  4. Alpha Test js-controller Kiera (v6.0)
alphajs-controllerkieratest
234 Beiträge 20 Kommentatoren 65.7k Aufrufe 25 Beobachtet
  • lobomauL lobomau
    Bei mir hat das Update nicht funktioniert. Ich komme nicht mehr in den Admin Adapter.
    Heute morgen hatte ich nodejs auf 20 hochgezogen. Das lief ohne Probleme.
    ======== Start marking the full check here =========
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.5.13-5-pve
        Architecture: x86-64
    model name	: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:53:55 up 15 min,  2 users,  load average: 1.16, 1.21, 1.18
    CPU threads: 3
    *** Time and Time Zones ***
                   Local time: Sat 2024-05-25 20:53:55 CEST
               Universal time: Sat 2024-05-25 18:53:55 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    lobomau
    HOME=/home/lobomau
    GROUPS=lobomau sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:             10G        2.3G        7.4G        131K        718M        8.1G
    Swap:           3.1G          0B        3.1G
    Total:           13G        2.3G         10G
    Active iob-Instances: 	38
            10000 M total memory
             2236 M used memory
             2055 M active memory
              561 M inactive memory
             7078 M free memory
                0 M buffer memory
              685 M swap cache
             3000 M total swap
                0 M used swap
             3000 M free swap
    top - 20:53:56 up 15 min,  2 users,  load average: 1.16, 1.21, 1.18
    Tasks:  53 total,   1 running,  52 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  10000.0 total,   7077.3 free,   2237.8 used,    685.1 buff/cache
    MiB Swap:   3000.0 total,   3000.0 free,      0.0 used.   7762.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       15G   12G  2.3G  85% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                                  SOURCE                           FSTYPE     OPTIONS
    /                                                       /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
    |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3247140k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1623568k,nr_inodes=405892,mode=700,uid=101000,gid=101000,inode64
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
    | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
    | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
    | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
    | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
    | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
    | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
    | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
    | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
    | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
    | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    2.0G	/var/
    1.5G	/var/log/journal/455f0ce5be8748d19c89e2021e5472af
    1.5G	/var/log
    373M	/var/cache
    Archived and active journals take up 659.0M in the file system.
    /opt/iobroker/backups:
    1.2G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G	/opt/iobroker/iobroker-data/
    670M	/opt/iobroker/iobroker-data/files
    298M	/opt/iobroker/iobroker-data/esphome.0/.esphome/build
    43M	/opt/iobroker/iobroker-data/objects.jsonl
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    25M	/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32-test2/.pioenvs/esp32-test2/libFrameworkArduino.a
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.13.1
    /usr/bin/node 		v20.13.1
    /usr/bin/npm 		10.5.2
    /usr/bin/npx 		10.5.2
    /usr/bin/corepack 	0.28.0
    nodejs:
      Installed: 20.13.1-1nodesource1
      Candidate: 20.13.1-1nodesource1
      Version table:
     *** 20.13.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	6.0.1-alpha.0-20240525-56d9e4a2e
    admin: 		6.17.6
    javascript: 	8.3.1
    nodejs modules from github: 	3
    +-- iobroker.heatingcontrol@2.12.5 (git+ssh://git@github.com/rg-engineering/ioBroker.heatingcontrol.git#830136e1eb912d51bbb270d931c16d98bdfd4ae9)
    +-- iobroker.ve@0.3.1 (git+ssh://git@github.com/derAlff/ioBroker.ve.git#584088cddf3318ede48554ed97414f5ff79f460e)
    +-- iobroker.vis-materialdesign@0.5.86 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#cf7fc5b85debcda156a3ec7feb761cff217fa855)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : Pi4                                      -  enabled
      system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.admin.1                  : admin                 : ioBroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      system.adapter.admin.2                  : admin                 : Pi4                                      - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
      system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.bmw.0                    : bmw                   : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : Pi4                                      -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : Pi4                                      -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 - disabled
    + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      system.adapter.esphome.0                : esphome               : Pi4                                      - disabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.go-e.0                   : go-e                  : ioBroker                                 -  enabled
    + system.adapter.go-e.1                   : go-e                  : ioBroker                                 -  enabled
    + system.adapter.hass.0                   : hass                  : ioBroker                                 -  enabled, port: 8123
    + system.adapter.heatingcontrol.0         : heatingcontrol        : Pi4                                      -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : Pi4                                      -  enabled
      system.adapter.ical.1                   : ical                  : Pi4                                      -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : Pi4                                      -  enabled
      system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 - disabled
      system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 - disabled, port: 8080
    + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
    + system.adapter.lovelace.1               : lovelace              : ioBroker                                 -  enabled, port: 8098, bind: 0.0.0.0, run as: admin
      system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
      system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
    + system.adapter.pid.0                    : pid                   : ioBroker                                 -  enabled
    + system.adapter.places.0                 : places                : ioBroker                                 -  enabled
    + system.adapter.proxmox.1                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.pushover.0               : pushover              : Pi3                                      - disabled
      system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
    + system.adapter.radar2.1                 : radar2                : Pi4                                      -  enabled
    + system.adapter.ring.0                   : ring                  : Pi4                                      -  enabled
    + system.adapter.rpi2.2                   : rpi2                  : Pi4                                      -  enabled
    + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
    + system.adapter.sayit.1                  : sayit                 : ioBroker                                 -  enabled
      system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sma-em.0                 : sma-em                : ioBroker                                 -  enabled
      system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
      system.adapter.smartmeter.0             : smartmeter            : Pi4                                      - disabled
      system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Pi4                                      -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
      system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : Pi4                                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tesla-motors.0           : tesla-motors          : ioBroker                                 -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : Pi4                                      -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : Pi4                                      -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      system.adapter.uv-protect.0             : uv-protect            : ioBroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.web.1                    : web                   : ioBroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.web.2                    : web                   : Pi4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.withings.0               : withings              : ioBroker                                 -  enabled
      system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : Pi4                                      -  enabled
    + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : ioBroker                                 -  enabled
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
    Adapter    "admin"        : 6.17.14  , installed 6.17.6 [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 1.2.0    , installed 0.16.0 [Updatable]
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "bmw"          : 2.8.0    , installed 2.8.0
    Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-watcher": 2.12.1  , installed 2.12.0 [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.4.0 [Updatable]
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "go-e"         : 1.0.29   , installed 1.0.29
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.2.2  [Updatable]
    Adapter    "javascript"   : 8.4.0    , installed 8.3.1  [Updatable]
    Controller "js-controller": 5.0.19   , installed 6.0.1
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.9  [Updatable]
    Adapter    "modbus"       : 6.2.2    , installed 6.1.0  [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "pid"          : 1.1.3    , installed 1.1.3
    Adapter    "places"       : 1.2.0    , installed 1.2.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "ring"         : 5.0.10   , installed 5.0.10
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
    Adapter    "sma-em"       : 1.0.1    , installed 1.0.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "telegram"     : 3.3.1    , installed 3.3.1
    Adapter    "tesla-motors" : 1.4.5    , installed 1.4.5
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "uv-protect"   : 0.6.0    , installed 0.6.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.60 [Updatable]
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 6.2.6    , installed 6.2.5  [Updatable]
    Adapter    "webui"        : 1.8.6    , installed 1.6.5  [Updatable]
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "worx"         : 3.0.2    , installed 2.3.4  [Updatable]
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yahoo-stock-market": 0.0.6, installed 0.0.6
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
    Objects and States
    Objects: 	32352
    States: 	25140
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          33110488   1/init
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       33133400   2894/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       33132368   2894/iobroker.js-co
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          33117615   857/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          33109589   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          33110490   1/init
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       33143061   3696/io.nuki-extend
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          33117616   857/master
    tcp6       0      0 :::8098                 :::*                    LISTEN      1001       33143032   3667/io.lovelace.1
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33145149   3854/io.simple-api.
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          33110489   1/init
    udp6       0      0 :::111                  :::*                                0          33110491   1/init
    2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
    2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.modbus/node_modules/@iobroker/adapter-core/build/index.js:19:27)
    2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
    2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]: Node.js v20.13.1
    2024-05-25 20:54:20.158  - error: host.ioBroker instance system.adapter.modbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-05-25 20:54:20.158  - info: host.ioBroker Restart adapter system.adapter.modbus.0 because enabled
    2024-05-25 20:54:21.894  - info: host.ioBroker instance system.adapter.mqtt.0 started with pid 7547
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     ^
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
    2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/index.js:19:27)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
    2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]: Node.js v20.13.1
    2024-05-25 20:54:22.334  - error: host.ioBroker instance system.adapter.mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-05-25 20:54:22.334  - info: host.ioBroker Restart adapter system.adapter.mqtt.0 because enabled
    crunchipC Offline
    crunchipC Offline
    #161
    @lobomau sagte in Alpha Test js-controller Kiera (v6.0):
    keiner deiner admin`s läuft
    lobomauL 1 Antwort Letzte Antwort
    • foxriver76F foxriver76
      @lobomau Admin ist nicht aktuell
      lobomauL Offline
      lobomauL Offline
      lobomau
      #162
      @foxriver76 ok, ich hatte nur 3 Adapter unter dem #2 geupdatet. Admin war stable.
      wie war nochmal der Befehl bzw. welches ist die zu installierende Admin-Version?
      Ich habe folgendes versucht. Er sagt nun eigentlich admin läuft!?
      lobomau@ioBroker:~$ iob upgrade admin
      Would you like to upgrade admin from @6.17.6 to @6.17.14 now? [(y)es, (n)o]: y
      Update admin from @6.17.6 to @6.17.14
      host.ioBroker Adapter "system.adapter.admin.0" is stopped.
      host.ioBroker Adapter "system.adapter.admin.1" is stopped.
      NPM version: 10.5.2
      Installing iobroker.admin@6.17.14... (System call)
      host.ioBroker Adapter "system.adapter.admin.0" is started
      host.ioBroker Adapter "system.adapter.admin.1" is started
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
        lobomauL Offline
        lobomauL Offline
        lobomau
        #163
        @crunchip als Laie habe ich daraus gelesen, dass die beiden Instanzen auf ioBroker laufen. Komisch.
        Bin erstmal wieder zurück auf js-controller 5.0.19 und alles läuft wieder normal.
        • Slave: Pi4
        • lobomauL lobomau
          crunchipC Offline
          crunchipC Offline
          #164
          ne
          , ein punkt davor bedeutet er läuft
          bei dir aber
            Gerne nochmal updaten.
            Das Problem, dass er sich über invalide Instanz Objekte vom Typ device beschwert wurde behoben und nochmal ein anderer Versuch für die alten Adapter-Core Versionen wird ausprobiert.
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            schrieb am zuletzt editiert von Feuersturm
            #165
            @foxriver76 update auf js-controller 6.0.1-alpha.0-20240525-56d9e4a2e
            Installation
            proxmox@ioBrokerTestsystem:~$ iob stop
            proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
            proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --omit=dev
            [sudo] password for proxmox:
            npm warn ERESOLVE overriding peer dependency
            npm warn While resolving: @mui/x-date-pickers@7.5.1
            npm warn Found: @mui/material@5.14.14
            npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
            npm warn   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22
            npm warn     @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6.17.13
            npm warn     node_modules/@iobroker/json-config
            npm warn     1 more (iobroker.radar-trap)
            npm warn
            npm warn Could not resolve dependency:
            npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1
            npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pickers
            npm warn   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22
            npm warn
            npm warn Conflicting peer dependency: @mui/material@5.15.18
            npm warn node_modules/@mui/material
            npm warn While resolving: @iobroker/adapter-core@3.1.4
            npm warn Found: @iobroker/types@6.0.0
            npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
            npm warn   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
            npm warn     iobroker.admin@"6.17.14" from the root project
            npm warn
            npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
            npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
            npm warn   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
            npm warn
            npm warn Conflicting peer dependency: @iobroker/types@5.0.19
            npm warn node_modules/@iobroker/types
            npm warn reify invalid or damaged lockfile detected
            npm warn reify please re-try this operation once it completes
            npm warn reify so that the damage can be corrected, or perform
            npm warn reify a fresh install with no lockfile if the problem persists.
            added 35 packages, removed 10 packages, and changed 13 packages in 1m
            397 packages are looking for funding
              run `npm fund` for details
            Keine Auffälligkeiten beim starten von ioBroker :-)
            lobomauL FeuersturmF 2 Antworten Letzte Antwort
            • FeuersturmF Feuersturm
              Installation
              npm warn
              npm warn
              npm warn
              npm warn
              lobomauL Offline
              lobomauL Offline
              lobomau
              #166
              @feuersturm dein Auszug ist nicht komplett, oder? Müsste doch der längere Befehl sein, oder?
              • Slave: Pi4
              Thomas BraunT FeuersturmF 2 Antworten Letzte Antwort
              • lobomauL lobomau
                #167
                Das ist ein falscher Zeilenumbruch. Bestimmt per puTTY hantiert, das fabriziert das schon mal ganz gerne.
                • lobomauL lobomau
                  FeuersturmF Offline
                  FeuersturmF Offline
                  Feuersturm
                  #168
                  @lobomau In putty gab es einen Zeilenumbruch und das copy paste Ergebnis wurde hier im Forum nicht richtig dargestellt. In den Codetags im Editor hier waren die Zeichen enthalten, wurden aber im Beitrag nicht angezeigt. Hab es korrigiert
                    Installation
                    npm warn
                    npm warn
                    npm warn
                    npm warn
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    #169
                    @foxriver76
                    Auf meinem zweiten Testsystem wo nodejs20 installiert ist und ich auch gerade einmal js-controller 6.0.1-alpha.0-20240525-56d9e4a2e installiert habe:
                    Installation
                    proxmox@ioB-Prod-Testsystem:~$ iob stop
                    proxmox@ioB-Prod-Testsystem:~$ cd /opt/iobroker/
                    proxmox@ioB-Prod-Testsystem:/opt/iobroker$ npm i iobroker.js-controller@next --omit=dev
                    npm WARN ERESOLVE overriding peer dependency
                    npm WARN While resolving: @mui/x-date-pickers@7.5.0
                    npm WARN Found: @mui/material@5.14.14
                    npm WARN node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
                    npm WARN   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.20
                    npm WARN     @iobroker/adapter-react-v5@"^4.13.6" from @iobroker/dm-gui-components@6.17.6
                    npm WARN     node_modules/@iobroker/dm-gui-components
                    npm WARN     2 more (@iobroker/json-config, iobroker.radar-trap)
                    npm WARN
                    npm WARN Could not resolve dependency:
                    npm WARN peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.0
                    npm WARN node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pickers
                    npm WARN   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.20
                    npm WARN
                    npm WARN Conflicting peer dependency: @mui/material@5.15.18
                    npm WARN node_modules/@mui/material
                    npm WARN While resolving: @iobroker/adapter-core@3.1.4
                    npm WARN Found: @iobroker/types@6.0.0
                    npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types
                    npm WARN   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
                    npm WARN     iobroker.admin@"6.17.14" from the root project
                    npm WARN
                    npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
                    npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                    npm WARN   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
                    npm WARN
                    npm WARN Conflicting peer dependency: @iobroker/types@5.0.19
                    npm WARN node_modules/@iobroker/types
                    added 13 packages, removed 134 packages, and changed 27 packages in 1m
                    291 packages are looking for funding
                    iobroker Start
                    Hier tauchen einige Errors auf. Der gleiche Fehler taucht bei sehr vielen Adaptern auf. Hier ein Auszug aus dem Log:
                    2024-05-25 22:28:39.073  - info: host.ioB-Prod-Testsystem iobroker.js-controller version 6.0.1 js-controller starting
                    2024-05-25 22:28:39.088  - info: host.ioB-Prod-Testsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                    2024-05-25 22:28:39.096  - info: host.ioB-Prod-Testsystem hostname: ioB-Prod-Testsystem, node: v20.13.1
                    2024-05-25 22:28:39.101  - info: host.ioB-Prod-Testsystem ip addresses: 192.168.178.105 fe80::be24:11ff:fe8c:71a4
                    2024-05-25 22:28:42.804  - info: host.ioB-Prod-Testsystem connected to Objects and States
                    2024-05-25 22:28:42.853  - info: host.ioB-Prod-Testsystem added notifications configuration of host
                    2024-05-25 22:28:44.062  - info: host.ioB-Prod-Testsystem 68 instances found
                    2024-05-25 22:28:44.220  - info: host.ioB-Prod-Testsystem starting 47 instances
                    2024-05-25 22:28:44.957  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.nodeCurrent"
                    2024-05-25 22:28:44.983  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.nodeNewest"
                    2024-05-25 22:28:45.014  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.nodeNewestNext"
                    2024-05-25 22:28:45.040  - info: host.ioB-Prod-Testsystem instance system.adapter.admin.0 started with pid 11898
                    2024-05-25 22:28:45.055  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.npmCurrent"
                    2024-05-25 22:28:45.112  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.npmNewest"
                    2024-05-25 22:28:45.126  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.npmNewestNext"
                    2024-05-25 22:28:45.138  - info: host.ioB-Prod-Testsystem Some obsolete host states deleted.
                    2024-05-25 22:28:47.059  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                    2024-05-25 22:28:47.061  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                    2024-05-25 22:28:47.064  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
                    2024-05-25 22:28:47.066  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                    2024-05-25 22:28:47.069  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                    2024-05-25 22:28:47.071  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                    2024-05-25 22:28:47.073  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:28:47.076  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    2024-05-25 22:28:47.078  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                    2024-05-25 22:28:47.081  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                    2024-05-25 22:28:47.083  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                    2024-05-25 22:28:47.086  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                    2024-05-25 22:28:47.088  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                    2024-05-25 22:28:47.091  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:28:47.094  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
                    2024-05-25 22:28:47.097  - error: host.ioB-Prod-Testsystem instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-05-25 22:28:47.100  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.admin.0 because enabled
                    2024-05-25 22:28:49.059  - info: host.ioB-Prod-Testsystem instance system.adapter.javascript.0 started with pid 11905
                    2024-05-25 22:28:52.945  - info: host.ioB-Prod-Testsystem instance system.adapter.scenes.0 started with pid 11916
                    2024-05-25 22:28:54.831  - info: javascript.0 (11905) starting. Version 8.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                    2024-05-25 22:28:57.173  - info: host.ioB-Prod-Testsystem instance system.adapter.scheduler.0 started with pid 11942
                    2024-05-25 22:28:58.780  - info: scenes.0 (11916) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                    2024-05-25 22:29:01.702  - info: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 started with pid 11957
                    2024-05-25 22:29:04.205  - info: scheduler.0 (11942) starting. Version 1.3.12 in /opt/iobroker/node_modules/iobroker.scheduler, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                    2024-05-25 22:29:05.626  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/controllerTools.js:80
                    2024-05-25 22:29:05.632  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                    2024-05-25 22:29:05.635  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
                    2024-05-25 22:29:05.638  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                    2024-05-25 22:29:05.641  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/controllerTools.js:80:11)
                    2024-05-25 22:29:05.645  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/controllerTools.js:154:18)
                    2024-05-25 22:29:05.648  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:05.651  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    2024-05-25 22:29:05.654  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                    2024-05-25 22:29:05.657  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                    2024-05-25 22:29:05.660  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                    2024-05-25 22:29:05.663  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                    2024-05-25 22:29:05.666  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                    2024-05-25 22:29:05.669  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:05.672  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
                    2024-05-25 22:29:05.675  - error: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-05-25 22:29:05.679  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.fritzbox.0 because enabled
                    2024-05-25 22:29:05.765  - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rpc.0 started with pid 11968
                    2024-05-25 22:29:08.260  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                    2024-05-25 22:29:08.263  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                    2024-05-25 22:29:08.265  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
                    2024-05-25 22:29:08.268  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                    2024-05-25 22:29:08.271  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                    2024-05-25 22:29:08.274  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                    2024-05-25 22:29:08.276  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:08.279  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    2024-05-25 22:29:08.282  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                    2024-05-25 22:29:08.285  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                    2024-05-25 22:29:08.289  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                    2024-05-25 22:29:08.291  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                    2024-05-25 22:29:08.296  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                    2024-05-25 22:29:08.299  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:08.302  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
                    2024-05-25 22:29:08.305  - error: host.ioB-Prod-Testsystem instance system.adapter.hm-rpc.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-05-25 22:29:08.308  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                    2024-05-25 22:29:09.392  - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rega.0 started with pid 11975
                    2024-05-25 22:29:11.653  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                    2024-05-25 22:29:11.656  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                    2024-05-25 22:29:11.659  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
                    2024-05-25 22:29:11.664  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                    2024-05-25 22:29:11.669  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                    2024-05-25 22:29:11.673  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                    2024-05-25 22:29:11.676  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:11.680  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    2024-05-25 22:29:11.683  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                    2024-05-25 22:29:11.686  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                    2024-05-25 22:29:11.690  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                    2024-05-25 22:29:11.695  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                    2024-05-25 22:29:11.699  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                    2024-05-25 22:29:11.702  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:11.705  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
                    2024-05-25 22:29:11.709  - error: host.ioB-Prod-Testsystem instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-05-25 22:29:11.712  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.hm-rega.0 because enabled
                    2024-05-25 22:29:13.217  - info: host.ioB-Prod-Testsystem instance system.adapter.proxmox.0 started with pid 11982
                    2024-05-25 22:29:17.035  - info: host.ioB-Prod-Testsystem instance system.adapter.tr-064.0 started with pid 11993
                    2024-05-25 22:29:18.402  - info: host.ioB-Prod-Testsystem instance system.adapter.admin.0 started with pid 12000
                    2024-05-25 22:29:19.087  - info: proxmox.0 (11982) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.proxmox, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                    2024-05-25 22:29:19.216  - warn: proxmox.0 (11982) Using Proxmox API: https://192.168.178.2:8006/api2/json
                    2024-05-25 22:29:21.748  - info: host.ioB-Prod-Testsystem instance system.adapter.worx.0 started with pid 12011
                    2024-05-25 22:29:22.101  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                    2024-05-25 22:29:22.105  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                    2024-05-25 22:29:22.108  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
                    2024-05-25 22:29:22.111  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                    2024-05-25 22:29:22.114  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                    2024-05-25 22:29:22.117  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                    2024-05-25 22:29:22.119  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:22.134  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    2024-05-25 22:29:22.137  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                    2024-05-25 22:29:22.139  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                    2024-05-25 22:29:22.142  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                    2024-05-25 22:29:22.145  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                    2024-05-25 22:29:22.147  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                    2024-05-25 22:29:22.150  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:22.153  - error: host.ioB-Prod-Testsystem Caught by controller[1]: Node.js v20.13.1
                    2024-05-25 22:29:22.156  - error: host.ioB-Prod-Testsystem instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-05-25 22:29:22.159  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.admin.0 because enabled
                    2024-05-25 22:29:25.494  - info: host.ioB-Prod-Testsystem instance system.adapter.unifi.0 started with pid 12026
                    2024-05-25 22:29:27.823  - info: tr-064.0 (11993) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                    2024-05-25 22:29:30.140  - info: host.ioB-Prod-Testsystem instance system.adapter.hue.0 started with pid 12052
                    2024-05-25 22:29:30.848  - info: worx.0 (12011) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.worx, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                    2024-05-25 22:29:32.056  - info: worx.0 (12011) Use new aws-iot-device-sdk-v2.
                    2024-05-25 22:29:32.065  - info: worx.0 (12011) Changed timeout for edgecut to 5000
                    2024-05-25 22:29:32.093  - info: worx.0 (12011) Login to worx
                    2024-05-25 22:29:33.930  - info: worx.0 (12011) Connected to worx server
                    2024-05-25 22:29:34.338  - info: worx.0 (12011) Found 1 devices
                    2024-05-25 22:29:34.350  - info: worx.0 (12011) Found device Maehphisto with id 201930198403020782E0
                    2024-05-25 22:29:34.762  - info: host.ioB-Prod-Testsystem instance system.adapter.backitup.0 started with pid 12080
                    2024-05-25 22:29:35.162  - info: worx.0 (12011) Multi-ZoneKeeper found! Create State : zoneKeeper
                    2024-05-25 22:29:36.336  - info: worx.0 (12011) DoubleShedule found, create states...
                    2024-05-25 22:29:38.606  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                    2024-05-25 22:29:38.613  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                    2024-05-25 22:29:38.615  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
                    2024-05-25 22:29:38.634  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                    2024-05-25 22:29:38.637  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                    2024-05-25 22:29:38.639  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                    2024-05-25 22:29:38.659  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:38.662  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    2024-05-25 22:29:38.664  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                    2024-05-25 22:29:38.684  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                    2024-05-25 22:29:38.686  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                    2024-05-25 22:29:38.691  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                    2024-05-25 22:29:38.698  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                    2024-05-25 22:29:38.701  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                    2024-05-25 22:29:38.716  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
                    2024-05-25 22:29:38.729  - error: host.ioB-Prod-Testsystem instance system.adapter.hue.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-05-25 22:29:38.732  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.hue.0 because enabled
                    2024-05-25 22:29:38.951  - info: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 started with pid 12087
                      @foxriver76
                      Installation
                      npm WARN
                      npm WARN
                      npm WARN
                      npm WARN
                      iobroker Start
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #170
                      @feuersturm welche Admin Version ist auf dem System installiert mit den Fehlern?
                      Videotutorials & mehr
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #171
                        @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
                        system.adapter.admin                   : admin          - v6.17.14
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          #172
                          @feuersturm Kannst du mir vom betroffenen Host npm ls @iobroker/adapter-core zeigen (ausgeführt in opt/iobroker)
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #173
                            Na klar:
                            proxmox@ioB-Prod-Testsystem:/opt/iobroker$ npm ls @iobroker/adapter-core
                            iobroker.inst@2.0.3 /opt/iobroker
                            +-- iobroker.admin@6.17.14
                            | +-- @iobroker/adapter-core@3.1.4
                            | `-- @iobroker/socket-classes@1.5.0
                            |   `-- @iobroker/adapter-core@3.0.4
                            +-- iobroker.backitup@2.11.0
                            +-- iobroker.daswetter@3.1.13
                            +-- iobroker.dwd@2.8.5
                            | `-- @iobroker/adapter-core@2.6.12
                            +-- iobroker.esphome@0.5.0-beta.8
                            +-- iobroker.fritzbox@0.6.0
                            | `-- @iobroker/adapter-core@3.0.6
                            +-- iobroker.fullcalendar@2.3.16
                            | `-- @iobroker/adapter-core@3.1.4
                            +-- iobroker.fully-tablet-control@0.3.8
                            | `-- @iobroker/adapter-core@2.6.12 deduped
                            +-- iobroker.hm-rega@4.0.0
                            | `-- @iobroker/adapter-core@3.0.3
                            +-- iobroker.hm-rpc@1.17.0
                            | +-- @iobroker/adapter-core@3.0.4
                            | `-- @iobroker/dm-utils@0.1.9
                            +-- iobroker.hue@3.11.0
                            +-- iobroker.ical@1.15.0
                            +-- iobroker.influxdb@4.0.2
                            +-- iobroker.javascript@8.4.0
                            +-- iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                            +-- iobroker.mqtt@5.2.0
                            +-- iobroker.nina@0.0.26
                            +-- iobroker.openweathermap@1.0.4
                            +-- iobroker.proxmox@2.3.0
                            +-- iobroker.radar-trap@2.2.0
                            +-- iobroker.rainbird@0.2.3
                            | `-- @iobroker/adapter-core@1.0.3
                            +-- iobroker.samsung@0.6.0
                            +-- iobroker.sayit@3.0.5
                            +-- iobroker.scenes@3.0.4
                            +-- iobroker.scheduler@1.3.12
                            +-- iobroker.seq@0.3.0
                            +-- iobroker.shuttercontrol@1.7.0
                            +-- iobroker.simple-api@2.8.0
                            +-- iobroker.socketio@6.7.0
                            +-- iobroker.sonos@3.0.0
                            +-- iobroker.spotify-premium@1.5.0
                            +-- iobroker.tankerkoenig@3.4.0
                            +-- iobroker.telegram@3.3.1
                            +-- iobroker.tr-064@4.3.0
                            +-- iobroker.trashschedule@3.3.0
                            +-- iobroker.unifi@0.7.0
                            +-- iobroker.valloxmv@1.2.0
                            +-- iobroker.vis-2@2.9.64
                            +-- iobroker.vis-google-fonts@1.0.4
                            +-- iobroker.vis-history@1.0.0
                            +-- iobroker.vis-metro@1.2.0
                            +-- iobroker.vis-timeandweather@1.2.2
                            +-- iobroker.vis@1.5.6
                            +-- iobroker.web@6.2.6
                            +-- iobroker.worx@3.0.2
                            `-- iobroker.ws@2.6.1
                              Na klar:
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              schrieb am zuletzt editiert von foxriver76
                              #174
                              @feuersturm Hm oaky, es scheint irgendein Adapter bringt eine exakte Version mit von Adapter-Core (3.0.4) aber ich muss suchen welcher. Dadurch wird dann für viele Adapter nicht die 3.1.4 mit verwendet.
                              Jop, daswetter scheint es zu sein, kannst du daswetter mal von GitHub updaten?
                              Das scheint allgemein bei den Adaptern von rg-engineering https://github.com/rg-engineering?tab=repositories&q=ioBroker.&type=source&language=&sort= der Fall zu sein :-(
                              FeuersturmF T 2 Antworten Letzte Antwort
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #175
                                @foxriver76 Hab daswetter von github installiert und noch einmal js-controller 6 installiert
                                Es sind immer noch sehr viele Fehler vorhanden
                                log.txt
                                  TT-Tom
                                  #176
                                  @foxriver76
                                  habe auch nochmal das Update angestoßen, nachdem ich den Admin auf 6.17.14 aktualisiert habe.
                                  tom@iobtest:/opt/iobroker $ npm i iobroker.js-controller@next --omit=dev
                                  npm WARN
                                  npm WARN
                                  npm ls @iobroker/adapter-core brachte das hier
                                  tom@iobtest:/opt/iobroker $ npm ls @iobroker/adapter-core
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├─┬ iobroker.accuweather@1.4.0
                                  │ └── @iobroker/adapter-core@3.1.4
                                  ├─┬ iobroker.admin@6.17.14
                                  │ ├── @iobroker/adapter-core@3.1.4
                                  │ └─┬ @iobroker/socket-classes@1.5.0
                                  ├─┬ iobroker.alias-manager@1.2.6
                                  │ └── @iobroker/adapter-core@2.6.12
                                  ├─┬ iobroker.backitup@2.11.0
                                  ├─┬ iobroker.fahrplan@1.2.3
                                  │ └── @iobroker/adapter-core@2.6.12 deduped
                                  ├─┬ iobroker.ical@1.15.0
                                  ├─┬ iobroker.influxdb@4.0.2
                                  ├─┬ iobroker.javascript@8.4.0
                                  ├─┬ iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                                  ├─┬ iobroker.mqtt-client@1.8.0
                                  ├─┬ iobroker.mqtt@5.2.0
                                  ├─┬ iobroker.netatmo-crawler@0.8.1
                                  ├─┬ iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
                                  ├─┬ iobroker.opendtu@1.0.1
                                  ├─┬ iobroker.simple-api@2.8.0
                                  ├─┬ iobroker.socketio@6.7.0
                                  ├─┬ iobroker.trashschedule@3.3.0
                                  ├─┬ iobroker.web@6.2.6
                                  ├─┬ iobroker.ws@2.6.1
                                  └─┬ iobroker.yahka@1.0.3
                                  das System läuft ansonsten sauber hoch, bis auf das die npm-Module die im Javascript-Adapter eingetragen sind geladen werden.
                                  serialport; dayjs, moment-parseformat
                                  meine Instanzen
                                  tom@iobtest:/opt/iobroker $ iob list instances
                                    system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
                                  + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                    system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                                  + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                                    system.adapter.devices.0                : devices               : iobtest                                  - disabled
                                  + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                                    system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                                  + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                                  + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                                  + system.adapter.mqtt-client.0            : mqtt-client           : iobtest                                  -  enabled, port: 7531
                                  + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                                    system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
                                    system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                                    system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                                    system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                                  + instance is alive
                                  Gruß Tom
                                  Public Transport
                                  NSPanel Adapter Wiki
                                    @mcm1957 @haus-automatisierung
                                    Start mit dem custom modul playactor aktiv:
                                    2024-05-25 14:25:54.749  - info: javascript.0 (179133) starting. Version 8.4.0 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                                    2024-05-25 14:26:03.646  - warn: javascript.0 (179133) Cannot install custom npm package playactor: Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                                    2024-05-25 14:26:04.391  - info: javascript.0 (179133) requesting all states
                                    2024-05-25 14:26:04.393  - info: javascript.0 (179133) requesting all objects
                                    2024-05-25 14:26:07.025  - info: javascript.0 (179133) received all objects
                                    2024-05-25 14:26:07.474  - info: javascript.0 (179133) received all states
                                    2024-05-25 14:26:07.722  - info: javascript.0 (179133) Start JavaScript script.js.common.awtrix (Blockly)
                                    2024-05-25 14:26:07.781  - info: javascript.0 (179133) script.js.common.awtrix: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.795  - info: javascript.0 (179133) Start JavaScript script.js.common.frostwarner (Blockly)
                                    2024-05-25 14:26:07.805  - info: javascript.0 (179133) script.js.common.frostwarner: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.805  - info: javascript.0 (179133) Start JavaScript script.js.common.lautstaerke_bad (Blockly)
                                    2024-05-25 14:26:07.812  - info: javascript.0 (179133) script.js.common.lautstaerke_bad: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.813  - info: javascript.0 (179133) Start JavaScript script.js.common.lautstaerke_kueche (Blockly)
                                    2024-05-25 14:26:07.819  - info: javascript.0 (179133) script.js.common.lautstaerke_kueche: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.820  - info: javascript.0 (179133) Start JavaScript script.js.common.nuki_ext_wohnungstuer_entriegelt (Blockly)
                                    2024-05-25 14:26:07.827  - info: javascript.0 (179133) script.js.common.nuki_ext_wohnungstuer_entriegelt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.827  - info: javascript.0 (179133) Start JavaScript script.js.common.paketlieferungen (Blockly)
                                    2024-05-25 14:26:07.918  - info: javascript.0 (179133) script.js.common.paketlieferungen: registered 1 subscription, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.918  - info: javascript.0 (179133) Start JavaScript script.js.common.pakettruhe_offen (Blockly)
                                    2024-05-25 14:26:07.924  - info: javascript.0 (179133) script.js.common.pakettruhe_offen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.926  - info: javascript.0 (179133) Start JavaScript script.js.common.ps4_waker (Blockly)
                                    2024-05-25 14:26:07.932  - info: javascript.0 (179133) script.js.common.ps4_waker: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.933  - info: javascript.0 (179133) Start JavaScript script.js.common.sonnenaufgang (Blockly)
                                    2024-05-25 14:26:07.939  - info: javascript.0 (179133) script.js.common.sonnenaufgang: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.940  - info: javascript.0 (179133) Start JavaScript script.js.common.sonnenuntergang (Blockly)
                                    2024-05-25 14:26:07.946  - info: javascript.0 (179133) script.js.common.sonnenuntergang: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.947  - info: javascript.0 (179133) Start JavaScript script.js.common.speedtest (Javascript/js)
                                    2024-05-25 14:26:07.954  - info: javascript.0 (179133) script.js.common.speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
                                    2024-05-25 14:26:07.958  - info: javascript.0 (179133) script.js.common.speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 180 Sekunden ausgeführt!
                                    2024-05-25 14:26:07.970  - info: javascript.0 (179133) script.js.common.speedtest: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.971  - info: javascript.0 (179133) Start JavaScript script.js.common.telefon_klingelt (Blockly)
                                    2024-05-25 14:26:07.977  - info: javascript.0 (179133) script.js.common.telefon_klingelt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.979  - info: javascript.0 (179133) Start JavaScript script.js.common.treppenhaus_licht_hub (Blockly)
                                    2024-05-25 14:26:07.985  - info: javascript.0 (179133) script.js.common.treppenhaus_licht_hub: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:07.986  - info: javascript.0 (179133) Start JavaScript script.js.common.tuerklingel_laeutet (Blockly)
                                    2024-05-25 14:26:07.992  - info: javascript.0 (179133) script.js.common.tuerklingel_laeutet: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:08.010  - info: javascript.0 (179133) Start JavaScript script.js.common.usv_warner (Blockly)
                                    2024-05-25 14:26:08.018  - info: javascript.0 (179133) script.js.common.usv_warner: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:08.019  - info: javascript.0 (179133) Start JavaScript script.js.common.wohnung_verlassen (Blockly)
                                    2024-05-25 14:26:08.026  - info: javascript.0 (179133) script.js.common.wohnung_verlassen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:08.027  - info: javascript.0 (179133) Start JavaScript script.js.common.zuhause_verlassen (Blockly)
                                    2024-05-25 14:26:08.034  - info: javascript.0 (179133) script.js.common.zuhause_verlassen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:08.060  - info: javascript.0 (179133) Watch /home/iobroker/skripte/common/
                                    2024-05-25 14:26:08.063  - info: javascript.0 (179133) Watch /home/iobroker/skripte/global/
                                    2024-05-25 14:26:08.064  - info: javascript.0 (179133) Watch /home/iobroker/skripte/
                                    2024-05-25 14:26:08.085  - info: javascript.0 (179133) Start JavaScript script.js.nuki_extended_restart_fix (Javascript/js)
                                    2024-05-25 14:26:08.092  - info: javascript.0 (179133) script.js.nuki_extended_restart_fix: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:08.108  - info: javascript.0 (179133) Start JavaScript script.js.solix2mqtt (Javascript/js)
                                    2024-05-25 14:26:08.115  - info: javascript.0 (179133) script.js.solix2mqtt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-05-25 14:26:08.115  - info: javascript.0 (179133) Start JavaScript script.js.stromzaehler2 (Javascript/js)
                                    2024-05-25 14:26:08.122  - info: javascript.0 (179133) script.js.stromzaehler2: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    Schaut so auf den ersten Blick gut aus, die anderen Skripte starten wohl alle richtig auf.
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #177
                                    @thomas-braun Kannst du mir mal die root package.json zeigen, also den Inhalt von /opt/iobroker/package.json
                                      #178
                                      @foxriver76
                                      echad@chet:~ $ cat /opt/iobroker/package.json
                                      {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=16.0.0"},"dependencies":{"@iobroker-javascript.0/playactor":"npm:playactor@^0.4.1","iobroker.admin":"6.17.14","iobroker.alexa2":"3.26.5","iobroker.alias-manager":"1.2.6","iobroker.awtrix-light":"1.2.0","iobroker.backitup":"2.11.0","iobroker.ble":"0.14.0","iobroker.cloud":"5.0.1","iobroker.devices":"1.1.5","iobroker.drops-weather":"github:inbux/ioBroker.drops-weather","iobroker.echarts":"1.7.2","iobroker.firetv":"2.1.0","iobroker.followthesun":"0.5.0","iobroker.govee-app":"github:TA2k/ioBroker.govee-app#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85","iobroker.govee-local":"0.2.6","iobroker.history":"3.0.1","iobroker.ical":"1.15.0","iobroker.iceroad":"1.2.1","iobroker.iot":"3.3.0","iobroker.javascript":"8.4.0","iobroker.js-controller":"^6.0.1-alpha.0-20240525-56d9e4a2e","iobroker.midea":"github:TA2k/ioBroker.midea#0d037c0c9a025b193546f881f747c8f998bfc724","iobroker.mihome":"1.4.0","iobroker.mihome-cloud":"0.1.1","iobroker.mihome-vacuum":"4.2.0","iobroker.mqtt":"5.2.0","iobroker.nina":"0.0.26","iobroker.nuki-extended":"2.7.0","iobroker.nut":"1.6.0","iobroker.opendtu":"1.0.1","iobroker.openweathermap":"1.0.4","iobroker.parcel":"github:TA2k/ioBroker.parcel","iobroker.rpi2":"1.3.2","iobroker.sainlogic":"0.10.5","iobroker.samsung":"0.6.0","iobroker.samsung_tizen":"1.1.0","iobroker.simple-api":"2.8.0","iobroker.socketio":"6.7.0","iobroker.switchbot-hub":"github:DrozmotiX/ioBroker.switchbot-hub#de8c1ad97edafedb16cbbb2c6dc14b032848df8e","iobroker.tado":"0.5.4","iobroker.tankerkoenig":"3.4.0","iobroker.tr-064":"4.3.0","iobroker.tradfri":"3.1.3","iobroker.trashschedule":"3.3.0","iobroker.tuya":"3.15.0","iobroker.vis-2":"2.9.64","iobroker.weather-warnings":"0.6.7","iobroker.web":"6.2.6","iobroker.whatsapp-cmb":"0.3.0","iobroker.ws":"2.6.1","iobroker.zigbee":"1.10.3"}}
                                      echad@chet:~ $
                                        @foxriver76
                                        echad@chet:~ $
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #179
                                        @thomas-braun gibt es den folder /opt/iobroker/node_modules/@iobroker-javascript.0/playactor ?
                                          #180
                                          @foxriver76
                                          Ja, den gibt es:
                                          echad@chet:~ $ ls -lah /opt/iobroker/node_modules/@iobroker-javascript.0/
                                          total 48K
                                          drwxrwxr-x+   3 iobroker iobroker 4.0K May 22 13:03 .
                                          drwxrwxr-x+ 907 iobroker iobroker  36K May 26 09:38 ..
                                          drwxrwxr-x+   4 iobroker iobroker 4.0K May 22 13:03 playactor
                                          echad@chet:~ $ ls -lah /opt/iobroker/node_modules/@iobroker-javascript.0/playactor/
                                          total 24K
                                          drwxrwxr-x+  4 iobroker iobroker 4.0K May 22 13:03 .
                                          drwxrwxr-x+  3 iobroker iobroker 4.0K May 22 13:03 ..
                                          -rw-rwxr--+  1 iobroker iobroker  992 May 22 13:03 README.md
                                          drwxrwxr-x+ 11 iobroker iobroker 4.0K May 22 13:03 dist
                                          drwxrwxr-x+ 16 iobroker iobroker 4.0K May 25 09:58 node_modules
                                          -rw-rwxr--+  1 iobroker iobroker 2.0K May 22 13:03 package.json
                                          echad@chet:~ $
