  4. [gelöst] Mehrfache gleiche Fehlermeldungen?
11 Beiträge 4 Kommentatoren 393 Aufrufe 4 Beobachtet
    Beowolf
    schrieb am zuletzt editiert von Beowolf
    ich bekomme immer mehrfach die gleichen Fehlermeldung/Hinweise hintereinander.
    Woran kann das liegen?
    host.raspberrypi
    	2024-05-22 10:30:12.333	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    ical.0
    	2024-05-22 10:30:11.815	info	Terminated (NO_ERROR): Without reason
    host.raspberrypi
    	2024-05-22 10:30:08.341	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
    pegelalarm.0
    	2024-05-22 10:30:07.828	info	Terminated (NO_ERROR): Without reason
    ical.0
    	2024-05-22 10:30:06.339	info	processing URL: termine Einträge manuell gelöscht.
    ical.0
    	2024-05-22 10:30:05.932	info	processing URL: calendar1 Einträge manuell gelöscht.
    ical.0
    	2024-05-22 10:30:05.221	info	starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
    host.raspberrypi
    	2024-05-22 10:30:04.050	info	instance system.adapter.ical.0 started with pid 19149
    pegelalarm.0
    	2024-05-22 10:30:01.312	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
    host.raspberrypi
    	2024-05-22 10:30:00.033	info	instance system.adapter.pegelalarm.0 started with pid 19109
    host.raspberrypi
    	2024-05-22 10:45:08.106	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
    pegelalarm.0
    	2024-05-22 10:45:07.593	info	Terminated (NO_ERROR): Without reason
    pegelalarm.0
    	2024-05-22 10:45:01.057	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
    host.raspberrypi
    	2024-05-22 10:45:00.027	info	instance system.adapter.pegelalarm.0 started with pid 19974
    admin.0
    	2024-05-22 10:41:42.936	info	==> Connected system.user.admin from ::ffff:192.168.49.12
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    admin.0
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    admin.0
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    admin.0
    admin.0
    	2024-05-22 10:41:14.907	info	<== Disconnect system.user.admin from ::ffff:192.168.49.12 admin
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
    • B Beowolf
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      host.raspberrypi
      pegelalarm.0
      pegelalarm.0
      host.raspberrypi
      admin.0
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      admin.0
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      admin.0
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      admin.0
      admin.0
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      host.raspberrypi
      ical.0
      host.raspberrypi
      pegelalarm.0
      ical.0
      ical.0
      ical.0
      host.raspberrypi
      pegelalarm.0
      host.raspberrypi
      sigi234S Online
      sigi234S Online
      sigi234
      @beowolf
      Persönliche Daten rausnehmen!!!
      Immer Daten sichern!
        Beowolf
        Danke. So ist es besser.
        • B Beowolf
          sigi234S Online
          sigi234S Online
          sigi234
          @beowolf sagte in Mehrfache gleiche Fehlermeldungen?:
          Gut, ich sehe da aber keine Fehler sind nur Info
            Beowolf
            Nee, es geht nicht um die Fehler/Hinweise. Es geht um das, das die immer wieder hintereinander kommen. Also mehrfach die selbe Zeit.
            Die Meldungen hier gehen um
            los, bis
            Also die selben Meldungen ein paar mal hintereinander.
            • B Beowolf
              los, bis
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @beowolf LOG löschen:
              Browserfenster neu laden.
              Lehrling seit 1975 !!!
              B 1 Antwort Letzte Antwort
              • DJMarc75D DJMarc75
                Beowolf
                @djmarc75 sagte in Mehrfache gleiche Fehlermeldungen?:
                Das habe ich auch schon versucht. Hat aber nicht funktioniert. Hätte mich auch gewundert. Die Meldungen kommen ja vom ioBroker.
                • B Beowolf
                  @beowolf
                  Schau dir das LogFile im Terminal an:
                  iob logs | uniq
                  Sind da auch doppelte Einträge drin?
                  Wenn nein, dann hat dich die GUI mal wieder angeschwindelt.
                    Beowolf
                    Habe jetzt mal dieses gemacht.
                    iob nodejs-update
                    Mal schauen ob jetzt Ruhe ist.
                    • B Beowolf
                      iob nodejs-update
                      @beowolf
                      Abgesehen davon, dass ein aktuelles nodejs immer eine gute Idee ist:
                      Sollte mit der üblichen Systempflege via
                      sudo apt update
                      sudo apt full-upgrade
                      mitlaufen. Doppelte Einträge in Logs verhindert das allerdings auch nicht.
                        Beowolf
                        Ok. Habe ich jetzt auch gemacht. Jetzt scheint Ruhe zu sein. 👍
