  5. (gelöst) javascript v8.3.1 - Umbau request method DELETE
13 Beiträge 4 Kommentatoren 1.1k Aufrufe 4 Beobachtet
  • S Nicht stören
    S Nicht stören
    stenmic
    schrieb am zuletzt editiert von stenmic
    Moin,
    ich nutze folgenden code den ich jetzt wegen dem request umbauen möchte.
    var requestDelete = require('request');
    var options = {
        url: 'http://192.168.xxx.xxx/server/files/gcodes/' + String(getState("0_userdata.0.3D-Drucker_Nextion.Loesche_Job").val),
        method: 'DELETE'
    requestDelete(options, function  (error, response, body) {
        log('error: ' + error);
        log('response: ' + JSON.stringify(response));
        log('body: ' + body);
    leider hab ich keine Ahnung wie 🤕
    • S stenmic
      Moin,
      var options = {
          method: 'DELETE'
      M Online
      M Online
      MCU
      @stenmic
      //var requestDelete = require('request');
      var options = {
          method: 'DELETE'
      httpGet(options, function  (error, response) {
          log('body: ' + response.data);
      • M MCU
        @stenmic
        var options = {
            method: 'DELETE'
        S Nicht stören
        S Nicht stören
        stenmic
        @mcu sagte in javascript v8.3.1 - request method DELETE:
        @stenmic
        var options = {
            method: 'DELETE'
        danke, aber es geht leider nicht (eventuell wegen dem "DELETE")
        javascript.0 2024-06-01 16:13:12.470	error	at process.processImmediate (node:internal/timers:476:21)
        javascript.0 2024-06-01 16:13:12.470	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
        javascript.0 2024-06-01 16:13:12.470	error	at Object.<anonymous> (script.js.3D-Drucker.Printjob:34:11)
        javascript.0 2024-06-01 16:13:12.470	error	at httpGet (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1183:20)
        javascript.0 2024-06-01 16:13:12.470	error	at getHttpRequestConfig (/opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:151:21)
        javascript.0 2024-06-01 16:13:12.469	error	at new NodeError (node:internal/errors:405:5)
        javascript.0 2024-06-01 16:13:12.470	error	at delete2 (script.js.3D-Drucker.Printjob:11:5)
        javascript.0 2024-06-01 16:13:12.470	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1399:38)
        javascript.0 2024-06-01 16:13:12.470	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8489:62)
        javascript.0 2024-06-01 16:13:12.469	error	script.js.3D-Drucker.Printjob: TypeError [ERR_INVALID_URL]: Invalid URL
        javascript.0 2024-06-01 16:13:12.469	error	at new URL (node:internal/url:676:13)
        • S stenmic
          @stenmic
          var options = {
              method: 'DELETE'
          M Online
          M Online
          MCU
          @stenmic Und so?
          let url = 'http://192.168.xxx.xxx/server/files/gcodes/' + String(getState("0_userdata.0.3D-Drucker_Nextion.Loesche_Job").val);
          var options = {
               method: 'DELETE'
          httpGet(url , options, function  (error, response) {
          • M MCU
            @stenmic Und so?
            var options = {
                 method: 'DELETE'
            haus-automatisierungH Offline
            @mcu Delete gibts aktuell nicht. Muss man per axios o.ä. selbst implementieren.
            Bitte in die Doku schauen und keine Parameter raten. Das müsste schon rot unterstrichen werden wenn man ein Objekt als ersten Parameter reingibt
            📚 Meine Dokumentation
            M S HomoranH 3 Antworten Letzte Antwort
              M Online
              M Online
              MCU
              @haus-automatisierung Axios
              const axios = require('axios');
              const url = 'http://192.168.xxx.xxx/server/files/gcodes/' + String(getState("0_userdata.0.3D-Drucker_Nextion.Loesche_Job").val);
              axios.delete(url)
                  .then(response => {
                      console.log('response: ' + JSON.stringify(response.data));
                  .catch(error => {
                      console.log('error: ' + error);
                      if (error.response) {
                          console.log('response: ' + JSON.stringify(error.response.data));
                S Nicht stören
                S Nicht stören
                stenmic
                @haus-automatisierung sagte in javascript v8.3.1 - request method DELETE:
                kein Problem, er versucht wenigstens mir zu helfen.
                • M MCU
                  axios.delete(url)
                      .then(response => {
                      .catch(error => {
                  S Nicht stören
                  S Nicht stören
                  stenmic
                  axios.delete(url)
                      .then(response => {
                      .catch(error => {
                  PERFEKT!!!
                  Danke, so gehts 👌
                    @haus-automatisierung sagte in (gelöst) javascript v8.3.1 - request method DELETE:
                    wie bereits in mehreren Threads erwähnt, hiesige User sind damit überfordert!
                      @homoran Mh? @MCU hat doch direkt danach die Lösung geteilt. Bin nur am Smartphone nebenbei unterwegs und kann hier schlecht Code tippen. War nur ein Hinweis… und hat ja scheinbar geholfen?
                        klar, hätte aber dem Hilfesuchenden nicht geholfen. @mcu hat dann auf axios umgebaut, was ein c&p user auch mit Doku nicht kann.
                          @homoran sagte in (gelöst) javascript v8.3.1 - request method DELETE:
                          Ich hab doch auf seinen Beitrag geantwortet und ihn explizit angesprochen?! Verstehe die Diskussion gerade nicht. Was ist dein Ziel gerade? Dass ich nicht mehr auf die Doku verweisen soll?
                            ok, dann hab ich das übersehen.
                            Ich hielt es für einen allgemeinen Einwurf an den Hilfesuchenden
                            Sorry!
