  4. [gelöst] Mehrfache gleiche Fehlermeldungen?
11 Beiträge 4 Kommentatoren 393 Aufrufe 4 Beobachtet
  • B Beowolf
    ich bekomme immer mehrfach die gleichen Fehlermeldung/Hinweise hintereinander.
    Woran kann das liegen?
    host.raspberrypi
    	2024-05-22 10:30:12.333	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    ical.0
    	2024-05-22 10:30:11.815	info	Terminated (NO_ERROR): Without reason
    host.raspberrypi
    	2024-05-22 10:30:08.341	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
    pegelalarm.0
    	2024-05-22 10:30:07.828	info	Terminated (NO_ERROR): Without reason
    ical.0
    	2024-05-22 10:30:06.339	info	processing URL: termine Einträge manuell gelöscht.
    ical.0
    	2024-05-22 10:30:05.932	info	processing URL: calendar1 Einträge manuell gelöscht.
    ical.0
    	2024-05-22 10:30:05.221	info	starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
    host.raspberrypi
    	2024-05-22 10:30:04.050	info	instance system.adapter.ical.0 started with pid 19149
    pegelalarm.0
    	2024-05-22 10:30:01.312	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
    host.raspberrypi
    	2024-05-22 10:30:00.033	info	instance system.adapter.pegelalarm.0 started with pid 19109
    host.raspberrypi
    	2024-05-22 10:45:08.106	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
    pegelalarm.0
    	2024-05-22 10:45:07.593	info	Terminated (NO_ERROR): Without reason
    pegelalarm.0
    	2024-05-22 10:45:01.057	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.20.2, js-controller: 5.0.19
    host.raspberrypi
    	2024-05-22 10:45:00.027	info	instance system.adapter.pegelalarm.0 started with pid 19974
    admin.0
    	2024-05-22 10:41:42.936	info	==> Connected system.user.admin from ::ffff:192.168.49.12
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    admin.0
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    admin.0
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    admin.0
    admin.0
    	2024-05-22 10:41:14.907	info	<== Disconnect system.user.admin from ::ffff:192.168.49.12 admin
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    host.raspberrypi
    ical.0
    host.raspberrypi
    pegelalarm.0
    ical.0
    ical.0
    ical.0
    host.raspberrypi
    pegelalarm.0
    host.raspberrypi
    sigi234S Online
    sigi234S Online
    @beowolf
    Persönliche Daten rausnehmen!!!
      Beowolf
      Danke. So ist es besser.
      • B Beowolf
        sigi234S Online
        sigi234S Online
        @beowolf sagte in Mehrfache gleiche Fehlermeldungen?:
        Gut, ich sehe da aber keine Fehler sind nur Info
          Beowolf
          Nee, es geht nicht um die Fehler/Hinweise. Es geht um das, das die immer wieder hintereinander kommen. Also mehrfach die selbe Zeit.
          Die Meldungen hier gehen um
          los, bis
          Also die selben Meldungen ein paar mal hintereinander.
          • B Beowolf
            los, bis
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @beowolf LOG löschen:
            Browserfenster neu laden.
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              Beowolf
              @djmarc75 sagte in Mehrfache gleiche Fehlermeldungen?:
              Das habe ich auch schon versucht. Hat aber nicht funktioniert. Hätte mich auch gewundert. Die Meldungen kommen ja vom ioBroker.
              • B Beowolf
                @beowolf
                Schau dir das LogFile im Terminal an:
                iob logs | uniq
                Sind da auch doppelte Einträge drin?
                Wenn nein, dann hat dich die GUI mal wieder angeschwindelt.
                  Beowolf
                  Habe jetzt mal dieses gemacht.
                  iob nodejs-update
                  Mal schauen ob jetzt Ruhe ist.
                  • B Beowolf
                    iob nodejs-update
                    @beowolf
                    Abgesehen davon, dass ein aktuelles nodejs immer eine gute Idee ist:
                    Sollte mit der üblichen Systempflege via
                    sudo apt update
                    sudo apt full-upgrade
                    mitlaufen. Doppelte Einträge in Logs verhindert das allerdings auch nicht.
                      Beowolf
                      Ok. Habe ich jetzt auch gemacht. Jetzt scheint Ruhe zu sein. 👍
