  4. Homebridge Fehler Code 243
    1.9k
    1.5k
41 Beiträge 4 Kommentatoren 8.3k Aufrufe 3 Beobachtet
    @marcelinho
    Bei den Updates war ein Kernel-Update dabei:
    Neustart der Kiste erforderlich!
    iob stop
    sudo reboot
    M
    M
    marcelinho
    @thomas-braun wie besprochen die neue Auslesung / Fehler Homebridge bleibt bestehen:
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     15:54:39 up 22:08,  3 users,  load average: 0.21, 0.31, 0.27
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-04-24 15:54:39 CEST
               Universal time: Wed 2024-04-24 13:54:39 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        2.9G        288M         86K        858M        1.1G
    Swap:           104M         15M         89M
    Total:          4.1G        2.9G        378M
             3793 M total memory
             2774 M used memory
             2927 M active memory
              374 M inactive memory
              274 M free memory
               93 M buffer memory
              726 M swap cache
               99 M total swap
               14 M used swap
               85 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
    [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
    [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
    [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    11G     /var/
    8.9G    /var/lib
    8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
    Archived and active journals take up 739.9M in the file system.
    /opt/iobroker/backups:
    215M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    320M    /opt/iobroker/iobroker-data/
    191M    /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    52M     /opt/iobroker/iobroker-data/backup-objects
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    32M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
    9.8M    /opt/iobroker/iobroker-data/states.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi        -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi        -  enabled
    + system.adapter.daikin.0                 : daikin                : raspberrypi        -  enabled
    + system.adapter.daikin.1                 : daikin                : raspberrypi        -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi        -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi        -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi        -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi        -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.myenergi.0               : myenergi              : raspberrypi        -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smart-eq.0               : smart-eq              : raspberrypi        -  enabled
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi        -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi        -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "node-red"     : 5.2.0    , installed 5.2.0
    Adapter    "openhab"      : 1.1.0    , installed 1.1.0
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
    Objects and States
    Objects:        14989
    States:         13387
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:8 https://repo.homebridge.io stable InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
    tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
    tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
    tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
    tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
    tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          343770     9169/cupsd
    tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
    tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
    tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
    tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
    tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          343769     9169/cupsd
    tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
    tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
    tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
    tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
    tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
    tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
    tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
    tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
    tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
    udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          343790     9192/cups-browsed
    udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
    udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
    udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
    2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
    2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
    2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
    2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
    2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
    2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
    2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
    2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
    2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
    • M marcelinho
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M         15M         89M
               3793 M total memory
               2774 M used memory
                274 M free memory
                 93 M buffer memory
                726 M swap cache
                 99 M total swap
                 14 M used swap
                 85 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      11G     /var/
      8.9G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        14989
      States:         13387
      Pending Updates: 3
      Thomas BraunT
      Thomas BraunT
      @marcelinho sagte in Homebridge Fehler Code 243:
      Pending Updates: 3
      Hau die noch rein.
      Und deiner influxdb geht es immer noch nicht so richtig gut, würde ich sagen.
      Wenn die da im Millisekundenbereich auf Fehler läuft kann das nicht gesund sein.
      Zu Homebridge: Mit ist immer noch nicht klar was genau du da machen willst.
        Pending Updates: 3
        Hau die noch rein.
        M
        M
        marcelinho
        @thomas-braun mit sudo apt update & upgrade sollte das gehen oder?
        Ich möchte Homebridge aktualisieren bzw alte plugins die nicht mehr benötigt werden löschen.
        Influxdb habe ich gestern mit @Marc-Berg bereinigt. Wüsste nicht was da falsch gehen sollte in grafana wird alles korrekt angezeigt.
        Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
        • M marcelinho
          Thomas BraunT
          Thomas BraunT
          Dann schau in das Log:
          Sieht für mich nicht gesund aus. Insbesondere nicht in der Frequenz mit der da Zeug geloggt wird. Das bläst dir alleine das Logfile in kürzester Zeit auf unnötige Größen auf.
          Homebridge über den ham-Adapter? Der ist aber gar nicht installiert bei dir.
          • M marcelinho
            Marc BergM
            Marc BergM
            Marc Berg
            Jain. Du hattest den Speicherzeitraum der InfluxDB auf 90 Tage gesetzt und wir haben gesagt, dass die ungewollt geloggten Daten nach 90 Tagen endgültig raus sind.
            Du könntest des Speicherzeitraum jetzt auch noch weiter verkürzen, um den Effekt zu beschleunigen.
            Weiterhin kannst du in den Datenpunkteinstellungen des InfluxDB Adapters prüfen, ob du weniger Daten wegschreibst, indem du z.B. die Blockierzeit auf 30 Sekunden setzt.
              M
              M
              marcelinho
              @thomas-braun said in Homebridge Fehler Code 243:
              ham-Adapter
              Homebridge habe ich über die SD-Karte über ein Image installiert gehabt
              https://smartapfel.de/homebridge/installieren/
              • Marc BergM Marc Berg
                M
                M
                marcelinho
                @marc-berg ich habe im influx.db Adapter nun auch 90 Tage geändert und die Blockzeit auf 30 gesetzt - ist dies so korrekt?Screenshot 2024-04-25 075854.png
                • M marcelinho
                  ham-Adapter
                  Thomas BraunT
                  Thomas BraunT
                  @marcelinho
                  Und wo ist da jetzt die Verbindung zum ioBroker?
                  Marc BergM M 2 Antworten Letzte Antwort
                  • M marcelinho
                    Marc BergM
                    Marc BergM
                    Marc Berg
                    Ob du die Einstellung für die Vorhaltezeit in der Instanz des Adapters änderst oder direkt in der Datenbank-Oberfläche ist völlig egal, das funktioniert beides.
                    Zur Blockzeit: Du hast jetzt lediglich die "Standardeinstellung" geändert, die angezogen wird, wenn du neue Datenpunkte mit der InfluxDB verbindest. Dies hat keine Auswirkungen auf schon bestehende Datenpunkte.
                    Du solltest also Datenpunkt für Datenpunkt durchgehen und jeweils schauen, ob du nur geänderte Werte aufzeichnen willst, ob du eine Blockzeit verwendest oder nur Änderungen protokollierst, wenn sich der Wert um x ändert.
                    Das kann man nicht pauschal empfehlen, es hängt einfach davon ab, welche Daten jeweils in welchen Intervallen reinfliegen. Ziel sollte jedenfalls sein, die Menge an Daten, die (vielleicht unnötigerweise) in die Datenbank geschrieben wird, auf ein sinnvolles Maß zu reduzieren.
                    EDIT: Außerdem wird die Blockzeit in Millisekunden angegeben
                      @marcelinho
                      Marc BergM
                      Marc BergM
                      Marc Berg
                      @thomas-braun sagte in Homebridge Fehler Code 243:
                      Im Tab "DB Settings"!? :-)
                        M
                        M
                        marcelinho
                        @marc-berg jetzt sieht es wohl besser aus, habe alle Influxdb Datenpunkte mit Millisekunden angepasst:
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         09:23:33 up 1 day, 15:37,  3 users,  load average: 0.27, 0.37, 0.33
                        CPU threads: 4
                        Current issues:
                                       Local time: Thu 2024-04-25 09:23:33 CEST
                                   Universal time: Thu 2024-04-25 07:23:33 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.0G        2.9G        827M         28K        296M        1.0G
                        Swap:           104M        104M        278K
                        Total:          4.1G        3.0G        827M
                                 3793 M total memory
                                 2796 M used memory
                                 2004 M active memory
                                  808 M inactive memory
                                  788 M free memory
                                   16 M buffer memory
                                  266 M swap cache
                                   99 M total swap
                                   99 M used swap
                                    0 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        11G     /var/
                        8.9G    /var/lib
                        217M    /opt/iobroker/backups/
                        303M    /opt/iobroker/iobroker-data/
                        18M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                        USB-Devices by-id:
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.16
                        javascript:     7.8.0
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        14991
                        States:         13387
                        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                        Pending Updates: 3
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1585299    38874/cupsd
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1585298    38874/cupsd
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1586228    38876/cups-browsed
                        2024-04-25 09:10:38.129  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.gas_savings.total_spent.raw_value" has to be type "number" but received type "string"
                        2024-04-25 09:10:38.133  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.total_spent.raw_value" has to be type "number" but received type "string"
                        2024-04-25 09:11:45.291  - info: influxdb.0 (47993) enabled logging of PV Tagesertrag, Alias=true
                        2024-04-25 09:12:30.314  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTag, Alias=true
                        2024-04-25 09:12:50.951  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTag, Alias=true
                        2024-04-25 09:13:25.909  - warn: influxdb.0 (47993) Error in query "from(bucket: "admin")  |> range(start: 1999-12-31T23:00:00.000Z, stop: 2024-04-25T07:12:55.411Z) |> filter(fn: (r) => r["_measurement"] == "BatterieEntladung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns:["_time"], desc: false) |> limit(n: 500)": RequestTimedOutError: Request timed out
                        2024-04-25 09:14:14.696  - info: influxdb.0 (47993) enabled logging of BatterieEntladung, Alias=true
                        2024-04-25 09:14:23.823  - info: influxdb.0 (47993) enabled logging of BatterieProzent, Alias=true
                        2024-04-25 09:14:32.228  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTotal, Alias=true
                        2024-04-25 09:14:38.869  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTotal, Alias=true
                        2024-04-25 09:14:42.461  - info: shelly.0 (1561) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
                        2024-04-25 09:14:57.799  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Accumulated_Energy_Yield, Alias=false
                        2024-04-25 09:15:10.195  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Active_Power, Alias=false
                        2024-04-25 09:15:16.964  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Daily_Energy_Yield, Alias=false
                        2024-04-25 09:15:31.414  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Input_Power, Alias=false
                        2024-04-25 09:15:42.478  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Internal_Temperature, Alias=false
                        2024-04-25 09:18:36.103  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_Euro, Alias=true
                        2024-04-25 09:18:42.306  - info: influxdb.0 (47993) enabled logging of Hausspeicher_gespart, Alias=true
                        2024-04-25 09:18:48.544  - info: influxdb.0 (47993) enabled logging of Netzbezug_Tag_Euro, Alias=true
                        2024-04-25 09:19:00.758  - info: influxdb.0 (47993) enabled logging of Netzeinspeisung_Tag_Euro, Alias=true
                        2024-04-25 09:19:13.266  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_kWh, Alias=true
                        2024-04-25 09:19:20.297  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, Alias=false
                        2024-04-25 09:19:26.029  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_W, Alias=false
                        2024-04-25 09:19:34.118  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_Tag_kWh, Alias=false
                        2024-04-25 09:19:43.416  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_W, Alias=false
                          @marcelinho
                          M
                          M
                          marcelinho
                          @thomas-braun hast du zufällig noch einen Vorschlag was ich gegen den Fehler machen könnte?
                          • M marcelinho
                            Thomas BraunT
                            Thomas BraunT
                            @marcelinho
                            Nein. Mit GUIs hab ich aber auch wenig am Hut. Und mit Homebridge auch nicht.
                            • M marcelinho
                              ich kann keine Plugins mehr löschen bzw. Homebridge updaten von v1.7.0 --> v1.8.0
                              Kann mir jemand bitte behilflich sein? Danke vorab.
                              Folgender Fehler:
                              USER: homebridge
                              DIR: /var/lib/homebridge
                              CMD: npm install --save homebridge@1.8.0
                              npm ERR! code EACCES
                              npm ERR! syscall mkdir
                              npm ERR! path /nonexistent
                              npm ERR! errno -13
                              npm ERR! Error: EACCES: permission denied, mkdir '/nonexistent'
                              npm ERR! [Error: EACCES: permission denied, mkdir '/nonexistent'] {
                              npm ERR! errno: -13,
                              npm ERR! code: 'EACCES',
                              npm ERR! syscall: 'mkdir',
                              npm ERR! path: '/nonexistent'
                              npm ERR! }
                              npm ERR!
                              npm ERR! The operation was rejected by your operating system.
                              npm ERR! It is likely you do not have the permissions to access this file as the current user
                              npm ERR!
                              npm ERR! If you believe this might be a permissions issue, please double-check the
                              npm ERR! permissions of the file and its containing directories, or try running
                              npm ERR! the command again as root/Administrator.
                              npm ERR! Log files were not written due to an error writing to the directory: /nonexistent/.npm/_logs
                              npm ERR! You can rerun the command with --loglevel=verbose to see the logs in your terminal
                              Operation failed with code 243.
                              You can download this log file for future reference.
                              See https://github.com/homebridge/homebridge-config-ui-x/wiki/Troubleshooting for help.
                              M
                              M
                              marcelinho
                              habe nun folgenden Fehler:
                              npm ERR! syscall rename
                              npm ERR! path /usr/local/bin/homebridge
                              npm ERR! dest /usr/local/bin/.homebridge-kaN4ImAr
                              npm ERR! errno -13
                              npm ERR! Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'
                              npm ERR! [Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'] {
                              npm ERR! syscall: 'rename',
                              npm ERR! path: '/usr/local/bin/homebridge',
                              npm ERR! dest: '/usr/local/bin/.homebridge-kaN4ImAr'
                              npm ERR! }
                              npm ERR!
                              npm ERR!
                              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-05-06T15_54_11_806Z-debug-0.log
                              jemand eine Idee?
                              • M marcelinho
                                npm ERR! errno -13
                                npm ERR! }
                                npm ERR!
                                npm ERR!
                                jemand eine Idee?
                                Thomas BraunT
                                Thomas BraunT
                                jemand eine Idee?
                                Du könntest dazu schreiben welche Aktion mit welchem User zu diesen Meldungen führt.
                                Und welche Berechtigungen für homebridge erforderlich sind.
                                ls -lah  /usr/local/bin/homebridge
                                  jemand eine Idee?
                                  M
                                  M
                                  marcelinho
                                  @thomas-braun wenn ich den Befehl in der Konsole eingebe kommt folgendes:
                                  pi@raspberrypi:~ $ ls -lah /usr/local/bin/homebridge
                                  lrwxrwxrwx 1 root root 45 May 6 17:51 /usr/local/bin/homebridge -> ../lib/node_ modules/homebridge/bin/homebridge
                                  ich bin etwas überfragt, weis nicht genau was du meinst.
                                  • M marcelinho
                                    Thomas BraunT
                                    Thomas BraunT
                                    @marcelinho
                                    Und
                                    ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                                    sagt?
                                    Konsolentext bitte immer in CodeTags setzen. Kann man besser lesen. Danke.
                                    Edit: c&p Fehler
                                      @marcelinho
                                      Und
                                      sagt?
                                      Edit: c&p Fehler
                                      M
                                      M
                                      marcelinho
                                      @thomas-braun ok sorry
                                      es kommt folgendes:
                                      pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_ modules/homebridge/bin/homebridg                                    e
                                      ls: cannot access '/usr/local/lib/node_': No such file or directory
                                      ls: cannot access 'modules/homebridge/bin/homebridge': No such file or directory
                                      • M marcelinho
                                        es kommt folgendes:
                                        DJMarc75D
                                        DJMarc75D
                                        DJMarc75
                                        @marcelinho
                                        war ein leerzeichen drin
                                        Lehrling seit 1975 !!!
                                        • DJMarc75D DJMarc75
                                          @marcelinho
                                          M
                                          M
                                          marcelinho
                                          @djmarc75 danke anbei neu
                                          pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                                          -rwxr-xr-x 1 pi root 349 May  6 17:51 /usr/local/lib/node_modules/homebridge/bin               /homebridge
                                          pi@raspberrypi:~ $
                                          83.8k
                                          1.4m
