh://git@github.com/ioBroker/ioBroker.ws.git#835702659099b5d0991289a5377d8f2bff4b89ac)
                                └── iobroker.zigbee@3.0.5
                                Bis auf die Javascript Sachen finde ich jetzt da nix ungewöhnliches
                                  #236
                                  iobroker.ws
                                  Warum ist der aus dem GitHub gefischt worden?
                                  Setz den wieder auf das richtige Gleis:
                                  iob upgrade iobroker.ws@3.0.19
                                  Die 5 @iobroker-javascript.0 Dinger sind im Javascript-Adapter als manuelle Module angelegt oder wo kommen die her?
                                    iobroker.ws
                                    Housemeister 0
                                    #237
                                    ja die stammen aus dem Javascript Adapter als manuelle NPM Module. Kann aber aktuell nicht mehr sagen, wo die alle herkommen.
                                    • J Offline
                                      JohnnyBahama
                                      #238
                                      Habe mir jetzt auch erstmalig den X40 Ultra zugelegt und freue mich, dass ich den über den Adapter starten kann.
                                      Bei mir kommen allerdings Meldungen zu fehlenden Objekten:
                                      dreame.0
                                      2025-10-13 09:43:13.682	warn	State "dreame.0.836**4060.map.carpetcleanset" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:13.009	warn	State "dreame.0.836**4060.map.cleanset.4.Route" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:13.008	warn	State "dreame.0.836**4060.map.cleanset.4.Repeat" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:13.008	warn	State "dreame.0.836**4060.map.cleanset.4.WaterVolume" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:13.003	warn	State "dreame.0.836**4060.map.cleanset.4.CleaningMode" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:13.002	warn	State "dreame.0.836**4060.map.cleanset.4.Level" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:13.001	warn	State "dreame.0.836**4060.map.cleanset.4.RoomOrder" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.996	warn	State "dreame.0.836**4060.map.cleanset.4.RoomSettings" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.297	warn	State "dreame.0.836**4060.map.cleanset.3.Route" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.297	warn	State "dreame.0.836**4060.map.cleanset.3.Repeat" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.296	warn	State "dreame.0.836**4060.map.cleanset.3.WaterVolume" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.293	warn	State "dreame.0.836**4060.map.cleanset.3.CleaningMode" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.292	warn	State "dreame.0.836**4060.map.cleanset.3.Level" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.291	warn	State "dreame.0.836**4060.map.cleanset.3.RoomOrder" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:12.287	warn	State "dreame.0.836**4060.map.cleanset.3.RoomSettings" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.652	warn	State "dreame.0.836**4060.map.cleanset.2.Route" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.651	warn	State "dreame.0.836**4060.map.cleanset.2.Repeat" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.649	warn	State "dreame.0.836**4060.map.cleanset.2.WaterVolume" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.645	warn	State "dreame.0.836**4060.map.cleanset.2.CleaningMode" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.645	warn	State "dreame.0.836**4060.map.cleanset.2.Level" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.643	warn	State "dreame.0.836**4060.map.cleanset.2.RoomOrder" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:11.636	warn	State "dreame.0.836**4060.map.cleanset.2.RoomSettings" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:10.955	warn	State "dreame.0.836**4060.map.cleanset.1.Route" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:10.954	warn	State "dreame.0.836**4060.map.cleanset.1.Repeat" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:10.953	warn	State "dreame.0.836**4060.map.cleanset.1.WaterVolume" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:10.950	warn	State "dreame.0.836**4060.map.cleanset.1.CleaningMode" has no existing object, this might lead to an error in future versions
                                      dreame.0
                                      2025-10-13 09:43:10.950	warn	State "dreame.0.836**4060.map.cleanset.1.Level" has no existing object, this might lead to an error in future versions
                                        MrHenker27
                                        #239
                                        moin.
                                        ich glaub es wurde schon mehrfach gefragt, aber ich habe die Antwort nicht gefunden.
                                        in welchem DP steht jetzt wo der Robby Aktuell ist? Also Raun ID würde mir reichen.
                                        • wawyoW wawyo
                                          @michael-ladstätter Ich habe den Fehler gefunden. Bitte nutzt den neuen Code und passt die Datenpunkte 'restart', 'start-clean' und 'update' auf 'true' an, nachdem der erste Start erfolgt ist.
                                          Download main.js
                                          knete20
                                          #240
                                          @wawyo sagte in Test Dreame Home Adapter:
                                          Download main.js
                                          Hallo ich habe einen Dreame Aqua10 Roller und habe die main.js ersetzt, nach Anleitung, aber ich bekomme keine Ordner angezeigt. Ich habe nur die drei Datenpunkte. Muss ich in der main.js noch etwas anpassen für den Aqua10 Kann jemand helfen?
